04-HH3C-LswINF-MIB | 121.91 KB |
hh3cifHybridPortTable (not supported)
hh3cifComboPortTable (not supported)
hh3cifPktBufTable (not supported)
hh3cifQueuePktBufTable (not supported)
hh3cifVLANTrunkStatusTable (not supported)
hh3cethernetTable of hh3cLswL2InfMibObject (not supported)
HH3C-LswINF-MIB
About this MIB
Use this MIB to manage interfaces.
An isolation group either can have only one uplink port or does not have any uplink port. You can create an isolation group, specify an uplink port for the group, add member ports to the group, and then remove the uplink port.
Speed autonegotiation allows an interface to operate at the possible fastest speed. You can set the speed modes that an interface can automatically negotiated with the peer interface to meet various speed requirements.
MIB file name
hh3c-splat-inf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35) .hh3cLswL2InfMib(5)
Scalar objects
hh3cSlotPortMax
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSlotPortMax (1.3.6.1.4.1.25506.8.35.5.1.1) |
read-only |
INTEGER |
1..65535 |
Maximum number of ports on a slot. |
As per the MIB. |
hh3cSwitchPortMax
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSwitchPortMax (1.3.6.1.4.1.25506.8.35.5.1.2) |
read-only |
INTEGER |
1..65535 |
Maximum number of ports on the switch. |
As per the MIB. |
hh3cIsolateGroupMax
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIsolateGroupMax (1.3.6.1.4.1.25506.8.35.5.1.5) |
read-only |
Integer32 |
Integer32(1..2147483647) |
Maximum number of isolation groups supported by the switch. |
As per the MIB. |
hh3cGlobalBroadcastMaxPps
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cGlobalBroadcastMaxPps (1.3.6.1.4.1.25506.8.35.5.1.6) |
read-write |
Integer32 |
Integer32(0..14881000) |
Broadcast storm threshold, in pps. |
Not supported |
hh3cGlobalBroadcastMaxRatio
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cGlobalBroadcastMaxRatio (1.3.6.1.4.1.25506.8.35.5.1.7) |
read-write |
Integer32 |
Integer32(0..100) |
Maximum rate of broadcast packets, in percentage. |
Not supported |
hh3cBdpuTunnelStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBpduTunnelStatus (1.3.6.1.4.1.25506.8.35.5.1.8) |
read-write |
INTEGER |
enabled(1) disabled(2) |
Enabling status of BPDU tunnels. |
Not supported |
hh3cVlanVPNTPIDMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVlanVPNTPIDMode (1.3.6.1.4.1.25506.8.35.5.1.9) |
read-only |
INTEGER |
port-based(1) global(2) |
VLAN VPN TPID mode. |
Not supported |
hh3cMaxMacLearnRange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMaxMacLearnRange (1.3.6.1.4.1.25506.8.35.5.1.12) |
read-only |
Integer32 |
Maximum number of MAC addresses supported by an interface. |
As per the MIB. |
Tabular objects
hh3cifXXTable (not supported)
About this table
This table contains extended information for an interface.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifUnBoundPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifUnBoundPort (1.3.6.1.4.1.25506.8.35.1.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Whether an interface is a member port of an aggregate interface. |
Not supported |
hh3cifISPhyPort (1.3.6.1.4.1.25506.8.35.1.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Whether the interface is a physical interface. |
Not supported |
hh3cifAggregatePort (1.3.6.1.4.1.25506.8.35.1.1.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Whether the interface is an aggregate interface. |
Not supported |
hh3cifMirrorPort (1.3.6.1.4.1.25506.8.35.1.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether the interface is a mirroring interface. |
Not supported. When read, this object returns false. |
hh3cifVLANType (1.3.6.1.4.1.25506.8.35.1.1.1.5) |
read-write |
INTEGER |
vLANTrunk(1), access(2), hybrid(3), fabric(4) |
VLAN type of the interface. |
Value fabric(4) is not supported. |
hh3cifMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.6) |
read-write |
INTEGER |
INTEGER (0..100) |
Multicast suppression threshold. |
Not supported. |
hh3cifFlowControl (1.3.6.1.4.1.25506.8.35.1.1.1.7) |
read-write |
TruthValue |
true(1), false(2) |
Flow control status on the interface. |
As per the MIB. |
hh3cifSrcMacControl (1.3.6.1.4.1.25506.8.35.1.1.1.8) |
read-only |
TruthValue |
true(1), false(2) |
Whether to filter packets by source MAC address. |
Not supported |
hh3cifClearStat (1.3.6.1.4.1.25506.8.35.1.1.1.9) |
read-write |
INTEGER |
clear(1) |
Clear packet statistics on the interface. |
Supports only the read operation. |
hh3cifXXBasePortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.10) |
read-only |
