01-Fundamentals
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10001-Fundamentals
01-HH3C-CONFIG-MAN-MIB
01-HH3C-CONFIG-MAN-MIB 163.53 KB
HH3C-CONFIG-MAN-MIB
About this MIB
Use this MIB to manage the device configuration. For example, access this MIB to save, back up, or restore the configuration. This MIB also contains notifications about configuration changes.
The following figure shows the relationship among the device memory, local storage medium, and remote server in configuration backup and restoration:
MIB file name
hh3c-config-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cConfig(4)
Scalar objects
hh3cCfgRunModifiedLast
Object (OID)
Access
Value range
Implementation
hh3cCfgRunModifiedLast (1.3.6.1.4.1.25506.2.4.1.1.1)
read-only
TimeTicks
Standard MIB values.
Time when the running configuration was last modified.
As per the MIB.
hh3cCfgRunSavedLast
Object (OID)
Access
Value range
Implementation
hh3cCfgRunSavedLast (1.3.6.1.4.1.25506.2.4.1.1.2)
read-only
TimeTicks
Time when the running configuration was last saved.
As per the MIB.
hh3cCfgStartModifiedLast
Object (OID)
Access
Value range
Implementation
hh3cCfgStartModifiedLast (1.3.6.1.4.1.25506.2.4.1.1.3)
read-only
TimeTicks
Time when the next-startup configuration file used currently was last modified.
As per the MIB.
hh3cCfgLogLimitedEntries
Object (OID)
Access
Value range
Implementation
hh3cCfgLogLimitedEntries (1.3.6.1.4.1.25506.2.4.1.1.4)
read-only
Integer32
Integer32 (0..2147483647)
Maximum number of rows in the hh3cCfgLogTable.
As per the MIB.
hh3cCfgLogDeletedEntries
Object (OID)
Access
Value range
Implementation
hh3cCfgLogDeletedEntries (1.3.6.1.4.1.25506.2.4.1.1.5)
read-only
Counter32
Counter32 (0..2147483647)
Total number of rows deleted from the hh3cCfgLogTable.
As per the MIB.
hh3cCfgLogWantBackup
Object (OID)
Access
Value range
Implementation
hh3cCfgLogWantBackup (1.3.6.1.4.1.25506.2.4.1.1.6)
read-write
TruthValue
true(1)
false(2)
Whether to back up the values of objects for the hh3cCfgLogTable.
The value for IRF-incapable devices is false.
The value can be set to true for IRF-capable devices.
hh3cCfgOperateGlobalEntryLimit
Object (OID)
Access
Value range
Implementation
hh3cCfgOperateGlobalEntryLimit (1.3.6.1.4.1.25506.2.4.1.2.1)
read-only
Integer32
Integer32 (1..10)
Maximum number of rows in the hh3cCfgOperateTable.
As per the MIB.
hh3cCfgOperateEntryAgeOutTime
Object (OID)
Access
Value range
Implementation
hh3cCfgOperateEntryAgeOutTime (1.3.6.1.4.1.25506.2.4.1.2.2)
read-write
Integer32
Integer32 (1..60)
Aging time for entries in the hh3cCfgOperateTable, in minutes.
As per the MIB.
hh3cCfgOperateResultGlobalEntryLimit
Object (OID)
Access
Value range
Implementation
hh3cCfgOperateResultGlobalEntryLimit (1.3.6.1.4.1.25506.2.4.1.2.3)
read-write
Integer32
Integer32 (1..50)
Maximum number of rows in the hh3cCfgOperateResultTable.
As per the MIB.
hh3cCfgReset
Object (OID)
Access
Value range
Implementation
hh3cCfgReset
1.3.6.1.4.1.25506.2.4.1.2.7
read-write
INTEGER
normal(1)
reset(2)
Reboots the device with factory defaults.
As per the MIB.
hh3cCfgExecuteOperateResultEntryLimit
Object (OID)
Access
Value range
Implementation
hh3cCfgExecuteOperateResultEntryLimit (1.3.6.1.4.1.25506.2.4.1.2.6.1)
read-write
Integer32
Integer32 (5..20)
Maximum number of rows in the hh3cCfgExecuteResultTable.
As per the MIB.
hh3cCfgFirstTrapTime
Object (OID)
Access
Value range
Implementation
hh3cCfgFirstTrapTime (1.3.6.1.4.1.25506.2.4.1.1.8)
read-only
TimeTicks
TimeTicks (0..4294967295)
Time when the first notification was sent.
