| 01-Hardware Information and Specifications | 882.37 KB |
1 Product models and technical specifications
3 Removable components and compatibility matrixes
Product models
Table1-1 Switch series and models
Model |
Product code (PID) |
S6530X switch series |
S6530X-48Y8C |
LS-6530X-48Y8C |
S6530X-48X8C |
LS-6530X-48X8C |
S6530X-24Y8C |
LS-6530X-24Y8C |
S6530X-24X8C |
LS-6530X-24X8C |
Technical specifications
Table1-2 Technical specifications
Item |
S6530X-48Y8C |
S6530X-48X8C |
S6530X-24Y8C |
S6530X-24X8C |
Dimensions (H × W × D) |
44 × 440 × 400 mm (1.73 × 17.32 × 15.75 in) |
Weight |
≤ 7.6 kg (16.75 lb) |
≤ 7.3 kg (16.09 lb) |
Console port |
1 × serial console port |
USB port |
1 |
Management Ethernet port |
1 |
SFP+ port |
N/A |
48 |
N/A |
24 |
SFP28 port |
48 |
N/A |
24 |
N/A |
QSFP28 port |
8 |
8 |
8 |
8 |
Power supply slot |
2 |
Fan tray slot |
5 |
Input voltage |
AC input for the PSR250-12A/PSR250-12A1 power supply: · Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz · Max voltage range: 90 VAC to 290 VAC @ 47 Hz to 63 Hz HVDC input for the PSR250-12A/PSR250-12A1 power supply: · Rated voltage: 240 VDC · Max voltage range: 180 VDC to 320 VDC PSR450-12D power supply: · Rated voltage range: –48 VDC to –60 VDC · Max voltage range: –36 VDC to –72 VDC DC power source for the PSR450-12D power supply: –48 VDC power source in the equipment room or an RPS (H3C RPS1600-A) |
Minimum power consumption |
Single power input: 76 W Dual power inputs: 83 W |
Maximum power consumption |
Single power input: 223 W Dual power inputs: 227 W |
Single power input: 217 W Dual power inputs: 221 W |
Single power input: 188 W Dual power inputs: 193 W |
Single power input: 186 W Dual power inputs: 191 W |
Chassis leakage current compliance |
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/IEC60950-1/GB4943.1 |
Melting current of power supply fuse |
PSR250-12A/PSR250-12A1 power supply: 6.3 A/250 V PSR450-12D power supply: 20 A/125 V |
Operating temperature |
–5°C to +45°C (23°F to 113°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Fire resistance compliance |
2 Chassis views
S6530X-48Y8C
Figure2-1 Front panel
(1) SFP28 port |
(2) SFP28 port LED |
(3) QSFP28 port |
(4) QSFP28 port LED |
(5) System status LED (SYS) |
(1) Management Ethernet port LED (ACT) |
(2) Management Ethernet port LED (LINK) |
(3) Console port |
(4) Fan tray 1 |
(5) Fan tray 2 |
(6) Fan tray 3 |
(7) Fan tray 4 |
(8) Fan tray 5 |
(9) Power supply 1 |
(10) Power supply 2 |
(11) USB port |
(12) Reset button (RESET) |
(13) Serial label pull tab |
(14) Management Ethernet port (MGMT) |
(15) Grounding screw |
The SN serial number and MAC address of the S6530X-48Y8C switch can be found on the serial label pull tab.
The S6530X-48Y8C switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-2, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S6530X-48Y8C switch came with five fan tray slots empty. You must install five fan trays of the same model for the switch. In Figure2-2, five LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S6530X-48Y8C switch provides a reset button on the rear panel for you to reset the switch.
To use both the console port and USB port on the S6530X-48Y8C switch, use a small-sized USB drive or a USB extension cable.
The S6530X switch series supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S6530X-48X8C
Figure2-3 Front panel
(1) SFP+ port |
(2) SFP+ port LED |
(3) QSFP28 port |
(3) Console port |
(4) Fan tray 1 |
(5) Fan tray 2 |
(6) Fan tray 3 |
(7) Fan tray 4 |
(8) Fan tray 5 |
(11) USB port |
The SN serial number and MAC address of the S6530X-48X8C switch can be found on the serial label pull tab.
