Application Signature V7-APR-1.0.155
Release time:2023-05-19
HomeSupportResource CenterSecuritySignature Database ServicesSignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-APR-1.0.155.dat 2.66 MB
Version number
V7-APR-1.0.155
MD5 number
7ad5d46abb6b288926d302ba9a6aae2c
Update time
2023-05-12
New protocol list
Modified protocols:    [2]
----Meta4
----MondayCom
----MozCom
----MuCommander
----Netsuite
----PingCode
----PivotalTracker
----PuxaRapido
----Teambition
----Tita
----Tower
----TQYunHuJiaoZhongXin
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9489 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1525 predefined applications can be generated
  • Become a Partner
  • Partner Resources