As per the MIB.
hh3cCfgBackupToServerIPType
Object (OID)
Access
Value range
Implementation
hh3cCfgBackupToServerIPType (1.3.6.1.4.1.25506.2.4.5.1)
accessible-for-notify
InetAddressType
unknown(0)
ipv4(1)
ipv6(2)
ipv4z(3)
ipv6z(4)
dns(16)
Server IP address type.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCfgBackupToServerIP (1.3.6.1.4.1.25506.2.4.5.2)
InetAddress
OCTET STRING (0..255)
Server IP address.
As per the MIB.
hh3cCfgBackupToServerVPNName
Object (OID)
Access
Value range
Implementation
hh3cCfgBackupToServerVPNName (1.3.6.1.4.1.25506.2.4.5.3)
DisplayString
Name of the VPN instance to which the server IP address belongs.
As per the MIB.
hh3cCfgBackupToServerTransType
Object (OID)
Access
Value range
Implementation
hh3cConfigBackupToServerTransType (1.3.6.1.4.1.25506.2.4.5.4)
INTEGER
ftp(1),
tftp(2),
scp(3)
File transfer method.
As per the MIB.
hh3cCfgBackupToServerFailReason
Object (OID)
Access
Value range
Implementation
hh3cConfigBackupToServerFailedReason (1.3.6.1.4.1.25506.2.4.5.5)
DisplayString
Backup failure reason.
As per the MIB.
hh3cCfgBackupToServerErrorCode
Object (OID)
Access
Value range
Implementation
hh3cConfigBackupToServerErrorCode (1.3.6.1.4.1.25506.2.4.5.6)
Integer32
Backup failure error code.
As per the MIB.
hh3cCfgRestoreType
Object (OID)
Access
Value range
Implementation
hh3cCfgRestoreType (1.3.6.1.4.1.25506.2.4.5.7)
INTEGER
binary(1)
text(2)
1 represents DBM configuration restoration.
2 represents text configuration restoration.
As per the MIB.
Tabular objects
hh3cCfgLogTable
About this table
Use this table to obtain configuration change records.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cCfgLogIndex.
Object (OID)
Access
Value range
Implementation
hh3cCfgLogIndex (1.3.6.1.4.1.25506.2.4.1.1.7.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Index of a configuration log.
As per the MIB.
hh3cCfgLogTime (1.3.6.1.4.1.25506.2.4.1.1.7.1.2)
read-only
TimeTicks
Time when the configuration log was generated.
As per the MIB.
hh3cCfgLogSrcCmd (1.3.6.1.4.1.25506.2.4.1.1.7.1.3)
read-only
INTEGER
cmdLine(1)
snmp(2)
other(3)
Type of the source command that caused the log generation.
As per the MIB.
hh3cCfgLogSrcData (1.3.6.1.4.1.25506.2.4.1.1.7.1.4)
read-only
INTEGER
erase(1)
runningData(2)
commandSource(3)
startupData(4)
local(5)
netFtp(6)
hotPlugging(7)
Source data recorded in the configuration log.
As per the MIB.
hh3cCfgLogDesData (1.3.6.1.4.1.25506.2.4.1.1.7.1.5)
read-only
INTEGER
unknown(1)
runningData(2)
commandSource(3)
startupData(4)
local(5)
netFtp(6)
hotPlugging(7)
Destination data recorded in the configuration log.
As per the MIB.
hh3cCfgLogTerminalType (1.3.6.1.4.1.25506.2.4.1.1.7.1.6)
read-only
INTEGER
notApplicable(1)
unknown(2)
console(3)
terminal(4)
virtual(5)
auxiliary(6)
Terminal type recorded in the configuration log.
As per the MIB.
hh3cCfgLogTerminalUser (1.3.6.1.4.1.25506.2.4.1.1.7.1.7)
read-only
DisplayString
OCTET STRING (0..64)
Name of the user that logged in to the CLI.
If the user uses SNMP to modify the device configuration, the value of this object is the SNMPv3 username.
hh3cCfgLogTerminalNum (1.3.6.1.4.1.25506.2.4.1.1.7.1.8)
read-only
Integer32
Integer32 (-2147483648..2147483647)
Number of terminals recorded in the configuration log.
If the value of hh3cCfgLogSrcCmd is not cmdLine, the value of this object must be -1.
hh3cCfgLogTerminalLocation (1.3.6.1.4.1.25506.2.4.1.1.7.1.9)
read-only
DisplayString
User location information recorded in the configuration log.
