01-Load balancing commands | 1.86 MB |
all-service-down action forward
arp-nd interface (SNAT address pool view)
arp-nd interface (virtual server view)
bandwidth busy-protection enable (transparent DNS proxy view)
bandwidth busy-protection enable (virtual server pool view)
bandwidth busy-protection enable (virtual server view)
bandwidth interface statistics enable
connection-limit max (link group member view)
connection-limit max (link view)
connection-limit max (real server view)
connection-limit max (server farm member view)
connection-limit max (virtual server view)
connection-sync enable (transparent DNS proxy view)
connection-sync enable (virtual server view)
content (HTTP content sticky group view)
content (HTTP passive sticky group view)
display loadbalance connections
display loadbalance dns-listener
display loadbalance dns-listener statistics
display loadbalance dns-map statistics
display loadbalance dns-proxy statistics
display loadbalance dns-server
display loadbalance dns-server statistics
display loadbalance dns-server-pool
display loadbalance external-monitor log
display loadbalance hot-backup statistics
display loadbalance limit-policy
display loadbalance link out-interface statistics
display loadbalance link statistics
display loadbalance link-group
display loadbalance local-dns-server parse-fail-record
display loadbalance probe-template
display loadbalance process-limit
display loadbalance protection-policy
display loadbalance reverse-zone
display loadbalance snat-global-policy
display loadbalance virtual-server total-statistics
display loadbalance virtual-server-pool
display real-server statistics
display virtual-server statistics
dns-server (DNS server pool view)
dns-server-pool (DNS server view)
dns-server-pool (LB action view)
external-link inject-domain-suffix
external-link proxy enable (LB action view)
external-link proxy enable (virtual server view)
external-link whitelist domain
fail-action (server farm view)
fallback-action response raw-file
header (HTTP header sticky group view)
header (HTTP passive sticky group view)
header delete request accept-encoding
inherit vpn-instance disable (link view)
inherit vpn-instance disable (real server view)
ip address (DNS listener view)
ip address (transparent DNS proxy view)
ipv6 address (DNS listener view)
ipv6 address (DNS server view)
ipv6 address (real server view)
ipv6 address (transparent DNS proxy view)
keepalive retransmission interval
lb-policy (transparent DNS proxy view)
lb-policy (virtual server view)
loadbalance dns-cache aging-time
loadbalance flow-redirect blade-aggregation
loadbalance flow-redirect disable
loadbalance flow-redirect failover-group
loadbalance isp auto-update enable
loadbalance isp auto-update frequency
loadbalance isp auto-update whois-server
loadbalance local-dns-server parse-fail-record type
loadbalance local-dns-server parse-fail-record max-number
loadbalance local-dns-server schedule-test ip
loadbalance local-dns-server schedule-test ipv6
loadbalance log enable bandwidth-busy
loadbalance log enable link-flow
loadbalance reload external-link file
loadbalance session flow-redirect local
loadbalance schedule-test ipv6
match-across-virtual-server enable
payload (HTTP/UDP payload sticky group view)
payload (UDP passive sticky group view)
port (transparent DNS proxy view)
predictor (DNS server pool view)
predictor (virtual server pool view)
priority (DNS server pool member view)
priority (link group member view)
priority (server farm member view)
priority (SNAT global policy view)
probe (DNS server pool member view)
probe (link group member view)
probe (server farm member view)
probe-template (real server view)
probe-template (server farm member view)
probe-template (server farm view)
probe log enable (real server view)
probe log enable (server farm member view)
proximity enable (link group view)
proximity enable (server farm view)
rate-limit bandwidth (link view)
rate-limit bandwidth (real server view)
rate-limit bandwidth (virtual server view)
rate-limit connection (link group member view)
rate-limit connection (link view)
rate-limit connection (real server view)
rate-limit connection (server farm member view)
rate-limit connection (virtual server view)
rate-limit http-request (real server view)
rate-limit http-request (server farm member view)
real-server (server farm view)
recover-from-auto-shutdown (real server view)
recover-from-auto-shutdown (server farm member view)
redirect relocation (LB action view)
redirect relocation (virtual server view)
redirect return-code (LB action view)
redirect return-code (virtual server view)
reset loadbalance dns-listener statistics
reset loadbalance dns-map statistics
reset loadbalance dns-proxy statistics
reset loadbalance dns-server statistics
reset loadbalance hot-backup statistics
reset loadbalance link statistics
reset loadbalance local-dns-server parse-fail-record
reset virtual-server statistics
selected-server (DNS server pool view)
selected-server (server farm view)
server-farm (real server view)
service enable (DNS listener view)
service enable (DNS mapping view)
service enable (transparent DNS proxy view)
service enable (virtual server view)
set ip tos (parameter profile view)
shutdown (link group member view)
slow-online (server farm view)
slow-shutdown enable (link group member view)
slow-shutdown enable (link view)
slow-shutdown enable (real server view)
slow-shutdown enable (server farm member view)
snmp-agent trap enable loadbalance
source-ip object-group (parameter profile view)
source-ip object-group (SNAT global policy view)
ssl-client-policy (LB action view)
ssl-client-policy (virtual server view)
sticky-sync enable (transparent DNS proxy view)
sticky-sync enable (virtual server view)
success-criteria (DNS server pool member view)
success-criteria (DNS server pool view)
success-criteria (DNS server view)
success-criteria (link group member view)
success-criteria (link group view)
success-criteria (real server view)
success-criteria (server farm member view)
success-criteria (server farm view)
timeout (LB probe template view)
transparent enable (link group view)
transparent enable (server farm view)
virtual-server (virtual server pool view)
vpn-instance (DNS listener view)
vpn-instance (DNS server view)
vpn-instance (real server view)
vpn-instance (SNAT address pool view)
vpn-instance (SNAT global policy view)
vpn-instance (transparent DNS proxy view)
vpn-instance (virtual server view)
weight (DNS server pool member view)
weight (link group member view)
All service modules except the Application delivery engine (ADE) module require a license to run the server load balancing feature.
Non-default vSystems do not support some of the load balancing commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
abnormal-url threshold
Use abnormal-url threshold to set the upper limit of URL error times.
Use undo abnormal-url threshold to restore the default.
abnormal-url threshold number
The upper limit of URL error times is 10000.
HTTP passive LB probe template view
context-admin
vsys-admin
number: Specifies the upper limit of URL error times, in the range of 1 to 4294967295.
The device monitors the responses of HTTP requests with URLs specified in the check-url command. If the response time for an HTTP request exceeds the specified timeout time or the status code in the HTTP response is the same as the specified response status code, a URL error is recorded. If the number of URL errors exceeds the upper limit of URL error times, the real server is automatically shut down.
# Set the upper limit of URL error times to 20 for HTTP passive LB probe template tplt.
[Sysname] loadbalance probe-template http-passive tplt
[Sysname-lbpt-http-passive-tplt] abnormal-url threshold 20
check-url
status-code
timeout
activate (link group view)
Use activate to set the criteria to determine whether a link group is available.
Use undo activate to restore the default.
activate lower lower-percentage upper upper-percentage
undo activate
A link group is available when a minimum of one link is available.
Link group view
context-admin
lower lower-percentage: Specifies the lower percentage value in the range of 1 to 99.
upper upper-percentage: Specifies the upper percentage value in the range of 1 to 99. The upper percentage value must be greater than or equal to the lower percentage value.
Non-default vSystems do not support this command.
When the percentage of available links in a primary link group is smaller than the lower percentage value, the primary link group becomes unavailable. Then the backup link group takes over. When the percentage of available links in a primary link group is greater than the upper percentage value, the primary link group becomes available again to process services.
If no backup link group is configured on the virtual server, this configuration does not take effect.
# Set the lower percentage value to 20 and upper percentage value to 80 for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] activate lower 20 upper 80
activate (server farm view)
Use activate to set the criteria to determine whether a server farm is available.
undo activate
A server farm is available when a minimum of one real server is available.
Server farm view
context-admin
vsys-admin
lower lower-percentage: Specifies the lower percentage value in the range of 1 to 99. When the percentage of available real servers in the primary server farm is lower than the lower percentage value, the primary server farm becomes unavailable. Then the backup server farm takes over.
upper upper-percentage: Specifies the upper percentage value in the range of 1 to 99. The upper percentage value must be higher than or equal to the lower percentage value. When the percentage of available real servers in the primary server farm is higher than the upper percentage value, the primary server farm becomes available again to process services.
If no backup server farm is configured on the virtual server, this configuration does not take effect.
# Set the lower percentage value to 20 and upper percentage value to 80 for the server farm sf.
[Sysname] server-farm sf
[Sysname-sfarm-sf] activate lower 20 upper 80
Use all-service-down action forward to enable the device to forward packets to the last selected server farm member when all server farm members are unavailable.
Use undo all-service-down action forward to restore the default.
The device drops packets when all server farm members are unavailable.
Server farm view
context-admin
This command takes effect only when the server farm is referenced by a TCP virtual server operating in Layer 7.
# Enable the device to forward packets to the last selected server farm member when all server farm members are unavailable.
[Sysname-sfarm-sf] all-service-down action forward
application-mode enable
Use application-mode enable to configure a TCP virtual server to operate at Layer 7.
Use undo application-mode enable to restore the default.
A TCP virtual server operates at Layer 4.
TCP virtual server view
context-admin
vsys-admin
# Configure TCP virtual server vs to operate at Layer 7.
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] application-mode enable
argument
Use argument to configure user-defined information for a custom-monitoring LB probe template.
Use undo argument to restore the default.
argument text
undo argument
No user-defined information is configured for a custom-monitoring LB probe template.
Custom-monitoring LB probe template view
context-admin
text: Specifies an information text, a case-sensitive string of 1 to 255 characters. The string can contain spaces and cannot contain quotation marks (").
When executing the script file used for custom monitoring, the device transfers the information text to the script file as a parameter.
You can configure multiple arguments separated by spaces as the user-defined information.
# In custom-monitoring LB probe template test_external, configure user-defined information as abc 123 456.
[Sysname] loadbalance probe-template external-monitor test_external
[Sysname-lbpt-external-monitor-test_external] argument abc 123 456
Use arp-nd interface to specify an interface for sending gratuitous ARP packets and ND packets.
Use undo arp-nd interface to disable an interface from sending gratuitous ARP packets and ND packets.
arp-nd interface interface-type interface-number
undo arp-nd interface interface-type interface-number
No interface is specified for sending gratuitous ARP packets and ND packets. No interface can send gratuitous ARP packets or ND packets.
context-admin
vsys-admin
You can execute this command multiple times to specify multiple interfaces for one SNAT address pool.
# For SNAT address pool lbsp, specify GigabitEthernet 1/0/1 as the interface for sending gratuitous ARP packets and ND packets.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] arp-nd interface gigabitethernet 1/0/1
Virtual server view
context-admin
vsys-admin
You can execute this command multiple times to specify multiple interfaces for one virtual server.
# For virtual server vs3, specify GigabitEthernet 1/0/1 as the interface for sending gratuitous ARP packets and ND packets.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] arp-nd interface gigabitethernet 1/0/1
auto-alloc address
Use auto-alloc address to enable the device to automatically obtain the IP address of a DNS server.
Use undo auto-alloc address to disable the device from automatically obtaining the IP address of a DNS server.
auto-alloc address
The device is disabled from automatically obtaining the IP address of a DNS server.
DNS server view
context-admin
This command is mutually exclusive with the ip address and ipv6 address commands.
Before configuring this command, you must configure the router interface command. Otherwise, the IP address of the DNS server cannot be obtained.
If the device obtains multiple DNS server IP addresses, it uses the smallest available IP address.
# Enable the device to automatically obtain the IP address of DNS server ds1.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] auto-alloc address
auto-shutdown recovery-time
Use auto-shutdown recovery-time to set the automatic recovery time for intelligent monitoring.
Use undo auto-shutdown recovery-time to restore the default.
auto-shutdown recovery-time recovery-time
The automatic recovery time is 0 minutes.
Server farm view
context-admin
vsys-admin
recovery-time: Specifies the automatic recovery time in the range of 0 to 15300 minutes. The value of 0 means that a server farm member placed in Auto shutdown state does not automatically recover.
Use this command to enable automatic recovery for a real server that is shut down by intelligent monitoring.
If health monitoring is not configured, a recovered real server is set to Unknown state.
If health monitoring is configured and succeeds, a recovered real server is set to Active state. If health monitoring fails, a recovered real server is set to Probe-failed state.
# Set the automatic recovery time to 5 minutes for server farm sf.
[Sysname-sfarm-sf] auto-shutdown recovery-time 5
Use bandwidth busy-protection enable to enable the link protection feature for a transparent DNS proxy.
Use undo bandwidth busy-protection enable to disable the link protection feature for a transparent DNS proxy.
The link protection feature is disabled for a transparent DNS proxy.
Transparent DNS proxy view
context-admin
This feature enables a transparent DNS proxy to select a DNS server from the DNS server pool based on the link bandwidth ratio. If the bandwidth ratio of a link exceeds the specified value, the corresponding DNS server is not selected.
If the link bandwidth ratio of all DNS servers in the DNS server pool exceeds the specified value, the link protection feature is automatically disabled. If the link bandwidth ratio of any DNS server drops below the specified value, the link protection feature is automatically enabled, and the corresponding DNS server is selected.
# Enable the link protection feature for transparent DNS proxy dns-proxy1.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] bandwidth busy-protection enable
bandwidth busy-rate (link view)
Use bandwidth busy-protection enable to enable the link protection feature for a virtual server pool.
Use undo bandwidth busy-protection enable to disable the link protection feature for a virtual server pool.
The link protection feature is disabled for a virtual server pool.
Virtual server pool view
context-admin
This feature enables a virtual server pool to select a virtual server based on the link bandwidth ratio. If the bandwidth ratio of a link is exceeded, the virtual server is not selected.
# Enable the link protection feature for the virtual server pool local-pool.
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] bandwidth busy-protection enable
Use bandwidth busy-protection enable to enable the link protection feature.
Use undo bandwidth busy-protection enable to disable the link protection feature.
The link protection feature is disabled.
Virtual server view
context-admin
vsys-admin
The link protection feature takes effect only when bandwidth statistics collection by interfaces is enabled.
# Enable the link protection feature for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] bandwidth busy-protection enable
bandwidth busy-rate
Use bandwidth busy-rate to set the bandwidth ratio for an LB link.
Use undo bandwidth busy-rate to restore the default.
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
The bandwidth ratio is 70.
LB link view
context-admin
inbound: Specifies the inbound bandwidth ratio.
outbound: Specifies the outbound bandwidth ratio.
busy-rate-number: Specifies bandwidth ratio in the range of 1 to 100.
recovery recovery-rate-number: Specifies bandwidth recovery ratio in the range of 1 to 100. By default, if the bandwidth ratio is greater than 10, the bandwidth recovery ratio equals the bandwidth ratio minus 10; if the bandwidth ratio is smaller than or equal to 10, the bandwidth recovery ratio equals the bandwidth ratio.
If the bandwidth of an LB link exceeds the maximum expected bandwidth multiplied by the bandwidth ratio, the LB link is busy and will not be selected. If the bandwidth of the LB link drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio, the LB link participates in scheduling again.
If you do not specify the inbound or outbound keyword, this command sets the total bandwidth ratio.
The bandwidth ratio equals the current bandwidth divided by the maximum bandwidth of the LB link. If the maximum bandwidth is not limited, the supported maximum bandwidth is used for calculating the bandwidth ratio.
The bandwidth recovery ratio must be smaller than or equal to the bandwidth ratio of an LB link.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Set the total bandwidth ratio and bandwidth recovery ratio for the LB link lk1 to 90 and 85.
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
max-bandwidth (link view)
Use bandwidth interface statistics enable to enable bandwidth statistics collection by interfaces.
Use undo bandwidth interface statistics enable to disable bandwidth statistics collection by interfaces.
Bandwidth statistics collection by interfaces is disabled.
Virtual server view
context-admin
vsys-admin
# Enable bandwidth statistics collection by interfaces for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] bandwidth interface statistics enable
bandwidth weight
Use bandwidth weight to set the bandwidth weight for proximity calculation.
Use undo bandwidth weight to restore the default.
bandwidth { inbound | outbound } weight bandwidth-weight
undo bandwidth { inbound | outbound } weight
The inbound or outbound bandwidth weight for proximity calculation is 100.
Proximity view
context-admin
inbound: Specifies the inbound bandwidth weight.
outbound: Specifies the outbound bandwidth weight.
bandwidth-weight: Specifies the bandwidth weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher bandwidth weight.
# Set the inbound bandwidth weight for proximity calculation to 200.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] bandwidth inbound weight 200
# Set the outbound bandwidth weight for proximity calculation to 200.
[Sysname-lb-proximity] bandwidth outbound weight 200
busy-action
Use busy-action to configure the action to take when a server farm is busy.
Use undo busy-action to restore the default.
busy-action { drop | enqueue length length timeout timeout-value | force }
undo busy-action
The default action is drop.
Server farm view
context-admin
vsys-admin
drop: Stops assigning client requests to the server farm.
enqueue: Assigns new client requests to a wait queue.
length length: Specifies the maximum number of client requests allowed in the wait queue, in the range of 1 to 100000. When the queue is full, new client requests are dropped.
timeout timeout-value: Specifies the aging time for the wait queue, in the range of 1 to 60 seconds.
force: Forcibly assigns client requests to all real servers in the server farm.
For the drop action, if the LB policy for the server farm contains the action of matching the next rule, the device compares client requests with the next rule. Otherwise, the device drops the client requests.
# Configure the action to take when a server farm is busy as force.
[Sysname-sfarm-sf] busy-action force
busy-action continue
Use busy-action continue to configure the action of matching the next rule when all links or DNS servers are busy.
undo busy-action
The device assigns packets to links or DNS servers regardless of whether they are busy.
Link-generic LB action view
DNS server LB action view
context-admin
This command enables the device to match the next rule when all links or DNS servers are busy.
# Configure link-generic LB action a1 to match the next rule when all links or DNS servers are busy.
[Sysname] loadbalance action a1 type link-generic
[Sysname-lba-link-generic-a1] busy-action continue
case-insensitive
Use case-insensitive to disable case sensitivity for matching character strings.
Use undo case-insensitive to restore the default.
case-insensitive
Case sensitivity is enabled for matching character strings.
HTTP parameter profile view
context-admin
vsys-admin
This command affects the following content:
· HTTP header value, HTTP cookie name and value, and URL for matching classes.
· Header value, URL, and key value used for generating sticky entries for the HTTP header sticky method.
· Cookie name and value and key value used for generating sticky entries for the cookie get sticky method.
# Disable case sensitivity for the HTTP-type parameter profile pp1.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] case-insensitive
check all-packet
Use check all-packet to enable checking for all packets.
Use undo check all-packet to restore the default.
check all-packet
Checking for all packets is disabled.
HTTP cookie sticky group view
context-admin
vsys-admin
If the sticky method is cookie get, use this command to get cookies from all HTTP response packets. If this command is not executed, the device gets only the Set-Cookie from the first response packet of a connection.
If the sticky method is cookie rewrite, use this command to rewrite cookies in all HTTP response packets. If this command is not executed, the device rewrites only the Set-Cookie in the first response packet of a connection.
If the sticky method is cookie insert, use this command to insert cookies to all HTTP response packets. If this command is not executed, the device inserts only the Set-Cookie to the first response packet of a connection.
If the sticky method is HTTP passive, use this command to generate sticky entries from all HTTP response packets. If this command is not executed, the device generates sticky entries only from the first response packet of a connection.
# Enable checking for all packets in the HTTP cookie sticky group sg3.
[Sysname] sticky-group sg3 type http-cookie
[Sysname-sticky-http-cookie-sg3] check all-packet
check-url
Use check-url to configure a URL regular expression to match URLs for an HTTP passive LB probe template.
Use undo check-url to remove the URL regular expression configuration.
check-url url
undo check-url url
No URL regular expression is configured.
context-admin
vsys-admin
url: Specifies a URL regular expression, a case-insensitive string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP request carries one of the specified URLs, the device examines whether a URL error occurs in the HTTP response.
You can configure a maximum of 10 URL regular expressions for one HTTP passive LB probe template.
# Configure www.abc.com as a matching URL for HTTP passive LB probe template tplt.
[Sysname-lbpt-http-passive-tplt] check-url www.abc.com
class
Use class to specify an LB action for the specified LB class.
Use undo class to delete an LB class.
class class-name [ insert-before before-class-name | insert-after [ after-class-name ] ] action action-name
undo class class-name
No LB action is specified for the LB class.
LB policy view
context-admin
vsys-admin
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters.
insert-before: Inserts the target class before an LB class (which must already be referenced by the current LB policy).
before-class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters.
insert-after: Inserts the target class after an LB class (which must already be referenced by the current LB policy).
after-class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument for the insert-after keyword, the target class is inserted before all LB classes.
action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters.
This command sets an LB action for packets matching the specified LB class.
If you do not specify the insert-before or insert-after keyword, this command inserts the target class after all LB classes.
You can specify an LB action for different LB classes.
A DNS LB policy can reference DNS LB actions only; a generic LB policy can reference generic LB classes and generic LB actions only. This rule does not apply to HTTP LB policies.
# Specify the LB action lba1 for the LB class lbc1 in the generic LB policy lbp1, and insert lbc1 before the LB class lbc0.
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1] class lbc1 insert-before lbc0 action lba1
compression level
Use compression level to set the compression level for response packets.
Use undo compression level to restore the default.
compression level level
The compression level for response packets is 1.
HTTP-compression parameter profile view
context-admin
vsys-admin
level: Specifies the compression level in the range of 1 to 9. A larger value indicates a lower compression speed and a higher compression ratio.
# Create the HTTP-compression parameter profile pa1, and set the compression level to 6.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] compression level 6
Use connection-limit max to set the maximum number of connections of a link group member.
Use undo connection-limit max to restore the default.
connection-limit max max-number
The maximum number of connections of a link is 0, which means the number is not limited.
Link group member view
context-admin
max-number: Specifies the maximum number of connections, in the range of 0 to 4294967295. If the value of this argument takes 0, the number is not limited.
# Set the maximum number of connections of the link group member lk1 to 10000.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a link.
Link view
context-admin
# Set the maximum number of connections of the link lk to 10000.
[Sysname-lb-link-lk] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a real server.
The maximum number of connections of a real server is 0, which means the number is not limited.
Real server view
context-admin
vsys-admin
# Set the maximum number of connections of the real server rs to 10000.
[Sysname] real-server rs
[Sysname-rserver-rs] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a server farm member.
Server farm member view
context-admin
vsys-admin
# Set the maximum number of connections of the server farm member rs1 to 10000.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname -sfarm-sf-#member#-rs1-port-80] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a virtual server.
The maximum number of connections of a virtual server is 0, which means the number is not limited.
Virtual server view
context-admin
vsys-admin
# Set the maximum number of connections for the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] connection-limit max 10000
Use connection-sync enable to enable session extension information synchronization for a transparent DNS proxy.
Use undo connection-sync enable to disable session extension information synchronization for a transparent DNS proxy.
Session extension information synchronization is disabled for a transparent DNS proxy.
context-admin
This command can back up session information to ensure service continuity during a master and backup switchover in hot backup mode.
# Enable session extension information synchronization for the transparent DNS proxy dns_proxy1.
<Sysname>system-view
[Sysname-lb-dp-udp-dns-proxy1] connection-sync enable
Use connection-sync enable to enable session extension information synchronization for a virtual server.
Use undo connection-sync enable to disable session extension information synchronization for a virtual server.
Session extension information synchronization is disabled for a virtual server.
Virtual server view
context-admin
vsys-admin
This command is not supported by the virtual servers of the HTTP type.
# Enable session extension information synchronization for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] connection-sync enable
Use content to configure the HTTP entity sticky method.
Use undo content to delete the HTTP entity sticky method.
content [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo content
No sticky methods exist.
HTTP entity sticky group view
context-admin
vsys-admin
offset offset: Specifies the offset value of the entity based on the start of the HTTP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the entity, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the entity, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the entity, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Use this command to obtain the HTTP entity information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
The HTTP entity sticky method applies only to contents within the entity. The HTTP entity sticky method does not apply to chunk and multipart entity content.
# Configure the HTTP entity sticky method for the HTTP entity sticky group sg2: Starting from the 30th byte of start of the HTTP packet, use the 20-byte HTTP entity with abc as the start string to generate sticky entries.
[Sysname] sticky-group sg2 type http-content
[Sysname-sticky-http-content-sg2] content offset 30 start abc length 20
Use content to configure the HTTP passive entity sticky method.
Use undo content to delete the HTTP passive entity sticky method.
content { get | match } id start start-string { end end-string | length length }
undo content { get | match } id
context-admin
vsys-admin
get: Obtains the specified string in the HTTP response entity, which is used to generate a sticky entry.
match: Obtains the specified string in the HTTP request entity, which is used to match a sticky entry.
id: Specifies the string ID in the range of 1 to 4.
start start-string: Specifies the regular expression that marks the start of the entity, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
Both the content get and content match commands are required for an HTTP passive sticky method.
The device obtains the content information of an incoming HTTP request based on the content match command and obtains the content information of an incoming HTTP response based on the content get command. If the content information of the HTTP request matches the content information of the HTTP response, the device generates a sticky entry based on the content information of the HTTP response. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
The following rules apply to use of the content match and content get commands:
· You can execute a maximum of four content get commands and four content match commands for one HTTP passive sticky method.
· A number of n strings that are obtained based on n content get commands generates 2n-1 strings in ascending order of string IDs. If the string obtained based on the content match command matches any one of these generated strings, the match is successful.
· A number of n strings that are obtained based on n content match commands combine as one string in ascending order of string IDs.
For example, three content get commands are executed with string IDs 1, 2, and 3. The device obtains three strings a, b, and c in the HTTP response header, generates seven strings a, b, c, ab, ac, bc, and abc, and generates seven sticky entries. Then, three content match commands are executed with string IDs 2, 3, and 4. The device obtains three strings a, b, and c in the HTTP request header and generates one string abc. If the string matches one of the seven strings, the device generates a sticky entry based on the string abc. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
# Configure the HTTP passive sticky method for the HTTP passive sticky group sg2: Obtain the 20-byte HTTP entity string starting with abc in the HTTP response. If the string matches the 20-byte HTTP entity string starting with xxx in the HTTP request, the device generates a sticky entry based on the string obtained from the HTTP response.
[Sysname] sticky-group sg2 type http-passive
[Sysname-sticky-http-passive-sg2] content get 1 start abc length 20
[Sysname-sticky-http-passive-sg2] content match 1 start xxx length 20
display sticky-group
content length-threshold
Use content length-threshold to set the minimum length of HTTP response content for compression.
Use undo content length-threshold to restore the default.
content length-threshold length
The minimum length of HTTP response content for compression is 1024 bytes.
context-admin
vsys-admin
length: Specifies the minimum length of HTTP response content for compression, in the range of 0 to 4294967295 bytes.
If an HTTP response packet contains the Content-Length header, the packet content is compressed only when its length reaches the minimum length of HTTP response content for compression. If the HTTP response packet does not contain the Content-Length header, the configuration does not take effect. The packet content is compressed regardless of its length.
# Create the HTTP-compression parameter profile http1, and set the minimum length of HTTP response content for compression to 2000 bytes.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] content length-threshold 2000
content maxparse-length
Use content maxparse-length to set the maximum length of HTTP entities that can be parsed.
Use undo content maxparse-length to restore the default.
content maxparse-length length
The maximum length of HTTP entities that can be parsed is 4096.
context-admin
vsys-admin
length: Specifies the maximum length of HTTP entities that can be parsed, in the range of 1 to 65535 bytes.
# Set the maximum length of HTTP entities that can be parsed to 8192 for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] content maxparse-length 8192
content request-max-length
Use content request-max-length to set the maximum size of the HTTP content.
Use undo content request-max-length to restore the default.
content request-max-length length
The size of the HTTP content is not limited.
context-admin
vsys-admin
length: Specifies the maximum size of the HTTP content, in the range of 1 to 4294967295 bytes.
If the size of the HTTP content in an HTTP request exceeds the specified maximum size, the device discards the HTTP request.
# Set the maximum size of the HTTP content to 1000 for the HTTP parameter profile h1.
[Sysname] parameter h1 type http
[Sysname-para-http-h1] content request-max-length 1000
content rewrite
Use content rewrite to rewrite the content of HTTP responses.
Use undo content rewrite to restore the default.
content rewrite value value replace replace-string
The content of HTTP responses is not rewritten.
HTTP LB action view
context-admin
vsys-admin
value value: Specifies the HTTP packet content to be rewritten, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace-string: Specifies the content after rewrite, a case-sensitive string of 1 to 127 characters.
This command applies only to the HTTP response packets in the format of text/*.
The rewrite operation is not performed in either of the following situations:
· A regular expression is used to match the content before rewrite, and the content before rewrite exceeds 4096 bytes in size.
· The content after rewrite exceeds 4096 bytes in size.
If you specify the replace-string argument as %[1-9], the matching packet content value will be replaced by the content in the corresponding pair of brackets. For example, if you execute the content rewrite value (Wel)(co)(me) replace %2 command, the content Welcome will be replaced by the content co in the second pair of brackets.
If you execute the content rewrite command multiple times, the most recent configuration takes effect.
# Create the HTTP LB action named replace, and replace the content 2000::1 in HTTP response packets with 2.3.4.5.
[Sysname] loadbalance action replace type http
[Sysname-lba-http-replace] content rewrite value 2000::1 replace 2.3.4.5
cookie (protection rule view)
Use cookie to configure a cookie-based protection threshold.
Use undo cookie to restore the default.
cookie cookie-name request-threshold threshold
undo cookie
No cookie-based protection threshold is configured.
Protection rule view
context-admin
vsys-admin
cookie-name: Specifies an HTTP cookie by its name, a case-sensitive string of 1 to 63 characters. The cookie name cannot contain brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). Additionally, the cookie name cannot contain ASCII codes that are less than or equal to 31 and greater than or equal to 127.
request-threshold threshold: Specifies a request threshold in the range of 1 to 4294967295.
If the number of times that a user accesses a protected URL exceeds the request threshold during the protection period, the protection action is taken. The device determines whether requests belong to the same user based on the following elements:
· Cookie—Requests with the same cookie value for the cookie specified in this command belong to the same user.
· Source IP address—Requests with the same source IP address belong to the same user.
If you configure both a cookie-based request threshold and a source-IP-based request threshold, the protection action is taken when either threshold is exceeded.
