11-Segment Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9119-6W10011-Segment Routing Command Reference
04-SRv6 VPN commands
04-SRv6 VPN commands 246.11 KB
SRv6 VPN commands
display l2vpn forwarding srv6
Use display l2vpn forwarding srv6 to display L2VPN SRv6 forwarding information.
display l2vpn forwarding srv6 [ vsi vsi-name | xconnect-group group-name ] [ slot slot-number ] [ verbose ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The group name cannot contain hyphens (-).
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays L2VPN SRv6 forwarding information on the active MPU.
verbose: Displays detailed L2VPN SRv6 forwarding information. If you do not specify this keyword, the command displays only brief L2VPN SRv6 forwarding information.
If you do not specify a VSI or a cross-connect group, this command displays L2VPN SRv6 forwarding information for all VSIs and cross-connect groups.
# Display brief L2VPN SRv6 forwarding information.
<Sysname> display l2vpn forwarding srv6
Total number of cross-connections: 1
Total number of VSIs: 1
Total number of SRv6 tunnels: 2, 2 up, 0 blocked, 0 down
VSI Name : vpnb
Link ID  : 0x9000000   Type: BE     State: Up
In SID   : 100::2
Out SID  : 200::3
Xconnect-group Name : vpna
Connection Name     : pw1
Link ID             : 0x8000000   Type: BE    State: Up
In SID              : 100::1
Out SID             : 200::1
Link ID
Link ID of the SRv6 tunnel in the VSI or cross-connect group.
Route recursion mode.
After the PE receives a customer packet destined for an SID, it forwards the packet according to the route recursion mode.
·     BE—SRv6 BE mode. In this mode, the PE first encapsulates the SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the encapsulated packet.
·     TE—SRv6 TE mode. In this mode, the PE first searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the SID assigned to L2VPN and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy.
·     BE/TE—SRv6 TE and SRv6 BE hybrid mode. In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
SRv6 tunnel status:
·     Up—The SRv6 tunnel is up.
·     Down—The SRv6 tunnel is down.
·     Blocked—The SRv6 tunnel is a bakup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
In SID
Input SID, which is a local SID.
Out SID
Output SID, which is a remote SID.
# Display detailed L2VPN SRv6 forwarding information.
<Sysname> display l2vpn forwarding srv6 verbose
VSI Name: vpnb
  Link ID                : 0x9000000
  SRv6 Tunnel State      : Up
  In  SID                : 200::3
  Out SID                : 100::2
  MTU                    : 1500
  SRv6 Tunnel Attributes : Main
  Tunnel NHLFE IDs       : -
  Remote Leaf Argument   : -
Xconnect-group Name: vpna
 Connection Name: pw1
  Link ID                : 0x8000000
  In  SID                : 200::1
  Out SID                : 100::1
  MTU                    : 1500
Link ID
Link ID of the SRv6 tunnel on the VSI or cross-connect group.
SRv6 Tunnel State
SRv6 tunnel status:
In SID
Out SID
MTU
Maximum transmission unit, in bytes.
SRv6 tunnel attributes:
·     Main—The primary tunnel.
·     Backup—The backup tunnel.
·     ac-Bypass—The Bypass tunnel for AC bypass.
·     ECMP—ECMP tunnel.
Tunnel NHLFE IDs
NHLFE entry IDs of the candidate paths in an SRv6 TE policy.
If service traffic is not forwarded through an SRv6 TE policy tunnel, this field displays a hyphen (-).
Argument value used by the remote PE to identify leaf ACs.
If no argument value exists, this field displays a hyphen (-).
display l2vpn peer srv6
Use display l2vpn peer srv6 to display L2VPN SRv6 information.
display l2vpn peer srv6 [ vsi vsi-name | xconnect-group group-name ] [ state-machine | verbose ]
state-machine: Displays L2VPN SRv6 state machine information.
verbose: Displays detailed L2VPN SRv6 information.
If you do not specify a VSI or a cross-connect group, this command displays L2VPN SRv6 information for all VSIs and cross-connect groups.
If you do not specify the state-machine or verbose keyword, this command displays brief information about L2VPN SRv6.
# Display brief information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6
Total number of SRv6 Tunnels: 2
VSI Name: vpnb
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Remote SrvID    : 2
# Display detailed information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6 verbose
VSI Name: vpnb
  Peer: 2::2
   Signaling Protocol            : EVPN
   Link ID                       : 0x9000000
   In SID                        : 100::2
   Out SID                       : 200::3
   MTU                           : 1500
   Tunnel Group ID               : 0x1000000030000000
   Tunnel NHLFE IDs              : 0
   Color                         : -
   Recursion Mode                : SID based
   Output Statistics             :
     Octets             : 0
     Packets            : 0
     Errors             : 0
     Discards           : 0
   Output Rate                   :
     Bytes per second   : 0
     Packets per second : 0
  Peer: 2::2
   Remote Service ID             : 2
   Link ID                       : 0x8000000
   In SID                        : 100::1
   Out SID                       : 200::1
   MTU                           : 1500
   Color                         : -
   Input Statistics              :
     Octets             : 0
     Packets            : 0
     Errors             : 0
     Discards           : 0
   Output Statistics             :
     Octets             : 0
     Packets            : 0
     Errors             : 0
     Discards           : 0
   Input Rate                    :
   Output Rate                   :
Peer
IPv6 address of the peer PE.
Flag
SRv6 tunnel flags:
·     ECMP—ECMP tunnel.
State/SRv6 Tunnel State
SRv6 tunnel status:
·     Blocked—The SRv6 tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
Remote SrvID/Remote Service ID
Remote service ID.
Signaling Protocol
Signaling protocol used to establish the SRv6 tunnel. The value is EVPN.
Link ID
In SID
Out SID
MTU
·     ECMP—ECMP tunnel.
Tunnel Group ID
ID of the public network tunnel group that carries the SRv6 tunnel.
Tunnel NHLFE IDs
Color
Color attribute of the expected SRv6 TE policy for route recursion.
If no color attribute is available, this field displays a hyphen (-).
