01-Fundamentals
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10001-Fundamentals
04-HH3C-SYS-MAN-MIB
04-HH3C-SYS-MAN-MIB 126.85 KB
HH3C-SYS-MAN-MIB
About this MIB
Use this MIB to manage the system time and daylight saving time, obtain the current configuration file and the version file, reboot the device, and upgrade device software. This MIB also contains notifications about configuration changes.
MIB file name
hh3c-sys-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSystemMan(3)
Scalar objects
hh3cSysLocalClock
Object (OID)
Access
Value range
Implementation
hh3cSysLocalClock (1.3.6.1.4.1.25506.2.3.1.1.1)
read-write
DateAndTime
OCTET STRING (8)
System time.
As per the MIB.
hh3cSysSummerTimeEnable (1.3.6.1.4.1.25506.2.3.1.1.2.1)
read-only
INTEGER
enable(1)
disable(2)
Enables or disables using daylight saving time.
As per the MIB.
hh3cSysSummerTimeZone (1.3.6.1.4.1.25506.2.3.1.1.2.2)
read-write
DisplayString
OCTET STRING (0..255)
Name for the daylight saving time schedule.
As per the MIB.
hh3cSysSummerTimeMethod (1.3.6.1.4.1.25506.2.3.1.1.2.3)
read-write
INTEGER
oneOff(1)
repeating(2)
Implementation method of daylight saving time.
Supports only the repeating method.
hh3cSysSummerTimeStart (1.3.6.1.4.1.25506.2.3.1.1.2.4)
read-write
DateAndTime
OCTET STRING (8)
Start time of the daylight saving time schedule.
As per the MIB.
hh3cSysSummerTimeEnd (1.3.6.1.4.1.25506.2.3.1.1.2.5)
read-write
DateAndTime
OCTET STRING (8)
End time of the daylight saving time schedule.
As per the MIB.
hh3cSysSummerTimeOffset (1.3.6.1.4.1.25506.2.3.1.1.2.6)
read-write
Integer32
Integer32 (0..86399)
Time to be added to the standard time.
As per the MIB.
hh3cSysLocalClockString (1.3.6.1.4.1.25506.2.3.1.1.3)
read-write
OCTET STRING
OCTET STRING (16..24)
System time in the format of strings.
As per the MIB.
Same with hh3cSysLocalClock.
hh3cSysReloadSchedule (1.3.6.1.4.1.25506.2.3.1.3.1)
read-write
Integer32
Integer32 (0..2147483647)
Reload entry index.
The device reboots if the value of the object is 1 on the occurrence of the reload operation.
hh3cSysReloadAction (1.3.6.1.4.1.25506.2.3.1.3.2)
read-write
INTEGER
reloadUnavailable(1)
reloadOnSchedule(2)
reloadAtOnce(3)
reloadCancel(4)
Reload action.
As per the MIB.
hh3cSysReloadTag (1.3.6.1.4.1.25506.2.3.1.3.4)
read-write
SnmpTagValue
Tag of the reload entry.
As per the MIB.
hh3cSysCFGFileNum (1.3.6.1.4.1.25506.2.3.1.5.1)
read-only
Integer32
Number of configuration files.
As per the MIB.
hh3cSysBtmLoadMaxNumber (1.3.6.1.4.1.25506.2.3.1.6.1.1)
read-only
Integer32
Maximum number of bootrom load entries.
As per the MIB.
hh3cSysPackageNum (1.3.6.1.4.1.25506.2.3.1.7.1)
read-only
Integer32
Number of packages.
As per the MIB.
hh3cSysPackageOperateEntryLimit (1.3.6.1.4.1.25506.2.3.1.7.3)
read-write
Integer32
Maximum number of package file operation entries.
Maximum number of instances in hh3cSysPackageOperateTable, in the range of 1 to 128. The default is 32.
If the number of the instances reaches the limit, the most recent instance overwrites the earliest one.
hh3cSysIpeFileNum (1.3.6.1.4.1.25506.2.3.1.8.1)
read-only
Integer32
Number of IPE files.
