08-ACL and QoS Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Guides(R27xx)-6W10508-ACL and QoS Configuration Guide
02-QoS configuration
02-QoS configuration 731.98 KB
QoS overview·· 1
QoS service models· 1
Best-effort service model 1
IntServ model 1
DiffServ model 1
QoS techniques in a network· 1
QoS processing flow in a device· 2
QoS configuration approaches· 3
Configuring a QoS policy· 4
About QoS policies· 4
QoS policy tasks at a glance· 4
Defining a traffic class· 4
Defining a traffic behavior 5
Defining a QoS policy· 5
Applying the QoS policy· 6
Application destinations· 6
Restrictions and guidelines for applying a QoS policy· 6
Applying the QoS policy to an Ethernet service instance· 6
Applying the QoS policy to an interface· 7
Applying the QoS policy to VLANs· 8
Applying the QoS policy globally· 8
Applying the QoS policy to a control plane· 8
Display and maintenance commands for QoS policies· 9
Configuring priority mapping· 12
About priority mapping· 12
About priorities· 12
Priority maps· 12
Priority mapping configuration methods· 13
Priority mapping process· 13
Priority mapping tasks at a glance· 15
Configuring a priority map· 16
Configuring a port to trust packet priority for priority mapping· 16
Changing the port priority of an interface· 17
Display and maintenance commands for priority mapping· 17
Priority mapping configuration examples· 17
Example: Configuring a priority trust mode· 17
Example: Configuring priority mapping tables and priority marking· 18
Configuring traffic policing, GTS, and rate limit 22
About traffic policing, GTS, and rate limit 22
Traffic evaluation and token buckets· 22
Traffic policing· 23
GTS· 24
Rate limit 25
Configuring traffic policing· 26
Configuring GTS· 27
Configuring the rate limit 27
Display and maintenance commands for traffic policing, GTS, and rate limit 28
Traffic policing configuration examples· 28
Example: Configuring traffic policing· 28
Configuring congestion management 30
About congestion management 30
Cause, negative results, and countermeasure of congestion· 30
Congestion management methods· 30
Congestion management tasks at a glance· 33
Configuring queuing on an interface· 33
Restrictions and guidelines for queuing configuration· 33
Configuring SP queuing· 33
Configuring WRR queuing· 33
Configuring WFQ queuing· 34
Configuring SP+WRR queuing· 34
Configuring SP+WFQ queuing· 34
Configuring a queue scheduling profile· 35
About queue scheduling profiles· 35
Restrictions and guidelines for queue scheduling profile configuration· 35
Configuring a queue scheduling profile· 36
Applying a queue scheduling profile· 36
Example: Configuring a queue scheduling profile· 36
Display and maintenance commands for congestion management 37
Configuring congestion avoidance· 39
About congestion avoidance· 39
Tail drop· 39
RED and WRED·· 39
Relationship between WRED and queuing mechanisms· 40
ECN· 40
WRED parameters· 41
Configuring and applying a queue-based WRED table· 41
Restrictions and guidelines· 41
Procedure· 42
Example: Configuring and applying a queue-based WRED table· 42
Display and maintenance commands for WRED·· 43
Configuring traffic filtering· 45
About traffic filtering· 45
Restrictions and guidelines: Traffic filtering configuration· 45
Procedure· 45
Traffic filtering configuration examples· 46
Example: Configuring traffic filtering· 46
Configuring protocol packet rate limiting· 48
About protocol packet rate limiting· 48
Procedure· 48
Protocol packet rate limiting configuration examples· 49
Example: Configuring protocol packet rate limiting· 49
Configuring priority marking· 51
About priority marking· 51
Restrictions and guidelines· 51
Priority marking configuration examples· 52
Example: Configuring priority marking· 52
Configuring nesting· 55
About nesting· 55
Restrictions and guidelines: Nesting configuration· 55
Procedure· 55
Nesting configuration examples· 56
Example: Configuring nesting· 56
Configuring traffic redirecting· 58
About traffic redirecting· 58
Restrictions and guidelines: Traffic redirecting configuration· 58
Procedure· 58
Traffic redirecting configuration examples· 59
Example: Configuring traffic redirecting· 59
Configuring global CAR·· 62
About global CAR· 62
Aggregate CAR· 62
Hierarchical CAR· 62
Restrictions and guidelines: Global CAR configuration· 63
Configuring aggregate CAR· 63
Display and maintenance commands for global CAR· 64
Configuring class-based accounting· 65
About class-based accounting· 65
Restrictions and guidelines: Class-based accounting configuration· 65
Procedure· 65
Class-based accounting configuration examples· 66
Example: Configuring class-based accounting· 66
Configuring QPPB·· 68
About QPPB· 68
Application scenarios· 68
QPPB fundamentals· 68
QPPB tasks at a glance· 68
Configuring the route sender 69
Configuring basic BGP functions· 69
Creating a routing policy· 69
Configuring the route receiver 69
Configuring a routing policy· 69
Applying a QoS policy to the route receiving interface· 69
QPPB configuration examples· 70
Example: Configuring QPPB in an IPv4 network· 70
Example: Configuring QPPB in an MPLS L3VPN· 73
Appendixes· 80
Appendix A Acronyms· 80
Appendix B Default priority maps· 81
Appendix C Introduction to packet precedence· 83
IP precedence and DSCP values· 83
802.1p priority· 84
EXP values· 85
QoS overview
In data communications, Quality of Service (QoS) provides differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate, all of which can affect QoS.
QoS manages network resources and prioritizes traffic to balance system resources.
The following section describes typical QoS service models and widely used QoS techniques.
QoS service models
This section describes several typical QoS service models.
The best-effort model is a single-service model. The best-effort model is not as reliable as other models and does not guarantee delay-free delivery.
The best-effort service model is the default model for the Internet and applies to most network applications. It uses the First In First Out (FIFO) queuing mechanism.
IntServ model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. This service model provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the RSVP. All nodes receiving the request reserve resources as requested and maintain state information for the application flow.
The IntServ model demands high storage and processing capabilities because it requires all nodes along the transmission path to maintain resource state information for each flow. This model is suitable for small-sized or edge networks. However, it is not suitable for large-sized networks, for example, the core layer of the Internet, where billions of flows are present.
DiffServ model
The differentiated service (DiffServ) model is a multiple-service model that can meet diverse QoS requirements. It is easy to implement and extend. DiffServ does not signal the network to reserve resources before sending data, as IntServ does.
The QoS techniques include the following features:
·     Traffic classification.
·     Traffic policing.
·     Traffic shaping.
·     Rate limit.
·     Congestion management.
·     Congestion avoidance.
The following section briefly introduces these QoS techniques.
All QoS techniques in this document are based on the DiffServ model.
Figure 1 Position of the QoS techniques in a network
As shown in Figure 1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
·     Traffic classification—Uses match criteria to assign packets with the same characteristics to a traffic class. Based on traffic classes, you can provide differentiated services.
·     Traffic policing—Polices flows and imposes penalties to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
·     Traffic shaping—Adapts the output rate of traffic to the network resources available on the downstream device to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
·     Congestion management—Provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
·     Congestion avoidance—Monitors the network resource usage. It is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance reduces the queue length by dropping packets.
Figure 2 briefly describes how the QoS module processes traffic.
1.     Traffic classifier identifies and classifies traffic for subsequent QoS actions.
2.     The QoS module takes various QoS actions on classified traffic as configured, depending on the traffic processing phase and network status. For example, you can configure the QoS module to perform the following operations:
¡     Traffic policing for incoming traffic.
¡     Traffic shaping for outgoing traffic.
¡     Congestion avoidance before congestion occurs.
¡     Congestion management when congestion occurs.
Figure 2 QoS processing flow
You can configure QoS by using the MQC approach or non-MQC approach.
In the modular QoS configuration (MQC) approach, you configure QoS service parameters by using QoS policies. A QoS policy defines QoS actions to take on different classes of traffic and can be applied to an object (such as an interface) to control traffic.
In the non-MQC approach, you configure QoS service parameters without using a QoS policy. For example, you can use the rate limit feature to set a rate limit on an interface without using a QoS policy.
About QoS policies
A QoS policy has the following components:
·     Traffic class—Defines criteria to match packets.
·     Traffic behavior—Defines QoS actions to take on matching packets.
By associating a traffic class with a traffic behavior, a QoS policy can perform the QoS actions on matching packets.
A QoS policy can have multiple class-behavior associations.
The switch supports three QoS policy types: accounting, marking, and generic.
Unless otherwise noted, a QoS policy in this document refers to a generic QoS policy.
To configure a QoS policy, perform the following tasks:
1.     Defining a traffic class
2.     Defining a traffic behavior
3.     Defining a QoS policy
4.     Applying the QoS policy
¡     Applying the QoS policy to an Ethernet service instance
¡     Applying the QoS policy to an interface
¡     Applying the QoS policy to VLANs
¡     Applying the QoS policy globally
¡     Applying the QoS policy to a control plane
2.     Create a traffic class and enter traffic class view.
3.     (Optional.) Configure a description for the traffic class.
By default, no description is configured for a traffic class.
4.     Configure a match criterion.
if-match match-criteria
By default, no match criterion is configured.
For more information, see the if-match command in ACL and QoS Command Reference.
2.     Create a traffic behavior and enter traffic behavior view.
3.     (Optional.) Enable MAC address learning for the traffic behavior.
mac-address mac-learning enable
By default, MAC address learning is disabled for a traffic behavior.
4.     Configure an action in the traffic behavior.
By default, no action is configured for a traffic behavior.
For more information about configuring an action, see the subsequent chapters for traffic policing, traffic filtering, priority marking, class-based accounting, and so on.
The device supports three QoS policy types: accounting, marking, and generic. Unless otherwise noted, the term "QoS policy" refers to generic QoS policy.
If you do not specify the accounting or remarking keyword when creating a QoS policy, a generic QoS policy is created.
QoS policies of different types cannot have the same policy name.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An accounting-type QoS policy can be applied to only interfaces and can contain only class-based accounting actions. A marking-type QoS policy can be applied to only interfaces and can contain only marking actions.
2.     Create a QoS policy and enter QoS policy view.
qos policy [ accounting | remarking ] policy-name
Parameter
accounting
Represents an accounting-type QoS policy.
remarking
Represents a marking-type QoS policy.
3.     Associate a traffic class with a traffic behavior to create a class-behavior association in the QoS policy.
classifier classifier-name behavior behavior-name [ mode { dcbx | qppb-manipulation } | insert-before before-classifier-name ]
By default, a traffic class is not associated with a traffic behavior.
Repeat this step to create more class-behavior associations.
Parameter
dcbx
Specifies that a class-behavior association applies only to DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
qppb-manipulation
Specifies that a class-behavior association applies only to matching the apply qos-local-id command configuration in a BGP routing policy. For more information, see Layer 3—IP Routing Configuration Guide.
This keyword is available only on HF cards. Before using this keyword, you must set the TCAM operating mode to routing by using the hardware-resource tcam command. For information about this command, see device management commands in Fundamentals Command Reference.
You can apply a QoS policy to the following destinations:
·     Ethernet service instance—The QoS policy takes effect on the traffic received on the Ethernet service instance.
·     Interface—The QoS policy takes effect on the traffic sent or received on the interface.
·     VLAN—The QoS policy takes effect on the traffic sent or received on all ports in the VLAN.
·     Globally—The QoS policy takes effect on the traffic sent or received on all ports.
·     Control plane—The QoS policy takes effect on the traffic received on the control plane.
You can modify traffic classes, traffic behaviors, and class-behavior associations in a QoS policy even after it is applied. If a traffic class uses an ACL for traffic classification, you can delete or modify the ACL.
When a QoS policy containing a CAR action is applied to the inbound direction of multiple interfaces, the actual rate limit that takes effect depends on the interface groups of these interfaces. By default, the actual rate limit that takes effect is the CIR plus the PIR specified in the CAR action multiplied by the number of involved interface groups. Interfaces on different cards belong to different interface groups. To identify interface group information, execute the debug port mapping command for the specified slot in probe view. Interfaces with the same Unit value belong to the same interface group.
When a QoS policy containing a CAR action is applied to the outbound direction of multiple interfaces, the actual rate limit that takes effect depends on the locations of these interfaces. By default, the actual rate limit that takes effect is the CIR plus the PIR specified in the CAR action multiplied by the number of cards where the interfaces reside.
