05-RADIUS-ACC-CLIENT-MIB | 45.09 KB |
About this MIB
Use this MIB to collect statistics about accounting packets of different types that a RADIUS client receives from RADIUS servers.
MIB file name
radius-acc-client.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).radiusMIB(67).radiusAccounting(2).radiusAccClientMIB(2)
Scalar objects
radiusAccClient
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
radiusAccClientInvalidServerAddresses (1.3.6.1.2.1.67.2.2.1.1.1) |
read-only |
Counter32 |
Standard MIB values. |
Number of unrecognizable IP addresses of accounting servers. |
As per the MIB. |
radiusAccClientIdentifier (1.3.6.1.2.1.67.2.2.1.1.2) |
read-only |
SnmpAdminString |
OCTET STRING (SIZE (0..255)) |
ID of a client. |
As per the MIB. |
Tabular objects
radiusAccServerTable
About this table
This table contains the statistics about accounting packets that a RADIUS client receives from a RADIUS server.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is radiusAccServerIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
radiusAccServerIndex (1.3.6.1.2.1.67.2.2.1.1.3.1.1) |
not-accessible |
Integer32 |
1..2147483647 |
Index of an accounting server. |
As per the MIB. |
radiusAccServerAddress (1.3.6.1.2.1.67.2.2.1.1.3.1.2) |
read-only |
IpAddress |
IP address of the accounting server. |
As per the MIB. |
radiusAccClientServerPortNumber (1.3.6.1.2.1.67.2.2.1.1.3.1.3) |
read-only |
Integer32 |
0..65535 |
Port number of the accounting server. |
As per the MIB. |
radiusAccClientRoundTripTime (1.3.6.1.2.1.67.2.2.1.1.3.1.4) |
read-only |
TimeTicks |
TimeTick |
Round trip time. |
As per the MIB. |
radiusAccClientRequests (1.3.6.1.2.1.67.2.2.1.1.3.1.5) |
read-only |
Counter32 |
Number of accounting requests sent to the server. |
As per the MIB. |
radiusAccClientRetransmissions (1.3.6.1.2.1.67.2.2.1.1.3.1.6) |
read-only |
Counter32 |
Number of accounting requests retransmitted. |
As per the MIB. |
radiusAccClientResponses (1.3.6.1.2.1.67.2.2.1.1.3.1.7) |
read-only |
Counter32 |
Number of accounting responses received. |
As per the MIB. |
radiusAccClientMalformedResponses (1.3.6.1.2.1.67.2.2.1.1.3.1.8) |
read-only |
Counter32 |
Number of malformed accounting responses received. |
As per the MIB. |
radiusAccClientBadAuthenticators (1.3.6.1.2.1.67.2.2.1.1.3.1.9) |
read-only |
Counter32 |
Number of Access-Reject packets received. |
As per the MIB. |
radiusAccClientPendingRequests (1.3.6.1.2.1.67.2.2.1.1.3.1.10) |
read-only |
Gauge32 |
Number of pending authentication requests. |
As per the MIB. |
radiusAccClientTimeouts (1.3.6.1.2.1.67.2.2.1.1.3.1.11) |
read-only |
Counter32 |
Number of timed out accounting requests. |
As per the MIB. |
radiusAccClientUnknownTypes (1.3.6.1.2.1.67.2.2.1.1.3.1.12) |
read-only |
Counter32 |
Number of packets with unknown types. |
As per the MIB. |
radiusAccClientPacketsDropped (1.3.6.1.2.1.67.2.2.1.1.3.1.13) |
read-only |
Counter32 |
Number of packets discarded. |
As per the MIB. |