INTEGER |
INTEGER |
Index of the interface. |
As per the MIB. |
hh3cifXXDevPortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.11) |
read-only |
INTEGER |
INTEGER |
As per the MIB. |
hh3cifPpsMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.12) |
read-write |
Integer32 |
Integer32 (-2147483648..2147483647) |
Multicast suppression threshold in pps. |
As per the MIB. |
hh3cifPpsBcastDisValControl (1.3.6.1.4.1.25506.8.35.1.1.1.13) |
read-write |
INTEGER |
enable(1), disable(2) |
Enabling status of broadcast suppression in pps mode. |
Not supported |
hh3cifUniSuppressionStep (1.3.6.1.4.1.25506.8.35.1.1.1.14) |
read-only |
Integer32 |
Step of unicast suppression in percentage. |
Not supported |
hh3cifPpsUniSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.15) |
read-only |
Integer32 |
Maximum number of the unicast suppression threshold in pps. |
Not supported |
hh3cifMulSuppressionStep (1.3.6.1.4.1.25506.8.35.1.1.1.16) |
read-only |
Integer32 |
Step of multicast suppression in percentage. |
Not supported |
hh3cifPpsMulSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.17) |
read-only |
Integer32 |
Maximum number of multicast suppression threshold in pps |
Not supported |
hh3cifUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.18) |
read-write |
Integer32 |
Unicast suppression threshold in percentage. |
Not supported |
hh3cifPpsUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.19) |
read-write |
Integer32 |
Unicast suppression threshold in pps. |
As per the MIB. |
hh3cifMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.20) |
read-write |
Integer32 |
Multicast suppression threshold in percentage. |
Not supported |
hh3cifPpsMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.21) |
read-write |
Integer32 |
As per the MIB. |
hh3cifComboActivePort (1.3.6.1.4.1.25506.8.35.1.1.1.22) |
read-write |
INTEGER |
fiber(1), copper(2) na(3) |
Active port of a combo interface. |
Not supported |
hh3cifBMbpsMulSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.23) |
read-only |
Integer32 |
Maximum value of the multicast suppression threshold in Mbps. |
Not supported |
hh3cifBMbpsMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.24) |
read-only |
Integer32 |
Multicast suppression threshold in Mbps. |
Not supported |
hh3cifBKbpsMulSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.25) |
read-only |
Integer32 |
Maximum value of the multicast suppression threshold in kbps. |
Not supported |
hh3cifBKbpsMulSuppressionStep (1.3.6.1.4.1.25506.8.35.1.1.1.26) |
read-only |
Integer32 |
Step of multicast suppression in kbps. |
Not supported |
hh3cifBKbpsMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.27) |
read-only |
Integer32 |
Multicast suppression in kbps. |
Not supported |
hh3cifUnknownPacketDropMul (1.3.6.1.4.1.25506.8.35.1.1.1.28) |
read-write |
INTEGER |
disable(name) |
Enabling status of dropping unknown multicast packets. |
Not supported |
hh3cifUnknownPacketDropUni (1.3.6.1.4.1.25506.8.35.1.1.1.29) |
read-write |
INTEGER |
disable(name) |
Enabling status of dropping unknown unicast packets. |
Not supported |
hh3cifBMbpsUniSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.30) |
read-only |
Integer32 |
Maximum value of the unicast suppression threshold in Mbps. |
Not supported |
hh3cifBMbpsUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.31) |
read-write |
Integer32 |
Unicast suppression threshold in Mbps. |
Not supported |
hh3cifBKbpsUniSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.32) |
read-only |
Integer32 |
Maximum value of the unicast suppression threshold in kbps. |
Not supported |
hh3cifBKbpsUniSuppressionStep (1.3.6.1.4.1.25506.8.35.1.1.1.33) |
read-only |
Integer32 |
Step of unicast suppression in kbps. |
Not supported |
hh3cifBKbpsUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.34) |
read-write |
Integer32 |
Unicast suppression threshold in kbps. |
Not supported |
hh3cifOutPayloadOctets (1.3.6.1.4.1.25506.8.35.1.1.1.35) |
read-only |
CounterBasedGauge64 |
Counter64 (0..18446744073709551615) |
Number of octets transmitted by the interface. |
Not supported |
hh3cifInPayloadOctets (1.3.6.1.4.1.25506.8.35.1.1.1.36) |
read-only |
Number of octets received on the interface. |
Not supported |
hh3cifInErrorPktsRate (1.3.6.1.4.1.25506.8.35.1.1.1.37) |
read-only |
Number of error packets on the interface. |
Not supported |
hh3cifInPkts (1.3.6.1.4.1.25506.8.35.1.1.1.38) |
read-only |
Number of correct packets on the interface. |
Not supported |
hh3cifInNormalPkts (1.3.6.1.4.1.25506.8.35.1.1.1.39) |
read-only |
Number of correct packets received on the interface. |