For configuration commands for Ethernet service instances, see MPLS L2VPN or VPLS in MPLS Command Reference or see VXLAN Command Reference.
2.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
¡     Enter Layer 2 Ethernet interface view:
interface
interface-type interface-number
¡     Enter Layer 2 aggregate interface view:
interface bridge-aggregation
interface-number
3.     Create an Ethernet service instance and enter Ethernet service instance view.
service-instance instance-id
4.     Apply the QoS policy to the Ethernet service instance.
By default, no QoS policy is applied to an Ethernet service instance.
A maximum of three QoS policies (one for each type) can be applied to one direction of an interface. Different actions can be taken on the same traffic class if QoS policies of different types are applied to an interface.
The QoS policy applied to the outgoing traffic on an interface does not regulate local packets. Local packets refer to critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, RIP, LDP, and SSH packets.
The term "interface" in this section collectively refers to Layer 2 Ethernet interfaces, Layer 2 aggregate interfaces, Layer 3 Ethernet interfaces, Layer 3 aggregate interfaces, and Layer 3 Ethernet subinterfaces. You can use the port link-mode command to configure an Ethernet port as a Layer 2 or Layer 3 interface (see Layer 2—LAN Switching Configuration Guide).
You can specify the extension keyword to apply the QoS policy in extended mode to a Layer 2 or Layer 3 Ethernet interface. This keyword is available only on FE cards and HF cards. Before using this keyword, you must set the TCAM operating mode to acl by using the hardware-resource tcam command. For information about this command, see device management commands in Fundamentals Command Reference.
You can specify the share-mode keyword to apply the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces on an interface card with the same QoS policy applied in one direction share one QoS and ACL resource. The device has four QoS and ACL resources in each direction.
2.     Enter interface view.
3.     Apply the QoS policy to the interface.
qos apply [ accounting | remarking ] policy policy-name { inbound [ extension ] | outbound } [ share-mode ]
By default, no QoS policy is applied to an interface.
About QoS policy application to VLANs
You can apply a QoS policy to VLANs to regulate the traffic on all ports of the VLANs.
QoS policies cannot be applied to dynamic VLANs, including VLANs created by GVRP.
When you apply a QoS policy to VLANs, the QoS policy is applied to the specified VLANs on all interface cards. If the hardware resources of an interface card are insufficient, applying a QoS policy to VLANs might fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to other interface cards. To ensure consistency, use the undo qos vlan-policy command to manually remove the QoS policy configuration applied to them.
2.     Apply the QoS policy to VLANs.
By default, no QoS policy is applied to a VLAN.
About global QoS policy application
You can apply a QoS policy globally to the inbound or outbound direction of all ports.
If the hardware resources of an interface card are insufficient, applying a QoS policy globally might fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to other interface cards. To ensure consistency, you must use the undo qos apply policy global command to manually remove the QoS policy configuration applied to them.
2.     Apply the QoS policy globally.
By default, no QoS policy is applied globally.
About the user plane and control plane
A device provides the user plane and the control plane.
·     User plane—The units at the user plane are responsible for receiving, transmitting, and switching (forwarding) packets, such as various dedicated forwarding chips. They deliver super processing speeds and throughput.
·     Control plane—The units at the control plane are processing units running most routing and switching protocols. They are responsible for protocol packet resolution and calculation, such as CPUs. Compared with user plane units, the control plane units allow for great packet processing flexibility but have lower throughput.
When the user plane receives packets that it cannot recognize or process, it transmits them to the control plane. If the transmission rate exceeds the processing capability of the control plane, the control plane will be busy handling undesired packets. As a result, the control plane will fail to handle legitimate packets correctly or timely. As a result, protocol performance is affected.
To address this problem, apply a QoS policy to the control plane to take QoS actions, such as traffic filtering (filter) or rate limiting (packet-rate), on inbound traffic. This ensures that the control plane can correctly receive, transmit, and process packets.
A predefined control plane QoS policy uses the protocol type or protocol group type to identify the type of packets sent to the control plane. You can use protocol types or protocol group types in if-match control-plane commands in traffic class view for traffic classification. Then you can reconfigure traffic behaviors for these traffic classes as required. You can use the display qos policy control-plane pre-defined command to display predefined control plane QoS policies.
2.     Enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
3.     Apply the QoS policy to the control plane.
By default, no QoS policy is applied to a control plane.
Display QoS policy configuration.
In standalone mode:
display qos policy user-defined [ accounting | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
In IRF mode:
display qos policy user-defined [ accounting | remarking ] [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
Display information about QoS policies applied to the control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number
Display information about the predefined QoS policy applied to the control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
Display information about QoS policies applied globally.
In standalone mode:
In IRF mode:
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
Display information about QoS policies applied to interfaces.
In standalone mode:
display qos [ accounting | remarking ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos [ accounting | remarking ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
Display information about QoS policies applied to Ethernet service instances.
display qos policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound ]
Display information about QoS policies applied to VLANs.
In standalone mode:
In IRF mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
Display QoS and ACL resource usage.
In standalone mode:
display qos-acl resource [ slot slot-number ]
In IRF mode:
display qos-acl resource [ chassis chassis-number slot slot-number ]
Display traffic behavior configuration.
In standalone mode:
In IRF mode:
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
Display traffic class configuration.
In standalone mode:
In IRF mode:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
Clear the statistics for the QoS policy applied to the control plane.
In standalone mode:
In IRF mode:
reset qos policy control-plane chassis chassis-number slot slot-number
Clear the statistics for a QoS policy applied globally.
Clear the statistics of the QoS policy applied in a certain direction of a VLAN.
When a packet arrives, a device assigns a set of QoS priority parameters to the packet based on either of the following:
·     A priority field carried in the packet.
·     The port priority of the incoming port.
This process is called priority mapping. During this process, the device can modify the priority of the packet according to the priority mapping rules. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority maps and involves the following priorities:
·     802.1p priority.
·     DSCP.
·     EXP.
·     IP precedence.
·     Local precedence.
·     Drop priority.
About priorities
Priorities include the following types: priorities carried in packets, and priorities locally assigned for scheduling only.
Packet-carried priorities include 802.1p priority, DSCP precedence, IP precedence, and EXP. These priorities have global significance and affect the forwarding priority of packets across the network. For more information about these priorities, see "Appendixes."
Locally assigned priorities only have local significance. They are assigned by the device only for scheduling. These priorities include the local precedence, drop priority, and user priority, as follows:
·     Local precedence—Used for queuing. A local precedence value corresponds to an output queue. A packet with higher local precedence is assigned to a higher priority output queue to be preferentially scheduled.
·     Drop priority—Used for making packet drop decisions. Packets with the highest drop priority are dropped preferentially.
·     User priority—Precedence that the device automatically extracts from a priority field of the packet according to its forwarding path. It is a parameter for determining the scheduling priority and forwarding priority of the packet. The user priority represents the following items:
¡     The 802.1p priority for Layer 2 packets.
¡     The IP precedence for Layer 3 packets.
¡     The EXP for MPLS packets.
The device supports only local precedence and drop priority for scheduling.
Priority maps
The device provides various types of priority maps. By looking through a priority map, the device decides which priority value to assign to a packet for subsequent packet processing.
The default priority maps (as shown in Appendix B Default priority maps) are available for priority mapping. They are adequate in most cases. If a default priority map cannot meet your requirements, you can modify the priority map as required.
You can configure priority mapping by using any of the following methods:
·     Configuring priority trust mode—In this method, you can configure a port to look up a trusted priority type (802.1p, for example) in incoming packets in the priority maps. Then, the system maps the trusted priority to the target priority types and values.
·     Changing port priority—If no packet priority is trusted, the port priority of the incoming port is used. By changing the port priority of a port, you change the priority of the incoming packets on the port.
On receiving an Ethernet packet on a port, the switch marks the scheduling priorities (local precedence and drop precedence) for the Ethernet packet. This procedure is done according to the priority trust mode of the receiving port and the 802.1Q tagging status of the packet, as shown in Figure 3.
Figure 3 Priority mapping process for an Ethernet packet
The switch marks a received MPLS packet with a scheduling priority based on the priority trust mode and the packet EXP value, as shown in Figure 4.
Figure 4 Priority mapping process for an MPLS packet
If you configure both an 802.1p priority marking action and a DSCP marking action, the device uses the marked 802.1p priority as the input value for the dot1p-lp and dot1p-dp priority maps to obtain the local precedence and drop priority.
For information about priority marking, see "Configuring priority marking."
To configure priority mapping, perform the following tasks:
1.     (Optional.) Configuring a priority map
2.     Configure a priority mapping method:
¡     Configuring a port to trust packet priority for priority mapping
¡     Changing the port priority of an interface
2.     (Optional.) Modify the 802.1p priority of outgoing packets as the local precedence value.
dot1p-trust-tc
By default, the 802.1p priority of an outgoing packet is not modified.
For an 802.1p priority marking action in a QoS policy to take effect, this command must be configured. For information about configuring an 802.1p priority marking action, see "Configuring priority marking."
3.     Enter priority map view.
qos map-table { dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp }
4.     Configure mappings for the priority map.
By default, the default priority maps are used. For more information, see "Appendix B Default priority maps."
About configuring a port to trust packet priority
You can configure the device to trust a particular priority field carried in packets for priority mapping on ports or globally. When you configure the trusted packet priority type on an interface, use the following available keywords:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
The term "interface" in this section collectively refers to Layer 2 and Layer 3 Ethernet interfaces. You can use the port link-mode command to configure an Ethernet port as a Layer 2 or Layer 3 interface (see Layer 2—LAN Switching Configuration Guide).
3.     Configure the trusted packet priority type.
qos trust { dot1p | dscp }
By default, an interface does not trust any packet priority and uses the port priority as the 802.1p priority for mapping.
About port priority
If an interface does not trust any packet priority, the device uses its port priority to look for priority parameters for the incoming packets. By changing port priority, you can prioritize traffic received on different interfaces.
3.     Set the port priority of the interface.
qos priority [ dscp ] priority-value
The default setting is 0.
The dscp keyword is available in Release 2712 and later versions.
Display priority map configuration.
display qos map-table [ dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp ]
Display the trusted packet priority type on a port.
As shown in Figure 5:
·     The 802.1p priority of traffic from Device A to Device C is 3.
·     The 802.1p priority of traffic from Device B to Device C is 1.
Configure Device C to preferentially process packets from Device A to the server when FortyGigE 1/0/3 of Device C is congested.
Figure 5 Network diagram
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
(Method 1) Configure Device C to trust packet priority
# Configure FortyGigE 1/0/1 and FortyGigE 1/0/2 to trust the 802.1p priority for priority mapping.
<DeviceC> system-view
[DeviceC] interface fortygige 1/0/1
[DeviceC-FortyGigE1/0/1] qos trust dot1p
[DeviceC-FortyGigE1/0/1] quit
[DeviceC] interface fortygige 1/0/2
[DeviceC-FortyGigE1/0/2] qos trust dot1p
[DeviceC-FortyGigE1/0/2] quit
(Method 2) Configure Device C to trust port priority
# Assign port priority to FortyGigE 1/0/1 and FortyGigE 1/0/2. Make sure the following requirements are met:
·     The priority of FortyGigE 1/0/1 is higher than that of FortyGigE 1/0/2.
·     No trusted packet priority type is configured on FortyGigE 1/0/1 or FortyGigE 1/0/2.
[DeviceC-FortyGigE1/0/1] qos priority 3
[DeviceC-FortyGigE1/0/2] qos priority 1
As shown in Figure 6:
·     The Marketing department connects to FortyGigE 1/0/1 of Device, which sets the 802.1p priority of traffic from the Marketing department to 3.
·     The R&D department connects to FortyGigE 1/0/2 of Device, which sets the 802.1p priority of traffic from the R&D department to 4.
·     The Management department connects to FortyGigE 1/0/3 of Device, which sets the 802.1p priority of traffic from the Management department to 5.
Configure port priority, 802.1p-to-local mapping table, and priority marking to implement the plan as described in Table 1.
