04-Interface
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10004-Interface
01-HH3C-E1-MIB
01-HH3C-E1-MIB 75.39 KB
HH3C-E1-MIB
About this MIB
Use this MIB to obtain E1 interface information.
MIB file name
hh3c-e1.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cE1(28)
Tabular objects
hh3ce1InterfaceStatusTable
About this table
This table contains statistics for an E1 interface.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3ce1InterfaceInErrs.
Object (OID)
Access
Value range
Implementation
hh3ce1InterfaceInErrs (1.3.6.1.4.1.25506.2.28.1.1.1)
read-only
Counter32
Standard MIB values.
Number of errors received on an E1 interface.
As per the MIB.
hh3ce1InterfaceInRuntsErrs (1.3.6.1.4.1.25506.2.28.1.1.2)
read-only
Counter32
Number of runts errors (too short packet) received on this interface.
As per the MIB.
hh3ce1InterfaceInGiantsErrs (1.3.6.1.4.1.25506.2.28.1.1.3)
read-only
Counter32
Number of giants errors (too long packet) received on this interface.
As per the MIB.
hh3ce1InterfaceInCrcErrs (1.3.6.1.4.1.25506.2.28.1.1.4)
read-only
Counter32
Number of CRC errors received on this interface.
As per the MIB.
hh3ce1InterfaceInAlignErrs (1.3.6.1.4.1.25506.2.28.1.1.5)
read-only
Counter32
Number of alignment errors received on this interface.
As per the MIB.
hh3ce1InterfaceInOverRunsErrs (1.3.6.1.4.1.25506.2.28.1.1.6)
read-only
Counter32
Number of overrun errors received on this interface.
As per the MIB.
hh3ce1InterfaceInDribblesErrs (1.3.6.1.4.1.25506.2.28.1.1.7)
read-only
Counter32
Number of dribble packets received on this interface.
As per the MIB.
hh3ce1InterfaceInAbortedSeqErrs (1.3.6.1.4.1.25506.2.28.1.1.8)
read-only
Counter32
Number of AbortedSeq errors received on this interface.
As per the MIB.
hh3ce1InterfaceInNoBufferErrs (1.3.6.1.4.1.25506.2.28.1.1.9)
read-only
Counter32
Number of insufficient buffer errors received on this interface.
As per the MIB.
hh3ce1InterfaceInFramingErrs (1.3.6.1.4.1.25506.2.28.1.1.10)
read-only
Counter32
Number of framing errors on this interface.
As per the MIB.
hh3ce1InterfaceOutputErrs (1.3.6.1.4.1.25506.2.28.1.1.11)
read-only
Counter32
Number of errors transmitted by this interface.
As per the MIB.
hh3ce1InterfaceOutUnderRunErrs (1.3.6.1.4.1.25506.2.28.1.1.12)
read-only
Counter32
Number of underrun errors transmitted by this interface.
As per the MIB.
hh3ce1InterfaceOutCollisonsErrs (1.3.6.1.4.1.25506.2.28.1.1.13)
read-only
Counter32
Number of collision errors transmitted by this interface.
As per the MIB.
hh3ce1InterfaceOutDeferedErrs (1.3.6.1.4.1.25506.2.28.1.1.14)
read-only
Counter32
Number of deferred errors transmitted by this interface.
As per the MIB.
hh3ce1Table
About this table
This table contains E1 interface management information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3ce1Type.
Object (OID)
Access
Value range
Implementation
hh3ce1Type (1.3.6.1.4.1.25506.2.28.2.1.1)
read-only
BITS
voice(0),
pos(1)
Type of an E1 interface.
As per the MIB.
hh3ce1Clock (1.3.6.1.4.1.25506.2.28.2.1.2)
read-write
INTEGER
slave(1),
master(2),
internal(3),
line(4),
linePri(5)
Clock type used on the E1 interface.
As per the MIB.
hh3ce1FrameFormat (1.3.6.1.4.1.25506.2.28.2.1.3)
read-write
INTEGER
crc4(1),
nocrc4(2)
Frame format used on the E1 interface.
As per the MIB.
hh3ce1LineCode (1.3.6.1.4.1.25506.2.28.2.1.4)
read-write
INTEGER
ami(1),
hdb3(3)
Line code type used on the E1 interface.
As per the MIB.
hh3ce1PriSetTimeSlot (1.3.6.1.4.1.25506.2.28.2.1.5)
read-write
Hh3cE1TimeSlot
Bit map of PRI time slots used on the E1 interface.
As per the MIB.
hh3ce1DChannelIndex (1.3.6.1.4.1.25506.2.28.2.1.6)
read-only
Integer32
Interface index of the D channels of the E1 interface.
As per the MIB.
hh3ce1SubScribLineChannelIndex (1.3.6.1.4.1.25506.2.28.2.1.7)
read-only
Integer32
Interface index of the subscriber-line channels of the E1 interface.
As per the MIB.
hh3ce1FcmChannelIndex
(1.3.6.1.4.1.25506.2.28.2.1.8)
read-only
Integer32
As per the MIB.
hh3ce1InterfaceTable
About this table
This table contains information about the D channel and the subscriber-line channel of an E1 interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3ce1ControllerIndex.
Object (OID)
Access
Value range
Implementation
hh3ce1ControllerIndex (1.3.6.1.4.1.25506.2.28.3.1.1)
read-only
Integer32
E1 interface to which a channel belongs.
As per the MIB.
hh3ce1TimeSlotSetTable
About this table
This table contains time slot information of an E1 interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3ce1TimeSlotSetGroupId.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.28.4.1.1)
read-create
Integer32
0..30
ID of the group to which time slots of an E1 interface belong.
As per the MIB.
hh3ce1TimeSlotSetSignalType
(1.3.6.1.4.1.25506.2.28.4.1.2)
read-create
INTEGER
unkown(1),
em-delay(2),
em-immediate(3),
em-wink(4),
fxo-ground(5),
fxo-loop(6),
fxs-ground(7),
fxs-loop(8),
r2(9)
Signal type of the time slots of the E1 interface.
Supports only value r2(9).
hh3ce1TimeSlotSetList
(1.3.6.1.4.1.25506.2.28.4.1.3)
read-create
Hh3cE1TimeSlot
Bit map of time slots of the E1 interface.
As per the MIB.
hh3ce1TimeSlotSetRowStatus
(1.3.6.1.4.1.25506.2.28.4.1.4)
read-create
RowStatus
Row status.
Supports only the following values: active(1), createAndgo(4), and destroy(6).
The CreateAndGo operation is supported only when hh3ce1TimeSlotSetGroupId, hh3ce1TimeSlotSetSignalType, and hh3ce1TimeSlotSetList are all specified in an SNMP request.
