03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10003-Device Management
06-HH3C-LSW-DEV-ADM-MIB
06-HH3C-LSW-DEV-ADM-MIB 118.44 KB
About this MIB
Use this MIB to obtain basic device information about chassis, slots, CPUs, and ports.
MIB file name
hh3c-lsw-dev-adm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswDeviceAdmin(18)
Scalar objects
hh3cLswSysIpAddr
Object (OID)
Access
Value range
Implementation
hh3cLswSysIpAddr (1.3.6.1.4.1.25506.8.35.18.1.1)
read-only
IpAddress
Standard MIB values.
IP address of a VLAN interface.
As per the MIB.
hh3cLswSysIpMask
Object (OID)
Access
Value range
Implementation
hh3cLswSysIpMask (1.3.6.1.4.1.25506.8.35.18.1.2)
read-only
IpAddress
Subnet mask for the system IP address.
As per the MIB.
hh3cLswSysCpuRatio
Object (OID)
Access
Value range
Implementation
hh3cLswSysCpuRatio (1.3.6.1.4.1.25506.8.35.18.1.3)
read-only
Integer32
Integer32 (0..100)
Real-time CPU usage on the card in 1-minute intervals.
For distributed devices in IRF mode, this object indicates the real-time CPU usage on the active MPU in the system.
As per the MIB.
hh3cLswSysVersion
Object (OID)
Access
Value range
Implementation
hh3cLswSysVersion (1.3.6.1.4.1.25506.8.35.18.1.4)
read-only
DisplayString
OCTET STRING (1..64)
Version of the system.
For distributed devices in IRF mode, this object indicates the version of the active MPU in the system.
As per the MIB.
hh3cLswSysTime
Object (OID)
Access
Value range
Implementation
hh3cLswSysTime (1.3.6.1.4.1.25506.8.35.18.1.5)
read-write
DateAndTime
OCTET STRING (8 | 11)
System time of the device.
For distributed devices in IRF mode, this object indicates the system time of the active MPU in the system.
Supports only the read operation on the non-default MDC.
hh3cLswSysPhyMemory
Object (OID)
Access
Value range
Implementation
hh3cLswSysPhyMemory (1.3.6.1.4.1.25506.8.35.18.1.13)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Physical memory space of the device, in bytes.
For distributed devices, this object indicates the physical memory space of the active MPU in the system.
As per the MIB.
hh3cLswSysMemory
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemory (1.3.6.1.4.1.25506.8.35.18.1.14)
read-only
Unsigned32
System memory space, in bytes.
For distributed devices, this object indicates the system memory space of the active MPU in the system.
As per the MIB.
hh3cLswSysMemoryUsed
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemoryUsed (1.3.6.1.4.1.25506.8.35.18.1.15)
read-only
Unsigned32
Used system memory, in bytes.
For distributed devices, this object indicates the used system memory on the active MPU in the system.
As per the MIB.
hh3cLswSysMemoryRatio
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemoryRatio (1.3.6.1.4.1.25506.8.35.18.1.16)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the used system memory on the device.
For distributed devices, this object indicates the percentage of the used system memory on the active MPU in the system.
As per the MIB.
hh3cLswSysPhyMemRev
Object (OID)
Access
Value range
Implementation
hh3cLswSysPhyMemRev (1.3.6.1.4.1.25506.8.35.18.1.18)
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysMemRev
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemRev (1.3.6.1.4.1.25506.8.35.18.1.19)
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysMemUsedRev
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemUsedRev (1.3.6.1.4.1.25506.8.35.18.1.20)
read-only
CounterBasedGauge64
As per the MIB.
Tabular objects
hh3cLswFrameTable
About this table
This table contains chassis-level information about devices.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLswFrameIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFrameIndex (1.3.6.1.4.1.25506.8.35.18.4.2.1.1)
read-only
Integer32
Integer32 (-2147483648..2147483647)
Chassis index.
As per the MIB.
hh3cLswFrameDesc (1.3.6.1.4.1.25506.8.35.18.4.2.1.3)
read-write
DisplayString
OCTET STRING (0..64)
Description of the chassis.
hh3cLswSlotNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.4)
read-only
Integer32
Number of slots in the current chassis.
As per the MIB.
hh3cLswFrameAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.2.1.5)
read-only
INTEGER
normal(1),
fault(2),
other(3)
Chassis status.
As per the MIB.
hh3cLswFrameSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.6)
read-only
SnmpAdminString
OCTET STRING (0..32)
Serial number of the chassis.
As per the MIB.
hh3cLswSlotTable
About this table
This table contains card information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex and hh3cLswSlotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswSlotIndex (1.3.6.1.4.1.25506.8.35.18.4.3.1.1)
read-only
Integer32
Card index.