# In protection rule 5, configure the cookie name as jsessionid and the request threshold as 2.
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] cookie jsessionid request-threshold 2
protected-url
protection-action
protection-period
source-ip
cookie (sticky group view)
Use cookie to configure the HTTP cookie sticky method.
cookie { get name cookie-name [ offset offset ] [ start start-string] [ end end-string | length length ] | { insert [ domain domain-name ] [ path path ] [ httponly ] [ secure ] | rewrite } [ name cookie-name ] [ httponly ] [ secure ] }
undo cookie { get | insert | rewrite }
No HTTP cookie sticky methods exist.
context-admin
vsys-admin
get: Specifies the cookie get sticky method that gets the Set-Cookie field in the HTTP response packets sent by the server.
offset offset: Specifies the offset value based on the start of the cookie value, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the cookie, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the cookie, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the cookie, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
insert: Specifies the cookie insert sticky method that inserts the Set-Cookie field to the HTTP response packets sent by the server.
rewrite: Specifies the cookie rewrite sticky method that rewrites the Set-Cookie field in the HTTP response packets sent by the server.
name cookie-name: Specifies an HTTP cookie by its name, a case-sensitive string of 1 to 63 characters. The default name is X-LB.
domain domain-name: Specifies a domain name indicating the hosts to which the cookie will be sent, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the cookie will be sent to only the host where it is created.
path path: Specifies a path indicating the paths to which the cookie will be sent, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the cookie will be sent to every path (the root directory / applies).
httponly: Specifies that the cookie cannot be accessed by scripts. If you do not specify this keyword, the cookie can be accessed by scripts.
secure: Specifies that the cookie can be transmitted over only HTTPS connections. If you do not specify this keyword, the cookie can be transmitted over any connections.
Use the cookie get command to obtain the HTTP cookie information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
If the sticky method is cookie rewrite, the Set-Cookie field of the specified cookie must be available in the HTTP response packets sent by the server. The system modifies only the cookie name and value in the Set-Cookie field without modifying other attributes such as Expires.
If the sticky method is cookie insert or cookie rewrite and the timeout timer for sticky entries is 0, the system adds the Expires field after the inserted or rewritten value. If the HTTP response packets sent by the server carry this attribute, the load balancing module does not modify the attribute. Instead, it adds the user-configured Expires information after the value. As a best practice, do not carry any timeout attribute in the Set-Cookie header on the server when you configure the cookie rewrite sticky method.
The domain domain-name option specifies the hosts to which the cookie will be sent. Suppose a client can visit hosts example.com, www.example.com, and www.corp.example.com. If you specify example.com for the domain domain-name option, the client includes the cookie when sending HTTP requests to any one of the three hosts. If you specify www.corp.example.com for the domain domain-name option, the client includes the cookie only when sending HTTP requests to www.corp.example.com.
The path path option limits the scope of the cookie to a set of paths. Suppose a client can visit folders www.example.com/a and www.example.com/b. If you specify www.example.com for the domain domain-name option and /a for the path path option, the client includes the cookie only when sending HTTP requests to www.example.com/a.
The httponly option prevents attackers from obtaining cookie information by using scripts.
The secure option makes sure the cookie is transmitted over an HTTPS connection. For an HTTP connection, the cookie is not transmitted.
# Configure the cookie get sticky method for the HTTP cookie sticky group sg3: Starting from the 10th byte of start of the HTTP packet, use the 32-byte HTTP cookie named user to generate sticky entries.
[Sysname-sticky-http-cookie-sg3] cookie get name user offset 10 length 32
# Configure the cookie insert sticky method for the HTTP cookie sticky group sg3.
[Sysname-sticky-http-cookie-sg3] cookie insert
cookie secondary name
Use cookie secondary name to specify the name of the secondary cookie to be searched in the URI.
Use undo cookie secondary name to restore the default.
cookie secondary name value
The name of the secondary cookie to be searched in the URI is not specified.
context-admin
vsys-admin
value: Specifies the name of the secondary cookie, a case-sensitive token string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
This command applies only to the cookie get sticky method. Executing this command enables the system to locate the secondary cookie in the URI when it fails to locate the specified cookie in the HTTP request packet header.
# Specify the name of the secondary cookie to be searched in the URI as sid for the HTTP cookie sticky group sg3.
[Sysname-sticky-http-cookie-sg3] cookie secondary name sid
cost
Use cost to set the link cost for proximity calculation.
Use undo cost to restore the default.
cost cost-value
The link cost for proximity calculation is 0.
Link view
context-admin
cost-value: Specifies the link cost for proximity calculation, in the range of 0 to 10240.
# Set the link cost for proximity calculation to 200 for the link lk1.
[Sysname-lb-link-lk1] cost 200
cost weight
Use cost weight to set the cost weight for proximity calculation.
Use undo cost weight to restore the default.
cost weight cost-weight
The cost weight for proximity calculation is 100.
Proximity view
context-admin
cost-weight: Specifies the cost weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher cost weight.
# Set the cost weight for proximity calculation to 200.
[Sysname-lb-proximity] cost weight 200
customlog content
Use customlog content to configure the content to be output by using the fast log output feature.
Use undo customlog content to restore the default.
customlog content content-value
No content is output by using the fast log output feature.
HTTP virtual server view
context-admin
vsys-admin
content-value: Specifies the log content to be output, a case-sensitive string of 1 to 255 characters. To enter multiple variables, separate them by semicolons. The device supports the following variables:
· %{is}—Source IP address in HTTP requests.
· %{ps}—Source port number in HTTP requests.
· %{id}—Destination IP address in HTTP requests.
· %{pd}—Destination port number in HTTP requests.
· %{sis}—Source IP address in HTTP responses.
· %{sps}—Source port number in HTTP responses.
· %{sid}—Destination IP address in HTTP responses.
· %{spd}—Destination port number in HTTP responses.
· %{vsn}—Virtual server name.
· %{sfn}—Server farm name.
· %{reqtmstamp}—HTTP request timestamp.
· %{uri}—HTTP URI.
· %{ver}—HTTP version number.
· %{args}—HTTP access parameters.
· %{method}—HTTP request method.
· %{xff}—IP address of XFF (X-Forwarded-For).
· %{ctype}—Content-Type field in HTTP requests.
· %{clen}—Content-Length field in HTTP requests.
· %{ref}—Referer header field in HTTP requests.
· %{ua}—User-Agent header field in HTTP requests.
· %{host}—Host header field in HTTP requests.
· %{path}—Path in HTTP requests.
· %{reqsz}—HTTP request size in bytes.
· %{reqtm}—HTTP request duration in milliseconds. The duration is from time when the device receives an HTTP request to the time when the device receives the HTTP response.
· %{rspclen}—Content-Type field in HTTP responses.
· %{reqsz}—HTTP response size in bytes.
· %{rsptm}—HTTP response duration in milliseconds. The duration is from the time when the device receives an HTTP response to the time when the device finishes sending out the HTTP response.
· %{stscode}—HTTP response status code.
· %{reqbsz}—Body size of HTTP requests, in bytes.
· %{rspbsz}—Body size of HTTP responses received by the device from the server, in bytes.
· %{rspsntbsz}—Body size of HTTP responses sent from the device to the client, in bytes.
· %{cookie_cookie-name—HTTP cookie. The cookie name cannot contain brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). Additionally, the cookie name cannot contain ASCII codes that are less than or equal to 31 and greater than or equal to 127. You can specify multiple cookies.
After you execute this command, the device sends the specified content to the log host by using the fast log output feature.
Before executing this command, you must enable fast log output for load balancing and configure fast log output parameters.
# For HTTP virtual server vs, output the source IP address and source port number in HTTP requests by using the fast log output feature.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] customlog content %{is};%{ps}
customlog format (Network Management and Monitoring Command Reference)
customlog host (Network Management and Monitoring Command Reference)
default dns-server-pool
Use default dns-server-pool to specify the default (primary) DNS server pool for a transparent DNS proxy.
Use undo default dns-server-pool to restore the default.
default dns-server-pool pool-name [ sticky sticky-name ]
No default DNS server pool is specified for a transparent DNS proxy.
context-admin
pool-name: Specifies a primary DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a sticky group, the DNS server pool does not correspond to any sticky group.
If you execute the default dns-server-pool command multiple times, the most recent configuration takes effect.
# Specify the primary DNS server pool dns-pool1 and the sticky group st1 for the transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] default dns-server-pool dns-pool1 sticky st1
default link-group
Use default link-group to specify the default (primary) link group.
Use undo default link-group to restore the default.
default link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
No default link group is specified.
Link-IP virtual server view
context-admin
link-group-name: Specifies a primary link group by its name, a case-insensitive string of 1 to 63 characters.
backup backup-link-group-name: Specifies a backup link group by its name, a case-insensitive string of 1 to 63 characters.
When the primary link group is available (contains links), the virtual server forwards packets through the primary link group. When the primary link group is not available, the virtual server forwards packets through the backup link group.
# Specify the primary link group link1, the backup link group link2, and the sticky group sg1 for the link-IP-type virtual server vs3.
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] default link-group link1 backup link2 sticky sg1
default server-farm
Use default server-farm to specify the default (primary) server farm.
Use undo default server-farm to restore the default.
default server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name [ backup backup-sticky-name ] ]
No default server farm is specified.
UDP virtual server view
context-admin
vsys-admin
server-farm-name: Specifies a primary server farm by its name, a case-insensitive string of 1 to 63 characters.
backup backup-server-farm-name: Specifies a backup server farm by its name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies a primary sticky group by its name, a case-insensitive string of 1 to 63 characters.
backup backup-sticky-name: Specifies a backup sticky group by its name, a case-insensitive string of 1 to 63 characters. This option is supported only by HTTP virtual servers and RADIUS virtual servers.
When the primary server farm is available (contains real servers), the virtual server forwards packets through the primary server farm. When the primary server farm is not available, the virtual server forwards packets through the backup server farm.
If you specify both a primary sticky group and a backup sticky group, the device generates both primary sticky entries and backup sticky entries. If packets do not match primary sticky entries, backup sticky entries will apply.
The device generates backup sticky entries for only the following sticky group combinations:
· RADIUS-type primary sticky group and port-address-type backup sticky group.
· HTTP cookie-type primary sticky group and port-address-type backup sticky group.
· HTTP cookie-type primary sticky group and HTTP passive-type backup sticky group.
# Specify the primary server farm sf, the backup server farm sfb, and the sticky group sg1 for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] default server-farm sf backup sfb sticky sg1
default-class action
Use default-class action to specify the default LB action.
Use undo default-class to restore the default.
default-class action action-name
undo default-class
No default LB action is specified.
LB policy view
context-admin
vsys-admin
This command sets the default LB action for packets that fail to match any LB class.
A DNS LB policy can reference DNS LB actions only; a generic LB policy can reference generic LB actions only. This rule does not apply to HTTP LB policies.
# Specify the default LB action lba1 for the generic LB policy lbp1.
[Sysname-lbp-generic-lbp1] default-class action lba1
description
Use description to configure a description.
No description is configured.
ISP view
LB action view
LB class view
LB policy view
LB connection limit policy view
Parameter profile view
Protection policy view
Real server view
Server farm view
Sticky group view
Virtual server view
Link group view
Link view
DNS server view
Statistics node view
context-admin
vsys-admin
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description LB action LBA1 for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] description LB action LBA1
destination-ip object-group
Use destination-ip object-group to specify a destination IP address object group for address translation.
Use undo destination-ip object-group to restore the default.
destination-ip object-group object-group-name
All packets are translated.
context-admin
vsys-admin
object-group-name: Specifies a destination IP address object group by its name, a case-insensitive string of 1 to 63 characters.
If you specify a destination IP address object group, the device performs SNAT on only packets with a matching destination IP address. For information about configuring an IP address object group, see object group configuration in Security Configuration Guide.
# Specify destination IP address object group obj1 for SNAT global policy sn1.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] destination-ip object-group obj1
object-group (Security Command Reference)
display loadbalance action
Use display loadbalance action to display LB action information.
display loadbalance action [ name action-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB actions.
# Display information about all LB actions.
<Sysname> display loadbalance action
LB action: lba1
Description:
Type: Generic
State: Inactive
Forward type: Drop
IP ToS:
Fallback-action: Disabled
Busy-action: Force
TCP payload rewrite:
Value: QMGR.S01
Replacement: QMGR.S01%[variable]
Direction: Request
Value: QMGR.S01_1
Replacement: QMGR.S01_2
Direction: Response
Value: QMGR.S02_2
Direction: Response
LB action: lba2
Description:
Type: HTTP
State: Active
Forward type: Server farm
Server farm: sf (in use)
Backup server farm: sfb
Sticky: sg3
Backup sticky: sg4
IP ToS: 20
SSL client policy:
Content rewrite:
Value:
Replacement:
Redirect relocation:
Redirect return-code: 302
Header delete:
Direction: Request
Header insert:
Value: 1234567890123456789012345678901234567890123456789012345678901234567890
Direction: Both
Header insert:
Value: dd
Direction: Request
Header rewrite:
Value: dd
Replacement: ff
Direction: Response
SSL URL rewrite:
Value: 12
Clear port: 12
SSL port: 123
LB action: lba3
Description: sina
Type: Link-generic
State: Active
Forward type: link group
Link group: lg1 (in use)
Backup link group: lg2
Sticky:
IP ToS:
Fallback-action: None
LB action: lba4
Description: xx
Type: DNS
State: Active
Forward type: DNS server pool
DNS server pool: dsp1
Sticky: st
IP ToS:
Busy-action: Force
LB action: lba5
Description:
Type: HTTP
State: Active
Forward type: Redirect
IP ToS:
Fallback-action: Continue
SSL client policy:
Content rewrite:
Value:
Replacement:
Redirect relocation: www.h3c.com
LB action: lba6
Description:
Type: HTTP
State: Active
Forward type: Response
IP ToS:
Fallback-action: Response
Raw file name: 301.raw
SSL client policy:
Content rewrite:
Value:
Replacement:
Response file:
File: index.html
URL: /index/css
Response file:
File name: subsys_intf.js
URL: /index/subsys
Response file:
File name: subsys.js
URL: /subsys.js
Response zip file:
Zip file name: subsys.zip
Working path: /
LB action |
LB action name. |
Description for the LB action. |
Type |
LB action type: · DNS. · Generic. · HTTP. · Link-generic. · RADIUS. |
State |
LB action state: · Active. · Inactive. |
Forward type |
Packet forwarding mode of the LB action: · Drop—Discards packets. · Drop(FIN-close)—Closes TCP connections by sending FIN packets (applicable to generic and HTTP LB actions). · Drop(RST-close)—Closes TCP connections by sending RST packets (applicable to generic and HTTP LB actions). · Forward—Forwards packets. · Server farm—Forwards packets through the server farm (applicable to generic, HTTP, and RADIUS LB actions). · Link group—Forwards packets through the link group (applicable to link-generic LB actions). · DNS server pool—Forwards packets through the DNS server pool (applicable to DNS LB actions). · Skip current DNS proxy (applicable to DNS LB actions). · Redirect—Redirects packets. · Response—Responds to client requests by using a file. |
Server farm |
Primary server farm name. (in use) indicates the server farm is in use. This field is displayed only when the packet forwarding mode is server farm. |
Backup server farm |
Backup server farm name. (in use) indicates the server farm is in use. This field is displayed only when the packet forwarding mode is server farm. |
Link group |
Default link group name. (in use) indicates the link group is in use. |
Backup link group |
Backup link group name. (in use) indicates the link group is in use. |
Sticky |
Primary sticky group name. This field is displayed only when the packet forwarding mode is server farm or DNS server pool. |
Backup sticky |
Backup sticky group name. This field is displayed only when the packet forwarding mode is server farm and the LB action type is HTTP or RADIUS. |
IP ToS |
ToS field value of IP packets. |
Fallback-action |
Action taken upon load balancing failure: · None—Does not take any action. · Continue—Matches the next rule. · Response—Responds to client requests by using a file. · Drop(FIN-close)—Closes TCP connections by sending FIN packets (applicable to generic and HTTP LB actions). · Drop(RST-close)—Closes TCP connections by sending RST packets (applicable to generic and HTTP LB actions). |
Busy-action |
Action taken upon busyness: · Continue—Matches the next rule. · Force—Assigns packets to links or DNS servers regardless of whether they are busy. |
SSL client policy |
SSL client policy name. This field is displayed for HTTP LB actions only. |
Content rewrite |
HTTP content rewrite configuration: · Value—Specifies the HTTP packet content to be rewritten. · Replacement—Specifies the content after rewrite. This field is displayed only for an HTTP-type LB action. |
Redirect relocation |
Redirection URL. This field is displayed only for HTTP-type LB actions. |
Redirect return-code |
Status code in the redirection packets. This field is displayed only for HTTP-type LB actions. |
Header delete |
Deletes the HTTP header. · Name—Name of the HTTP packet header. · Direction—Specifies HTTP requests, HTTP responses, or both. This field is displayed only when the header delete command is configured. |
Header insert |
Inserts the HTTP header. · Name—Name of the HTTP packet header. · Value—Content of the HTTP packet header. · Direction—Specifies HTTP requests, HTTP responses, or both. This field is displayed only when the header insert command is configured. |
Header rewrite |
Rewrites the HTTP header. · Name—Name of the HTTP packet header. · Value—Content of the HTTP packet header to be rewritten. · Replacement—Content after rewrite. · Direction—Specifies HTTP requests, HTTP responses, or both. This field is displayed only when the header rewrite command is configured. |
SSL URL rewrite |
Rewrites the URL in the Location header of HTTP response packets sent by the server. · Value—Regular expression for the location header URL. · Clear port—HTTP port number to be rewritten. · SSL port—SSL port number after rewrite. This field is displayed only when the ssl url rewrite command is configured. |
DNS server pool |
DNS server pool name. This field is displayed only when the packet forwarding mode is DNS server pool. |
Response file |
Responds to client requests by using an uncompressed file. |
File name |
Name of the uncompressed file. |
URL |
URL path used to match client requests. |
Response zip file |
Responds to client requests by using a compressed file. |
Zip file name |
Name of the compressed file. |
Working path |
Working path used to match client requests. |
Raw file name |
Response file used upon load balancing failure. |
TCP payload rewrite |
Rewrite the TCP payload: · Value—Content of the TCP packet header to be rewritten. · Replacement—Content after rewrite. · Direction—Specifies TCP requests, TCP responses, or both. This field is displayed only when the payload rewrite command is configured. |
display loadbalance alg
Use display loadbalance alg to display the ALG status for all protocols.
context-admin
context-operator
vsys-admin
vsys-operator
# Display the ALG status for all protocols.
<Sysname> display loadbalance alg
LB ALG:
DNS : Enable
FTP : Enable
H323 : Disabled
ICMP-ERROR : Enable
ILS : Disabled
MGCP : Disabled
NBT : Disabled
PPTP : Enable
RSH : Disabled
RTSP : Enable
SCCP : Disabled
SIP : Disabled
SQLNET : Disabled
TFTP : Disabled
XDMCP : Disabled
display loadbalance class
Use display loadbalance class to display LB class information.
display loadbalance class [ name class-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB classes.
# Display information about all LB classes.
<Sysname> display loadbalance class
LB class: lbc1
Description:
Type: HTTP
Match type: Match-all
Match rule:
match 1 source ip address 1.2.3.0 24
match 2 source ipv6 address 1::2
match 3 cookie abc value 123
match 4 header def value 12
match 5 method ext xde
match 6 method rfc CONNECT
match 7 class cla2
match 8 url 2q3
match 9 acl ipv4 number 2000
match 10 acl ipv6 number 2001
match 11 acl ipv4 name aaa
match 12 acl ipv6 name bbb
match 13 isp name isp1
LB class: lbc2
Description:
Type: Generic
Match type: Match-any
Match rule:
match 1 class cla2
match 2 source ip address 1.2.23.0 24
match 3 source ipv6 address 1::12
match 4 acl ipv4 number 3000
match 5 acl ipv6 number 3001
match 6 acl ipv4 name ccc
match 7 acl ipv6 name ddd
match 8 isp name isp2
match 9 payload orcl
LB class: lbc3
Description:
Type: Link-generic
Match rule:
match 1 class cla3
match 2 source ip address 1.2.3.0 24
match 4 acl ipv4 number 3002
match 5 acl ipv6 number 3003
match 9 user u1
match 10 user-group lb-group
match 11 interface GE1/0/1
LB class: lbc4
Description:
Type: DNS
Match rule:
match 1 class cla2
match 8 destination ip address 1.2.3.0 24
match 9 destination ipv6 address 1::12
match 10 domain-name www.h3c.com
LB class: lbc5
Description:
Type: MySQL
Match rule:
match 1 class cla2
match 8 sql select
LB class |
LB class name. |
Description for the LB class. |
Type |
LB class type: · DNS. · Generic. · HTTP. · Link-generic. · MySQL. · RADIUS. |
Match type |
Match type for the LB class: · Match-all—Requires matching all rules of the LB class. · Match-any—Requires matching any rule of the LB class. |
Match rule |
Match rules for the LB class. |
display loadbalance connections
Use display loadbalance connections to display information about Layer 7 LB TCP connections.
In standalone mode:
display loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ slot slot-number ] [ verbose ]
In IRF mode:
display loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ chassis chassis-number slot slot-number ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
client-side: Displays client-side connections.
server-side: Displays server-side connections.
ipv4: Specifies IPv4 connections.
ipv6: Specifies IPv6 connections.
cs-client-ip ip-address: Specifies a client by its IP address on the client side.
cs-client-port port-number: Specifies the port number of the client on the client side, in the range of 0 to 65535. 0 means any port number.
ss-client-ip ip-address: Specifies a client by its IP address on the server side.
ss-client-port port-number: Specifies the port number of the client on the server side, in the range of 0 to 65535. 0 means any port number.
cs-server-ip ip-address: Specifies a server by its IP address on the client side.
cs-server-port port-number: Specifies the port number of the server on the client side, in the range of 0 to 65535. 0 means any port number.
ss-server-ip ip-address: Specifies a server by its IP address on the server side.
ss-server-port port-number: Specifies the port number of the server on the server side, in the range of 0 to 65535. 0 means any port number.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about Layer 7 LB TCP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about Layer 7 LB TCP connections for all cards. (In IRF mode.)
state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait }: Specifies TCP connections by connection state. If you do not specify this parameter, the command displays information about TCP connections in each state.
verbose: Displays detailed information about TCP connections. If you do not specify this keyword, the command displays brief information.
If you do not specify any parameters, this command displays information about all Layer 7 LB TCP connections.
# Display brief information about all Layer 7 LB TCP connections.
<Sysname> display loadbalance connections
Client side: State Server side: State
192.168.56.1 <--> 8.8.8.8/80 ESTAB 192.168.56.1 <--> 2.2.2.2/80 ESTB
/50168 /1026
Any <-->Any CLOSED 192.168.56.1 <--> 2.2.2.2/80 TIMEWT
/1027
Total sessions: 3
# Display detailed information about all Layer 7 LB TCP connections.
<Sysname> display loadbalance connections verbose
Slot 1:
Client side Server side
Client address 12.12.12.12/3032 12.12.12.12/54649
Server address 4.4.44.4/80 5.5.5.5/80
State ESTABLISHED ESTABLISHED
VPN name -- --
Idle time 0 sec
Idle timeout 20 sec
Start time 2018-05-30 16:54:13
Client address 12.12.12.12/2996 Any
Server address 4.4.44.4/80 Any
State TIME_WAIT N/A
VPN name -- --
Idle time 1 sec
Idle timeout 20 sec
Start time 2018-05-30 16:54:12
Client address 12.12.12.12/3251 12.12.12.12/54341
VPN name -- --
Idle time 0 sec
Idle timeout 20 sec
Start time 2018-05-30 16:54:14
Total sessions: 3
State |
TCP connection state: · LISTEN. · SYNSNT—SYN_SENT. · SYNRCV—SYN_RECEIVED. · ESTB—ESTABLISHED. · FINWT1—FIN_WAIT_1. · FINWT2—FIN_WAIT_2. · CLOWAT—CLOSE_WAIT. · CLOSING. · LASACK—LAST_ACK. · TIMEWT—TIME_WAIT. · CLOSED. For more information about these states, see RFC 793. |
VPN name |
VPN instance name. |
Start time |
Time when the TCP connection was established. |
display loadbalance dns-cache
Use display loadbalance dns-cache to display DNS cache information.
In standalone mode:
display loadbalance dns-cache [ vpn-instance vpn-instance-name ] [ domain-name domain-name ] [ slot slot-number ]
In IRF mode:
display loadbalance dns-cache [ vpn-instance vpn-instance-name ] [ domain-name domain-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DNS cache information for the public network.
domain-name domain-name: Specifies a domain name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays DNS cache information for all domain names.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DNS cache information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DNS cache information for all cards. (In IRF mode.)
Non-default vSystems do not support this command.
DNS cache information records mappings between domain names and IP addresses.
# Display all DNS cache information.
<Sysname> display loadbalance dns-cache
Slot 1:
Domain name: www.aaa.com
Aging time: 20 min
IPv4 addresses: 6.3.5.2
4.5.6.3
192.169.41.8
IPv6 addresses: 4:4:4::7
Domain name: www.bbb.com
Aging time: 20 min
IPv4 addresses: 5.5.5.5
3.4.5.9
display loadbalance dns-listener
Use display loadbalance dns-listener to display DNS listener information.
display loadbalance dns-listener [ name listener-name ]
context-admin
context-operator
name listener-name: Specifies a DNS listener by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all DNS listeners.
This command can display the service state, IPv4 address, port number, and fallback method.
# Display information about the DNS listener listener1.
<Sysname> display loadbalance dns-listener name listener1
DNS listener name: listener1
Service state: Enabled
IPv4 address: 1.1.1.2
Port: 53
IPv6 address: --
IPv6 Port: 53
Fallback: Reject
VPN instance:
Service state |
DNS listener state: · Enabled. · Disabled. |
IPv4 address |
IPv4 address of the DNS listener. |
Port |
Port number of the DNS listener. |
IPv6 address |
IPv6 address of the DNS listener. |
IPv6 Port |
IPv6 port number of the DNS listener. |
Fallback |
Processing method when the DNS listener fails to find the server to respond to the DNS request: · dns-proxy—Responds to the DNS request through the DNS proxy. · No-response—Does not respond to the DNS request. · Reject—Sends a DNS reject packet. |
VPN instance |
VPN instance to which the DNS listener belongs. |
display loadbalance dns-listener statistics
Use display loadbalance dns-listener statistics to display DNS listener statistics.
In standalone mode:
display loadbalance dns-listener statistics [ name dns-listener-name ] [ slot slot-number ]
In IRF mode:
display loadbalance dns-listener statistics [ name dns-listener-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
name dns-listener-name: Specifies a DNS listener by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all DNS listeners.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DNS listener statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DNS listener statistics for all cards. (In IRF mode.)
# Display statistics for the DNS listener dl.
<Sysname> display loadbalance dns-listener statistics name dl
DNS listener: dl
Total:
Received requests: 100
Received valid requests: 70
Unresponded requests: 10
Rejected requests: 20
Proxy requests: 0
RCVR - Received requests, RVR - Received valid requests,
UR - Unresponded requests, RJTR - Rejected requests, PR - Proxy requests
Type RCVR RVR UR RJTR PR
A 50 50 0 0 0
AAAA 0 0 0 0 0
MX 10 5 5 0 0
NS 20 5 5 10 0
CNAME 10 5 0 5 0
SOA 10 5 0 5 0
PTR 0 0 0 0 0
TXT 10 5 0 5 0
SRV 0 0 0 0 0
Table 5 Command output
Proxy requests |
Number of responses to DNS requests through transparent DNS proxies. |
Type |
DNS request type: · A—IPv4 host address. · AAAA—IPv6 host address. · CNAME—Canonical name. · MX—Mail exchanger. · NS—Name server. · PTR—Pointer. · SOA—Start of authority. · SRV—Service. · TXT—Text. |
display loadbalance dns-map
Use display loadbalance dns-map to display DNS mapping information.
display loadbalance dns-map [ name dns-map-name ]
context-admin
context-operator
dns-map-name: Specifies a DNS mapping by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command displays information about all DNS mappings.
Use this command to view the service state, domain name, and virtual server pool for DNS mappings.
# Display information about the DNS mapping dm1.
<Sysname> display loadbalance dns-map name dm1
DNS mapping name: dm1
TTL: 3600s
Domain name list: www.h3c.domain.com
Virtual server pool: pool1
Table 6 Command output
Service state |
DNS mapping state: · Enabled. · Disabled. |
TTL |
TTL, in seconds, to cache DNS records for DNS responses. |
Domain name list |
Domain name of the DNS mapping. |
Virtual server pool |
Virtual server pool used by the DNS mapping. |
display loadbalance dns-map statistics
Use display loadbalance dns-map statistics to display DNS mapping statistics.
In standalone mode:
display loadbalance dns-map statistics [ name dns-map-name ] [ slot slot-number ]
In IRF mode:
display loadbalance dns-map statistics [ name dns-map-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
name dns-map-name: Specifies a DNS mapping by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all DNS mappings.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DNS mapping statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DNS mapping statistics for all cards. (In IRF mode.)
# Display statistics for the DNS mapping dm.
<Sysname> display loadbalance dns-map statistics name dm
DNS map: dm
Matched DNS requests: 100
Table 7 Command output
DNS map |
DNS mapping name. |
Matched DNS requests |
Number of DNS requests matching the DNS mapping. |
display loadbalance dns-proxy
Use display loadbalance dns-proxy to display transparent DNS proxy information.
display loadbalance dns-proxy [ brief | name dns-proxy-name ]
context-admin
context-operator
brief: Displays brief transparent DNS proxy information. If you do not specify this keyword, the command displays detailed transparent DNS proxy information.
name dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all transparent DNS proxies.
# Display brief information about all transparent DNS proxies.
<Sysname> display loadbalance dns-proxy brief
DNS proxy State Type VPN instance IP address Port
dns-proxy1 Active UDP 1.2.3.0/24 53
dns-proxy2 Inactive UDP -- 5353
# Display information about transparent DNS proxy dns-proxy1.
<Sysname> display loadbalance dns-proxy name dns-proxy1
DNS proxy: dns-proxy1
Type: UDP
State: Active
VPN instance:
IPv4 address: 1.2.3.0/24
IPv6 address: --
Port: 53
DNS server pool: dns-pool1
Sticky: st
LB policy: dns-policy1
Connection synchronization: Enabled
Sticky synchronization: Enabled
Bandwidth busy protection: Disabled
Table 8 Command output
DNS proxy |
Transparent DNS proxy name. |
Type |
Transparent DNS proxy type. Only UDP is supported. |
State |
Transparent DNS proxy state: · Active—The transparent DNS proxy is available. · Inactive—The transparent DNS proxy is unavailable for any reason except that the transparent DNS proxy feature is disabled. · Inactive (disabled)—The transparent DNS proxy is unavailable because the transparent DNS proxy feature is disabled. |
Service state |
Transparent DNS proxy state: Enabled or Disabled. |
VPN instance |
VPN instance to which the transparent DNS proxy belongs. |
DNS server pool |
Default DNS server pool used by the transparent DNS proxy. |
Sticky |
Sticky group used by the transparent DNS proxy. |
Connection synchronization |
Session extension information synchronization state: Enabled or Disabled. |
Sticky synchronization |
Sticky entry synchronization state: Enabled or Disabled. |
Bandwidth busy protection |
Link protection state: Enabled or Disabled. |
display loadbalance dns-proxy statistics
Use display loadbalance dns-proxy statistics to display transparent DNS proxy statistics.
In standalone mode:
display loadbalance dns-proxy statistics [ name dns-proxy-name ] [ slot slot-number ]
In IRF mode:
display loadbalance dns-proxy statistics [ name dns-proxy-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
name dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all transparent DNS proxies.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays transparent DNS proxy statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays transparent DNS proxy statistics for all cards. (In IRF mode.)
