H3C Access Points Comware 7 Configuration Examples-6W102
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Points Comware 7 Configuration Examples-6W102
07-H3C Access Points IPv6 Configuration Examples (V7)
H3C Access Points
Comware 7 IPv6 Access
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring IPv6 access.
This document applies to Comware 7-based APs. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of DHCPv6, WLAN authentication, and WLAN access.
Example: Configuring IPv6 access
As shown in Figure 1, the clients associate with the AP to access the network. Configure the AP to act as a DHCP server to assign addresses to client 1 and assign a prefix in prefix range 3001::/64 to client 2. Make sure the following requirements are met:
·     Client 1 joins VLAN 200 and client 2 joins VLAN 300.
·     The WLAN uses IPv6 addresses.
Figure 1 Network diagram
Procedures
1.     Configure VLAN interfaces:
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. Client 1 will join this VLAN after coming online.
<AP> system-view
[AP] vlan 200
[AP-vlan200] quit
[AP] interface vlan-interface 200
[AP-Vlan-interface200] ipv6 address 2001::1/64
[AP-Vlan-interface200] quit
# Create VLAN 300 and VLAN-interface 300, and assign an IP address to the VLAN interface. Client 2 will join this VLAN after coming online.
[AP] vlan 300
[AP-vlan300] quit
[AP] interface vlan-interface 300
[AP-Vlan-interface300] ipv6 address 3001::1/64
[AP-Vlan-interface300] quit
# Configure uplink interface VLAN-interface 1 to use DHCP for IP address acquisition.
[AP] interface vlan-interface 1
[AP-Vlan-interface1] ip address dhcp-alloc
[AP-Vlan-interface1] quit
2.     Configure the DHCPv6 service:
# Enable the DHCPv6 server on the VLAN interfaces.
[AP-Vlan-interface200] ipv6 dhcp select server
[AP-Vlan-interface300] ipv6 dhcp select server
# Disable RA message suppression, and set both the managed address configuration flag (M) and the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
[AP-Vlan-interface200] undo ipv6 nd ra halt
[AP-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[AP-Vlan-interface200] ipv6 nd autoconfig other-flag
[AP-Vlan-interface300] undo ipv6 nd ra halt
[AP-Vlan-interface300] ipv6 nd autoconfig managed-address-flag
[AP-Vlan-interface300] ipv6 nd autoconfig other-flag
# Create a DHCPv6 address pool 1, and specify subnet 2000::0/64. The AP will use this address pool to assign addresses to client 1.
[AP] ipv6 dhcp pool 1
[AP-dhcp6-pool-1] network 2000::0/64
[AP-dhcp6-pool-1] quit
# Create prefix pool 1, and specify prefix 3001::/64 with an assigned prefix length of 64.
[AP] ipv6 dhcp prefix-pool 1 prefix 3001::/64 assign-len 64
# Create a DHCPv6 address pool 2, and specify gateway address 3001::1. The AP will use this address pool to assign addresses to client 2.
[AP] ipv6 dhcp pool 2
[AP-dhcp6-pool-2] gateway-list 3001::1
# Apply prefix pool 1 to address pool 2.
[AP-dhcp6-pool-2] prefix-pool 1
[AP-dhcp6-pool-2] quit
3.     Configure wireless services:
# Create service template 1 and enter its view.
[AP] wlan service-template 1
# Configure the SSID as service1.
[AP-wlan-st-1] ssid service1
# Specify VLAN 200 for the service template.
[AP-wlan-st-1] vlan 200
# Enable the service template.
[AP-wlan-st-1] service-template enable
# Enable snooping DHCPv6 packets and snooping ND packets.
[AP-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
[AP-wlan-st-1] client ipv6-snooping nd-learning enable
[AP-wlan-st-1] quit
# Create service template 2 and enter its view.
[AP] wlan service-template 2
# Configure the SSID as service2.
[AP-wlan-st-2] ssid service2
# Specify VLAN 300 for the service template.
[AP-wlan-st-2] vlan 300
[AP-wlan-st-2] service-template enable
[AP-wlan-st-2] client ipv6-snooping dhcpv6-learning enable
[AP-wlan-st-2] client ipv6-snooping nd-learning enable
[AP-wlan-st-2] quit
4.     Bind service templates to radio interfaces:
# Enter interface view of interface WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
# Bind service template 1 to interface WLAN-Radio 1/0/1.
[AP-WLAN-Radio1/0/1] service-template 1
# Bind service template 2 to interface WLAN-Radio 1/0/1.
[AP-WLAN-Radio1/0/1] service-template 2
[AP-WLAN-Radio1/0/1] quit
# Verify that client 1 and client 2 can access the IPv6 WLAN successfully.
[AP] display wlan client ipv6
MAC address    AP name              IPv6 address                            VLAN
3829-5a40-9589 fatap                2001::4D34:CD98:CB21:D6F7               200
68ef-4338-9513 fatap                3001::2                                 300
Related documentation
·     Network Connectivity Command Reference in H3C Access Points Command References
·     Network Connectivity Configuration Guide in H3C Access Points Configuration Guides
·     WLAN Access Command Reference in H3C Access Points Command References
·     WLAN Access Configuration Guide in H3C Access Points Configuration Guides