As per the MIB.
hh3cSysSetBootImageAction (1.3.6.1.4.1.25506.2.3.1.9.1.1)
read-write
INTEGER
none(1)
done(2)
bootLoadPrimary(3)
bootLoadSecondary(4)
bootLoadPrimarySecondary(5)
bootPrimary(6)
bootSecondary(7)
bootPrimarySecondary(8)
loadPrimary(9)
loadSecondary(10)
loadPrimarySecondary(11)
Sets images as primary boot images, secondary boot images, or both.
Supports only none(1), done(2), bootLoadPrimary(3), bootLoadSecondary(4), and bootLoadPrimarySecondary(5).
Verify the result after setting boot images or performing boot image loading. To avoid next upgrade being affected, clear the upgrade records after the upgrade.
As a best practice, verify that the upgrade files and the upgrade records are empty before the next upgrade.
hh3cSysSetBootImageFileOverWrite (1.3.6.1.4.1.25506.2.3.1.9.1.2)
read-write
TruthValue
true(1)
false(2)
Selects whether to overwrite the existing image files during boot image setting.
As per the MIB.
hh3cSysSetBootImageRemoveIpeFile (1.3.6.1.4.1.25506.2.3.1.9.1.3)
read-write
TruthValue
true(1)
false(2)
Selects whether to delete the specified IPE file after boot image setting.
As per the MIB.
hh3cSysSetBootImageStatus (1.3.6.1.4.1.25506.2.3.1.9.1.4)
read-only
INTEGER
none(1)
doing(2)
success(3)
failed(4)
Status of boot image setting operation or boot image loading operation.
As per the MIB.
hh3cSysSetBootImageFailedReason (1.3.6.1.4.1.25506.2.3.1.9.1.5)
read-only
DisplayString
Failure reason for boot image setting or boot image loading.
As per the MIB.
Tabular objects
hh3cSysCurTable
About this table
This table contains information about the current system configuration file, device software, and bootrom files.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysCurEntPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysCurEntPhysicalIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.1)
not-accessible
Integer32
Device entity index.
As per the MIB.
hh3cSysCurCFGFileIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.2)
read-only
Integer32
Configuration file index.
As per the MIB.
hh3cSysCurImageIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.3)
read-only
Integer32
Image file index.
Not supported
hh3cSysCurBtmFileName (1.3.6.1.4.1.25506.2.3.1.2.1.1.4)
read-only
OCTET STRING
OCTET STRING (1..64)
Name of the current bootrom file.
Not supported
hh3cSysCurUpdateBtmFileName (1.3.6.1.4.1.25506.2.3.1.2.1.1.5)
read-only
OCTET STRING
Name of the bootrom file after the upgrade. The bootrom file will be used for the next boot.
Not supported
hh3cSysReloadScheduleTable
About this table
This table specifies reboot entries for device reboot.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
You must specify hh3cSysReloadScheduleIndex, hh3cSysReloadEntity, and hh3cSysReloadRowStatus when you create a row. hh3cSysReloadEntity must be a valid entity. The entity index from hh3cSysReloadScheduleIndex must be the same with the index of hh3cSysReloadEntity.
An entity supports only one reload table. Entries in Active status are not configurable.
Columns
The table index is hh3cSysReloadScheduleIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysReloadScheduleIndex (1.3.6.1.4.1.25506.2.3.1.3.3.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Index of the hh3cSysReloadScheduleTable.
As per the MIB.
hh3cSysReloadEntity (1.3.6.1.4.1.25506.2.3.1.3.3.1.2)
read-create
Integer32
Entry in entPhysicalTable, which is the entity to be reloaded.
As per the MIB.
hh3cSysReloadCfgFile (1.3.6.1.4.1.25506.2.3.1.3.3.1.3)
read-create
Integer32
Integer32 (0.. 2147483647)
Entry in hh3cSysImageFileTable.
The value 0 indicates that the entity does not specify the next-startup configuration files.
hh3cSysReloadImage (1.3.6.1.4.1.25506.2.3.1.3.3.1.4)
read-create
Integer32
Entry in hh3cSysCFGFileTable.
Not supported
hh3cSysReloadReason (1.3.6.1.4.1.25506.2.3.1.3.3.1.5)
read-create
DisplayString
Reason for system reloading.
