H3C Access Points Comware 7 Configuration Examples-6W102
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Points Comware 7 Configuration Examples-6W102
04-H3C Access Points PPPoE Configuration Examples (V7)
H3C Access Points
Comware 7 PPPoE Configuration Examples
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring PPPoE.
This document applies to Comware 7-based APs. Procedures and information in the examples might be slightly different depending on the software or hardware version of the APs.
This document assumes that you have basic knowledge of PPPoE.
Example: Configuring PPPoE
As shown in Figure 1, the wireless clients access the network through the AP. The AP assigns IP addresses to the clients as a DHCP server. The device acts as a PPPoE server, and the AP acts as a PPPoE client.
Configure the device and the AP to meet the following requirements:
·     The device performs one-way authentication on the wireless clients without using usernames.
·     The PPPoE session on the AP works in permanent mode.
·     Clients can initiate connection requests to access the resources in the IP network.
Figure 1 Network diagram
Procedures
Configuring the device
# Create a network access user named user1.
[Device] local-user user1 class network
# Set the password to pass1 in plaintext form for the user, and authorize the user to use the PPP service.
[Device-luser-network-user1] password simple pass1
[Device-luser-network-user1] service-type ppp
[Device-luser-network-user1] quit
# Create VT interface 1.
[Device] interface virtual-template 1
# Configure the VT interface to authenticate the peer by using CHAP, with the authentication domain as domain system.
[Device-Virtual-Template1] ppp authentication-mode chap domain system
# Configure an IP address for the VT interface and specify an IP address for the peer.
[Device-Virtual-Template1] ip address 1.1.1.1 255.255.255.0
[Device-Virtual-Template1] remote address 1.1.1.2
[Device-Virtual-Template1] quit
# Enable the PPPoE server on GigabitEthernet 1/0/2, and bind the interface to the VT interface.
[Device-GigabitEthernet1/0/2] pppoe-server bind virtual-template 1
# Configure local authentication for the PPP users in ISP domain system.
[Device] domain system
[Device-isp-system] authentication ppp local
[Device-isp-system] quit
Configuring the AP
1.     Configure VLANs and VLAN interfaces on the AP:
# Create VLAN 100 and its VLAN interface, and assign an IP address to the VLAN interface.
<AP> system-view
[AP] vlan 100
[AP-vlan100] quit
[AP] interface vlan-interface 100
[AP-Vlan-interface100] ip address 192.1.0.1 24
[AP-Vlan-interface100] quit
2.     Configure the wireless service template:
# Create a service template named service and enter its view.
[AP] wlan service-template service
# Configure service as the SSID.
[AP-wlan-st-service] ssid service
# Assign clients coming online through service template 100 to VLAN 100.
[AP-wlan-st-service] vlan 100
# Configure the PSK AKM mode and the 12345678 plaintext key.
[AP-wlan-st-service] akm mode psk
[AP-wlan-st-service] preshared-key pass-phrase simple 12345678
# Configure CCMP as the cipher suite and RSN as the security IE.
[AP-wlan-st-service] cipher-suite ccmp
[AP-wlan-st-service] security-ie rsn
# Enable the service template.
[AP-wlan-st-service] service-template enable
[AP-wlan-st-service] quit
# Enter interface view of WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
# Bind service template service to interface WLAN-Radio 1/0/1.
[AP-WLAN-Radio1/0/1] service-template service
[AP-WLAN-Radio1/0/1] quit
3.     Configure the DHCP server:
# Configure DHCP address pool 100 for address allocation to the wireless clients.
[AP] dhcp server ip-pool 100
[AP-dhcp-pool-100] network 192.1.0.0 mask 255.255.255.0
[AP-dhcp-pool-100] gateway-list 192.1.0.1
[AP-dhcp-pool-100] quit
# Enable the DHCP service.
[AP] dhcp enable
4.     Configure the PPPoE client:
# Create dialer group 1 and configure a dial rule for it.
[AP] dialer-group 1 rule ip permit
# Enable bundle DDR on Dialer 1.
[AP] interface dialer 1
[AP-Dialer1] dialer bundle enable
# Associate Dialer 1 with dialer group 1.
[AP-Dialer1] dialer-group 1
# Configure Dialer 1 to obtain an IP address through PPP negotiation.
[AP-Dialer1] ip address ppp-negotiate
[AP-Dialer1] quit
# Configure a PPPoE session that corresponds to dialer bundle 1 (dialer bundle 1 corresponds to Dialer 1).
[AP-Vlan-interface1] pppoe-client dial-bundle-number 1
[AP-Vlan-interface1] quit
# Configure the PPPoE session to operate in permanent mode.
[AP-Dialer1] dialer timer idle 0
# Set the DDR auto-dial interval to 60 seconds.
[AP-Dialer1] dialer timer autodial 60
# Configure the username and password for CHAP authentication.
[AP-Dialer1] ppp chap user user1
[AP-Dialer1] ppp chap password simple pass1
[AP-Dialer1] quit
# Configure a static route.
[AP] ip route-static 1.1.1.1 255.0.0.0 dialer 1
5.     Configure NAT:
# Configure ACL 2000 to permit packets sourced from 192.1.0.0.
[AP] acl basic 2000
[AP-acl-ipv4-basic-2000] rule 0 permit source 192.1.0.0 0.0.0.255
[AP-acl-ipv4-basic-2000] quit
# Configure an outbound dynamic PAT rule on VLAN-interface 1 to translate the source IP addresses permitted by ACL 2000.
[AP-Vlan-interface1] nat outbound 2000
# Display summary information about the PPPoE session on the AP.
[AP] display pppoe-client session summary
Bundle ID    Interface    VA           RemoteMAC      LocalMAC       State
1      1     Vlan1        VA0          00e0-1400-4300 00e0-1500-4100 SESSION
Configuration files
·     Device:
 sysname Device
vlan 1
interface Virtual-Template1
interface GigabitEthernet 1/0/2
 port link-mode route
domain system
 domain default enable system
 password cipher $c$3$d3q9pKjQeMNyFxOjfKRkD7HF6XDPDFet
 service-type ppp
Return
·     AP:
 sysname AP
 dhcp enable
vlan 1
vlan 100
 ssid service
 vlan 100
 akm mode psk
 preshared-key pass-phrase cipher $c$3$7hZ2DNiI+h/ajPE7DhZbD6Y7py9vqf4721sp
 cipher-suite ccmp
 security-ie rsn
interface Dialer1
 ppp chap password cipher $c$3$y9xXZso6tDA2+FSK8p+0qiC61/eATRxj
 ppp chap user user1
 dialer-group 1
 dialer timer idle 0
 nat outbound 2000
interface Vlan-interface1
interface Vlan-interface100
 ip address 192.1.0.1 255.255.255.0
interface WLAN-Radio1/0/1
ip route-static 1.1.1.0 24 Dialer1
acl basic 2000
return
Related documentation
·     Network Connectivity Command Reference in H3C Access Points Command References
·     Network Connectivity Configuration Guide in H3C Access Points Configuration Guides
·     WLAN Access Command Reference in H3C Access Points Command References
·     WLAN Access Configuration Guide in H3C Access Points Configuration Guides
