03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10003-Device Management
02-HH3C-COMMON-SYSTEM-MIB
02-HH3C-COMMON-SYSTEM-MIB 67.69 KB
About this MIB
Use this MIB to perform basic operations on the device. For example, access this MIB to reboot the device, obtain basic system information such as reboot mode and system operating mode, and send poweroff alarms. This MIB also contains notifications about device operation changes.
MIB file name
hh3c-common-system.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
hh3cReboot
Object (OID)
Access
Value range
Implementation
hh3cReboot (1.3.6.1.4.1.25506.6.7)
read-write
INTEGER
normal(0), reboot(1)
Reboots the device.
As per the MIB.
hh3cSysBootType
Object (OID)
Access
Value range
Implementation
hh3cSysBootType (1.3.6.1.4.1.25506.6.10)
read-only
INTEGER
coldStart(1), warmStart(2)
Boot mode of the system.
Implementation varies by the product.
hh3cSystemWorkingModeDefault
Object (OID)
Access
Value range
Implementation
hh3cSystemWorkingModeDefault (1.3.6.1.4.1.25506.6.14.2)
read-only
Integer32
Integer32 (1..2147483647)
Default system operating mode.
Supported.
hh3cSystemWorkingModeCurrent
Object (OID)
Access
Value range
Implementation
hh3cSystemWorkingModeCurrent (1.3.6.1.4.1.25506.6.14.3)
read-only
Integer32
Current system operating mode.
Supported.
hh3cSystemWorkingModeNext
Object (OID)
Access
Value range
Implementation
hh3cSystemWorkingModeNext (1.3.6.1.4.1.25506.6.14.4)
read-write
Integer32
The system operating mode for the next startup.
Supported.
For the modified operating mode to take effect, reboot the device, The new operating mode will take effect on the entire device.
hh3cSysFirstTrapTime
Object (OID)
Access
Value range
Implementation
hh3cSysFirstTrapTime (1.3.6.1.4.1.25506.6.11.10)
accessible-for-notify
Timeticks
Standard MIB values.
Time when a trap is sent for the first time.
Implementation varies by product.
Supports only some traps.
hh3cSysBannerMOTD
Object (OID)
Access
Value range
Implementation
hh3cSysBannerMOTD (1.3.6.1.4.1.25506.6.11.11)
read-write
OCTETSTRING
OCTET STRING (0..2000)
Banner message.
As per the MIB.
Tabular objects
hh3cSystemDiagInfoTable
About this table
This table creates diagnosis files for the system.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cSystemDiagInfoIndex.
Object (OID)
Access
Value range
Implementation
hh3cSystemDiagInfoIndex (1.3.6.1.4.1.25506.6.13.1.1)
not-accessible
Integer32
Entry index.
As per the MIB.
hh3cSystemDiagInfoFilename (1.3.6.1.4.1.25506.6.13.1.2)
read-create
DisplayString
OCTET STRING (0..255)
Diagnosis file name.
As per the MIB.
The system uses the default file name if you do not specify a file name during row creation.
hh3cSystemDiagInfoRowStatus (1.3.6.1.4.1.25506.6.13.1.3)
read-create
RowStatus
active(1),notInService(2),notReady(3),createAndGo(4),createAndWait(5),destroy(6)
Row status.
As per the MIB.
hh3cSystemDiagInfoOperEndTime(1.3.6.1.4.1.25506.6.13.1.4)
read-only
TimeStamp
Time when the operation was completed.
As per the MIB.
hh3cSystemDiagInfoOperState (1.3.6.1.4.1.25506.6.13.1.5)
read-only
INTEGER
opInProgress(1),opSuccess(2),opFailure(3)
Operation status.
As per the MIB.
hh3cSystemDiagInfoOperFailReason (1.3.6.1.4.1.25506.6.13.1.6)
read-only
DisplayString
Failure reason.
As per the MIB.
hh3cSystemWorkingModeTable
About this table
This table contains information about the system operating modes supported on the device.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSystemWorkingModeIndex.
Object (OID)
Access
Value range
Implementation
hh3cSystemWorkingModeIndex (1.3.6.1.4.1.25506.6.14.1.1.1)
not-accessible
Integer32
Index of a system operating mode.
Supported
hh3cSystemWorkingModeName (1.3.6.1.4.1.25506.6.14.1.1.2)
read-only
DisplayString
OCTET STRING (1..32)
Name of the system operating mode.
Supported.
Notifications
The following information describes the notifications included in the HH3C-COMMON-SYSTEM-MIB module.
hh3cRebootSendTrap
Basic information
OID (object name)
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.6.8.3
The device is to reboot
Informational
Warning
N/A
ON
This notification is generated two seconds before the reboot command is used to reboot the device.
Status control
This alarm cannot be cleared.
Objects
N/A
Recommended action
No action is required.
hh3cSysColdStartTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.4
A cold boot was performed
Informational
Warning
N/A
ON
This notification is generated when a cold boot is performed on the device.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.6.11.10 (hh3cSysFirstTrapTime)
Time when the alarm occurred.
N/A
TimeTicks
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
hh3cSysWarmStartTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.5
A warm boot was performed
Informational
Warning
N/A
ON
Status control
Objects
OID (object name)
Index
Value range
N/A
TimeTicks
Recommended action
hh3cSysDyingGaspTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.7
Poweroff alarm
Informational
Major
N/A
ON
This alarm occurs when the device is powered off.
Status control
Objects
N/A
Recommended action
Verify that the power cord is connected correctly.