As per the MIB.
hh3cSysReloadScheduleTime (1.3.6.1.4.1.25506.2.3.1.3.3.1.6)
read-create
DateAndTime
OCTET STRING (8)
Time when the reload action will occur.
As per the MIB.
hh3cSysReloadRowStatus (1.3.6.1.4.1.25506.2.3.1.3.3.1.7)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
hh3cSysReloadScheduleTagList (1.3.6.1.4.1.25506.2.3.1.3.3.1.8)
read-create
SnmpTagList
Tag list for the entry.
If the value of hh3cSysReloadSchedule is valid, the value of hh3cSysReloadScheduleTagList is ignored.
hh3cSysCFGFileTable
About this table
This table contains information about the configuration files of the system, including file names and file sizes.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysCFGFileIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysCFGFileIndex (1.3.6.1.4.1.25506.2.3.1.5.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cSysCFGFileName (1.3.6.1.4.1.25506.2.3.1.5.2.1.2)
read-only
DisplayString
Configuration file name.
As per the MIB.
hh3cSysCFGFileSize (1.3.6.1.4.1.25506.2.3.1.5.2.1.3)
read-only
Integer32
Configuration file size.
As per the MIB.
hh3cSysCFGFileLocation (1.3.6.1.4.1.25506.2.3.1.5.2.1.4)
read-only
DisplayString
Configuration file path.
As per the MIB.
hh3cSysBtmLoadTable
About this table
This table upgrades bootrom and contains information about bootrom upgrade records, including bootrom file names, result of the upgrade operation, and upgrading time.
This table index consists of the two parts as shown in the following figure:
The value of entityIndex is entPhysicalIndex, which is the entity index of entPhysicalClass as module. The value of randomIndex is determined by users. The value of hh3cSysBtmLoadIndex is calculated as follows:
hh3cSysBtmLoadIndex = (entityIndex << 16) | randomIndex
For example, a file in flash:/boot.bin path is a valid bootrom file, the value of entPhysicalIndex is 2 for the current operating MPU, and the random index specified by users is 1. Then, the value of hh3cSysBtmLoadIndex is 131073. To create an entry based on the above information, you must configure the entry settings as follows:
hh3cSysBtmFileName.131073 = "flash:/boot.bin"
hh3cSysBtmFileType.131073 = 'main(1)'
hh3cSysBtmRowStatus.131073 = 'createAndGo'
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
You must specify hh3cSysBtmFileName, hh3cSysBtmFileType, and hh3cSysBtmRowStatus when you create a row.
A file specified by hh3cSysBtmFileName must exist and be valid. You must set hh3cSysBtmFileType to main and hh3cSysBtmRowStatus to CreateAndGo.
Columns
The table index is hh3cSysBtmLoadIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysBtmLoadIndex (1.3.6.1.4.1.25506.2.3.1.6.2.1.1)
not-accessible
Integer32
Table index, consisting of two parts, high 16 bits and low 16 bits.
As per the MIB.
hh3cSysBtmFileName (1.3.6.1.4.1.25506.2.3.1.6.2.1.2)
read-create
OCTET STRING
Bootrom file for the next boot.
As per the MIB.
hh3cSysBtmFileType (1.3.6.1.4.1.25506.2.3.1.6.2.1.3)
read-create
INTEGER
main(1)
none(2)
Type of the bootrom file for the next boot.
As per the MIB.
For the indexes with the same high 16 bits, this object  can only be main(1).
If the object is none(2), the corresponding bootrom file cannot be used for the next boot.
hh3cSysBtmRowStatus (1.3.6.1.4.1.25506.2.3.1.6.2.1.4)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
An existing entry cannot be modified.
hh3cSysBtmErrorStatus (1.3.6.1.4.1.25506.2.3.1.6.2.1.5)
read-only
INTEGER
invalidFile(1)
inProgress(2)
success(3)
failed(4)
Entry creation status, which indicates an entry is being created, has been created, or failed to be created.
As per the MIB.
hh3cSysBtmLoadTime (1.3.6.1.4.1.25506.2.3.1.6.2.1.6)
read-only
TimeTicks
Standard MIB values.