As per the MIB.
hh3cLswSlotType (1.3.6.1.4.1.25506.8.35.18.4.3.1.2)
read-only
Integer32
Card type.
Implementation varies by product.
hh3cLswSlotDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.3)
read-write
DisplayString
Description of the card.
hh3cLswSlotCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.4)
read-only
Integer32
CPU usage on the card.
As per the MIB.
hh3cLswSlotPcbVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.5)
read-only
DisplayString
Hardware version of the card.
As per the MIB.
hh3cLswSlotSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.6)
read-only
DisplayString
Software version of the card.
As per the MIB.
hh3cLswSubslotNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.7)
read-only
Integer32
Number of subcards.
As per the MIB.
hh3cLswSlotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.8)
read-only
INTEGER
not-install(1), normal(2), fault(3), forbidden(4)
Administrative status of the card.
As per the MIB.
hh3cLswSlotOperStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.9)
read-write
INTEGER
disable(1), enable(2), reset(3), test(4)
Operation status of the card.
Supports only reset.
hh3cLswSlotPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.10)
read-only
Unsigned32
Physical memory space of the card, in bytes.
The memory is a 32-bit wide memory.
As per the MIB.
hh3cLswSlotMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.11)
read-only
Unsigned32
System memory space of the card, in bytes.
As per the MIB.
hh3cLswSlotMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.3.1.12)
read-only
Unsigned32
Used system memory on the card, in bytes.
As per the MIB.
hh3cLswSlotMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.13)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the system used memory on the card, in bytes.
As per the MIB.
hh3cLswSlotTemperature (1.3.6.1.4.1.25506.8.35.18.4.3.1.14)
read-only
Integer32
Temperature of the card.
Not supported
hh3cLswSlotPktBufFree (1.3.6.1.4.1.25506.8.35.18.4.3.1.15)
read-only
Integer32
Number of free packet buffers on the card.
As per the MIB.
hh3cLswSlotPktBufInit (1.3.6.1.4.1.25506.8.35.18.4.3.1.16)
read-only
Integer32
Number of packet buffers on the card.
As per the MIB.
hh3cLswSlotPktBufMin (1.3.6.1.4.1.25506.8.35.18.4.3.1.17)
read-only
Integer32
Minimum number of packet buffers on the card.
As per the MIB.
hh3cLswSlotPktBufMiss (1.3.6.1.4.1.25506.8.35.18.4.3.1.18)
read-only
Counter64
Counter64 (0..18446744073709551615)
Packet loss counting in packet buffers on the card.
As per the MIB.
hh3cLswSlotRunTime (1.3.6.1.4.1.25506.8.35.18.4.3.1.19)
read-only
DisplayString
Running time of the card.
As per the MIB.
hh3cLswSlotMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.20)
read-only
Counter64
The memory is a 64-bit wide memory.
As per the MIB.
hh3cLswSlotPhyMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.21)
read-only
Counter64
As per the MIB.
hh3cLswSlotMemUsedRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.22)
read-only
Counter64
As per the MIB.
hh3cLswSlotModelDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.23)
read-only
DisplayString
OCTET STRING (0..255)
Description of the extended module in the slot.
As per the MIB.
hh3cLswSlotPktBufThreshold (1.3.6.1.4.1.25506.8.35.18.4.3.1.24)
read-write
Integer32
Integer32 (1..100)
Threshold for the number of packet buffers on the card.
As per the MIB.
hh3cLswSlotSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.25)
read-only
SnmpAdminString
Serial number of the card.
As per the MIB.
hh3cLswSubslotTable
About this table
This table contains subcard information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswSubslotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswSubslotIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.1)
read-only
Integer32
Subcard index.
As per the MIB.
hh3cLswSubslotType (1.3.6.1.4.1.25506.8.35.18.4.4.1.2)
read-only
Integer32
Subcard type.
hh3cLswSubslotPortNum (1.3.6.1.4.1.25506.8.35.18.4.4.1.3)
read-only
Integer32
Port number of the subcard.
As per the MIB.
hh3cLswSubslotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.4.1.4)
read-only
INTEGER
not-install(1),
normal(2),
fault(3),
forbidden(4)
Status of the subacard.
As per the MIB.
hh3cLswSubslotFirstIfIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.5)
read-only
Integer32
Index of the first physical port on the subcard.
Supports only Ethernet ports.
hh3cLswSubslotSerialNumber(1.3.6.1.4.1.25506.8.35.18.4.4.1.6)
read-only
SnmpAdminString
Serial number of the subcard.
As per the MIB.
hh3cLswPortTable
About this table
This table contains port information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswPortIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.1)
read-only
Integer32
Port index.
