| Title | Size | Downloads |
| V7-APR-1.0.156.dat | 2.67 MB |
Version number
V7-APR-1.0.156
MD5 number
c6663a00cf6a4e7979dbf1b8e9505b75
Update time
2023-05-26
New protocol list
Modified protocols: [2]
----NezCn
----UserVoice
----Veritas
----Vidyo
----Workday
----XAudioPro
----Zine
----Zoho(ZohoMeeting requires cooperation from Zoho to block it)
----BoSiTongRuanJian
----ChangJieTong
----BaiShanYunKeJi
----BaiDuAIKaiFangPingTai
----ALiFanYi
----SiChuanAir
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9503 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1526 predefined applications can be generated