Not supported |
hh3cifOutPkts (1.3.6.1.4.1.25506.8.35.1.1.1.40) |
read-only |
Number of correct packets transmitted by the interface. |
Not supported |
hh3cifMulSuppressionFlag (1.3.6.1.4.1.25506.8.35.1.1.1.41) |
read-write |
INTEGER |
all(1), unknown(2) |
Flag of multicast suppression. |
As per the MIB. |
About this table
This table contains hybrid interface information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifHybridPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifHybridPortIndex (1.3.6.1.4.1.25506.8.35.1.3.1.1) |
read-only |
INTEGER |
INTEGER |
Index of a hybrid interface. |
As per the MIB. |
hh3cifHybridTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Per-bit representation of tagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN. |
As per the MIB. |
hh3cifHybridTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.3) |
read-write |
OCTET STRING |
Per-bit representation of tagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN. |
As per the MIB. |
hh3cifHybridUnTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.4) |
read-write |
OCTET STRING |
Per-bit representation of untagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN. |
As per the MIB. |
hh3cifHybridUnTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.5) |
read-write |
OCTET STRING |
Per-bit representation of untagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN. |
As per the MIB. |
About this table
This table contains combo interface information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifComboPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifComboPortIndex (1.3.6.1.4.1.25506.8.35.1.4.1.1) |
read-only |
Integer32 |
Index of a combo interface. |
As per the MIB. |
hh3cifComboPortCurActive (1.3.6.1.4.1.25506.8.35.1.4.1.2) |
read-write |
INTEGER |
fiber(1) copper(2) na(3) |
Type of the activated combo port. |
As per the MIB. |
About this table
This table contains packet buffer information for an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifPktBufFree.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifPktBufFree (1.3.6.1.4.1.25506.8.35.1.5.1.1) |
read-only |
Integer32 |
Size of the available packet buffer for an interface. |
As per the MIB. |
hh3cifPktBufInit (1.3.6.1.4.1.25506.8.35.1.5.1.2) |
read-only |
Integer32 |
Number of packet buffers allocated to the interface when the interface was created. |
As per the MIB. |
hh3cifPktBufMin (1.3.6.1.4.1.25506.8.35.1.5.1.3) |
read-only |
Integer32 |
Minimum number of packet buffers allocated to the interface. |
As per the MIB. |
hh3cifPktBufMiss (1.3.6.1.4.1.25506.8.35.1.5.1.4) |
read-only |
Counter64 |
Number of times that the interface failed to obtain a packet buffer before dropping the packet. |
As per the MIB. |
About this table
This table contains packet buffer queue information for an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifQueueId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifQueueId (1.3.6.1.4.1.25506.8.35.1.6.1.1) |
read-only |
Integer32 |
Integer32(1..8) |
ID of a packet buffer queue. |
As per the MIB. |
hh3cifQueuePktBufTotal (1.3.6.1.4.1.25506.8.35.1.6.1.2) |
read-only |
Unsigned32 |
Unsigned32 |
Number of packet buffers for the queue. |
As per the MIB. |
hh3cifQueueBufUsed (1.3.6.1.4.1.25506.8.35.1.6.1.3) |
read-only |
Unsigned32 |
Unsigned32 |
Number of packet buffers used by the queue. |
As per the MIB. |
hh3cifQueueBufThreCount (1.3.6.1.4.1.25506.8.35.1.6.1.4) |
read-only |
Counter32 |
Counter32 |
Number of times that a queue of the interface has exceeded the threshold. |
As per the MIB. |
About this table
This table contains GVRP attributes for a trunk port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifVLANTrunkIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifVLANTrunkIndex (1.3.6.1.4.1.25506.8.35.5.1.3.1.1) |
read-only |
INTEGER |
INTEGER |
Index of a trunk port. |
As per the MIB. |
hh3cifVLANTrunkPassListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.4) |
read-only |
OCTET STRING |
Per-bit representation of permitted VLANs (in the range of VLAN 1 to VLAN 2048) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN. |
As per the MIB. |
hh3cifVLANTrunkPassListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.5) |
read-only |
OCTET STRING |
Per-bit representation of permitted VLANs (in the range of VLAN 2049 to VLAN 4094) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN. |
As per the MIB. |
hh3cifVLANTrunkAllowListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.6) |
read-write |
OCTET STRING |
