07-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10007-Layer 3 - IP Services
02-HH3C-ARP-SUPPRESSION-MIB
02-HH3C-ARP-SUPPRESSION-MIB 38.21 KB
About this MIB
Use this MIB to realize the ARP suppression feature.
MIB file name
hh3c-arp-suppression.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPSuppression(220)
Tabular objects
hh3cARPSuppressionVsiTable
About this table
This table obtains ARP suppression entries based on VSIs.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cARPSuppressionChassis, hh3cARPSuppressionSlot, hh3cARPSuppressionVsiName, and hh3cARPSuppressionIpAddr.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.220.1.1.1)
not-accessible
Unsigned32
Standard MIB values.
Chassis number.
As per the MIB.
(1.3.6.1.4.1.25506.2.220.1.1.2)
not-accessible
Unsigned32
Slot number.
As per the MIB.
(1.3.6.1.4.1.25506.2.220.1.1.3)
not-accessible
DisplayString
OCTET STRING(31)
VSI instance name.
As per the MIB.
(1.3.6.1.4.1.25506.2.220.1.1.4)
not-accessible
IpAddress
IP address.
As per the MIB.
hh3cARPSuppressionMacAddr
(1.3.6.1.4.1.25506.2.220.1.1.5)
read-only
MacAddress
OCTET STRING (6)
MAC address.
As per the MIB.
hh3cARPSuppressionLinkID
(1.3.6.1.4.1.25506.2.220.1.1.6)
read-only
Unsigned32
Link ID.
As per the MIB.
hh3cARPSuppressionAging
(1.3.6.1.4.1.25506.2.220.1.1.7)
read-only
Unsigned32
Aging timer.
As per the MIB.