Table 1 Configuration plan
Traffic destination
Traffic priority order
Queuing plan
Traffic source
Output queue
Queue priority
Public servers
R&D department > Management department > Marketing department
R&D department
6
High
4
Medium
2
Low
Internet
Management department > Marketing department > R&D department
R&D department
2
Low
6
High
4
Medium
Figure 6 Network diagram
IMPORTANT
IMPORTANT:
1.     Configure trusting port priority:
# Set the port priority of FortyGigE 1/0/1 to 3.
[Device] interface fortygige 1/0/1
[Device-FortyGigE1/0/1] qos priority 3
[Device-FortyGigE1/0/1] quit
# Set the port priority of FortyGigE 1/0/2 to 4.
[Device] interface fortygige 1/0/2
[Device-FortyGigE1/0/2] qos priority 4
[Device-FortyGigE1/0/2] quit
# Set the port priority of FortyGigE 1/0/3 to 5.
[Device] interface fortygige 1/0/3
[Device-FortyGigE1/0/3] qos priority 5
[Device-FortyGigE1/0/3] quit
2.     Configure the 802.1p-to-local mapping table to map 802.1p priority values 3, 4, and 5 to local precedence values 2, 6, and 4.
This guarantees the R&D department, Management department, and Marketing department decreased priorities to access the public servers.
[Device-maptbl-dot1p-lp] quit
3.     Configure priority marking to mark the packets from Management department, Marketing department, and R&D department to the Internet with 802.1p priority values 4, 5, and 3.
This guarantees the Management department, Marketing department, and R&D department decreased priorities to access the Internet.
# Create ACL 3000, and configure a rule to match HTTP packets.
[Device] acl advanced 3000
[Device-acl-adv-3000] quit
# Create a traffic class named http, and use ACL 3000 as a match criterion.
[Device-classifier-http] quit
# Create a traffic behavior named admin, and configure a marking action for the Management department.
[Device-behavior-admin] remark dot1p 4
[Device-behavior-admin] quit
# Create a QoS policy named admin, and associate traffic class http with traffic behavior admin in QoS policy admin.
[Device] qos policy admin
[Device-qospolicy-admin] quit
# Apply QoS policy admin to the inbound direction of FortyGigE 1/0/3.
[Device-FortyGigE1/0/3] qos apply policy admin inbound
# Create a traffic behavior named market, and configure a marking action for the Marketing department.
[Device-behavior-market] remark dot1p 5
[Device-behavior-market] quit
# Create a QoS policy named market, and associate traffic class http with traffic behavior market in QoS policy market.
[Device] qos policy market
[Device-qospolicy-market] classifier http behavior market
# Apply QoS policy market to the inbound direction of FortyGigE 1/0/1.
[Device-FortyGigE1/0/1] qos apply policy market inbound
# Create a traffic behavior named rd, and configure a marking action for the R&D department.
[Device] traffic behavior rd
[Device-behavior-rd] remark dot1p 3
[Device-behavior-rd] quit
# Create a QoS policy named rd, and associate traffic class http with traffic behavior rd in QoS policy rd.
[Device] qos policy rd
[Device-qospolicy-rd] classifier http behavior rd
[Device-qospolicy-rd] quit
# Apply QoS policy rd to the inbound direction of FortyGigE 1/0/2.
[Device-FortyGigE1/0/2] qos apply policy rd inbound
Traffic limit helps assign network resources (including bandwidth) and increase network performance. For example, you can configure a flow to use only the resources committed to it in a certain time range. This avoids network congestion caused by burst traffic.
Traffic policing, Generic Traffic Shaping (GTS), and rate limit control the traffic rate and resource usage according to traffic specifications. You can use token buckets for evaluating traffic specifications.
Token bucket features
A token bucket is analogous to a container that holds a certain number of tokens. Each token represents a certain forwarding capacity. The system puts tokens into the bucket at a constant rate. When the token bucket is full, the extra tokens cause the token bucket to overflow.
Evaluating traffic with the token bucket
A token bucket mechanism evaluates traffic by looking at the number of tokens in the bucket. If the number of tokens in the bucket is enough for forwarding the packets:
·     The traffic conforms to the specification (called conforming traffic).
·     The corresponding tokens are taken away from the bucket.
Otherwise, the traffic does not conform to the specification (called excess traffic).
A token bucket has the following configurable parameters:
·     Mean rate at which tokens are put into the bucket, which is the permitted average rate of traffic. It is usually set to the committed information rate (CIR).
·     Burst size or the capacity of the token bucket. It is the maximum traffic size permitted in each burst. It is usually set to the committed burst size (CBS). The set burst size must be greater than the maximum packet size.
Each arriving packet is evaluated.
Complicated evaluation
You can set two token buckets, bucket C and bucket E, to evaluate traffic in a more complicated environment and achieve more policing flexibility. For example, traffic policing uses the following mechanisms:
·     Single rate two color—Uses one token bucket and the following parameters:
¡     CIR—Rate at which tokens are put into bucket C. It sets the average packet transmission or forwarding rate allowed by bucket C.
¡     CBS—Size of bucket C, which specifies the transient burst of traffic that bucket C can forward.
When a packet arrives, the following rules apply:
¡     If bucket C has enough tokens to forward the packet, the packet is colored green.
¡     Otherwise, the packet is colored red.
·     Single rate three color—Uses two token buckets and the following parameters:
¡     EBS—Size of bucket E minus size of bucket C, which specifies the transient burst of traffic that bucket E can forward. The EBS cannot be 0. The size of E bucket is the sum of the CBS and EBS.
¡     If bucket C has enough tokens, the packet is colored green.
¡     If bucket C does not have enough tokens but bucket E has enough tokens, the packet is colored yellow.
¡     If neither bucket C nor bucket E has sufficient tokens, the packet is colored red.
·     Two rate three color—Uses two token buckets and the following parameters:
¡     PIR—Rate at which tokens are put into bucket E, which specifies the average packet transmission or forwarding rate allowed by bucket E.
¡     EBS—Size of bucket E, which specifies the transient burst of traffic that bucket E can forward.
Traffic policing
Traffic policing supports policing only the inbound traffic.
A typical application of traffic policing is to supervise the specification of traffic entering the switch and limit it within a reasonable range. Another application is to "discipline" the extra traffic to prevent aggressive use of bandwidth resources by an application. For example, you can limit bandwidth for HTTP packets to less than 50% of the total on an interface. If the traffic of a session exceeds the limit, traffic policing can drop the packets or reset the IP precedence of the packets. Figure 7 shows an example of policing outbound traffic on an interface.
Figure 7 Traffic policing
Traffic policing is widely used in policing traffic entering the switch. It can classify the policed traffic and take predefined policing actions on each packet depending on the evaluation result:
·     Forwarding the packet if the evaluation result is "conforming."
·     Dropping the packet if the evaluation result is "excess."
GTS
GTS supports shaping the outbound traffic. GTS limits the outbound traffic rate by buffering exceeding traffic. You can use GTS to adapt the traffic output rate on a device to the input traffic rate of its connected device to avoid packet loss.
The differences between traffic policing and GTS are as follows:
·     Packets to be dropped with traffic policing are retained in a buffer or queue with GTS, as shown in Figure 8. When enough tokens are in the token bucket, the buffered packets are sent at an even rate.
·     GTS can result in additional delay and traffic policing does not.
Figure 8 GTS
For example, in Figure 9, Device B performs traffic policing on packets from Device A and drops packets exceeding the limit. To avoid packet loss, you can perform GTS on the outgoing interface of Device A so that packets exceeding the limit are cached in Device A. Once resources are released, GTS takes out the cached packets and sends them out.
Figure 9 GTS application
Rate limit
The switch supports rate limit on a per-card basis and rate limit on a per-interface basis. This section takes the per-interface rate limit as an example.
The rate limit of an interface specifies the maximum rate for sending packets (excluding critical packets).
Rate limit also uses token buckets for traffic control. When rate limit is configured on an interface, a token bucket handles all packets to be sent through the interface for rate limiting. If enough tokens are in the token bucket, packets can be forwarded. Otherwise, packets are put into QoS queues for congestion management. In this way, the traffic passing the interface is controlled.
Figure 10 Rate limit implementation
The token bucket mechanism limits traffic rate when accommodating bursts. It allows bursty traffic to be transmitted if enough tokens are available. If tokens are scarce, packets cannot be transmitted until efficient tokens are generated in the token bucket. It restricts the traffic rate to the rate for generating tokens.
Rate limit controls the total rate of all packets on an interface. It is easier to use than traffic policing in controlling the total traffic rate.
A traffic policing action takes effect only when it is applied to the inbound direction of the following destinations:
·     Interface.
·     VLANs.
·     Globally.
2.     Define a traffic class.
a.     Create a traffic class and enter traffic class view.
b.     Configure a match criterion.
For more information about the if-match command, see ACL and QoS Command Reference.
c.     Return to system view.
3.     Define a traffic behavior.
a.     Create a traffic behavior and enter traffic behavior view.
b.     Configure a traffic policing action.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no traffic policing action is configured.
4.     Define a QoS policy.
a.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
b.     Associate the traffic class with the traffic behavior in the QoS policy.
5.     Apply the QoS policy.
For more information, see "Applying the QoS policy."
By default, no QoS policy is applied.
Configuring GTS
GTS settings take effect only on outbound traffic.
3.     Configure GTS for a queue.
undo qos gts queue queue-id
By default, GTS is not configured on an interface.
The switch supports inbound rate limit on a per-card basis and outbound rate limit on a per-interface basis.
The per-card inbound rate limit level setting takes effect only for H-series cards. The default per-card rate limit level for an HF card varies by TCAM operating mode. For information about setting the TCAM operating mode, see device management commands in Fundamentals Command Reference.
2.     (Optional.) Set the per-card inbound rate limit level.
pps-level inbound level-value
By default:
¡     The per-card rate limit level for an HF card varies by TCAM operating mode:
-     6 for routing mode.
-     1 for ACL mode.
-     0 for mixed mode.
-     1023 for normal mode and IPv6 mode.
¡     The per-card rate limit level for an HB card is 1023.
3.     Enter interface view.
4.     Configure the rate limit for the interface.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
By default, no rate limit is configured on an interface.
Display GTS configuration and statistics for interfaces.
Display rate limit configuration.
In standalone mode:
In IRF mode:
Network requirements
As shown in Figure 11:
·     The server, Host A, and Host B can access the Internet through Device A and Device B.
·     The server, Host A, and FortyGigE 1/0/1 of Device A are in the same network segment.
·     Host B and FortyGigE 1/0/2 of Device A are in the same network segment.
Perform traffic control for the packets that FortyGigE 1/0/1 of Device A receives from the server and Host A using the following guidelines:
·     Limit the rate of packets from the server to 10240 kbps. When the traffic rate is below 10240 kbps, the traffic is forwarded. When the traffic rate exceeds 10240 kbps, the excess packets are marked with DSCP value 0 and then forwarded.
·     Limit the rate of packets from Host A to 2560 kbps. When the traffic rate is below 2560 kbps, the traffic is forwarded. When the traffic rate exceeds 2560 kbps, the excess packets are dropped.
Figure 11 Network diagram
Configuration procedure
IMPORTANT
IMPORTANT:
# Configure ACL 2001 and ACL 2002 to permit the packets from the server and Host A, respectively.
[DeviceA] acl basic 2001
[DeviceA-acl-ipv4-basic-2001] rule permit source 1.1.1.1 0
[DeviceA] acl basic 2002
[DeviceA-acl-ipv4-basic-2002] rule permit source 1.1.1.2 0
[DeviceA-acl-ipv4-basic-2002] quit
# Create a traffic class named server, and use ACL 2001 as the match criterion.
[DeviceA] traffic classifier server
[DeviceA-classifier-server] if-match acl 2001
[DeviceA-classifier-server] quit
# Create a traffic class named host, and use ACL 2002 as the match criterion.
[DeviceA] traffic classifier host
[DeviceA-classifier-host] if-match acl 2002
[DeviceA-classifier-host] quit
# Create a traffic behavior named server, and configure a traffic policing action (CIR 10240 kbps).
[DeviceA] traffic behavior server
[DeviceA-behavior-server] car cir 10240 red remark-dscp-pass 0
[DeviceA-behavior-server] quit
# Create a traffic behavior named host, and configure a traffic policing action (CIR 2560 kbps).
[DeviceA] traffic behavior host
[DeviceA-behavior-host] car cir 2560
[DeviceA-behavior-host] quit
# Create a QoS policy named car, and associate traffic classes server and host with traffic behaviors server and host in QoS policy car, respectively.
