07-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9119-6W10007-Layer 3—IP Services Command Reference
13-IPv6 neighbor discovery commands
13-IPv6 neighbor discovery commands 199.14 KB
display ipv6 nd user-ip-conflict record
Use display ipv6 nd user-ip-conflict record to display user IPv6 address conflict records.
display ipv6 nd user-ip-conflict record [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user IP address conflict records for all cards.
# Display all user IPv6 address conflict records.
<Sysname> display ipv6 nd user-ip-conflict record
IPv6 address: 10::1
System time: 2020-02-02 11:22:29
Conflict count: 1
Log suppress count: 0
Old interface: GigabitEthernet0/0/1
New interface: GigabitEthernet0/0/2
Old SVLAN/CVLAN: 100/2
New SVLAN/CVLAN: 100/2
Old MAC: 00e0-ca63-8141
New MAC: 00e0-ca63-8142
IPv6 address: 10::2
System time: 2020-02-02 10:20:30
Conflict count: 1
Old SVLAN/CVLAN: 100/--
New SVLAN/CVLAN: 100/--
IPv6 address
IPv6 address of a user.
System time
Time when the user IPv6 address conflict occurred.
Conflict count
Number of times user IPv6 address conflicts occurred.
Log suppress count
Number of times user IPv6 address conflict log generation has been suppressed.
Old interface
Output interface in the old ND entry.
New interface
Output interface in the new ND entry.
Old SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the old ND entry. This field displays hyphens (--) if the ND entry does not belong to any outer VLAN or inner VLAN.
New SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the new ND entry. This field displays hyphens (--) if the ND entry does not belong to any outer VLAN or inner VLAN.
Old MAC
MAC address in the old ND entry.
New MAC
MAC address in the new ND entry.
ipv6 nd user-ip-conflict record enable
display ipv6 nd user-move record
Use display ipv6 nd user-move record to display user port migration records.
display ipv6 nd user-move record [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user port migration records for all cards.
# Display all user port migration records.
<Sysname> display ipv6 nd user-move record
IPv6 address: 10::1
MAC address: 00e0-ca63-8141
Move count: 1
Before:
  SVLAN/CVLAN: 100/2
After:
  SVLAN/CVLAN: 100/2
IPv6 address: 10::2
MAC address: 00e0-ca63-8142
Move count: 1
Before:
  SVLAN/CVLAN: 100/--
After:
  SVLAN/CVLAN: 100/--
IPv6 address
IPv6 address of the user.
MAC address
MAC address of the user.
System time
Time when the user port migration occurred.
Move count
Number of times the user port migrated.
Log suppress count
Number of times user port migration log generation has been suppressed.
Before
Information before the user port migration.
interface
Interface information in the ND entry.
SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the ND entry. This field displays hyphens (--) if the ND entry does not belong to any outer VLAN or inner VLAN.
After
Information after the user port migration.
ipv6 nd user-move record enable
display ipv6 neighbors
Use display ipv6 neighbors to display IPv6 neighbor information.
ipv6-address: Specifies the IPv6 address of a neighbor whose information is displayed.
all: Displays information about all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information about all neighbors acquired dynamically.
static: Displays information about all neighbors configured statically.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 neighbor information for all cards.
vlan vlan-id: Displays information about neighbors in the specified SVLAN. The value range for the SVLAN ID is 1 to 4094.
verbose: Displays detailed neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
Type: S-Static    D-Dynamic    R-Rule    IS-Invalid static
IPv6 address              MAC address    VLAN/VSI   Interface     State T  Aging
1::2                      6864-6839-0202 1          GE0/0/1       STALE D  136
FE80::6A64:68FF:FE39:202  6864-6839-0202 1          GE0/0/1       STALE D  126
1::3                      6864-6839-0203 1          Tunnel1       STALE D  136
1::4                      6864-6839-0204 1          GE0/0/2       STALE D  136
# Display detailed information about all neighbors.
<Sysname> display ipv6 neighbors all verbose
IPv6 address     : 1::2
MAC address      : 6864-6839-0202          Type : Dynamic
State            : STALE                     Aging: 136   seconds
Interface        : GE0/0/1                   SVLAN/CVLAN : 1/--
VPN instance     : --
Service instance : --
Link ID            : --
VXLAN ID         : --
VSI name           : --
VSI interface     : --
IPv6 address     : FE80::6A64:68FF:FE39:202
VPN instance     : --
Link ID          : --
VXLAN ID         : --
VSI name         : --
VSI interface    : --
IPv6 address     : 1::3
MAC address      : 6864-6839-0203            Type : Dynamic
Interface        : Tunnel1                   SVLAN/CVLAN : 1/--
VPN instance     : --
Link ID          : 0x5000001
VXLAN ID         : 10
VSI name         : --
VSI interface    : --
IPv6 address     : 1::4
MAC address      : 6864-6839-0204          Type : Dynamic
Interface        : GE0/0/2                   SVLAN/CVLAN : 1/--
VPN instance     : --
Service instance : 1
Link ID           : 0x1
VXLAN ID         : 10
VSI name          : --
VSI interface    : --
IPv6 address
IPv6 address of the neighbor.
MAC address
MAC address of the neighbor.
