- 02-System Management Configuration Guide
- 01-Basic device management configuration
- 02-Device hardening configuration
- 03-Hardware resource management configuration
- 04-EAA configuration
- 05-Process monitoring and maintenance configuration
- 06-Fast log output configuration
- 07-Flow log configuration
- 08-Information center configuration
- 09-GOLD configuration
03-Hardware resource management configuration | 128.10 KB |
Hardware resource management tasks at a glance
Configuring CPU usage tracking
Displaying CPU usage monitoring information
Setting memory alarm thresholds
Displaying memory usage monitoring information
Displaying device temperature information
Setting the port status detection timer
Setting the operating mode for an interface card
Verifying and diagnosing transceiver modules
Diagnosing transceiver modules
Specifying an ITU channel number for a transceiver module
Displaying device hardware information
Managing hardware resources
This chapter describes routine device hardware resource management tasks, including monitoring CPU and memory usage, displaying power supply and fan operating status, and configuring basic device operating parameters.
All hardware resource management tasks are optional. You can perform any of the tasks in any order.
· Monitoring CPU usage
¡ Configuring CPU usage alarm
¡ Configuring CPU usage tracking
¡ Displaying CPU usage monitoring information
· Monitoring memory usage
¡ Setting memory alarm thresholds
¡ Displaying memory usage monitoring information
· Monitoring device temperature
¡ Displaying device temperature information
· Setting the port status detection timer
· Verifying and diagnosing transceiver modules
¡ Verifying transceiver modules
¡ Diagnosing transceiver modules
· Specifying an ITU channel number for a transceiver module
· Displaying device hardware information
· Displaying device hardware electronic label information
· Displaying device hardware alarm information
The device samples CPU usage at 1-minute intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
The device supports the following CPU usage thresholds:
· Minor threshold—If the CPU usage increases to or above the minor threshold but is less than the severe threshold, the CPU usage enters minor alarm state. The device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
· Severe threshold—If the CPU usage increases above the severe threshold, the CPU usage enters severe alarm state. The device sends severe alarms periodically until the severe alarm is removed.
· Recovery threshold—If the CPU usage decreases below the recovery threshold, the CPU usage enters recovered state. The device sends a recovery notification.
CPU usage alarms and notifications can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information about NETCONF and SNMP, see Network Management and Monitoring Configuration Guide. For more information about information center, see "Configuring the information center."
Figure 1 CPU alarms and alarm-removed notifications
Figure 2 CPU alarms and alarm-removed notifications
1. Enter system view.
2. Set the CPU usage alarm thresholds.
monitor cpu-usage threshold severe-threshold [ slot slot-number [ cpu cpu-number ] ]
By default, the CPU usage alarm threshold is 99%.
CAUTION: If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected. |
After you enable CPU usage tracking, the system samples CPU usage at intervals and saves the samples to a buffer. You can use the display cpu-usage history command to view the recent CPU usage.
2. Set the sampling interval for CPU usage tracking.
By default, the sampling interval for CPU usage tracking is 1 minute.
3. Enable CPU usage tracking.
By default, CPU usage tracking is enabled.
· Display CPU usage monitoring settings.
· Display the current CPU usage statistics.
display cpu-usage [data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
· Display the historical CPU usage statistics in a coordinate system.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space reaches the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules and processes.
(On devices that do not support low memory.) You can use the display memory command to display memory usage information.
(On devices that support low memory.) The system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information.
(On devices with slots that support low memory.) For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
The early warning feature warns you of an approaching insufficient-memory condition.
As shown in Table 1 and Figure 3, the system supports the following free-memory thresholds:
· Sufficient-memory threshold.
· Early-warning threshold.
· Normal state threshold.
· Minor alarm threshold.
· Severe alarm threshold.
· Critical alarm threshold.