[DeviceA] qos policy car
[DeviceA-qospolicy-car] classifier server behavior server
[DeviceA-qospolicy-car] classifier host behavior host
[DeviceA-qospolicy-car] quit
# Apply QoS policy car to the inbound direction of FortyGigE 1/0/1.
[DeviceA] interface fortygige 1/0/1
[DeviceA-FortyGigE1/0/1] qos apply policy car inbound
Congestion occurs on a link or node when traffic size exceeds the processing capability of the link or node. It is typical of a statistical multiplexing network and can be caused by link failures, insufficient resources, and various other causes.
Figure 12 shows two typical congestion scenarios.
Figure 12 Traffic congestion scenarios
Congestion produces the following negative results:
·     Increased delay and jitter during packet transmission.
·     Decreased network throughput and resource use efficiency.
·     Network resource (memory, in particular) exhaustion and even system breakdown.
Congestion is unavoidable in switched networks and multiuser application environments. To improve the service performance of your network, take measures to manage and control it.
The key to congestion management is defining a resource dispatching policy to prioritize packets for forwarding when congestion occurs.
Congestion management uses queuing and scheduling algorithms to classify and sort traffic leaving a port.
The device supports the following queuing mechanisms:
·     SP.
·     WRR.
·     WFQ.
SP queuing
SP queuing is designed for mission-critical applications that require preferential service to reduce the response delay when congestion occurs.
Figure 13 SP queuing
In Figure 13, SP queuing classifies eight queues on a port into eight classes, numbered 7 to 0 in descending priority order.
SP queuing schedules the eight queues in the descending order of priority. SP queuing sends packets in the queue with the highest priority first. When the queue with the highest priority is empty, it sends packets in the queue with the second highest priority, and so on. You can assign mission-critical packets to a high priority queue to make sure they are always served first. Common service packets can be assigned to low priority queues to be transmitted when high priority queues are empty.
The disadvantage of SP queuing is that packets in the lower priority queues cannot be transmitted if packets exist in the higher priority queues. In the worst case, lower priority traffic might never get serviced.
WRR queuing
WRR queuing schedules all the queues in turn to ensure that every queue is served for a certain time, as shown in Figure 14.
Figure 14 WRR queuing
Assume a port provides eight output queues. WRR assigns each queue a weight value (represented by w7, w6, w5, w4, w3, w2, w1, or w0). The weight value of a queue decides the proportion of resources assigned to the queue. On a 100 Mbps port, you can set the weight values to 50, 30, 10, 10, 50, 30, 10, and 10 for w7 through w0. In this way, the queue with the lowest priority can get a minimum of 5 Mbps of bandwidth. WRR solves the problem that SP queuing might fail to serve packets in low-priority queues for a long time.
Another advantage of WRR queuing is that when the queues are scheduled in turn, the service time for each queue is not fixed. If a queue is empty, the next queue will be scheduled immediately. This improves bandwidth resource use efficiency.
WRR queuing includes the following types:
·     Basic WRR queuing—Contains multiple queues. You can set the weight for each queue, and WRR schedules these queues based on the user-defined parameters in a round robin manner.
·     Group-based WRR queuing—All the queues are scheduled by WRR. You can divide output queues to WRR priority queue group 1 and WRR priority queue group 2. Round robin queue scheduling is performed for group 1 first. If group 1 is empty, round robin queue scheduling is performed for group 2. Only WRR priority queue group 1 is supported in the current software version.
On an interface enabled with group-based WRR queuing, you can assign queues to the SP group. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
WFQ queuing
Figure 15 WFQ queuing
WFQ is similar to WRR. WFQ queuing includes basic WFQ queuing and group-based WFQ queuing. Only WFQ group 1 is supported in the current software version.
On an interface with group-based WFQ queuing enabled, you can also assign queues to the SP group. The difference is that WFQ enables you to set guaranteed bandwidth that a WFQ queue can get during congestion.
SP+WFQ queuing schedules traffic in the following order:
1.     Schedules the traffic conforming to the minimum guaranteed bandwidth of each queue in the WFQ group.
2.     Schedules the queues in the SP group based on their priorities.
3.     Schedules the traffic in each queue in the WFQ group according to the configured weights when all queues in the SP group are empty.
To configure congestion management, perform the following tasks:
·     Configuring queuing on an interface
¡     Configuring SP queuing
¡     Configuring WRR queuing
¡     Configuring WFQ queuing
¡     Configuring SP+WRR queuing
¡     Configuring SP+WFQ queuing
·     Configuring a queue scheduling profile
3.     Configure SP queuing.
qos sp
By default, an interface uses SP queuing.
3.     Enable WRR queuing.
qos wrr { byte-count | weight }
4.     Assign a queue to a WRR group, and configure scheduling parameters for the queue.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
By default, all queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
3.     Enable WFQ queuing.
qos wfq { byte-count | weight }
4.     Assign a queue to a WFQ group, and configure scheduling parameters for the queue.
qos wfq queue-id group  1 { byte-count | weight } schedule-value
By default, all queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
To configure the scheduling weight, you must specify the same scheduling unit as specified when enabling WRR queuing.
3.     Enable byte-count or packet-count WRR queuing.
4.     Assign a queue to the SP group.
qos wrr queue-id group sp
By default, all queues on a WRR-enabled interface are in WRR group 1.
5.     Assign a queue to a WRR group, and configure a scheduling weight for the queue.
To configure the scheduling weight, you must specify the same scheduling unit as specified when enabling WFQ queuing.
3.     Enable byte-count or packet-count WFQ queuing.
qos wfq [ byte-count | weight ]
qos wfq queue-id group sp
By default, all queues on a WFQ-enabled interface are in WFQ group 1.
5.     Assign a queue to a WFQ queue scheduling group, and configure a scheduling weight for the queue.
6.     (Optional.) Set the minimum guaranteed bandwidth for a queue.
The default setting is 64 kbps.
In a queue scheduling profile, you can configure scheduling parameters for each queue. By applying the queue scheduling profile to an interface, you can implement congestion management on the interface.
Queue scheduling profiles support three queue scheduling algorithms: SP, WRR, and WFQ. In a queue scheduling profile, you can configure SP+WRR or SP+WFQ. For information about each scheduling algorithm, see "About congestion management." When SP and WRR groups are configured in a queue scheduling profile, Figure 16 shows the scheduling order.
Figure 16 Queue scheduling profile configured with both SP and WRR
·     Queue 7 has the highest priority in the SP group. Its packets are sent preferentially.
·     Queue 5 has the second highest priority in the SP group. Packets in queue 5 are sent when queue 7 is empty.
·     All queues in WRR group 1 are scheduled according to their weights. When queue 7 and queue 5 are empty, WRR group 1 is scheduled.
When you configure a queue scheduling profile, follow these restrictions and guidelines:
·     The term "interface" in this section collectively refers to Layer 2 and Layer 3 Ethernet interfaces. You can use the port link-mode command to configure an Ethernet port as a Layer 2 or Layer 3 interface (see Layer 2—LAN Switching Configuration Guide).
·     Only one queue scheduling profile can be applied to an interface.
·     You can modify the scheduling parameters in a queue scheduling profile already applied to an interface.
2.     Create a queue scheduling profile and enter queue scheduling profile view.
qos qmprofile profile-name
3.     (Optional.) Configure queue scheduling parameters.
¡     Configure a queue to use SP.
queue queue-id sp
¡     Configure a queue to use WRR.
queue queue-id wrr group group-id { weight | byte-count } schedule-value
¡     Configure a queue to use WFQ.
queue queue-id wfq { weight | byte-count } schedule-value
By default, all queues in a queue scheduling profile use SP queuing.
4.     (Optional.) Set the minimum guaranteed bandwidth for a WFQ queue.
3.     Apply the queue scheduling profile to the outbound direction of the interface.
By default, no queue scheduling profile is applied to an interface.
Configure a queue scheduling profile to meet the following requirements on FortyGigE 1/0/1:
·     Queue 7 has the highest priority, and its packets are sent preferentially.
·     Queue 0 through queue 6 are in the WRR group and are scheduled according to their packet-count weights, which are 2, 1, 2, 4, 6, 8, and 10, respectively. When queue 7 is empty, the WRR group is scheduled.
IMPORTANT
IMPORTANT:
# Enter system view.
# Create a queue scheduling profile named qm1.
[Sysname] qos qmprofile qm1
[Sysname-qmprofile-qm1]
# Configure queue 7 to use SP queuing.
[Sysname-qmprofile-qm1] queue 7 sp
# Assign queue 0 through queue 6 to WRR group 1, with their packet-count weights as 2, 1, 2, 4, 6, 8, and 10, respectively.
[Sysname-qmprofile-qm1] queue 0 wrr group 1 weight 2
[Sysname-qmprofile-qm1] queue 1 wrr group 1 weight 1
[Sysname-qmprofile-qm1] queue 2 wrr group 1 weight 2
[Sysname-qmprofile-qm1] queue 3 wrr group 1 weight 4
[Sysname-qmprofile-qm1] queue 4 wrr group 1 weight 6
[Sysname-qmprofile-qm1] queue 5 wrr group 1 weight 8
[Sysname-qmprofile-qm1] queue 6 wrr group 1 weight 10
[Sysname-qmprofile-qm1] quit
# Apply queue scheduling profile qm1 to FortyGigE 1/0/1.
[Sysname] interface fortygige 1/0/1
[Sysname-FortyGigE1/0/1] qos apply qmprofile qm1
After the configuration is completed, FortyGigE 1/0/1 performs queue scheduling as specified in queue scheduling profile qm1.
Display the configuration of queue scheduling profiles.
In standalone mode:
In IRF mode:
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
Display the queue scheduling profiles applied to interfaces.
Display SP queuing configuration.
Display WFQ queuing configuration.
Display WRR queuing configuration.
Avoiding congestion before it occurs is a proactive approach to improving network performance. As a flow control mechanism, congestion avoidance:
·     Actively monitors network resources (such as queues and memory buffers).
·     Drops packets when congestion is expected to occur or deteriorate.
When dropping packets from a source end, congestion avoidance cooperates with the flow control mechanism at the source end to regulate the network traffic size. The combination of the local packet drop policy and the source-end flow control mechanism implements the following functions:
·     Maximizes throughput and network use efficiency.
·     Minimizes packet loss and delay.
Tail drop
Congestion management techniques drop all packets that are arriving at a full queue. This tail drop mechanism results in global TCP synchronization. If packets from multiple TCP connections are dropped, these TCP connections go into the state of congestion avoidance and slow start to reduce traffic. However, traffic peak occurs later. Consequently, the network traffic jitters all the time.
RED and WRED
You can use Random Early Detection (RED) or Weighted Random Early Detection (WRED) to avoid global TCP synchronization.
Both RED and WRED avoid global TCP synchronization by randomly dropping packets. When the sending rates of some TCP sessions slow down after their packets are dropped, other TCP sessions remain at high sending rates. Link bandwidth is efficiently used, because TCP sessions at high sending rates always exist.
The RED or WRED algorithm sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
·     When the queue size is shorter than the lower threshold, no packet is dropped.
·     When the queue size reaches the upper threshold, all subsequent packets are dropped.
·     When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
If the current queue size is compared with the upper threshold and lower threshold to determine the drop policy, burst traffic is not fairly treated. To solve this problem, WRED compares the average queue size with the upper threshold and lower threshold to determine the drop probability.
The average queue size reflects the queue size change trend but is not sensitive to burst queue size changes, and burst traffic can be fairly treated.
When WFQ queuing is used, you can set the following parameters for packets with different precedence values to provide differentiated drop policies:
·     Exponent for average queue size calculation.
·     Upper threshold.
·     Lower threshold.
·     Drop probability.
Figure 17 Relationship between WRED and queuing mechanisms
Through combining WRED with WFQ, the flow-based WRED can be realized. Each flow has its own queue after classification.
·     A flow with a smaller queue size has a lower packet drop probability.
·     A flow with a larger queue size has a higher packet drop probability.
In this way, the benefits of the flow with a smaller queue size are protected.
ECN
By dropping packets, WRED alleviates the influence of congestion on the network. However, the network resources for transmitting packets from the sender to the device which drops the packets are wasted. When congestion occurs, it is a better idea to perform the following actions:
·     Inform the sender of the congestion status.
·     Have the sender proactively slow down the packet sending rate or decrease the window size of packets.
This better utilizes the network resources.