VLAN/VSI
ID of the VLAN or index of the VSI to which the neighbor entry belongs. This field displays hyphens (--) if the neighbor entry does not belong to a VLAN or VSI.
Interface connected to the neighbor.
·     If the neighbor entry does not belong to a VSI, this field displays the interface name. If the interface name is not available, the field displays hyphens (--).
·     If the neighbor entry belongs to a VSI and the interface is a tunnel interface, the displayed value depends on the address resolution status.
¡     If the address is not resolved, this field displays the VSI.
¡     If the address is resolved, this field displays the tunnel ID.
·     If the neighbor entry belongs to a VSI but the interface is not a tunnel interface, the displayed value depends on the address resolution status.
¡     If the address is resolved, this field displays the interface.
State of the neighbor:
·     INCMP—The address is being resolved. The link layer address of the neighbor is unknown.
·     REACH—The neighbor is reachable.
·     STALE—Whether the neighbor is reachable is unknown. The device does not verify the reachability any longer unless data is sent to the neighbor.
·     DELAY—Whether the neighbor is reachable is unknown. The device sends an NS message after a delay.
·     PROBE—Whether the neighbor is reachable is unknown. The device sends an NS message to verify the reachability of the neighbor.
Neighbor information type:
·     Static—Statically configured.
·     Dynamic—Dynamically obtained.
·     Rule—Learned from the IPoE or Portal module.
·     Invalid static—Invalid static configuration.
Aging
Reachable time of the neighbor:
·     For a static neighbor entry, this field displays hyphens (--), representing the neighbor entry never expires.
·     For a dynamic entry, this field displays the elapsed time in seconds. If the neighbor is never reachable, this field displays a pound sign (#).
SVLAN/CVLAN
SVLAN and CVLAN to which the interface connected to the neighbor belongs. This field displays hyphens (--) if the interface does not belong to a VLAN.
VPN instance
Name of a VPN instance. This field displays hyphens (--) if no VPN instance is configured.
Service instance
Ethernet service instance. If the neighbor entry does not belong to any Ethernet service instance for the related Layer 2 Ethernet interface or Layer 2 aggregate interface, this field displays hyphens (--).
Link ID
ID of the link that connects to the neighbor. The link ID is a string with a maximum of eight hexadecimal numbers.
If the neighbor entry does not belong to any VSI, the field displays hyphens (--).
VXLAN ID
ID of the VXLAN associated with the VSI in the neighbor entry. If no VXLAN is specified, the field displays hyphens (--).
VSI name
Name of the VSI to which the neighbor entry belongs. This field displays hyphens (--) if the neighbor entry does not belong to a VSI.
VSI interface
VSI interface associated with a VSI. This field displays hyphens (--) if no VSI interface associated with the VSI is specified.
ipv6 neighbor
reset ipv6 neighbors
display ipv6 neighbors count
Use display ipv6 neighbors count to display the number of neighbor entries.
all: Displays the total number of all neighbor entries, including neighbor entries created dynamically and configured statically.
dynamic: Displays the total number of neighbor entries created dynamically.
static: Displays the total number of neighbor entries configured statically.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the number of neighbor entries for all cards. .
vlan vlan-id: Displays the total number of neighbor entries in the specified VLAN. The value range for VLAN ID is 1 to 4094.
# Display the total number of neighbor entries created dynamically.
<Sysname> display ipv6 neighbors dynamic count
 Total number of dynamic entries: 2
display ipv6 neighbors entry-limit
Use display ipv6 neighbors entry-limit to display the maximum number of ND entries that a device supports.
# Display the maximum number of ND entries that the device supports.
<Sysname> display ipv6 neighbors entry-limit
ND entries: 2048
display ipv6 neighbors vpn-instance
Use display ipv6 neighbors vpn-instance to display neighbor information about a VPN instance.
display ipv6 neighbors vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance must already exist.
count: Displays the total number of neighbor entries in the specified VPN instance.
# Display neighbor information about the VPN instance vpn1.
<Sysname> display ipv6 neighbors vpn-instance vpn1
IPv6 address                MAC address    VID  Interface           State T  Aging
FE80::200:5EFF:FE32:B800  0000-5e32-b800 --   GE1/0/1             REACH IS --
IPv6 address
MAC address
VID
VLAN to which the interface connected to the neighbor belongs. This field displays hyphens (--) if the neighbor entry does not belong to a VLAN.
Neighbor state:
T
·     Rule—Learned from IPoE or portal.
Aging
·     For a dynamic neighbor entry, this field displays the elapsed time in seconds. If the neighbor is never reachable, this field displays a pound sign (#).
Use ipv6 nd autoconfig managed-address-flag to set the managed address configuration flag (M) to 1 in RA advertisements to be sent.
Use undo ipv6 nd autoconfig managed-address-flag to restore the default.
The M flag is set to 0 in RA advertisements. Hosts receiving the advertisements will obtain IPv6 addresses through stateless autoconfiguration.
Interface view
The M flag in RA advertisements determines whether receiving hosts use stateful autoconfiguration to obtain IPv6 addresses.
·     If the M flag is set to 1 in RA advertisements, receiving hosts use stateful autoconfiguration (for example, from a DHCPv6 server) to obtain IPv6 addresses.