Table 1 Memory alarm notifications and memory alarm-removed notifications
Notification |
Triggering condition |
Remarks |
Early-warning notification |
The amount of free memory space decreases to or below the early-warning threshold. |
After generating and sending an early-warning notification, the system does not generate and send any additional early-warning notifications until the early warning is removed. |
Minor alarm notification |
The amount of free memory space decreases to or below the minor alarm threshold. |
After generating and sending a minor alarm notification, the system does not generate and send any additional minor alarm notifications until the minor alarm is removed. |
Severe alarm notification |
The amount of free memory space decreases to or below the severe alarm threshold. |
After generating and sending a severe alarm notification, the system does not generate and send any additional severe alarm notifications until the severe alarm is removed. |
Critical alarm notification |
The amount of free memory space decreases to or below the critical alarm threshold. |
After generating and sending a critical alarm notification, the system does not generate and send any additional critical alarm notifications until the critical alarm is removed. |
Critical alarm-removed notification |
The amount of free memory space increases above the severe alarm threshold. |
N/A |
Severe alarm-removed notification |
The amount of free memory space increases above the minor alarm threshold. |
N/A |
Minor alarm-removed notification |
The amount of free memory space increases above the normal state threshold. |
N/A |
Early-warning-removed notification |
The amount of free memory space increases above the sufficient-memory threshold. |
N/A |
Figure 3 Memory alarm notifications and alarm-removed notifications
Figure 4 Memory alarm notifications and alarm-removed notifications
2. Set the memory usage threshold.
By default, the memory usage threshold is 100%.
3. Set the free-memory thresholds.
The default settings are as follows:
¡ Minor alarm threshold—256 MB.
¡ Severe alarm threshold—192 MB.
¡ Critical alarm threshold—128 MB.
¡ Normal state threshold—320 MB.
¡ Early-warning threshold—384 MB.
¡ Sufficient-memory threshold—448 MB.
· Display memory usage information.
· Display memory alarm thresholds and statistics.
To display device temperature information, execute the following command in any view:
Monitoring fans
Displaying fan information
· Display fan tray operating status information.
display fan [ fan-id ] [ verbose ]
· Display electronic label information for a fan tray.
display device manuinfo fan fan-id
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
2. Set the port status detection timer.
shutdown-interval time
The default setting is 30 seconds.
Some interface cards can operate in multiple modes to provide different types of interfaces. Use this feature to set the operating mode for an interface card.
For the new setting to take effect, you must perform one of the following tasks to activate the setting:
· Restart the device.
· Hot swap the interface card if the interface card supports hot swapping.
2. Set the operating mode for an interface card.
card-mode slot slot-number subslot subslot-number mode-name
The default varies by device model.
Supported operating modes depend on the card model.
You can use one of the following methods to verify the genuineness of a transceiver module:
· Display the key parameters of a transceiver module, including its transceiver type, connector type, central wavelength of the transmit laser, transfer distance, and vendor name.
· Display its electronic label. The electronic label is a profile of the transceiver module and contains the permanent configuration, including the serial number, manufacturing date, and vendor name. The data was written to the transceiver module or the device's storage component during debugging or testing of the transceiver module or device.
The device regularly checks transceiver modules for their vendor names. If a transceiver module does not have a vendor name or the vendor name is not H3C, the device repeatedly outputs traps and log messages. For information about logging rules, see "Configuring the information center."
To verify transceiver modules, execute the following commands in any view:
· Display the key parameters of transceiver modules.
· Display the electrical label information of transceiver modules.
The device provides the alarm and digital diagnosis functions for transceiver modules. When a transceiver module fails or is not operating correctly, you can perform the following tasks:
· Check the alarms that exist on the transceiver module to identify the fault source.
· Examine the key parameters monitored by the digital diagnosis function, including the temperature, voltage, laser bias current, TX power, and RX power.
To diagnose transceiver modules, execute the following commands in any view:
· Display transceiver alarms.
· Display the current values of the digital diagnosis parameters on transceiver modules.
ITU numbers and identifies fiber signals by wavelength and frequency. A transceiver module sends signals of a specific wavelength and frequency based on the specified ITU channel number.
This feature is required in dense wavelength division multiplexing scenarios.
This feature is supported only on the HPE X130 10G SFP+ LC LH80 Tunable Transceiver (JL250A) module.
This feature is supported only on the SFP-XG-LH80-Tunable transceiver module.
The ITU channel number is saved in a register on the transceiver module. It is not saved to the configuration file.
2. Enter Ethernet interface view.
3. Specify an ITU channel number.
itu-channel channel-number
By default, the ITU channel number is 1.
Displaying ITU channel information
To display ITU channel information for transceiver modules, execute the following command in any view:
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
To display device hardware information, execute the following command in any view:
display device [ flash | harddisk | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
To display hardware electronic label information for the device, execute the following command in any view:
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
To display device hardware alarm information, execute the following command in any view:
display alarm [ slot slot-number ]