Recursion Mode
Route recursion mode of the SRv6 tunnel:
·     SID based—SRv6 BE mode.
·     Nexthop based—SRv6 TE mode.
·     Nexthop based/SID based—SRv6 TE and SRv6 BE hybrid mode.
Input Statistics
SRv6 PW incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
·     Errors—Number of error packets.
·     Discards—Number of dropped packets.
This field is not available in an EVPN VPLS over SRv6 network.
Output statistics
SRv6 PW outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
Input Rate
SRv6 PW incoming traffic rate:
·     Bytes per second—Number of incoming bytes per second.
·     Packets per second—Number of incoming packets per second.
Output Rate
SRv6 PW outgoing traffic rate:
·     Bytes per second—Number of outgoing bytes per second.
·     Packets per second—Number of outgoing packets per second.
# Display state machine information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6 state-machine
SRv6 tunnel group state:
  Idle: Idle    N: Normal    UA: Unavailable    PF: Protecting failure
  P: Protection tunnel failure    W: Working tunnel failure    L: Local
VSI Name: vpnb
  SRv6 Group Link ID            : 0x9000000
    Main SRv6 Tunnel:
      Peer                      : 2::2
    Backup SRv6 Tunnel          : -
    Main SRv6 Defect State      : No defect
    Backup SRv6 Defect State    : -
    Switch Result               : Working
    Switch Reason               : None
    Remote Event                : -
    Local Event                 : SFCW
    SRv6 Group Old State        : Idle
    SRv6 Group State            : UA:P:L
  SRv6 Group Link ID            : 0x8000000
    Main SRv6 Tunnel:
      Peer                      : 2::2
      Service ID                : 2
    Remote Event                : -
    Local Event                 : SFCW
Main SRv6 Tunnel
Primary SRv6 tunnel.
Peer
IPv6 address of the remote PE for the SRv6 tunnel.
Service ID
Service ID of the remote PE.
Backup SRv6 Tunnel
Backup SRv6 tunnel.
Signaling Protocol
Signaling protocol used to establish the SRv6 tunnels. The value is EVPN.
Defect state of the primary SRv6 tunnel:
·     No defect.
·     Signal defect—The signaling protocol detected defects.
Defect state of the backup SRv6 tunnel:
·     No defect.
If no backup SRv6 tunnel exists, this field displays a hyphen (-).
Switch Result
SRv6 tunnel in use after a primary/backup tunnel switchover:
·     None—Neither the primary nor the backup SRv6 tunnel is in use.
·     Working—The primary SRv6 tunnel is in use.
·     Backup—The backup SRv6 tunnel is in use.
Switch Reason
Reason that causes the primary/backup tunnel switchover:
·     Config changed—An SRv6 tunnel is added to or removed from the tunnel redundancy group.
·     Fault dectected—An SRv6 tunnel fault is detected.
·     SRv6 down—The state of an SRv6 tunnel changes from active to down.
·     SRv6 up—The state of an SRv6 tunnel changes from active to up.
·     None—No primary/backup tunnel switchover has occurred.
Remote Event
Remote state machine event.
Local Event
Local state machine event:
·     SFW—Local primary SRv6 tunnel defect event.
·     SFP—Local backup SRv6 tunnel defect event.
·     SFCW—Local primary SRv6 tunnel up event.
·     SFCP—Local backup SRv6 tunnel up event.
·     None—No local event.
SRv6 tunnel redundancy group state before switchover:
·     Idle—Both the primary and backup SRv6 tunnels are not available.
·     Normal—Both the primary and backup SRv6 tunnels are available. The primary SRv6 tunnel is up and the backup SRv6 tunnel is blocked. The primary SRv6 tunnel is used to forward traffic.
·     UA:P:L—The backup SRv6 tunnel has defects and the primary SRv6 tunnel is up.
·     PF:W:L—The primary SRv6 tunnel has defects and the back SRv6 tunnel is up.
SRv6 Group State
SRv6 tunnel redundancy group state after switchover. The supported values are the same as those of the SRv6 Group Old State field.
display l2vpn statistics srv6-pw inbound
Use display l2vpn statistics srv6-pw inbound to display incoming packet statistics for SRv6 PWs in an EVPN VPLS over SRv6 network.
display l2vpn statistics srv6-pw inbound [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays incoming packet statistics for all SRv6 PWs on all VSIs.
Use this command to display incoming packet statistics for all SRv6 PWs on the specified VSI or all VSIs.
To display outgoing packet statistics, use the display l2vpn peer srv6 verbose command.
# Display incoming packet statistics for all SRv6 PWs on VSI aaa.
<Sysname> display l2vpn statistics srv6-pw inbound vsi aaa
VSI name: aaa
  Input statistics:
    Octets             : 0
    Packets            : 0
    Errors             : 0
    Discards           : 0
  Input rate      :
Table 5 Command output
Input statistics
Incoming packet statistics for all SRv6 PWs:
·     Discards—Number of discarded packets.
Input rate
Incoming traffic rate for all SRv6 PWs:
reset l2vpn statistics srv6-pw
statistics enable
display l2vpn vsi
Use display l2vpn vsi to display L2VPN VSI information.
display l2vpn vsi [ evpn-srv6 | name vsi-name ] [ count | verbose ]
evpn-srv6: Specifies VSIs in the EVPN VPLS over SRv6 network.
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
count: Displays VSI statistics.
verbose: Displays detailed VSI information.
If you do not specify a VSI or the evpn-srv6 keyword, this command displays L2VPN VSI information for all VSIs.
If you do not specify the count or verbose keyword, this command displays brief VSI information.
# Display brief information about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpnb                            0               1500   Up
# Display statistics about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6 count
Table 6 Command output
MTU
Maximum transmission unit of the VSI.
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI is manually shut down by using the shutdown command.