As per the MIB.
hh3cLswPortType (1.3.6.1.4.1.25506.8.35.18.4.5.1.2)
read-only
Integer32
Port type.
hh3cLswPortIfIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.3)
read-only
Integer32
Index of the interface attached to the port.
As per the MIB.
Hh3cLswPortIsPlugged (1.3.6.1.4.1.25506.8.35.18.4.5.1.4)
read-only
INTEGER
unplugged(0),
plugged(1)
Connection status of the port.
As per the MIB.
hh3cLswFabricTable
About this table
This table contains fabric module channel information.
This table does not support the read operation only on the default MDC.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswFabricChannelIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFabricChannelIndex (1.3.6.1.4.1.25506.8.35.18.4.7.1.1)
not-accessible
Integer32
Channel index.
As per the MIB.
hh3cLswFabricUtilIn (1.3.6.1.4.1.25506.8.35.18.4.7.1.2)
read-only
Integer32
Integer32 (0..100)
Ingress utilization of the channel.
As per the MIB.
hh3cLswFabricUtilOut (1.3.6.1.4.1.25506.8.35.18.4.7.1.3)
read-only
Integer32
Integer32 (0..100)
Egress utilization of the channel.
As per the MIB.
hh3cLswFabricPeakIn (1.3.6.1.4.1.25506.8.35.18.4.7.1.4)
read-only
Integer32
Integer32 (0..100)
Peak ingress utilization of the channel.
As per the MIB.
hh3cLswFabricPeakInTime (1.3.6.1.4.1.25506.8.35.18.4.7.1.5)
read-only
DateAndTime
Time at which peak ingress utilization of the channel is present.
As per the MIB.
hh3cLswFabricPeakOut (1.3.6.1.4.1.25506.8.35.18.4.7.1.6)
read-only
Integer32
Integer32 (0..100)
Peak egress utilization of the channel.
As per the MIB.
hh3cLswFabricPeakOutTime (1.3.6.1.4.1.25506.8.35.18.4.7.1.7)
read-only
DateAndTime
Time at which peak egress utilization of the channel is present.
As per the MIB.
hh3cLswExtendModelTable
About this table
This table contains extended module information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLswExtendModelIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswExtendModelIndex (1.3.6.1.4.1.25506.8.35.18.4.9.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Extended module index.
As per the MIB.
hh3cLswExtendModelDesc (1.3.6.1.4.1.25506.8.35.18.4.9.1.2)
read-only
DisplayString
Description of the Extended module.
As per the MIB.
hh3cLswCpuTable
About this table
This table contains CPU information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswCpuIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswCpuIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.1)
not-accessible
PhysicalIndex
Integer32 (0..2147483647)
CPU index.
As per the MIB.
hh3cLswCpuEntityIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.2)
read-only
Integer32
Index of the CPU entity.
As per the MIB.
hh3cLswCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.3)
read-only
Unsigned32
Unsigned32 (0..100)
Real-time CPU usage on the host.
As per the MIB.
hh3cLswCpuSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.10.1.4)
read-only
DisplayString
CPU software version.
As per the MIB.
hh3cLswCpuAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.5)
read-only
INTEGER
notInstall(1),
normal(2),
fault(3),
forbidden(4)
CPU status.
As per the MIB.
hh3cLswCpuOperStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.6)
read-write
INTEGER
disable(1),
enable(2),
reset(3),
test(4)
Operation status of the CPU.
Supports reset only on the active CPU.
Supports the read operation only on the non-default MDC.
hh3cLswCpuPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.7)
read-only
Counter64
Physical memory space of the node, in bytes.
As per the MIB.
hh3cLswCpuMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.8)
read-only
Counter64
System memory space of the node, in bytes.
As per the MIB.
hh3cLswCpuMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.9)
read-only
Counter64
Used memory on the node, in bytes.
As per the MIB.
hh3cLswCpuMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.10)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the used memory on the node.
As per the MIB.
hh3cLswCpuMemoryFree (1.3.6.1.4.1.25506.8.35.18.4.10.1.14)
read-only
CounterBasedGauge64
Free memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryFreeRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.15)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the free memory.
As per the MIB.
hh3cLswCpuMemoryHighTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.16)
read-only
CounterBasedGauge64
Total high memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryHighFree  (1.3.6.1.4.1.25506.8.35.18.4.10.1.17)
read-only
CounterBasedGauge64
Free high memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryLowTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.18)
read-only
CounterBasedGauge64
Total low memory size, in bytes.
