07-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10007-Layer 3 - IP Services
10-HH3C-IPV6-ADDRESS-MIB
10-HH3C-IPV6-ADDRESS-MIB 44.84 KB
About this MIB
Use this MIB to obtain and configure IPv6 addresses.
MIB file name
hh3c-ipv6-address.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpv6AddrMIB(71)
Tabular objects
hh3cIpv6AddrSetTable
About this table
This table configures an IPv6 addresses.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cIpv6AddrSetIfIndex, hh3cIpv6AddrSetAddrType, and hh3cIpv6AddrSetAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpv6AddrSetIfIndex (1.3.6.1.4.1.25506.2.71.1.1.1.1.1)
not-accessible
Integer32
Integer32 (1..2147483)
Interface index.
As per the MIB.
hh3cIpv6AddrSetAddrType (1.3.6.1.4.1.25506.2.71.1.1.1.1.2)
not-accessible
InetAddressType
ipv6(2)
IP address version.
As per the MIB.
hh3cIpv6AddrSetAddr (1.3.6.1.4.1.25506.2.71.1.1.1.1.3)
not-accessible
InetAddress
OCTET STRING (0..255)
IP address.
As per the MIB.
hh3cIpv6AddrSetPfxLength (1.3.6.1.4.1.25506.2.71.1.1.1.1.4)
read-create
Integer32
Integer32 (1..128)
IPv6 address subnet prefix length.
As per the MIB.
hh3cIpv6AddrSetSourceType (1.3.6.1.4.1.25506.2.71.1.1.1.1.5)
read-create
INTEGER
assignedIp(1)
assignedEUI64Ip(2)
assignedLinklocalIp(3)
Source type of the IPv6 address.
As per the MIB.
hh3cIpv6AddrSetRowStatus (1.3.6.1.4.1.25506.2.71.1.1.1.1.6)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Create a new row or delete an existing row.
As per the MIB.
hh3cIpv6AddrReadTable
About this table
This table displays IPv6 addresses.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cIpv6AddrReadIfIndex, hh3cIpv6AddrReadAddrType, and hh3cIpv6AddrReadAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpv6AddrReadIfIndex (1.3.6.1.4.1.25506.2.71.1.1.2.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Interface index.
As per the MIB.
hh3cIpv6AddrReadAddrType (1.3.6.1.4.1.25506.2.71.1.1.2.1.2)
not-accessible
InetAddressType
ipv6(2)
IP address version.
As per the MIB.
hh3cIpv6AddrReadAddr (1.3.6.1.4.1.25506.2.71.1.1.2.1.3)
not-accessible
InetAddress
IPv6 address.
As per the MIB.
hh3cIpv6AddrReadPfxLength (1.3.6.1.4.1.25506.2.71.1.1.2.1.4)
read-only
Integer32
Integer32 (1..128)
IPv6 address prefix length.
As per the MIB.
hh3cIpv6AddrReadSourceType (1.3.6.1.4.1.25506.2.71.1.1.2.1.5)
read-only
INTEGER
assignedIp(1)
assignedEUI64Ip(2),
assignedAutoIp(3)
autoIp(4)
dhcpv6(5)
negotiate(6)
cluster(7)
As per the MIB.
hh3cIpv6AddrReadCatalog (1.3.6.1.4.1.25506.2.71.1.1.2.1.6)
read-only
INTEGER
nodelocal(1)
linklocal(2)
sitelocal(3)
orglocal(4)
global(5)
Type of the IPv6 address.
As per the MIB.