# Display detailed information about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6 verbose
VSI Name: vpnb
  VSI Index               : 0
  VSI Description         : vsi for vpnb
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : -
  MAC Learning rate       : Unlimited
  Local MAC aging time    : 300 sec
  Remote MAC aging time   : 300 sec
  Drop Unknown            : Disabled
  PW Redundancy Mode      : Slave
  Statistics              : Disabled
  VXLAN ID                : -
  EVPN Encapsulation      : SRv6
  SRv6 SIDs:
    Dt2U SID  : 222::1(64/64/0)
    Dt2UL SID : 222::2(64/64/0)
    Dt2M SID  : 222::3(64/64/0)
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x9000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE0/0/1                            0x0        Up
    Statistics: Disabled
<Sysname> display l2vpn vsi verbose
VSI Name: vpnb
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Table Limit         : -
  VXLAN ID                : -
  SRv6 SIDs:
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x9000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE0/0/3 srv1                       0x0        Up
Table 7 Command output
VSI Description
VSI description.
If no description is configured, this field is not available.
VSI State
VSI state:
·     Up—The VSI is up.
MTU
Diffserv Mode
DiffServ mode. Options include the following:
·     ingress—DiffServ mode for the inbound direction.
·     egress—DiffServ mode for the outbound direction.
·     pipe—Pipe mode.
·     short-pipe—Short-pipe mode.
·     uniform—Uniform mode
·     trust—Priority trust mode
¡     inner-dot1p—Trusts the inner 802.1p priority in packets.
¡     dscp—Trusts the DSCP in packets.
af1, af2, af3, af4, be, cs6, cs7, or ef represents the MPLS EXP value.
If no DiffServ mode is configured, this field displays a hyphen (-).
Bandwidth
Maximum bandwidth (in kbps) for known unicast traffic on the VSI.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
Multicast Restrain
Multicast restraint bandwidth (in kbps).
Unknown unicast restraint bandwidth (in kbps).
MAC Learning
State of the MAC learning feature.
MAC Tabel Limit
Maximum number of MAC address entries on the VSI.
If the VSI does not limit the maximum number of MAC address entries, this field displays Unlimited.
MAC Learning rate
MAC address entry learning rate of the VSI.
MAC aging time for dynamic local-MAC entries, in seconds.
If dynamic local-MAC entries do not age out, this field displays NotAging.
MAC aging time for dynamic remote-MAC entries, in seconds.
If dynamic remote-MAC entries do not age out, this field displays NotAging.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
PW Redundancy Mode
PW redundancy operation mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
·     Independent—Independent mode.
Flooding
State of the VSI's flooding feature.
This field is not supported by VPLS.
Statistics
Packet statistics state.
Input Statistics
Incoming traffic statistics:
Output statistics
Outgoing traffic statistics:
Input Rate
Incoming traffic rate:
Output Rate
Outgoing traffic rate:
VXLAN ID
VXLAN ID.
EVPN Encapsulation
EVPN encapsulation type:
·     VXLAN.
·     MPLS.
·     SRv6.
SRv6 SIDs
SRv6 SIDs of the VSI.
Dt2U SID
SRv6 SID used for unicast forwarding in the EVPN VPLS over SRv6 network. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128.
Dt2Ul SID
SRv6 SID used for unicast forwarding over the bypass tunnel at the multihomed EVPN VPLS over SRv6 site. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128.
Dt2M SID
SRv6 SID used for flood forwarding in the EVPN VPLS over SRv6 network. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128.
SRv6 Tunnels
SRv6 tunnels on the VSI.
Peer
IPv6 address of the PW remote PE.
Link ID
Link ID of the SRv6 tunnel on the VSI.
SRv6 tunnel state, which can be Up, Down, Blocked, or Defect.
ACs
ACs of the VSI.
AC
For a Layer 3 interface, this field displays the interface name.
For an Ethernet service instance, this field displays the name of the Ethernet service instance and the name of the Layer 2 interface where the Ethernet service instance name resides.
Link ID
Link ID of the AC on the VSI.
AC state, which can be Up or Down.
Statistics
AC packet statistics state.
display l2vpn xconnect-group
Use display l2vpn xconnect-group to display L2VPN cross-connect group information.
display l2vpn xconnect-group [ evpn-srv6 | name group-name [ connection connection-name ] ] [ count | verbose ]
evpn-srv6: Specifies cross-connect groups in the EVPN VPWS over SRv6 network.
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters. The cross-connect name cannot contain hyphens (-). If you do not specify a cross-connect, this command displays information about all cross-connects in the specified cross-connect group.
count: Displays cross-connect group statistics.
verbose: Displays detailed cross-connect group information.
If you do not specify a cross-connect group or the evpn-srv6 keyword, this command displays information for all cross-connect groups.
If you do not specify the count or verbose keyword, this command displays brief cross-connect group information.
# Display brief information about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6
Status Codes: UP - Up, DN - Down, DF - Defect, BD - Blocked, AD - Admin Down,
              DL - Idle, DP - Duplicate
Total number of cross-connections: 1, 1 up, 0 down, 0 admin down
Xconnect-group                          Connection                          ST
Segment1                            ST  Segment2                            ST
vpna                                    pw1                                 UP
GE0/0/2                             UP  EVPN   2::2                         UP
# Display statistics about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6 count
Table 8 Command output
ST
State of the cross-connect:
·     UP—The cross-connect is up.
·     DN—The cross-connect is down.
·     AD—The cross-connect is manullay shut down by using the shutdown command.
Segment1 / Segment2
For an AC segment:
·     If the AC is a Layer 3 interface, this field displays the interface name.
·     If the AC is an Ethernet service instance, this field displays the Ethernet service instance name.
For an SRv6 tunnel segment, this field displays the establishment method of the SRv6 tunnel and the IPv6 address of the remote PE. Only the EVPN establishment method is supported.
ST
If this field displays AC state, the following options are available:
·     UP—The AC is up.
·     DN—The AC is down.
If this field displays SRv6 tunnel state, the following options are available:
·     UP—The tunnel is up.
·     DN—The tunnel is down.
·     DF—BFD detects that the tunnel has defects.
·     BD—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
·     DL—The input SID of the tunnel is not available.
·     DP—This option is not supported in the current software version.