# Display statistics for the transparent DNS proxy dns-proxy1.
<Sysname> display loadbalance dns-proxy statistics name dns-proxy1
Dropped requests: 2
Received responses: 98
Dropped responses: 0
Table 9 Command output
DNS proxy |
Received requests |
Number of DNS requests received by the transparent DNS proxy. |
Dropped requests |
Number of DNS requests dropped by the transparent DNS proxy. |
Received responses |
Number of DNS responses received by the transparent DNS proxy. |
Dropped responses |
Number of DNS responses dropped by the transparent DNS proxy. |
display loadbalance dns-query
Use display loadbalance dns-query to display information about the domain names queried by external link proxy.
In standalone mode:
display loadbalance dns-query [ vpn-instance vpn-instance-name ] [ slot slot-number ]
In IRF mode:
display loadbalance dns-query [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name information for the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays domain name information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays domain name information for all cards. (In IRF mode.)
# Display information about the domain names queried by external link proxy.
<Sysname> display loadbalance dns-query
Slot 1:
VPN instance:
Domain name DNS server
www.a.com 1.2.3.4
www.b.com 2.2.3.4
Slot 2:
VPN instance:
www.c.com 3.2.3.4
www.d.com 4.2.3.4
Table 10 Command output
Domain name |
Domain name being queried. |
DNS server |
IP address of the DNS server. |
display loadbalance dns-server
Use display loadbalance dns-server to display DNS server information or DNS server pool member information.
display loadbalance dns-server [ brief | name dns-server-name ]
display loadbalance dns-server dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ]
context-admin
context-operator
brief: Displays brief DNS server information. If you do not specify this keyword, the command displays detailed DNS server information.
name dns-server-name: Displays detailed information about a DNS server. The dns-server-name argument specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters.
dns-server-pool dns-server-pool-name: Displays information about members of a DNS server pool. The dns-server-pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server dns-server-name port port-number: Displays information about a DNS server pool member. The dns-server-name argument specifies a DNS server pool member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the DNS server pool member, in the range of 0 to 65535. If you do not specify this option, the command displays information about all members of a DNS server pool.
If you do not specify any parameter, the command displays detailed information about all DNS servers.
If the device obtains multiple DNS server IP addresses, it uses the smallest available IP address.
If no health monitoring method is specified, the device determines that all obtained DNS server IP addresses are available. If a health monitoring method is specified, the device determines that only the DNS server IP addresses that pass health monitoring are available.
# Display brief information about all DNS servers.
<Sysname> display loadbalance dns-server brief
(*) – Auto-alloc address using
DNS server Address Port Link State DNS server pool
ds1 10.150.100.100(*) 0 link1 Active dns_pool
ds2 20.150.100.100 5353 link2 Probe-failed dns_pool
ds3 -- 0 link3 Inactive dns_pool
ds4 --(*) 0 link3 Inactive dns_pool
# Display detailed information about DNS server ds1.
<Sysname> display loadbalance dns-server name ds1
dns-server: ds1
Description:
State: Active
VPN instance: --
Auto-alloc address: Enabled
IPv4 address: 10.150.100.100(*)
10.160.100.1
10.154.60.2
IPv6 address: --
Port: 0 (port number in original packet)
Link: link1
Weight: 100
Priority: 4
Probe information:
Probe success criteria: All
Probe method State
t4 Succeeded
# Display information about all members of DNS server pool dsp1.
<Sysname> display loadbalance dns-server dns-server-pool dsp1
dns-server: ds1
Description: DNS server 1
Parent state: Inactive
State: Inactive
Weight: 2
Priority: 2
Probe method State
icmp Failed
dns-server: rs2
Description: DNS server 2
State: Inactive
Port: 53
Weight: 100
Priority: 4
Probe information:
Probe method State
DNS Failed
Table 11 Command output
DNS server |
DNS server name. |
Address |
IP address of the DNS server. The asterisk (*) indicates that the IP address is automatically obtained and is being used. If all obtained IP addresses are unavailable, this field displays --(*). If no IP address is obtained and no IP address is manually configured, this field displays two hyphens (--). |
Link |
Link of the DNS server. |
Parent state/State |
DNS server state/DNS server pool member state: · Active—The DNS server is available. · Busy—The DNS server is busy. When the DNS server is in Active state and enabled with the link protection feature, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The DNS server is unavailable, because the configuration is not complete or the server is not referenced. · Probe-failed—Health monitoring has failed. · Unknown—Health monitoring is not configured. |
Description for the DNS server. |
Auto-alloc address |
Whether the device is enabled to automatically obtain the IP address of a DNS server: Disabled or Enabled. |
IPv4 address |
IPv4 address of the DNS server. |
IPv6 address |
IPv6 address of the DNS server. |
Port |
Port number of the DNS server. 0 means the port number in the packet is used. |
Weight |
Weight of the DNS server. |
Priority |
Priority of the DNS server. |
Probe information |
Detailed health monitoring information for the DNS server. |
Probe success criteria |
Health monitoring success criteria for the DNS server: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Probe method |
Name of the NQA template used by the health monitoring method. |
State |
State of the health monitoring method: · Failed—Health monitoring has failed. · In progress—Health monitoring is in progress. · Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the DNS server is unavailable. · Succeeded—Health monitoring has succeeded. |
display loadbalance dns-server statistics
Use display loadbalance dns-server statistics to display DNS server statistics or DNS server pool member statistics.
In standalone mode:
display loadbalance dns-server statistics [ name dns-server-name ] [ slot slot-number ]
display loadbalance dns-server statistics dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ] [ slot slot-number ]
In IRF mode:
display loadbalance dns-server statistics [ name dns-server-name ] [ chassis chassis-number slot slot-number ]
display loadbalance dns-server statistics dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
name dns-server-name: Specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all DNS servers.
dns-server-pool dns-server-pool-name: Displays statistics for members of a DNS server pool. The dns-server-pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server dns-server-name port port-number: Displays statistics for a DNS server pool member. The dns-server-name argument specifies a DNS server pool member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the DNS server pool member, in the range of 0 to 65535. If you do not specify this option, the command displays statistics for all members of a DNS server pool.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DNS server statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DNS server statistics for all cards. (In IRF mode.)
# Display statistics for the DNS server ds1.
<Sysname> display loadbalance dns-server statistics name ds1
DNS server: ds1
Send requests: 98
Dropped requests: 2
Send responses: 98
# Display statistics for all members of DNS server pool dsp1.
<Sysname> display loadbalance dns-server statistics dns-server-pool dsp1
DNS server (port: 20): ds1
Dropped requests: 2
Sent responses: 98
DNS server (port: 28): ds2
Dropped requests: 0
Sent responses: 100
Table 12 Command output
DNS server |
DNS server name. |
Received requests |
Number of DNS requests received by the DNS server. |
Send requests |
Number of DNS requests sent by the DNS server. |
Dropped requests |
Number of DNS requests dropped by the DNS server. |
Number of DNS responses received by the DNS server. |
Send responses |
Number of DNS responses sent by the DNS server. |
Dropped responses |
Number of DNS responses dropped by the DNS server. |
display loadbalance dns-server-pool
Use display loadbalance dns-server-pool to display DNS server pool information.
display loadbalance dns-server-pool [ brief | name pool-name ]
context-admin
context-operator
brief: Displays brief DNS server pool information. If you do not specify this keyword, the command displays detailed DNS server pool information.
name pool-name: Displays detailed information about a DNS server pool. The pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameter, the command displays detailed information about all DNS server pools.
# Display brief information about all DNS server pools.
<Sysname> display loadbalance dns-server-pool brief
Predictor: RR - Round robin, RD - Random,
BW - Bandwidth, MBW - Max bandwidth,
IBW - Inbound bandwidth, OBW - Outbound bandwidth,
MIBW - Max inbound bandwidth, MOBW - Max outbound bandwidth,
HASH(SIP) - Hash address source IP,
HASH(DIP) - Hash address destination IP,
HASH(SIP-PORT) - Hash address source IP-port
DNS server pool Predictor Total Active
dns-pool RR 3 2
dns-pool1 RR 0 0
dns-pool2 RD 3 0
# Display detailed information about DNS server pool dns-pool.
<Sysname> display loadbalance dns-server-pool name dns-pool
Description:
Predictor: Round robin
Selected server: Enabled
Min servers: 3
Max servers: 5
Probe information:
Probe success criteria: At-least 2
Probe method: t4
Total DNS servers: 3
Active DNS servers: 0
DNS server list:
Name State Address port Link Weight Priority
ds1 Active 10.150.100.100 0 link1 100 4
ds2 Probe-failed 20.150.100.100 5353 link2 100 4
ds3 Inactive -- 0 link3 100 4
Table 13 Command output
Predictor |
Scheduling algorithm of the DNS server pool: · RR—Weighted round robin algorithm. · RD—Random algorithm. · BW—Bandwidth algorithm. · IBW—Inbound bandwidth algorithm. · OBW—Outbound bandwidth algorithm. · MBW—Maximum bandwidth algorithm. · MIBW—Maximum inbound bandwidth algorithm. · MOBW—Maximum outbound bandwidth algorithm. · HASH(SIP)—Hash algorithm based on source IP address. · HASH(DIP)—Hash algorithm based on destination IP address. · HASH(SIP-PORT)—Hash algorithm based on source IP address and port number. |
DNS server pool |
DNS server pool name. |
Total |
Total number of DNS servers. |
Active |
Number of active DNS servers. |
Description for the DNS server pool. |
Selected server |
State of DNS server limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed: · Min servers—Minimum number of DNS servers that can participate in scheduling. · Max servers—Maximum number of DNS servers that can participate in scheduling. |
Probe information |
Detailed health monitoring information for the DNS server pool. |
Health monitoring success criteria for the DNS server pool: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Probe method |
Total DNS servers |
Active DNS servers |
Name |
DNS server name. |
State |
DNS server state: · Active—The DNS server is available. · Busy—The DNS server is busy. When the DNS server is in Active or Ramp state and enabled with link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The DNS server is unavailable, because the configuration is not complete or the server is not referenced. · Probe-failed—Health monitoring has failed. |
Address |
Port |
Port number of the DNS server. |
Link |
Name of the link corresponding to the DNS server. |
Weight |
Priority |
display loadbalance external-monitor log
Use display loadbalance external-monitor log to display the log information for custom monitoring.
context-admin
context-operator
# Display the log information for custom monitoring.
<Sysname> display loadbalance external-monitor log
The external monitor probe state of (server farm sf, real server rs, port: 3306) template mysql-template changed to successful.
The external monitor probe state of (server farm sf2, real server rs2, port: 3306) template mysql-template changed to failed.
display loadbalance hot-backup statistics
Use display loadbalance hot-backup statistics to display LB hot backup statistics.
In standalone mode:
display loadbalance hot-backup statistics [ slot slot-number ]
In IRF mode:
display loadbalance hot-backup statistics [ chassis chassis-number slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays LB hot backup statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays LB hot backup statistics for all cards. (In IRF mode.)
# Display LB hot backup statistics.
<Sysname> display loadbalance hot-backup statistics
Slot 2:
TryAdd TryDel AckDel AckOK AckNO NotSpt
StiSnd 1 0 0 0 0 0
StiRcv 0 0 0 0 0 0
StiSndFail 0 0 0 0 0 0
StiRcvFail 0 0 0 0 0 0
MsgSnd 1 0 0 0 0 0
MsgRcv 0 0 0 0 0 0
MsgSndFail 0 0 0 0 0 0
MsgRcvFail 0 0 0 0 0 0
MAllocFail 0 0 0 0 0 0
SesBkTotal : 0
SesBkFail : 0
SesResTotal: 0
SesResFail : 0
SesUpdate : 0
Table 14 Command output
Message for adding sticky entries. |
Message for deleting sticky entries. |
Message for acknowledging the deletion of sticky entries. |
Message indicating the sticky entries that can be deleted. |
Message indicating the sticky entries that cannot be deleted. |
Message indicating the unsupported sticky entries. |
Number of sent sticky entries. |
Number of received sticky entries. |
Number of sticky entry sending failures. |
Number of sticky entry receiving failures. |
Number of sent messages. |
Number of received messages. |
Number of message sending failures. |
Number of message receiving failures. |
MAllocFail |
Number of memory application failures. |
Number of session backups. |
Number of session backup failures. |
Number of session restorations. |
Number of session restoration failures. |
Number of session updates. |
display loadbalance isp
Use display loadbalance isp to display ISP information.
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
context-admin
context-operator
ip ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address.
name isp-name: Specifies an ISP by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command displays information about all ISPs.
# Display information about all ISPs.
<Sysname> display loadbalance isp
(*) - User-defined object
Last successful auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update result: Successful
ISP update count: 1
LB ISP: isp1
Whois maintainer object name:
MAINT-CHINANET
Description: ISP1
IPv4 address/Mask length: --
IPv6 address/Prefix length: --
LB ISP: isp2(*)
Description:
1.2.3.0/32(*) 1.2.3.4/32 3.3.3.6/32(*)
192.168.6.131/32(*) 192.168.195.189/32(*)
1::2/128
FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
# Display information about the ISP corresponding to the IP address 1.2.3.0.
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name Source IPv4 address/Mask length
isp2 user-set 1.2.3.0/28
isp2 user-set 1.2.3.0/29
isp2 user-set 1.2.3.0/30
isp2 file-load 1.2.3.0/31
auto-update
isp2 user-set 1.2.3.0/32
file-load
# Display information about the ISP corresponding to the IPv6 address 1::1234.
<Sysname> display loadbalance isp ipv6 1::1234
ISP name Source IPv6 address/Prefix length
isp2 user-set 1::1234/126
isp2 user-set 1::1234/127
isp2 file-load 1::1234/128
Table 15 Command output
(*) indicates that the ISP information is manually configured. If the ISP information is also imported from a file, (*) is not displayed. |
Last successful auto update time |
Time of the most recent successful update. |
Last auto update time |
Time of the most recent update. |
Last auto update result |
Result of the most recent auto update: · Successful. · Failed to connect to WHOIS server. · Connection failed. · Failed to query DNS (which means failed to send DNS requests). |
ISP update count |
Number of ISPs in the most recent update. |
ISP name. |
Description for the ISP. |
Source of the ISP: · user-set—Manually configured. · file-load—Imported from a file. · auto-update—ISP auto update. |
display loadbalance limit-policy
Use display loadbalance limit-policy to display LB connection limit policy information.
display loadbalance limit-policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 63 characters.
# Display information about the LB connection limit policy lptest.
<Sysname> display loadbalance limit-policy name lptest
Limit-policy: lptest
Description:
Limit rule:
limit lptest acl 3000 amount 10 10
display loadbalance link
Use display loadbalance link to display LB link information or link group member information.
display loadbalance link [ brief | name link-name ]
display loadbalance link link-group link-group-name [ name link-name ]
context-admin
context-operator
brief: Displays brief information about all LB links. If you do not specify this keyword, the command displays detailed LB link information.
name link-name: Displays detailed information about the specified LB link. The link-name argument specifies an LB link name, a case-insensitive string of 1 to 63 characters.
link-group link-group-name: Displays information about members of a link group. The link-group-name argument specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
name link-name: Displays information about a link group member. The link-name argument specifies a link group member by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all members of a link group.
If you do not specify the brief keyword or the name link-name option, the command displays detailed information about all LB links.
# Display brief information about all LB links.
<Sysname> display loadbalance link brief
Link Router IP/Interface State VPN instance Link group
Lk1 192.168.1.1 Busy -- lg
Lk2 192.168.2.1 Active -- lg
Lk3 Dialer0 Inactive -- lg
# Display detailed information about the LB link lk.
<Sysname> display loadbalance link name lk
Link: lk
Description: lk
State: Busy
VPN instance: --
Inherit VPN: Disabled
Router IP: 1.2.3.4
Router IPv6: --
Link-group: lg
Weight: 100
Priority: 4
Cost: 0
Slow-shutdown: Disabled
Connection limit: 0
Rate limit:
Connections: 10000
Bandwidth: 10000 kbps
Inbound bandwidth: 5000 kbps
Outbound bandwidth: 5000 kbps
Bandwidth busy:
Max bandwidth: 10000 kbps
Max inbound bandwidth: 5000 kbps
Max outbound bandwidth: 5000 kbps
Busy rate: 80
Inbound busy rate: 70
Outbound busy rate: 60
Busy recovery rate: 60
Inbound busy recovery rate: 60
Outbound busy recovery rate: 60
Probe information:
Probe method State
t4 Inactive
Link: lk2
Description: link2
State: Inactive
VPN instance: --
IPv4 address state: Active
IPv6 address state: Inactive
Router interface: Dialer0
Link group: lg
Weight: 150
Priority: 3
Cost: 100
Slow shutdown: Enabled
Connection limit: 10000
Rate limit:
Connections: 10000
Bandwidth busy:
Busy rate: 80
Probe information:
Probe method State
t4 Inactive
# Display information about all members of link group lg.
<Sysname> display loadbalance link link-group lg
Link group: lg
Link: lk1
Description: link 1
State: Inactive
Weight: 2
Priority: 2
Slow shutdown: Disabled
Connection limit: --
Connection rate limit: --
Probe information:
Probe method State
icmp Failed
Link: lk2
Description: link 2
State: Inactive
Weight: 100
Priority: 4
Probe information:
Probe method State
tcp Failed
Table 16 Command output
Link |
LB link name. |
Router IP/Interface |
Gateway IP address or outgoing interface of the LB link. |
LB link state/Link group member state: · Active—The LB link is available. · Busy—The LB link is busy. · Inactive—The LB link is unavailable, because the configuration is not complete, the LB link is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The LB link is shut down. · Standby—Standby phase of slow online. · Unknown—Health monitoring is not configured. |
VPN instance |
VPN instance of the LB link. · Config—Manually configured. · Inherit—Inherited. |
Link group |
Link group to which the LB link belongs. |
Description for the LB link. |
Inherit VPN |
State of VPN instance inheritance: Enabled or Disabled. |
IPv4 address state |
IPv4 address state of the LB link: · Active—An available IPv4 address is obtained through the outgoing interface of the LB link. · Inactive—No available IPv4 address is obtained through the outgoing interface of the LB link. This field is displayed only if an outgoing interface is specified for an LB link. |
IPv6 address state |
IPv6 address state of the link: · Active—An available IPv6 address is obtained through the outgoing interface of the LB link. · Inactive—No available IPv6 address is obtained through the outgoing interface of the LB link. This field is displayed only if an outgoing interface is specified for an LB link. |
Weight |
Weight of the LB link. |
Priority |
Priority of the LB link. |
Cost |
Cost for proximity calculation. |
Slow shutdown |
Slow offline state of the LB link: · Disabled. · Enabled. |
Connection limit |
Maximum number of connections for the LB link. |
Connection rate limit |
Maximum number of connections per second for the LB link. |
Rate limit |
Rate limit of the LB link. |
Connections |
Bandwidth |
Maximum bandwidth for the LB link in kbps. |
Inbound bandwidth |
Maximum inbound bandwidth for the LB link in kbps. |
Outbound bandwidth |
Maximum outbound bandwidth for the LB link in kbps. |
Bandwidth busy |
Bandwidth ratio. |
Max bandwidth |
Maximum expected bandwidth for the LB link in kbps. |
Max inbound bandwidth |
Maximum inbound expected bandwidth for the LB link in kbps. |
Max outbound bandwidth |
Maximum outbound expected bandwidth for the LB link in kbps. |
Busy rate |
Bandwidth ratio for the LB link. |
Inbound busy rate |
Inbound bandwidth ratio for the LB link. |
Outbound busy rate |
Outbound bandwidth ratio for the LB link. |
Busy recovery rate |
Bandwidth recovery ratio for the LB link. |
Inbound busy recovery rate |
Inbound bandwidth recovery ratio for the LB link. |
Outbound busy recovery rate |
Outbound bandwidth recovery ratio for the LB link. |
Probe information |
Detailed health monitoring information for the LB link. |
Health monitoring success criteria for the LB link: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Probe method |
State |
State of the health monitoring method: · Failed—Health monitoring has failed. · In progress—Health monitoring is in progress. · Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the real server is unavailable. · Succeeded—Health monitoring has succeeded. |
display loadbalance link out-interface statistics
Use display loadbalance link out-interface statistics to display link outbound interface statistics.
display loadbalance link out-interface statistics [ name link-name ]
context-admin
context-operator
name link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays outbound interface statistics for all links.
If the link outbound interface is a logical interface, the rate statistics are calculated based on the interface traffic.
# Display outbound interface statistics for the link lk1.
<Sysname> display loadbalance link out-interface statistics name lk1
Loadbalance link: lk1
Input rate: 1524 bps
Output rate: 90 bps
Table 17 Command output
Loadbalance link |
LB link name. |
Input rate |
Input rate of the outbound interface in bps. |
Output rate |
Output rate of the outbound interface in bps. |
display loadbalance link statistics
Use display loadbalance link statistics to display link statistics or link group member statistics.
In standalone mode:
display loadbalance link statistics [ name link-name ] [ slot slot-number ]
display loadbalance link statistics link-group link-group-name [ name link-name ] [ slot slot-number ]
In IRF mode:
display loadbalance link statistics [ name link-name] [ chassis chassis-number slot slot-number ]
display loadbalance link statistics link-group link-group-name [ name link-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
link-group link-group-name: Displays statistics for members of a link group. The link-group-name argument specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
name link-name: Displays statistics for a link group member. The link-name argument specifies a link group member by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all members of a link group.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays link statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays link statistics for all cards. (In IRF mode.)
# Display statistics for the link lk1.
<Sysname> display loadbalance link statistics name lk1
Total connections: 1798
Active connections: 788
Max connections: 803
recorded at 11:02:49 on Tue May 21 2019
Connections per second: 157
Max connections per second: 163
Downstream traffic: 333332 bytes
Upstream traffic: 472054 bytes
Throughput: 4396 bps
Inbound throughput: 1214 bps
Outbound throughput: 3128 bps
Max throughput: 4564 bps
Max inbound throughput: 1214 bps
Max outbound throughput: 3320 bps
Received packets: 1798
Sent packets: 0
Dropped packets: 0
Packet loss rate: 10
# Display statistics for all members of link group lg.
<Sysname> display loadbalance link statistics link-group lg
Loadbalance link group: lg
Total connections: 0
Active connections: 0
Max connections: 0
Connections per second: 0
Max connections per second: 0
Downstream traffic: 0 bytes
Upstream traffic: 0 bytes
Throughput: 0 bps
Inbound throughput: 0 bps
Outbound throughput: 0 bps
Max throughput: 0 bps
Max inbound throughput: 0 bps
Max outbound throughput: 0 bps
Received packets: 0
Sent packets: 0
Dropped packets: 0
Loadbalance link: lk2
Max connections: 0
Throughput: 0 bps
Received packets: 0
Sent packets: 0
Dropped packets: 0
Table 18 Command output
Loadbalance link |
Link name. |
Total connections |
Total number of connections. |
Active connections |
Number of active connections. |
Max connections |
Maximum number of connections. |
Connections per second |
Number of connections per second. |
Max connections per second |
Maximum number of connections per second. |
Downstream traffic |
Downstream traffic (in bytes) received by the LB device. |
Upstream traffic |
Upstream traffic (in bytes) sent by the LB device. |
Throughput |
Total packet throughput in bps. |
Inbound throughput |
Inbound packet throughput in bps. |
Outbound throughput |
Outbound packet throughput in bps. |
Max throughput |
Maximum packet throughput in bps. |
Max inbound throughput |
Maximum inbound packet throughput in bps. |
Max outbound throughput |
Maximum outbound packet throughput in bps. |
Received packets |
Number of received packets. |
Sent packets |
Number of sent packets. |
Dropped packets |
Number of dropped packets. |
Packet loss rate |
Packet loss ratio of the link. |
display loadbalance link-group
Use display loadbalance link-group to display link group information.
display loadbalance link-group [ brief | name link-group-name ]
context-admin
context-operator
brief: Displays brief information about all link groups. If you do not specify this keyword, the command displays detailed link group information.
name link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all link groups.
If you do not specify any parameters, the command displays detailed information about all link groups.
A link is displayed as unavailable if the link group configuration is not complete, the link group is not referenced, or the virtual server is not enabled. This does not mean that the link is not available.
# Display brief information about all link groups.
<Sysname> display loadbalance link-group brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
BW – Bandwidth, MBW – Max bandwidth,
IBW – Inbound bandwidth, OBW – Outbound bandwidth,
MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
NAT/SNAT: Y - Enabled, N - Disabled
Link group Predictor NAT SNAT Total Active
lg RR Y N 3 3
# Display detailed information about all link groups.
Link group: lg1
Description:
Predictor: Hash address
Proximity: Disabled
NAT: Enabled
SNAT pool:
Failed action: Keep
Active threshold: Enabled
Lower: 80
Upper: 90
Slow-online: Enabled
Standby time: 5s
Ramp-up time: 10s
Selected link: Enabled
Min link: 100
Max link: 600
Probe information:
Probe method:
aaa
ddd
Total link: 1
Active link: 1
Link list:
Name State VPN instance Router IP Weight Priority
Link1 Inactive 1.2.3.4 4 100
Table 19 Command output
Link group |
Link group name. |
Description for the link group. |
Predictor |
Scheduling algorithm of the link group: · RR—Weighted round robin algorithm. · RD—Random algorithm. · LC—Weighted least connection algorithm. · BW—Bandwidth algorithm. · IBW—Inbound bandwidth algorithm. · OBW—Outbound bandwidth algorithm. · MBW—Maximum bandwidth algorithm. · MIBW—Maximum inbound bandwidth algorithm. · MOBW—Maximum outbound bandwidth algorithm. · HASH(SIP)—Hash algorithm based on source IP address. · HASH(DIP)—Hash algorithm based on destination IP address. · HASH(SIP-PORT)—Hash algorithm based on source IP address and port number. |
Proximity |
Proximity state of the link group: · Disabled. · Enabled. |
NAT |
NAT state of the link group: · Disabled. · Enabled. |
SNAT pool |
Name of the SNAT address pool referenced by the link group. |
Failed action |
Fault processing method of the link group: · Keep—Keeps existing connections. · Reschedule—Redirects connections. · Reset—Terminates existing connections. |
Active threshold |
State of the criteria to determine that the link group is available: disabled or enabled. If the state is enabled, the following fields are displayed: · Lower—Lower percentage value. · Upper—Upper percentage value. |
Slow-online |
State of the slow online feature: disabled or enabled. If the state is enabled, the following fields are displayed: · Standby time. · Ramp-up time. |
Selected link |
State of link limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed: · Min server—Minimum number of links that participate in scheduling. · Max server—Maximum number of links that participate in scheduling. |
Health monitoring success criteria for the link group: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least X—Health monitoring succeeds when a minimum of X health monitoring methods succeed. |
Probe method |
Total link |
Total number of links. |
Active link |
Number of active links. |
Name |
Link name. |
State |
Link state: · Active—The link is available. · Busy—The link is busy. When the link is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The link is unavailable, because the configuration is not complete, the link is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The link is shut down. · Standby—Standby phase of slow online. |
VPN instance |
VPN instance of the link. |
Router IP |
IPv4 and IPv6 addresses of the link. |
Weight |
Weight of the link. |
Priority |
Priority of the link. |
display loadbalance local-dns-server parse-fail-record
Use display loadbalance local-dns-server parse-fail-record to display DNS request parse failures.
In standalone mode:
display loadbalance local-dns-server parse-fail-record [ type { a | aaaa | cname | mx | ns | soa | srv | txt } ] [ domain domain-name ] | ptr [ ip address { ipv4-address | ipv6-address } ] ] [ vpn-instance vpn-instance-name ] [ slot slot-number ]
In IRF mode:
display loadbalance local-dns-server parse-fail-record [ type { a | aaaa | cname | mx | ns | soa | srv | txt } ] [ domain domain-name ] | ptr [ ip address { ipv4-address | ipv6-address } ] ] [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
type { a | aaaa | cname | mx | ns | ptr | soa | srv | txt }: Specifies a DNS request type. If you do not specify a DNS request type, this command displays DNS request parse failures for all DNS request types.
domain domain-name: Specifies a domain name, a case-insensitive, dot-separated string of 1 to 254 characters for an absolute domain name or 1 to 253 characters for a relative domain name. Each dot-separated label in the domain name can contain a maximum of 63 characters. If you do not specify a domain name, this command displays DNS request parse failures for all domain names.
ip address { ipv4-address | ipv6-address }: Specifies an IP address used for reverse DNS. If you do not specify this option, the command displays DNS request parse failures for all IP addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DNS request parse failures for the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DNS request parse failures for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DNS request parse failures for all cards. (In IRF mode.)
# Display all DNS request parse failures.
<Sysname> display loadbalance local-dns-server parse-fail-record
Slot 0:
ID Time Type SIP/Port DIP/Port VPN instance Domain Failure cause
1 03 Nov 2016 A 1.2.3.4/1 2.2.2.2/53 -- www.aaa.com No matched virtual
19:09:52 server member.
2 03 Nov 2016 AAAA 1.2.3.4/2 2.2.2.2/53 -- www.lb.com No matched.
19:09:43 DNS mapping
3 03 Nov 2016 MX 1.2.3.5/3 2.2.2.2/53 -- mail.aa.com No matched record.
20:09:41
4 04 Nov 2016 NS 1.2.3.4/4 2.2.2.2/53 -- ns.aaa.com No matched record.
11:15:40
5 05 Nov 2016 CNAME 1.2.3.4/5 2.2.2.2/53 -- www.aaa.com No matched DNS
11:16:35 zone.
6 05 Nov 2016 SOA 1.2.3.4/6 2.2.2.2/53 -- www.aaa.com No matched DNS
12:16:25 zone.
7 05 Dec 2016 PTR 1.2.3.4/7 2.2.2.2/53 -- 1.2.3.4 No matched record.
15:19:16
Table 20 Command output
ID |
Failure record ID. |
Time |
Time when the device received a DNS request. |
Type |
Resource record type: · A—IPv4 host address. · AAAA—IPv6 host address. · CNAME—Canonical name. · MX—Mail exchanger. · NS—Name server. · PTR—Pointer. · SOA—Start of authority. · SRV—Service. · TXT—Text. |
SIP/Port |
Source IP address and port number of a DNS request. |
DIP/Port |
Destination IP address and port number of a DNS request. |
Failure cause |
Failure cause for DNS request parsing: · --—Parsing succeeded. · No matched DNS listener. · No matched DNS mapping. · No matched virtual server pool. · No matched DNS zone. · Failed to get buffer. · No matched record. · No enough memory resource. · Failed to parse domain. · Failed to find DNS listener by ID. · No scheduling content. · Scheduling failed—The scheduling content exists, but scheduling failed. · No matched virtual server member. |
display loadbalance policy
Use display loadbalance policy to display LB policy information.
display loadbalance policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB policies.
