03-HH3C-RADIUS-MIB | 165.58 KB |
hh3cRdSecondaryAuthServerTable
hh3cRadiusAuthenticationServerUpTrap
hh3cRadiusAccountingServerUpTrap
hh3cRadiusAuthenticationServerDownTrap
HH3C-RADIUS-MIB
About this MIB
Use this MIB to obtain and configure RADIUS server settings.
MIB file name
hh3c-radius.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRadius(13)
Scalar objects
hh3cRadiusAuthErrThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRadiusAuthErrThreshold (1.3.6.1.4.1.25506.2.13.1.3.1) |
read-write |
Unsigned32 |
Unsigned32 (1..100) |
Authentication failure alarm threshold. |
As per the MIB. |
hh3cRadiusStatistic
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRadiusStatAccReq (1.3.6.1.4.1.25506.2.13.6.1) |
read-only |
Counter64 |
Standard MIB values. |
Number of RADIUS accounting requests sent to the RADIUS server, including start-accounting requests and real-time accounting requests. |
As per the MIB. |
hh3cRadiusStatAccAck (1.3.6.1.4.1.25506.2.13.6.2) |
read-only |
Counter64 |
Number of RADIUS accounting responses received from the RADIUS server. |
As per the MIB. |
hh3cRadiusStatLogoutReq (1.3.6.1.4.1.25506.2.13.6.3) |
read-only |
Counter64 |
Number of logout requests sent to the RADIUS server. |
As per the MIB. |
hh3cRadiusStatLogoutAck (1.3.6.1.4.1.25506.2.13.6.4) |
read-only |
Counter64 |
Number of logout responses received from the RADIUS server. |
As per the MIB. |
Tabular objects
hh3cRdInfoTable
About this table
Use this table to configure or obtain RADIUS authentication scheme settings. Each RADIUS scheme contains a primary authentication server, a secondary authentication server, and other settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cRdGroupName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRdGroupName (1.3.6.1.4.1.25506.2.13.1.1.1.1) |
not-accessible |
DisplayString |
OCTET STRING (1..32) |
Name of a RADIUS scheme. |
As per the MIB. |
hh3cRdPrimUdpPort (1.3.6.1.4.1.25506.2.13.1.1.1.3) |
read-create |
Integer32 |
Port number of the primary authentication server. |
Value range: 1 to 65535. |
hh3cRdPrimState (1.3.6.1.4.1.25506.2.13.1.1.1.4) |
read-create |
INTEGER |
active(1), block(2) |
Status of the primary authentication server. |
As per the MIB. |
hh3cRdSecUdpPort (1.3.6.1.4.1.25506.2.13.1.1.1.6) |
read-create |
Integer32 |
Port number of the secondary authentication server. |
hh3cRdSecState (1.3.6.1.4.1.25506.2.13.1.1.1.7) |
read-create |
INTEGER |
Status of the secondary authentication server. |
As per the MIB. |
hh3cRdKey (1.3.6.1.4.1.25506.2.13.1.1.1.8) |
read-create |
DisplayString |
Shared key for communication with the authentication server. |
The shared key is a string of 0 to 64 characters. When read, this object returns a zero-length string. |
hh3cRdRetry (1.3.6.1.4.1.25506.2.13.1.1.1.9) |
read-create |
Integer32 |
Maximum number of attempts for transmitting an authentication packet to the authentication server. |
Value range: 1 to 20. |