# Display detailed information about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6 verbose
  Connection ID         : 1
  State                 : Up
  MTU                   : 1500
  Diffserv Mode         : -
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x8000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE0/0/1                            0x0        Up
  Connection ID         : 1
  State                 : Up
  MTU                   : 1500
  Diffserv Mode         : -
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x8000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE0/0/4 srv1                       0x0        Up
Table 9 Command output
Description of the cross-connect group.
Cross-connect group state:
·     Up—The cross-connect group is up.
·     Down—The cross-connect group is down.
·     Administratively down—The cross-connect group is manually shut down by using the shutdown command.
MTU
Maximum transmission unit of cross-connects.
PW Redundancy Mode
Diffserv Mode
·     pipe—Pipe mode.
SRv6 tunnels
SRv6 tunnel information.
Peer
IPv6 address of the SRv6 tunnel remote PE.
Link ID
Link ID of the SRv6 tunnel on the cross-connect.
ACs
AC information.
AC
Link ID
Link ID of the AC on the cross-connect.
Statistics
evpn encapsulation srv6
Use evpn encapsulation srv6 to create an EVPN instance, specify it to use SRv6 encapsulation, and enter its view, or enter the view of an existing EVPN instance that uses SRv6 encapsulation.
Use undo evpn encapsulation to restore the default.
No EVPN instance is created.
Cross-connect group view
Before you can configure EVPN settings for a VSI or cross-connect group, you must create an EVPN instance on it.
# In a cross-connect group, create an EVPN instance that uses SRv6 encapsulation and enter its view.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] evpn encapsulation srv6
[Sysname-xcg-vpna-evpn-srv6]
nexthop interface (BGP IPv4 SR next hop view/BGP-VPN IPv4 SR next hop view/BGP-VPN IPv4 EVPN SR next hop view)
Use nexthop interface to specify a next hop to which an End.DX4 SID can be dynamically allocated and specify the output interface of the next hop.
Use undo nexthop to restore the default.
nexthop nexthop-address interface interface-type interface-number
undo nexthop nexthop-address
No End.DX4 SID is allocated to a next hop.
nexthop-address: Specifies a next hop by its IPv4 address.
interface-type interface-number: Specifies an output interface by its type and number.
This command is applicable to the IPv4 L3VPN over SRv6, IPv4 EVPN L3VPN over SRv6, or IPv4 public network over SRv6 scenario to accelerate traffic forwarding. This command allocates an End.DX4 SID to the specified next hop for BGP IPv4 routes and associates the next hop with an output interface.
Use one of the following methods to allocate End.DX4 SIDs to next hops:
·     Use this command to dynamically allocate an End.DX4 SID to a next hop from the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in this command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot dynamically allocate an End.DX4 SID to the next hop.
·     Use the opcode end-dx4 vpn-instance command to manually configure an End.DX4 SID in the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in the opcode end-dx4 vpn-instance command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot use the manually configured End.DX4 SID to forward traffic.
If both methods are used for the same next hop, the manually configured End.DX4 SID takes precedence over the dynamically allocated one.
You can specify only one output interface for one next hop. To change the output interface of a next hop, first use the undo nexthop command to remove the original next hop and output interface association.
The device might be unable to dynamically allocate SIDs to BGP IPv4 routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 SIDs, it allocates the End.DT4 SID or End.DT46 SID of the VPN instance or public instance to the routes.
# In BGP IPv4 SR next hop view, allow the system to allocate an End.DX4 SID to next hop 10.1.1.2 and specify GigabitEthernet 0/0/1 as the output interface of the next hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv4] nexthop 10.1.1.2 interface gigabitethernet 0/0/1
opcode
nexthop interface (BGP SRv6 next hop view/BGP-VPN SRv6 next hop view/BGP-VPN IPv6 EVPN SR next hop view)
Use nexthop interface to specify a next hop to which an End.DX6 SID can be dynamically allocated and specify the output interface of the next hop.
nexthop nexthop-ipv6-address interface interface-type interface-number
undo nexthop nexthop-ipv6-address
No End.DX6 SID is allocated to a next hop.
nexthop-ipv6-address: Specifies a next hop by its IPv6 address.
This command is applicable to the IPv6 L3VPN over SRv6, IPv6 EVPN L3VPN over SRv6, or IPv6 public network over SRv6 scenario to accelerate traffic forwarding. This command allocates an End.DX6 SID to the specified next hop for BGP IPv6 routes and associates the next hop with an output interface.
Use one of the following methods to allocate End.DX6 SIDs to next hops:
·     Use this command to dynamically allocate an End.DX6 SID to a next hop from the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in this command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot dynamically allocate an End.DX6 SID to the next hop.
·     Use the opcode end-dx6 vpn-instance command to manually configure an End.DX6 SID in the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in the opcode end-dx6 vpn-instance command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot use the manually configured End.DX6 SID to forward traffic.
If both methods are used for the same next hop, the manually configured End.DX6 SID takes precedence over the dynamically allocated one.
The device might be unable to dynamically allocate SIDs to BGP IPv6 routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX6 SIDs, it allocates the End.DT6 SID or End.DT46 SID of the VPN instance or public instance to the routes.
# In BGP SRv6 next hop view, allow the system to allocate an End.DX6 SID to next hop 10::1:2 and specify GigabitEthernet 0/0/1 as the output interface of the next hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv6] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv6] nexthop 10::1:2 interface gigabitethernet 0/0/1
opcode
peer advertise encap-type srv6
Use peer advertise encap-type srv6 to enable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
Use undo peer advertise encap-type srv6 to disable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
undo peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
IP prefix advertisement routes use VXLAN encapsulation.
BGP EVPN address family view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
Use this command to enable the device to advertise EVPN IP prefix advertisement routes with SRv6 encapsulation in an EVPN L3VPN over SRv6 or EVPN VPWS over SRv6 network.
In an EVPN L3VPN over SRv6 network, execute this command on the edge nodes of the EVPN L3VPN network and RRs.
# Enable SRv6 encapsulation for the IP prefix advertisement routes advertised to peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] peer 1::1 advertise encap-type srv6
peer prefix-sid
Use peer prefix-sid to enable BGP to exchange SRv6 SID information with an IPv6 peer or peer group.
