H3C UniServer BX608FE Switch Module User Guide-6W100
HomeSupportServersBlade ServerH3C UniServer B16000BX608FEInstall & UpgradeInstallation GuidesH3C UniServer BX608FE Switch Module User Guide-6W100
02-Appendixes
02-Appendixes 44.54 KB
Appendix A  Technical support
If you encounter any complicated problems during daily maintenance or troubleshooting, contact Technical Support.
Collecting fault information
Before contacting Technical Support, collect the following server information to facilitate troubleshooting:
·     Log and sensor information about the switch module.
·     Product serial number.
·     Product model and name.
·     Snapshots of error messages and descriptions.
·     Switch module insertion, replacement, and removal history in the chassis.
Preparing the maintenance tools
To facilitate troubleshooting, prepare the following tools:
·     Diagonal pliers.
·     Multimeter.
·     Interface cables (network cables for example).
·     Configuration terminal (PC for example).
·     ESD wrist strap, ESD gloves, or ESD clothing.
For more information about the tool descriptions, see "Installation tools."
Appendix B  Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: [email protected]
·     Website: http://www.h3c.com
Appendix C  Glossary
Item
H
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
R
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
Appendix D  Acronyms
Acronym
Full name
A
AE
App Engine
AMC
Auxiliary Management Controller
C
CLI
Command-Line Interface
F
FC
Fiber Channel
FCoE
Fibre Channel over Ethernet
FCF
FCoE Forwarder
I
ICM
Interconnect module
IRF
Intelligent Resilient Framework
M
Mezz
Mezzanine
N
NPV
N_Port Virtualization
O
OM
Onboard Manager
S
SOL
Serial Over LAN
SSH
Secure Shell
U
UID
Unit identification