You must specify this object and hh3cifVLANTrunkAllowListHigh in pairs in an SNMP request. |
hh3cifVLANTrunkAllowListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.7) |
read-write |
OCTET STRING |
You must specify this object and hh3cifVLANTrunkAllowListLow in pairs in an SNMP request. |
About this table
This table contains Layer 2 interface settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifEthernetDuplex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifEthernetDuplex (1.3.6.1.4.1.25506.8.35.5.1.4.1.3) |
read-write |
INTEGER |
full(1), half(2), auto(3) |
Duplex mode of an interface. |
Values half and auto are supported only when the interface operates at a speed higher than 1000 Mbps or is connected to a fiber connector. Layer 3 interfaces do not support write operation. |
hh3cifEthernetMTU (1.3.6.1.4.1.25506.8.35.5.1.4.1.4) |
read-write |
INTEGER |
1..65535 |
MTU of the interface. |
Only interfaces that operate in Layer 2 mode or allow jumbo frames to pass through support write operation. Implementation varies by product. When write, value 1 indicates to set the maximum value in the value range. Value 2 indicates to set the minimum value in the value range. |
hh3cifEthernetSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.5) |
read-write |
INTEGER |
auto(0), s10M(10), s100M(100), s1000M(1000), s2500M(2500), s5000M(5000), s10000M(10000), s24000M(24000), s40000M(40000), s20000M(20000), s25000M(25000), s50000M(50000), s100000M(100000) |
Speed of the interface. |
Ethernet interfaces do not support values s1000 and higher. GE interfaces do not support values s10000 and higher. |
hh3cifEthernetMdi (1.3.6.1.4.1.25506.8.35.5.1.4.1.7) |
read-write |
INTEGER |
mdi-ii(1), mdi-x(2), mdi-auto(3) |
MDI type of the interface. |
GE, XGE, 20GE, 25GE, 40GE, 50GE, and 100GE interfaces that connect to fiber connectors do not support write operation. |
hh3cMaxMacLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.8) |
read-write |
INTEGER |
-1..2147483647 |
Maximum number of MAC addresses that the interface can learn. |
The value of this object must be smaller than the maximum number of MAC addresses supported on the interface. |
hh3cifMacAddressLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.9) |
read-only |
INTEGER |
enabled(1), disabled(2) |
Enabling status of MAC address learning on the interface. |
As per the MIB. |
hh3cifEthernetTest (1.3.6.1.4.1.25506.8.35.5.1.4.1.10) |
read-write |
INTEGER |
test(1) |
Test the interface. |
Not supported |
hh3cifMacAddrLearnMode (1.3.6.1.4.1.25506.8.35.5.1.4.1.11) |
read-only |
INTEGER |
iVL(1), sVL(2) |
MAC address learning mode of the interface. |
Not supported |
hh3cifEthernetFlowInterval (1.3.6.1.4.1.25506.8.35.5.1.4.1.12) |
read-write |
INTEGER |
5..300 |
Flow interval of the interface. |
Not supported |
hh3cifEthernetIsolate (1.3.6.1.4.1.25506.8.35.5.1.4.1.13) |
read-write |
OCTETSTRING |
OCTETSTRING |
Isolation groups. |
Not supported |
hh3cifVlanVPNStatus (1.3.6.1.4.1.25506.8.35.5.1.4.1.14) |
read-write |
INTEGER |
Enabling status of the VLAN-VPN feature. |
Not supported |
hh3cifVlanVPNUplinkStatus(1.3.6.1.4.1.25506.8.35.5.1.4.1.15) |
read-write |
INTEGER |
Uplink status of the VLAN VPN for the interface. |
Not supported |
hh3cifVlanVPNTPID(1.3.6.1.4.1.25506.8.35.5.1.4.1.16) |
read-write |
Integer32 |
Integer32(1..65535) |
VLAN VPN TPID of the interface. |
Not supported |
hh3cifIsolateGroupID (1.3.6.1.4.1.25506.8.35.5.1.4.1.17) |
read-write |
Integer32 |
ID of the isolation group to which the interface belongs. |
Value 0 indicates that the interface does not belong to any isolation group. |
hh3cifisUplinkPort (1.3.6.1.4.1.25506.8.35.5.1.4.1.18) |
read-only |
INTEGER |
yes(1), no(2) |
Uplink status of the interface. |
Not supported |
hh3cifEthernetAutoSpeedMask (1.3.6.1.4.1.25506.8.35.5.1.4.1.19) |
read-only |
SpeedModeFlagBITS |
BITS{ s10M(0), s100M(1), s1000M(2), s10000M(3), s24000M(4), s40000M(5), s100000M(6), s2500M(7), s5000M(8), s20000M(9), s25000M(10), s50000M(11) } |
Speed modes that can be negotiated |
As per the MIB. |
hh3cifEthernetAutoSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.20) |
read-write |
SpeedModeFlagBITS |
Speed modes that are negotiable on this port |
As per the MIB. |
hh3cPortIsolateGroupTable (not supported)
About this table
This table contains isolation group settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cPortIsolateGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortIsolateGroupIndex (1.3.6.1.4.1.25506.8.35.5.1.11.1.1) |
not-accessible |
Integer32 |
Index of an isolation group. |
As per the MIB. |