hh3cRdTimeout (1.3.6.1.4.1.25506.2.13.1.1.1.10) |
read-create |
Integer32 |
Response timeout time for the RADIUS authentication server, in seconds. |
Value range: 1 to 10. |
hh3cRdPrimAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.1.1.11) |
read-create |
InetAddressType |
Type of the IP address for the primary authentication server. |
You must specify hh3cRdPrimAuthIpAddrType and hh3cRdPrimAuthIpAddr in pairs in an SNMP request. |
hh3cRdPrimAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.1.1.12) |
read-create |
InetAddress |
OCTET STRING (0..255) |
IP address of the primary authentication server. |
As per the MIB. |
hh3cRdSecAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.1.1.13) |
read-create |
InetAddressType |
Type of the IP address for the secondary authentication server. |
You must specify hh3cRdSecAuthIpAddrType and hh3cRdSecAuthIpAddr in pairs in an SNMP request. |
hh3cRdSecAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.1.1.14) |
read-create |
InetAddress |
IP address of the secondary authentication server. |
As per the MIB. |
hh3cRdQuietTime (1.3.6.1.4.1.25506.2.13.1.1.1.16) |
read-create |
Integer32 |
Integer32 (0..255) |
Quiet time for the authentication server to restore to the active status, in minutes. |
Value range: 0 to 255. |
hh3cRdUserNameFormat (1.3.6.1.4.1.25506.2.13.1.1.1.17) |
read-create |
INTEGER |
withoutdomain(1), withdomain(2) , keeporignal(3) |
Format of usernames sent to the RADIUS server. |
As per the MIB. |
hh3cRdRowStatus (1.3.6.1.4.1.25506.2.13.1.1.1.18) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cRdSecKey (1.3.6.1.4.1.25506.2.13.1.1.1.19) |
read-create |
DisplayString |
OCTET STRING (0..64) |
Shared key for communication with the secondary authentication server. |
hh3cRdPrimVpnName (1.3.6.1.4.1.25506.2.13.1.1.1.20) |
read-create |
DisplayString |
OCTET STRING (0..31) |
Name of the VPN to which the primary authentication server belongs. |
As per the MIB. |
hh3cRdSecVpnName (1.3.6.1.4.1.25506.2.13.1.1.1.21) |
read-create |
DisplayString |
Name of the VPN to which the secondary authentication server belongs. |
As per the MIB. |
hh3cRdAuthNasIpAddrType (1.3.6.1.4.1.25506.2.13.1.1.1.22) |
read-create |
InetAddressType |
Type of the NAS IP addresses for RADIUS authentication packets sent to the authentication server. |
Not supported. |
hh3cRdAuthNasIpAddr (1.3.6.1.4.1.25506.2.13.1.1.1.23) |
read-create |
IpAddress |
NAS IPv4 address. |
As per the MIB. |
hh3cRdAuthNasIpv6Addr (1.3.6.1.4.1.25506.2.13.1.1.1.24) |
read-create |
Ipv6Address |
NAS IPv6 address. |
As per the MIB. |
hh3cRdAccInfoTable
About this table
Use this table to configure or obtain RADIUS accounting scheme settings. Each RADIUS scheme contains a primary accounting server, a secondary accounting server, and other settings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
You must specify hh3cRdAccRealTime and hh3cRdAccRealTimeUnit in pairs in an SNMP request.
