H3C WA6120H Access Point Installation Guide-6W100
HomeSupportWirelessWA6120H Access PointInstall & UpgradeInstallation GuidesH3C WA6120H Access Point Installation Guide-6W100
02-Appendix A AP view and technical specifications
Appendix A  Technical specifications
Table 1 Technical specifications
Item
Specification
Dimensions (H × W × D)
160 × 86 × 39 mm (6.30 × 3.39 × 1.54 in, excluding the mounting bracket)
Weight
350 g (12.35 oz)
Power consumption
≤ 15 W with a USB device attached
Power supply
·     Local power source
·     PoE power supply
Antenna
Built-in antenna:
·     2.4 G: 3 dBi gain
·     5 G: 5 dBi gain
Standards
·     802.11ax, 802.11ac, 802.11n
·     802.3af