The S6530X-48X8C switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S6530X-48X8C switch came with five fan tray slots empty. You must install five fan trays of the same model for the switch. In Figure2-4, five LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S6530X-48X8C switch provides a reset button on the rear panel for you to reset the switch.
To use both the console port and USB port on the S6530X-48X8C switch, use a small-sized USB drive or a USB extension cable.
S6530X-24Y8C
Figure2-5 Front panel
(1) SFP28 port |
(3) QSFP28 port |
(3) Console port |
(4) Fan tray 1 |
(5) Fan tray 2 |
(6) Fan tray 3 |
(7) Fan tray 4 |
(8) Fan tray 5 |
(11) USB port |
The SN serial number and MAC address of the S6530X-24Y8C switch can be found on the serial label pull tab.
The S6530X-24Y8C switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-6, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S6530X-24Y8C switch came with five fan tray slots empty. You must install five fan trays of the same model for the switch. In Figure2-6, five LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S6530X-24Y8C switch provides a reset button on the rear panel for you to reset the switch.
To use both the console port and USB port on the S6530X-24Y8C switch, use a small-sized USB drive or a USB extension cable.
S6530X-24X8C
Figure2-7 Front panel
(1) SFP+ port |
(2) SFP+ port LED |
(3) QSFP28 port |
(3) Console port |
(4) Fan tray 1 |
(5) Fan tray 2 |
(6) Fan tray 3 |
(7) Fan tray 4 |
(8) Fan tray 5 |
(11) USB port |
The SN serial number and MAC address of the S6530X-24X8C switch can be found on the serial label pull tab.
The S6530X-24X8C switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-8, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S6530X-24X8C switch came with five fan tray slots empty. You must install five fan trays of the same model for the switch. In Figure2-8, five LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S6530X-24X8C switch provides a reset button on the rear panel for you to reset the switch.
To use both the console port and USB port on the S6530X-24X8C switch, use a small-sized USB drive or a USB extension cable.
The switch supports removable components. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
FRU model |
S6530X-48Y8C S6530X-48X8C S6530X-24Y8C S6530X-24X8C |
Removable power supplies |
PSR250-12A |
Supported |
PSR250-12A1 |
Supported |
PSR450-12D |
Supported |
Removable fan trays |
LSPM1FANSA-SN |
Supported |
LSPM1FANSB-SN |
Supported |
The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supply you have installed on the switch.
The switch provides two power supply slots. One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy. Do not install power supplies of different models on the same switch.
The switch uses removable fan trays. Do not power on the switch if it does not have five fan trays of the same model installed.
Table3-2 Power supplies available for the switch
Power supply model |
AC or DC input |
Specifications |
PSR250-12A PSR250-12A1 |
AC input |
· Rated input voltage range: 100 to 240 VAC @ 50/60 Hz · Max input voltage range: 90 to 290 VAC @ 47 to 63 Hz · Max output power: 250 W |
HVDC input |
· Rated input voltage: 240 VDC · Max input voltage range: 180 to 320 VDC · Max output power: 250 W |
PSR450-12D |
DC input |
· Rated input voltage range: –48 VDC to –60 VDC · Max input voltage range: –36 VDC to –72 VDC · Max output power: 450 W |
Removable fan trays
Table3-3 Fan tray specifications
Fan tray model |
Item |
Specifications |
· LSPM1FANSA-SN (from the power supply side to the port side) · LSPM1FANSB-SN (from the port side to the power supply side) |
Quantity |
One 40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in) fan |
Fan speed |
20000 R.P.M |
Max airflow |
20 CFM (0.57 m3/min) |
Input voltage |
12 V |
Power consumption |
9.8 W |
