- 01-AAA configuration
- 02-Password control configuration
- 03-Keychain configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Object group configuration
- 10-Attack detection and prevention configuration
- 11-TCP attack prevention configuration
- 12-IP source guard configuration
- 13-ARP attack protection configuration
- 14-ND attack defense configuration
- 15-uRPF configuration
- 16-FIPS configuration
- 17-MACsec configuration
- 18-Crypto engine configuration
| 18-Crypto engine configuration | 38.70 KB |
Restrictions: Software compatibility with crypto engine
Display and maintenance commands for crypto engines
Configuring crypto engines
About crypto engines
Crypto engines encrypt and decrypt data for service modules.
The device only supports one software crypto engine, which is a set of software encryption algorithms. The software crypto engine is always enabled.
When a service module requires data encryption/decryption, it sends the desired data to the crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Crypto engine is supported only in Release 2719 and later.
Task |
Command |
Display crypto engine information. |
display crypto-engine |
Display crypto engine statistics. |
In standalone mode: display crypto-engine statistics [ engine-id engine-id slot slot-number ] In IRF mode: display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ] |
Clear crypto engine statistics. |
In standalone mode: reset crypto-engine statistics [ engine-id engine-id slot slot-number ] In IRF mode: reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ] |