Entry creation time.
As per the MIB.
hh3cSysPackageTable
About this table
This table contains information about package files of the operating system, including basic package file information and operations on package files.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cSysPackageIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysPackageIndex (1.3.6.1.4.1.25506.2.3.1.7.2.1.1)
not-accessible
Integer32
Table index.
As per the MIB.
hh3cSysPackageName (1.3.6.1.4.1.25506.2.3.1.7.2.1.2)
read-only
DisplayString
Package file name.
As per the MIB.
hh3cSysPackageSize (1.3.6.1.4.1.25506.2.3.1.7.2.1.3)
read-only
Unsigned32
Unsigned32 (1..4294967295)
Package file size, in bytes.
As per the MIB.
hh3cSysPackageLocation (1.3.6.1.4.1.25506.2.3.1.7.2.1.4)
read-only
DisplayString
Package file path.
As per the MIB.
hh3cSysPackageType (1.3.6.1.4.1.25506.2.3.1.7.2.1.5)
read-only
INTEGER
boot(1)
system(2)
feature(3)
patch(4)
Type of the package file.
As per the MIB.
hh3cSysPackageAttribute (1.3.6.1.4.1.25506.2.3.1.7.2.1.6)
read-write
INTEGER
none(1)
primary(2)
secondary(3)
primarySecondary(4)
Attribute of the package file.
As per the MIB.
hh3cSysPackageStatus (1.3.6.1.4.1.25506.2.3.1.7.2.1.7)
read-only
INTEGER
active(1)
inactive(2)
Status of the package file.
As per the MIB.
hh3cSysPackageDescription (1.3.6.1.4.1.25506.2.3.1.7.2.1.8)
read-only
DisplayString
Description of the package file.
As per the MIB.
hh3cSysPackageFeature (1.3.6.1.4.1.25506.2.3.1.7.2.1.9)
read-only
DisplayString
Feature of the package file.
As per the MIB.
hh3cSysPackageVersion (1.3.6.1.4.1.25506.2.3.1.7.2.1.10)
read-only
DisplayString
Version of the package file.
As per the MIB.
hh3cSysPackageLoadAttribute (1.3.6.1.4.1.25506.2.3.1.7.2.1.11)
read-create
INTEGER
none(1)
primary(2)
secondary(3)
primarySecondary(4)
Load attribute of the package file.
Supports only none(1) and primary(2).
hh3cSysPackageModel (1.3.6.1.4.1.25506.2.3.1.7.2.1.12)
read-only
DisplayString
OCTET STRING (0..63)
Device type of the package file.
As per the MIB.
About this table
This table manages package files.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
You must specify hh3cSysPackageOperateIndex, hh3cSysPackageOperateIndex, hh3cSysPackageOperateStatus, and hh3cSysPackageOperateRowStatus when you create a row. The package file specified by hh3cSysPackageOperateIndex must a valid feature package.
Columns
The table index is hh3cSysPackageOperateIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysPackageOperateIndex (1.3.6.1.4.1.25506.2.3.1.7.4.1.1)
not-accessible
Integer32
Entry index.
As per the MIB.
hh3cSysPackageOperatePackIndex (1.3.6.1.4.1.25506.2.3.1.7.4.1.2)
read-create
Integer32
Index of the specified package file.
As per the MIB.
hh3cSysPackageOperateStatus(1.3.6.1.4.1.25506.2.3.1.7.4.1.3)
read-create
INTEGER
active(1)
inactive(2)
Activation or deactivation of the package file.
As per the MIB.
hh3cSysPackageOperateRowStatu (1.3.6.1.4.1.25506.2.3.1.7.4.1.4)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
hh3cSysPackageOperateResult(1.3.6.1.4.1.25506.2.3.1.7.4.1.5)
read-only
INTEGER
opInProgress(1)
opSuccess(2)
opUnknownFailure(3)
opInvalidFile(4)
opNotSupport(5)
Operation result.
As per the MIB.
hh3cSysIpeFileTable
About this table
This table contains information about IPE files.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysIpeFileIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysIpeFileIndex (1.3.6.1.4.1.25506.2.3.1.8.2.1.1)
not-accessible
Integer32
Index of an IPE file.