Documentation reference |
H3C LSPM1FANSA-SN & LSPM1FANSB-SN Fan Trays User Guide |
4 Ports and LEDs
Ports
Console port
Table4-1 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
Compliant standard |
EIA/TIA-232 |
Port transmission rate |
9600 bps (default) to 115200 bps |
Services |
· Provides connection to an ASCII terminal · Provides connection to the serial port of a local PC running terminal emulation program |
Compatible devices |
All device models |
Table4-2 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X autosensing |
Transmission medium |
Category-5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i, 802.3u, and 802.3ab |
Functions and services |
Switch software and Boot ROM upgrade, network management |
All device models |
Usage guidelines |
Do not forcibly configure a management Ethernet port to operate at 1000 Mbps in full duplex mode. |
USB port
Table4-3 USB port specifications
Item |
Specification |
Interface type |
USB 2.0 |
OHC |
Uploads and downloads data at a rate up to 480 Mbps |
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files |
All device models |
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
SFP+ port
Table4-4 SFP+ port specifications
Item |
Specification |
Interface type |
SFP+ port |
Compatible transceiver modules and cables |
· 10GE SFP+ transceiver modules and cables in Table4-5, Table4-6, and Table4-7 · GE SFP transceiver modules and cables in Table4-8 |
S6530X-48X8C and S6530X-24X8C switches |
Table4-5 10GE SFP+ transceiver modules available for the SFP+ ports
10GE SFP+ transceiver module |
Central wavelength (nm) |
Connector |
Fiber diameter (µm) |
Modal bandwidth (MHz × km) |
SFP-XG-SX-MM850-D |
850 |
LC |
Multi-mode, 50/125 |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
Multi-mode, 62.5/125 |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310-E |
1310 |
LC |
Single-mode, 9/125 |
N/A |
10 km (6.21 miles) |
SFP-XG-LX-SM1310 |
1310 |
LC |
N/A |
SFP-XG-LX-SM1310-D |
1310 |
LC |
N/A |
SFP-XG-LH40-SM1550 |
1550 |
LC |
N/A |
40 km (24.86 miles) |
SFP-XG-LH40-SM1550-D |
1550 |
LC |
N/A |
SFP-XG-LH80-SM1550 |
1550 |
LC |
N/A |
80 km (49.71 miles) |
SFP-XG-LH80-SM1550-D |
1550 |
LC |
N/A |
SFP-XG-LX-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
N/A |
SFP-XG-LX-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
N/A |
SFP-XG-LH40-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
N/A |
SFP-XG-LH40-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
N/A |
SFP-XG-LH80-SM1490-BIDI |
TX: 1490 RX: 1550 |
LC |
N/A |
SFP-XG-LH80-SM1550-BIDI |
TX: 1550 RX: 1490 |
LC |
N/A |
IMPORTANT: The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table4-6 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable |
Cable length |
LSWM1STK |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
Table4-7 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable |
Cable length |
SFP-XG-D-AOC-7M |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
Table4-8 GE SFP transceiver modules and cables available for the SFP+ ports
GE SFP transceiver module and cable |
Connector |
Cable/Fiber type and diameter (µm) |
SFP copper transceiver modules |
SFP-GE-T |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP fiber transceiver modules |
SFP-GE-SX-MM850-A |
850 |
LC |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
500 |
400 |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
N/A |
500 or 400 |
500 |
SFP-GE-LH40-SM1310 |
1310 |
LC |
N/A |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
N/A |
SFP-GE-LH40-SM1550 |
1550 |
LC |
N/A |
SFP-GE-LH80-SM1550 |
1550 |
LC |
N/A |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
N/A |
SFP-GE-LH100-SM1550 |
1550 |
LC |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 RX: 1490 |
LC |
N/A |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 RX: 1310 |
LC |
N/A |
SFP-GE-LH40-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