·     If the M flag is set to 0 in RA advertisements, receiving hosts use stateless autoconfiguration. Stateless autoconfiguration generates IPv6 addresses according to link-layer addresses and the prefix information in the RA advertisements.
# Set the M flag to 1 in RA advertisements to be sent.
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] ipv6 nd autoconfig managed-address-flag
ipv6 nd autoconfig other-flag
Use ipv6 nd autoconfig other-flag to set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
Use undo ipv6 nd autoconfig other-flag to restore the default.
The O flag is set to 0 in RA advertisements. Hosts receiving the advertisements will acquire other information through stateless autoconfiguration.
Interface view
The O flag in RA advertisements determines whether receiving hosts use stateful autoconfiguration to obtain configuration information other than IPv6 addresses.
·     If the O flag is set to 1 in RA advertisements, receiving hosts use stateful autoconfiguration (for example, from a DHCPv6 server) to obtain configuration information other than IPv6 addresses.
·     If the O flag is set to 0 in RA advertisements, receiving hosts use stateless autoconfiguration to obtain configuration information other than IPv6 addresses.
# Set the O flag to 0 in RA advertisements to be sent.
[Sysname-GigabitEthernet0/0/1] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts
Use ipv6 nd dad attempts to set the number of attempts to send an NS message for DAD.
Use undo ipv6 nd dad attempts to restore the default.
ipv6 nd dad attempts times
The number of attempts to send an NS message for DAD is 1.
Interface view
times: Specifies the number of attempts to send an NS message for DAD, in the range of 0 to 600. If it is set to 0, DAD is disabled.
An interface sends an NS message for DAD after obtaining an IPv6 address.
If the interface does not receive a response within the time specified by using ipv6 nd ns retrans-timer, it resends an NS message.
If the interface receives no response after making the maximum sending attempts (set by using ipv6 nd dad attempts), the interface uses the obtained address.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-GigabitEthernet0/0/1] ipv6 nd dad attempts 20
display ipv6 interface
ipv6 nd mode uni
Use ipv6 nd mode uni to configure a port as a customer-side port.
Use undo ipv6 nd mode to restore the default.
ipv6 nd mode uni
undo ipv6 nd mode
A port acts as a network-side port.
VLAN interface view
VSI interface view
By default, the device associates an ND entry with routing information when the device learns an ND entry. The ND entry provides the next hop information for routing. To save hardware resources, you can use this command to specify a port that connects to a user terminal as a customer-side port. The device will not associate the routing information with the learned ND entries.
# Specify VLAN-interface 2 as a customer-side port.
[Sysname-Vlan-interface2] ipv6 nd mode uni
Use ipv6 nd ns retrans-timer to set the interval for retransmitting an NS message.
Use undo ipv6 nd ns retrans-timer to restore the default.
The local interface sends NS messages at every an interval of 1000 milliseconds, and the Retrans Timer field in the RA messages sent is 0. The interval for retransmitting an NS message is determined by the receiving device.
Interface view
value: Specifies the interval value in the range of 1000 to 4294967295 milliseconds.
If a device does not receive a response from the peer within the specified interval, the device resends an NS message. The device retransmits an NS message at the specified interval and uses the interval value to fill the Retrans Timer field in RA messages to be sent.
# Specify GigabitEthernet 0/0/1 to retransmit NS messages every 10000 milliseconds.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time
Use ipv6 nd nud reachable-time to set the neighbor reachable time on an interface.
Use undo ipv6 nd nud reachable-time to restore the default.
The neighbor reachable time on the local interface is 30000 milliseconds, and the value of the Reachable Time field in RA messages is 0. The reachable time is determined by the receiving device.
Interface view
time: Specifies the neighbor reachable time in the range of 1 to 3600000 milliseconds.
If the neighbor reachability detection shows that a neighbor is reachable, the device considers the neighbor reachable within the specified reachable time. If the device must send a packet to the neighbor after the specified reachable time expires, the device reconfirms whether the neighbor is reachable. The device sets the specified value as the neighbor reachable time on the local interface and uses the value to fill the Reachable Time field in RA messages to be sent.
# Set the neighbor reachable time on GigabitEthernet 0/0/1 to 10000 milliseconds.
[Sysname-GigabitEthernet0/0/1] ipv6 nd nud reachable-time 10000
ipv6 nd online-offline-log enable
Use ipv6 nd online-offline-log enable to enable ND logging for user online and offline events.
Use undo ipv6 nd online-offline-log enable to disable ND logging for user online and offline events.
ipv6 nd online-offline-log enable [ rate rate ]
ND logging for user online and offline events is disabled.
rate rate: Specifies the maximum number of logs that can be output per second. The value range is 10 to 300. If you do not specify this option, the maximum log output rate is 100 logs per second.
A higher log output rate consumes more CPU resources. Adjust the log output rate based the CPU performance and usage.
# Enable ND logging for user online and offline events, and set the maximum log output rate to 100 logs per second.
[Sysname] ipv6 nd online-offline-log enable rate 100
ipv6 neighbor
ipv6 nd ra boot-file-url
Use ipv6 nd ra boot-file-url to specify the URL of the boot file in RA messages.
Use undo ipv6 nd ra boot-file-url to restore the default.
ipv6 nd ra boot-file-url url-string
RA messages do not contain the URL of the boot file.