# Display information about all LB policies.
<Sysname> display loadbalance policy
LB policy: lbp1
Description:
Type: Generic
Class: lbc1
Action: lba1
Default action: lba0
LB policy: lbp2
Description:
Type: HTTP
Default action:
LB policy: lbp3
Description:
Type: Link-generic
Class: lbc3
Action: lba3
Default action: lba3
LB policy: lbp4
Description:
Type: DNS
Class: lbc4
Action: lba4
Default action: lba4
LB policy: lbp5
Description:
Type: MySQL
Class: lbc5
Action: lba5
Default action: lba5
Table 21 Command output
LB policy |
LB policy name. |
Description for the LB policy. |
Type |
LB policy type: · DNS. · Generic. · HTTP. · Link-generic. · MySQL. · RADIUS. |
Class |
LB class for the LB policy. |
Action |
LB action for the LB class. |
Default class action |
Default LB action. |
display loadbalance probe-template
Use display loadbalance probe-template to display LB probe template information.
display loadbalance probe-template [ name template-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name template-name: Specifies an LB probe template by its name, a case-insensitive string of 1 to 32 characters. If you do not specify this option, the command displays information about all LB probe templates.
# Display information about all LB probe templates.
<Sysname> display loadbalance probe-template
Load balancing probe template: rst1
Description:
Type: tcp-rst
Monitoring interval: 20 sec
RST threshold: 10
Protection action: auto-shutdown
Load balancing probe template: zero2
Description:
Type: tcp-zero-window
Monitoring interval: 30 sec
Zero-window threshold: 20
Protection action: busy
Probe interval: 30 sec
Probe times: 3
Load balancing probe template: icmp1
Description:
Type: icmp
Timeout: 3 sec
Frequency: 300
Load balancing probe template: http1
Description:
Type: http-passive
Monitoring interval: 1 sec
Abnormal-url threshold: 10000
Timeout: 30 sec
URL list:
aaa
Status code list:
404
Load balancing probe template: test_external
Description:
Type: external-monitor
External script: http.sh
Monitoring interval: 5 sec
Timeout: 6 sec
Argument: 192.168.1.123
Environment variable list:
Name Value
Test3 /opt/lib
Test4 /usr/bin
Table 22 Command output
Load balancing probe template |
LB probe template name. |
Description for the LB probe template. |
Type |
LB probe template type: · external-monitor—Custom monitoring. · http-passive. · icmp. · tcp-rst. · tcp-zero-window. |
Monitoring interval |
Monitoring time. During the monitoring time, the system counts the number of RST packets or zero-window packets sent by each server farm member in a server farm. This field is displayed only for a custom-monitoring, HTTP passive, TCP-RST, or TCP zero-window LB probe template. |
RST threshold |
Maximum number of RST packets a real server can send. This field is displayed only for a TCP-RST LB probe template. |
Zero-window threshold |
Maximum percentage of zero-window packets a real server can send. This field is displayed only for a TCP zero-window LB probe template. |
Protection action |
Action to take when the RST or zero-window packet threshold is reached: Auto-shutdown or Busy. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
Probe interval |
Interval to probe the real server in busy state. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
Probe times |
Maximum number of times for probing the real server in busy state. If the number of probe times is reached, the real server is automatically shut down. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
Timeout |
Timeout time for probe responses, HTTP responses, or custom monitoring probe packet responses. This field is displayed only for an ICMP LB probe template, HTTP passive, or custom-monitoring LB probe template. |
Frequency |
Probe interval for an LB probe template. This field is displayed only for an ICMP LB probe template or HTTP passive LB probe template. |
Abnormal-url threshold |
Upper limit of URL error times. This field is displayed only for an HTTP passive LB probe template. |
URL list |
List of URLs to check for an HTTP passive LB probe template This field is displayed only for an HTTP passive LB probe template. |
Status code list |
List of response status codes to check for an HTTP passive LB probe template This field is displayed only for an HTTP passive LB probe template. |
External script |
Script file used by a custom-monitoring LB probe template. This field is displayed only for a custom-monitoring LB probe template. |
Argument |
User-defined information for a custom-monitoring LB probe template. This field is displayed only for a custom-monitoring LB probe template. |
Environment variables list |
Environment variable list for a custom-monitoring LB probe template. This field is displayed only for a custom-monitoring LB probe template. |
Name |
Environment variable name. This field is displayed only for a custom-monitoring LB probe template. |
Value |
Environment variable value. This field is displayed only for a custom-monitoring LB probe template. |
reset real-server statistics
display loadbalance process-limit
Use display loadbalance process-limit to display the maximum number of processes allowed to be started for custom monitoring.
context-admin
context-operator
# Display the maximum number processes allowed to be started for custom monitoring.
<Sysname> display loadbalance process-limit
Loadbalance process-limit: 200
display loadbalance protection-policy
Use display loadbalance protection-policy to display the configuration of protection policies.
display loadbalance protection-policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name policy-name: Specifies a protection policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a protection policy, this command displays the configuration of all protection policies.
# Display the configuration of all protection policies.
<Sysname> display loadbalance protection-policy
Policy name: p1
Description:
Type: HTTP
Protection action: verify js
Rule ID: 3
URL: /index.php
Protection period: 2
Method Threshold
Cookie (Jsessionid) 20
Source IP 10
Rule ID: 5
URL: /test.php
Protection period: 20
Method Threshold
Cookie (A1B2C3D4) 20
Table 23 Command output
Protection action |
Protection action: · warning—Generates a log message. · drop—Drops requests. · verify (insert header)—Performs cookie verification by inserting an HTTP header. · verify (js)—Performs cookie verification by inserting a JS script. |
URL |
Protected URL. |
Method |
Threshold type: · Cookie (xxx)—Cookie-based threshold (cookie name). · Source IP—- Source-IP-based threshold. |
display loadbalance proximity
Use display loadbalance proximity to display proximity entry information.
In standalone mode:
display loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ slot slot-number ]
In IRF mode:
display loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays proximity entry information for the public network.
ip [ ipv4-address ]: Displays IPv4 proximity entry information. If you specify the ipv4-address argument, this command displays detailed information about the proximity entry corresponding to the IPv4 address. If you do not specify the ipv4-address argument, this command displays brief information about all IPv4 proximity entries.
ipv6 [ ipv6-address ]: Displays IPv6 proximity entry information. If you specify the ipv6-address argument, this command displays detailed information about the proximity entry corresponding to the IPv6 address. If you do not specify the ipv6-address argument, this command displays brief information about all IPv6 proximity entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays proximity information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays proximity information for all cards. (In IRF mode.)
If you do not specify the vpn-instance, ip, or ipv6 keyword, this command displays brief information about all IPv4 and IPv6 proximity entries.
# Display brief information about all IPv4 and IPv6 proximity entries for the public network.
<Sysname> display loadbalance proximity
(*) – Real server object
Slot :1
IPv4 address/Mask length Timeout Best link RTT Dynamic weight
1.2.3.0/24 59 lk1 1 170
1.2.15.0/24 58 lk2 2 170
IPv6 address/Prefix length Timeout Best link RTT Dynamic weight
11:22::/96 40 lk1 3 200
# Display detailed information about the proximity entry corresponding to the IP address 1.2.3.1 for the public network.
<Sysname> display loadbalance proximity ip 1.2.3.1
IPv4 address/Mask length: 1.2.3.0/24
Timeout: 40
Link list/RTT:
lk1/1
lk2/3
<Sysname> display loadbalance proximity ipv6 11:22::
IPv6 address/Prefix length: 11:22::/96
Timeout: 34
Link list/RTT:
lk1/2
lk2/3
Table 24 Command output
Slot |
Card for which proximity entry information is displayed. |
Remaining time of the proximity entries, in seconds. |
Links for the proximity entry. They are listed in descending priority order. |
RTT |
Network delay for the link in milliseconds. |
display loadbalance reverse-zone
Use display loadbalance reverse-zone to display DNS reverse zone information.
display loadbalance reverse-zone { ip [ ipv4-address mask-length ] | ipv6 [ ipv6-address prefix-length ] }
context-admin
context-operator
ip: Displays IPv4 DNS reverse zone information.
ipv4-address mask-length: Specifies an IPv4 address and the mask length. The mask length is in the range of 0 to 32. If you do not specify this argument, the command displays all IPv4 DNS reverse zone information.
ipv6: Displays IPv6 DNS reverse zone information.
ipv6-address prefix-length: Specifies an IPv6 address and the prefix length. The prefix length is in the range of 0 to 128. If you do not specify this argument, the command displays all IPv6 DNS reverse zone information.
Non-default vSystems do not support this command.
# Display all IPv4 DNS reverse zone information.
<Sysname> display loadbalance reverse-zone ip
Reverse zone: 10.1.1.0/24
Record list:
Type TTL RDATA
PTR 3600 1.1.1.2 a.mail.h3c.com
PTR 2700 1.1.1.3 b.mail.h3c.com
# Display all IPv6 DNS reverse zone information.
<Sysname> display loadbalance reverse-zone ipv6
Reverse zone: 1::/64
Record list:
Type TTL RDATA
PTR 3600 1::1 a.mail.h3c.com
PTR 2700 1::2 b.mail.h3c.com
Table 25 Command output
Reverse zone |
IPv4/IPv6 address and mask/prefix length of the DNS reverse zone. |
Record list |
List of resource records. |
Type |
Resource record type (only PTR is supported). |
TTL |
TTL of the resource record, in seconds. |
RDATA |
Resource data. |
display loadbalance snat-global-policy
Use display loadbalance snat-global-policy to display SNAT global policy information.
display loadbalance snat-global-policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name policy-name: Specifies a SNAT global policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all SNAT global policies.
# Display information about all SNAT global policies.
<Sysname> display loadbalance snat-global-policy
Policy name: lbsnat1
Description:
State: Active
Priority: 0
VPN instance:
Source IP object group: src-obj
Destination IP object group: dst-obj
Service object group: proto-obj
Translation mode: snat-pool sp
Policy name: lbsnat2
Description:
State: Inactive(disable)
Priority: 0
VPN instance:
Translation mode: auto-map
Table 26 Command output
State |
State of the SNAT global policy: · Active—The SNAT global policy is enabled and available. · Inactive—The SNAT global policy is enabled but unavailable. · Inactive (disabled)—The SNAT global policy is disabled and unavailable. |
display loadbalance snat-pool
Use display loadbalance snat-pool to display SNAT address pool information.
display loadbalance snat-pool [ name pool-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name pool-name: Specifies a SNAT address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all SNAT address pools.
# Display information about all SNAT address pools.
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
Description:
VPN instance:
Type: Address split
IPv4 range:
Start address End address
202.110.10.5 202.110.10.10
202.110.20.10 202.110.20.15
IPv6 range:
2002::2 2002::100
2002::200 2002::300
ARP/ND interfaces:
GigabitEthernet1/0/1
GigabitEthernet1/0/3
SNAT pool: lbsp2
Description:
VPN instance:
Type: Port-based split
IPv4 range:
203.110.10.10 203.110.10.15
IPv6 range:
2003::2 2003::100
ARP/ND interfaces:
GigabitEthernet1/0/2
Table 27 Command output
SNAT pool |
SNAT address pool name. |
Description for the SNAT address pool. |
VPN instance |
VPN instance to which the SNAT address pool belongs. |
Type |
Splitting method for the SNAT address pool: · Address split—Address-based splitting. · Failover-group-based spit—Failover group-based splitting. · Port-based spit—Port-based splitting. |
IPv4 range |
IPv4 address range. |
IPv6 range |
IPv6 address range. |
ARP/ND interfaces |
Interfaces from which gratuitous ARP packets and ND packets are sent out. |
display loadbalance virtual-server total-statistics
Use display loadbalance virtual-server total-statistics to display cumulative statistics for all virtual servers.
In standalone mode:
display loadbalance virtual-server total-statistics [ slot slot-number ]
In IRF mode:
display loadbalance virtual-server total-statistics [ chassis chassis-number slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays cumulative statistics for all virtual servers on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays cumulative statistics for all virtual servers on all cards. (In IRF mode.)
This command displays the cumulative connection statistics for all virtual servers. If you execute the reset virtual-server command for a virtual server, the statistical values are affected.
# Display cumulative statistics for all virtual servers.
<Sysname> display loadbalance virtual-server total-statistics
Slot 1:
Slot 2:
Table 28 Command output
Total connections |
display loadbalance virtual-server-pool
Use display loadbalance virtual-server-pool to display virtual server pool information.
display loadbalance virtual-server-pool [ brief | name pool-name ]
context-admin
context-operator
brief: Displays brief information about all virtual server pools.
name pool-name: Displays detailed information about the specified virtual server pool.
If you do not specify the brief keyword or the name pool-name option, the command displays detailed information about all virtual server pools.
# Display brief information about all virtual server pools.
<Sysname> display loadbalance virtual-server-pool brief
TOP - Topology, PRO – Proximity
VSpool Pre Alt Fbk BWP Total Active
vsp RR LC Enabled 0 0
vpp RR Enabled 0 0
vsp1 RD TOP Enabled 3 0
# Display detailed information about the virtual server pool local-pool.
<Sysname> display loadbalance virtual-server-pool name local-pool
Virtual-server pool: local-pool
Predictor:
Preferred RD
Alternate TOP
Fallback --
Bandwidth busy-protection: Disabled
Total virtual servers: 3
Active virtual servers: 0
Virtual server list:
Name State Address Port Weight Link
vs1 Active 192.168.1.1 0 150 ct-link1
vs2 Active 192.167.1.1 0 120 ct-link2
vs3 Active 192.169.1.1 0 80 cnc-link
Virtual IP address list:
Address State Weight Link
10.0.1.1 Active 150 ct-link1
10.1.1.1 Active 120 ct-link2
10.2.1.1 Active 80 cnc-link
Virtual IPv6 address list:
9::5 Active 150 ct-link1
9::6 Active 120 ct-link2
9::7 Active 80 cnc-link
Table 29 Command output
Virtual-server pool |
Virtual server pool name. |
Predictor |
Scheduling algorithm of the virtual server pool. |
Bandwidth busy-protection |
Link protection feature state for the virtual server pool: · Disabled. · Enabled. |
Name |
Name of the virtual server. |
State |
Virtual server state: · Active—The virtual server is available. · Busy—The virtual server is busy. When the virtual server is in Active state and enabled with the link protection feature, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The virtual server is unavailable, because the configuration is not complete or the associated LB link is unavailable. |
Address |
IP address of the virtual server or virtual IP address. |
Port |
Port number of the virtual server. |
Weight |
Weight of the virtual server or virtual IP address. |
Link |
LB link used by the virtual server. |
display loadbalance zone
Use display loadbalance zone to display DNS forward zone information.
display loadbalance zone [ name domain-name ]
context-admin
context-operator
name domain-name: Specifies a domain name. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.). The domain name can include a maximum of 253 characters, and each separated string includes no more than 63 characters. If you do not specify a domain name, this command displays DNS forward zone information for all domain names.
# Display all DNS forward zone information.
<Sysname> display loadbalance zone
Zone: abc.com
TTL: 3600s
SOA:
Primary name server: ns1.abc.com
Responsible mail: root.ns1.abc.com
Serial: 11812
Retry: 14400s
Expire: 604800s
Min TTL: 86400s
Record list:
Type TTL RDATA
NS 3600s ns1.abc.com
NS 4200s ns2.abc.com
NS 4200s a.abc.com ns2.abc.com
MX 3600s a.mail.abc.com 10
MX 2700s b.mail.abc.com 20
CNAME 5000s a.test.abc.com abc1.abc.com
CNMAE 3600s b.test.abc.com abc2.abc.com
TXT 5000s v=spf1 include:spf.abcmail.abc.com.cn -all
SRV -- _ http._tcp.example.com. www.example.com 5 10 80
Table 30 Command output
Zone |
Domain name of the DNS forward zone. |
TTL |
TTL of the resource record in the DNS forward zone, in seconds. |
SOA |
Start of Authority (SOA) information. |
Responsible mail |
Email address of the domain administrator. |
Serial |
Domain serial number. |
Retry |
Retry interval in seconds. |
Expire |
Expiration time in seconds. |
Min TTL |
Minimum TTL in seconds. |
Record list |
Type |
Resource record type: · MX—Mail exchange record. · CNAME—Canonical name record. · NS—Name server record. · SRV—Service location record. · TXT—Text record. |
TTL |
RDATA |
Resource data. |
display parameter-profile
Use display parameter-profile to display parameter profile information.
display parameter-profile [ name parameter-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all parameter profiles.
# Display information about all parameter profiles.
<Sysname> display parameter-profile
Parameter profile: pp1
Description:
Type: IP
IP ToS: 20
Parameter profile: pp2
Description:
Type: TCP
Exceed MSS: Allow
TCP window size: 65535
TCP connection idle-timeout: 10
Time-wait timeout: 5
Keepalive idle-timeout: 300
Keepalive retransmission interval: 3
Keepalive retransmission count: 5
SYN retransmission-timeout: 5
Fin-wait1 timeout: 6
Fin-wait2 timeout: 10
Src-addr-option:
Option number: 29
Encoding: string
TCP option remove:
Option number: 8
TCP option remove:
Option number: 5
TCP option insert:
Option number: 28
Value: src-ip
Encoding: string
Parameter profile: pp3
Description:
Type: HTTP
Rebalance per request: Enabled
Server connection reuse: Enabled
Case insensitive: Enabled
Header modify per request: Enabled
Content maximum parse length: 8192
Header maximum parse length: 8192
Secondary cookie delimiters: !@#$
Secondary cookie start: ?
Encrypted cookie name: cookie1
Header exceed length: Drop
Parameter profile: compress
Description:
Type: HTTP compression
Compression level: 1
Prefer method: Gzip
Content length threshold: 1024
Memory size: 8KB
Window size: 16KB
Header Insert: Enabled
Header Delete: Enabled
Request version all: Disabled
Rule 1: Permit url abc
Parameter profile: urlstat
Description:
Type: HTTP-statistics
Node: bank1
Description:
rule 1 url url1
rule 2 url url2
Node: bank2
Description:
rule 1 url url3
rule 2 url url4
Object group name:
ObjGrp1
ObjGrp2
Parameter profile: pp4
Description:
Type: OneConnect
Max reuse times: 1000
Idle time: 10000
IPv4 source mask length: 24
IPv6 source prefix length: 120
Parameter profile: pp5
Description:
Type: TCP-application
Match-buffer-time: 5
Match-buffer-size: 4096
Match-buffer-end: YY
Parameter profile: pp6
Description:
Type: MySQL
Pool size: 2000
Idle time: 10000 sec
Table 31 Command output
Parameter profile |
Parameter profile name. |
Description for the parameter profile. |
Type |
Parameter profile type: · IP. · HTTP. · HTTP-compression. · HTTP statistics. · MySQL. · OneConnect. · TCP. · TCP-application. |
IP ToS |
ToS field of the IP packets sent to the server. |
Exceed MSS |
Action to take on the segments that exceed the MSS in the HTTP requests sent by the client: · Allow—Allows the segments to exceed the MSS. · Drop—Discards the segments that exceed the MSS. |
Rebalance per request |
Whether or not to enable load balancing for each HTTP request. |
Pool size |
Size of the MySQL connection pool. |
Server connection reuse |
Whether or not to reuse the connection between the LB device and the server. |
Header modify per request |
Whether or not to perform the insert, delete, or modify operation for the header of each HTTP request or response packet. |
Case insensitive |
Whether or not to enable case sensitivity for matching character strings. |
Content maximum parse length |
Maximum length of the HTTP entities that can be parsed. |
Header maximum parse length |
Maximum length of the HTTP headers that can be parsed. |
Secondary cookie delimiters |
Delimiters that can separate secondary cookies in URLs. |
Secondary cookie start |
Start delimiter for secondary cookies in URLs. |
Encrypted cookie name |
Cookie enabled with encryption. |
Header exceed length |
Action to take on the HTTP requests or responses when their packet headers exceed the maximum length: · Continue—Continues to perform load balancing. · Drop—Stops performing load balancing, discards the packet, and terminates the connection. |
TCP window size |
Maximum local window size for TCP connections. |
TCP connection idle-timeout |
Idle timeout time for TCP connections, in seconds. |
Time-wait timeout |
TIME_WAIT state timeout time for TCP connections, in seconds. |
Keepalive idle-timeout |
Idle timeout time for sending TCP keepalive packets. |
Keepalive retransmission interval |
Retransmission interval for TCP keepalive packets. |
Keepalive retransmission count |
Retransmission times for TCP keepalive packets. |
SYN retransmission-timeout |
Retransmission timeout time for TCP SYN packets |
Fin-wait1 timeout |
FIN-WAIT-1 state timeout time for TCP connections. |
Fin-wait2 timeout |
FIN-WAIT-2 state timeout time for TCP connections. |
Node |
Statistics node name and all URL match rules configured for the statistics node. |
Object group name |
IP address object groups used by the HTTP statistics parameter profile. |
Max reuse times |
Maximum number of times a TCP connection can be reused. |
Idle time |
IPv4 source mask length |
Mask length for connection reuse. |
IPv6 source prefix length |
Prefix length for connection reuse. |
Match-buffer-time |
Buffering period for TCP payload matching, in seconds. |
Match-buffer-size |
Maximum buffering size for TCP payload matching. |
Match-buffer-end |
Buffering end string for TCP payload matching. |
Src-addr-option |
TCP option for SNAT address translation. |
Option number |
TCP option number |
Encoding |
Encoding mode for the TCP option: · binary. · string. |
TCP option insert |
Inserts contents into a TCP option. |
Value |
Contents to insert into the TCP option |
TCP option remove |
Removes a TCP option. |
display real-server
Use display real-server to display real server information or server farm member information.
display real-server [ brief | name real-server-name ]
display real-server server-farm server-farm-name [ name real-server-name port port-number ]
context-admin
context-operator
vsys-admin
vsys-operator
brief: Displays brief real server information. If you do not specify this keyword, the command displays detailed real server information.
name real-server-name: Displays information about the specified real server. The real-server-name argument specifies a real server name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all real servers.
server-farm server-farm-name: Displays information about members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
name real-server-name port port-number: Displays information about a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays information about all members of a server farm.
# Display brief information about all real servers.
<Sysname> display real-server brief
Real server Address Port State VPN instance Server farm
rs1 192.168.1.1 0 Active sf
rs2 192.168.1.2 0 Busy sf
rs3 192.168.1.3 0 Active sf
# Display detailed information about the real server rs.
<Sysname> display real-server name rs
Real server: rs
Description: Real server RS
State: Active
VPN instance:
IPv4 address: 1.1.1.1
IPv6 address: 1001::1
Port: 0 (port number in original packet)
Server farm: sf
Weight: 150
Priority: 3
Cost: 100
Rate limit:
Connections: 10000
Bandwidth busy:
Busy rate: 80
Probe log: Enabled
Probe information:
Dynamic weight: 1
SNMPDCA busy state: Normal
Probe success criteria: All
Probe method State
t4 Succeeded
External-monitor method State
test_external Succeeded
test_external2 Succeeded
# Display information about all members of server farm sf.
<Sysname> display real-server server-farm sf
Server farm: sf
Real server: rs1
Description: real server 1
Parent state: Inactive
State: Inactive
Port: 2
Weight: 2
Priority: 2
Probe log: Enabled
Probe information:
Probe method State
icmp Failed
Real server: rs2
Description: real server 2
State: Inactive
Port: 80
Weight: 100
Priority: 4
Probe log: Enabled
Probe information:
Probe method State
tcp Failed
Variable information:
Variable name: variable
Variable value: 2
Table 32 Command output
Real server |
Address |
IPv4 address of the real server. |
Port |
Port number of the real server. 0 means the port number in the packet is used. |
Parent state/State |
Real server state/Server farm member state: · Active—The real server is available. · Busy—The real server is busy. When the real server is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The real server is unavailable, because the configuration is not complete, the server is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The real server is shut down. · Standby—Standby phase of slow online. · Unknown—Health monitoring is not configured. · Auto shutdown—The real server is automatically shut down when the RST or zero-window packet threshold is reached or the number of probe times is reached. |
VPN instance |
VPN instance to which the real server belongs. |
Inherit VPN |
Server farm |
Server farm of the real server. |
Description for the real server. |
IPv4 address |
IPv6 address |
IPv6 address of the real server. |
Weight |
Weight of the real server. |
Priority |
Priority of the real server. |
Slow shutdown |
Slow offline state of the real server: · Disabled. · Enabled. |
Connection limit |
Maximum number of connections for the real server. |
Maximum number of connections per second for the real server. |
Rate limit |
Rate limit of the real server. |
Connections |
Bandwidth |
Maximum bandwidth for the real server in kbps. |
Inbound bandwidth |
Maximum uplink bandwidth for the real server in kbps. |
Maximum downlink bandwidth for the real server in kbps. |
Max bandwidth |
Maximum expected bandwidth for the real server in kbps. |
Maximum uplink expected bandwidth for the real server in kbps. |
Maximum downlink expected bandwidth for the real server in kbps. |
Bandwidth ratio for the real server. |
Inbound bandwidth ratio for the real server. |
Outbound bandwidth ratio for the real server. |
Bandwidth recovery ratio for the real server. |
Inbound bandwidth recovery ratio for the real server. |
Outbound bandwidth recovery ratio for the real server. |
Dynamic weight |
Dynamic weight calculated by using the dynamic round robin algorithm. This field displays a weight value only if the dynamic round robin algorithm is used. If any other algorithm is used, this field displays two hyphens (--). |
SNMPDCA busy state |
Busy state obtained by using the dynamic round robin algorithm: Normal or Busy. If the dynamic round robin algorithm is not used, this field displays two hyphens (--). |
Probe log |
Health monitoring logging state of the real server: · Disabled. · Enabled. |
Probe success criteria |
Health monitoring success criteria for the real server: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least X—Health monitoring succeeds when a minimum of X health monitoring methods succeed. |
Probe method |
Name of the NQA template used by the health monitoring method. |
State |
State of the health monitoring method (custom monitoring or NQA): · Failed—Health monitoring has failed. · In progress—Health monitoring is in progress. · Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the real server is unavailable. · Succeeded—Health monitoring has succeeded. |
External-monitor method |
Custom monitoring method. |
display real-server statistics
Use display real-server statistics to display real server statistics or server farm member statistics.
In standalone mode:
display real-server statistics [ name real-server-name ] [ slot slot-number ]
display real-server statistics server-farm server-farm-name [ name real-server-name port port-number ] [ slot slot-number ]
In IRF mode:
display real-server statistics [ name real-server-name ] [ chassis chassis-number slot slot-number ]
display real-server statistics server-farm server-farm-name [ name real-server-name port port-number ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
name real-server-name: Specifies a real server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all real servers.
server-farm server-farm-name: Displays statistics for members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
name real-server-name port port-number: Displays statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays statistics for all members of a server farm.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays real server statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays real server statistics for all cards. (In IRF mode.)
# Display statistics for the real server rs.
<Sysname> display real-server statistics name rs
Real server: rs
Server input: 333332 bytes
Server output: 472054 bytes
Sent packets: 0
Dropped packets: 0
Received packets per second: 0
Sent packets per second: 0
Received requests: 0
Dropped requests: 0
Sent responses: 0
Dropped responses: 0
Connection failures: 1
Busy state: Busy
# Display statistics for all members of server farm sf.
<Sysname> display real-server statistics server-farm sf
Server farm: sf
Real server: rs1
Max connections: 0
Server input: 0 bytes
Server output: 0 bytes
Throughput: 0 bps
Received packets: 0
Sent packets: 0
Dropped packets: 0
Dropped requests: 0
Sent responses: 0
Connection failures: 0
RST packets: 50
Max RST packets: 5000
RST probe protection times: 3
Max RST probe protection times: 9
Zero-window packet percentage: 10
Max zero-window packet percentage: 50
Zero-window probe protection times: 2
Max zero-window probe protection times: 8
Real server: rs2
Max connections: 0
Throughput: 0 bps
Received packets: 0
Sent packets: 0
Dropped packets: 0
Dropped requests: 0
Sent responses: 0
RST packets: 50
Abnormal URL times: 10
Max abnormal URL times: 20
Table 33 Command output
Real server |
Real server name. |
Total connections |
Max connections |
Server input |
Traffic (in bytes) received by the server. |
Server output |
Traffic (in bytes) sent by the server. |
Throughput |
Max throughput |
Received packets |
Sent packets |
Dropped packets |
Received requests |
Number of received HTTP request packets. This field is displayed only for Layer 7 real servers. |
Dropped requests |
Number of dropped HTTP request packets. This field is displayed only for Layer 7 real servers. |
Sent responses |
Number of sent HTTP response packets. This field is displayed only for Layer 7 real servers. |
Dropped responses |
Number of dropped HTTP response packets. This field is displayed only for Layer 7 real servers. |
Connection failures |
Number of connection establishment failures. |
Busy state |
Real server state: · --—Unavailable. · Normal. · Busy. |
RST packets |
Number of RST packets sent by the real server during the monitoring time. |
Max RST packets |
Maximum number of RST packets sent by the real server during the monitoring time. |
RST probe protection times |
Number of probe times for the RST LB probe template. |
Max RST probe protection times |
Maximum number of probe times for the RST LB probe template. |
Zero-window packet percentageZero-window packet rate |
Percentage of zero-window packets sent by the real server during the monitoring time. |
Max zero-window packet percentageMax zero-window packet rate |
Maximum percentage of zero-window packets sent by the real server during the monitoring time. |
Zero-window probe protection times |
Number of probe times for the zero-window LB probe template. |
Max zero-window probe protection times |
Maximum number of probe times for the zero-window LB probe template. |
Abnormal URL times |
Number of URL error times during the current monitoring time during the monitoring time. |
Max abnormal URL times |
Maximum number of URL error times during the monitoring time. |
display server-farm
Use display server-farm to display server farm information.
display server-farm [ brief | name server-farm-name ]
context-admin
context-operator
vsys-admin
vsys-operator
brief: Displays brief server farm information. If you do not specify this keyword, the command displays detailed server farm information.
name server-farm-name: Displays information about the specified server farm. The server-farm-name argument specifies a server farm name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all server farms.
