07-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10007-Layer 3 - IP Services
09-HH3C-IPFW-MIB
09-HH3C-IPFW-MIB 69.95 KB
HH3C-IPFW-MIB
About this MIB
Use this MIB to obtain IP forwarding information and configure IP forwarding.
MIB file name
hh3c-ipfw.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpfw(211)
Tabular objects
hh3cIpfwSpeedTable
About this table
This table obtains IPv4 and IPv6 packet forwarding rate information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cSystemDiagInfoIndex and hh3cIpSpeedStatIpType.
Object (OID)
Access
Value range
Implementation
hh3cIpfwSpeedStatIfIndex (1.3.6.1.4.1.25506.2.211.1.1.1.1)
not-accessible
InterfaceIndex
Integer32 (1..2147483647)
Interface index.
As per the MIB.
hh3cIpfwSpeedStatIpType (1.3.6.1.4.1.25506.2.211.1.1.1.2)
not-accessible
INTEGER
ipv4(1),
ipv6(2)
IP protocol type.
As per the MIB.
hh3cIpfwSpeedStatInterval (1.3.6.1.4.1.25506.2.211.1.1.1.3)
read-only
Uinteger32
Standard MIB values.
Packet statistics collection period.
As per the MIB.
hh3cIpfwSpeedStatInPkts (1.3.6.1.4.1.25506.2.211.1.1.1.4)
read-only
Counter64
Incoming packet rate.
As per the MIB.
hh3cIpfwSpeedStatOutPkts (1.3.6.1.4.1.25506.2.211.1.1.1.5)
read-only
Counter64
Outgoing packet rate.
As per the MIB.
hh3cIpfwSpeedStatInBytes (1.3.6.1.4.1.25506.2.211.1.1.1.6)
read-only
Counter64
Incoming byte rate.
As per the MIB.
hh3cIpfwSpeedStatOutBytes (1.3.6.1.4.1.25506.2.211.1.1.1.7)
read-only
Counter64
Outgoing byte rate.
As per the MIB.
hh3cIpfwSpeedStatInBits (1.3.6.1.4.1.25506.2.211.1.1.1.8)
read-only
Counter64
Incoming bit rate.
As per the MIB.
hh3cIpfwSpeedStatOutBits (1.3.6.1.4.1.25506.2.211.1.1.1.9)
read-only
Counter64
Outgoing bit rate.
As per the MIB.
Notifications
hh3cIpfwPktNumExcAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.211.2.0.1
Disordered packets detected.
Error
Warning
1.3.6.1.4.1.25506.2.211.2.0.2(hh3cFragPktNumExcAlarmResume)
ON
This notification is generated when the length of the received packet queue exceeds the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable ip-forwarding command.
OFF
CLI: Use the undo snmp-agent trap enable ip-forwarding command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.211.2.1.1 (hh3cIpfwIfIndex)
Index of the interface from which the packets are received.
Yes
InterfaceIndex
1.3.6.1.4.1.25506.2.211.2.1.2 (hh3cIpfwPeerAddress)
IP address of the interface from which the packets are received.
No
OCTET STRING
OCTET STRING  (0..255)
1.3.6.1.4.1.25506.2.211.2.1.3 (hh3cIpfwInterfaceName)
Name of the interface from which the packets are received.
No
OCTET STRING
Recommended action
Examine if packet-based attacks exist in the network.
hh3cIpfwPktNumExcAlarmResume
Basic information
OID
Event
Severity
Default status
Disordered packet alarm removal
Informational
Event
ON
This notification is generated when the threshold exceeding alarm (packet queue length threshold) is removed.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
InterfaceIndex
No
OCTET STRING
No
OCTET STRING
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