As per the MIB.
hh3cSysIpeFileName (1.3.6.1.4.1.25506.2.3.1.8.2.1.2)
read-only
DisplayString
IPE file name.
As per the MIB.
hh3cSysIpeFileSize (1.3.6.1.4.1.25506.2.3.1.8.2.1.3)
read-only
Unsigned32
IPE file size, in bytes.
As per the MIB.
hh3cSysIpeFileLocation (1.3.6.1.4.1.25506.2.3.1.8.2.1.4)
read-only
DisplayString
IPE file path.
As per the MIB.
hh3cSysIpeFileModel (1.3.6.1.4.1.25506.2.3.1.8.2.1.5)
read-only
SnmpTagList
Device model in the IPE file.
As per the MIB.
hh3cSysIpePackageTable
About this table
This table contains information about packages in IPE files.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are hh3cSysIpeFileIndex and hh3cSysIpePackageIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysIpePackageIndex (1.3.6.1.4.1.25506.2.3.1.8.3.1.1)
not-accessible
Integer32
IPE package index.
As per the MIB.
hh3cSysIpePackageName (1.3.6.1.4.1.25506.2.3.1.8.3.1.2)
read-only
DisplayString
Package file name.
As per the MIB.
hh3cSysIpePackageSize (1.3.6.1.4.1.25506.2.3.1.8.3.1.3)
read-only
Unsigned32
As per the MIB.
hh3cSysIpePackageType (1.3.6.1.4.1.25506.2.3.1.8.3.1.4)
read-only
INTEGER
boot(1)
system(2)
feature(3)
patch(4)
As per the MIB.
hh3cSysPackageDescription (1.3.6.1.4.1.25506.2.3.1.8.3.1.5)
read-only
DisplayString
As per the MIB.
hh3cSysIpePackageFeature (1.3.6.1.4.1.25506.2.3.1.8.3.1.6)
read-only
DisplayString
As per the MIB.
hh3cSysIpePackageVersion (1.3.6.1.4.1.25506.2.3.1.8.3.1.7)
read-only
DisplayString
As per the MIB.
hh3cSysIpePackageModel (1.3.6.1.4.1.25506.2.3.1.8.3.1.8)
read-only
DisplayString
As per the MIB.
hh3cSysIpeFileOperateTable
About this table
This table manages IPE files.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
You must specify hh3cSysIpeFileOperateInde, hh3cSysIpeFileOperateIndex, hh3cSysIpeFileOperateAttribute, and hh3cSysIpeFileOperateRowStatus when you create a row.
Columns
The table index is hh3cSysIpeFileOperateIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysIpeFileOperateIndex (1.3.6.1.4.1.25506.2.3.1.8.4.1.1)
not-accessible
Integer32
Entry index.
If the entity index is 1, IPE files will be decompressed to the active MPU.
hh3cSysIpeFileOperateFileIndex (1.3.6.1.4.1.25506.2.3.1.8.4.1.2)
read-create
Integer32
The value of this object is an instance index in hh3cSysIpeFileTable.
hh3cSysIpeFileOperateAttribute(1.3.6.1.4.1.25506.2.3.1.8.4.1.3)
read-create
INTEGER
none(1)
primary(2)
secondary(3)
primarySecondary(4)
Attribute of the IPE file.
As per the MIB.
hh3cSysIpeFileOperateRowStatus (1.3.6.1.4.1.25506.2.3.1.8.4.1.4)
read-create
INTEGER
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
hh3cSysIpeFileOperateResult (1.3.6.1.4.1.25506.2.3.1.8.4.1.5)
read-only
INTEGER
opInProgress(1)
opSuccess(2)
opUnknownFailure(3)
opInvalidFile(4)
opDeviceFull(5)
opFileOpenError(6)
Operation result.
As per the MIB.
hh3cSysBootPackageTable
About this table
This table specifies boot images.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
The value of hh3cSysBootPackageIndex must exist in hh3cSysPackageTable when you create a row. Before specifying boot images, make sure hh3cSysBootIpeTable is empty.
