H3C Access Points Comware 7 Configuration Examples-6W102
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Points Comware 7 Configuration Examples-6W102
02-H3C Access Points Client Rate Limiting Configuration Examples (V7)
H3C Access Points
Comware 7 Client Rate Limiting
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring client rate limiting.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of client rate limiting.
Example: Configuring client rate limiting
As shown in Figure 1, the clients access the WLAN provided by the AP. The AP obtains IP addresses from a DHCP server in the IP network.
·     Configure the AP to act as a DHCP server to assign IP addresses to the clients.
·     Configure client rate limit to limit the incoming traffic rate to 4000 Kbps in static mode, and limit the outgoing traffic rate to 16000 Kbps in dynamic mode.
Figure 1 Network diagram
Procedures
1.     Configure AP interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AP will use this IP address to communicate with clients.
<AP>system-view
[AP] vlan 100
[AP-vlan100] quit
[AP] interface vlan-interface 100
[AP-Vlan-interface100] ip address 192.1.1.1 24
[AP-Vlan-interface100] quit
# Configure uplink interface VLAN-interface 1 to obtain IP addresses through DHCP.
[AP-Vlan-interface1] undo ip address
[AP-Vlan-interface1] ip address dhcp-alloc
[AP-Vlan-interface1] quit
2.     Configure wireless services:
# Create service template service and enter its view.
[AP] wlan service-template service
# Configure the SSID as service.
[AP-wlan-st-service] ssid service
# Specify VLAN 100 for clients to access the WLAN defined by the service template.
[AP-wlan-st-service] vlan 100
# Specify PSK as the AKM mode and specify 12345678 as the plaintext key.
[AP-wlan-st-service] akm mode psk
[AP-wlan-st-service] preshared-key pass-phrase simple 12345678
# Specify CCMP as the cipher suite and specify RSN as the security IE.
[AP-wlan-st-service] cipher-suite ccmp
[AP-wlan-st-service] security-ie rsn
# Configure rate limiting for the service template: set the CIR to 4000 Kbps for each client's incoming traffic and set the CIR to 16000 Kbps for total outgoing traffic of all clients.
[AP-wlan-st-service] client-rate-limit enable
[AP-wlan-st-service] client-rate-limit inbound mode static cir 4000
[AP-wlan-st-service] client-rate-limit outbound mode dynamic cir 16000
# Enable the service template.
[AP-wlan-st-service] service-template enable
[AP-wlan-st-service] quit
3.     Bind the service template to interface WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
[AP-WLAN-Radio1/0/1] service-template service
[AP-WLAN-Radio1/0/1] quit
4.     Configure the DHCP service:
# Enable DHCP.
[AP] dhcp enable
# Create a DHCP address pool named vlan100, specify subnet 192.1.1.0/24, and specify gateway address 192.1.1.1.
[AP] dhcp server ip-pool vlan100
[AP-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
[AP-dhcp-pool-vlan100] gateway-list 192.1.1.1
[AP-dhcp-pool-vlan100] quit
# Verify that the incoming rate of each client does not exceed 4000 Kbps, and the total outgoing rate of all clients does not exceed 16000 Kbps.
Configuration files
 dhcp enable
vlan 1
vlan 100
 ssid service
 vlan 100
 akm mode psk
 preshared-key pass-phrase cipher $c$3$7hZ2DNiI+h/ajPE7DhZbD6Y7py9vqf4721sp
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface1
interface Vlan-interface100
 ip address 192.1.1.1 255.255.255.0
interface WLAN-Radio1/0/1
return
Related documentation
·     WLAN QoS Command Reference in H3C Access Points Command References
·     WLAN QoS Configuration Guide in H3C Access Points Configuration Guides