N/A |
SFP-GE-LH40-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
N/A |
SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules and SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module. |
Figure4-1 SFP+ cable
(1) Connector |
(2) Pull latch |
NOTE: The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff. |
SFP28 port
Table4-9 SFP28 port specifications
Item |
Specification |
Interface type |
SFP28 port |
· SFP28 transceiver modules and cables in Table4-10 and Table4-11 · 10GE SFP+ transceiver modules and cables in Table4-5, Table4-6, and Table4-7 · GE SFP transceiver modules and cables in Table4-8 |
S6530X-48Y8C and S6530X-24Y8C |
Table4-10 SFP28 transceiver modules available for the SFP28 ports
SFP28 transceiver module |
Connector |
SFP-25G-SR-MM850 |
850 |
LC |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
SFP-25G-LR-SM1310 |
1310 |
LC |
N/A |
Table4-11 SFP28 cables available for the SFP28 ports
SFP28 cable |
Cable length |
SFP-25G-D-CAB-1M |
1 m (3.28 ft) |
SFP-25G-D-CAB-3M |
3 m (9.84 ft) |
SFP-25G-D-CAB-5M |
5 m (16.40 ft) |
(1) Connector |
(2) Pull latch |
NOTE: The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff. |
QSFP28 ports
Table4-12 QSFP28 port specifications
Item |
Specification |
Interface type |
QSFP28 port |
· QSFP28 transceiver modules and cables in Table4-13, Table4-14, Table4-15, and Table4-16 · QSFP+ transceiver modules and cables in Table4-17, Table4-18, Table4-19, and Table4-20 |
All device models |
Usage guidelines |
· On an S6530X-48X8C or S6530X-24X8C switch, a QSFP28 port operates at 40 Gbps by default. You can increase the port speed to 100 Gbps by installing a license. To have the port operate at 100 Gbps, active the license by executing the active port basic-license command. For more information about the command, see Ethernet interface commands in the command reference for the switch. · You can install two types of licenses on the S6530X-48X8C or S6530X-24X8C switch to increase the speed of two or four QSFP28 ports to 100 Gbps. · You can install multiple licenses on the S6530X-48X8C or S6530X-24X8C switch and increase the speed of a maximum of eight QSFP28 ports to 100 Gbps. · For more information about licenses, see H3C Switches & Routers Licensing Guide. · When you connect an S6530X-24Y8C-G or S6530X-48Y8C-G switch to a device (not an S6530X switch) through a SFP28 port installed with a 25G transceiver module, make sure the two ports on the local and peer ends are in the same FEC mode. |
Table4-13 QSFP28 transceiver modules available for the QSFP28 ports
QSFP28 transceiver module |
Connector |
Modal bandwidth (MHz*km) |
Maximum transmission distance |
QSFP-100G-SR4-MM850 |
850 |
MPO |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
QSFP-100G-eSR4-MM850 |
850 |
MPO |
4700 |
300 m (984.25 ft) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 1295.56 · 1300.05 · 1304.58 · 1309.14 |
LC |
Single mode, 9/125 |
N/A |
QSFP-100G-LR4L-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
N/A |
2 km (1.24 miles) |
QSFP-100G-ER4L-WDM1300 |
LC |
N/A |
Table4-14 100G QSFP28 fiber cables available for the QSFP28 ports
QSFP28 fiber cable |
Cable length |
QSFP-100G-D-AOC-7M |
7 m (22.97 ft) |
QSFP-100G-D-AOC-10M |
10 m (32.81 ft) |
Table4-15 QSFP28 to SFP28 copper cables available for the QSFP28 ports
Cable length |
QSFP-100G-4SFP-25G-CAB-1M |
1 m (3.28 ft) |
QSFP-100G-4SFP-25G-CAB-3M |
3 m (9.84 ft) |
QSFP-100G-4SFP-25G-CAB-5M |
5 m (16.40 ft) |
Table4-16 100G QSFP28 copper cables available for the QSFP28 ports
QSFP28 copper cable |
Cable length |
QSFP-100G-D-CAB-1M |
1 m (3.28 ft) |
QSFP-100G-D-CAB-3M |
3 m (9.84 ft) |
QSFP-100G-D-CAB-5M |
5 m (16.40 ft) |
Table4-17 QSFP+ transceiver modules available for the QSFP28 ports
QSFP+ transceiver module |
Connector |
QSFP-40G-SR4-MM850 |
850 |
MPO |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.13 ft) |