Columns
The table index is hh3cRdAccGroupName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRdAccGroupName (1.3.6.1.4.1.25506.2.13.1.2.1.1) |
not-accessible |
DisplayString |
Name of a RADIUS accounting scheme. |
As per the MIB. |
hh3cRdPrimAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.2.1.2) |
read-create |
InetAddressType |
Type of the IP address for the primary accounting server. |
You must specify hh3cRdPrimAccIpAddrType and hh3cRdPrimAccIpAddr in pairs in an SNMP request. |
hh3cRdPrimAccIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.3) |
read-create |
InetAddress |
IP address of the primary accounting server. |
As per the MIB. |
hh3cRdPrimAccUdpPort (1.3.6.1.4.1.25506.2.13.1.2.1.4) |
read-create |
Integer32 |
Port number of the primary accounting server. |
hh3cRdPrimAccState (1.3.6.1.4.1.25506.2.13.1.2.1.5) |
read-create |
INTEGER |
Status of the primary accounting server. |
As per the MIB. |
hh3cRdSecAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.2.1.6) |
read-create |
InetAddressType |
Type of the IP address for the secondary accounting server. |
You must specify hh3cRdSecAccIpAddrType and hh3cRdSecAccIpAddr in pairs in an SNMP request. |
hh3cRdSecAccIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.7) |
read-create |
InetAddress |
IP address of the secondary accounting server. |
As per the MIB. |
hh3cRdSecAccUdpPort (1.3.6.1.4.1.25506.2.13.1.2.1.8) |
read-create |
Integer32 |
Port number of the secondary accounting server. |
hh3cRdSecAccState (1.3.6.1.4.1.25506.2.13.1.2.1.9) |
read-create |
INTEGER |
As per the MIB. |
hh3cRdAccKey (1.3.6.1.4.1.25506.2.13.1.2.1.10) |
read-create |
DisplayString |
Shared key for communication with the accounting server. |
hh3cRdAccRetry (1.3.6.1.4.1.25506.2.13.1.2.1.11) |
read-create |
Integer32 |
Maximum number of attempts for transmitting an accounting packet to the accounting server. |
hh3cRdAccTimeout (1.3.6.1.4.1.25506.2.13.1.2.1.12) |
read-create |
Integer32 |
Response timeout time for the accounting server, in seconds. |
hh3cRdAccServerType (1.3.6.1.4.1.25506.2.13.1.2.1.13) |
read-create |
INTEGER |
standard(1), iphotel(2), portal(3), extended(4) |
Service type provided by the accounting server. |
Not supported. |
hh3cRdAccQuietTime (1.3.6.1.4.1.25506.2.13.1.2.1.14) |
read-create |
Integer32 |
Quiet time for the accounting server to restore to the active status, in minutes. |
hh3cRdAccFailureAction (1.3.6.1.4.1.25506.2.13.1.2.1.15) |
read-create |
INTEGER |
ignore (1), reject(2) |
Action to take on accounting failure. |
Not supported |
hh3cRdAccRealTime (1.3.6.1.4.1.25506.2.13.1.2.1.16) |
read-create |
Integer32 |
Integer32 (0..71582) |
Interval for sending real-time accounting packets (in minutes by default). |
As per the MIB. |
hh3cRdAccRealTimeRetry (1.3.6.1.4.1.25506.2.13.1.2.1.17) |
read-create |
Integer32 |
Integer32 (1..255) |
Maximum number of accounting attempts. |
As per the MIB. |
hh3cRdAccDataFlowUnit (1.3.6.1.4.1.25506.2.13.1.2.1.20) |
read-create |
INTEGER |
byte(1), kiloByte(2), megaByte(3), gigaByte(4) |
Data flow measurement unit for traffic statistics. |
As per the MIB. |
hh3cRdAccPacketUnit (1.3.6.1.4.1.25506.2.13.1.2.1.21) |
read-create |
INTEGER |
onePacket(1), kiloPacket (2), megaPacket (3), gigaPacket (4)
Packet measurement unit for traffic statistics. |
As per the MIB. |
hh3cRdAccRowStatus (1.3.6.1.4.1.25506.2.13.1.2.1.22) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cRdAcctOnEnable (1.3.6.1.4.1.25506.2.13.1.2.1.23) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the accounting-on feature. |
As per the MIB. |
hh3cRdAcctOnSendTimes (1.3.6.1.4.1.25506.2.13.1.2.1.24) |
read-create |
Integer32 |
Maximum number of accounting-on packet transmission attempts. |
As per the MIB. |
hh3cRdAcctOnSendInterval (1.3.6.1.4.1.25506.2.13.1.2.1.25) |
read-create |
Integer32 |
Interval for retransmitting an accounting-on packet. |
As per the MIB. |
hh3cRdSecAccKey (1.3.6.1.4.1.25506.2.13.1.2.1.26) |
read-create |
DisplayString |
Shared key for communication with the secondary accounting server. |
hh3cRdPrimAccVpnName (1.3.6.1.4.1.25506.2.13.1.2.1.27) |
read-create |
DisplayString |
Name of the VPN to which the primary accounting server belongs. |
As per the MIB. |