Interface view
url-string: Specifies the URL address of the boot file, a case-sensitive string of 1 to 127 characters. The URL address must be started with http://, https://. ftp://, or tftp://.
In a data center, a device follows the steps to implement automatic configuration:
1.     Obtains an IPv6 address through ND or DHCPv6.
2.     Obtains the URL address for downloading the boot file from the DHCPv6 server.
3.     Downloads the boot file from the FTP server and installs it.
With the boot file URL specified in RA messages, the device can use the ND protocol to obtain both the IPv6 address and the boot file URL for automatic configuration. DHCPv6 is not required in the network, simplifying the network deployment.
# Specify the boot file URL address as tftp://169.254.0.1/file/softimg.iso in RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra boot-file-url tftp://169.254.0.1/file/softimg.iso
ipv6 nd ra dns search-list
Use ipv6 nd ra dns search-list to specify DNS suffix information to be advertised in RA messages.
Use undo ipv6 nd ra dns search-list to remove a DNS suffix from RA message advertisement.
undo ipv6 nd ra dns search-list domain-name
DNS suffix information is not specified and RA messages do not contain DNS suffix options.
Interface view
domain-name: Specifies a DNS suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, aabbcc.com. The DNS suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
seconds: Specifies the lifetime of the DNS suffix, in seconds. The value range is 4 to 4294967295. Value 4294967295 indicates that the lifetime of the DNS suffix is infinite.
infinite: Sets the lifetime of the DNS suffix to infinite.
seqno: Specifies the sequence number of the DNS suffix, in the range of 0 to 4294967295. The sequence number for a DNS suffix must be unique. A smaller sequence number represents a higher priority.
The DNS search list (DNSSL) option in RA messages provides DNS suffix information for hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS suffix through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
The default lifetime of the DNS suffix is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
You can configure a maximum of eight DNS suffixes on an interface. One DNSSL option contains one DNS suffix. All DNSSL options are sorted in ascending order of the sequence number of the DNS suffix.
The sequence number uniquely identifies a DNS suffix. To modify a DNS suffix or its sequence number, you must first use the undo ipv6 nd ra dns search-list command to remove the DNS suffix from RA message advertisement.
After you execute the ipv6 nd ra dns search-list command, the device immediately sends an RA message with the existing and newly specified DNS suffix information.
After you execute the undo ipv6 nd ra dns search-list command, the device immediately sends two RA messages.
·     The first RA message carries information about all DNS suffixes, including DNS suffixes specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message carries information about remaining DNS suffixes.
Each time the device sends an RA message from an interface, it immediately refreshes the RA message advertisement interval for that interface.
# Specify the DNS suffix as com, the suffix lifetime as infinite, and the sequence number as 1 for RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra dns search-list com 3600 sequence 1
ipv6 nd ra dns search-list suppress
ipv6 nd ra interval
Use ipv6 nd ra dns search-list suppress to enable DNS suffix suppression in RA messages.
Use undo ipv6 nd ra dns search-list suppress to disable DNS suffix suppression in RA messages.
DNS suffix suppression in RA messages is disabled.
Interface view
This command suppresses advertising DNS suffixes in RA messages on an interface. If you specify a new DNS suffix or remove a DNS suffix on the interface, the device immediately sends an RA message without any DNSSL options.
RA messages are suppressed by default. To disable RA message suppression, use the undo ipv6 nd ra halt command.
Whether enabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS suffix information configured, the device immediately sends two RA messages. In the first message, the lifetime for DNS suffixes is 0 seconds. The second RA message does not contain any DNSSL options.
·     If the interface has no DNS suffix information specified, no RA messages are triggered.
Whether disabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS suffix information configured, the device immediately sends an RA message containing the DNS suffix information.
# Enable DNS suffix suppression in RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
Use ipv6 nd ra dns server to specify DNS server information to be advertised in RA messages.
Use undo ipv6 nd ra dns server to remove a DNS server from RA message advertisement.
undo ipv6 nd ra dns server ipv6-address
DNS server information is not specified and RA messages do not contain DNS server options.
Interface view
ipv6-address: Specifies the IPv6 address of the DNS server, which must be a global unicast address or a link-local address.
seconds: Specifies the lifetime of the DNS server, in seconds. The value range is 4 to 4294967295. Value 4294967295 indicates that the lifetime of the DNS server is infinite.
infinite: Sets the lifetime of the DNS server to infinite.
sequence seqno: Specifies the sequence number of the DNS server, in the range of 0 to 4294967295. The sequence number for a DNS server must be unique. A smaller sequence number represents a higher priority.
The DNS server option in RA messages provides DNS server information for hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS server through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
The default lifetime of the DNS server is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
You can configure a maximum of eight DNS servers on an interface. One DNS server option contains one DNS server. All DNS server options are sorted in ascending order of the DNS server sequence number.
The sequence number uniquely identifies a DNS server. To modify the IPv6 address or sequence number of a DNS server, you must first use the undo ipv6 nd ra dns server command to remove the DNS server from RA message advertisement.
After you execute the ipv6 nd ra dns server command, the device immediately sends an RA message with the existing and newly specified DNS server options.
After you execute the undo ipv6 nd ra dns server command, the device immediately sends two RA messages.
