06-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S12500X-AF & S12500-X & S9800 Switch Series Command References(R27xx)-6W10506-IP Multicast Command Reference
13-IPv6 PIM snooping commands
13-IPv6 PIM snooping commands 80.95 KB
IPv6 PIM snooping is supported only in Release 2719 and later.
display ipv6 pim-snooping neighbor
Use display ipv6 pim-snooping neighbor to display IPv6 PIM snooping neighbor information.
In standalone mode:
display ipv6 pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
In IRF mode:
display ipv6 pim-snooping neighbor [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6 PIM snooping neighbor information for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 PIM snooping neighbor information for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 PIM snooping neighbor information for the global active MPU. (In IRF mode.)
verbose: Displays detailed information about IPv6 PIM snooping neighbors. If you do not specify this keyword, the command displays brief information about IPv6 PIM snooping neighbors.
# Display detailed information about IPv6 PIM snooping neighbors for VLAN 2.
<Sysname> display ipv6 pim-snooping neighbor vlan 2 verbose
Total 2 neighbors.
VLAN 2: Total 2 neighbors.
  FE80::6401:101
    Slots (0 in total):
    Ports (1 in total):
      FGE1/0/1                              (02:02:23)    LAN Prune Delay(T)
  FE80::C801:101
    Slots (0 in total):
    Ports (1 in total):
      FGE1/0/2                              (02:02:25)
Total 2 neighbors
Total number of IPv6 PIM snooping neighbors.
Total number of IPv6 PIM snooping neighbors in VLAN 2.
FE80::6401:101
IPv6 address of the IPv6 PIM snooping neighbor.
Slots (0 in total)
(In standalone mode.) Slot numbers and total number of the cards that have the neighbor, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have the neighbor, except for the specified card or the global active MPU when no card is specified.
Ports (1 in total)
Ports where IPv6 PIM snooping neighbors reside, and the total number of the ports.
(02:02:23)
Remaining aging time for an IPv6 PIM snooping neighbor on the port.
This field is always displayed for a global port (such as Layer 2 aggregate interfaces).
(In standalone mode.) For a non-global port, this field is displayed when one of the following conditions exists:
·     The port is on the specified card.
·     The port is on the MPU and no card is specified.
(In IRF mode.) For a non-global port, this field is displayed when one of the following conditions exists:
·     The port is on the global active MPU and no card is specified.
LAN Prune Delay
IPv6 PIM hello message sent by the IPv6 PIM snooping neighbor has the LAN_Prune_Delay option.
(T)
The join report suppression feature has been disabled for the IPv6 PIM snooping neighbor.
display ipv6 pim-snooping router-port
Use display ipv6 pim-snooping router-port to display IPv6 PIM snooping router port information.
In standalone mode:
display ipv6 pim-snooping router-port [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
In IRF mode:
display ipv6 pim-snooping router-port [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6 PIM snooping router port information for all VLANs.
verbose: Displays detailed information about IPv6 PIM snooping router ports. If you do not specify this keyword, the command displays brief information about IPv6 PIM snooping router ports.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 PIM snooping router port information for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 PIM snooping router port information for the global active MPU. (In IRF mode.)
# Display IPv6 PIM snooping router port information for VLAN 2.
<Sysname> display ipv6 pim-snooping router-port vlan 2
VLAN 2:
  Router ports (2 in total):
    FGE1/0/1                              (00:01:30)
    FGE1/0/2                              (00:01:32)
VLAN 2
VLAN ID.
Router slots (0 in total)
(In standalone mode.) Slot numbers and total number of the cards that have router ports, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have router ports, except for the specified card or the global active MPU when no card is specified.
Router ports and total number of router ports.
(00:01:30)
Remaining aging time for the router port.
For a global port, this field is always displayed.
display ipv6 pim-snooping routing-table
Use display ipv6 pim-snooping routing-table to display IPv6 PIM snooping routing entries.
In standalone mode:
display ipv6 pim-snooping routing-table [ vlan vlan-id ] [slot slot-number ] [ verbose ]
In IRF mode:
display ipv6 pim-snooping routing-table [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6 PIM snooping routing entries for all VLANs.
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that holds the card. If you do not specify a card, this command displays IPv6 PIM snooping routing entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 PIM snooping routing entries for the global active MPU. (In IRF mode.)
verbose: Displays detailed information about IPv6 PIM snooping routing entries. If you do not specify this keyword, the command displays brief information about IPv6 PIM snooping routing entries.
# Display detailed information about IPv6 PIM snooping routing entries for VLAN 2.
<Sysname> display ipv6 pim-snooping routing-table vlan 2 verbose
Total 1 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 2: Total 1 entries.