RFC 2482 defined an end-to-end congestion notification mechanism named Explicit Congestion Notification (ECN). ECN uses the DS field in the IP header to mark the congestion status along the packet transmission path. An ECN-capable terminal can determine whether congestion occurs on the transmission path according to the packet contents. Then, it adjusts the packet sending speed to avoid deteriorating congestion. ECN defines the last two bits (ECN field) in the DS field of the IP header as follows:
·     Bit 6 indicates whether the sending terminal device supports ECN, and is called the ECN-Capable Transport (ECT) bit.
·     Bit 7 indicates whether the packet has experienced congestion along the transmission path, and is called the Congestion Experienced (CE) bit.
For more information about the DS field, see "Appendixes."
In actual applications, the following packets are considered as packets that an ECN-capable endpoint transmits:
·     Packets with ECT set to 1 and CE set to 0.
·     Packets with ECT set to 0 and CE set to 1.
After you enable ECN on a device, congestion management processes packets as follows:
·     When the average queue size is below the lower threshold, no packet is dropped, and the ECN fields of packets are not identified or marked.
·     When the average queue size is between the lower threshold and the upper threshold, the device  performs the following operations:
a.     Picks out packets to be dropped according to the drop probability.
b.     Examines the ECN fields of these packets and determines whether to drop these packets.
¡     If the ECN field shows that the packet is sent out of ECN-capable terminal, the device performs the following operations:
-     Sets both the ECT bit and the CE bit to 1.
-     Forwards the packet.
¡     If both the ECT bit and the CE bit are 1 in the packet, the device forwards the packet without modifying the ECN field. The combination of ECT  bit 1 and CE bit 1 indicates that the packet has experienced congestion along the transmission path.
¡     If both the ECT bit and the CE bit are 0 in the packet, the device drops the packet.
·     When the average queue size exceeds the upper threshold, the device drops the packet, regardless of whether the packet is sent from an ECN-capable terminal.
WRED parameters
Determine the following parameters before configuring WRED:
·     Upper threshold and lower threshold—When the average queue size is smaller than the lower threshold, packets are not dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue, the higher the drop probability. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
·     Drop precedence—A parameter used for packet drop. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. Red packets are dropped preferentially.
·     Exponent for average queue size calculation—The greater the exponent, the less sensitive the average queue size is to real-time queue size changes. The formula for calculating the average queue size is:
Average queue size = ( previous average queue size x (1 – 2–n) ) + (current queue size x 2–n), where n is the exponent.
·     Drop probability—Drop probability in percentage. The greater the value, the higher the drop probability. (Applicable when you configure a WRED table on an interface.)
Configuring and applying a queue-based WRED table
By using a WRED table, WRED randomly drops packets during congestion based on the queues that hold packets.
One WRED table can be applied to multiple interfaces. You can modify the parameters of a WRED table applied to an interface, but you cannot delete the WRED table.
2.     Create a WRED table and enter its view.
3.     (Optional.) Set the WRED exponent for average queue size calculation.
queue queue-id weighting-constant exponent
The default setting is 9.
4.     (Optional.) Configure the other WRED parameters.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
By default, the lower limit is 250, the higher limit is 1000, and the drop probability is 10%.
5.     (Optional.) Enable ECN for a queue.
queue queue-id ecn
By default, ECN is disabled for a queue.
6.     Return to system view.
7.     Enter interface view.
8.     Apply the WRED table to the interface.
qos wred apply [ table-name ]
By default, no WRED table is applied to an interface, and tail drop is used on an interface.
Example: Configuring and applying a queue-based WRED table
Apply a WRED table to FortyGigE 1/0/2, so that the packets are dropped as follows when congestion occurs:
·     For the interface to preferentially forward higher-priority traffic, set a lower drop probability for a queue with a greater queue number. Set different drop parameters for queue 0, queue 3, and queue 7.
·     Drop packets according to their colors.
¡     In queue 0, set the drop probability to 25%, 50%, and 75% for green, yellow, and red packets, respectively.
¡     In queue 3, set the drop probability to 5%, 10%, and 25% for green, yellow, and red packets, respectively.
¡     In queue 7, set the drop probability to 1%, 5%, and 10% for green, yellow, and red packets, respectively.
·     Enable ECN for queue 7.
IMPORTANT
IMPORTANT:
# Configure a queue-based WRED table, and set different drop parameters for packets with different drop levels in different queues.
[Sysname-wred-table-queue-table1] queue 0 drop-level 0 low-limit 128 high-limit 512 discard-probability 25
[Sysname-wred-table-queue-table1] queue 0 drop-level 1 low-limit 128 high-limit 512 discard-probability 50
[Sysname-wred-table-queue-table1] queue 0 drop-level 2 low-limit 128 high-limit 512 discard-probability 75
[Sysname-wred-table-queue-table1] queue 3 drop-level 0 low-limit 256 high-limit 640 discard-probability 5
[Sysname-wred-table-queue-table1] queue 3 drop-level 1 low-limit 256 high-limit 640 discard-probability 10
[Sysname-wred-table-queue-table1] queue 3 drop-level 2 low-limit 256 high-limit 640 discard-probability 25
[Sysname-wred-table-queue-table1] queue 7 drop-level 0 low-limit 512 high-limit 1024 discard-probability 1
[Sysname-wred-table-queue-table1] queue 7 drop-level 1 low-limit 512 high-limit 1024 discard-probability 5
[Sysname-wred-table-queue-table1] queue 7 drop-level 2 low-limit 512 high-limit 1024 discard-probability 10
[Sysname-wred-table-queue-table1] queue 7 ecn
[Sysname-wred-table-queue-table1] quit
# Apply the queue-based WRED table to FortyGigE 1/0/2.
[Sysname] interface fortygige 1/0/2
[Sysname-FortyGigE1/0/2] qos wred apply queue-table1
[Sysname-FortyGigE1/0/2] quit
Display and maintenance commands for WRED
Display WRED configuration and statistics for an interface.
Display the configuration of a WRED table or all WRED tables.
In standalone mode:
In IRF mode:
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
Configuring traffic filtering
About traffic filtering
You can filter in or filter out traffic of a class by associating the class with a traffic filtering action. For example, you can filter packets sourced from an IP address according to network status.
Restrictions and guidelines: Traffic filtering configuration
A traffic filtering action takes effect only when it is applied to the following destinations:
·     Interface.
·     VLANs.
·     Globally.
·     Control plane.
For more information about configuring match criteria, see ACL and QoS Command Reference.
b.     Configure the traffic filtering action.
filter { deny | permit }
By default, no traffic filtering action is configured.
If a traffic behavior has the filter deny action, all other actions in the traffic behavior except class-based accounting do not take effect.
6.     (Optional.) Display the traffic filtering configuration.
This command is available in any view.
Traffic filtering configuration examples
Example: Configuring traffic filtering
As shown in Figure 18, configure traffic filtering on FortyGigE 1/0/1 to deny the incoming packets with a source port number other than 21.
Figure 18 Network diagram
IMPORTANT
IMPORTANT:
# Create advanced ACL 3000, and configure a rule to match packets whose source port number is not 21.
[Device-acl-ipv4-adv-3000] rule 0 permit tcp source-port neq 21
# Create a traffic class named classifier_1, and use ACL 3000 as the match criterion in the traffic class.
# Create a traffic behavior named behavior_1, and configure the traffic filtering action to drop packets.
# Create a QoS policy named policy, and associate traffic class classifier_1 with traffic behavior behavior_1 in the QoS policy.
[Device] qos policy policy
[Device-qospolicy-policy] classifier classifier_1 behavior behavior_1
[Device-qospolicy-policy] quit
# Apply QoS policy policy to the incoming traffic of FortyGigE 1/0/1.
[Device-FortyGigE1/0/1] qos apply policy policy inbound
Configuring protocol packet rate limiting
About protocol packet rate limiting
The protocol packet processing rate of a CPU is limited. When a large number of protocol packets are sent to the CPU, the CPU might be occupied by the protocol packets and cannot process other tasks. The protocol packet rate limiting feature limits the rate of protocol packets sent to the CPU, and it guarantees the normal operation of the CPU.
if-match match-criteria
By default, no match criteria are configured.
For more information, see the if-match command in ACL and QoS Command Reference.
b.     Configure protocol packet rate limiting.
packet-rate value
By default, protocol packet rate limiting is not configured.
b.     Associate the class with the traffic behavior in the QoS policy.
By default, a class is not associated with any behavior.
5.     Apply the QoS policy to a control plane.
For more information, see "Applying the QoS policy to a control plane."
6.     (Optional.) Display the protocol packet rate limiting configuration.
Protocol packet rate limiting configuration examples
Example: Configuring protocol packet rate limiting
As shown in Figure 19, limit the rate of DHCP protocol packets sent to the CPU of the device to 500 pps.
Figure 19 Network diagram
IMPORTANT
IMPORTANT:
# Create a traffic class named classifier_1 and configure the class to match DHCP protocol packets.
[Device-classifier-classifier_1] if-match control-plane protocol dhcp
# Create a traffic behavior named behavior_1 and configure the behavior to limit the packet rate to 500 pps.
[Device-behavior-behavior_1] packet-rate 500
# Create a QoS policy named and associate class classifier_1 with behavior behavior_1 in the policy.
# Apply QoS policy policy to the control plane.
[Device] control-plane slot 1
[Device-cp] qos apply policy policy inbound
About priority marking
Priority marking sets the priority fields or flag bits of packets to modify the priority of packets. For example, you can use priority marking to set IP precedence or DSCP for a class of IP packets to control the forwarding of these packets.
To configure priority marking to set the priority fields or flag bits for a class of packets, perform the following tasks:
1.     Configure a traffic behavior with a priority marking action.
2.     Associate the traffic class with the traffic behavior.
Priority marking can be used together with priority mapping. For more information, see "Configuring priority mapping."
Marking different priority types has different impacts on QoS scheduling. For more information, see Figure 3.
This feature allows you to configure a marking action in a traffic behavior and is different from a marking-type QoS policy, which allows you to specify the remarking keyword when applying the QoS policy. For more information about marking-type QoS policies, see "Defining a QoS policy".
A priority marking action takes effect only when it is applied to the following destinations:
·     Interface.
·     VLANs.
·     Globally.
By default, no match criterion is configured.
b.     Configure a priority marking action.
For configurable priority marking actions, see the  remark commands in ACL and QoS Command Reference.
classifier classifier-name behavior behavior-name
By default, a traffic class is not associated with a traffic behavior.
6.     (Optional.) Display the priority marking configuration.
Priority marking configuration examples
Example: Configuring priority marking
As shown in Figure 20, configure priority marking on the device to meet the following requirements:
Traffic source
Destination
Processing priority
Host A, B
Data server
High
Host A, B
Mail server
Medium
Host A, B
File server
Low
Figure 20 Network diagram
IMPORTANT
IMPORTANT:
# Create advanced ACL 3000, and configure a rule to match packets with destination IP address 192.168.0.1.
[Device-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.1 0
# Create advanced ACL 3001, and configure a rule to match packets with destination IP address 192.168.0.2.
[Device] acl advanced 3001
[Device-acl-ipv4-adv-3001] rule permit ip destination 192.168.0.2 0
# Create advanced ACL 3002, and configure a rule to match packets with destination IP address 192.168.0.3.
[Device] acl advanced 3002
[Device-acl-ipv4-adv-3002] rule permit ip destination 192.168.0.3 0
[Device-acl-ipv4-adv-3002] quit
# Create a traffic class named classifier_dbserver, and use ACL 3000 as the match criterion in the traffic class.
[Device] traffic classifier classifier_dbserver
[Device-classifier-classifier_dbserver] if-match acl 3000
[Device-classifier-classifier_dbserver] quit
# Create a traffic class named classifier_mserver, and use ACL 3001 as the match criterion in the traffic class.
[Device] traffic classifier classifier_mserver
[Device-classifier-classifier_mserver] if-match acl 3001
[Device-classifier-classifier_mserver] quit
# Create a traffic class named classifier_fserver, and use ACL 3002 as the match criterion in the traffic class.
[Device] traffic classifier classifier_fserver
[Device-classifier-classifier_fserver] if-match acl 3002
[Device-classifier-classifier_fserver] quit
# Create a traffic behavior named behavior_dbserver, and configure the action of setting the local precedence value to 4.