·     The first RA message carries information about all DNS servers, including the DNS servers specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message carries information about remaining DNS servers.
In an IPv6 environment, PPP users can obtain the IPv6 DNS server address through AAA authorization. This AAA-authorized IPv6 DNS server address is also carried in RA messages. If an interface obtains the AAA-authorized and manually specified IPv6 DNS server addresses, the RA messages contain both, with the AAA-authorized address in the front. When the two addresses conflict, the AAA-authorized address is used.
For more information about the PPP support for IPv6, see PPP configuration in Layer 2—WAN Access Configuration Guide.
# Specify the DNS server address as 2001:10::100, the server lifetime as infinite, and the sequence number as 1 for RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra dns server 2001:10::100 3600 sequence 1
ipv6 nd ra dns server suppress
ipv6 nd ra interval
Use ipv6 nd ra dns server suppress to enable DNS server suppression in RA messages.
Use undo ipv6 nd ra dns server suppress to disable DNS server suppression in RA messages.
DNS server suppression in RA messages is disabled.
Interface view
This command suppresses advertising DNS server addresses in RA messages on an interface. If you specify a new DNS server or remove a DNS server on the interface, the device immediately sends an RA message without any DNS server options.
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends two RA messages. In the first message, the lifetime for DNS server addresses is 0 seconds. The second RA message does not contain any DNS server options.
·     If the interface has no DNS server information specified or no AAA-authorized DNS server address assigned, no RA messages are triggered.
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends an RA message containing the DNS server information.
# Enable DNS server suppression in RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra dns server suppress
ipv6 nd ra halt
Use ipv6 nd ra halt to suppress an interface from advertising RA messages.
Use undo ipv6 nd ra halt to disable this feature.
ipv6 nd ra halt
An interface is suppressed from sending RA messages.
Interface view
# Disable RA message suppression on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] undo ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
Use ipv6 nd ra hop-limit unspecified to specify unlimited hops in RA messages.
Use undo ipv6 nd ra hop-limit unspecified to restore the default.
The maximum number of hops in the RA messages is limited to 64.
Interface view
To set the maximum number of hops to a value rather than the default setting, use the ipv6 hop-limit command.
# Specify unlimited hops in the RA messages on interface GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra hop-limit unspecified
ipv6 hop-limit
ipv6 nd ra interval
Use ipv6 nd ra interval to set the maximum and minimum intervals for advertising RA messages.
Use undo ipv6 nd ra interval to restore the default.
The maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Interface view
max-interval: Specifies the maximum interval value in seconds, in the range of 4 to 1800.
min-interval: Specifies the minimum interval value in the range of 3 seconds to three-fourths of the maximum interval.
The device advertises RA messages randomly between the maximum interval and the minimum interval.
The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1000 seconds and the minimum interval to 700 seconds.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra interval 1000 700
ipv6 nd ra router-lifetime
ipv6 nd ra no-advlinkmtu
Use ipv6 nd ra no-advlinkmtu to turn off the MTU option in RA messages.
Use undo ipv6 nd ra no-advlinkmtu to restore the default.
RA messages contain the MTU option.
Interface view
The MTU option in the RA messages specifies the link MTU to ensure that all nodes on the link use the same MTU.
# Turn off the MTU option in RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
Use ipv6 nd ra prefix to configure the prefix information in RA messages.
Use undo ipv6 nd ra prefix to restore the default.
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix/prefix-length }
No prefix information is configured for RA messages. Instead, the IPv6 address of the interface sending RA messages is used as the prefix information.
If the IPv6 address is manually configured, the prefix uses the fixed valid lifetime 2592000 seconds (30 days) and preferred lifetime 604800 seconds (7 days).
If the IPv6 address is automatically obtained (through DHCP, for example), the prefix uses the valid and preferred lifetime of the IPv6 address.
Interface view
ipv6-prefix: Specifies the IPv6 prefix.
prefix-length: Specifies the prefix length of the IPv6 address.
valid-lifetime: Specifies the valid lifetime of a prefix, in the range of 0 to 4294967295 seconds. The default value is 2592000 seconds (30 days).
preferred-lifetime: Specifies the preferred lifetime of a prefix used for stateless autoconfiguration, in the range of 0 to 4294967295 seconds. The preferred lifetime cannot be longer than the valid lifetime. The default value is 604800 seconds (7 days).
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If you do not specify this keyword, the prefix is used for stateless autoconfiguration.
off-link: Indicates that the address with the prefix is not directly reachable on the link. If you do not specify this keyword, the address with the prefix is directly reachable on the link.
no-advertise: Disables the device from advertising the prefix specified in this command. If you do not specify this keyword, the device advertises the prefix specified in this command.
After hosts on the same link receive RA messages, they can use the prefix information in the RA messages for stateless autoconfiguration.
A prefix specified without a parameter in this command preferentially uses the default settings configured by using the ipv6 nd ra prefix default command. If the default settings are unavailable, the prefix uses the following settings:
·     Valid lifetime of 2592000 seconds (30 days).
·     Preferred lifetime of 604800 seconds (7 days).
·     The prefix is used for stateless autoconfiguration.
·     The address with the prefix is directly reachable on the link.
·     The prefix is advertised in RA messages.