Use undo peer prefix-sid to restore the default.
peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
undo peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
BGP does not exchange SRv6 SID information with an IPv6 peer or peer group.
BGP VPNv4 address family view
BGP VPNv6 address family view
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
Use this command to enable IPv6 peers in an SRv6 VPN network to exchange SRv6 SID information through BGP VPNv4, VPNv6, IPv4 unicast, or IPv6 unicast routes.
# In BGP VPNv4 address family view, enable BGP to exchange SRv6 SID information with peer 2001:1::1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 2001:1::1 prefix-sid
ping evpn vpls srv6
Use ping evpn vpls srv6 to test the connectivity of an SRv6 PW in an EVPN VPLS over SRv6 network by pinging a remote PE from the local PE.
ping evpn vpls srv6 vsi vsi-name mac mac-address ] [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
mac mac-address: Specifies a host attached to a remote PE by its MAC address in H-H-H format. Do not specify a broadcast MAC address, multicast MAC address, or all-zeros MAC address.
-a source-ipv6: Specifies the source IPv6 address of MPLS echo requests. If you do not specify a source IPv6 address, the IPv6 address of the traffic output interface is used as the source IPv6 address of MPLS echo requests.
-c count: Specifies the number of MPLS echo requests to be sent. The value range for the count argument is 1 to 4294967295, and the default value is 5.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255, and the default value is 255.
-m interval: Specifies the interval at which an MPLS echo request is sent, in milliseconds. The value range for the interval argument is 1 to 10000, and the default value is 2000.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to MPLS echo requests. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver searches the IP forwarding table for the destination IP address to forward MPLS echo replies. If the mode is 4, the receiver searches the IPv6 routing table for the source IPv6 address of the echo requests, encapsulates an SRH to the replies, and forwards them.
-s packet-size: Specifies the length of MPLS echo requests, in bytes. The value range for the packet-size argument is 81 to 1200, and the default value is 100. The specified packet length does not include the IPv6 header and UDP header length.
-t time-out: Specifies the timeout time of MPLS echo replies, in milliseconds. The value range for the time-out argument is 0 to 65535, and the default value is 2000. If the local PE does not receive an MPLS echo reply within the timeout time after sending an MPLS echo request, it determines that the MPLS echo reply times out.
-tc tc: Specifies the traffic class value in MPLS echo requests. The value range for the tc argument is 0 to 255 and the default value is 0.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
# Test the connectivity of the SRv6 PW from the local PE to the remote PE attached to the host with MAC address 2-2-2 in VSI vpna.
<System> ping evpn vpls srv6 vsi vpna mac 2-2-2
Ping a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002: 100 data bytes.
Press CTRL+C to break.
100 bytes from 11::2: sequence=1 time=1 ms
100 bytes from 11::2: sequence=2 time=2 ms
100 bytes from 11::2: sequence=3 time=1 ms
100 bytes from 11::2: sequence=4 time=2 ms
100 bytes from 11::2: sequence=5 time=1 ms
--- Ping statistics for MAC 0002-0002-0002 ---
5 packets transmitted, 5 packets received, 0.0% packets lost
Round-trip min/avg/max = 1/1/2 ms
Table 10 Command output
Ping a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002.
Each MPLS echo request contains 100 bytes.
Press escape key Ctrl+C to abort the ping operation.
Received MPLS echo replies from the device whose IPv6 address is 11::2.
·     bytes—Number of bytes in the MPLS echo reply.
·     Sequence—Packet sequence, used to determine whether a segment is lost, disordered or repeated.
·     time—Response time.
If no MPLS echo reply is received when the echo reply timeout time expires, the device displays Request time out.
Statistics on data received and sent in the ping operation.
Number of MPLS echo requests sent.
5 packets received
Number of MPLS echo replies received.
0.0% packets lost
Percentage of unacknowledged packets to the total packets sent.
Minimum, average, or maximum response time, in milliseconds.
tracert evpn vpls srv6
ping evpn vpws srv6
Use ping evpn vpws srv6 to test the connectivity of an SRv6 PW in an EVPN VPWS over SRv6 network by pinging a remote PE from the local PE.
ping evpn vpws srv6 xconnect-group group-name local-service-id  remote-service-id [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The string cannot contain a hyphen (-).
local-service-id: Specifies a local service ID in the range of 1 to 16777215.
remote-service-id: Specifies a remote service ID in the range of 1 to 16777215.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255 and the default value is 255.
-m interval: Specifies the interval at which an MPLS echo request is sent. The value range for the interval argument is 1 to 10000 milliseconds and the default value is 2000 milliseconds.
-s packet-size: Specifies the length of MPLS echo requests, in bytes. The value range for the packet-size argument is 80 to 1200, and the default value is 100. The specified packet length does not include the IPv6 header and UDP header length.
In an EVPN VPWS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
# Ping a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
<Sysname> ping evpn vpws srv6 xcga 2 1
Ping a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga: 100 data bytes.
100 bytes from 111::100: sequence=1 time=2 ms
100 bytes from 111::100: sequence=2 time=2 ms
100 bytes from 111::100: sequence=3 time=1 ms
100 bytes from 111::100: sequence=4 time=1 ms
100 bytes from 111::100: sequence=5 time=2 ms
--- Ping statistics for the PW with local ID 2 and remote ID 1 ---
5 packets transmitted,5 packets received,0.00% packets lost
Table 11 Command output
100 bytes from 111::100: sequence=5 time=1 ms
Received MPLS echo replies from the device whose IPv6 address is 111::100.
·     sequence—Packet sequence, used to determine whether a segment is lost, disordered or repeated.
5 packets received
0.0% packets lost
tracert evpn vpws srv6
Use reset l2vpn statistics srv6-pw to clear SRv6 PW packet statistics.
reset l2vpn statistics srv6-pw [ vsi vsi-name [ peer ipv6-address ] | xconnect-group group-name [ connection connection-name ] ]
peer ipv6-address: Specifies a remote PE by its IPv6 address to clear outgoing packet statistics for the SRv6 PWs between the local PE and the specified remote PE. If you do not specify a remote PE, this command clears all SRv6 PW packet statistics for the specified VSI.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters. If you do not specify a cross-connect, this command clears all SRv6 PW packet statistics for the specified cross-connect group.