As per the MIB.
hh3cCfgLogCmdSrcAddress (1.3.6.1.4.1.25506.2.4.1.1.7.1.10)
read-only
IpAddress
OCTET STRING (4)
User IP address information recorded in the configuration log.
As per the MIB.
hh3cCfgLogVirHost (1.3.6.1.4.1.25506.2.4.1.1.7.1.11)
read-only
DisplayString
Host name of the remote system recorded in the configuration log.
If the value of hh3cCfgLogTerminalType is virtual, the value of this object is the host name of the remote system connected to the system.
In other situations, the value of this object is a zero-length string.
hh3cCfgLogUserName (1.3.6.1.4.1.25506.2.4.1.1.7.1.12)
read-only
DisplayString
Service username recorded in the configuration log.
If the value of the hh3cCfgLogSrcData and hh3cCfgLogDesData nodes are any values other than netFtp, the value of this node is a zero-length string.
hh3cCfgLogServerAddress (1.3.6.1.4.1.25506.2.4.1.1.7.1.13)
read-only
IpAddress
OCTET STRING (4)
Server address recorded in the configuration log.
If the values of the hh3cCfgLogSrcData and hh3cCfgLogDesData nodes are any values other than netFtp, the value of this node is 0.0.0.0.
hh3cCfgLogFile (1.3.6.1.4.1.25506.2.4.1.1.7.1.14)
read-only
DisplayString
Current configuration file name recorded in the configuration log.
As per the MIB.
hh3cCfgLogCmdSrcAddrType
(1.3.6.1.4.1.25506.2.4.1.1.7.1.15)
read-only
InetAddressType
unknown(0)
ipv4(1)
ipv6(2)
ipv4z(3)
ipv6z(4)
dns(16)
Type of the command source address recorded in the configuration log.
Not supported.
hh3cCfgLogCmdSrcAddrRev
(1.3.6.1.4.1.25506.2.4.1.1.7.1.16)
read-only
InetAddress
Command source address recorded in the configuration log.
Not supported.
hh3cCfgLogCmdSrcAddrVPNName(1.3.6.1.4.1.25506.2.4.1.1.7.1.17)
read-only
DisplayString
Name of the VPN instance to which the command source address belongs.
Not supported.
hh3cCfgLogServerAddrType
(1.3.6.1.4.1.25506.2.4.1.1.7.1.18)
read-only
InetAddressType
unknown(0)
ipv4(1)
ipv6(2)
ipv4z(3)
ipv6z(4)
dns(16)
Type of the server address recorded in the configuration log.
Not supported
hh3cCfgLogServerAddrRev
(1.3.6.1.4.1.25506.2.4.1.1.7.1.19)
read-only
InetAddress
Not supported.
hh3cCfgLogServerAddrVPNName(1.3.6.1.4.1.25506.2.4.1.1.7.1.20)
read-only
DisplayString
Name of the VPN instance to which the server address belongs.
Not supported.
hh3cCfgOperateTable
About this table
Use this MIB to manage configuration file transfers between the NMS and the device, for example, through FTP or TFTP.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
If the row status is active, you cannot modify the objects in the table.
Columns
The table index is hh3cCfgOperateIndex.
Object (OID)
Access
Value range
Implementation
hh3cCfgOperateIndex (1.3.6.1.4.1.25506.2.4.1.2.4.1.1)
not-accessible
Integer32
Index of a configuration file operation.
As per the MIB.
hh3cCfgOperateType (1.3.6.1.4.1.25506.2.4.1.2.4.1.2)
read-create
ConfigOperationType
running2Startup(1)
startup2Running(2)
running2Net(3)
net2Running(4)
net2Startup(5)
startup2Net(6)
running2File(7)
file2Running(8)
Operation type.
As per the MIB.
hh3cCfgOperateProtocol (1.3.6.1.4.1.25506.2.4.1.2.4.1.3)
read-create
INTEGER
ftp(1)
tftp(2)
clusterftp(3)
clustertftp(4)
Protocol used for file transfer.
As per the MIB.
hh3cCfgOperateFileName (1.3.6.1.4.1.25506.2.4.1.2.4.1.4)
read-create
DisplayString
OCTET STRING (1..128)
Configuration file name.
As per the MIB.
hh3cCfgOperateServerAddress (1.3.6.1.4.1.25506.2.4.1.2.4.1.5)
read-create
IpAddress
OCTET STRING (4)
Address of the remote configuration file server.
