- 17-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-EAA commands
- 05-Process monitoring and maintenance commands
- 06-NETCONF commands
- 07-Information center commands
- 08-SNMP commands
- 09-NetStream commands
- 10-RMON commands
- 11-Flow log commands
- 12-Event MIB commands
- 13-Packet capture commands
- 14-Fast log output commands
- 15-Mirroring commands
- 16-GOLD commands
- 17-BFD commands
- 18-Track commands
- 19-Interface collaboration commands
- 20-Process placement commands
| 15-Mirroring commands | 34.45 KB |
Flow mirroring commands
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
Traffic behavior view
context-admin
You can execute this command multiple times for a traffic behavior to mirror traffic to different interfaces.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0/1 for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1