# Configure the prefix information in RA messages on GigabitEthernet 0/0/1.
Method 1:
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra prefix 2001:10::100/64 100 10
Method 2:
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra prefix 2001:10::100 64 100 10
Use ipv6 nd ra prefix default to configure the default settings for prefixes advertised in RA messages.
Use undo ipv6 nd ra prefix default to restore the default.
ipv6 nd ra prefix default [ valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] * | no-advertise ]
No default settings are configured for prefixes advertised in RA messages.
Interface view
This command specifies the default settings for the prefix specified by using the ipv6 nd ra prefix command. If none of the parameters (valid-lifetime, preferred-lifetime, no-autoconfig, off-link, and no-advertise) is configured in the ipv6 nd ra prefix command, the prefix uses the default settings.
# Configure the default settings for prefixes advertised in RA messages on GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra prefix default 100 10
Use ipv6 nd ra router-lifetime to set the router lifetime in RA messages.
Use undo ipv6 nd ra router-lifetime to restore the default.
The router lifetime in RA messages is three times as long as the maximum interval for advertising RA messages.
Interface view
time: Specifies the router lifetime in the range of 0 to 9000 seconds. If the value is set to 0, the router does not act as the default router.
The router lifetime in RA messages specifies how long the router sending the RA messages acts as the default router. Hosts receiving the RA messages check this value to determine whether to use the sending router as the default router. If the router lifetime is 0, the router cannot be used as the default router.
The router lifetime in RA messages must be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on GigabitEthernet 0/0/1 to 1000 seconds.
[Sysname-GigabitEthernet0/0/1] ipv6 nd ra router-lifetime 1000
ipv6 nd ra interval
ipv6 nd route-direct advertise
Use ipv6 nd route-direct advertise to enable ND direct route advertisement.
Use undo ipv6 nd route-direct advertise to disable ND direct route advertisement.
The ND direct route advertisement feature is disabled.
Interface view
# Enable ND direct route advertisement for L3VE interface VE-L3VPN 1.
[Sysname] interface ve-l3vpn 1
[Sysname-VE-L3VPN1] ipv6 nd route-direct advertise
# Enable ND direct route advertisement for GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd route-direct advertise
ipv6 nd route-direct prefix convert-length
Use ipv6 nd route-direct prefix convert-length to specify a prefix length for generating a network route for identified ND entries.
Use undo ipv6 nd route-direct prefix to restore the default.
ipv6 nd route-direct prefix ipv6-prefix prefix-length convert-length convert-length
undo ipv6 nd route-direct prefix ipv6-prefix prefix-length
No prefix length is specified for generating a network route for identified ND entries.
Interface view
ipv6-prefix: Specifies an IPv6 prefix.
prefix-length: Specifies an IPv6 prefix length in the range of 1 to 128. The ipv6-prefix prefix-length arguments identify ND entries for which the network route is generated.
convert-length: Specifies an IPv6 prefix length for the generated network route, in the range of 1 to 127. The value for this argument must be higher than the value for the prefix-length argument.
After you execute the ipv6 nd route-direct advertise command on an interface, the device generates 128-bit host routes for ND entries learned on the interface. As a result, the routing table might be populated with excessive host routes. To reduce the routing table size, execute the ipv6 nd route-direct prefix convert-length command for the device to generate network routes for identified ND entries instead of host routes.
The specified IPv6 prefix must be the IPv6 address prefix of the interface.
# On GigabitEthernet 0/0/1, set the prefix length to 70 for generating a network route for ND entries with IPv6 prefix 2001::1/64.
[Sysname-GigabitEthernet0/0/1] ipv6 nd route-direct prefix 2001::1 64 convert-length 70
# On VSI-interface 1, set the prefix length to 70 for generating a network route for ND entries with IPv6 prefix 2001::1/64.
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] ipv6 nd route-direct prefix 2001::1 64 convert-length 70
# On VE-L3VPN 1, set the prefix length to 70 for generating a network route for ND entries with IPv6 prefix 2001::1/64.
[Sysname-VE-L3VPN1] ipv6 nd route-direct prefix 2001::1 64 convert-length 70
ipv6 nd router-preference
Use ipv6 nd router-preference to set a router preference in RA messages.
Use undo ipv6 nd router-preference to restore the default.
The router preference is medium.
Interface view
high: Sets the router preference to the highest setting.
low: Sets the router preference to the lowest setting.
medium: Sets the router preference to the medium setting.
A host selects a router with the highest preference as the default router.
When router preferences are the same in RA messages, a host selects the router corresponding to the first received RA message as the default gateway.
# Set the router preference in RA messages to the lowest on interface GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] ipv6 nd router-preference low
ipv6 nd suppression push interval
Use ipv6 nd suppression push interval to enable the ND suppression push feature and set a push interval.
Use undo ipv6 nd suppression push interval to disable the ND suppression push feature.
ipv6 nd suppression push interval interval
The ND suppression push feature is disabled.
interval: Specifies the push interval value in the range of 1 to 1440 minutes.
The ND suppression push feature regularly pushes ND suppression entries by advertising NA messages.
# Enable the device to push ND suppression entries every 2 minutes.
[Sysname]ipv6 nd suppression push interval 2
ipv6 nd suppression enable
ipv6 nd unsolicited-na-learning enable
Use ipv6 nd unsolicited-na-learning enable to enable unsolicited NA learning.
