03-NAT66 configuration | 125.56 KB |
IPv6 source prefix translation
IPv6 destination prefix translation
Configuring IPv6 source prefix translation
Configuring IPv6 destination prefix translation
Display and maintenance commands for NAT66
Example: Configuring IPv6 source prefix translation
Example: Configuring IPv6 destination prefix translation
Example: Configuring IPv6 source prefix translation (single internal and external network)
Example: Configuring IPv6 source prefix translation (multihomed network)
Configuring NAT66
Overview
IPv6-to-IPv6 Network Prefix Translation (NPTv6), also known as NAT66, translates the internal IPv6 prefix in the IPv6 packet header to an external IPv6 prefix and vice versa. A device that implements NAT66 translation is called a NAT66 device.
NAT66 source address translation is applicable to the following scenarios:
· Single internal and external network—The NAT66 device is connected to an internal network and an external network. Hosts in the internal network uses locally routed IPv6 prefixes. When an internal host sends packets to access the external network, the NAT66 device translates the source IPv6 address prefix in the packets to a global unicast address prefix.
· Redundancy and load sharing—Multiple NAT66 devices are deployed between two IPv6 networks and they use ECMPs for load sharing. To allow any NAT66 device to process IPv6 traffic among different sites, configure the same source prefix mappings on these NAT66 devices.
· Multihoming—In a multihomed network, NAT66 devices are connected to an internal network and multiple external networks. One internal prefix is mapped to different external prefixes on the NAT66 devices, so that one internal address can be translated to multiple external addresses.
To allow external users to access internal servers, such as Wed server or FTP server, configure IPv6 destination prefix mappings on the interface connected to the external network.
NAT66 ALG
NAT66 ALG (Application Level Gateway) translates address or port information in the application layer payloads to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT66 ALG to translate the address and port information for data connection establishment.
NAT66 ALG supports the following protocol packets: FTP packets and ICMP error messages.
On one interface, the mapping between an internal prefix and an external prefix must be unique.
On different interfaces, different internal prefixes cannot be mapped to the same external prefix.
When you configure source address translation in NO-PAT mode, specify the same IPv6 prefix length before and after NAT66 in a mapping.
The source IPv6 prefix after translation cannot be the same as the external prefix of the NAT66 device or the prefix of the external destination address.
You can configure the global NAT policy to achieve IPv6 source prefix translation. For more information about global NAT policy, see "Configuring NAT."
This feature cannot perform translation on AH or ESP packets.
1. Enter system view.
2. Enter interface view.
3. Configure an IPv6 prefix mapping for IPv6 source address translation.
nat66 prefix source original-ipv6-prefix prefix-length translated-ipv6-prefix prefix-length [ pat ]
By default, no IPv6 prefix mappings are configured for IPv6 source address translation.
On one interface, the mapping between an external prefix and an internal prefix must be unique.
On different interfaces, one external prefix cannot be mapped to different internal prefixes.
The external IPv6 prefix of the internal server cannot be the same as the external prefix of the NAT66 device or the prefix of external hosts that access the internal server.
You can configure the global NAT policy to achieve IPv6 destination prefix translation. For more information about global NAT policy, see "Configuring NAT."
3. Configure an IPv6 prefix mapping for IPv6 destination address translation.
nat66 prefix destination original-ipv6-prefix prefix-length [ protocol pro-type [ global-port ] ] translated-ipv6-prefix prefix-length [ local-port ]
By default, no IPv6 prefix mappings are configured for IPv6 destination address translation.
Task |
Command |
Display all NAT66 configurations. |
display nat66 all |
Display NAT66 sessions. |
In standalone mode: display nat66 session [ slot slot-number [ cpu cpu-number ] ] [ verbose ] In IRF mode: display nat66 session [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose ] |
Display NAT66 statistics. |
In standalone mode: display nat66 statistics [ summary ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display nat66 statistics [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Delete NAT66 sessions. |
In standalone mode: reset nat66 session [ slot slot-number [ cpu cpu-number ] ] In IRF mode: reset nat66 session [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
NAT configuration examples
As shown in Figure 1, internal users use IPv6 prefix FD01:0203:0405::/48 and the internal IPv6 addresses are not routable on the Internet. For internal users to access the FTP server on the Internet, configure IPv6 source prefix translation to translate the internal IPv6 prefix FD01:0203:0405::/48 to external prefix 2001:0DF8:0001::/48.
# Assign IPv6 addresses to interfaces and configure routes, security zones, and security policies. Make sure the network connections are available. (Details not shown.)
# Configure an IPv6 source prefix mapping from FD01:0203:0405::/48 to FD01:0203:0405::/48.
[Device-GigabitEthernet1/0/2] nat66 prefix source fd01:0203:0405:: 48 2001:0df8:0001:: 48
# Verify that internal hosts can access the FTP server. (Details not shown.)
# Verify NAT66 configurations.
[Device] display nat66 all
NAT66 source information:
Totally 1 source rules.
