03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10003-Device Management
09-HH3C-POWER-ETH-EXT-MIB
09-HH3C-POWER-ETH-EXT-MIB 58.80 KB
About this MIB
This MIB is an extension of POWER-ETHERNET-MIB. To implement this MIB, you must first implement relevant parts of POWER-ETHERNET-MIB, such as pethMainPseTable.
This MIB adds some objects which POWER-ETHERNET-MIB does not contain to monitor some specific aspects of entities for better and comprehensive management on devices.
MIB file name
hh3c-power-eth-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPowerEthernetExt(14)
Scalar objects
hh3cPsePolicyMode
Object (OID)
Access
Value range
Implementation
hh3cPsePolicyMode (1.3.6.1.4.1.25506.2.14.9)
read-write
INTEGER
disabled(1), priority(2)
PSE power management policy mode.
As per the MIB.
hh3cPDPolicyMode
Object (OID)
Access
Value range
Implementation
hh3cPDPolicyMode (1.3.6.1.4.1.25506.2.14.10)
read-write
INTEGER
PD power management policy mode.
As per the MIB.
Tabular objects
hh3cPsePortTable
About this table
Use this table to manage PSE ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are pethPsePortGroupIndex and pethPsePortIndex.
Object (OID)
Access
Value range
Implementation
hh3cPsePortFaultDescription (1.3.6.1.4.1.25506.2.14.1.1.2)
read-write
DisplayString
OCTET STRING (0..255)
Description about the precise PoE hardware state causing the pethPsePortDetectionStatus object to be in the fault state.
Not supported
hh3cPsePortPeakPower (1.3.6.1.4.1.25506.2.14.1.1.3)
read-write
Integer32
Standard MIB values.
Peak power of the PSE port, in milliwatts.
As per the MIB.
You can set the value to 0. Other values are not effective.
hh3cPsePortAveragePower (1.3.6.1.4.1.25506.2.14.1.1.4)
read-write
Integer32
Average power of the PSE port, in milliwatts.
As per the MIB.
hh3cPsePortCurrentPower (1.3.6.1.4.1.25506.2.14.1.1.5)
read-only
Integer32
Current power of the PSE port, in milliwatts.
As per the MIB.
hh3cPsePortPowerLimit (1.3.6.1.4.1.25506.2.14.1.1.6)
read-write
Integer32
Power limit for the PSE port, in milliwatts.
As per the MIB.
hh3cPsePortProfileIndex (1.3.6.1.4.1.25506.2.14.1.1.7)
read-write
Integer32
Integer32 (0..100)
Index of the power profile currently associated with this port.
As per the MIB.
hh3cMainPseTable
About this table
Use this table to manage PSEs.
This table is not supported on non-default MDCs.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is pethPsePortGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cMainPsePowerLimit (1.3.6.1.4.1.25506.2.14.2.1.1
read-write
Integer32
Power limit for the PSE, in watts.
As per the MIB.
hh3cMainPseAveragePower (1.3.6.1.4.1.25506.2.14.2.1.2)
read-write
Integer32
Average power of the PSE, in watts.
As per the MIB.
hh3cMainPsePeakPower (1.3.6.1.4.1.25506.2.14.2.1.3)
read-write
Integer32
Peak power of the PSE, in watts.
As per the MIB.
hh3cMainGuaranteedPowerRemaining (1.3.6.1.4.1.25506.2.14.2.1.4)
read-only
Integer32
Remaining guaranteed power of the PSE, in watts.
As per the MIB.
hh3cMainPsePriorityMode (1.3.6.1.4.1.25506.2.14.2.1.5)
read-write
INTEGER
disconnection(0), non-disconnection(1)
Describes or controls the priority mode on slot which must be enabled firstly. When a new card is inserted, and the power is overloaded, a value of disconnection(0) means that power will not be supplied to the low priority slot. A value of non-disconnection(1) means that power is supplied to the slot when a new card is inserted, and the power is overloaded.
Not supported.
hh3cMainPseLegacy (1.3.6.1.4.1.25506.2.14.2.1.6)
read-write
INTEGER
enable(0), disable(1)
Standard or nonstandard PD detection mode.
As per the MIB.
hh3cMainPsePowerPriority (1.3.6.1.4.1.25506.2.14.2.1.7)
read-write
INTEGER
critical(1), high(2), low(3)
Priority of the PSE.
As per the MIB.
hh3cPseProfilesTable
About this table
Use this table to manage power profiles.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cPseProfileIndex.
Object (OID)
Access
Value range
Implementation
hh3cPseProfileIndex (1.3.6.1.4.1.25506.2.14.7.1.1)
not-accessible
Integer32
Integer32 (1..100)
Profile index.
As per the MIB.
hh3cPseProfileName (1.3.6.1.4.1.25506.2.14.7.1.2)
read-create
DisplayString
OCTET STRING (1..15)
Profile name.
As per the MIB.
hh3cPseProfilePowerMode (1.3.6.1.4.1.25506.2.14.7.1.3)
read-create
INTEGER
powerDisabled(1), powerEnabled(2)
Power mode.
As per the MIB.
hh3cPseProfilePowerLimit (1.3.6.1.4.1.25506.2.14.7.1.4)
read-create
Integer32
Power limit, in milliwatts.
As per the MIB.
hh3cPseProfilePriority (1.3.6.1.4.1.25506.2.14.7.1.5)
read-create
INTEGER
Port priority.
As per the MIB.
hh3cPseProfilePairs (1.3.6.1.4.1.25506.2.14.7.1.6)
read-create
INTEGER
signal(1), spare(2)
Pairs in use.
As per the MIB.
hh3cPseProfileApplyNum (1.3.6.1.4.1.25506.2.14.7.1.7)
read-only
Integer32
Number of this profile being applied.
As per the MIB.
hh3cPseProfileRowStatus (1.3.6.1.4.1.25506.2.14.7.1.8)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Row status.
Supports only active, createAndGo, and destory.
This row cannot be deleted when the value of the hh3cPseProfileApplyNum is 0.
Notifications
This section contains the HH3C-POWER-ETH-EXT-MIB notifications.
hh3cpsePDChangeNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.14.6.1
PD connected or disconnected
Informational
N/A
N/A
ON
This notification is generated when a PD is connected or disconnected.
Status control
ON
MIB: Set pethNotificationControlEnable to true(1).
OFF
MIB: Set pethNotificationControlEnable to false(2).
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.105.1.1.1.6 (pethPsePortDetectionStatus)
PD detection status of the PSE port.
N
INTEGER
disabled(1), searching(2), deliveringPower(3), fault(4), test(5), otherFault(6)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Check the connection to the PD. No action is required if the alarm is triggered by a human operation.
