Application Signature V7-APR-1.0.160
Release time:2023-08-05
HomeSupportResource CenterSecuritySignature Database ServicesSignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-APR-1.0.160.dat 2.67 MB
Version number
V7-APR-1.0.160
MD5 number
42323fe94b45f3db85bbf993e365fc25
Update time
2023-07-31
New protocol list
Modified protocols:    [1]
----YueWen
Update protocol list
----AnJuKe
----SouFangWang
----ELeMe
----MIAppStore
----SinaNews
----MaoYanDianYing
----DouBanYueDu
----TuDou
----BaiduVideo
----MoGuJie
----ETao
----LanRenZuoYe
----XiaoXiangShuYuan
----MeiYanXiangJi
----JinRiTouTiao
Modified protocols:    [2]
----HanJuTV
----ChinaEasternAirlines
----JiaoTongYinHang
----FangTianXia
----DeDao
----DiWuRenGe
----HuaWeiYingYongShiChang
----QingTingFM
----QuTouTiao
----JiaKaoBaoDian
----39yst
----DaYiMa
----ZhengQuanShiBaoWang
----2345YingShiDaQuan
----DJDuoDuo
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9533 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1528 predefined applications can be generated
  • Become a Partner
  • Partner Resources