QSFP-40G-CSR4-MM850 |
850 |
MPO |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.34 ft) |
QSFP-40G-BIDI-SR-MM850 |
Two lanes: · 850 · 900 |
LC |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.13 ft) |
QSFP-40G-LR4-WDM1300 |
LC |
N/A |
QSFP-40G-LR4L-WDM1300 |
LC |
N/A |
2 km (1.24 miles) |
QSFP-40G-ER4-WDM1300 |
LC |
N/A |
Table4-18 40G QSFP+ copper cables available for the QSFP28 ports
QSFP+ copper cable |
LSWM1QSTK0 |
1 m (3.28 ft) |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
Table4-19 QSFP+ to SFP+ copper cables available for the QSFP28 ports
LSWM1QSTK3 |
1 m (3.28 ft) |
LSWM1QSTK4 |
3 m (9.84 ft) |
LSWM1QSTK5 |
5 m (16.40 ft) |
Table4-20 40G QSFP+ fiber cables available for the QSFP28 ports
QSFP+ fiber cable |
QSFP-40G-D-AOC-7M |
7 m (22.97 ft) |
QSFP-40G-D-AOC-20M |
20 m (65.62 ft) |
Figure4-3 100G QSFP28/40G QSFP+ copper cable
(1) Connector |
(2) Pull tab |
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-21 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch has started correctly. |
Flashing green (1 Hz) |
The switch is performing power-on self test (POST). |
Steady red |
The switch has failed the POST or is faulty. |
Off |
The switch is powered off. |
Table4-22 Management Ethernet port LED description
LED mark |
Status |
LINK |
Off |
No link is present on the port |
Steady green |
The port is operating at 10/100/1000 Mbps. |
ACT |
Off |
The port is not receiving or sending data. |
Flashing yellow |
The port is sending or receiving data. |
QSFP28 port LED
Table4-23 QSFP28 port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 100 Gbps. |
Flashing green |
The port is sending or receiving data at 100 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 10 Gbps, 25 Gbps, or 40 Gbps. |
Flashing yellow |
The port is sending or receiving data at 10 Gbps, 25 Gbps, or 40 Gbps. |
Off |
No transceiver module or cable has been installed or no link is present on the port. |
SFP28 port LEDs
Table4-24 SFP28 port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 25 Gbps. |
Flashing green |
The port is sending or receiving data at 25 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 1Gbps or 10 Gbps. |
Flashing yellow |
The port is sending or receiving data at 1 Gbps or 10 Gbps. |
Off |
SFP+ port LED
Table4-25 SFP+ port LED description
SFP+ port LED status |
Steady green |
A transceiver module or cable has been correctly installed. A link is present on the port and the port is operating at 10 Gbps. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed. A link is present on the port and the port is operating at 1 Gbps. |
Flashing yellow |
The port is sending or receiving data at 1 Gbps. |
Off |
Status LED on a power supply
The power supplies each have a LED to indicate the power supply operating status. For more information, see the user manual for the power supply.
Fan tray status LED on a fan tray
The LSPM1FANSA-SN and LSPM1FANSB-SN fan trays each have a LED to indicate the fan tray operating status.
Table4-26 Fan tray status LED description
Status |
On |
The fan tray is faulty. |
Off |
The fan tray is operating correctly. |
5 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
The switch uses removable fan trays and provides airflow from the port side to the power supply side or from the power supply side to the port side by using different types of fan trays. You must install five fan trays of the same model for the switch. Table5-1 describes the fan trays available for the switch.
Table5-1 Fan trays available for the switch
Switch model |
Fan tray model |
Airflow direction |
S6530X-48X8C S6530X-48Y8C S6530X-24Y8C S6530X-24X8C |
LSPM1FANSA-SN |
From the power supply side to the port side |
LSPM1FANSB-SN |
From the port side to the power supply side |
Figure5-1 Airflow direction for LSPM1FANSA-SN (S6530X-48Y8C)
Figure5-2 Airflow direction for LSPM1FANSB-SN (S6530X-48Y8C)