As per the MIB.
hh3cLswCpuMemoryLowFree   (1.3.6.1.4.1.25506.8.35.18.4.10.1.19)
read-only
CounterBasedGauge64
Free low memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryVmallocTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.20)
read-only
CounterBasedGauge64
Total vmalloc memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryVmallocUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.21)
read-only
CounterBasedGauge64
Used vmalloc memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryVmallocChunk (1.3.6.1.4.1.25506.8.35.18.4.10.1.22)
read-only
CounterBasedGauge64
Number of chunks for the vmalloc memory.
As per the MIB.
hh3cLswCpuMemoryCommitLimit (1.3.6.1.4.1.25506.8.35.18.4.10.1.23)
read-only
CounterBasedGauge64
Memory size that can be allocated to the system, in bytes.
As per the MIB.
hh3cLswCpuMemoryCommittedAs (1.3.6.1.4.1.25506.8.35.18.4.10.1.24)
read-only
CounterBasedGauge64
Committed_As memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryThresholdUnit  (1.3.6.1.4.1.25506.8.35.18.4.10.1.25)
read-write
INTEGER
inMB(1),
inPercentage(2)
Unit of memory thresholds.
As per the MIB.
hh3cLswCpuMemorySecureThreshold  (1.3.6.1.4.1.25506.8.35.18.4.10.1.26)
read-write
Unsigned32
Sufficient-memory threshold for the memory.
As per the MIB.
hh3cLswCpuMemoryEarlyWarningThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.27)
read-write
Unsigned32
Early-warning threshold for the memory.
As per the MIB.
hh3cLswCpuMemoryNormalThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.28)
read-write
Unsigned32
Normal state threshold for the memory.
As per the MIB.
 hh3cLswCpuMemoryMinorThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.29)
read-write
Unsigned32
Minor memory alarm threshold.
As per the MIB.
 hh3cLswCpuMemorySevereThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.30)
read-write
Unsigned32
Major memory alarm threshold.
As per the MIB.
 hh3cLswCpuMemoryCriticalThreshold  (1.3.6.1.4.1.25506.8.35.18.4.10.1.31)
read-write
Unsigned32
Critical memory alarm threshold.
As per the MIB.
 hh3cLswCpuMemoryCurrentState (1.3.6.1.4.1.25506.8.35.18.4.10.1.32)
read-only
INTEGER
secure(1),
earlywarning(2),
normal(3),
minor(4),
severe(5),
critical(6)
Current memory status.
As per the MIB.
hh3cLswPowerTable
About this table
This table contains power supply information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswPowerIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswPowerIndex (1.3.6.1.4.1.25506.8.35.18.4.11.1.1)
read-only
Integer32
Power supply index.
As per the MIB.
hh3cLswPowerSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.11.1.2)
read-only
SnmpAdminString
Serial number of the power supply.
As per the MIB.
hh3cLswFanTable
About this table
This table contains fan information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswFanIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFanIndex (1.3.6.1.4.1.25506.8.35.18.4.12.1.1)
read-only
Integer32
Fan index.
As per the MIB.
hh3cLswFanSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.12.1.2)
read-only
SnmpAdminString
Serial number of the fan.
As per the MIB.
hh3cLswTransceiverTable
About this table
This table contains transceiver module information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswTransceiverIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswTransceiverIndex (1.3.6.1.4.1.25506.8.35.18.4.13.1.1)
read-only
Integer32
Transceiver module index.
As per the MIB.
hh3cLswTransceiverSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.13.1.2)
read-only
SnmpAdminString
Serial number of the transceiver module.
As per the MIB.
hh3cLswCoreTable
About this table
This table contains CPU core information.
Support for this table varies by product.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswCpuIndex, and hh3cLswCoreIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswCoreIndex (1.3.6.1.4.1.25506.8.35.18.4.15.1.1)
read-only
Integer32
CPU core index.
As per the MIB.
hh3cLswCoreUsageInLast5Sec (1.3.6.1.4.1.25506.8.35.18.4.15.1.2)
read-only
Unsigned32
CPU core usage in the most recent 5-second interval.
As per the MIB.
hh3cLswCoreUsageInLast1Min (1.3.6.1.4.1.25506.8.35.18.4.15.1.3)
read-only
Unsigned32
CPU core usage in the most recent 1-minute interval.
As per the MIB.
hh3cLswCoreUsageInLast5Min (1.3.6.1.4.1.25506.8.35.18.4.15.1.4)
read-only
Unsigned32
CPU core usage in the most recent 5-minute interval.
As per the MIB.
hh3cLswCoreThreshold (1.3.6.1.4.1.25506.8.35.18.4.15.1.5)
read-write
Unsigned32
CPU core alarm threshold.
As per the MIB.
hh3cLswCoreState (1.3.6.1.4.1.25506.8.35.18.4.15.1.6)
read-only
INTEGER
normal(1),
warning(2)
CPU core status.
As per the MIB.
