04-Interface
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10004-Interface
02-HH3C-E1T1VI-MIB
02-HH3C-E1T1VI-MIB 47.01 KB
HH3C-E1T1VI-MIB
About this MIB
Use this MIB to obtain E1 or T1 voice interface information.
MIB file name
hh3c-e1t1vi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cE1T1VI(76)
Tabular objects
hh3cE1T1VITable
About this table
This table contains E1 or T1 voice interface information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cE1T1VIUsingTimeslots.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.76.1.1.1)
read-only
Integer32
Standard MIB values.
Number of time slots used on an E1 or T1 interface.
As per the MIB.
hh3cE1T1VIUsingTimeslotsRatio (1.3.6.1.4.1.25506.2.76.1.1.2)
read-only
Integer32
Ratio of used time slots to all time slots on the interface.
As per the MIB.
hh3cE1T1VIGeneral
About this table
Use this table to configure attributes of an E1 or T1 interface globally.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cE1T1VITrapTimeSlotEnable.
Object (OID)
Access
Value range
Implementation
hh3cE1T1VITrapTimeSlotEnable (1.3.6.1.4.1.25506.2.76.3.1)
read-write
INTEGER
enable(1),
disable(2)
Enabling status of notifications for all time slots  on an E1 or T1 interface being used.
As per the MIB.
Notifications
This section contains the HH3C-E1T1VI-MIB notifications.
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.76.2.0.1
All time slots of an E1 or T1 interface were being used.
Informational
N/A
N/A
ON
This notification is generated when all time slots of an E1 or T1 interface are being used.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of an E1 or T1 interface.
Yes
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Description of the interface.
No
DisplayString
OCTET STRING (SIZE (0..255))
Recommended action
No action is required.