Interface(outbound): GigabitEthernet1/0/2
Original prefix/prefix-length: FD01:203:405::/48
Translated prefix/prefix-length: 2001:DF8:1::/48
# Verify that NAT66 sessions are established.
<Device> display nat66 session verbose
Slot 1
Initiator:
Source IP/port: FD01:203:405::1/56002
Destination IP/port: 2001:DC8:1::100/21
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/1
Source security zone: Trust
Responder:
Source IP/port: 2001:DC8:1::100/21
Destination IP/port: 2001:DF8:1:D50F::1/56002
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/2
Source security zone: Untrust
State: TCP_ESTABLISHED
Application: FTP
Rule ID: 1
Rule name: 1
Start time: 2018-12-06 14:48:31 TTL: 3597s
Initiator->Responder: 0 packets 0 bytes
Responder->Initiator: 0 packets 0 bytes
Total sessions found: 1
As shown in Figure 2, the internal IPv6 address of FTP server is FD01:0203:0405::100/48. The internal prefix is FD01:0203:0405::/48. Configure destination IPv6 prefix translation to allow the FTP server to use IPv6 address 2001:AB01:0001::1 to provide services for external users.
# Configure an IPv6 destination prefix mapping from 2001:AB01:0001::1/128 to FD01:0203:0405::100/128.
[Device-GigabitEthernet1/0/2] nat66 prefix destination 2001:ab01:1::1 128 fd01:203:405::100 128
# Verify that external hosts can access the FTP server. (Details not shown.)
NAT66 destination information:
Totally 1 destination rules.
Interface(inbound): GigabitEthernet1/0/2
Original prefix/prefix-length: 2001:AB01:1::1/128
Translated prefix/prefix-length: FD01:203:405::100/128
[Device] display nat66 session verbose
Slot 1:
Initiator:
Source IP/port: 2001:DC8:1::100/9025
Destination IP/port: 2001:AB01:1::1/21
Protocol: TCP(6)
Responder:
Source IP/port: FD01:203:405::100/21
Destination IP/port: 2001:DC8:1::100/9025
Protocol: TCP(6)
Application: FTP
Rule ID: 1
Rule name: 1
Start time: 2018-12-06 14:56:03 TTL: 3579s
As shown in Figure 3, internal users use IPv6 prefix FD01:0203:0405::/48 and the internal IPv6 addresses are not routable on the Internet. For internal users to access the FTP server on the Internet, configure IPv6 source prefix translation to translate the internal IPv6 prefix FD01:0203:0405::/48 to external prefix 2001:0DF8:0001::/48.
1. Assign IPv6 addresses to interfaces:
# Assign an IPv6 address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ipv6 address FD01:0203:0405::10 48
# Assign IPv6 addresses to other interfaces in the same way. (Details not shown.)
2. Configure settings for routing.
This example configures a static route, and the next hop in the route is 2001:0DB8:0001::11.
[Device] ipv6 route-static 2001:0DC8:0001::100 48 2001:0DB8:0001::11
3. Add interfaces to security zones.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
4. Configure a security policy:
# Configure a rule named trust-untrust to permit the packets from Host A and Host B to the FTP server.
[Device] security-policy ipv6
[Device-security-policy-ipv6] rule 1 name trust-untrust
[Device-security-policy-ipv6-1-trust-untrust] source-zone trust
[Device-security-policy-ipv6-1-trust-untrust] destination-zone untrust
[Device-security-policy-ipv6-1-trust-untrust] source-ip-host FD01:0203:0405::1
[Device-security-policy-ipv6-1-trust-untrust] source-ip-host FD01:0203:0405::2
[Device-security-policy-ipv6-1-trust-untrust] destination-ip-host 2001:0DC8:0001::100
[Device-security-policy-ipv6-1-trust-untrust] action pass
[Device-security-policy-ipv6-1-trust-untrust] quit
[Device-security-policy-ipv6] quit
5. Configure IPv6 source prefix translation:
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
Application: FTP
Rule ID: 1
Rule name: 1
As shown in Figure 4, internal users use IPv6 prefix FD01:0203:0405::/48 and the internal IPv6 address is not routable on the Internet.
Device A and Device B are connected to the same internal network but different external networks. Configure IPv6 source prefix translation to translate the internal IPv6 prefix FD01:0203:0405::/48 to different external prefixes so that the internal address can be translated to two external addresses.
1. Configure Device A.
a. Assign IPv6 addresses to interfaces:
[DeviceA-GigabitEthernet1/0/1] ipv6 address FD01:0203:0405::10 48
b. Configure settings for routing.
[DeviceA] ipv6 route-static 2001:0DC8:0001::100 48 2001:0DB8:0001::11
c. Add interfaces to security zones.