# Display brief information about all server farms.
<Sysname> display server-farm brief
HASH(SIP) - Hash address source IP,
HASH(DIP) - Hash address destination IP,
HASH(SIP-PORT) - Hash address source IP-port
LT - Least time, DRR - Dynamic round robin
CARP(SIP) - CARP address source IP
CARP(DIP) - CARP address destination IP
CARP(SIP-PORT) - CARP address source IP-port
CARP(HTTP) - CARP HTTP payload
HASH(HTTP) - Hash HTTP payload
Server farm Predictor NAT SNAT Total Active
sf RR Y N 3 3
# Display detailed information about all server farms.
Server farm: sf1
Description:
Proximity: Disabled
NAT: Enabled
SNAT mode: snat-pool sp
Failed action: Keep
Lower: 80
Upper: 90
Standby time: 5s
Ramp-up time: 10s
Selected server: Enabled
Min server: 100
Max server: 600
Busy action: Enqueue
Queue length: 11
Queue timeout: 12
Probe information:
Probe method:
aaa
bbb
ccc
TCP RST probe template: aaa
TCP zero-window probe template: bbb
HTTP passive probe template: ccc
Auto-shutdown recovery time: 30
All-service-down action: Forward
Forwarded to member: rs1
Total real server: 1
Active real server: 1
Real server list:
Name State VPN instance Address Port Weight Priority LT-weight
rs1 Inactive 1.2.3.4 0 4 100 50
rs2 Auto shutdown 1.2.3.4 0 4 100 50
Table 34 Command output
Server farm |
Server farm name. |
Predictor |
Scheduling algorithm of the server farm: · RR—Weighted round robin algorithm. · RD—Random algorithm. · LC—Weighted least connection algorithm. · BW—Bandwidth algorithm. · IBW—Inbound bandwidth algorithm. · OBW—Outbound bandwidth algorithm. · MBW—Maximum bandwidth algorithm. · MIBW—Maximum inbound bandwidth algorithm. · MOBW—Maximum outbound bandwidth algorithm. · HASH(SIP)—Hash algorithm based on source IP address. · HASH(DIP)—Hash algorithm based on destination IP address. · HASH(SIP-PORT)—Hash algorithm based on source IP address and port number. · LT—Least time algorithm. · DRR—Dynamic round robin algorithm. · CARP(SIP)—CARP hash algorithm based on source IP address. · CARP(DIP)—CARP hash algorithm based on destination IP address. · CARP(SIP-PORT)—CARP hash algorithm based on source IP address and port number. · CARP(HTTP)—CARP hash algorithm based on HTTP content. · HASH(HTTP)—Hash algorithm based on HTTP content. |
NAT |
NAT state of the server farm: · N—Disabled. · Y—Enabled. |
SNAT |
SNAT state of the server farm: · N—Disabled. · Y—Enabled. |
Total |
Total number of real servers. |
Active |
Number of active real servers. |
Description for the server farm. |
Proximity state of the server farm: · Disabled. · Enabled. |
NAT |
NAT state of the server farm: · Disabled—NAT is not configured. · Enabled. · Disabled (no license)—NAT is disabled because of lack of license. |
SNAT mode |
SNAT translation mode: · auto-map—Automatic mapping mode. · tcp-option—TCP option mode. · snat-pool—SNAT pool mode, which uses the SNAT address pool (specified by its name) to perform address translation. |
Failed action |
Fault processing method of the server farm: · Keep—Keeps existing connections. · Reschedule—Redirects connections. · Reset—Terminates existing connections. |
Active threshold |
State of the criteria to determine that the server farm is available: disabled or enabled. If the state is enabled, the following fields are displayed: · Lower—Lower percentage value. · Upper—Upper percentage value. |
Slow-online |
Selected server |
State of real server limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed: · Min server—Minimum number of real servers that participate in scheduling. · Max server—Maximum number of real servers that participate in scheduling. |
Health monitoring success criteria for the real server: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Busy action |
Action to take when the server farm is busy: · Drop. · Enqueue. · Force. |
Queue length |
This field is displayed only if the busy action is Enqueue. |
Queue timeout |
Probe method |
All-service-down action |
Indicates how packets are processed when all server farm members are unavailable: · --—Drop packets. · Forward—Forward packets to the last selected server farm member. |
Forwarded to member |
Last selected server farm member to which packets are forwarded. |
Total real server |
Active real server |
Name |
Real server name. |
State |
Real server state: · Active—The real server is available. · Busy—The real server is busy. When the real server is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The real server is unavailable, because the configuration is not complete, the server is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The real server is shut down. · Standby—Standby phase of slow online. · Unknown—Health monitoring is not configured. · Auto shutdown—The real server is automatically shut down when the RST or zero-window packet threshold is reached or the number of probe times is reached. |
Address |
IPv4 and IPv6 addresses of the real server. |
Port |
Port number of the real server. |
Weight |
Priority |
LT-weight |
Weight calculated by using the least time algorithm. This field displays a weight value only if the least time algorithm is used. If any other algorithm is used, this field displays two hyphens (--). |
TCP RST probe template |
TCP-RST LB probe template referenced by the server farm. This field is displayed only if a TCP-RST LB probe template is referenced. |
TCP zero-window probe template |
TCP zero-window LB probe template referenced by the server farm. This field is displayed only if a TCP zero-window LB probe template is referenced. |
HTTP passive probe template |
HTTP passive LB probe template referenced by the server farm. This field is displayed only if an HTTP passive LB probe template is referenced. |
Auto-shutdown recovery time |
Automatic recovery time for intelligent monitoring, in minutes. |
display sticky dns-proxy
Use display sticky dns-proxy to display sticky entry information for transparent DNS proxies.
In standalone mode:
display sticky dns-proxy [ dns-proxy-name dns-proxy-name ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | dns-server-addr { ipv4-address | ipv6-address } | dns-server-pool pool-name | dns-server-port port-number | key sticky-key ] * [ brief ] [ slot slot-number ]
In IRF mode:
display sticky dns-proxy [ dns-proxy-name dns-proxy-name ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | dns-server-addr { ipv4-address | ipv6-address } | dns-server-pool pool-name | dns-server-port port-number | key sticky-key ] * [ brief ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
dns-proxy dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays sticky entry information for all transparent DNS proxies.
class { class-name | default-class }: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters, or specifies the default LB class.
client-addr { ipv4-address | ipv6-address }: Specifies a client by its IPv4 or IPv6 address.
dns-server-addr { ipv4-address | ipv6-address }: Specifies a DNS server by its IPv4 or IPv6 address.
dns-server-pool pool-name: Specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server-port port-number: Specifies a DNS server port number in the range of 0 to 65535.
key sticky-key: Specifies a key value, a case-sensitive string of 1 to 36 characters.
brief: Displays brief information about sticky entries. If you do not specify this keyword, the command displays detailed information about sticky entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays sticky entry information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays sticky entry information for all cards. (In IRF mode.)
# Display detailed sticky entry information for all transparent DNS proxies.
<Sysname> display sticky dns-proxy
DNS proxy name: dsp1
DNS server pool name: dns-pool
Class: cl
Sticky type: Address-port
Sticky method: Source IP
Sticky key: 3.0.0.13
DNS proxy addr: 33.44.1.1:80
DNS server addr: 7.0.0.7:80
Client addr: 3.0.0.1
Timeout: 100 sec
Expiration time: 58 sec
# Display brief sticky entry information for all transparent DNS proxies.
<Sysname> display sticky dns-proxy brief
Sticky type Sticky method Sticky key DNS proxy DNS server addr
Address-port Src IP 3.0.0.13 dsp1 7.0.0.7:80
Address-port Src IP 3.0.0.15 dsp2 7.0.0.8:80
Table 35 Command output
Sticky group name |
Name of the sticky group that generates the sticky entries. |
Sticky method |
Sticky method corresponding to the sticky entries: · Src IP—Source IPv4 address sticky method. · Src IPv6—Source IPv6 address sticky method. · Src IP and port—Source IPv4 address + source port sticky method. · Src IPv6 and port—Source IPv6 address + source port sticky method. · Dst IP—Destination IPv4 address sticky method. · Dst IPv6—Destination IPv6 address sticky method. · Dst IP and port—Destination IPv4 address + destination port sticky method. · Dst IPv6 and port—Destination IPv6 address + destination port sticky method. · Both IP—Source IPv4 address + destination IPv4 address sticky method. · Both IPv6—Source IPv6 address + destination IPv6 address sticky method. · Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method. · Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method. |
Sticky key |
Key value corresponding to the sticky entry. |
Timeout |
Configured timeout time for sticky entries, in seconds. |
Expiration time |
Remaining lifetime of the sticky entry, in seconds. |
display sticky statistics
Use display sticky statistics to display sticky entry statistics
In standalone mode:
display sticky statistics [ dns-proxy | virtual-server ] [ slot slot-number ]
In IRF mode:
display sticky statistics [ dns-proxy | virtual-server ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
dns-proxy dns-proxy-name: Dispalys sticky entry statistics for transparent DNS proxies.
virtual-server: Displays sticky entry statistics for virtual servers.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays sticky entry statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays sticky entry statistics for all cards. (In IRF mode.)
If you do not specify the dns-proxy or virtual-server keyword, this command dispalys statistics for all sticky entries.
# Display sticky entry statistics for virtual servers.
<Sysname> display sticky statistics virtual-server
Virtual server:
Total sticky entries for all sticky types: 27000
Sticky type Sticky method Total sticky entries Synced sticky entries
Address-port 12000 120
Src IP 100 10
Src IPv6 100 10
Dst IP 100 10
Dst IPv6 100 10
Both IP 100 10
Both IPv6 100 10
Src IP port 100 10
Src IPv6 port 100 10
Dst IP port 100 10
Dst IPv6 port 100 10
Both IP port 100 10
Both IPv6 port 100 10
HTTP header 5000 50
HTTP version 100 10
HTTP URL 100 10
HTTP method 100 10
HTTP host 100 10
Header name 100 10
HTTP cookie Cookie get 100 10
HTTP content HTTP content 100 10
Payload Payload 100 10
SSL SSL session 100 10
RADIUS Attribute ID 200 20
SIP SIP Call-ID 100 10
HTTP passive HTTP Passive 100 10
UDP passive Payload Passive 100 10
TCP payload TCP Payload 100 10
# Display sticky entry statistics for transparent DNS proxies.
<Sysname> display sticky statistics dns-proxy
DNS proxy:
Total sticky entries for all sticky types: 12000
Src IP 100 10
Src IPv6 100 10
Dst IP 100 10
Dst IPv6 100 10
Both IP 100 10
Both IPv6 100 10
Src IP port 100 10
Dst IP port 100 10
Both IP port 100 10
Table 36 Command output
Sticky group name |
Sticky method |
Sticky method corresponding to the sticky entries: · Src IP—Source IPv4 address sticky method. · Src IPv6—Source IPv6 address sticky method. · Src IP and port—Source IPv4 address + source port sticky method. · Src IPv6 and port—Source IPv6 address + source port sticky method. · Dst IP—Destination IPv4 address sticky method. · Dst IPv6—Destination IPv6 address sticky method. · Dst IP and port—Destination IPv4 address + destination port sticky method. · Dst IPv6 and port—Destination IPv6 address + destination port sticky method. · Both IP—Source IPv4 address + destination IPv4 address sticky method. · Both IPv6—Source IPv6 address + destination IPv6 address sticky method. · Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method. · Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method. · HTTP URL—HTTP URL based sticky method. · HTTP header name—HTTP header name based sticky method. · HTTP version—HTTP version based sticky method. · HTTP host—HTTP host based sticky method. · HTTP method—HTTP Request-Method based sticky method. · HTTP content—HTTP entity sticky method. · Cookie get—HTTP cookie get sticky method. · Payload—HTTP or UDP payload sticky method. · HTTP passive—HTTP passive sticky method. · Payload passive—UDP payload passive sticky method. · TCP payload—TCP payload sticky method. · RADIUS IP—Sticky method based on the Framed-IP-Address attribute of RADIUS packets. · RADIUS ID—Sticky method based on the specified attribute of RADIUS packets. · SIP Call-ID—Sticky method based on the Call-ID header field of SIP packets. · SSL session ID—SSL sticky method based on SSL session ID. |
Synced sticky entries |
Number of sticky entries synchronized from other devices or other cards on the local device. |
display sticky virtual-server
Use display sticky virtual-server to display sticky entry information for virtual servers.
In standalone mode:
display sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | sticky-type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ brief ] [ slot slot-number ]
In IRF mode:
display sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | sticky-type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ brief ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
virtual-server virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays sticky entry information for all virtual servers.
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }: Specifies a link by its IPv4 address, IPv6 address, or output interface.
link-group link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
real-server-addr { ipv4-address | ipv6-address }: Specifies a real server by its IPv4 or IPv6 address.
real-server-port port-number: Specifies a real server port number in the range of 0 to 65535.
server-farm server-farm-name: Specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
text text: Specifies a text string to match.
sticky-type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }: Specifies a sticky group type.
key sticky-key: Specifies a key value, a case-sensitive string of 1 to 36 characters. If you do not specify key value, this command displays sticky entries for all key values.
# Display detailed sticky entry information for all virtual servers.
<Sysname> display sticky virtual-server
Virtual server name: vs
Server farm name: sf
Class: cla
Virtual server addr: 33.44.1.1:80
Real server addr: 7.0.0.7:80
Client addr: 3.0.0.13
Timeout: 100 sec
Virtual server name: vs1
Server farm name: sf_http
Class: Default Class
Sticky type: HTTP header
Sticky method: HTTP header name
Sticky key: cb3bae31bb1c443fbf3db8889055f2fe
Text: a1b2c3d4e5
Virtual server addr: 33.44.1.2:80
Timeout: 100 sec
Virtual server name: vs2
Link group name: lg
Class: cl2
Sticky key: 3.0.0.15
Virtual server addr: 0.0.0.0:0
link: 20.1.1.1
Client addr: 3.0.0.15
Timeout: 100 sec
# Display brief sticky entry information for all virtual servers.
<Sysname> display sticky virtual-server brief
Sticky type Sticky method Sticky key Virtual server Real-server/link
Address-port Src IP 3.0.0.13 vs 7.0.0.7:80
Address-port Src IP 3.0.0.15 vs2 20.1.1.1
Table 37 Command output
Sticky group name |
Sticky method |
Sticky method corresponding to the sticky entries: · Src IP—Source IPv4 address sticky method. · Src IPv6—Source IPv6 address sticky method. · Src IP and port—Source IPv4 address + source port sticky method. · Src IPv6 and port—Source IPv6 address + source port sticky method. · Dst IP—Destination IPv4 address sticky method. · Dst IPv6—Destination IPv6 address sticky method. · Dst IP and port—Destination IPv4 address + destination port sticky method. · Dst IPv6 and port—Destination IPv6 address + destination port sticky method. · Both IP—Source IPv4 address + destination IPv4 address sticky method. · Both IPv6—Source IPv6 address + destination IPv6 address sticky method. · Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method. · Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method. · HTTP URL—HTTP URL based sticky method. · HTTP header name—HTTP header name based sticky method. · HTTP version—HTTP version based sticky method. · HTTP host—HTTP host based sticky method. · HTTP method—HTTP Request-Method based sticky method. · HTTP content—HTTP entity sticky method. · Cookie get—HTTP cookie get sticky method. · Payload—HTTP or UDP payload sticky method. · HTTP passive—HTTP passive sticky method. · Payload passive—UDP payload passive sticky method. · TCP payload—TCP payload sticky method. · Framed-IP-Address—Sticky method based on the Framed-IP-Address attribute of RADIUS packets. · User-Name—Sticky method based on the User-Name attribute of RADIUS packets. · Code=attribute-code—Sticky method based on the attribute (specified by attribute-code) of RADIUS packets. · SIP Call-ID—Sticky method based on the Call-ID header field of SIP packets. · SSL session ID—SSL sticky method based on SSL session ID. |
Sticky key |
Timeout |
Expiration time |
display sticky-group
Use display sticky-group to display sticky group information.
display sticky-group [ name group-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name group-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all sticky groups.
# Display information about all sticky groups.
<Sysname> display sticky-group
Sticky group: sg1
Description:
Timeout: 60
Override limit: Disabled
Stickiness-over-busyness: Enabled
Matching across services: Enabled
Matching across virtual servers: Enabled
Sticky group type: Address-port
Method: Both IP and port
Mask: 32
Sticky group: sg2
Description:
Timeout: 60
Sticky group type: HTTP header
Method: HTTP header name
Offset: 4
Start: gzip
Length: 10
Sticky group: sg3
Description:
Timeout: 60
Sticky group type: RADIUS
Method: User-Name
Sticky group: sg4
Description:
Timeout: 86400
Stickiness-over-busyness: Disabled
Sticky group type: HTTP cookie
Method: HTTP cookie insert
Domain: test.com
Path: /test1
HttpOnly: Enabled
Secure: Enabled
Check all packets: Disabled
Table 38 Command output
Sticky group |
Sticky group name. |
Description for the sticky group. |
Timeout |
Timeout time for sticky entries in seconds. The value Infinite indicates that sticky entries never age out. |
Override limit |
Whether the feature of ignoring the limits for sessions that match sticky entries is enabled: Enabled or Disabled. |
Stickiness-over-busyness |
Whether the stickiness-over-busyness feature is enabled: Enabled or Disabled. |
Sticky group type |
Sticky group type: · Address-port—Address and port. · HTTP content—HTTP entity. · HTTP cookie. · HTTP header. · HTTP passive. · Payload—HTTP or UDP payload. · RADIUS. · SIP. · SSL. · UDP passive. · TCP payload. |
Table 39 Detailed information for sticky groups
Sticky group type |
Address-port |
Method |
Sticky method: · Source IP—Source IPv4 address sticky method. · Source IPv6—Source IPv6 address sticky method. · Source IP and port—Source IPv4 address + source port sticky method. · Source IPv6 and port—Source IPv6 address + source port sticky method. · Destination IP—Destination IPv4 address sticky method. · Destination IPv6—Destination IPv6 address sticky method. · Destination IP and port—Destination IPv4 address + destination port sticky method. · Destination IPv6 and port—Destination IPv6 address + destination port sticky method. · Both IP—Source IPv4 address + destination IPv4 address sticky method. · Both IPv6—Source IPv6 address + destination IPv6 address sticky method. · Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method. · Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method. |
Mask |
Mask length for the sticky method. This field is displayed only for IPv4 sticky methods. |
Prefix |
Prefix length for the sticky method. This field is displayed only for IPv6 sticky methods. |
HTTP content |
Offset |
Offset value of the entity based on the start of the HTTP packet. |
Start |
Regular expression that marks the start of the entity. |
End |
Regular expression that marks the end of the entity. Either this field or the Length field is displayed, but not both of them. |
Length |
Length of the entity. Either this field or the End field is displayed, but not both of them. |
HTTP cookie |
Method |
Sticky method: · HTTP cookie insert—Cookie insert sticky method. · HTTP cookie rewrite—Cookie rewrite sticky method. · HTTP cookie get—Cookie get sticky method. This field is displayed only for the HTTP cookie sticky method. |
Name |
HTTP cookie name. This field is displayed only for the HTTP cookie sticky method. |
Domain |
Domain scope of the cookie. This field is displayed only for the HTTP cookie insert sticky method. |
Path |
Path scope of the cookie. This field is displayed only for the HTTP cookie insert sticky method. |
Offset |
Offset value based on the start of the cookie value. This field is displayed only for the cookie insert sticky method. |
Start |
Regular expression that marks the start of the cookie. This field is displayed only for the cookie insert sticky method. |
End |
Regular expression that marks the end of the cookie. Either this field or the Length field is displayed, but not both of them. This field is displayed only for the cookie insert sticky method. |
Length |
Length of the cookie. Either this field or the End field is displayed, but not both of them. This field is displayed only for the cookie insert sticky method. |
Cookie secondary name |
Name of the secondary cookie to be searched in the URI. This field is displayed only for the cookie insert sticky method. |
HttpOnly |
HttpOnly attribute of the cookie. This field is displayed only for the HTTP cookie insert or cookie rewrite sticky method. |
Secure |
Secure attribute of the cookie. This field is displayed only for the HTTP cookie insert or cookie rewrite sticky method. |
Check all packets |
Whether or not to enable checking for all packets. |
HTTP header |
Method |
Sticky method: · HTTP host—HTTP host based sticky method. · HTTP header name—HTTP header name based sticky method. · HTTP method—HTTP Request-Method based sticky method. · HTTP URL—HTTP URL based sticky method. · HTTP version—HTTP version based sticky method. This field is displayed only for the HTTP header sticky method. |
Name |
HTTP header name. This field is displayed only for the HTTP header name based sticky method. |
Offset |
Offset value of the HTTP header based on the start of the HTTP packet. This field is displayed only for the HTTP host or URL based sticky method. |
Start |
Regular expression that marks the start of the HTTP header. This field is displayed only for the HTTP host or URL based sticky method. |
End |
Regular expression that marks the end of the HTTP header. Either this field or the Length field is displayed, but not both of them. This field is displayed only for the HTTP host or URL based sticky method. |
Length |
Length of the HTTP header. Either this field or the End field is displayed, but not both of them. This field is displayed only for the HTTP host or URL based sticky method. |
Payload |
Offset |
Offset value of the HTTP or UDP payload based on the start of the HTTP packet. |
Start |
Regular expression that marks the start of the HTTP or UDP payload. |
End |
Regular expression that marks the end of the HTTP or UDP payload. Either this field or the Length field is displayed, but not both of them. . |
Length |
Length of the HTTP or UDP payload. Either this field or the End field is displayed, but not both of them. |
RADIUS |
Method |
Sticky method: · Framed-IP-Address—Sticky method based on the Framed-IP-Address attribute of RADIUS packets. · User-Name—Sticky method based on the User-Name attribute of RADIUS packets. · Code=attribute-code—Sticky method based on the attribute (specified by attribute-code) of RADIUS packets. This field is not displayed if no RADIUS attribute based sticky method is specified. |
SIP |
Method |
Sticky method, which can only be SIP Call-ID (SIP sticky method based on the Call-ID header field of SIP packets). |
SSL |
Method |
Sticky method, which can only be SSL session ID (SSL sticky method based on SSL session ID). This field is displayed only for the SSL sticky method based on SSL session ID. |
HTTP passive |
Method |
Sticky method: · HTTP header name—HTTP header name sticky method. · HTTP URL—HTTP URL sticky method. · HTTP content—HTTP content sticky method. |
Get |
Obtains the specified string in HTTP responses. |
Match |
Matches the specified string in HTTP requests. |
Name |
Start |
Regular expression that marks the start of the HTTP header. |
End |
Regular expression that marks the end of the HTTP header. Either this field or the Length field is displayed, but not both of them. |
Length |
Length of the HTTP header. Either this field or the End field is displayed, but not both of them. |
UDP passive |
Get |
Obtains the specified string in UDP responses. |
Match |
Matches the specified string in UDP requests. |
Start |
Regular expression that marks the start of the UDP payload. |
End |
Regular expression that marks the end of the UDP payload. Either this field or the Length field is displayed, but not both of them. |
Length |
Length of the UDP payload. Either this field or the End field is displayed, but not both of them. |
TCP payload |
Offset |
Offset value of the TCP payload based on the start of the TCP packet. |
Start |
Regular expression that marks the start of the TCP payload. |
End |
Regular expression that marks the end of the TCP payload. Either this field or the Length field is displayed, but not both of them. |
Length |
Length of the TCP payload. Either this field or the End field is displayed, but not both of them. |
display virtual-server
Use display virtual-server to display virtual server information.
display virtual-server [ brief | name virtual-server-name ]
context-admin
context-operator
vsys-admin
vsys-operator
brief: Displays brief virtual server information. If you do not specify this keyword, the command displays detailed virtual server information.
name virtual-server-name: Displays information about the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all virtual servers.
# Display brief information about all virtual servers.
<Sysname> display virtual-server brief
Virtual server State Type VPN instance Virtual address Port
vs1 Inactive IP 192.168.21.148/32 80
1111:2222:3333:4444
:5555:6666:7777:888
8/128
vs2 Active HTTP 61.159.4.100/32 8080
vs3 Active LINK-IP 51.139.4.100/32 0
vs4 Active MySQL 12.139.5.132/32 3306
# Display detailed information about all virtual servers.
Virtual server: vs
Description: Virtual server VS
Type: HTTP
State: Active
VPN instance:
Virtual IPv4 address: 1.1.1.1/32
Virtual IPv6 address: 1001::1/128
Port: 0 (any port)
Primary server farm: sf (in use)
Backup server farm: sfb
Primary sticky: sg3
Backup sticky: sg4
LB policy: lbp2
LB limit-policy:
TCP parameter profile (client-side): ptc
TCP parameter profile (server-side): pts
HTTP parameter profile: pp1
HTTP-statistics parameter profile: 1
OneConnect parameter profile: one
UDP per-packet: Enabled
Connection limit: 10000
Rate limit:
Connections: 10000
Bandwidth: 10000 kbps
Inbound bandwidth: 5000 kbps
Outbound bandwidth: 5000 kbps
SSL server policies with SNI list:
Server name indication: www.aaa.com
Server name indication: www.bbb.com
SSL server policy: ssl-server
SSL client policy: ssl-client
Redirect relocation:
Redirect return-code: 302
VRRP IPv4 Info:
VRRP IPv4 VRID: 1
VRRP IPv6 info:
VRRP IPv6 VRID: 3
Sticky: test
Sticky synchronization: Disabled
Bandwidth busy protection: Disabled
Interface bandwidth statistics: Disabled
Route advertisement: Enabled
ARP/ND interfaces:
HTTP protection policy: p1
Customlog content: %{is};%{ps}
External-link proxy: Enabled
External-link inject URI: proxy
External-link inject domain suffix: c.com
External-link SNAT pool: spool1
External-link domain name whitelist:
a.com
b.com
Virtual server: vstcp
Type: TCP
State: Active
VPN instance:
Port: 8080
Sticky: sg3
LB policy: lbp2
LB limit-policy:
TCP-Application parameter profile: ptapp
Rate limit:
Connections: 10000
Application-Mode: Enabled
ARP/ND interfaces:
# Display detailed information about the virtual server lk.
<Sysname> display virtual-server name lk
Virtual server: lk
Description:
Type: Link-IP
State: Active
VPN instance:
Port: 0
Primary link group: lg1 (in use)
Backup link group: lg2
Sticky: sg3
LB policy: lbp2
LB limit-policy:
Rate limit:
Connections: 10000
Connection synchronization: Disabled
Route advertisement: Disabled
ARP/ND interfaces:
# Display detailed information about the virtual server vs4.
<Sysname> display virtual-server name vs4
Virtual server: vs4
Description: Virtual server VS4
Type: MySQL
State: Active
VPN instance:
Port: 3306
Sticky: sg3
LB policy: lbp2
LB limit-policy:
MySQL parameter profile: my
Rate limit:
Connections: 10000
ARP/ND interfaces:
Version: 5.6
User list:
Username: wangping
Username: liqiang
Read server farm: rd
Read sticky group: rsg
Write server farm: wr
Write sticky group: wsg
Table 40 Command output
Virtual server |
Virtual server name. |
State |
Virtual server state: · Active—The virtual server is available. · Inactive—The virtual server is unavailable for any reason other than lack of license and disabled virtual server. · Inactive (no license)—The virtual server is unavailable because of lack of license. · Inactive (disabled)—The virtual server is unavailable because the virtual server is disabled. |
Type |
Virtual server type: HTTP, IP, MySQL, RADIUS, TCP, UDP, or link-IP. |
Name of the VPN instance to which the virtual server belongs. |
Virtual address |
IPv4 address and mask of the virtual server. |
Port |
Port number of the virtual server. 0 means any port. |
Description of the virtual server. |
Virtual IPv4 address |
Virtual IPv6 address |
IPv6 address and prefix of the virtual server. |
Primary server farm |
Default primary server farm name. (in use) indicates the server farm is in use. |
Backup server farm |
Default backup server farm name. (in use) indicates the server farm is in use. |
Primary link group |
Default primary link group name. (in use) indicates the link group is in use. |
Backup link group |
Default backup link group name. (in use) indicates the link group is in use. |
Primary sticky |
Default primary sticky group name. |
Backup sticky |
Backup sticky group name. This field is displayed only for HTTP and RADIUS virtual servers. |
LB policy |
LB policy referenced by the virtual server. |
HTTP parameter profile |
HTTP parameter profile referenced by the virtual server. This field is displayed only if an HTTP parameter profile is configured. |
IP parameter profile |
IP parameter profile referenced by the virtual server. This field is displayed only if an IP parameter profile is configured. |
TCP parameter profile |
TCP parameter profile referenced by the virtual server. This field is displayed only if a TCP parameter profile is configured. |
TCP parameter profile (client-side) |
Client-side TCP parameter profile referenced by the virtual server. This field is displayed only if a client-side TCP parameter profile is configured. |
TCP parameter profile (server-side) |
Server-side TCP parameter profile referenced by the virtual server. This field is displayed only if a server-side TCP parameter profile is configured. |
OneConnect parameter profile |
OneConnect parameter profile referenced by the virtual server. This field is displayed only if a OneConnect parameter profile is configured. |
HTTP-statistics parameter profile |
HTTP statistics parameter profile referenced by the virtual server. This field is displayed only if an HTTP statistics parameter profile is configured. |
TCP-Application parameter profile |
TCP-application parameter profile referenced by the virtual server. This field is displayed only if a TCP-application parameter profile is configured. |
MySQL parameter profile |
MySQL parameter profile referenced by the virtual server. This field is displayed only if a MySQL parameter profile is configured. |
UDP per-packet |
State of the per-packet load balancing for UDP traffic: · Disabled. · Enabled. This field is displayed only for UDP virtual servers. |
Connection limit |
Maximum number of connections of the virtual server. |
Rate limit |
Rate limit of the virtual server. |
Connections |
Maximum number of connections per second of the virtual server. |
Bandwidth |
Maximum bandwidth for the virtual server in kbps. |
Inbound bandwidth |
Maximum inbound bandwidth for the virtual server in kbps. |
Outbound bandwidth |
Maximum outbound bandwidth for the virtual server in kbps. |
SSL server policies with SNI list |
List of SSL server policies with SNIs. This field is displayed only for TCP-type and HTTP-type virtual servers. |
Server name indication |
Server name indication. This field is displayed only for TCP-type and HTTP-type virtual servers. |
SSL server policy |
SSL server policy name. This field is displayed only for HTTP-type virtual servers. |
SSL client policy |
SSL client policy name. This field is displayed only for HTTP-type virtual servers. |
Redirect relocation |
Redirection URL. This field is displayed only for HTTP-type virtual servers. |
Redirect return-code |
Status code in the redirection packets. This field is displayed only for HTTP-type virtual servers. |
VRRP IPv4 Info |
Information about the IPv4 VRRP group bound to the virtual server. |
VRRP IPv4 VRID |
Virtual router ID of the VRRP group bound to the virtual server. |
Interface on which the VRRP group bound to the virtual server is created. |
VRRP IPv6 Info |
Information about the IPv6 VRRP group bound to the virtual server. |
VRRP IPv6 VRID |
Virtual router ID of the IPv6 VRRP group bound to the virtual server. |
Sticky |
Sticky group for the virtual server. This field is displayed only for HTTP-type virtual servers. |
Session extension information synchronization state: Enabled or Disabled. This field is not displayed for HTTP-type virtual servers. |
Sticky entry synchronization state: Enabled or Disabled. |
Link protection state: Enabled or Disabled. |
Interface bandwidth statistics |
Bandwidth statistics collection by interfaces: Disabled or Enabled. |
Route advertisement |
IP address advertisement for the virtual server: Disabled or Enabled. |
Application-Mode |
Layer 7 operating mode for the virtual server: Disabled or Enabled. This field is displayed only for a TCP virtual server. |
ARP/ND interfaces |
Interfaces from which gratuitous ARP packets and ND packets are sent out. |
Version |
MySQL database version. This field is displayed only for a MySQL virtual server. |
User list |
List of users logged in to the MySQL database. This field is displayed only for a MySQL virtual server. |
Username |
Username used to log in to the MySQL database. This field is displayed only for a MySQL virtual server. |
Read server farm |
Read server farm referenced by the MySQL virtual server. This field is displayed only for a MySQL virtual server. |
Read sticky group |
Sticky group associated with the read server farm. This field is displayed only for a MySQL virtual server. |
Write server farm |
Write server farm referenced by the MySQL virtual server. This field is displayed only for a MySQL virtual server. |
Write sticky group |
Sticky group associated with the write server farm. This field is displayed only for a MySQL virtual server. |
Customlog content |
Content output by using the fast log output feature. This field is displayed only for an HTTP virtual server. |
HTTP protection policy |
HTTP protection policy referenced by the virtual server. |
External-link proxy |
External link proxy state: Disabled or Enabled. |
External-link inject URI |
URI of external link proxy. |
External-link inject domain suffix |
Domain name suffix of external link proxy. |
External-link SNAT pool |
SNAT address pool of external link proxy. |
External-link domain name whitelist |
Whitelist of external link proxy. |
display virtual-server statistics
Use display virtual-server statistics to display virtual server statistics.