As per the MIB.
hh3cCfgOperateUserName (1.3.6.1.4.1.25506.2.4.1.2.4.1.6)
read-create
DisplayString
OCTET STRING (0..40)
Username used to access the remote server.
If the value of hh3cCfgOperateType is running2Net, net2Running, net2Startup, or startup2Net and the value of hh3cCfgOperateProtocol is ftp, this node represents the username used to access the FTP server. In this case, you must specify this node for the create operation.
hh3cCfgOperateUserPassword (1.3.6.1.4.1.25506.2.4.1.2.4.1.7)
read-create
DisplayString
Password used to access the remote server.
If the value of hh3cCfgOperateType is running2Net, net2Running, net2Startup, or startup2Net and the value of hh3cCfgOperateProtocol is ftp, this node represents the password used to access the FTP server. In this case, you must specify this node for the create operation.
When read, this node returns a zero-length string.
hh3cCfgOperateEndNotificationSwitch (1.3.6.1.4.1.25506.2.4.1.2.4.1.8)
read-create
TruthValue
true(1)
false(2)
Whether to notify that the operation completes. By default, the value is false.
As per the MIB.
hh3cCfgOperateRowStatus (1.3.6.1.4.1.25506.2.4.1.2.4.1.9)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
A row entry cannot be modified if its row status is active.
hh3cCfgOperateServerPort
(1.3.6.1.4.1.25506.2.4.1.2.4.1.10)
read-create
Integer32
Integer32 (0..65535)
Remote port number.
If the value is an invalid port number, the default port number is used.
As per the MIB.
hh3cCfgOperateSrvAddrType
(1.3.6.1.4.1.25506.2.4.1.2.4.1.11)
read-create
InetAddressType
unknown(0)
ipv4(1)
ipv6(2)
ipv4z(3)
ipv6z(4)
dns(16)
Address type of the remote server.
Supports only ipv4, ipv6, and dns.
hh3cCfgOperateSrvAddrRev
(1.3.6.1.4.1.25506.2.4.1.2.4.1.12)
read-create
InetAddress
Address of the remote server.
If the value of the hh3cCfgOperateSrvAddrType object is ipv4, ipv6, or dns, you must specify this object.
An IPv4 address is in dotted decimal notation.
An IPv6 address is a colon-separated hexadecimal string.
A DNS address is a string of up to 253 characters.
hh3cCfgOperateSrvVPNName(1.3.6.1.4.1.25506.2.4.1.2.4.13)
read-create
DisplayString
Name of the VPN instance to which the remote server belongs.
As per the MIB.
About this table
Use this table to obtain the creation result of rows in the hh3cCfgOperateTable.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
A row is automatically created or deleted in this table for each row created or deleted in the hh3cCfgOperateTable.
Columns
The table index is hh3cCfgOperateResultIndex.
Object (OID)
Access
Value range
Implementation
hh3cCfgOperateResultIndex (1.3.6.1.4.1.25506.2.4.1.2.5.1.1)
not-accessible
Integer32
Index of the hh3cCfgOperateResultIndex table.
As per the MIB.
hh3cCfgOperateResultOptIndex (1.3.6.1.4.1.25506.2.4.1.2.5.1.2)
read-only
Integer32
Index of a configuration file operation in the hh3cCfgOperateTable.
As per the MIB.
hh3cCfgOperateResultOpType (1.3.6.1.4.1.25506.2.4.1.2.5.1.3)
read-only
ConfigOperationType
running2Startup(1)
startup2Running(2)
running2Net(3)
net2Running(4)
net2Startup(5)
startup2Net(6)
running2File(7)
file2Running(8)
Type of the operation.
As per the MIB.
hh3cCfgOperateState (1.3.6.1.4.1.25506.2.4.1.2.5.1.4)
read-only
ConfigOperationStateType
opInProgress(1)
opSuccess(2)
opInvalidOperation(3)
opInvalidProtocol(4)
opInvalidSourceName(5)
opInvalidDestName(6)
opInvalidServerAddress(7)
opDeviceBusy(8)
opDeviceOpenError(9)
opDeviceError(10)
opDeviceNotProgrammable(11)
opDeviceFull(12)
opFileOpenError(13)
opFileTransferError(14)
opFileChecksumError(15)
opNoMemory(16)
opAuthFail(17)
opTimeOut(18)
opUnknownFailure(19)
opInvalidConfigFile(20)
opSlaveFull(21)
opCopyToSlaveFailure(22)
Operation state type.
