10-User Access and Authentication
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10010-User Access and Authentication
01-HH3C-8021X-EXT2-MIB
01-HH3C-8021X-EXT2-MIB 47.95 KB
HH3C-8021X-EXT2-MIB
About this MIB
Use this MIB to configure 802.1X parameters.
MIB file name
hh3c-8021x-ext2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3c8021XExt2(153)
Scalar objects
hh3c8021XExt2System
Object (OID)
Access
Value range
Implementation
hh3c8021XExt2AuthQuietPeriod (1.3.6.1.4.1.25506.2.153.1.1.1)
read-write
Unsigned32
Unsigned32 (10..120)
Quiet time after authentication failure.
As per the MIB.
hh3c8021XExt2AuthTxPeriod
(1.3.6.1.4.1.25506.2.153.1.1.2)
read-write
Unsigned32
Unsigned32 (1..120)
Username request timeout time.
As per the MIB.
hh3c8021XExt2AuthSuppTimeout
(1.3.6.1.4.1.25506.2.153.1.1.3)
read-write
Unsigned32
Unsigned32 (1..120)
Client response timeout time.
As per the MIB.
hh3c8021XExt2AuthServerTimeout
(1.3.6.1.4.1.25506.2.153.1.1.4)
read-write
Unsigned32
Unsigned32 (100..300)
Server response timeout time.
As per the MIB.
hh3c8021XExt2AuthMaxReq
(1.3.6.1.4.1.25506.2.153.1.1.5)
read-write
Unsigned32
Unsigned32 (1..10)
Maximum number of attempts to send an authentication request to the same client.
As per the MIB.
hh3c8021XExt2AuthReAuthPeriod
(1.3.6.1.4.1.25506.2.153.1.1.6)
read-write
Unsigned32
Unsigned32 (60..7200)
Periodic reauthentication interval on the access device.
As per the MIB.
hh3c8021XExt2AuthMethod
(1.3.6.1.4.1.25506.2.153.1.1.7)
read-write
INTEGER
chap(1),
pap(2),
eap(3)
EAP message handling method used by the access device.
As per the MIB.
Tabular objects
hh3c8021XExt2AuthConfigExtTable
About this table
Use this table to configure port-specific extended 802.1X features.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is dot1xPaePortNumber.
Object (OID)
Access
Value range
Implementation
hh3c8021XExt2PaePortAuthAdminStatus (1.3.6.1.4.1.25506.2.153.1.2.1.1.1)
read-write
TruthValue
true(1),
false(2)
Whether 802.1X is enabled on a port.
As per the MIB.
hh3c8021XExt2PaePortControlledType (1.3.6.1.4.1.25506.2.153.1.2.1.1.2)
read-write
INTEGER
portbased(1),
macbased(2)
Port access control method.
As per the MIB.
hh3c8021XExt2PaePortMaxUserNum (1.3.6.1.4.1.25506.2.153.1.2.1.1.3)
read-write
Unsigned32
Unsigned32 (1..4294967295)
Maximum number of concurrent users on the port.
As per the MIB.
hh3c8021XExt2PaePortUserNumNow (1.3.6.1.4.1.25506.2.153.1.2.1.1.4)
read-only
Unsigned32
Standard MIB values
Number of current online users on the port.
As per the MIB.
hh3c8021XExt2PaePortClearStatistics
(1.3.6.1.4.1.25506.2.153.1.2.1.1.5)
read-write
INTEGER
noClear(0),
clear(1)
Clears 802.1X statistics.
As per the MIB.
You can set the value only to clear(1).
hh3c8021XExt2PaePortMcastTrigStatus
(1.3.6.1.4.1.25506.2.153.1.2.1.1.6)
read-write
TruthValue
true(1),
false(2)
Whether to enable the multicast trigger.
As per the MIB.
hh3c8021XExt2PaePortHandshakeStatus
(1.3.6.1.4.1.25506.2.153.1.2.1.1.7)
read-write
TruthValue
true(1),
false(2)
Whether to send handshake packets.
As per the MIB.