In standalone mode:
display virtual-server statistics [ name virtual-server-name ] [ slot slot-number ]
In IRF mode:
display virtual-server statistics [ name virtual-server-name ] [ chassis chassis-number slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
name virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics of all virtual servers.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays virtual server statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays virtual server statistics for all cards. (In IRF mode.)
# Display statistics for the virtual server vs.
<Sysname> display virtual-server statistics name vs
Virtual server: vs
Total connections: 979
Active connections: 618
Max connections: 661
recorded at 11:02:49 on Tue May 21 2019
Connections per second: 146
Max connections per second: 156
Client input: 333332 bytes
Client output: 472054 bytes
Throughput: 4088 bps
Inbound throughput: 1214 bps
Outbound throughput: 2874 bps
Max throughput: 4368 bps
Max inbound throughput: 1214 bps
Max outbound throughput: 3154 bps
Received packets: 979
Sent packets: 0
Dropped packets: 0
Authentication permitted requests: 0
Authentication denied requests: 0
Redirected requests for login: 4
Redirected requests for re-authentication: 0
Table 41 Command output
Virtual server |
Total connections |
Total number of connections. |
Active connections |
Number of active connections. |
Max connections |
Maximum number of connections. |
Connections per second |
Number of connections per second. |
Max connections per second |
Maximum number of connections per second. |
Client input |
Traffic (in bytes) received from the client. |
Client output |
Traffic (in bytes) sent to the client. |
Throughput |
Total packet throughput in bps. |
Inbound throughput |
Inbound packet throughput in bps. |
Outbound throughput |
Outbound packet throughput in bps. |
Max throughput |
Maximum packet throughput in bps. |
Max throughput |
Maximum inbound packet throughput in bps. |
Max throughput |
Maximum outbound packet throughput in bps. |
Received packets |
Number of received packets. |
Sent packets |
Number of packets sent by the virtual server to the client. |
Dropped packets |
Number of dropped packets. |
Received requests |
Number of received HTTP request packets. This field is displayed only for HTTP-type virtual servers. |
Dropped requests |
Number of dropped HTTP request packets. This field is displayed only for HTTP-type virtual servers. |
Sent responses |
Number of sent HTTP response packets. This field is displayed only for HTTP-type virtual servers. |
Dropped responses |
Number of dropped HTTP response packets. This field is displayed only for HTTP-type virtual servers. |
Authentication permitted requests |
Number of permitted requests after authentication. |
Authentication denied requests |
Number of denied requests after authentication. |
Redirected requests for login |
Number of requests redirected to the login page. |
Redirected requests for re-authentication |
Number of requests redirected to the reauthentication page. |
reset virtual-server statistics
dns-server (DNS server pool view)
Use dns-server to create a DNS server pool member and enter its view, or enter the view of an existing DNS server pool member.
Use undo dns-server to delete a DNS server pool member.
dns-server dns-server-name port port-number
undo dns-server dns-server-name port port-number
No DNS server pool members exist.
context-admin
dns-server-name: Specifies a DNS server pool member name, a case-insensitive string of 1 to 63 characters.
port-number: Specifies the port number of the DNS server pool member, in the range of 0 to 65535.
Non-default vSystems do not support this command.
You can use one of the following methods to add a member to a DNS server pool:
· Use the dns-server command in DNS server pool view. H3C recommends using this method.
· Use the dns-server-pool command in DNS server view.
You cannot use both methods to add a member with the same DNS server name and port number to a DNS server pool.
# Add DNS server pool member ds1 and enter DNS server pool member view.
[Sysname] loadbalance dns-server-pool dsp1
[Sysname-lb-dspool-dsp1] dns-server ds1 port 10
[Sysname-lb-dspool-dsp1-#member#-ds1-port-10]
dns-server-pool (DNS server view)
Use dns-server-pool to specify a DNS server pool for a DNS server.
Use undo dns-server-pool to restore the default.
A DNS server does not belong to any DNS server pool.
DNS server view
context-admin
You can specify a DNS server pool that has not been created.
# Specify DNS server pool dns-pool1 for DNS server ds1.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] dns-server-pool dns-pool1
display loadbalance dns-server
dns-server-pool (LB action view)
Use dns-server-pool to specify a DNS server pool for guiding packet forwarding.
dns-server-pool pool-name [ sticky sticky-name ]
No DNS server pool is specified for guiding packet forwarding.
DNS LB action view
context-admin
sticky sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a sticky group, the DNS server pool does not correspond to any sticky group.
This command is mutually exclusive with the forward all or skip current-dns-proxy command. If you configure one command, the other command (if configured) is automatically cancelled.
# Specify the DNS server pool dsp and the sticky group sg1 for DNS LB action lba1.
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] dns-server-pool dsp sticky st1
forward all
domain-name
Use domain-name to specify a domain name for a DNS mapping.
Use undo domain-name to delete a domain name from a DNS mapping.
domain-name domain-name
undo domain-name domain-name
No domain name is specified for a DNS mapping.
DNS mapping view
context-admin
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. Each dot-separated label in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), dots (.), and wildcards (asterisks and question marks). Dots cannot be used as the start and end characters.
You can specify multiple domain names for a DNS mapping.
When you use wildcards (asterisks and question marks) in a domain name, follow these guidelines:
· An asterisk (*) can substitute a character string.
· A question mark (?) can substitute any single character except for dot (.).
# Specify two domain names for the DNS mapping dm1.
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] domain-name www.aaa.domain.com
[Sysname-lb-dm-dm1] domain-name ???.aaa.*.com
encrypt-cookie
Use encrypt-cookie to encrypt a cookie.
Use undo encrypt-cookie to remove the encryption for a cookie.
encrypt-cookie name cookie-name key { cipher | simple } string
undo encrypt-cookie name cookie-name
No cookie is encrypted.
HTTP parameter profile view
context-admin
vsys-admin
name cookie-name: Specifies a cookie by its name, a case-sensitive string of 1 to 63 characters.
key: Specifies a key used to encrypt the cookie.
cipher: Specifies a key in ciphertext form.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in ciphertext form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its ciphertext form is a case-sensitive string of 1 to 73 characters.
After you execute this command, the device encrypts the Set-Cookie field in HTTP responses to prevent personal information from being revealed. When a client request contains an encrypted cookie, the device decrypts the cookie before sending the request to the server.
# For HTTP parameter profile p1, encrypt cookie cookie1 with encryption key 123456.
[Sysname] parameter-profile p1 type http
[Sysname-para-http-p1] encrypt-cookie name cookie1 key simple 123456
env-variables
Use env-variables to configure an environment variable for custom monitoring.
Use undo env-variables to delete an environment variable for custom monitoring.
env-variables variable-name value variable-value
undo env-variables variable-name
No environment variables are configured for custom monitoring.
Custom-monitoring LB probe template view
context-admin
variable-name: Specifies the environment variable name, a case-sensitive string of 1 to 63 characters. The name can contain spaces.
value variable-value: Specifies an environment variable value, a case-sensitive string of 1 to 255 characters. The name can contain spaces and cannot contain quotation marks (").
You can specify the environment to execute the custom script file by configuring an environment variable.
You can configure a maximum of 16 environment variables.
# In custom-monitoring LB probe template test_external, configure an environment variable with name env and value /var/tmp.
[Sysname] loadbalance probe-template external-monitor test_external
[Sysname-lbpt-external-monitor-test_external] env-variables env value /var/tmp
exceed-mss
Use exceed-mss to specify the action to take on the segments that exceed the MSS in the HTTP requests sent by the client.
Use undo exceed-mss to restore the default.
exceed-mss { allow | drop }
undo exceed-mss
The device allows the segments to exceed the MSS in the HTTP requests sent by the client.
TCP parameter profile view
context-admin
vsys-admin
allow: Allows the segments to exceed the MSS.
drop: Discards the segments that exceed the MSS.
# For the TCP parameter profile pp3, specify the drop action for the segments that exceed the MSS in the HTTP requests sent by the client.
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] exceed-mss drop
expire
Use expire to set the expiration time for SOA resource records.
Use undo expire to restore the default.
expire expire-time
undo expire
The expiration time is 86400 seconds.
SOA view
context-admin
expire-time: Specifies the expiration time in the range of 500 to 4294967295 seconds.
The expiration time for SOA resource records is the amount of time that the secondary DNS server can work after it loses contact with the primary DNS server.
# Set the expiration time for SOA resource records to 7 days for DNS forward zone abc.com.
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com] soa
[Sysname-lb-zone-abc.com-soa] expire 604800
display loadbalance zone
external-link inject-domain-suffix
Use external-link inject-domain-suffix to configure the domain name suffix for external link proxy.
Use undo external-link inject-domain-suffix to delete the domain name suffix for external link proxy.
external-link inject-domain-suffix domain-suffix
No domain name suffix is configured for external link proxy.
HTTP virtual server view
context-admin
domain-suffix: Specifies the domain name suffix for rewriting domain names of external links. This argument is a case-insensitive, dot-separated string of 1 to 254 characters (for example, example.com). Each dot-separated label in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
If DNS packet link selection is performed by inbound link load balancing, make sure the domain name suffixes in DNS mappings are the same as those on the external link proxy.
# Configure the domain name suffix as b.com for external link proxy on HTTP virtual server vs.
[Sysname] virtual-server vs http
[Sysname-vs-http-vs] external-link inject-domain-suffix b.com
external-link inject-uri
external-link proxy enable
Use external-link inject-uri to configure the URI for external link proxy.
Use undo external-link inject-uri to delete the URI for external link proxy.
external-link inject-uri string
No URI is configured for external link proxy.
context-admin
string: Specifies the URI for rewriting domain names of external links. This argument is a case-insensitive string of 1 to 63 characters. The URI can contain letters, digits, hyphens (-), and underscores (_), and cannot contain dots (.).
Use this command to rewrite domain names of external links. Upon receiving a response from the IPv6 site server, the LB device rewrites the IPv4 external link in the response by adding the specified parameters to the associated domain name. The parameters include the URI, domain name suffix, and virtual server port number. Suppose the domain name of the original external link is http://www.aaa.com, URI is proxy, domain name suffix is bbb.com, and virtual server port number is 8080. The external link domain name after rewrite is http://www.aaa.com.proxy.bbb.com:8080. Upon receiving a DNS request containing this modified domain name, the LB device performs the following operations:
1. Extracts the original domain name.
2. Requests the associated IPv4 resource on behalf of the IPv6 client.
3. Returns the obtained IPv4 resource to the IPv6 client.
# Configure the URI as proxy for external link proxy on HTTP virtual server vs.
[Sysname-vs-http-vs] external-link inject-uri proxy
external-link proxy enable (LB action view)
Use external-link proxy enable to enable external link proxy.
Use undo external-link proxy enable to disable external link proxy.
External link proxy is disabled.
HTTP LB action view
context-admin
To perform external link proxy for a traffic class instead of all traffic of a virtual server, enable external link proxy in an HTTP LB action. Additionally, configure external link proxy parameters in the view of the virtual server and specify the LB policy for the virtual server.
The external link proxy action is first taken when the following actions are also configured:
· A forwarding LB action.
· HTTP redirection action.
· Specifying a response file for matching HTTP requests.
· Specifying a response file used upon load balancing failure.
# Enable external link proxy for HTTP LB action a1.
[Sysname] loadbalance action a1 type http
[Sysname-lba-http-a1] external-link proxy enable
display loabalance action
external-link proxy enable (virtual server view)
context-admin
This command enables the LB device to operate as a proxy to request IPv4 resources on behalf of IPv6 clients. External link proxy operates as follows:
1. The LB device receives an IPv6 DNS request containing an IPv4 link, and sends the request to the IPv6 site server.
2. Upon receiving a response from the server, the LB device returns a script file with the external link rewritten as configured to the client.
3. The client executes the script file, modifies the external link domain name as instructed, and then sends another DNS request containing the modified domain name.
4. Upon receiving the request, the LB device extracts the original domain name and requests the associated IPv4 resource on behalf of the client.
5. The LB device returns the obtained IPv4 resource to the client.
# Enable external link proxy for HTTP virtual server vs.
[Sysname-vs-http-vs] external-link proxy enable
external-link snat-pool
Use external-link snat-pool to specify the SNAT address pool for external link proxy.
Use undo external-link snat-pool to restore the default.
external-link snat-pool pool-name
No SNAT address pool is specified for external link proxy.
context-admin
pool-name: Specifies a SNAT address pool by its name, a case-insensitive string of 1 to 63 characters.
To request an IPv4 resource as an external link proxy, the LB device will choose an IP address from the specified SNAT pool. The LB device uses this IP address as the client IP address to initiate a request on behalf of the IPv6 client.
If you do not specify a SNAT address pool, the LB device uses the IP address of the output interface to the server as the client IP address.
# Specify the SNAT address pool as spool1 for external link proxy on HTTP virtual server vs.
[Sysname-vs-http-vs] external-link snat-pool spool1
loadbalance snat-pool
external-link whitelist domain
Use external-link whitelist domain to add a domain name to the whitelist for external link proxy.
Use undo external-link whitelist domain to delete a domain name from the whitelist for external link proxy.
external-link whitelist domain domain-name
undo external-link whitelist domain domain-name
No domain names are added to the whitelist for external link proxy.
context-admin
domain-name: Specifies a domain name, a case-insensitive, dot-separated string of 1 to 254 characters. Each dot-separated label in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
The LB device does not rewrite the external links containing any domain names in the whitelist. You can add specific domain names (for example, those of the IPv6 external links in the IPv6 site) to the whitelist.
# Add domain name a.com to the whitelist for external link proxy on HTTP virtual server vs.
[Sysname-vs-http-vs] external-link whitelist domain a.com
external-script
Use external-script to specify a script file used for custom monitoring.
Use undo external-script to restore the default.
external-script file-name
No script file is specified for custom monitoring.
context-admin
file-name: Specifies a script file by its name, a case-insensitive string of 1 to 255 characters.
The device detects the state of real severs according to the detection contents in the script file.
Before specifying a script file, upload the file to the device.
The device supports specifying only script files with the .py suffix.
# In custom-monitoring LB probe template test_external, use script file test.py for custom monitoring.
[Sysname] loadbalance probe-template external-monitor test-external
[Sysname-lbpt-external-monitor-test-external] external-script test.py
fail-action (link group view)
Use fail-action to specify the fault processing method for a link group.
Use undo fail-action to restore the default.
fail-action { keep | reschedule | reset }
undo fail-action
The fault processing method is to keep existing connections.
Link group view
context-admin
keep: Keeps the connection with the failed link. Keeping or terminating the connection depends on the timeout mechanism of the protocol.
reschedule: Redirects the connection to another available link in the link group.
reset: Terminates the connection with the failed link by sending RST packets (for TCP packets) or ICMP unreachable packets (for other types of packets).
The fault processing method applies when the link that processes packets fails.
# Specify the fault processing method for the link group lg as reschedule.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] fail-action reschedule
fail-action (server farm view)
Use fail-action to specify the fault processing method for a server farm.
undo fail-action
Server farm view
context-admin
vsys-admin
keep: Keeps the connection with the failed real server. Keeping or terminating the connection depends on the timeout mechanism of the protocol.
reschedule: Redirects the connection to another available real server in the server farm.
reset: Terminates the connection with the failed real server by sending RST packets (for TCP packets) or ICMP unreachable packets (for other types of packets).
The fault processing method applies when the real server that processes packets fails.
# Specify the fault processing method for the server farm sf as reschedule.
[Sysname] server-farm sf
[Sysname-sfarm-sf] fail-action reschedule
fallback
Use fallback to specify a processing method for DNS mapping search failure.
Use undo fallback to restore the default.
fallback { dns-proxy | no-response | reject }
undo fallback
A DNS listener sends a DNS reject packet for DNS mapping search failure.
DNS listener view
context-admin
dns-proxy: Responds to DNS requests through a transparent DNS proxy.
no-response: Does not respond to DNS requests.
reject: Sends a DNS reject packet.
# Specify the processing method for DNS mapping search failure as no-response.
[Sysname] loadbalance dns-listener ct-listener
[Sysname-lb-dl-ct-listener] fallback no-response
fallback-action close
Use fallback-action close to configure the method of closing TCP connections upon failure to find a real server.
Use undo fallback-action to restore the default.
fallback-action close { fin | rst }
Packets are dropped when no real servers are available for the current LB action.
Generic/HTTP LB action view
context-admin
vsys-admin
fin: Closes TCP connections by sending FIN packets.
rst: Closes TCP connections by sending RST packets.
This command enables the device to close TCP connections matching the LB policy by sending FIN or RST packets if the device fails to find a real server according to the LB action.
# In HTTP LB action a1, configure the method of closing TCP connections by sending RST packets.
[Sysname-lba-http-a1] fallback-action close rst
fallback-action continue
Use fallback-action continue to match the next rule upon failure to find an available server.
Packets are dropped when no servers are available for the current LB action.
LB action view
context-admin
vsys-admin
This command enables packets to match the next rule in an LB policy when no servers are available for the current LB action.
# Match the next rule upon failure to find a real server for the HTTP LB action a1.
[Sysname-lba-http-a1] fallback-action continue
# Match the next rule upon failure to find a DNS server for the DNS LB action a2.
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
fallback-action response raw-file
Use fallback-action response raw-file to specify a response file used upon load balancing failure.
fallback-action response raw-file raw-filename
Packets are discarded upon load balancing failure.
HTTP LB action view
context-admin
vsys-admin
raw-filename: Specifies a response file by its name, a case-insensitive string of 1 to 255 characters.
This command enables the device to respond to client requests when the device fails to find an available real server or fails to find the response file specified in the response command. The response file specified in the fallback-action response raw-file command must contain a complete HTTP packet and cannot contain only the HTTP content.
The fallback-action response raw-file command and the fallback-action continue command are mutually exclusive.
# Specify the 301.raw file as the response file used upon load balancing failure.
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] fallback-action response raw-file 301.raw
display loadbalance action
fin-wait1 timeout
Use fin-wait1 timeout to set the FIN-WAIT-1 state timeout time for TCP connections.
Use undo fin-wait1 timeout to restore the default.
fin-wait1 timeout timeout-value
The FIN-WAIT-1 state timeout time is 5 seconds for TCP connections.
context-admin
vsys-admin
timeout-value: Specifies the FIN-WAIT-1 state timeout time in the range of 1 to 65535 seconds.
# Set the FIN-WAIT-1 state timeout time for TCP connections to 10 seconds in the TCP parameter profile profile.
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] fin-wait1 timeout 10
display parameter-profile
fin-wait2 timeout
Use fin-wait2 timeout to set the FIN-WAIT-2 state timeout time for TCP connections.
Use undo fin-wait2 timeout to restore the default.
The FIN-WAIT-2 state timeout time is 5 seconds for TCP connections.
context-admin
vsys-admin
timeout-value: Specifies the FIN-WAIT-2 state timeout time in the range of 1 to 65535 seconds.
# Set the FIN-WAIT-2 state timeout time for TCP connections to 10 seconds in the TCP parameter profile profile.
[Sysname-para-tcp-profile] fin-wait2 timeout 10
forward all
Use forward all to configure the packet forwarding mode.
Use undo forward to restore the default.
forward all
undo forward
The packet forwarding mode is to discard packets.
DNS/Generic/Link-generic LB action view
context-admin
vsys-admin
In DNS LB action view, this command is mutually exclusive with the dns-server-pool or skip current-dns-proxy command. In generic LB action view, the forward all and server-farm commands are mutually exclusive. In link-generic LB action view, the forward all and link-group commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
# Configure the packet forwarding mode for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] forward all
dns-server-pool
link-group (LB action view)
server-farm (LB action view)
frequency
Use frequency to set the probe interval for an LB probe template.
Use undo frequency to restore the default.
frequency interval
undo frequency
The probe interval is 300 seconds.
Load balancing probe template view
context-admin
interval: Specifies the probe interval in the range of 5 to 604800 seconds.
This command specifies the interval for sending probe packets.
# Set the probe interval to 3600 seconds for ICMP probe template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lb-pt-icmp-icmptplt] frequency 3600
header (HTTP header sticky group view)
Use header to configure the HTTP header sticky method.
Use undo header to restore the default.
header { { { host | name header-name | url } [ offset offset ] [ start start-string ] [ end end-string | length length ] } | request-method | version }
undo header
No HTTP header sticky methods exist.
context-admin
vsys-admin
host: Specifies the HTTP host based sticky method.
name header-name: Specifies the HTTP header name based sticky method. The header-name argument is a case-insensitive string of 1 to 63 characters.
url: Specifies the HTTP URL based sticky method.
offset offset: Specifies the offset value of the HTTP header based on the start of the HTTP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP header, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP header, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP header, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
request-method: Specifies the HTTP Request-Method based sticky method.
version: Specifies the HTTP version based sticky method.
Use this command to obtain the HTTP header information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
# Configure the HTTP header sticky method for the HTTP header sticky group sg4: Specify the HTTP host based sticky method.
[Sysname] sticky-group sg4 type http-header
[Sysname-sticky-http-header-sg4] header host
header (HTTP passive sticky group view)
Use header to configure the HTTP header passive sticky method.
Use undo header to delete the HTTP header passive sticky method.
header { get id name header-name | match id { name header-name | url } } start start-string { end end-string | length length }
undo { get | match } id
No HTTP header passive sticky methods exist.
context-admin
vsys-admin
get: Obtains the specified string in the HTTP response header, which is used to generate an HTTP header passive sticky entry.
match: Obtains the specified string in the HTTP request header, which is used to match an HTTP header passive sticky entry.
id: Specifies the string ID in the range of 1 to 4.
start start-string: Specifies the regular expression that marks the start of the HTTP header or URL, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP header or URL, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP header or URL, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Both the header get and header match commands are required for an HTTP header passive sticky method.
The device obtains the header or URL information of an incoming HTTP request based on the header match command and obtains the header information of an incoming HTTP response based on the header get command. If the header or URL information of the HTTP request matches the header information of the HTTP response, the device generates a sticky entry based on the header information of the HTTP response. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
The following rules apply to use of the header match and header get commands:
· You can execute a maximum of four header get commands and four header match commands for one HTTP passive sticky method.
· A number of n strings that are obtained based on n header get commands generates 2n-1 strings in ascending order of string IDs. If the string obtained based on the header match command matches any one of these generated strings, the match is successful.
· A number of n strings that are obtained based on n header match commands combine as one string in ascending order of string IDs.
For example, three header get commands are executed with string IDs 1, 2, and 3. The device obtains three strings a, b, and c in the HTTP response header, generates seven strings a, b, c, ab, ac, bc, and abc, and generates seven sticky entries. Then, three header match commands are executed with string IDs 2, 3, and 4. The device obtains three strings a, b, and c in the HTTP request header and generates one string abc. If the string matches one of the seven strings, the device generates a sticky entry based on the string abc. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
# Configure the HTTP passive sticky method for the HTTP passive sticky group sg4: Obtain the string between callid and & in the URL of the HTTP request. If the string matches the string between phone-number and & in HTTP response header x-forward-callid, the device generates a sticky entry based on the string between phone-number and &.
[Sysname] sticky-group sg4 type http-passive
[Sysname-sticky-http-passive-sg4] header get 1 name x-forward-callid start phone-number end &
[Sysname-sticky-http-passive-sg4] header match 1 url start callid end &
content (HTTP passive sticky group view)
header call-id
Use header call-id to configure the SIP call ID sticky method.
Use undo header call-id to restore the default.
header call-id
undo header call-id
No sticky methods exist.
SIP sticky group view
context-admin
vsys-admin
The SIP call ID sticky method allows the device to generate sticky entries based on the Call-ID header field in SIP messages. Packets with the same call ID are assigned to the same real server.
# Configure the SIP call ID sticky method for the SIP sticky group sg6.
[Sysname] sticky-group sg6 type sip
[Sysname-sticky-sip-sg6] header call-id
header delete
Use header delete to delete the HTTP header.
Use undo header delete to keep the HTTP header.
header delete { both | request | response } name header-name
undo header delete { both | request | response } name header-name
The HTTP header is kept.
HTTP LB action view
context-admin
vsys-admin
both: Specifies both the HTTP request and response packets.
request: Specifies the HTTP request packets.
response: Specifies the HTTP response packets.
name header-name: Specifies the name of the HTTP packet header, including standard and user-defined headers that must match the header in the packet. The header-name argument is a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127. You can enter a question mark (?) to obtain a list of standard header names. For more information about the header names, see RFC 4229.
This command deletes the specified header from HTTP packets.
# Delete the header named host from HTTP request packets for the HTTP LB action lba2.
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] header delete request name host
header delete request accept-encoding
Use header delete request accept-encoding to delete the Accept-Encoding header from HTTP requests.
Use undo header delete request accept-encoding to keep the Accept-Encoding header in HTTP requests.
The LB device deletes the Accept-Encoding header from HTTP requests.
HTTP-compression parameter profile view
context-admin
vsys-admin
This command enables the LB device to delete the Accept-Encoding header from the HTTP request before sending it to the server. If the response packet sent by the server matches the specified match rule, the LB device compresses the packet before sending it to the requesting client. If the HTTP request sent by the client does not contain the Accept-Encoding header, the LB device does not compress the response packet regardless of whether this command is executed.
By default, the LB device does not modify request packets. If the response packet sent by the server is compressed, the LB device sends the packet to the requesting client without compressing it. If the response packet sent by the server is not compressed and matches the specified match rule, the LB device compresses the packet before sending it to the requesting client.
# Create the HTTP-compression parameter profile http1, and delete the Accept-Encoding header from HTTP requests.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] header delete request accept-encoding
header exceed-length
Use header exceed-length to specify the action to take on the HTTP requests or responses when their packet headers exceed the maximum length.
Use undo header exceed-length to restore the default.
header exceed-length { continue | drop }
The system continues to perform load balancing for HTTP requests or responses when their packet headers exceed the maximum length.
context-admin
vsys-admin
continue: Continues to perform load balancing.
drop: Stops performing load balancing, discards the packet, and terminates the connection.
When the HTTP packet header length exceeds the processing capability of load balancing, the drop method applies.
# For the HTTP parameter profile pp1, specify the drop action for the HTTP requests or responses with their packet headers exceeding the maximum length.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] header exceed-length drop
header insert
Use header insert to insert the HTTP header.
Use undo header insert to remove the configuration.
header insert { both | request | response } name header-name value value [ encode { base64 | url } ]
undo header insert { both | request | response } name header-name
The HTTP header is not inserted.
HTTP LB action view
context-admin
vsys-admin
name header-name: Specifies the name of the HTTP packet header, including standard and user-defined headers. The header-name argument is a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127. You can enter a question mark (?) to obtain a list of standard header names. For more information about the header names, see RFC 4229.
value value: Specifies the header content to be inserted to the HTTP packet, a string of 1 to 255 characters. You can also specify the following replacement strings:
· %is—Source IP address in HTTP requests.
· %ps—Source port number in HTTP requests.
· %id—Destination IP address in HTTP requests.
· %pd—Destination port number in HTTP requests.
· %sps—Source port number in HTTP responses.
· %spd—Destination port number in HTTP responses.
· %sis—Source IP address in HTTP responses.
· %sid—Destination IP address in HTTP responses.
· %{x509v}—Certificate version.
· %{x509snum}—Certificate serial number.
· %{x509sigalgo}—Certificate signature algorithm.
· %{x509issuer}—Certificate issuer.
· %{x509before}—Certificate effective time.
· %{x509after}—Certificate expiration time.
· %{x509sub}—Certificate subject.
· %{x509spktype}—Public key type for the certificate subject.
· %{x509spk}—Public key for the certificate subject.
· %{x509spkRSA}—Length of the RSA public key for the certificate subject (this field is available only for an RSA public key).
· %{x509hash}—MD5 hash value of the client certificate.
· %{dncn}—Issuee.
· %{dne}—Email.
· %{dno}—Company/Organization.
· %{dnou}—Department.
· %{dnc}—Country.
· %{dns}—State/Province.
· %{dnl}—City.
encode { base64 | url }: Specifies an encoding method for replacement strings. If you do not specify an encoding method, replacement strings are not encoded.
This command inserts the specified header to HTTP packets.
URL encoding encodes only special characters in replacement strings, for example, colons in IPv6 addresses. Base64 encoding encodes entire replacement strings.
# Insert the header named source with source IP address and source port number as the content to HTTP request packets for the HTTP LB action lba2.
[Sysname-lba-http-lba2] header insert request name source value %is:%ps
header insert response vary
Use header insert response vary to insert the Vary header into HTTP responses.
Use undo header insert response vary to remove the configuration.
The Vary header is inserted into HTTP responses.
context-admin
vsys-admin
This command inserts the Vary header to HTTP responses and sets the header content to Accept-Encoding before sending them to the client. The command takes effect regardless of whether the response packets contain the Vary header or whether the packets are compressed.
# Create the HTTP-compression parameter profile http1, and insert the Vary header into HTTP responses.
[Sysname-para-http-compression-http1] header insert response vary
header maxparse-length
Use header maxparse-length to set the maximum length of HTTP headers that can be parsed.
Use undo header maxparse-length to restore the default.
header maxparse-length length
The maximum length of HTTP headers that can be parsed is 4096.
context-admin
vsys-admin
length: Specifies the maximum length of HTTP headers that can be parsed, in the range of 1 to 65535 bytes.
# Set the maximum length of HTTP headers that can be parsed to 8192 for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] header maxparse-length 8192
header modify per-request
Use header modify per-request to perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
Use undo header modify per-request to restore the default.
The insert, delete, or modify operation is performed for the header of the first HTTP request or response packet of a connection.
context-admin
vsys-admin
# For the HTTP parameter profile pp1, perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
[Sysname-para-http-pp1] header modify per-request
header rewrite
Use header rewrite to rewrite the HTTP header.
Use undo header rewrite to remove the configuration.
header rewrite { both | request | response } name header-name value value replace replace [ encode { base64 | url } ]
undo header rewrite { both | request | response } name header-name
The HTTP header is not rewritten.
HTTP LB action view
context-admin
vsys-admin
value value: Specifies the HTTP packet header content to be rewritten, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace: Specifies the content after rewrite, a case-sensitive string of 1 to 127 characters. You can also specify the following replacement strings:
· %{dncn}—Issuee.
· %{dne}—Email.
· %{dnc}—Country.
· %{dnl}—City.
This command rewrites the value setting of the specified header in HTTP packets to the replace setting.
# For the HTTP LB action lba2, rewrite the content www.hello.com of the header named host in HTTP request packets to www.he.com.cn.
[Sysname-lba-http-lba2] header rewrite request name host value www\.(he)(llo)\.com replace www.%1.com.cn encode url
header rewrite request url
Use header rewrite request url to rewrite the URL in HTTP requests.
Use undo header rewrite request url to restore the default.
header rewrite request url value value replace replace [ encode { base64 | url } ]
The URL in HTTP requests is not rewritten.