This command clears packet statistics for both primary and backup SRv6 PWs.
If you do not specify any parameters, this command clears all SRv6 PW packet statistics.
# Clear all SRv6 PW packet statistics.
<Sysname> reset l2vpn statistics srv6-pw
statistics enable
Use segment-routing ipv6 to specify a route recursion mode.
Use undo segment-routing ipv6 to restore the default.
segment-routing ipv6 { best-effort | traffic-engineer | traffic-engineer best-effort }
The device searches the IPv6 routing table based on the next hop of a matching EVPN route to forward traffic.
Cross-connect group EVPN instance view
VSI EVPN instance view
best-effort: Specifies the SRv6 BE mode.
traffic-engineer: Specifies the SRv6 TE mode.
traffic-engineer best-effort: Specifies the SRv6 TE and SRv6 BE hybrid mode.
Use this command in an EVPN VPWS over SRv6 or EVPN VPLS over SRv6 network.
After the PE receives a customer packet destined for an End.DT2M, End.DT2U, End.DT2UL, End.DX2, or End.DX2L SID, it forwards the packet according to the route recursion mode.
·     SRv6 BE mode—In this mode, the PE first encapsulates the SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
·     SRv6 TE mode—In this mode, when the PE forwards the packet, it first searches the tunnel policies for a matching SRv6 TE policy based on the color attribute or next hop of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DT2M, End.DT2U, End.DT2UL, End.DX2, or End.DX2L SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy.
·     SRv6 TE and SRv6 BE hybrid mode—In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
# In VSI EVPN instance view, specify the SRv6 BE route recursion mode.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-mpls-srv6] segment-routing ipv6 best-effort
# In cross-connect group EVPN instance view, specify the SRv6 BE route recursion mode.
[Sysname-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid all-nexthop to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP IPv4 or IPv6 routes in the public network.
Use undo segment-routing ipv6 apply-sid all-nexthop to restore the default.
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of the public instance to BGP IPv4 or IPv6 routes in the public network.
Use this command to forward an SRv6 decapsulated public network packet to the next hop without looking up the routing table of the public network.
This command is applicable to the IPv4 or IPv6 public network over SRv6 scenario. By default, a PE allocates the same SID to all BGP public network routes. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, use this command.
This command dynamically allocates an End.DX4 or End.DX6 SID to each next hop for the BGP public network IPv4 or IPv6 routes. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use this command in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
In the same view, the segment-routing ipv6 apply-sid all-nexthop command is mutually exclusive with the segment-routing ipv6 apply-sid specify-nexthop command. Do not use both commands in the same view.
The device might be unable to dynamically allocate SIDs to BGP public network routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 or End.DX6 SIDs, it allocates the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the public instance to the routes.
The segment-routing ipv6 apply-sid all-nexthop command cannot allocate End.DX4 or End.DX6 SIDs to direct routes.
# In BGP IPv4 unicast address family view, enable the system to automatically allocate an End.DX4 SID to each next hop of BGP public network routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid all-nexthop to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
segment-routing ipv6 apply-sid all-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid all-nexthop [ evpn ]
VPN instance-based SID allocation is used for BGP private network routes.
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
evpn: Allocates SIDs to private network routes based on the route next hops when the routes are converted to EVPN routes. If you do not specify this keyword, the command allocates SIDs to private network routes based on the route next hops when the routes are converted to BGP VPNv4 or VPNv6 routes.
Use this command to forward an SRv6 decapsulated VPN packet to the next hop without looking up the routing table of the matching VPN instance.
This command is applicable to IP L3VPN over SRv6 and EVPN L3VPN over SRv6 networks. By default, a PE allocates the same SID to all BGP private network routes of a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, use this command.
This command dynamically allocates an End.DX4 or End.DX6 SID to each next hop of the BGP private network routes in a VPN instance based on the next hop addresses. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use this command in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
The device might be unable to dynamically allocate SIDs to BGP private network routes in a VPN instance based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 or End.DX6 SIDs, it allocates the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the VPN instance to the routes.
# In BGP-VPN IPv4 unicast address family view, enable the device to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid specify-nexthop to configure next hop-specific dynamic End.DX4 or End.DX6 SID allocation for BGP public network IPv4 or IPv6 routes, and create and enter BGP IPv4 or SRv6 next hop view. If the view already exists, the command directly places you in the view.
Use undo segment-routing ipv6 apply-sid specify-nexthop to restore the default.
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of the public instance to BGP public network IPv4 or IPv6 routes.
By default, a PE allocates the same SID to all BGP public network routes. When a PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, use this command and the nexthop interface command.
This command and the nexthop interface command dynamically allocate an End.DX4 or End.DX6 SID to the specified next hop. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use the segment-routing ipv6 apply-sid specify-nexthop command in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
In the same view, the segment-routing ipv6 apply-sid specify-nexthop command is mutually exclusive with the segment-routing ipv6 apply-sid all-nexthop command. Do not use both commands in the same view.
The segment-routing ipv6 apply-sid specify-nexthop command cannot allocate End.DX4 or End.DX6 SIDs to direct routes.
# In BGP IPv4 unicast address family view, configure next hop-specific dynamic End.DX4 SID allocation for BGP public network IPv4 routes, and create and enter BGP IPv4 SR next hop view.
[Sysname] bgp 100
nexthop interface
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid specify-nexthop to configure next hop-specific dynamic End.DX4 or End.DX6 SID allocation for BGP private network IPv4 or IPv6 routes, and create and enter BGP-VPN IPv4 or SRv6 next hop view. If the view already exists, the command directly places you in the view.
segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of a VPN instance to the BGP private network IPv4 or IPv6 routes of that VPN instance.
evpn: Enables next hop-specific dynamic End.DX4 or End.DX6 SID allocation for private network routes when the routes are converted to BGP EVPN routes in an EVPN L3VPN over SRv6 network. If you do not specify this keyword, this command enables nexthop-specific dynamic End.DX4 or End.DX6 SID allocation for private network routes when the routes are converted to BGP VPNv4 or VPNv6 routes.