[Device] traffic behavior behavior_dbserver
[Device-behavior-behavior_dbserver] remark local-precedence 4
[Device-behavior-behavior_dbserver] quit
# Create a traffic behavior named behavior_mserver, and configure the action of setting the local precedence value to 3.
[Device] traffic behavior behavior_mserver
[Device-behavior-behavior_mserver] remark local-precedence 3
[Device-behavior-behavior_mserver] quit
# Create a traffic behavior named behavior_fserver, and configure the action of setting the local precedence value to 2.
[Device] traffic behavior behavior_fserver
[Device-behavior-behavior_fserver] remark local-precedence 2
[Device-behavior-behavior_fserver] quit
# Create a QoS policy named policy_server, and associate traffic classes with traffic behaviors in the QoS policy.
[Device] qos policy policy_server
[Device-qospolicy-policy_server] classifier classifier_dbserver behavior behavior_dbserver
[Device-qospolicy-policy_server] classifier classifier_mserver behavior behavior_mserver
[Device-qospolicy-policy_server] classifier classifier_fserver behavior behavior_fserver
[Device-qospolicy-policy_server] quit
# Apply QoS policy policy_server to the incoming traffic of FortyGigE 1/0/1.
[Device-FortyGigE1/0/1] qos apply policy policy_server inbound
Configuring nesting
About nesting
Nesting adds a VLAN tag to the matching packets to allow the VLAN-tagged packets to pass through the corresponding VLAN. For example, you can add an outer VLAN tag to packets from a customer network to a service provider network. This allows the packets to pass through the service provider network by carrying a VLAN tag assigned by the service provider.
Restrictions and guidelines: Nesting configuration
A nesting action takes effect only when it is applied to the inbound direction of the following destinations:
·     Interface.
·     VLANs.
·     Globally.
For a QoS policy that contains a nesting action to take effect on an H-series card, make sure both the downlink port and uplink port permit the single-tagged packets matching the QoS policy. The double-tagged packets are forwarded in the device based on the inner VLAN tag.
By default, no match criterion is configured for a traffic class.
For more information about the match criteria, see the if-match command in ACL and QoS Command Reference.
b.     Configure an outer VLAN tag adding action.
nest top-most vlan vlan-id
By default, no outer VLAN tag adding action is configured for a traffic behavior.
6.     (Optional.) Display the nesting configuration.
Nesting configuration examples
Example: Configuring nesting
As shown in Figure 21:
·     Site 1 and Site 2 in VPN A are two branches of a company. They use VLAN 5 to transmit traffic.
·     Because Site 1 and Site 2 are located in different areas, the two sites use the VPN access service of a service provider. The service provider assigns VLAN 100 to the two sites.
Configure nesting, so that the two branches can communicate through the service provider network.
Figure 21 Network diagram
IMPORTANT
IMPORTANT:
1.     Configuring PE 1:
# Create a traffic class named test to match traffic with VLAN ID 5.
<PE1> system-view
[PE1] traffic classifier test
[PE1-classifier-test] if-match service-vlan-id 5
[PE1-classifier-test] quit
# Configure an action to add outer VLAN tag 100 in traffic behavior test.
[PE1] traffic behavior test
[PE1-behavior-test] nest top-most vlan 100
[PE1-behavior-test] quit
# Create a QoS policy named test, and associate class test with behavior test in the QoS policy.
[PE1] qos policy test
[PE1-qospolicy-test] classifier test behavior test
[PE1-qospolicy-test] quit
# Configure the downlink port (FortyGigE 1/0/1) as a hybrid port, assign the port to VLAN 5 as a tagged member, and assign the port to VLAN 100 as an untagged member.
[PE1] interface fortygige 1/0/1
[PE1-FortyGigE1/0/1] port link-type hybrid
[PE1-FortyGigE1/0/1] port hybrid vlan 5 tagged
[PE1-FortyGigE1/0/1] port hybrid vlan 100 untagged
# Apply QoS policy test to the incoming traffic of FortyGigE 1/0/1.
[PE1-FortyGigE1/0/1] qos apply policy test inbound
[PE1-FortyGigE1/0/1] quit
# Configure the uplink port (FortyGigE 1/0/2) as a trunk port, and assign it to VLAN 5 and VLAN 100.
[PE1] interface fortygige 1/0/2
[PE1-FortyGigE1/0/2] port link-type trunk
[PE1-FortyGigE1/0/2] port trunk permit vlan 5 100
[PE1-FortyGigE1/0/2] quit
2.     Configuring PE 2:
Configure PE 2 in the same way PE 1 is configured.
Configuring traffic redirecting
About traffic redirecting
Traffic redirecting redirects packets matching the specified match criteria to a location for processing.
You can redirect packets to the following destinations:
·     CPU.
·     Interface.
Restrictions and guidelines: Traffic redirecting configuration
·     A traffic redirecting action takes effect only when it is applied to the inbound direction of the following destinations:
¡     Interface.
¡     VLANs.
¡     Globally.
·     Only Layer 2 packets can be redirected to interfaces.
·     If you execute the redirect command multiple times, the most recent configuration takes effect.
·     For traffic redirecting to an Ethernet interface, the switch does not display the redirecting action after the interface module or interface expansion card that hosts the interface is removed. After the interface module or interface expansion card is reinserted, the switch can display the redirecting action.
b.     Configure a traffic redirecting action.
In standalone mode:
redirect { cpu | interface interface-type interface-number }
By default, no traffic redirecting action is configured for a traffic behavior.
6.     (Optional.) Display traffic redirecting configuration.
Traffic redirecting configuration examples
Example: Configuring traffic redirecting
As shown in Figure 22:
·     Device A is connected to Device B through two links. Device A and Device B are each connected to other devices.
·     FortyGigE 1/0/2 of Device A and FortyGigE 1/0/2 of Device B belong to VLAN 200.
·     FortyGigE 1/0/3 of Device A and FortyGigE 1/0/3 of Device B belong to VLAN 201.
·     On Device A, the IP address of VLAN-interface 200 is 200.1.1.1/24, and that of VLAN-interface 201 is 201.1.1.1/24.
·     On Device B, the IP address of VLAN-interface 200 is 200.1.1.2/24, and that of VLAN-interface 201 is 201.1.1.2/24.
Configure the actions of redirecting traffic to an interface to meet the following requirements:
·     Packets with source IP address 2.1.1.1 received on FortyGigE 1/0/1 of Device A are forwarded to FortyGigE 1/0/2.
·     Packets with source IP address 2.1.1.2 received on FortyGigE 1/0/1 of Device A are forwarded to FortyGigE 1/0/3.
·     Other packets received on FortyGigE 1/0/1 of Device A are forwarded according to the routing table.
Figure 22 Network diagram
IMPORTANT
IMPORTANT:
# Create basic ACL 2000, and configure a rule to match packets with source IP address 2.1.1.1.
[DeviceA] acl basic 2000
[DeviceA-acl-ipv4-basic-2000] rule permit source 2.1.1.1 0
# Create basic ACL 2001, and configure a rule to match packets with source IP address 2.1.1.2.
[DeviceA-acl-ipv4-basic-2001] rule permit source 2.1.1.2 0
# Create a traffic class named classifier_1, and use ACL 2000 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier_1
[DeviceA-classifier-classifier_1] if-match acl 2000
[DeviceA-classifier-classifier_1] quit
# Create a traffic class named classifier_2, and use ACL 2001 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier_2
[DeviceA-classifier-classifier_2] if-match acl 2001
[DeviceA-classifier-classifier_2] quit
# Create a traffic behavior named behavior_1, and configure the action of redirecting traffic to FortyGigE 1/0/2.
[DeviceA] traffic behavior behavior_1
[DeviceA-behavior-behavior_1] redirect interface fortygige 1/0/2
[DeviceA-behavior-behavior_1] quit
# Create a traffic behavior named behavior_2, and configure the action of redirecting traffic to FortyGigE 1/0/3.
[DeviceA] traffic behavior behavior_2
[DeviceA-behavior-behavior_2] redirect interface fortygige 1/0/3
[DeviceA-behavior-behavior_2] quit
# Create a QoS policy named policy.
[DeviceA] qos policy policy
# Associate traffic class classifier_1 with traffic behavior behavior_1 in the QoS policy.
[DeviceA-qospolicy-policy] classifier classifier_1 behavior behavior_1
# Associate traffic class classifier_2 with traffic behavior behavior_2 in the QoS policy.
[DeviceA-qospolicy-policy] classifier classifier_2 behavior behavior_2
[DeviceA-qospolicy-policy] quit
[DeviceA-FortyGigE1/0/1] qos apply policy policy inbound
Configuring global CAR
About global CAR
Global committed access rate (CAR) is an approach to policing traffic flows globally. It adds flexibility to common CAR where traffic policing is performed only on a per-traffic class or per-interface basis. In this approach, CAR actions are created in system view and each can be used to police multiple traffic flows as a whole.
Global CAR provides the following CAR actions: aggregate CAR and hierarchical CAR.
Aggregate CAR
An aggregate CAR action is created globally. It can be directly applied to interfaces or used in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
Hierarchical CAR
A hierarchical CAR action is created globally. It must be used in conjunction with a common CAR or aggregate CAR action. With a hierarchical CAR action, you can limit the total traffic of multiple traffic classes.
A hierarchical CAR action can be used in the common or aggregate CAR action for a traffic class in either AND mode or OR mode.
·     In AND mode, the rate of the traffic class is strictly limited under the common or aggregate CAR. This mode applies to flows that must be strictly rate limited.
·     In OR mode, the traffic class can use idle bandwidth of other traffic classes associated with the hierarchical CAR. This mode applies to high priority, bursty traffic like video.
By using the two modes appropriately, you can improve bandwidth efficiency.
For example, suppose two flows exist: a low priority data flow and a high priority, bursty video flow. Their total traffic rate cannot exceed 4096 kbps and the video flow must be assured of at least 2048 kbps bandwidth. You can perform the following tasks:
·     Configure common CAR actions to set the traffic rate to 2048 kbps for the two flows.
·     Configure a hierarchical CAR action to limit their total traffic rate to 4096 kbps.
·     Use the action in AND mode in the common CAR action for the data flow.
·     Use the action in OR mode in the common CAR action for the video flow.
The video flow is assured of 2048 kbps bandwidth and can use idle bandwidth of the data flow.
In a bandwidth oversubscription scenario, the uplink port bandwidth is lower than the total downlink port traffic rate. You can use hierarchical CAR to meet the following requirements:
·     Limit the total rate of downlink port traffic.
·     Allow each downlink port to forward traffic at the maximum rate when the other ports are idle.
For example, you can perform the following tasks:
·     Use common CAR actions to limit the rates of Internet access flow 1 and flow 2 to both 128 kbps.
·     Use a hierarchical CAR action to limit their total traffic rate to 192 kbps.
·     Use the hierarchical CAR action for both flow 1 and flow 2 in AND mode.
When flow 1 is not present, flow 2 is transmitted at the maximum rate, 128 kbps. When both flows are present, the total rate of the two flows cannot exceed 192 kbps. As a result, the traffic rate of flow 2 might drop below 128 kbps.
Restrictions and guidelines: Global CAR configuration
Only aggregate CAR is supported in the current software version.
An aggregate CAR action takes effect only when it is applied to the inbound direction of the following destinations:
·     Interface.
·     VLANs.
·     Globally.
When a QoS policy containing an aggregation CAR is applied to the inbound direction of multiple interfaces, the actual rate limit that takes effect depends on the interface groups of these interfaces. By default, the actual rate limit that takes effect is the CIR plus the PIR specified in the aggregation CAR action multiplied by the number of involved interface groups. Interfaces on different cards belong to different interface groups. To identify interface group information, execute the debug port mapping command for the specified slot in probe view. Interfaces with the same Unit value belong to the same interface group.
Configuring aggregate CAR
For configurable match criteria, see the if-match command in ACL and QoS Command Reference.
3.     Configure an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no aggregate CAR action is configured.
4.     Define a traffic behavior.
a.     Enter traffic behavior view.
b.     Use the aggregate CAR in the traffic behavior.
car name car-name
By default, no aggregate CAR action is used in a traffic behavior.
Display and maintenance commands for global CAR
Display statistics for global CAR actions.
Clear statistics for global CAR actions.
Configuring class-based accounting
About class-based accounting
Class-based accounting collects statistics on a per-traffic class basis. For example, you can define the action to collect statistics for traffic sourced from a certain IP address. By analyzing the statistics, you can determine whether anomalies have occurred and what action to take.