hh3cRdSecAccVpnName (1.3.6.1.4.1.25506.2.13.1.2.1.28) |
read-create |
DisplayString |
Name of the VPN to which the secondary accounting server belongs. |
As per the MIB. |
hh3cRdAccNasIpAddrType (1.3.6.1.4.1.25506.2.13.1.2.1.29) |
read-create |
InetAddressType |
Type of the NAS IP addresses for RADIUS accounting packets sent to the RADIUS accounting server. |
Not supported. |
hh3cRdAccNasIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.30) |
read-create |
IpAddress |
NAS IPv4 address. |
As per the MIB. |
hh3cRdAccNasIpv6Addr (1.3.6.1.4.1.25506.2.13.1.2.1.31) |
read-create |
Ipv6Address |
NAS IPv6 address. |
As per the MIB. |
hh3cRdAccRealTimeUnit (1.3.6.1.4.1.25506.2.13.1.2.1.32) |
read-create |
INTEGER |
minute(0), second(1) |
Interval for sending real-time accounting packets. |
As per the MIB. |
About this table
Use this table to configure or obtain secondary RADIUS authentication server settings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cRdGroupName, hh3cRdSecondaryAuthIpAddrType, hh3cRdSecondaryAuthIpAddr, hh3cRdSecondaryAuthVpnNam, and hh3cRdSecondaryAuthUdpPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRdSecondaryAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.4.1.1) |
not-accessible |
InetAddressType |
Type of the IP address for a secondary authentication server. |
As per the MIB. |
hh3cRdSecondaryAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.4.1.2) |
not-accessible |
InetAddress |
As per the MIB. |
hh3cRdSecondaryAuthVpnName (1.3.6.1.4.1.25506.2.13.1.4.1.3) |
not-accessible |
DisplayString |
As per the MIB. |
hh3cRdSecondaryAuthUdpPort (1.3.6.1.4.1.25506.2.13.1.4.1.4) |
not-accessible |
Integer32 |
Integer32 (1..65535) |
As per the MIB. |
hh3cRdSecondaryAuthState (1.3.6.1.4.1.25506.2.13.1.4.1.5) |
read-create |
INTEGER |
As per the MIB. |
hh3cRdSecondaryAuthKey (1.3.6.1.4.1.25506.2.13.1.4.1.6) |
read-create |
DisplayString |
hh3cRdSecondaryAuthRowStatus (1.3.6.1.4.1.25506.2.13.1.4.1.7) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cRdSecondaryAccServerTable
About this table
Use this table to configure or obtain secondary RADIUS accounting server settings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cRdAccGroupName, hh3cRdSecondaryAccIpAddrType, hh3cRdSecondaryAccIpAddr, hh3cRdSecondaryAccVpnName, and hh3cRdSecondaryAccUdpPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRdSecondaryAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.5.1.1) |
not-accessible |
InetAddressType |
Type of the IP address for a secondary accounting server. |
As per the MIB. |
hh3cRdSecondaryAccIpAddr (1.3.6.1.4.1.25506.2.13.1.5.1.2) |
not-accessible |
InetAddress |
As per the MIB. |
hh3cRdSecondaryAccVpnName (1.3.6.1.4.1.25506.2.13.1.5.1.3) |
not-accessible |
DisplayString |
As per the MIB. |
hh3cRdSecondaryAccUdpPort (1.3.6.1.4.1.25506.2.13.1.5.1.4) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cRdSecondaryAccState (1.3.6.1.4.1.25506.2.13.1.5.1.5) |
read-create |
INTEGER |
Status of the secondary accounting server. |
As per the MIB. |
hh3cRdSecondaryAccKey (1.3.6.1.4.1.25506.2.13.1.5.1.6) |
read-create |
DisplayString |
hh3cRdSecondaryAccRowStatus (1.3.6.1.4.1.25506.2.13.1.5.1.7) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cRadiusAccServerTable
About this table
This table collects packet statistics by RADIUS accounting server, which is not implemented by standard MIBs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is radiusAccServerIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRadiusAccClientStartRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.1) |
read-only |
Counter32 |
Number of start-accounting requests sent to the RADIUS server. |
As per the MIB. |
hh3cRadiusAccClientStartResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.2) |
read-only |
Counter32 |
Number of start-accounting requests received from the RADIUS server. |
As per the MIB. |
hh3cRadiusAccClientInterimRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.3) |
read-only |
Counter32 |
Number of real-time accounting request sent to the RADIUS server. |
As per the MIB. |
hh3cRadiusAccClientInterimResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.4) |
read-only |
Counter32 |
Number of real-time accounting requests received from the RADIUS server. |