If the value is opFileOpenError(13), the configuration file might be invalid, might not exist, or might not be accessible.
hh3cCfgOperateTime (1.3.6.1.4.1.25506.2.4.1.2.5.1.5)
read-only
TimeTicks
Time when the configuration started.
As per the MIB.
hh3cCfgOperateEndTime (1.3.6.1.4.1.25506.2.4.1.2.5.1.6)
read-only
TimeTicks
Time when the configuration was finished.
As per the MIB.
hh3cCfgOperFailReason
(1.3.6.1.4.1.25506.2.4.1.2.5.1.7)
read-only
DisplayString
Failure reason of the configuration file operation.
As per the MIB.
hh3cCfgOperateFailCmd
(1.3.6.1.4.1.25506.2.4.1.2.5.1.8)
read-only
DisplayString
OCTET STRING (0..512)
Command that caused the configuration file operation failure.
As per the MIB.
hh3cCfgOperateFailCmdView
(1.3.6.1.4.1.25506.2.4.1.2.5.1.9)
read-only
DisplayString
OCTET STRING (0..264)
View in which the command was executed and caused the configuration file operation failure.
As per the MIB.
hh3cCfgOperateFailCmdReason
(1.3.6.1.4.1.25506.2.4.1.2.5.1.10)
read-only
DisplayString
Failure reason.
Possible failure reasons:
·     Failed to execute command.
·     Failed to parse command.
About this table
Use this table to obtain execution results about the startup2Running, net2Running, and file2Running operations created in the hh3cCfgOperateTable.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
A row is automatically created in this table for each row created in the hh3cCfgOperateTable if the operation type of the row in the hh3cCfgOperateTable is startup2Running, net2Running, or file2Running.
Columns
The table index is hh3cCfgExecuteResultIndex.
Object (OID)
Access
Value range
Implementation
hh3cCfgExecuteResultIndex (1.3.6.1.4.1.25506.2.4.1.2.6.2.1.1)
not-accessible
Integer32
Index of a configuration file execution result.
As per the MIB.
hh3cCfgExecuteResultOptIndex (1.3.6.1.4.1.25506.2.4.1.2.6.2.1.2)
read-only
Integer32
Index of a configuration file execution in the hh3cCfgOperateTable.
As per the MIB.
hh3cCfgExecuteResultOpType (1.3.6.1.4.1.25506.2.4.1.2.6.2.1.3)
read-only
ConfigOperationType
running2Startup(1)
startup2Running(2)
running2Net(3)
net2Running(4)
net2Startup(5)
startup2Net(6)
running2File(7)
file2Running(8)
Operation type of the configuration file execution.
As per the MIB.
hh3cCfgExecuteState (1.3.6.1.4.1.25506.2.4.1.2.6.2.1.4)
read-only
opInProgress(1)
opSuccess(2)
opDeviceBusy(8)
opDeviceError(10)
opDeviceFull(12)
opFileOpenError(13)
opNoMemory(16)
opAuthFail(17)
opTimeOut(18)
opSlaveFull(21)
Configuration fie execution status.
As per the MIB.
hh3cCfgExecuteTime (1.3.6.1.4.1.25506.2.4.1.2.6.2.1.5)
read-only
TimeTicks
Time when the configuration file execution started.
As per the MIB.
hh3cCfgExecuteEndTime (1.3.6.1.4.1.25506.2.4.1.2.6.2.1.6)
read-only
TimeTicks
Time when the configuration file execution ended.
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-CONFIG-MAN-MIB module.
hh3cCfgManEventlog
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.4.2.1
Configuration change event.
Informational
N/A
N/A
ON
This notification is generated as follows:
Configuration source (hh3cCfgLogSrcCmd)
Source data (hh3cCfgLogSrcData)
Destination data (hh3cCfgLogDesData)
Notification generation
cmdLine(1)
runningData(2)
startupData(4)
This notification is generated when the save command is used.
snmp(2)
startupData(4)
runningData(2)
The system automatically detects the running configuration at intervals (on majority devices, the interval is 10 minutes).
This notification is generated when the system detects that new configuration is submitted to the running configuration.
Status control
ON
CLI: Use the snmp-agent trap enable configuration command.
OFF
CLI: Use the undo snmp-agent trap enable configuration command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.4.1.1.7.1.3 (hh3cCfgLogSrcCmd)
Configuration source.
No
INTEGER
cmdLine(1)
snmp(2)
1.3.6.1.4.1.25506.2.4.1.1.7.1.4 (hh3cCfgLogSrcData)
Source data.