This command is applicable to the IP L3VPN over SRv6 and EVPN L3VPN over SRv6 scenarios.
By default, a PE allocates the same SID to all BGP routes of a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, use this command and the nexthop interface command.
Before you use the segment-routing ipv6 apply-sid specify-nexthop command in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
# In BGP-VPN IPv4 unicast address family view, configure next hop-specific dynamic End.DX4 SID allocation for BGP private network IPv4 routes, and create and enter BGP-VPN IPv4 SR next hop view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4 unicast
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid specify-nexthop
nexthop interface
Use segment-routing ipv6 best-effort to recurse routes to SRv6 BE tunnels.
Use undo segment-routing ipv6 best-effort to restore the default.
In BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view:
segment-routing ipv6 best-effort [ evpn ]
undo segment-routing ipv6 best-effort [ evpn ]
In BGP IPv4 unicast address family view or BGP IPv6 unicast address family view:
A PE searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
evpn: Recurses EVPN routes to SRv6 BE tunnels. If you do not specify this keyword, the device recurses BGP VPNv4 or VPNv6 routes to SRv6 BE tunnels.
This command is applicable to the IP L3VPN over SRv6, EVPN L3VPN over SRv6, and IP public network over SRv6 networks. This command enables a PE to forward packets by looking up the IPv6 routing table based on the SRv6 SIDs in the packets.
Use this command in different address family views according to your network scenario.
·     In the IPv4 or IPv6 L3VPN over SRv6 network and the EVPN L3VPN over SRv6 network, use this command in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
·     In the IPv4 or IPv6 public network over SRv6 network, use this command in BGP IPv4 unicast address family view or BGP IPv6 unicast address family view.
# In BGP-VPN IPv4 unicast address family view, recurse private network routes to SRv6 BE tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
# In BGP-VPN IPv6 unicast address family view, recurse private network routes to SRv6 BE tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv6
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort
Use segment-routing ipv6 locator to apply a locator to a BGP family.
Use undo segment-routing ipv6 locator to restore the default.
segment-routing ipv6 locator locator-name [ evpn ] [ auto-sid-disable ]
undo segment-routing ipv6 locator [ evpn ]
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
No locator is applied to a BGP family.
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. The specified locator must exist.
evpn: Adds the SID attribute to private network routes when the routes are converted to EVPN routes. If you do not specify this keyword, the command adds the SID attribute to private network routes when the routes are converted to BGP VPNv4 or VPNv6 routes.
auto-sid-disable: Disables automatic SRv6 SID allocation. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
Use this command to enable a BGP family to use BGP routes to advertise SRv6 SIDs in the specified locator.
If you execute this command multiple times for the same address family, the most recent configuration takes effect.
# Apply locator abc to BGP-VPN IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
# Apply locator abc to BGP-VPN IPv6 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
segment-routing ipv6 locator (cross-connect view and VSI EVPN instance view)
Use segment-routing ipv6 locator to apply an SRv6 locator to a cross-connect or a VSI.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from a cross-connect or a VSI.
In cross-connect view:
segment-routing ipv6 locator locator-name [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ]
In VSI EVPN instance view:
segment-routing ipv6 locator locator-name [ dt2u-locator dt2u-locator-name ] [ dt2ul-locator dt2ul-locator-name ] [ dx2-locator dx2-locator-name ] [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ]
No SRv6 locators are applied to a cross-connect or a VSI.
Cross-connect view
dx2l-locator dx2l-locator-name: Specifies the locator used to apply for End.DX2L SIDs. The dx2l-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dt2u-locator dt2u-locator-name: Specifies the locator used to apply for End.DT2U SIDs. The dt2u-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dt2ul-locator dt2ul-locator-name: Specifies the locator used to apply for End.DT2UL SIDs. The dt2ul-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dx2-locator dx2-locator-name: Specifies the locator used to apply for End.DX2 SIDs. The dx2-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
auto-sid-disable: Disables automatic SID allocation. If no opcode is configured for the locator specified in this command when automatic SID allocation is disabled, SID application fails. If you do not specify this keyword, automatic SID allocation is enabled and static SRv6 SIDs and dynamic SRv6 SIDs can coexist. The static SRv6 SIDs take precedence over the dynamically allocated SRv6 SIDs.
Use this command to enable a cross-connect or VSI to apply for SRv6 SIDs from the specified locator.
·     If you specify the dx2l-locator dx2l-locator-name option, the locator-name argument applies for End.DX2 SIDs and the dx2l-locator-name argument applies for End.DX2L SIDs.
·     If you do not specify the dx2l-locator dx2l-locator-name option, the locator-name argument applies for both End.DX2 SIDs and End.DX2L SIDs.
·     If you do not specify the dt2u-locator dt2u-locator-name, dt2ul-locator dt2ul-locator-name, dx2-locator dx2-locator-name, or dx2l-locator dx2l-locator-name option, the locator-name argument applies for End.DT2M, End.DT2U, End.DT2UL, End.DX2, and End.DX2L SIDs.
·     If you specify the dt2u-locator dt2u-locator-name, dt2ul-locator dt2ul-locator-name, dx2-locator dx2-locator-name, or dx2l-locator dx2l-locator-name option, the option applies for End.DT2U, End.DT2UL, End.DX2, or End.DX2L SIDs and the locator-name argument applies for other SRv6 SIDs.
# Configure VSI aaa to use locator test1 to apply for End.DT2M, End.DT2UL, End.DX2, and End.DX2L SIDs and use locator test2 to apply for End.DT2U SIDs.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] segment-routing ipv6 locator test1 dt2u-locator test2
# Configure cross-connect aaa in cross-connect group bbb to use locator test3 to apply for End.DX2 and End.DX2L SIDs and disable automatic SID allocation.
