07-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9119-6W10007-Layer 3—IP Services Command Reference
18-HTTP redirect commands
18-HTTP redirect commands 45.03 KB
display http-redirect statistics
Use display http-redirect statistics to display packet statistics for HTTP redirect.
display http-redirect statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays HTTP redirect packet statistics on all cards.
# Display HTTP redirect packet statistics for slot 1.
<Sysname> display http-redirect statistics slot 1
Slot 1:
HTTP:
 Received SYN packets                            :1000
 Sent SYN ACK packets                            :1000
 Sent RST packets                                :500
 Redirect node not found events                  :50
 Assembled redirect URL failed times/total times :100/700
HTTPS:
 Redirect node not found events                  :300
 SSL handshake failed times/total times          :0/700
 SSL data interaction failed times/total times   :0/700
HTTP
Packet statistics for HTTP redirect.
Number of SYN packets that have been received.
Number of SYN ACK packets that have been sent.
Sent RST packets
Number of RST packets that have been sent.
Number of times that the system failed to find redirect nodes.
Redirect URL assembly failures and total number of redirect URL assemblies.
HTTPS
Packet statistics for HTTPS redirect.
SSL handshake failed/total times
Number of SSL handshake failures, and the total number of SSL handshakes.
Number of SSL data exchange failures, and the total number of SSL data exchanges.
reset http-redirect statistics
http-redirect ssl-server-policy
Use http-redirect ssl-server-policy to associate an SSL server policy with the HTTPS redirect service.
Use undo http-redirect ssl-server-policy to restore the default.
http-redirect ssl-server-policy policy-name
No SSL server policy is associated with the HTTPS redirect service. The HTTPS redirect service uses a self-assigned certificate and the default SSL parameters.
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
HTTPS redirect is unavailable if the associated SSL server policy does not exist. You can first associate a nonexistent SSL server policy with the HTTPS redirect service and then configure the SSL server policy.
If you change the SSL server policy associated with the HTTPS redirect service, the new policy takes effect immediately.
If you perform this task multiple times, the most recent configuration takes effect.
# Associate SSL server policy policy1 with the HTTPS redirect service.
[Sysname] http-redirect ssl-server-policy policy1
ssl server-policy
Use reset http-redirect statistics to reset packet statistics for HTTP redirect.
reset http-redirect statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears HTTP redirect packet statistics on all cards.
# Clear HTTP redirect packet statistics.
<Sysname> reset http-redirect statistics
# Clear HTTP redirect packet statistics for slot 1.
<Sysname> reset http-redirect statistics slot 1