Use undo ipv6 nd unsolicited-na-learning enable to disable unsolicited NA learning.
Unsolicited NA learning is disabled.
Layer 3 interface view
To ensure that the device learns ND entries from trusted NA messages, enable this feature only on a secure network.
This feature might cause the device to learn excessive ND entries that consume too many system resources. As a best practice, execute the ipv6 neighbor stale-aging command to set a smaller aging timer before you enable this feature. The smaller aging timer accelerates the aging of ND entries in stale state.
# Enable unsolicited NA learning on Layer 3 Ethernet interface GigabitEthernet 0/0/1.
[Sysname] interface GigabitEthernet 0/0/1
[Sysname-GigabitEthernet0/0/1] ipv6 nd unsolicited-na-learning enable
Use ipv6 nd user-ip-conflict record enable to enable recording user IPv6 address conflicts.
Use undo ipv6 nd user-ip-conflict record enable to disable recording user IPv6 address conflicts.
Recording user IPv6 address conflicts is disabled.
This feature detects and records user IPv6 address conflicts. A conflict occurs if an incoming NA packet has the same source IPv6 address as an existing ND entry but a different source MAC address. The device generates a user IPv6 address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in System Management Configuration Guide.
Each card can generate a maximum of 10 user IPv6 address conflict logs per second. When this maximum number is reached, the card suppresses generating user IPv6 address conflict logs and records the suppression times. Each card can save a maximum of 200 user IPv6 address conflict records.
When the number of saved user IPv6 address conflict records reaches the upper limit, new records overwrite old ones.
# Enable recording user IPv6 address conflicts.
[Sysname] ipv6 nd user-ip-conflict record enable
Use ipv6 nd user-move record enable to enable recording user port migrations.
Use undo ipv6 nd user-move record enable to disable recording user port migrations.
Recording user port migrations is disabled.
This feature enables the device to detect and record user port migrations. A user port migrates if an incoming NA packet has the same source IPv6 address and source MAC address as an existing ND entry but a different port. The device generates a user port migration record, logs the migration event, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in System Management Configuration Guide.
Each card can generate a maximum of 10 user port migration logs per second. When this maximum number is reached, the card suppresses generating user port migration logs and records the suppression times. Each card can save a maximum of 200 user port migration records.
When the number of saved user port migration records reaches the upper limit, new records overwrite old ones.
# Enable recording user port migrations.
[Sysname] ipv6 nd user-move record enable
ipv6 neighbor
Use ipv6 neighbor to configure a static neighbor entry.
Use undo ipv6 neighbor to delete a neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
No static neighbor entries exist.
ipv6-address: Specifies the IPv6 address of the static neighbor entry.
mac-address: Specifies the MAC address (48 bits) of the static neighbor entry, in the format of H-H-H.
vlan-id: Specifies the VLAN ID of the static neighbor entry, in the range of 1 to 4094.
port-type port-number: Specifies a Layer 2 port of the static neighbor entry by its type and number.
interface interface-type interface-number: Specifies a Layer 3 interface of the static neighbor entry by its type and number.
A neighbor entry stores information about a link-local node. The entry can be created dynamically through NS and NA messages, or configured statically.
The device uniquely identifies a static neighbor entry by using the neighbor's IPv6 address and the number of the Layer 3 interface that connects to the neighbor. You can configure a static neighbor entry by using either of the following methods:
·     Method 1—Associate a neighbor IPv6 address and link-layer address with the Layer 3 interface of the local node.
·     Method 2—Associate a neighbor IPv6 address and link-layer address with a Layer 2 port in a VLAN containing the local node.
To configure a static neighbor entry for a VLAN interface, use Method 1 or Method 2.
·     If Method 1 is used, the neighbor entry is in INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry goes into REACH state.
·     If Method 2 is used, the port specified by port-type port-number must belong to the VLAN specified by vlan-id and the corresponding VLAN interface must already exist. After the static neighbor entry is configured, the device associates the VLAN interface with the IPv6 address to uniquely identify the static neighbor entry. The entry will be in REACH state.
To delete a neighbor entry for a VLAN interface, specify only the VLAN interface.
You can use the undo ipv6 neighbor command to delete both static and dynamic neighbor entries.
# Configure a static neighbor entry for Layer 3 interface GigabitEthernet 0/0/1.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 interface gigabitethernet 0/0/1
Use ipv6 neighbor link-local minimize to minimize link-local ND entries.
Use undo ipv6 neighbor link-local minimize to restore the default.
All ND entries are assigned to the driver.
Perform this command to minimize link-local ND entries assigned to the driver. Link-local ND entries refer to ND entries that contain link-local addresses.
With this feature enabled, the device does not add newly learned link-local ND entries whose link local addresses are not the next hop of any route to the driver. This saves driver resources.
This feature affects only newly learned link-local ND entries rather than existing ND entries.
# Minimize link-local ND entries.
[Sysname] ipv6 neighbor link-local minimize
Use ipv6 neighbor stale-aging to set the aging timer for ND entries in stale state.