hh3cPortIsolateUplinkIfIndex (1.3.6.1.4.1.25506.8.35.5.1.11.1.2) |
read-create |
Integer32 |
Integer32 |
Index of the uplink interface. |
Not supported |
hh3cPortIsolateGroupRowStatus (1.3.6.1.4.1.25506.8.35.5.1.11.1.3) |
read-create |
INTEGER |
INTEGER |
Row status. |
Supports only the following values: createAndGo, destroy, and active. Isolation group is available only when the row is in active status. You can set this object only when the device supports multiple isolation groups. |
hh3cPortIsolateGroupDescription (1.3.6.1.4.1.25506.8.35.5.1.11.1.4) |
read-create |
DisplayString |
OCTETSTRING(0..80) |
Description of the isolation group. |
Not supported |
hh3cifPortProtocolStatTable (not supported)
About this table
This table contains IPv4 and IPv6 packet statistics for an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifIPv4InOctets.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifIPv4InOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.1) |
read-only |
Counter64 |
Number of octets in IPv4 packets received on an interface. |
As per the MIB. |
hh3cifIPv4InUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.2) |
read-only |
Counter64 |
Number of IPv4 unicast packets received on the interface. |
As per the MIB. |
hh3cifIPv4InMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.3) |
read-only |
Counter64 |
Number of IPv4 multicast packets received on the interface. |
As per the MIB. |
hh3cifIPv4InBroadcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.4) |
read-only |
Counter64 |
Number of IPv4 broadcast packets received on the interface. |
As per the MIB. |
hh3cifIPv4InDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.5) |
read-only |
Counter64 |
Number of incoming IPv4 packets dropped by the interface. |
As per the MIB. |
hh3cifIPv4InErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.6) |
read-only |
Counter64 |
Number of incoming IPv4 error packets on the interface. |
As per the MIB. |
hh3cifIPv4OutOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.7) |
read-only |
Counter64 |
Number of IPv4 packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.8) |
read-only |
Counter64 |
Number of IPv4 unicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.9) |
read-only |
Counter64 |
Number of IPv4 multicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutBroadcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.10) |
read-only |
Counter64 |
Number of IPv4 broadcast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.11) |
read-only |
Counter64 |
Number of outgoing IPv4 packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.12) |
read-only |
Counter64 |
Number of outgoing IPv4 error packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6InOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.13) |
read-only |
Counter64 |
Number of octets in IPv6 packets received on an interface. |
As per the MIB. |
hh3cifIPv6InUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.14) |
read-only |
Counter64 |
Number of IPv6 unicast packets received on the interface. |
As per the MIB. |
hh3cifIPv6InMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.15) |
read-only |
Counter64 |
Number of IPv6 multicast packets received on the interface. |
As per the MIB. |
hh3cifIPv6InAnycastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.16) |
read-only |
Counter64 |
Number of IPv6 broadcast packets received on the interface. |
As per the MIB. |
hh3cifIPv6InDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.17) |
read-only |
Counter64 |
Number of incoming packets dropped by the interface. |
As per the MIB. |
hh3cifIPv6InErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.18) |
read-only |
Counter64 |
Number of incoming error packets received on the interface. |
As per the MIB. |
hh3cifIPv6OutOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.19) |
read-only |
Counter64 |
Number of octets in IPv6 packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.20) |
read-only |
Counter64 |
Number of IPv6 unicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.21) |
read-only |
Counter64 |
Number of IPv6 multicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutAnycastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.22) |
read-only |
Counter64 |
Number of IPv6 broadcast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.23) |
read-only |
Counter64 |
Number of outgoing packets dropped by the interface. |
As per the MIB. |
hh3cifIPv6OutErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.24) |
read-only |
Counter64 |
Number of outgoing error packets received on the interface. |
As per the MIB. |