HTTP LB action view
context-admin
vsys-admin
value value: Specifies the URL to be rewritten, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace: Specifies the URL after rewrite, a case-sensitive string of 1 to 127 characters. You can also specify the following replacement strings:
· %{dncn}—Issuee.
· %{dne}—Email.
· %{dnc}—Country.
· %{dnl}—City.
This command rewrites the value setting in the HTTP request URL to the replace setting.
# For the HTTP LB action lba2, rewrite the URL www.hello.com in HTTP requests to www.he.com.cn.
[Sysname-lba-http-lba2] header rewrite request url value www\.(he)(llo)\.com replace www.%1.com.cn encode url
idle-time
Use idle-time to set the idle timeout time for TCP connections between the LB device and servers.
Use undo idle-time to restore the default.
idle-time idle-time
undo idle-time
The idle timeout time for TCP connections between the LB device and servers is 86400 seconds.
OneConnect parameter profile view
MySQL parameter profile view
context-admin
vsys-admin
idle-time: Specifies the idle timeout time in the range of 1 to 4294967295 seconds.
The idle timeout time is the amount of time that a TCP connection can stay idle before it is disconnected. After the TCP connection is disconnected, new connection requests trigger establishment of a new TCP connection.
# In OneConnect parameter profile ocp, set the idle timeout time to 10000 seconds for TCP connections between the LB device and servers.
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] idle-time 10000
inherit vpn-instance disable (link view)
Use inherit vpn-instance disable to disable VPN instance inheritance for a link.
Use undo inherit vpn-instance disable to enable VPN instance inheritance for a link.
VPN instance inheritance is enabled for a link.
Link view
context-admin
When VPN instance inheritance is enabled, a link without a VPN instance specified inherits the VPN instance of the virtual server. When VPN instance inheritance is disabled, a link without a VPN instance specified belongs to the public network.
To specify a VPN instance for a link, use the vpn-instance vpn-instance-name command in link view.
You can display the VPN instance for a link by using the display loadbalance link command.
# Disable VPN instance inheritance for link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] inherit vpn-instance disable
vpn-instance (link view)
inherit vpn-instance disable (real server view)
Use inherit vpn-instance disable to disable VPN instance inheritance for a real server.
Use undo inherit vpn-instance disable to enable VPN instance inheritance for a real server.
VPN instance inheritance is enabled for a real server.
Real server view
context-admin
When VPN instance inheritance is enabled, a real server without a VPN instance specified inherits the VPN instance of its virtual server. When VPN instance inheritance is disabled, a real server without a VPN instance specified belongs to the public network.
To specify a VPN instance for a real server, use the vpn-instance command in real server view.
# Disable VPN instance inheritance for real server rs.
[Sysname] real-server rs
[Sysname-rserver-rs] inherit vpn-instance disable
vpn-instance (real server view)
vpn-instance (virtual server view)
ip
Use ip to configure the IPv4 sticky method.
Use undo ip to restore the default.
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
No IPv4 sticky method is configured.
Sticky group view
context-admin
vsys-admin
port: Specifies the sticky method as IPv4 address + port number. If you do not specify this keyword, the sticky method is IPv4 address.
both: Specifies the sticky method as source IPv4 address + destination IPv4 address (if you do not specify the port keyword), or source IPv4 address + source port number + destination IPv4 address + destination port number (if you specify the port keyword).
destination: Specifies the sticky method as destination IPv4 address if you do not specify the port keyword, or destination IPv4 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv4 address if you do not specify the port keyword, or source IPv4 address + source port number if you specify the port keyword.
mask mask-length: Specifies the mask length for the sticky method.
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address + source port number.
[Sysname-sticky-address-port-sg1] ip port source
sticky-group
ip address (DNS listener view)
Use ip address to specify an IPv4 address and a port number for a DNS listener.
Use undo ip address to restore the default.
ip address ipv4-address [ port port-number ]
undo ip address
No IPv4 address or port number is specified for a DNS listener.
DNS listener view
context-admin
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
port-number: Specifies a port number in the range of 1 to 65535. The default port number is 53.
You can specify only one IPv4 address for a DNS listener. If you execute this command multiple times, the most recent configuration takes effect. A DNS listener without an IPv4 address configured does not process IPv4 DNS requests.
To ensure correct operation of inbound link load balancing when server load balancing is also enabled, do not specify the virtual server's IP address as the DNS listener's IP address.
# Specify the IPv4 address for the DNS listener as 1.2.3.4 and port number as 8080.
[Sysname-lb-dl-ct-listener] ip address 1.2.3.4 port 8080
display loadbalance dns-listener
ip address (DNS server view)
Use ip address to specify an IPv4 address for a DNS server.
undo ip address
No IPv4 address is specified for a DNS server.
DNS server view
context-admin
# Specify the IPv4 address for DNS server ds1 as 1.2.3.4.
[Sysname-lb-ds-ds1] ip address 1.2.3.4
ip address (ISP view)
Use ip address to configure an IPv4 address for an ISP.
ip address ipv4-address { mask-length | mask }
undo ip address ipv4-address { mask-length | mask }
No IPv4 address is configured for an ISP.
ISP view
context-admin
ipv4-address: Specifies an IPv4 address.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32.
mask: Specifies the mask for the IPv4 address.
# Configure the IPv4 address for the ISP isp1 as 1.1.1.1.
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] ip address 1.1.1.1 24
ip address (real server view)
Use ip address to configure an IPv4 address for a real server.
undo ip address
No IPv4 address is configured for a real server.
Real server view
context-admin
vsys-admin
# Configure the IPv4 address for the real server rs as 1.1.1.1.
[Sysname-rserver-rs] ip address 1.1.1.1
ip address (transparent DNS proxy view)
Use ip address to specify an IPv4 address for a transparent DNS proxy.
ip address ipv4-address [ mask-length | mask ]
undo ip address
No IPv4 address is specified for a transparent DNS proxy.
Transparent DNS proxy view
context-admin
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a subnet mask.
A transparent DNS proxy processes a DNS request only when the destination IP address and port number of the DNS request match those of the transparent DNS proxy.
If server load balancing is configured, configure different IP addresses and port numbers for the transparent DNS proxy and the virtual server of the UDP type.
# Specify the IPv4 address for transparent DNS proxy dns-proxy1 as 1.2.3.4/24.
[Sysname] loadbalance dns-proxy dns_proxy1
[Sysname-lb-dp-udp-dns-proxy1] ip address 1.2.3.4 24
ip mask
Use ip mask to set the mask length for IPv4 proximity entries.
Use undo ip mask to restore the default.
ip mask { mask-length | mask }
The mask length for IPv4 proximity entries is 24.
Proximity view
context-admin
mask-length: Specifies the mask length for IPv4 proximity entries, in the range of 0 to 32. A value of 0 indicates the natural mask.
mask: Specifies the mask for IPv4 proximity entries.
# Set the mask length for IPv4 proximity entries to 30.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] ip mask 30
ip range
Use ip range to add an IPv4 address range to a SNAT address pool.
Use undo ip range to remove an IPv4 address range from a SNAT address pool.
ip range start start-ipv4-address end end-ipv4-address [ failover-group group-name [ channel channel-id ] ]
undo ip range start start-ipv4-address end end-ipv4-address
An SNAT address pool does not contain IPv4 address ranges.
SNAT address pool view
context-admin
vsys-admin
start start-ipv4-address: Specifies the start IPv4 address.
end end-ipv4-address: Specifies the end IPv4 address, which must be greater than or equal to the start IPv4 address.
failover-group group-name: Specifies a failover group for the address range by its name, a case-sensitive string of 1 to 63 characters. The specified failover group must already exist. You must specify a failover group if you have specified the failover group-based splitting method when creating the SNAT address pool. For other splitting methods, you cannot specify a failover group.
channel channel-id: Specifies a channel by its ID. The channel ID can be 0 or 1. The default channel ID is 0.
You can execute this command multiple times to add multiple IPv4 address ranges to a SNAT address pool. Each address range can have a maximum of 256 IPv4 addresses. No overlapping IPv4 addresses are allowed in the same SNAT address pool or different SNAT address pools.
If you specify a failover group and a channel in this command, only that channel in that failover group can use the configured address range. For more information about failover groups, see Virtual Technologies Configuration Guide.
If the addresses in an SNAT address pool are in the same network segment as the IP address of the interface connect the device to the server, you must specify an interface for sending gratuitous ARP or ND packets.
# Add IPv4 address range 1.1.1.1 to 1.1.1.100 to the SNAT address pool lbsp.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
arp-nd interface (SNAT address pool view)
ip source mask
Use ip source mask to specify the IPv4 mask for connection reuse.
Use undo ip source mask to restore the default.
ip source mask { mask-length | mask }
undo ip source mask
The IPv4 mask for connection reuse is the natural mask.
context-admin
vsys-admin
mask-length: Specifies the mask length in the range of 0 to 32. A value of 0 indicates the natural mask.
mask: Specifies the subnet mask in dotted decimal notation.
This command limits the network segment of clients that can reuse connections between the LB device and servers. If the client that initiates a connection request is in the same network segment as the idle TCP connection, the idle TCP connection is reused. If the client does not match this requirement, a new TCP connection is established.
# In OneConnect parameter profile ocp, set the mask length for connection reuse to 24.
[Sysname-para-oneconnect-ocp] ip source mask 24
ipv6
Use ipv6 to configure the IPv6 sticky method.
Use undo ipv6 to restore the default.
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
No IPv6 sticky method is configured.
Sticky group view
context-admin
vsys-admin
port: Specifies the sticky method as IPv6 address + port number. If you do not specify this keyword, the sticky method is IPv6 address.
both: Specifies the sticky method as source IPv6 address + destination IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number + destination IPv6 address + destination port number if you specify the port keyword.
destination: Specifies the sticky method as destination IPv6 address if you do not specify the port keyword, or destination IPv6 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number if you specify the port keyword.
prefix prefix-length: Specifies the prefix length for the sticky method.
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address.
[Sysname-sticky-address-port-sg1] ipv6 source
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address + source port number.
[Sysname-sticky-address-port-sg1] ipv6 port source
sticky-group
ipv6 address (DNS listener view)
Use ipv6 address to configure an IPv6 address and a port number for a DNS listener.
Use undo ipv6 address to restore the default.
ipv6 address ipv6-address [ port port-number ]
undo ipv6 address
No IPv6 address or port number is configured for a DNS listener.
DNS listener view
context-admin
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address.
port port-number: Specifies a port number in the range of 1 to 65535. The default is 53.
A DNS listener can be configured with only one IPv6 address. A DNS listener without an IPv6 address configured does not process IPv6 DNS requests.
# Configure the IPv6 address and port number for DNS listener ct-listener as 1001::1 and 64.
[Sysname-lb-dl-ct-listener] ipv6 address 1001::1 port 64
ipv6 address (DNS server view)
Use ipv6 address to configure an IPv6 address for a DNS server.
undo ipv6 address
No IPv6 address is configured for a DNS server.
DNS server view
context-admin
# Configure the IPv6 address for DNS server ds1 as 1001::1.
[Sysname-lb-ds-ds1] ipv6 address 1001::1
ipv6 address (ISP view)
Use ipv6 address to configure an IPv6 address for an ISP.
ipv6 address ipv6-address prefix-length
undo ipv6 address ipv6-address prefix-length
No IPv6 address is configured for an ISP.
ISP view
context-admin
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 1 to 128.
# Configure the IPv6 address for the ISP isp1 as 200::1.
[Sysname-lbisp-isp1] ipv6 address 200::1 100
ipv6 address (real server view)
Use ipv6 address to configure an IPv6 address for a real server.
undo ipv6 address
No IPv6 address is configured for a real server.
Real server view
context-admin
vsys-admin
# Configure the IPv6 address for the real server rs as 1001::1.
[Sysname-rserver-rs] ipv6 address 1001::1
ipv6 address (transparent DNS proxy view)
Use ipv6 address to configure an IPv6 address for a transparent DNS proxy.
ipv6 address ipv6-address [ prefix-length ]
undo ipv6 address
No IPv6 address is configured for a transparent DNS proxy.
context-admin
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (If the prefix length is 0, you can specify the all-zero address.).
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
# Configure the IPv6 address for transparent DNS proxy dns-proxy1 as 1::2:3/112.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] ipv6 address 1::2:3 112
ipv6 prefix
Use ipv6 prefix to configure the prefix length for IPv6 proximity entries.
Use undo ipv6 prefix to restore the default.
ipv6 prefix prefix-length
The prefix length for IPv6 proximity entries is 96.
Proximity view
context-admin
prefix-length: Specifies the prefix length for IPv6 proximity entries, in the range of 1 to 128.
# Specify the prefix length for IPv6 proximity entries as 64.
[Sysname-lb-proximity] ipv6 prefix 64
ipv6 range
Use ipv6 range to add an IPv6 address range to a SNAT address pool.
Use undo ipv6 range to remove an IPv6 address range from a SNAT address pool.
ipv6 range start start-ipv6-address end end-ipv6-address [ failover-group group-name [ channel channel-id ] ]
undo ipv6 range start start-ipv6-address end end-ipv6-address
An SNAT address pool does not contain IPv6 address ranges.
context-admin
vsys-admin
start start-ipv6-address: Specifies the start IPv6 address.
end end-ipv6-address: Specifies the end IPv6 address, which must be greater than or equal to the start IPv6 address.
You can execute this command multiple times to add multiple IPv6 address ranges to a SNAT address pool. Each address range can have a maximum of 10000 IPv6 addresses. No overlapping IPv6 addresses are allowed in the same SNAT address pool or different SNAT address pools.
# Add IPv6 address range 1001::1 to 1001::100 to the SNAT address pool lbsp.
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
ipv6 source prefix
Use ipv6 source prefix to specify the IPv6 prefix length for connection reuse.
Use undo ipv6 source prefix to restore the default.
ipv6 source prefix prefix-length
Client IPv6 addresses with a prefix length of 0 can reuse connections.
context-admin
vsys-admin
prefix-length: Specifies the prefix length in the range of 0 to 128.
# In OneConnect parameter profile ocp, set the prefix length for connection reuse to 24.
[Sysname-para-oneconnect-ocp] ipv6 source prefix 24
isp
Use isp to add an ISP to a region.
Use undo isp to delete an ISP from a region.
isp isp-name
undo isp isp-name
A region does not contain any ISPs.
Region view
context-admin
isp-name: Specifies an ISP by its name, a case-insensitive string of 1 to 63 characters.
# Add the ISP isp-ct to the region region-ct.
[Sysname] loadbalance region region-ct
[Sysname-lb-region-region-ct] isp isp-ct
loadbalance region
keepalive idle-timeout
Use keepalive idle-timeout to set the idle timeout time for sending keepalive packets.
Use undo keepalive idle-timeout to restore the default.
keepalive idle-timeout timeout-value
The idle timeout time for sending keepalive packets is 1800 seconds.
context-admin
vsys-admin
timeout-value: Specifies the idle timeout time for sending keepalive packets, in the range of 1 to 65535 seconds.
# Set the timeout time for sending keepalive packets to 5 seconds in the TCP parameter profile profile.
[Sysname-para-tcp-profile] keepalive idle-timeout 5
keepalive retransmission interval
Use keepalive retransmission interval to set the retransmission interval and retransmission times for keepalive packets.
Use undo keepalive retransmission interval to restore the default.
keepalive retransmission interval interval count count
The retransmission interval is 10 seconds, and the retransmission times is 3.
context-admin
vsys-admin
interval: Specifies the retransmission interval for keepalive packets, in the range of 1 to 65535 seconds.
count: Specifies the retransmission times for keepalive packets, in the range of 1 to 65535.
# Set the retransmission interval and retransmission times for keepalive packets to 5 seconds and 10, respectively, in the TCP parameter profile profile.
[Sysname-para-tcp-profile] keepalive retransmission interval 5 count 10
lb-limit-policy
Use lb-limit-policy to apply an LB connection limit policy to a virtual server.
Use undo lb-limit-policy to restore the default.
lb-limit-policy policy-name
No LB connection limit policies are applied to a virtual server.
Virtual server view
context-admin
vsys-admin
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 63 characters.
Use this command to implement rate limit for user traffic.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Apply the LB connection limit policy llp to the HTTP-type virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs]lb-limit-policy llp
loadbalance limit-policy
lb-policy (transparent DNS proxy view)
Use lb-policy to specify an LB policy to be referenced by a transparent DNS proxy.
Use undo lb-policy to restore the default.
lb-policy policy-name
undo lb-policy
No LB policy is referenced by a transparent DNS proxy.
context-admin
policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 63 characters.
Non-default vSystems do not support this command.
By referencing an LB policy, a transparent DNS proxy implements load balancing for matching packets based on the packet contents.
A transparent DNS proxy can reference only a DNS policy template.
# Specify the LB policy dns-policy1 to be referenced by transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] lb-policy dns-policy1
lb-policy (virtual server view)
Use lb-policy to specify an LB policy to be referenced by the specified virtual server.
undo lb-policy
No LB policy is referenced by a virtual server.
Virtual server view
context-admin
vsys-admin
By referencing an LB policy, the virtual server implements load balancing for matching packets based on the packet contents.
A virtual server can reference the policy template of the specified type. For example, a virtual server of the HTTP type can reference a policy template of the generic type or HTTP type. A virtual server of the IP, SIP, TCP, or UDP type can reference a policy template of the generic type only.
# Specify the LB policy lbp1 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] lb-policy lbp1
limit
Use limit to configure an LB connection limit rule.
Use undo limit to delete an LB connection limit rule.
limit limit-id acl [ ipv6 ] { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
No rules are configured for an LB connection limit policy.
LB connection limit policy view
context-admin
vsys-admin
limit-id: Specifies an LB connection limit rule ID. The value range for this argument is 1 to 65535.
acl: Specifies an ACL to limit user connections of a specified user range.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command uses an IPv4 ACL.
acl-number: Specifies the ACL number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name.
per-destination: Limits user connections by destination IP address.
per-service: Limits user connections by service. Services are classified by transport layer protocol and service port number.
per-source: Limits user connections by source IP address.
max-amount: Specifies the upper limit of connections, in the range of 1 to 4294967295. When the number of connections in a specified range or for a certain type reaches the upper limit, the device does not accept new connection requests.
min-amount: Specifies the lower limit of connections, in the range of 1 to 4294967295. The min-amount must be equal to or smaller than the max-amount. The device accepts new connection requests only when the number of connections drops below the lower limit.
An LB connection limit policy can have multiple rules. You can specify an ACL, a type, and the upper and lower limits for each rule. You can specify one or more of the per-destination, per-service, and per-source keywords for the command. For example, you can specify both the per-destination and per-source keywords to limit user connections by destination address and source address of packets.
You must specify a different ACL for each rule in an LB connection limit policy.
If the per-destination, per-service, and per-source keywords are not specified, the command limits all user connections matching the specified ACL.
The rules in an LB connection limit policy are matched in ascending order of the rule IDs until a match is found.
When the specified ACL changes, the device uses a new LB connection limit policy to process existing connections again.
# Configure rule 1 for the LB connection limit policy 1. Use ACL 3000 to permit user connections sourced from the network 192.168.0.0/24, and set the upper and lower limits to 2000 and 1800 for the user connections by source and destination addresses.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
[Sysname] loadbalance limit-policy 1
[Sysname-lb-limit-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800
link (DNS server view)
Use link to associate a link with a DNS server.
Use undo link to restore the default.
link link-name
undo link
No link is associated with a DNS server.
DNS server view
context-admin
link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters.
A DNS server can be associated with only one link. A link can be associated with multiple DNS servers.
# Associate link link1 with DNS server ds1.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] link link1
link (link group view)
Use link to create a link group member and enter its view, or enter the view of an existing link group member.
Use undo link to delete a link group member.
link link-name
undo link link-name
No link group members exist.
Link group view
context-admin
link-name: Specifies a link group member name, a case-insensitive string of 1 to 63 characters.
You can use one of the following methods to add a member to a link group:
· Use the link command in link group view. H3C recommends using this method.
· Use the link-group command in link view.
You cannot use both methods to add a member with the same link name to a link group.
# Add link group member lk1 and enter link group member view.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1]
link-group (link view)
Use link-group to specify the primary link group.
Use undo link-group to restore the default.
link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
undo link-group
No primary link group is specified.
LB action view
context-admin
link-group-name: Specifies a primary link group name, a case-insensitive string of 1 to 63 characters.
backup backup-link-group-name: Specifies a backup link group name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies the name of the sticky group corresponding to the link group. It is a case-insensitive string of 1 to 63 characters.
The link-group and forward all commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
When the primary link group is available (contains links), packets are forwarded through the primary link group. When the primary link group is not available, packets are forwarded through the backup link group.
# Specify the primary link group lg, the backup link group lgb, and the sticky group sg1 for the link-generic LB action lba1.
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba-link-generic-lba1] server-farm sf backup sfb sticky sg1
forward all
Use link-group to specify a link group for a link.
undo link-group
A link does not belong to any link group.
Link view
context-admin
link-group-name: Specifies a link group name, a case-insensitive string of 1 to 63 characters.
The device selects the best link from the matching link group to perform link load balancing.
# Specify the link group lkg1 for the link lk1.
[Sysname-lb-link-lk1] link-group lkg1
loadbalance action
Use loadbalance action to create an LB action and enter its view, or enter the view of an existing LB action.
Use undo loadbalance action to delete the specified LB action.
loadbalance action action-name [ type { dns | generic | http | link-generic | radius } ]
undo loadbalance action action-name
No LB actions exist.
context-admin
vsys-admin
action-name: Specifies the LB action name, a case-insensitive string of 1 to 63 characters.
type { dns | generic | http | link-generic | radius }: Specifies an LB action type.
· dns: DNS load balancing action. Non-default vSystems do not support this parameter.
· generic: Generic server load balancing action.
· http: HTTP load balancing action.
· link-generic: Link load balancing action. Non-default vSystems do not support this parameter.
· radius: RADIUS load balancing action.
When you create an LB action, you must specify the LB action type. You can enter an existing LB action view without entering the type of the LB action.
You can create generic, HTTP, and RADIUS LB actions only if the device has licenses installed. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create the LB action lba1 with the generic type, and enter LB action view.
loadbalance alg
Use loadbalance alg to enable ALG for the specified protocols.
Use undo loadbalance alg to disable ALG for the specified protocols.
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
ALG is enabled for the DNS, FTP, PPTP, and RTSP protocols and ICMP error packets.
context-admin
vsys-admin
dns: Specifies the DNS protocol.
ftp: Specifies the FTP protocol.
h323: Specifies the H.323 protocol.
icmp-error: Specifies the ICMP error packets.
ils: Specifies the Internet Locator Service (ILS) protocol.
mgcp: Specifies the Media Gateway Control Protocol (MGCP).
nbt: Specifies the NetBIOS over TCP/IP (NBT) protocol.
pptp: Specifies the Point-to-Point Tunneling Protocol (PPTP).
rsh: Specifies the Remote Shell (RSH) protocol.
rtsp: Specifies the Real Time Streaming Protocol (RTSP).
sccp: Specifies the Skinny Client Control Protocol (SCCP).
sip: Specifies the Session Initiation Protocol (SIP).
sqlnet: Specifies the SQLNET protocol.
tftp: Specifies the TFTP protocol.
xdmcp: Specifies the X Display Manager Control Protocol (XDMCP).
The ALG feature distributes parent and child sessions to the same link.
# Enable ALG for TFTP.
[Sysname] loadbalance alg tftp
loadbalance alg all-enable
Use loadbalance alg all-enable to enable ALG for all protocols.
Use loadbalance alg all-disable to disable ALG for all protocols.
context-admin
vsys-admin
# Enable ALG for all protocols.
[Sysname] loadbalance alg all-enable
loadbalance class
Use loadbalance class to create an LB class and enter its view, or enter the view of an existing LB class.
Use undo loadbalance class to delete the specified LB class.
loadbalance class class-name [ type { dns | generic | http | link-generic | mysql | radius } [ match-all | match-any ] ]
undo loadbalance class class-name
No LB classes exist.
context-admin
vsys-admin
class-name: Specifies the LB class name, a case-insensitive string of 1 to 63 characters.
type { dns | generic | http | link-generic | mysql | radius }: Specifies an LB class type.
· dns: DNS load balancing class. Non-default vSystems do not support this parameter.
· generic: Generic server load balancing class.
· http: HTTP load balancing class.
· link-generic: Link load balancing class. Non-default vSystems do not support this parameter.
· mysql: MySQL load balancing class.
· radius: RADIUS load balancing class.
[ match-all | match-any ]: Requires matching all rules or any rule of the LB class. match-all is the default match mode.
When you create an LB class, you must specify an LB class type. You can enter an existing LB class view without entering the type of the LB class.
You can create generic, HTTP, MySQL, and RADIUS LB classes only if the device has licenses installed. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create the LB class lbc1 with the generic type, and enter LB class view.
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1]
loadbalance dns-cache aging-time
Use loadbalance dns-cache aging-time to set the aging time for DNS cache entries.
Use undo loadbalance dns-cache aging-time to restore the default.
loadbalance dns-cache aging-time aging-time
The aging time for DNS cache entries is 60 minutes.
context-admin
aging-time: Specifies the aging time for DNS cache entries, in the range of 1 to 1440 minutes.
# Set the aging time for DNS cache entries to 100 minutes.
[Sysname] loadbalance dns-cache aging-time 100
Use loadbalance dns-listener to create a DNS listener and enter its view, or enter the view of an existing DNS listener.
Use undo loadbalance dns-listener to delete a DNS listener.
loadbalance dns-listener dns-listener-name
undo loadbalance dns-listener dns-listener-name
No DNS listeners exist.
context-admin
dns-listener-name: Specifies the DNS listener name, a case-insensitive string of 1 to 63 characters.
A DNS listener listens for DNS requests on the LB device.
# Create the DNS listener ct-listener, and enter DNS listener view.
loadbalance dns-map
Use loadbalance dns-map to create a DNS mapping and enter its view, or enter the view of an existing DNS mapping.
Use undo loadbalance dns-map to delete a DNS mapping.
loadbalance dns-map dns-map-name
undo loadbalance dns-map dns-map-name
No DNS mappings exist.
context-admin
dns-map-name: Specifies the DNS mapping name, a case-insensitive string of 1 to 63 characters.
A DNS mapping maps a domain name to the IP address of a virtual server pool. A domain name can be mapped to only one virtual server pool.
# Create the DNS mapping dm1, and enter DNS mapping view.
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1]
Use loadbalance dns-proxy to create a transparent DNS proxy and enter its view, or enter the view of an existing transparent DNS proxy.
Use undo loadbalance dns-proxy to delete a transparent DNS proxy.
loadbalance dns-proxy dns-proxy-name type udp
undo loadbalance dns-proxy dns-proxy-name
No transparent DNS proxies exist.
context-admin
dns-proxy-name: Specifies the transparent DNS proxy name, a case-insensitive string of 1 to 63 characters.
type udp: Specifies the transparent DNS proxy type as UDP.
# Create the UDP transparent DNS proxy dns-proxy1, and enter UDP transparent DNS proxy view.
[Sysname] loadbalance dns-proxy dns-proxy1 type udp
display loadbalance dns-proxy
Use loadbalance dns-server to create a DNS server and enter its view, or enter the view of an existing DNS server.
Use undo loadbalance dns-server to delete a DNS server.
loadbalance dns-server dns-server-name
undo loadbalance dns-server dns-server-name
No DNS servers exist.
context-admin
dns-server-name: Specifies the DNS server name, a case-insensitive string of 1 to 63 characters.
# Create the DNS server ds1, and enter DNS server view.
[Sysname-lb-ds-ds1]
loadbalance dns-server-pool
Use loadbalance dns-server-pool to create a DNS server pool and enter its view, or enter the view of an existing DNS server pool.
Use undo loadbalance dns-server-pool to delete a DNS server pool.
loadbalance dns-server-pool pool-name
undo loadbalance dns-server-pool pool-name
No DNS server pools exist.
context-admin
pool-name: Specifies the DNS server pool name, a case-insensitive string of 1 to 63 characters.
# Create the DNS server pool dns-pool1, and enter DNS server pool view.
[Sysname] loadbalance dns-server-pool dns-pool1
[Sysname-lb-dspool-dns-pool1]
loadbalance flow-redirect blade-aggregation
Use loadbalance flow-redirect blade-aggregation to distribute traffic to the specified Blade aggregate interfaces.
Use undo loadbalance flow-redirect to restore the default.
Traffic is evenly distributed among failover groups.
context-admin
This command distributes LB traffic to Blade aggregate interface 257 and distributes the return traffic that does not match any traffic distribution rules to Blade aggregate interface 1. This command requires the following configurations:
· Configure the link-aggregation load-sharing mode source-ip command on Blade aggregate interface 257.
· Configure the link-aggregation load-sharing mode destination-ip command on Blade aggregate interface 1.
# Distribute traffic to the specified Blade aggregate interfaces.
[Sysname] loadbalance flow-redirect blade-aggregation
link-aggregation load-sharing mode (Layer 2—LAN Switching Command Reference)
loadbalance flow-redirect disable
Use loadbalance flow-redirect disable to disable traffic distribution rule deployment.
Use undo loadbalance flow-redirect disable to enable traffic distribution rule deployment.
Traffic distribution rule deployment is enabled.
context-admin
After you disable traffic distribution rule deployment, the system deletes the deployed traffic distribution rules, and does not deploy new traffic distribution rules. In this case, you must configure traffic redirection by using a QoS policy to ensure that the request and response packets are processed by one failover group. For information about configuring traffic redirection by using a QoS policy, see ACL and QoS Configuration Guide.
# Disable traffic distribution rule deployment.
[Sysname] loadbalance flow-redirect disable
loadbalance flow-redirect failover-group
Use loadbalance flow-redirect failover-group to distribute traffic to the specified failover group.
context-admin
This command distributes LB traffic always to the failover group that is selected by NAT Server to process NAT traffic. The traffic distribution rule deployed by NAT Server distributes traffic always to one failover group. If you do not configure this command, the default LB traffic direction method might conflict with the traffic distribution rule deployed by NAT Server. As a result, load balancing fails to be performed. For more information about NAT Server, see Layer 3—IP Services Configuration Guide.
# Distribute traffic to the specified failover group.
[Sysname] loadbalance flow-redirect failover-group
loadbalance isp auto-update enable
Use loadbalance isp auto-update enable to enable ISP auto update.
Use undo loadbalance isp auto-update enable to disable ISP auto update.
ISP auto update is disabled.
context-admin
With ISP auto update enabled, the device regularly queries IP address information from the whois server according to the whois maintainer object of the ISP.
# Enable ISP auto update.
[Sysname] loadbalance isp auto-update enable
loadbalance isp auto-update frequency
loadbalance isp auto-update whois-server
Use loadbalance isp auto-update frequency to configure the ISP auto update frequency.
Use undo loadbalance isp auto-update frequency to restore the default.
loadbalance isp auto-update frequency { per-day | per-week | per-month }
The ISP auto update is performed once per week.
context-admin
per-day: Updates ISP address information once per day.
per-week: Updates ISP address information once per week.
per-month: Updates ISP address information once per month.
The specific update time is about 04:00:00 a.m. For the first auto update, the specific update time is 04:00:00 a.m on the next day.