Restrictions and guidelines: Class-based accounting configuration
Class-based accounting takes effect only when it is applied to the following destinations:
·     Interface.
·     VLANs.
·     Globally.
b.     Configure an accounting action.
accounting [ byte | packet ] *
By default, no traffic accounting action is configured.
The byte and packet keywords can be both configured in Release 2712 and later versions.
6.     (Optional.) Display the class-based accounting configuration.
See the following commands in ACL and QoS Command Reference:
¡     display qos policy control-plane.
¡     display qos policy global.
¡     display qos policy interface.
¡     display qos vlan-policy.
Class-based accounting configuration examples
Example: Configuring class-based accounting
As shown in Figure 23, configure class-based accounting on FortyGigE 1/0/1 to collect statistics for incoming traffic from 1.1.1.1/24.
Figure 23 Network diagram
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
# Create basic ACL 2000, and configure a rule to match packets with source IP address 1.1.1.1.
[Device] acl basic 2000
[Device-acl-ipv4-basic-2000] rule permit source 1.1.1.1 0
[Device-classifier-classifier_1] if-match acl 2000
# Create a traffic behavior named behavior_1, and configure the class-based accounting action.
[Device-behavior-behavior_1] accounting packet
# Display traffic statistics to verify the configuration.
[Device] display qos policy interface fortygige 1/0/1
Interface: FortyGigE1/0/1
  Direction: Inbound
  Policy: policy
   Classifier: classifier_1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: behavior_1
      Accounting enable:
        28529 (Packets)
Configuring QPPB
About QPPB
The QoS Policy Propagation Through the Border Gateway Protocol (QPPB) feature enables you to classify IP packets based on the following attributes:
·     BGP community lists.
·     Prefix lists.
·     BGP AS paths.
Application scenarios
QPPB minimizes the QoS policy configuration and management efforts on the BGP route receiver when the network topology changes. It is suitable for a large-scaled complex network.
The QPPB feature is implemented as follows:
·     The BGP route sender preclassifies routes before advertising them.
·     The BGP route receiver performs the following operations:
¡     Sets the IP precedence and local QoS ID for the routes.
¡     Takes appropriate QoS actions on the packets that match the routes.
QPPB is used in the following scenarios:
·     Traffic classification based on source or destination IP addresses.
·     Traffic classification based on IBGP and EBGP within an autonomous system or across multiple autonomous systems.
QPPB fundamentals
QPPB works on the BGP receiver by applying a QoS policy to BGP routes with the same local QoS ID. It depends on the BGP route sender to preclassify routes.
The BGP route sender uses a routing policy to set route attributes for BGP routes before advertising them.
The BGP sender performs the following operations:
·     Uses a routing policy to match routes based on these route attributes.
·     Sets the local QoS ID for the matching routes.
The BGP receiver performs the following operations:
1.     Compares the routes with the incoming route policy based on their BGP AS path, prefix, or community attributes.
2.     Applies the local QoS ID to the matching routes.
3.     Adds the BGP routes and their associated local QoS ID to the routing table.
4.     Applies the local QoS ID to the packets sourced from or destined to the IP address in the route.
5.     Takes QoS actions on the packets according to the QoS priority settings.
QPPB tasks at a glance
To configure QPPB, perform the following tasks:
1.     Configuring the route sender
a.     Configuring basic BGP functions
b.     (Optional.) Creating a routing policy
2.     Configuring the route receiver
b.     Configuring a routing policy
c.     Applying a QoS policy to the route receiving interface
Configure the BGP route sender to set route attributes for routes before advertising them.
For more information, see Layer 3—IP Routing Configuration Guide.
Configure a routing policy to classify routes and set route attributes for the route classes. For more information, see Layer 3—IP Routing Configuration Guide.
Configure a routing policy to perform the following operations:
·     Match the route attributes set by the route sender.
·     Set the local QoS ID for the matching routes.
This feature is available only on HF cards. Before configuring this feature, you must set the TCAM operating mode to routing by using the hardware-resource tcam command. For information about this command, see device management commands in Fundamentals Command Reference.
For QPPB to work correctly, you must configure the QoS policy as follows:
·     Use the local QoS ID set in the routing policy to match packets.
·     Specify the mode qppb-manipulation keyword when associating a traffic behavior with a traffic class.
For more information about QoS policies, see "Configuring a QoS policy."
if-match qos-local-id local-id-value
The local QoS ID must be same as that set in "Configuring a routing policy".
b.     Configure an action.
By default, no action is configured.
For configuration commands, see traffic behavior commands in ACL and QoS Command Reference.
classifier classifier-name behavior behavior-name mode qppb-manipulation
5.     Enter interface view.
6.     Apply a QoS policy to the interface.
By default, no QoS policy is applied to an interface.
QPPB configuration examples
Example: Configuring QPPB in an IPv4 network
As shown in Figure 24, all devices run BGP.
Configure QPPB so that Device B can perform the following operations:
·     Receive routes.
·     Set the local QoS ID according to the routing policy.
·     Use the QoS policy to limit the traffic rate to 512000 kbps.
Figure 24 Network diagram
IMPORTANT
IMPORTANT:
1.     Configure IP addresses for each interface. (Details not shown.)
2.     Configure a BGP connection to Device B, and add the network 1.1.1.0/8 to the BGP routing table on Device A.
[DeviceA] bgp 1000
[DeviceA-bgp] peer 168.1.1.2 as-number 2000
[DeviceA-bgp] peer 168.1.1.2 connect-interface fortygige 1/0/2
[DeviceA-bgp] address-family ipv4
[DeviceA-bgp-ipv4] import-route direct
[DeviceA-bgp-ipv4] peer 168.1.1.2 enable
[DeviceA-bgp-ipv4] quit
[DeviceA-bgp] quit
3.     Configure Device B:
# Configure a BGP connection to Device A.
[DeviceB] bgp 2000
[DeviceB-bgp] peer 168.1.1.1 as-number 1000
[DeviceB-bgp] peer 168.1.1.1 connect-interface fortygige 1/0/2
[DeviceB-bgp] address-family ipv4
[DeviceB-bgp-ipv4] peer 168.1.1.1 enable
[DeviceB-bgp-ipv4] peer 168.1.1.1 route-policy qppb import
[DeviceB-bgp-ipv4] quit
[DeviceB-bgp] quit
# Configure the routing policy qppb.
[DeviceB] route-policy qppb permit node 0
[DeviceB-route-policy-qppb-0] apply qos-local-id 3
[DeviceB-route-policy-qppb-0] quit
# Configure a QoS policy.
[DeviceB] traffic classifier qppb
[DeviceB-classifier-qppb] if-match qos-local-id 3
[DeviceB-classifier-qppb] quit
[DeviceB] traffic behavior qppb
[DeviceB-behavior-qppb] car cir 512000 green pass red discard
[DeviceB-behavior-qppb] quit
[DeviceB] qos policy qppb
[DeviceB-qospolicy-qppb] classifier qppb behavior qppb mode qppb-manipulation
[DeviceB-qospolicy-qppb] quit
# Apply the QoS policy to incoming traffic on FortyGigE 1/0/2.
[DeviceB] interface fortygige 1/0/2
[DeviceB-FortyGigE1/0/2] qos apply policy qppb inbound
[DeviceB-FortyGigE1/0/2] quit
# Verify that the related route on Device B takes effect.
[DeviceB] display ip routing-table 1.1.1.0 24 verbose
Summary Count : 1
Destination: 1.1.1.0/24
   Protocol: BGP             Process ID: 0
  SubProtID: 0x2                    Age: 00h00m33s
       Cost: 0               Preference: 255
      IpPre: 1               QosLocalID: 3
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 1000
      NibID: 0x15000000          LastAs: 1000
     AttrID: 0x0               Neighbor: 168.1.1.1
      Flags: 0x10060        OrigNextHop: 168.1.1.1
      Label: NULL           RealNextHop: 168.1.1.1
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: FortyGigE1/0/2
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A              VpnPeerId: N/A
       Dscp: N/A
# Display the QoS policy configuration on FortyGigE1/0/2 of Device B.
[DeviceB] display qos policy interface fortygige 1/0/2
  Direction: Inbound
  Policy: qppb
   Classifier: qppb
         Mode: qppb-manipulation
     Operator: AND
     Rule(s) :
      If-match qos-local-id 3
     Behavior: qppb
      Committed Access Rate:
        CIR 512000 (kbps), CBS 32000000 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
Example: Configuring QPPB in an MPLS L3VPN
As shown in Figure 25, all devices run BGP.
Configure QPPB so that Device C can perform the following operations:
·     Receive routes.
·     Set the QPPB local QoS IDs.
·     Use the QoS policy to limit the traffic rate to 200000 kbps in the inbound direction.
Figure 25 Network diagram
Table 2 Interfaces and IP address assignment
Device
IP address
Device
IP address
Device A
FGE1/0/1
192.168.1.2/24
Device B
FGE1/0/1
167.1.1.2/24
FGE1/0/2
167.1.1.1/24
FGE1/0/2
168.1.1.2/24
Device C
FGE1/0/1
169.1.1.2/24
Device D
FGE1/0/2
169.1.1.1/24
FGE1/0/2
168.1.1.1/24
FGE1/0/1
192.168.3.2/24
IMPORTANT
IMPORTANT:
2.     Configure a BGP connection on Device A.
[DeviceA] bgp 100
[DeviceA-bgp] peer 167.1.1.2 as-number 200
[DeviceA-bgp] peer 167.1.1.2 connect-interface fortygige 1/0/2
[DeviceA-bgp-ipv4] peer 167.1.1.2 enable
[DeviceA-bgp] quit
# Configure a VPN instance.
[DeviceB] ip vpn-instance vpn1
[DeviceB-vpn-instance-vpn1] route-distinguisher 200:1
[DeviceB-vpn-instance-vpn1] vpn-target 200:1 export-extcommunity
[DeviceB-vpn-instance-vpn1] vpn-target 200:1 import-extcommunity
[DeviceB-vpn-instance-vpn1] quit
# Configure a BGP connection.
[DeviceB] router id 1.1.1.1
[DeviceB] bgp 200
[DeviceB-bgp] peer 2.2.2.2 as-number 200
[DeviceB-bgp] peer 2.2.2.2 connect-interface loopback 0
[DeviceB-bgp] ip vpn-instance vpn1
[DeviceB-bgp-vpn1] peer 167.1.1.1 as-number 100
[DeviceB-bgp-vpn1] address-family ipv4
[DeviceB-bgp-ipv4-vpn1] peer 167.1.1.1 enable
[DeviceB-bgp-ipv4-vpn1] quit
[DeviceB-bgp] address-family vpnv4
[DeviceB-bgp-vpnv4] peer 2.2.2.2 enable
[DeviceB-bgp-vpnv4] quit
[DeviceB-bgp] quit
# Configure MPLS.
[DeviceB] mpls lsr-id 1.1.1.1
[DeviceB] mpls ldp
[DeviceB-mpls-ldp] quit
# Configure OSPF.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[DeviceB-ospf-1-area-0.0.0.0] network 168.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