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/1
[DeviceA-security-zone-Trust] quit
[DeviceA] security-zone name untrust
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/2
[DeviceA-security-zone-Untrust] quit
d. Configure a security policy:
# Configure a rule named trust-untrust to permit the packets from the host to the FTP server.
[DeviceA] security-policy ipv6
[DeviceA-security-policy-ipv6] rule name trust-untrust
[DeviceA-security-policy-ipv6-1-trust-untrust] source-zone trust
[DeviceA-security-policy-ipv6-1-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ipv6-1-trust-untrust] source-ip-host FD01:0203:0405::1
[DeviceA-security-policy-ipv6-1-trust-untrust] destination-ip-host 2001:0DC8:0001::100
[DeviceA-security-policy-ipv6-1-trust-untrust] action pass
[DeviceA-security-policy-ipv6-1-trust-untrust] quit
[DeviceA-security-policy-ipv6] quit
e. Configure IPv6 source prefix translation:
# Configure an IPv6 source prefix mapping from FD01:0203:0405::/48 to 2001:0DF8:0001::/48.
[DeviceA-GigabitEthernet1/0/2] nat66 prefix source fd01:0203:0405:: 48 2001:0df8:0001:: 48
2. Configure Device B.
[DeviceB-GigabitEthernet1/0/1] ipv6 address FD01:0203:0405::20 48
This example configures a static route, and the next hop in the route is 2001:0DB8:5555::11.
[DeviceB] ipv6 route-static 2001:0DC8:0001::100 48 2001:0DB8:5555::11
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Trust] quit
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/2
[DeviceB-security-zone-Untrust] quit
[DeviceB] security-policy ipv6
[DeviceB-security-policy-ipv6] rule name trust-untrust
[DeviceB-security-policy-ipv6-1-trust-untrust] source-zone trust
[DeviceB-security-policy-ipv6-1-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ipv6-1-trust-untrust] source-ip-host FD01:0203:0405::1
[DeviceB-security-policy-ipv6-1-trust-untrust] destination-ip-host 2001:0DC8:0001::100
[DeviceB-security-policy-ipv6-1-trust-untrust] action pass
[DeviceB-security-policy-ipv6-1-trust-untrust] quit
[DeviceB-security-policy-ipv6] quit
# Configure an IPv6 source prefix mapping from FD01:0203:0405::/48 to 2001:0DE8:0001::/48.
[DeviceB-GigabitEthernet1/0/2] nat66 prefix source fd01:0203:0405:: 48 2001:0de8:0001:: 48
# Verify that the internal host can access the FTP server through Device A or Device B. The internal prefix is mapped to different external prefixes and external prefixes are mapped to the same internal prefix on the two NAT66 devices.
# Verify NAT66 configurations on Device A.
[DeviceA] display nat66 all
# Verify NAT66 configurations on Device B.
[DeviceB] display nat66 all
Translated prefix/prefix-length: 2001:DE8:1::/48
# Verify that NAT66 sessions are established on Device A.
[DeviceA] display nat66 session verbose
Slot 1:
Initiator:
Source IP/port: FD01:203:405::1/35990
Protocol: TCP(6)
Responder:
Destination IP/port: 2001:DF8:1:D50F::1/35990
Protocol: TCP(6)
Application: FTP
Rule ID: 0
Rule name: aaa
Start time: 2021-10-31 14:47:44 TTL: 3584s
# Verify that NAT66 sessions are established on Device B.
[DeviceB] display nat66 session verbose
Slot 1:
Initiator:
Source IP/port: FD01:203:405::1/35992
Protocol: TCP(6)
Responder:
Destination IP/port: 2001:DE8:1:D51F::1/35992
Protocol: TCP(6)
Application: FTP
Rule ID: 0
Rule name: aaa
Start time: 2021-10-31 14:50:03 TTL: 3594s
As shown in Figure 5, the internal IPv6 address of FTP server is FD01:0203:0405::100/48. The internal prefix is FD01:0203:0405::/48. Configure destination IPv6 prefix translation to allow the FTP server to use IPv6 address 2001:AB01:0001::1 to provide services for external users.
2. Add interfaces to security zones.
3. Configure a security policy:
# Configure a rule named untrust-trust to permit the packets from the hosts in the external network to the FTP server in the Trust security zone.
[Device-security-policy-ipv6] rule 1 name untrust-trust
[Device-security-policy-ipv6-1-untrust-trust] source-zone untrust
[Device-security-policy-ipv6-1-untrust-trust] destination-zone trust
[Device-security-policy-ipv6-1-untrust-trust] destination-ip-host FD01:0203:0405::100
[Device-security-policy-ipv6-1-untrust-trust] action pass
[Device-security-policy-ipv6-1-untrust-trust] quit
4. Configure IPv6 destination prefix translation:
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
Application: FTP
Rule ID: 1
Rule name: 1