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] evpn encapsulation srv6
[Sysname-xcg-bbb-evpn-srv6] quit
[Sysname-xcg-bbb] connection aaa
[Sysname-xcg-bbb-connection-aaa] segment-routing ipv6 locator test3 auto-sid-disable
segment-routing ipv6 traffic-engineering
Use segment-routing ipv6 traffic-engineering to recurse routes to SRv6 TE policy tunnels.
Use undo segment-routing ipv6 traffic-engineering to restore the default.
segment-routing ipv6 traffic-engineering [ best-effort ] [ evpn ]
undo segment-routing ipv6 traffic-engineering [ best-effort ] [ evpn ]
best-effort: Switches to the SRv6 BE route recursion mode when the matching SRv6 TE policy tunnel fails for L3VPN traffic. With this keyword, a PE looks up the routing table for the End.DT4, End.DT6, or End.DT46 SID of a packet to forward that packet when the matching SRv6 TE policy tunnel fails. If you do not specify this keyword, the PE looks up the routing table based on the destination IP address of a packet to forward that packet when the matching SRv6 TE policy tunnel fails.
evpn: Recurses the private network routes based on the SID attribute in EVPN routes. If you do not specify this keyword, the device recurses the private network routes based on the SID attribute in BGP VPNv4 or VPNv6 routes.
This command enables PEs to recurse routes to SRv6 TE policy tunnels and use the tunnels to forward L3VPN traffic between the PEs.
To improve high availability for L3VPN packet forwarding, specify the best-effort keyword. A PE forwards an L3VPN packet as follows:
1.     The PE forwards the packet through the matching SRv6 TE policy tunnel.
2.     If the matching SRv6 TE policy tunnel fails, the PE forwards the packet in SRv6 BE mode.
3.     If the packet forwarding still fails in SRv6 BE mode, the PE forwards the packet by looking up the routing table based on the destination IP address of the packet.
4.     If the packet forwarding still fails, the PE drops the packet.
This command is mutually exclusive with the segment-routing ipv6 best-effort command.
# In BGP IPv4 unicast address family view, recurse routes to SRv6 TE policy tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 traffic-engineering
statistics enable
Use statistics enable to enable SRv6 PW packet statistics.
Use undo statistics enable to disable SRv6 PW packet statistics.
statistics enable
The SRv6 PW packet statistics feature is disabled.
Cross-connect EVPN PW view
EVPN VPWS over SRv6 network:
Use this command to enable SRv6 PW packet statistics in cross-connect EVPN PW view. To display SRv6 PW packet statistics, use the display l2vpn peer srv6 verbose command. To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command.
The statistics enable command is not supported by PWs in a cross-connect group EVPN instance that uses MPLS encapsulation.
EVPN VPLS over SRv6 network:
Use the statistics enable command to enable packet statistics for all SRv6 PWs in a VSI EVPN instance. To display inbound packet statistics for all SRv6 PWs, use the display l2vpn statistics srv6-pw inbound command. To display outbound packet statistics for each SRv6 PW, use the display l2vpn peer srv6 verbose command. To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command.
The statistics enable command is supported only by VSI EVPN instances that use SRv6 encapsulation.
# In an EVPN VPWS over SRv6 network, enable packet statistics for an SRv6 PW.
[Sysname] xconnect-group vpws
[Sysname-xcg-vpws] connection aa
[Sysname-xcg-vpws-aa] evpn local-service-id 2 remote-service-id 4
[Sysname-xcg-vpws-aa-2-4] statistics enable
# In an EVPN VPLS over SRv6 network, enable packet statistics for all SRv6 PWs in an EVPN instance.
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6
[Sysname-vsi-vpna-evpn-srv6] stastics enable
Use tracert evpn vpls srv6 to trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPLS over SRv6 network.
tracert evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ipv6 | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
-tc tc: Specifies the traffic class value in MPLS echo replies. The value range for the tc argument is 0 to 255 and the default value is 0.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This command helps you locate the failed nodes on the path.
# Trace route to a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002.
<Sysname> tracert evpn vpls srv6 vsi vpna mac 2-2-2
Trace route to a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002.
  Hop  Wait time     Type       Replier
  0    0 ms           Ingress
  1    4 ms           Transit    1111::2
  2    5 ms           Transit    2222::2
  3    6 ms           Transit    3333::2
  4    6 ms           Egress     4444::2
Table 12 Command output
Press escape key Ctrl+C to abort the tracert operation.
Hop
Hop number.
Wait time
Interval between the time when an echo request was sent and the time when the reply of the echo request was received. The unit is millisecond.
Node type:
·     Ingress.
·     Transit.
·     Egress.
Replier
IPv6 address of the node.
Request time out
This field is available if the local PE does not receive any MPLS echo reply to an MPLS echo request when the echo reply timeout time expires.
ping evpn vpls srv6
Use tracert evpn vpws srv6 to trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPWS over SRv6 network.
tracert evpn vpws srv6 xconnect-group group-name local-service-id  remote-service-id [ -a source-ip | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
-a source-ip: Specifies the source IPv6 address of MPLS echo requests. If you do not specify a source IPv6 address, the IPv6 address of the traffic output interface is used as the source IPv6 address of MPLS echo requests.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to an MPLS echo request. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver searches the IP forwarding table for the destination IP address to forward MPLS echo replies. If the mode is 4, the receiver searches the IPv6 routing table for the source IPv6 address of the echo requests, encapsulates an SRH to the replies, and forwards them.
In an EVPN VPWS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This command helps you locate the failed nodes on the path.
# Trace the route that an SRv6 PW traverses from the local PE to the remote PE in an EVPN VPWS over SRv6 network. The SRv6 PW belongs to cross-connect group xcga, its local service ID is 2, and its remote service ID is 1.
<Sysname> tracert evpn vpws srv6 xconnect-group xcga 1 2
Trace route to a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
  0     0 ms            Ingress
  4     6 ms            Egress     3333::2
Table 13 Command output
Trace route to a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
Hop
Hop number.
Wait time
Node type:
·     Ingress.
·     Transit.
·     Egress.
Replier
Request time out
ping evpn vpws srv6