# Bind FortyGigE 1/0/1 to VPN instance vpn1.
[DeviceB] interface fortygige 1/0/1
[DeviceB-FortyGigE1/0/1] ip binding vpn-instance vpn1
[DeviceB-FortyGigE1/0/1] ip address 167.1.1.2 24
[DeviceB-FortyGigE1/0/1] quit
# Enable MPLS on FortyGigE 1/0/2.
[DeviceB-FortyGigE1/0/2] mpls enable
[DeviceB-FortyGigE1/0/2] mpls ldp enable
4.     Configure Device C:
<DeviceC> system-view
[DeviceC] ip vpn-instance vpn1
[DeviceC-vpn-instance-vpn1] route-distinguisher 200:1
[DeviceC-vpn-instance-vpn1] vpn-target 200:1 export-extcommunity
[DeviceC-vpn-instance-vpn1] vpn-target 200:1 import-extcommunity
[DeviceC-vpn-instance-vpn1] quit
[DeviceC] router id 2.2.2.2
[DeviceC] bgp 200
[DeviceC-bgp] peer 1.1.1.1 as-number 200
[DeviceC-bgp] peer 1.1.1.1 connect-interface loopback 0
[DeviceC-bgp] ip vpn-instance vpn1
[DeviceC-bgp-vpn1] peer 169.1.1.1 as-number 300
[DeviceC-bgp-vpn1] address-family ipv4
[DeviceC-bgp-ipv4-vpn1] peer 169.1.1.1 enable
[DeviceC-bgp-ipv4-vpn1] peer 169.1.1.1 route-policy qppb import
[DeviceC-bgp-ipv4-vpn1] quit
[DeviceC-bgp-vpn1] quit
[DeviceC-bgp] address-family vpnv4
[DeviceC-bgp-vpnv4] peer 1.1.1.1 enable
[DeviceC-bgp-vpnv4] peer 1.1.1.1 route-policy qppb import
[DeviceC-bgp-vpnv4] quit
[DeviceC-bgp] quit
# Configure a routing policy.
[DeviceC] route-policy qppb permit node 0
[DeviceC-route-policy-qppb-0] apply qos-local-id 3
[DeviceC-route-policy-qppb-0] quit
# Configure MPLS.
[DeviceC] mpls lsr-id 2.2.2.2
[DeviceC] mpls ldp
[DeviceC-mpls-ldp] quit
# Configure OSPF.
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[DeviceC-ospf-1-area-0.0.0.0] network 168.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] traffic classifier qppb
[DeviceC-classifier-qppb] if-match qos-local-id 3
[DeviceC-classifier-qppb] quit
[DeviceC] traffic behavior qppb
[DeviceC-behavior-qppb] car cir 200000 green pass red discard
[DeviceC-behavior-qppb] quit
[DeviceC] qos policy qppb
[DeviceC-qospolicy-qppb] classifier qppb behavior qppb mode qppb-manipulation
[DeviceC-qospolicy-qppb] quit
[DeviceC] interface fortygige 1/0/2
[DeviceC-FortyGigE1/0/2] mpls enable
[DeviceC-FortyGigE1/0/2] mpls ldp enable
[DeviceC-FortyGigE1/0/2] quit
[DeviceC] interface fortygige 1/0/1
[DeviceC-FortyGigE1/0/1] ip binding vpn-instance vpn1
[DeviceC-FortyGigE1/0/1] ip address 169.1.1.2 24
# Apply QoS policy qppb to the incoming traffic of FortyGigE 1/0/1.
[DeviceC-FortyGigE1/0/1] qos apply policy qppb inbound
[DeviceC-FortyGigE1/0/1] quit
# Apply QoS policy qppb to the incoming traffic of FortyGigE 1/0/2.
[DeviceC-FortyGigE1/0/2] qos apply policy qppb inbound
5.     Configure a BGP connection on Device D.
<DeviceD> system-view
[DeviceD] bgp 300
[DeviceD-bgp] peer 169.1.1.2 as-number 200
[DeviceD-bgp] peer 169.1.1.2 connect-interface fortygige 1/0/2
[DeviceD-bgp] address-family ipv4
[DeviceD-bgp-ipv4] peer 169.1.1.2 enable
[DeviceD-bgp-ipv4] import-route direct
[DeviceD-bgp-ipv4] quit
# Verify that the related routes on Device A take effect.
[DeviceA] display ip routing-table
Destinations : 18        Routes : 18
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
167.1.1.0/24        Direct 0    0            167.1.1.1       FGE1/0/2
167.1.1.0/32        Direct 0    0            167.1.1.1       FGE1/0/2
167.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
167.1.1.255/32      Direct 0    0            167.1.1.1       FGE1/0/2
169.1.1.0/24        BGP    255  0            167.1.1.2       FGE1/0/2
192.168.1.0/24      Direct 0    0            192.168.1.2     FGE1/0/1
192.168.1.0/32      Direct 0    0            192.168.1.2     FGE1/0/1
192.168.1.2/32      Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.2     FGE1/0/1
192.168.3.0/24      BGP    255  0            167.1.1.2       FGE1/0/2
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Verify that the related routes on Device B take effect.
Destinations : 14        Routes : 14
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.2/32          OSPF   10   1            168.1.1.1       FGE1/0/2
168.1.1.0/24        Direct 0    0            168.1.1.2       FGE1/0/2
168.1.1.0/32        Direct 0    0            168.1.1.2       FGE1/0/2
168.1.1.2/32        Direct 0    0            127.0.0.1       InLoop0
168.1.1.255/32      Direct 0    0            168.1.1.2       FGE1/0/2
[DeviceB] display ip routing-table vpn-instance vpn1
Destinations : 16        Routes : 16
167.1.1.0/24        Direct 0    0            167.1.1.2       FGE1/0/1
167.1.1.0/32        Direct 0    0            167.1.1.2       FGE1/0/1
167.1.1.2/32        Direct 0    0            127.0.0.1       InLoop0
167.1.1.255/32      Direct 0    0            167.1.1.2       FGE1/0/1
169.1.1.0/24        BGP    255  0            2.2.2.2         FGE1/0/2
192.168.1.0/24      BGP    255  0            167.1.1.1       FGE1/0/1
192.168.2.0/24      BGP    255  0            167.1.1.1       FGE1/0/1
192.168.3.0/24      BGP    255  0            2.2.2.2         FGE1/0/2
# Verify that the related routes on Device C take effect.
[DeviceC] display ip routing-table
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.1.1/32          OSPF   10   1            168.1.1.2       FGE1/0/2
2.2.2.2/32          Direct 0    0            127.0.0.1       InLoop0
168.1.1.0/24        Direct 0    0            168.1.1.1       FGE1/0/2
168.1.1.0/32        Direct 0    0            168.1.1.1       FGE1/0/2
168.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
168.1.1.255/32      Direct 0    0            168.1.1.1       FGE1/0/2
[DeviceC] display ip routing-table vpn-instance vpn1
167.1.1.0/24        BGP    255  0            1.1.1.1         FGE1/0/2
169.1.1.0/24        Direct 0    0            169.1.1.2       FGE1/0/1
169.1.1.0/32        Direct 0    0            169.1.1.2       FGE1/0/1
169.1.1.2/32        Direct 0    0            127.0.0.1       InLoop0
169.1.1.255/32      Direct 0    0            169.1.1.2       FGE1/0/1
192.168.1.0/24      BGP    255  0            1.1.1.1         FGE1/0/2
192.168.2.0/24      BGP    255  0            169.1.1.1       FGE1/0/1
192.168.3.0/24      BGP    255  0            169.1.1.1       FGE1/0/1
# Verify that the related routes on Device D take effect.
[DeviceD] display ip routing-table
167.1.1.0/24        BGP    255  0            169.1.1.2       FGE1/0/2
169.1.1.0/24        Direct 0    0            169.1.1.1       FGE1/0/2
169.1.1.0/32        Direct 0    0            169.1.1.1       FGE1/0/2
169.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
169.1.1.255/32      Direct 0    0            169.1.1.1       FGE1/0/2
192.168.1.0/24      BGP    255  0            169.1.1.2       FGE1/0/2
192.168.3.0/24      Direct 0    0            192.168.3.2     FGE1/0/1
192.168.3.0/32      Direct 0    0            192.168.3.2     FGE1/0/1
192.168.3.2/32      Direct 0    0            127.0.0.1       InLoop0
192.168.3.255/32    Direct 0    0            192.168.3.2     FGE1/0/1
# Display the QoS policy configuration and statistics for the inbound direction of interfaces on Device C.
[DeviceC] display qos policy interface inbound
  Direction: Inbound
  Policy: qppb
   Classifier: qppb
     Operator: AND
     Rule(s) :
     Behavior: qppb
        CIR 200000 (kbps), CBS 1250000 (Bytes), EBS 0 (Bytes)
        Green action  : pass
  Direction: Inbound
  Policy: qppb
   Classifier: qppb
     Operator: AND
     Rule(s) :
     Behavior: qppb
        Green action  : pass
Appendixes
Appendix A Acronyms
Table 3 Appendix A Acronyms
Acronym
Full spelling
AF
Assured Forwarding
BE
Best Effort
BQ
Bandwidth Queuing
CAR
CBS
Committed Burst Size
CBQ
Class Based Queuing
CE
CIR
Committed Information Rate
CQ
Custom Queuing
DCBX
Data Center Bridging Exchange Protocol
DiffServ
Differentiated Service
DSCP
Differentiated Services Code Point
EBS
Excess Burst Size
ECN
EF
Expedited Forwarding
FIFO
First in First out
FQ
Fair Queuing
GMB
Guaranteed Minimum Bandwidth
GTS
Generic Traffic Shaping
IntServ
Integrated Service
ISP
Internet Service Provider
LLQ
Low Latency Queuing
LSP
Label Switched Path
MPLS
Multiprotocol Label Switching
PE
Provider Edge
PIR
Peak Information Rate
PQ
Priority Queuing
PW
Pseudowire
QoS
Quality of Service
QPPB
RED
RSVP
Resource Reservation Protocol
RTP
Real-Time Transport Protocol
SP
Strict Priority
ToS
Type of Service
VoIP
Voice over IP
VPN
Virtual Private Network
WFQ
Weighted Fair Queuing
WRED
WRR
Weighted Round Robin
Appendix B Default priority maps
For the default dscp-dscp and exp-dot1p priority maps, an input value yields a target value equal to it.
Table 4 Default dot1p-lp, dot1p-dp and dot1p-dscp priority maps
Input priority value
dot1p-lp map
dot1p-dp map
dot1p-dscp map
dot1p
lp
dp
dscp
0
2
0
0
1
0
0
8
2
1
0
16
3
3
0
24
4
4
0
32
5
5
0
40
6
6
0
48
7
7
0
56
Table 5 Default dscp-dp, dscp-dot1p, and dscp-exp priority maps
dscp-dp map
dscp-dot1p map
dscp-exp map
dscp
dp
dot1p
exp
0 to 7
0
0
0
8 to 15
0
1
1
16 to 23
0
2
2
24 to 31
0
3
3
32 to 39
0
4
4
40 to 47
0
5
5
48 to 55
0
6
6
56 to 63
0
7
7
Table 6 Default exp-dscp priority map
exp-dscp map
EXP value
dscp
0
0
1
8
2
16
3
24
4
32
5
40
6
48
7
56
Table 7 Default port priority-local priority map
Port priority
Local precedence
0
0
1
1
2
2
3
3
4
4
5
5
6
6
7
7
Appendix C Introduction to packet precedence
IP precedence and DSCP values
Figure 26 ToS and DS fields
As shown in Figure 26, the ToS field in the IP header contains 8 bits. The first 3 bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field is redefined as the differentiated services (DS) field. A DSCP value is represented by the first 6 bits (0 to 5) of the DS field and is in the range 0 to 63. The remaining 2 bits (6 and 7) are reserved.
Table 8 IP precedence
IP precedence (decimal)
IP precedence (binary)
0
000
Routine
1
001
priority
2
010
immediate
3
011
flash
4
100
flash-override
5
101
critical
6
110
internet
7
111
network
Table 9 DSCP values
DSCP value (decimal)
DSCP value (binary)
46
101110
ef
10
001010
af11
12
001100
af12
14
001110
af13
18
010010
af21
20
010100
af22
22
010110
af23
26
011010
af31
28
011100
af32
30
011110
af33
34
100010
af41
36
100100
af42
38
100110
af43
8
001000
cs1
16
010000
cs2
24
011000
cs3
32
100000
cs4
40
101000
cs5
48
110000
cs6
56
111000
cs7
0
000000
be (default)
802.1p priority
802.1p priority lies in the Layer 2 header. It applies to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 27 An Ethernet frame with an 802.1Q tag header
As shown in Figure 27, the 4-byte 802.1Q tag header contains the 2-byte tag protocol identifier (TPID) and the 2-byte tag control information (TCI). The value of the TPID is 0x8100. Figure 28 shows the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called 802.1p priority, because its use is defined in IEEE 802.1p. Table 10 shows the values for 802.1p priority.
Figure 28 802.1Q tag header
Table 10 Description on 802.1p priority
802.1p priority (decimal)
802.1p priority (binary)
0
000
best-effort
1
001
background
2
010
spare
3
011
excellent-effort
4
100
controlled-load
5
101
video
6
110
voice
7
111
network-management
EXP values
The EXP field is in MPLS labels for MPLS QoS purposes. As shown in Figure 29, the EXP field is 3-bit long and is in the range of 0 to 7.
Figure 29 MPLS label structure