Columns
The table index is hh3cSysBootPackageIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysBootPackageIndex (1.3.6.1.4.1.25506.2.3.1.9.2.1.1)
not-accessible
Integer32
Table index.
Same with the index of a package file in hh3cSysPackageTable.
hh3cSysBootPackageRowStatus (1.3.6.1.4.1.25506.2.3.1.9.2.1.2)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cSysBootIpeTable
About this table
This table specifies IPE files for startup.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
The value of hh3cSysBootIpeIndex must exist in hh3cSysIpeFileTable when you create a row. Before specifying IPE files, make sure hh3cSysBootPackageTable is empty.
Columns
The table index is hh3cSysBootIpeIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysBootIpeIndex (1.3.6.1.4.1.25506.2.3.1.9.3.1.1)
not-accessible
Integer32
IPE file index.
Same with the index of an IPE file in hh3cIpeFileTable.
hh3cSysBootIpeRowStatus (1.3.6.1.4.1.25506.2.3.1.9.3.1.2)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
hh3cSysSetBootImageResultTable
About this table
This table contains operation result of setting boot images. To clear the records in this table, set h3cSysSetBootImageAction to done(2).
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysSetBootImageResultIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysSetBootImageResultIndex (1.3.6.1.4.1.25506.2.3.1.9.4.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Table index.
Same with the entity index of the device.
hh3cSysSetBootImageResultStatusOfEachCard (1.3.6.1.4.1.25506.2.3.1.9.4.1.2)
read-only
INTEGER
none(1)
doing(2)
success(3)
failed(4)
Operation status.
As per the MIB.
hh3cSysSetBootImageFailedReasonOfEachCard (1.3.6.1.4.1.25506.2.3.1.9.4.1.3)
read-only
DisplayString
Failure reason.
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-SYS-MAN-MIB module.
hh3cSysClockChangedNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.3.2.1
System time change
Informational
Warning
ON
This notification is generated when the system time is modified manually by the administrators, or is modified automatically by the clock protocol.
Status control
ON
CLI: Use the snmp-agent trap enable system command.
OFF
CLI: Use the undo snmp-agent trap enable system command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.3.1.1.1 (hh3cSysLocalClock)
System time after modification
No
DateAndTime
OCTET STRING (SIZE (8 | 11))
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve the issue:
1.     Verify that the timing configuration at the back end is correct.
2.     Modify the timing program that has been automatically invalid.
hh3cSysReloadNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.3.2.2
The system reboot policy took effect or changed
Informational
Warning
ON
This notification is generated when the reboot schedule configuration is to take effect or becomes invalid because of system time change.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.3.1.3.3.1.4 (hh3cSysReloadImage)
Image file used by the system reboot policy.
No
Integer32
0..2147483647
1.3.6.1.4.1.25506.2.3.1.3.3.1.3 (hh3cSysReloadCfgFile)
Configuration file used by the system reboot policy.
No
Integer32
0..2147483647
1.3.6.1.4.1.25506.2.3.1.3.3.1.5 (hh3cSysReloadReason)
Reason for system reboot.
No
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.3.1.3.3.1.6 (hh3cSysReloadScheduleTime)
Scheduled time at which the system reboot occurs.
No
DateAndTime
OCTET STRING (SIZE (8))
1.3.6.1.4.1.25506.2.3.1.3.2 (hh3cSysReloadAction)
Reload action of the system reboot policy.
No
INTEGER
reloadOnSchedule(2)
reloadAtOnce(3)
reloadCancel(4)
Recommended action
1.     If the system reboot policy is to take effect, wait for the system to reboot.
2.     If this notification is generated  because of system time change, reconfigure the reboot schedule based on the new system time.
hh3cSysStartUpNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.3.2.3
A system software image file became invalid
Informational
Warning
ON
This alarm occurs when the system fails to boot with the main packages or IPE files and boots with the backup packages or IPE files. The main packages or IPE files might be incompatible with the device.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.3.1.4.2.1.5 (hh3cSysImageType)
Type of the system software image files
No
INTEGER
backup(2)
Recommended action
1.     Verify that the system software image files are correct.
2.     If the issue persists, contact H3C Support.