  (2000::1, FF1E::1)
    FSM information: dummy
    Upstream neighbor: FE80::101
      Upstream Slots (0 in total):
      Upstream Ports (1 in total):
        FGE1/0/1
      Downstream Slots (0 in total):
      Downstream Ports (2 in total):
        FGE1/0/2
          Expires: 00:03:01, FSM: J
          Downstream Neighbors (2 in total):
            1001::1
              Expires: 00:59:19, FSM: J
            1001::2
              Expires: 00:59:20, FSM: J
        FGE1/0/3
          Expires: 00:02:21, FSM: PP
Total 1 entries
Total number of (S, G) and (*, G) entries.
State machine flag of the downstream port:
·     NI—Initial state.
·     J—Join.
·     PP—Prune pending.
Total number of (S, G) entries in VLAN 2.
(2000::1, FF1E::1)
(S, G) entry.
FSM information
Finite state machine information for the entry:
·     delete—The entry attributes have been deleted.
·     dummy—The entry is a new temporary entry.
·     no info—The entry does not exist.
·     normal—The entry is a correct entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
(In standalone mode.) Slot numbers and total number of the cards that have the upstream neighbor, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have the upstream neighbor, except for the specified card or the global active MPU when no card is specified.
Upstream ports, and the total number of the ports.
(In standalone mode.) This field is displayed when one of the following conditions exists:
(In IRF mode.) This field is displayed when one of the following conditions exists:
(In standalone mode.) Slot numbers and total number of the cards that have downstream ports, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have downstream ports, except for the specified card or the global active MPU when no card is specified.
Remaining aging time for the downstream port or downstream neighbor, and the finite sate machine information.
display ipv6 pim-snooping statistics
Use display ipv6 pim-snooping statistics to display statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
# Display statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
<Sysname> display ipv6 pim-snooping statistics
Received IPv6 PIM hello:  100
Received IPv6 PIM join/prune:  100
Received IPv6 PIM error:  0
Received IPv6 PIM messages in total:  200
Number of received IPv6 PIM hello messages.
Number of received IPv6 PIM join/prune messages.
Number of received IPv6 PIM messages with errors.
Total number of received IPv6 PIM messages.
reset ipv6 pim-snooping statistics
ipv6 pim-snooping enable
Use ipv6 pim-snooping enable to enable IPv6 PIM snooping for a VLAN.
Use undo ipv6 pim-snooping enable to disable IPv6 PIM snooping for a VLAN.
IPv6 PIM snooping is disabled for a VLAN.
VLAN view
IPv6 PIM snooping does not take effect on sub-VLANs of IPv6 multicast VLANs.
You must enable the MLD snooping feature and enable MLD snooping for a VLAN before you execute this command.
# Enable the MLD snooping feature, and then enable MLD snooping and IPv6 PIM snooping for VLAN 2.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] ipv6 pim-snooping enable
mld-snooping
mld-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
Use ipv6 pim-snooping graceful-restart join-aging-time to set the aging time for global downstream ports and global router ports on the new active MPU after an active/standby switchover.
Use undo ipv6 pim-snooping graceful-restart join-aging-time to restore the default.
ipv6 pim-snooping graceful-restart join-aging-time seconds
The aging time is 210 seconds for global downstream ports and global router ports on the new active MPU after an active/standby switchover.
VLAN view
seconds: Specifies an aging time in the range of 210 to 18000 seconds.
You must enable IPv6 PIM snooping for a VLAN before you execute this command.
Global ports include Layer 2 aggregate interfaces. A global downstream port or a global router port is a global port that acts as a downstream port or router port, respectively.
# In VLAN 2, set the aging time to 300 seconds for global downstream ports and global router ports on the new active MPU after an active/standby switchover.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 pim-snooping graceful-restart join-aging-time 300
ipv6 pim-snooping graceful-restart neighbor-aging-time
Use ipv6 pim-snooping graceful-restart neighbor-aging-time to set the aging time for global neighbor ports on the new active MPU after an active/standby switchover.
Use undo ipv6 pim-snooping graceful-restart neighbor-aging-time to restore the default.
ipv6 pim-snooping graceful-restart neighbor-aging-time seconds
The aging time is 105 seconds for global neighbor ports on the new active MPU after an active/standby switchover.
VLAN view
seconds: Specifies an aging time in the range of 105 to 18000 seconds.
Global ports include Layer 2 aggregate interfaces. A global neighbor port is a global port that acts as a neighbor port.
# In VLAN 2, set the aging time to 300 seconds for global neighbor ports on the new active MPU after an active/standby switchover.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 pim-snooping graceful-restart neighbor-aging-time 300
Use reset ipv6 pim-snooping statistics to clear statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
# Clear statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
<Sysname> reset ipv6 pim-snooping statistics
