- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Device management commands
- 10-Tcl commands
- 11-Python commands
- 12-License management commands
- 13-Preprovisioning commands
| 13-Preprovisioning commands | 51.72 KB |
chassis slot
Use chassis slot to select a slot to provision and enter slot view.
chassis chassis-number slot slot-number
chassis chassis-number slot slot-number: Specifies an interface card slot on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the interface card to be preprovisioned.
# Enter the slot view of slot 1 in chassis 1.
[Sysname] chassis 1 slot 1
[Sysname-chassis-1-slot-1]
provision
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
· duplex
· location
· speed
· sflow
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
interface FortyGigE1/1/0/1
speed 40000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision [ subslot subslot-number ] model model
undo provision [ subslot subslot-number ] model
Preprovisioning is disabled.
Slot view
subslot subslot-number: Specifies a subslot by its subslot number. If you do not specify a subslot, preprovisioning is enabled on the slot. To specify a subslot, you must first enable provisioning on the slot and make sure the provisioned slot has subslots.
model model: Specifies the card, IRF member device, or subcard model to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
CAUTION: · When you disable preprovisioning on a slot, the device removes all preconfigured settings for the slot, including the preconfigured settings for the subslots. · When you disable preprovisioning on a subslot, the device removes preconfigured settings for the subslot. |
This command allows you to enable preprovisioning on offline modules, including interface cards, subcards, and IRF member devices.
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command will not display these interfaces until the module comes online.
# Enable preprovisioning for the LSVM1QGS12FX1 module on a slot.
[Sysname-chassis-1-slot-1] provision model LSVM1QGS12FX1
chassis slot
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned modules that repeatedly come online and go offline (or join and leave the IRF fabric) might leave a number of commands that were not applied in memory. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