No
INTEGER
runningData(2)
startupData(4)
1.3.6.1.4.1.25506.2.4.1.1.7.1.5 (hh3cCfgLogDesData)
Destination data.
No
INTEGER
runningData(2)
startupData(4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Check the system running configuration. If necessary, save the running configuration.
hh3cCfgOperateCompletion
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.4.2.2
A configuration operation completed.
Informational
N/A
N/A
ON
This notification is generated when a configuration operation performed through the hh3cCfgOperateTable completes if the value of hh3cCfgOperateEndNotificationSwitch is true.
Parameters included in this notification vary by operation type. For more information, see the online help for the NMS.
Status control
ON
·     CLI: Use the snmp-agent trap enable configuration command.
·     MIB: Set hh3cCfgOperateEndNotificationSwitch to true(1).
OFF
·     CLI: Use the undo snmp-agent trap enable configuration command.
·     MIB: Set hh3cCfgOperateEndNotificationSwitch to false(2).
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.4.1.2.4.1.2 (hh3cCfgOperateType)
Operation type.
No
ConfigOperationType
running2Startup(1)
startup2Running(2)
running2Net(3)
net2Running(4)
net2Startup(5)
startup2Net(6)
1.3.6.1.4.1.25506.2.4.1.2.5.1.5 (hh3cCfgOperateTime)
Operation start time.
No
TimeTicks
1.3.6.1.4.1.25506.2.4.1.2.5.1.4 (hh3cCfgOperateState)
Operation status.
No
INTEGER
opInProgress(1)
opSuccess(2)
opDeviceBusy(8)
opDeviceError(10)
opDeviceFull(12)
opFileOpenError(13)
opNoMemory(16)
opAuthFail(17)
opTimeOut(18)
opSlaveFull(21)
1.3.6.1.4.1.25506.2.4.1.2.5.1.6 (hh3cCfgOperateEndTime)
Operation end time
No
TimeTicks
1.3.6.1.4.1.25506.2.4.1.2.5.1.7 (hh3cCfgOperFailReason)
Failure reason.
No
DisplayString
OCTET STRING (SIZE (0..255))
Recommended action
No action is required.
hh3cCfgInvalidConfigFile
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.4.2.3
An invalid file was used for configuration restoration.
Informational
N/A
N/A
ON
This notification is generated when the system detects that the configuration file used for configuration restoration is invalid.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Operation type.
No
ConfigOperationType
net2Running(4)
net2Startup(5)
1.3.6.1.4.1.25506.2.4.1.2.4.1.4 (hh3cCfgOperateFileName)
No
DisplayString
OCTET STRING (SIZE (1..128))
Recommended action
Verify that the configuration file is valid and use a valid configuration file for configuration restoration.
hh3cCfgBackupToServerSuccess
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.4.4.0.1
A configuration file was backed up to a server successfully.
Informational
N/A
N/A
ON
This notification is generated when a configuration file is backed up to a server successfully.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.4.4.1 (hh3cCfgBackupToServerIPType)
No
InetAddressType
As per the MIB.
1.3.6.1.4.1.25506.2.4.4.2 (hh3cCfgBackupToServerIP)
Server IP address.
No
InetAddress
As per the MIB.
1.3.6.1.4.1.25506.2.4.4.3 (hh3cCfgBackupToServerVPNName)
No
DisplayString
As per the MIB.
1.3.6.1.4.1.25506.2.4.4.4 (hh3cConfigBackupToServerTransType)
No
INTEGER
As per the MIB.
Recommended action
hh3cCfgBackupToServerFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.4.4.0.2
Failed to back up a configuration file to a server.
Informational
N/A
N/A
ON
This notification is generated when the system fails to back up a configuration file to a server.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
InetAddressType
As per the MIB.
Server IP address.
No
InetAddress
As per the MIB.
No
DisplayString
As per the MIB.
No
INTEGER
As per the MIB.
1.3.6.1.4.1.25506.2.4.4.3 (hh3cConfigBackupToServerFailedReason)
No
DisplayString
As per the MIB.
1.3.6.1.4.1.25506.2.4.4.4 (hh3cConfigBackupToServerErrorCode)
No
INTEGER
As per the MIB.
Recommended action
Handle the issue according to the failure reason.
hh3cCfgRestoreSuccess
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.4.4.0.3
The main startup configuration file was restored successfully.
Informational
N/A
N/A
ON
This notification is generated when the main startup configuration file is restored successfully.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.4.4.6 (hh3cCfgRestoreType)
Configuration restoration type.
No
INTEGER
binary(1)
text(2)
Recommended action