Use undo ipv6 neighbor stale-aging to restore the default.
ipv6 neighbor stale-aging { aging-minutes | second aging-seconds }
The aging timer for ND entries in stale state is 240 minutes.
aging-minutes: Specifies the aging timer in minutes for ND entries in stale state, in the range of 1 to 1440.
second aging-seconds: Specifies the aging timer in seconds for ND entries in stale state, in the range of 60 to 86400.
This aging time applies to all ND entries in stale state. If an ND entry in stale state is not updated before the timer expires, it moves to the delay state. If it is still not updated in 5 seconds, the ND entry moves to the probe state. The device sends an NS message for detection a maximum of three times. If no response is received, the device deletes the ND entry.
# Set the aging timer for ND entries in stale state to 120 minutes.
[Sysname] ipv6 neighbor stale-aging 120
ipv6 neighbor timer stale-aging
Use ipv6 neighbor timer stale-aging to set the aging timer for ND entries in stale state on an interface.
Use undo ipv6 neighbor timer stale-aging to restore the default.
ipv6 neighbor timer stale-aging { aging-minutes | second aging-seconds }
The aging timer of ND entries in stale state is not configured on an interface. The aging timer is determined by the configuration of the ipv6 neighbor stale-aging command in system view.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
Layer 3 RPR logical interface view
VXLAN VSI interface view
VLAN interface view
Tunnel interface view
Serial interface view
This aging timer applies to ND entries in stale state on the interface. If an ND entry in stale state is not updated before the timer expires, it changes to the delay state. If it is still not updated in 5 seconds, the ND entry changes to the probe state. The device sends an NS message for probe and a maximum of three attempts is allowed. If no response is received, the device deletes the ND entry.
You can set the aging timer for ND entries in stale state in system view and interface view. For ND entries in stale state on an interface, the aging timer in interface view has higher priority than the aging timer in system view.
# On GigabitEthernet 0/0/1, set the aging timer to 200 minutes for ND entries in stale state.
[Sysname-GigabitEthernet0/0/1] ipv6 neighbor timer stale-aging 200
ipv6 neighbors max-learning-num
Use ipv6 neighbors max-learning-num to set the maximum number of dynamic neighbor entries that an interface can learn. This prevents the interface from occupying too many neighbor table resources.
Use undo ipv6 neighbors max-learning-num to restore the default.
An interface can learn a maximum of 2048 dynamic neighbor entries.
Layer 2/Layer 3 interface view
Layer 2/Layer 3 aggregate interface view
max-number: Specifies the maximum number of dynamic neighbor entries that an interface can learn. The value range for this argument is 1 to 2048.
The device can dynamically acquire the link-layer address of a neighboring node through NS and NA messages and add it into the neighbor table.
When the number of dynamic neighbor entries reaches the threshold, the interface stops learning neighbor information.
# Set the maximum number of dynamic neighbor entries that GigabitEthernet 0/0/1 can learn to 10.
[Sysname-GigabitEthernet0/0/1] ipv6 neighbors max-learning-num 10
local-proxy-nd enable
Use local-proxy-nd enable to enable local ND proxy.
Use undo local-proxy-nd enable to disable local ND proxy.
Local ND proxy is disabled.
VLAN interface view
# Enable local ND proxy on interface GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] local-proxy-nd enable
proxy-nd enable
proxy-nd enable
Use proxy-nd enable to enable common ND proxy.
Use undo proxy-nd enable to disable common ND proxy.
proxy-nd enable
Common ND proxy is disabled.
VLAN interface view
# Enable common ND proxy on interface GigabitEthernet 0/0/1.
[Sysname-GigabitEthernet0/0/1] proxy-nd enable
proxy-nd span-segment enable
Use proxy-nd span-segment enable to enable cross-segment ND proxy.
Use undo proxy-nd span-segment enable to disable cross-segment ND proxy.
Cross-segment ND proxy is disabled.
VLAN interface view
ND proxy enables a device to answer an NS message requesting the hardware address of a host on another network. With ND proxy, hosts in different broadcast domains can communicate with each other as they would on the same network.
Cross-segment ND proxy allows neighbor discovery when the hosts are connected to different Layer 3 interfaces or subinterfaces and the IP addresses of the hosts and the interfaces are not in the same network.
# Enable cross-segment ND proxy on interface GigabitEthernet0/0/1.
[Sysname-GigabitEthernet0/0/1] proxy-nd span-segment enable
Use reset ipv6 neighbors to clear IPv6 neighbor information.
all: Clears static and dynamic neighbor information for all interfaces.
dynamic: Clears dynamic neighbor information for all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information for the interface specified by its type and number.
slot slot-number: Specifies a card by its slot number. If you do not specify a cad, this command clears dynamic neighbor information for all cards.
static: Clears static neighbor information for all interfaces.
# Clear neighbor information for all interfaces.
<Sysname> reset ipv6 neighbors all
This will delete all the entries. Continue? [Y/N]:Y
# Clear dynamic neighbor information for all interfaces.
<Sysname> reset ipv6 neighbors dynamic
This will delete all the dynamic entries. Continue? [Y/N]:Y
# Clear all neighbor information for GigabitEthernet 0/0/1.
<Sysname> reset ipv6 neighbors interface gigabitethernet 0/0/1
This will delete all the dynamic entries by the interface you specified. Continue? [Y/N]:Y
ipv6 neighbor