As per the MIB. |
hh3cRadiusAccClientStopRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.5) |
read-only |
Counter32 |
Number of stop-accounting request sent to the RADIUS server. |
As per the MIB. |
hh3cRadiusAccClientStopResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.6) |
read-only |
Counter32 |
Number of stop-accounting requests received from the RADIUS server. |
As per the MIB. |
hh3cRadiusAuthServerTable
About this table
This table collects authentication failure statistics by RADIUS authentication server, which is not implemented by standard MIBs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is radiusAuthServerIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRadiusAuthFailureTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.1) |
read-only |
Counter32 |
Number of authentication failures. |
As per the MIB. |
hh3cRadiusAuthTimeoutTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.2) |
read-only |
Counter32 |
Number of authentication timeouts. |
As per the MIB. |
hh3cRadiusAuthRejectTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.3) |
read-only |
Counter32 |
Number of authentication rejections. |
As per the MIB. |
Notifications
hh3cRadiusAuthErrTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.3 |
Authentication failure alarm threshold crossing. |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the authentication failure ratio reaches the authentication failure alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-error-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-error-threshold command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.67.1.2.1.1.3.1.2 (radiusAuthServerAddress) |
IP address of an authentication server. |
Yes |
IP Address |
1.3.6.1.2.1.67.1.2.1.1.3.1.3 (radiusAuthClientServerPortNumber) |
Port number of the authentication server. |
Yes |
INTEGER |
1.. 65535 |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.4 |
Authentication server up |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the status of an authentication server changes from blocked to active.
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-server-up command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-server-up command.
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Yes |
INTEGER |
1.. 65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.5 |
Accounting server up |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the status of an accounting server changes from blocked to active.
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-server-up command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-server-up command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.67.2.2.1.1.3.1.2 (radiusAccServerAddress) |
IP address of an accounting server. |
Yes |
IP Address |
1.3.6.1.2.1.67.2.2.1.1.3.1.3 (radiusAccClientServerPortNumber) |
Port number of the accounting server. |
Yes |
INTEGER |
1.. 65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.6 |
Authentication server down |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the status of an authentication server changes from active to blocked.
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-server-down command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-server-down command.
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Yes |
INTEGER |
1.. 65535 |
Recommended action
hh3cRadiusAccountingServerDownTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.7 |
Accounting server down |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the status of an accounting server changes from active to blocked.
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-server-down command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-server-down command.
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Port number of an accounting server. |
Yes |
INTEGER |
1.. 65535 |
Recommended action
hh3cRadiusAuthServerDownTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.1 |
Informational |
N/A |
N/A |
OFF |
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Yes |
INTEGER |
1.. 65535 |
1.3.6.1.4.1.25506.2.13.7.1 (hh3cRadiusServerFirstTrapTime) |
Time when the notification was generated. |
No |
Timeticks |
Recommended action