# Configure the ISP auto update frequency as per day.
[Sysname] loadbalance isp auto-update frequency per-day
Use loadbalance isp auto-update whois-server to specify the whois server to be queried for ISP auto update.
Use undo loadbalance isp auto-update whois-server to restore the default.
loadbalance isp auto-update whois-server { domain domain-name | ip ip-address }
No whois server is specified for ISP auto update.
context-admin
domain domain-name: Specify a whois server by its domain name, a case-insensitive, dot-separated string of 1 to 253 characters (for example, example.com). Each dot-separated part in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and periods (.).
ip ip-address: Specify a whois server by its IPv4 address.
# Specify the whois server with IP address 20.1.1.1 for ISP auto update.
[Sysname] loadbalance isp auto-update whois-server ip 20.1.1.1
loadbalance isp file
Use loadbalance isp file to import an ISP file.
Use undo loadbalance isp file to delete an ISP file.
loadbalance isp file isp-file-name
context-admin
isp-file-name: Specifies the ISP file name, a case-insensitive string of 1 to 255 characters.
The system keeps the imported information intact when detecting the following problems:
· The file does not exist.
· The file name is invalid.
· File decryption occurs.
If the system quits the import operation because of IP address parsing failure, the system performs the following operations:
· Clears the most recently imported information.
· Saves the information imported this time.
You cannot delete the imported ISP and its IPv4 or IPv6 address. If the manually configured and imported ISP information overlaps, you can delete the manually configured ISP information.
To perform an active/standby MPU switchover, make sure the standby MPU has the same ISP file as the active MPU.
# Import the ISP file isp2.
[Sysname] loadbalance isp file isp2
Use loadbalance isp name to create an ISP and enter its view, or enter the view of an existing ISP.
Use undo loadbalance isp name to delete the specified ISP.
loadbalance isp name isp-name
undo loadbalance isp name isp-name
No ISPs exist.
context-admin
isp-name: Specifies the ISP name, a case-insensitive string of 1 to 63 characters.
# Create ISP isp1, and enter ISP view.
Use loadbalance limit-policy to create an LB connection limit policy and enter its view, or enter the view of an existing LB connection limit policy.
Use undo loadbalance limit-policy to delete an LB connection limit policy.
loadbalance limit-policy policy-name
undo loadbalance limit-policy policy-name
No LB connection limit policies exist.
context-admin
vsys-admin
policy-name: Specifies the LB connection limit policy name, a case-insensitive string of 1 to 63 characters.
Using an LB connection limit policy can limit the number of connections on the device. It helps prevent a large number of connections from consuming too many device system resources and server resources. In this way, internal network resources (hosts or servers) are protected, and device system resources can be used more appropriately.
# Create the LB connection limit policy llp, and enter LB connection limit policy view.
[Sysname] loadbalance limit-policy llp
[Sysname-lb-limit-policy-llp]
loadbalance link
Use loadbalance link to create an LB link and enter its view, or enter the view of an existing LB link.
Use undo loadbalance link to delete an LB link.
loadbalance link link-name
undo loadbalance link link-name
No LB links exist.
context-admin
link-name: Specifies the LB link name, a case-insensitive string of 1 to 63 characters.
Each physical link connected to the external network corresponds to an LB link.
# Create the LB link lk1, and enter LB link view.
loadbalance link-group
Use loadbalance link-group to create a link group and enter its view, or enter the view of an existing link group.
Use undo loadbalance link-group to delete a link group.
loadbalance link-group link-group-name
undo loadbalance link-group link-group-name
No link groups exist.
context-admin
link-group-name: Specifies the link group name, a case-insensitive string of 1 to 63 characters.
You can add links that contain similar functions to a link group to facilitate management.
# Create the link group lg, and enter link group view.
[Sysname] loadbalance link-group lg
loadbalance local-dns-server parse-fail-record type
Use loadbalance local-dns-server parse-fail-record type to configure the types of DNS request parse failures to be recorded.
Use undo loadbalance local-dns-server parse-fail-record type to remove the configuration.
loadbalance local-dns-server parse-fail-record type { a | aaaa | all-disable | all-enable | cname | mx | ns | ptr | soa | srv | txt }
undo loadbalance local-dns-server parse-fail-record type { a | aaaa | cname | mx | ns | ptr | soa | srv | txt }
All types of DNS request parse failures are recorded.
context-admin
a: Specifies the A (host address) type.
aaaa: Specifies the AAAA type.
all-disable: Specifies no type.
all-enable: Specifies all types.
cname: Specifies the canonical name type.
mx: Specifies the mail exchanger type.
ns: Specifies the name server type.
ptr: Specifies the pointer type.
soa: Specifies the start of authority type.
srv: Specifies the service type.
txt: Specifies the text type.
# Configure the A-type DNS request parse failures to be recorded.
[Sysname] loadbalance local-dns-server parse-fail-record type a
loadbalance local-dns-server parse-fail-record max-number
Use loadbalance local-dns-server parse-fail-record max-number to set the maximum number of DNS request parse failures to be recorded.
Use undo loadbalance local-dns-server parse-fail-record max-number to restore the default.
loadbalance local-dns-server parse-fail-record max-number max-number
The maximum number of DNS request parse failures to be recorded is 10000.
context-admin
max-number: Specifies the maximum number of DNS request parse failures to be recorded, in the range of 0 to 4294967295.
# Set the maximum number of DNS request parse failures to be recorded to 600.
[Sysname] loadbalance local-dns-server parse-fail-record max-number 600
loadbalance local-dns-server schedule-test ip
Use loadbalance local-dns-server schedule-test ip to perform an IPv4 inbound link load balancing test for DNS resolution.
In standalone mode:
loadbalance local-dns-server schedule-test ip [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address { ipv4-address | ipv6-address } } [ slot slot-number ]
In IRF mode:
loadbalance local-dns-server schedule-test ip [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address { ipv4-address | ipv6-address } } [ chassis chassis-number slot slot-number ]
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command is executed for the public network.
destination destination-address: Specifies the destination IPv4 address, the IPv4 address of the DNS listener.
destination-port destination-port: Specifies the destination port number in the range of 0 to 65535. The default is 53.
source source-address: Specifies the source IPv4 address.
source-port source-port: Specifies the source port number in the range of 0 to 65535.
type: Specifies a DNS request type.
domain domain-name: Specifies the domain name to be resolved, a case-insensitive, dot-separated string of 1 to 254 characters for an absolute domain name or 1 to 253 characters for a relative domain name. Each dot-separated label in the domain name can contain a maximum of 63 characters.
ptr: Specifies the pointer type, which is used to resolve an IP address into a domain name.
ip address { ipv4-address | ipv6-address }: Specifies the IP address to be resolved into a domain name.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command tests all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command tests all cards. (In IRF mode.)
# Perform an IPv4 inbound link load balancing test on A-type DNS requests.
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type a domain www.aaa.com
Slot 0:
Matched DNS listener: dl2
Matched zone: --
Matched DNS mapping: dm2
Matched virtual server pool: vsp2
Preferred scheduling algorithm: Round robin
Alternative scheduling algorithm: --
Fallback scheduling algorithm: --
Preferred algorithm failure cause: --
Alternative algorithm failure cause: --
Fallback algorithm failure cause: --
Selected virtual server: vs2
Response type: Send response
Failure cause: --
# Perform an IPv4 inbound link load balancing test on MX-type DNS requests.
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type mx domain www.aaa.com
Slot 0:
Matched zone: h3c.com
Failure cause: --
# Perform an IPv4 inbound link load balancing test on PTR-type DNS requests.
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type ptr ip address 1.2.3.4
Slot 0:
Matched zone: 1.2.3.0/24
Failure cause: --
Table 42 Command output
Matched zone |
Matched DNS zone. · For a PTR-type DNS request, this field displays the IP address of the DNS reverse zone. · For a DNS request other than the PTR type, this field displays the domain name of the DNS forward zone. |
Preferred scheduling algorithm |
Preferred scheduling algorithm: · Round robin. · Random. · Least connection. · Topology. · Proximity. · Bandwidth. · Inbound bandwidth. · Outbound bandwidth. · Max bandwidth. · Max inbound bandwidth. · Max outbound bandwidth. · Hash address source IP. · Hash address destination IP. · Hash address source IP-port. |
Alternative scheduling algorithm |
Alternative scheduling algorithm: · Round robin. · Random. · Least connection. · Topology. · Proximity. · Bandwidth. · Inbound bandwidth. · Outbound bandwidth. · Max bandwidth. · Max inbound bandwidth. · Max outbound bandwidth. · Hash address source IP. · Hash address destination IP. · Hash address source IP-port. |
Fallback scheduling algorithm |
Backup scheduling algorithm: · Round robin. · Random. · Least connection. · Topology. · Proximity. · Bandwidth. · Inbound bandwidth. · Outbound bandwidth. · Max bandwidth. · Max inbound bandwidth. · Max outbound bandwidth. · Hash address source IP. · Hash address destination IP. · Hash address source IP-port. |
Preferred algorithm failure cause |
Preferred algorithm failure cause: · --—Scheduling succeeded. · No scheduling content. · Scheduling failed—The scheduling content exists, but scheduling failed. · No matched virtual server member. |
Alternative algorithm failure cause |
Alternative algorithm failure cause: · --—Scheduling succeeded. · No scheduling content. · Scheduling failed—The scheduling content exists, but scheduling failed. · No matched virtual server member. |
Fallback algorithm failure cause |
Backup algorithm failure cause: · --—Scheduling succeeded. · No scheduling content. · Scheduling failed—The scheduling content exists, but scheduling failed. · No matched virtual server member. |
Response type |
Response type for a DNS request: · Send response—Replies with a DNS response. · Send reject—Replies with a DNS reject. · No response—Does not respond to the DNS request. |
Failure cause |
Failure cause for DNS request parsing: · --—Parsing succeeded. · No matched DNS listener. · No matched DNS mapping. · No matched virtual server pool. · No matched DNS zone. · Failed to get buffer. · No matched record. · No enough memory resource. · Failed to parse domain. · Failed to find DNS listener by ID. · No scheduling content. · Scheduling failed—The scheduling content exists, but scheduling failed. · No matched virtual server member. |
loadbalance local-dns-server schedule-test ipv6
Use loadbalance local-dns-server schedule-test ipv6 to perform an IPv6 inbound link load balancing test for DNS resolution.
In standalone mode:
loadbalance local-dns-server schedule-test ipv6 [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address ipv4-address } [ slot slot-number ]
In IRF mode:
loadbalance local-dns-server schedule-test ipv6 [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address { ipv4-address | ipv6-address } } [ chassis chassis-number slot slot-number ]
context-admin
destination destination-address: Specifies the destination IPv6 address, the IPv6 address of the DNS listener.
source source-address: Specifies the source IPv6 address.
a: Specifies the IPv4 host address type.
aaaa: Specifies the IPv6 host address type.
ptr: Specifies the pointer type, which is used to resolve an IP address to a domain name.
ip address { ipv4-address | ipv6-address }: Specifies the IP address to be resolved to a domain name.
# Perform an IPv6 inbound link load balancing test on A-type DNS requests.
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 source 1::5 source-port 5 type a domain www.aaa.com
Slot 0:
Matched zone: --
Preferred algorithm failed cause: --
Alternative algorithm failed cause: --
Fallback algorithm failed cause: --
Selected virtual server: vsa1
Failure cause: --
# Perform an IPv6 inbound link load balancing test on MX-type DNS requests.
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 destination-port 953 source 1::5 source-port 5 type mx domain www.aaa.com
Slot 0:
Failure cause: --
# Perform an IPv6 inbound link load balancing test on PTR-type DNS requests.
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 source 1::5 source-port 5 type ptr ip address 1.2.3.4
Slot 0:
Failure cause: --
Table 43 Command output
Matched zone |
Matched DNS zone. · For a PTR-type DNS request, this field displays the IPv6 address of the DNS reverse zone. · For a DNS request other than the PTR type, this field displays the domain name of the DNS forward zone. |
Alternative scheduling algorithm: · Round robin. · Random. · Least connection. · Topology. · Proximity. · Bandwidth. · Inbound bandwidth. · Outbound bandwidth. · Max bandwidth. · Max inbound bandwidth. · Max outbound bandwidth. · Hash address source IP. · Hash address destination IP. · Hash address source IP-port. · --—No alternative scheduling algorithm is configured. |
Backup scheduling algorithm: · Round robin. · Random. · Least connection. · Topology. · Proximity. · Bandwidth. · Inbound bandwidth. · Outbound bandwidth. · Max bandwidth. · Max inbound bandwidth. · Max outbound bandwidth. · Hash address source IP. · Hash address destination IP. · Hash address source IP-port. · --—No alternative scheduling algorithm is configured. |
Response type |
Failure cause |
Failure cause for DNS request parsing: · --—Parsing succeeded. · No matched DNS listener. · No matched DNS mapping. · No matched virtual server pool. · No matched DNS zone. · Failed to get buffer. · Failed to get CONTEXT. · No matched record. · No enough memory resource. · Failed to parse domain. · Failed to find DNS listener by ID. · No scheduling content. · Scheduling failed—The scheduling content exists, but scheduling failed. · No matched virtual server member. |
loadbalance log enable bandwidth-busy
Use loadbalance log enable bandwidth-busy to enable load balancing link busy state logging.
Use undo loadbalance log enable bandwidth-busy to disable load balancing link busy state logging.
Load balancing link busy state logging is disabled.
context-admin
Load balancing link busy state logging records busy states for all links.
# Enable load balancing link busy state logging.
[Sysname] loadbalance log enable bandwidth-busy
loadbalance log enable base
Use loadbalance log enable base to enable load balancing basic logging.
Use undo loadbalance log enable base to disable load balancing basic logging.
Load balancing basic logging is enabled.
context-admin
vsys-admin
Load balancing basic logging generates logs for the following events:
· The state of a real server, real server group, link, or link group changes.
· The health monitoring result of a real server or link changes.
· The number of connections on a real server, virtual server, or link reaches or drops below the upper limit.
· The connection establishment rate on a real server, virtual server, or link reaches or drops below the upper limit.
· A primary/backup server farm switchover occurs between server farms specified for a virtual server.
· A primary/backup link group switchover occurs between link groups specified for a virtual server.
· A primary/backup server farm switchover occurs between server farms specified for an LB action.
· A primary/backup link group switchover occurs between link groups specified for an LB action.
# Enable load balancing basic logging.
[Sysname] loadbalance log enable base
loadbalance log enable link-flow
Use loadbalance log enable link-flow to enable load balancing link flow logging.
Use undo loadbalance log enable link-flow to disable load balancing link flow logging.
Load balancing link flow logging is disabled.
context-admin
Use this command to enable logging for flows forwarded through all links.
# Enable load balancing link flow logging.
[Sysname] loadbalance log enable link-flow
loadbalance log enable nat
Use loadbalance log enable nat to enable load balancing NAT logging.
Use undo loadbalance log enable nat to disable load balancing NAT logging.
Load balancing NAT logging is disabled.
context-admin
vsys-admin
Load balancing NAT logging records NAT session information, including IP address and port translation information and access information.
Load balancing NAT logs are exported as flow logs. To export load balancing NAT logs, you must also configure flow log settings.
For more information about flow logs, see Network Management and Monitoring Configuration Guide.
# Enable load balancing NAT logging.
[Sysname] loadbalance log enable nat
loadbalance policy
Use loadbalance policy to create an LB policy and enter its view, or enter the view of an existing LB policy.
Use undo loadbalance policy to delete the specified LB policy.
loadbalance policy policy-name [ type { dns | generic | http | link-generic | mysql | radius } ]
undo loadbalance policy policy-name
No LB policies exist.
context-admin
vsys-admin
policy-name: Specifies the LB policy name, a case-insensitive string of 1 to 63 characters.
type { dns | generic | http | link-generic | mysql | radius }: Specifies an LB policy type.
· dns: DNS load balancing policy. Non-default vSystems do not support this parameter.
· generic: Generic server load balancing policy.
· http: HTTP load balancing policy.
· link-generic: Link load balancing policy. Non-default vSystems do not support this parameter.
· mysql: MySQL load balancing policy.
· radius: RADIUS load balancing policy.
When you create an LB policy, you must specify the LB policy type. You can enter existing LB policy view without entering the type of the LB policy.
You can create generic, HTTP, MySQL, and RADIUS LB policies only if the device has licenses installed. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create the LB policy lbp1 with the generic type, and enter LB policy view.
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1]
loadbalance probe-template
Use loadbalance probe-template to create an LB probe template and enter its view, or enter the view of an existing LB probe template.
Use undo loadbalance probe-template to delete an LB probe template.
loadbalance probe-template { external-monitor | http-passive | icmp | tcp-rst | tcp-zero-window } template-name
undo loadbalance probe-template { external-monitor | http-passive | icmp | tcp-rst | tcp-zero-window } template-name
No LB probe templates exist.
context-admin
vsys-admin
external-monitor: Specifies the custom-monitoring-type template. Non-default vSystems do not support this parameter.
http-passive: Specifies the HTTP-passive-type template.
icmp: Specifies the ICMP-type template. Non-default vSystems do not support this parameter.
tcp-rst: Specifies the TCP-RST template.
tcp-zero-window: Specifies the TCP zero-window template.
template-name: Specifies a template name, a case-insensitive string of 1 to 32 characters.
A server farm, a server farm member, or a real server can use a custom-monitoring LB probe template to detect the health state of each real server.
A server farm can use an HTTP passive LB probe template to count the number of URL error times by monitoring the responses of HTTP requests to each real server.
The proximity feature can use an ICMP LB probe template to start ICMP tests and identify the reachability of hosts according to received ICMP responses.
A server farm can use a TCP-RST or TCP zero-window LB probe template to count the number of RST packets or zero-window packets sent by each server farm member.
# Create an LB probe template named icmptplt, and enter LB probe template view.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lbpt-icmp-icmptplt]
loadbalance process-limit
Use loadbalance process-limit to set the maximum number of processes allowed to be started for custom monitoring.
Use undo loadbalance process-limit to restore the default.
loadbalance process-limit number
A maximum of four processes can be started for custom monitoring.
context-admin
number: Specifies the maximum number of processes, in the range of 1 to 8.
# Set the maximum number of processes allowed to be started for custom monitoring to 200.
[Sysname] loadbalance process-limit 200
display loadbalance process-limit
loadbalance protection-policy
Use loadbalance protection-policy to create a protection policy and enter its view, or enter the view of an existing protection policy.
Use undo loadbalance protection-policy to delete a protection policy.
loadbalance protection-policy policy-name [ type http ]
undo loadbalance protection-policy policy-name
No protection policies exist.
context-admin
vsys-admin
policy-name: Specifies a protection policy name, a case-insensitive string of 1 to 63 characters.
type http: Specifies the HTTP-type protection policy. When you create a protection policy, you must specify the policy type. You can enter the view of an existing protection policy without specifying the policy type.
# Create an HTTP protection policy named p1 and enter its view.
[Sysname] loadbalance protection-policy p1 type http
[Sysname-lbpp-http-p1]
Use loadbalance proximity to create proximity and enter its view, or enter the view of the existing proximity.
Use undo loadbalance proximity to delete proximity view and clear all configuration in proximity view.
loadbalance proximity [ vpn-instance vpn-instance-name ]
undo loadbalance proximity [ vpn-instance vpn-instance-name ]
context-admin
# Create and enter proximity view.
loadbalance region
Use loadbalance region to create a region and enter its view, or enter the view of an existing region.
Use undo loadbalance region to delete a region.
loadbalance region region-name
undo loadbalance region region-name
No regions exist.
context-admin
region-name: Specifies the region name, a case-insensitive string of 1 to 63 characters.
A region contains network segments corresponding to different ISPs.
# Create the region isp-ct, and enter region view.
[Sysname] loadbalance region isp-ct
[Sysname-lb-region-isp-ct]
loadbalance reload external-link file
Use loadbalance reload external-link file to load an external link rewrite file.
Use undo loadbalance reload external-link file to remove the configuration.
loadbalance reload external-link file filename
No external link rewrite file is used.
context-admin
filename: Specifies a file by its complete name, a case-insensitive string of 1 to 256 characters.
If the file content has changed, you must reload the external link rewrite file to ensure it is effective.
Make sure the file format is supported by the client browser. As a best practice, use the JS script file.
By default, a distributed device loads the external link rewrite file from the active MPU.
Make sure the name of the external link rewrite file is different from the response file for HTTP requests.
# Load external link rewrite file /sub_lb_sw.js.
[Sysname] loadbalance reload external-link file /sub_lb_sw.js
external-link inject-domain-suffix
external-link inject-uri
external-link proxy enable
external-link whitelist domain
loadbalance reverse-zone
Use loadbalance reverse-zone to create a DNS reverse zone and enter its view, or enter the view of an existing DNS reverse zone.
Use undo loadbalance reverse-zone to delete a DNS reverse zone.
loadbalance reverse-zone { ip ipv4-address mask-length | ipv6 ipv6-address prefix-length }
undo loadbalance reverse-zone { ip ipv4-address mask-length | ipv6 ipv6-address prefix-length }
No DNS reverse zones exist.
context-admin
ip ipv4-address mask-length: Specifies an IPv4 address and mask length for the DNS reverse zone. The value range for the mask-length argument is 0 to 32.
ipv6 ipv6-address prefix-length: Specifies an IPv6 address and prefix length for the DNS reverse zone. The value range for the prefix-length argument is 0 to 128.
# Create a DNS reverse zone with IPv4 address 10.11.2.0/24, and enter DNS reverse zone view.
[Sysname] loadbalance reverse-zone ip 10.11.2.0 24
[Sysname-lb-rzone-10.11.2.0/24]
# Create a DNS reverse zone with IPv6 address 1001::0/64, and enter DNS reverse zone view.
[Sysname] loadbalance reverse-zone ipv6 1001::0 64
[Sysname-lb-rzone-1001::/64]
display loadbalance reverse-zone
loadbalance session flow-redirect local
Use loadbalance session flow-redirect local to enable traffic processing on the security module that forwards return packets.
Use undo loadbalance session flow-redirect local to restore the default.
The device transparently transmits the return packets to the security module where the original packets are forwarded.
context-admin
After you execute the session flow-redirect enable command to enable session flow redirection, the packets and return packets of a data flow can be correctly processed when they are forwarded to different security modules. After this feature is enabled, the system immediately synchronizes the session information created for the packets to the security module where return packets are processed. If the original packets and return packets are forwarded to different security modules, the device transparently transmits the return packets to the security module where the original packets are forwarded. This command disables transparent transmission of return packets to the security module of the original packets if they are forwarded to different security modules. The return packets will be directly processed by the local security module. Without transparent packet transmission, you can save resource costs and improve device performance. For more information about session flow redirection, see session management in Security Configuration Guide.
For the session flow redirection feature to take effect, first disable traffic distribution rule deployment with the loadbalance flow-redirect disable command.
Do not execute this command for the Layer 7 server load balancing or ALG feature that requires processing both packets and return packets on the same security module.
# Enable traffic processing on the security module that forwards return packets.
<Sysname> system
[Sysname] loadbalance session flow-redirect local
session flow-redirect enable (Security Command Reference)
loadbalance schedule-test ip
Use loadbalance schedule-test ip to perform an IPv4 load balancing test.
In standalone mode:
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
In IRF mode:
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ chassis chassis-number slot slot-number ]
context-admin
application: Specifies an application to be tested.
http: Specifies the HTTP application.
message-file file-name: Specifies the file that contains HTTP packet contents. The file name is a case-insensitive string of 1 to 255 characters. The file size cannot exceed 5000 bytes.
method: Specifies an HTTP request method.
get: Specifies the GET method.
post: Specifies the POST method.
url url: Specifies a URL for the HTTP packet, a case-insensitive string of 1 to 255 characters. A URL can contain letters, digits, hyphens (-), underscores (_), and periods (.). The URL cannot contain consecutive periods.
[ header header ]&<1-10>: Specifies a space-separated list of up to 10 HTTP packet headers. A header is a case-sensitive string of 1 to 127 characters excluding question marks (?).
content content-value: Specifies the content of the HTTP packet body, a case-sensitive string of 1 to 255 characters excluding question marks (?).
protocol { protocol-number | icmp | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMP (1), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv4 address.
destination-port destination-port: Specifies the destination port number in the range of 0 to 65535. This option is not supported by some protocols.
source-port source-port: Specifies the source port number in the range of 0 to 65535. This option is not supported by some protocols.
# Perform an IPv4 load balancing test for the TCP protocol.
Matched virtual server: vs2
Matched default server farm: sf
Forward type: Forwarding to real server
Selected real server: rs2
Scheduling algorithm: Predictor
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
Matched default link group: lg
Forward type: Forwarding to link
Selected link: link2
Table 44 Command output
Forwarding mode: · The destination address is not supported. Load balancing is not performed. · Matching HTTP virtual server is not supported—An HTTP virtual server is matched. Load balancing is not supported. · Forward all—Forwards packets. · Forwarding to real server—Forwards packets to the real server. · Forwarding to link—Forwards packets to the link. · Drop—Drops packets. · Redirect—Redirects packets. · Waiting—Enqueues packets. |
Packet drop reason: · Number of connections or bandwidth for the virtual server exceeded the limit. · No class matched and no valid default server farm/link group configured. · No valid real server/link in the server farm/link group. · Action is drop. · A sticky entry was matched but the number of connections or bandwidth for the real server/link exceeded the limit. · A class was matched but no valid server farm/link group exists in the action of the class. · The HTTP message is not valid. · The HTTP request line is not valid. · The HTTP header is not valid. · The chunk HTTP content is not valid. · The server farm is busy. · Queue overflow (which means the wait queue is full). |
Scheduling algorithm used to select the real server or link: · Predictor—The real server or link is selected by using the scheduling algorithm. · Sticky method—The real server or link is selected by using the sticky method. · Proximity—The link is selected by using the proximity feature. |
loadbalance schedule-test ipv6
Use loadbalance schedule-test ipv6 to perform an IPv6 load balancing test.
In standalone mode:
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
In IRF mode:
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ chassis chassis-number slot slot-number ]
context-admin
protocol { protocol-number | icmpv6 | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMPv6 (58), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv6 address.
# Schedule an IPv6 load balancing test for the ICMPv6 protocol.
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
Table 45 Command output
Forward type |
Forwarding mode: · The destination address is not supported. Load balancing is not performed. · Matching HTTP virtual server is not supported—An HTTP virtual server is matched. Load balancing is not supported. · Forward all—Forwards packets. · Forwarding to real server/link—Forwards packets to the real server or link. · Drop—Drops packets. · Redirect—Redirects packets. · Waiting—Enqueues packets. |
Drop reason |
Scheduling algorithm |
loadbalance snat-global-policy
Use loadbalance snat-global-policy to create a SNAT global policy and enter its view, or enter the view of an existing SNAT global policy.
Use undo loadbalance snat-global-policy to delete the specified SNAT global policy.
loadbalance snat-global-policy policy-name
undo loadbalance snat-global-policy policy-name
No SNAT global policies exist.
context-admin
vsys-admin
policy-name: Specifies the SNAT global policy name, a case-insensitive string of 1 to 63 characters.
# Create the SNAT global policy sn1, and enter SNAT global policy view.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1]
snat-mode
snat-pool (server farm view)
loadbalance snat-pool
Use loadbalance snat-pool to create a SNAT address pool and enter its view, or enter the view of an existing SNAT address pool.
Use undo loadbalance snat-pool to delete the specified SNAT address pool.
loadbalance snat-pool pool-name [ type { address-split | failover-group | port-split } ]
undo loadbalance snat-pool pool-name
No SNAT address pools exist.
context-admin
vsys-admin
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters.
type: Specifies a splitting method for the SNAT address pool. If you do not specify this keyword, the address-split method is used.
address-split: Specifies the address-based splitting method.
failover-group: Specifies the failover group-based splitting method.
port-split: Specifies the port-based splitting method.
When multiple service modules are installed on the device, address conflicts might occur among the service modules. To solve this problem, you can split a SNAT address pool by using the following methods:
· Address-based splitting—Evenly divides IP addresses in the address pool among failover groups. Each failover group uses a unique subset of the IP addresses in the address pool.
· Port-based splitting—Evenly divides port numbers in the address pool among failover groups. Each failover group uses the full set of the IP addresses in the address pool, with a different set of port numbers.
· Failover group-based splitting—Uses an IP address range in an address pool only for a specific failover group. When you configure an IP address range for an address pool, you can specify the failover group to use that IP address range.
For more information about failover groups, see Virtual Technologies Configuration Guide.
# Create the SNAT address pool lbsp, and enter SNAT address pool view.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp]
loadbalance test pcre
Use loadbalance test pcre to perform a PCRE regular expression match test and display the match result.
loadbalance test pcre value value { string string | file file-name } [ offset offset ] [ case-insensitive ]
context-admin
value value: Specifies a PCRE regular expression, a case-sensitive string of 1 to 255 characters excluding question marks (?).
string string: Specifies the string to be tested, a case-sensitive string of 1 to 255 characters.
file file-name: Specifies the file to be tested by its name, a case-insensitive string of 1 to 255 characters. The file size cannot exceed 5000 bytes.
offset offset: Specifies the offset from the content to be tested, in the range of 0 to 255 bytes. The default is 0.
case-insensitive: Enables case-insensitivity matching. If you do not specify this keyword, case-sensitivity matching applies.
Non-default vSystems do not support this command.
If the specified string or file matches the PCRE regular expression multiple times, the device displays only the result of the first match.
For a string test, the device displays the match result in text strings. For a file test, the device displays the match result in both hexadecimal characters and text strings. Characters that cannot be displayed are represented as periods (.).
# Perform a PCRE regular expression match test for string ABCDAAaefg.
<Sysname> loadbalance test pcre value aaa string ABCDAAaefg case-insensitive
Matched string content: AAa
# Perform a PCRE regular expression match test for file 123.txt.
<Sysname> loadbalance test pcre value dzckgjlfdsfdsfsdnfsdkjgnf file 123.txt
Matched file content:
64 7a 63 6b 67 6a 6c 66 64 73 66 64 73 66 73 64 dzckgjlf dsfdsfsd
6e 66 73 64 6b 6a 67 6e 66 64 nfsdkjgn f
loadbalance test rewrite
Use loadbalance test rewrite to perform a regular-expression-based rewrite test and display the rewrite result.
loadbalance test rewrite value value replace replace-string { string string | file file-name } [ offset offset ] [ case-insensitive ]
context-admin
value value: Specifies a regular expression to match the content to be rewritten, a case-sensitive string of 1 to 255 characters excluding question marks (?). You can also specify the following character strings:
· %is—Source IP address.
· %ps—Source port number.
· %id—Destination IP address.
· %pd—Destination port number.
replace replace-string: Specifies the content after rewrite, a case-sensitive string of 1 to 255 characters.
If the string or file to be tested matches the regular expression, the device replaces the matching content with the content after rewrite.
If the string or file matches the regular expression multiple times, the device displays only the rewrite result of the first match.
For a string test, the device displays the rewrite result in text strings. For a file test, the device displays the rewrite result in both hexadecimal characters and text strings. Characters that cannot be displayed are represented as periods (.).
# Perform a rewrite test for string ABCDAAaefg.
<Sysname> loadbalance test rewrite value %id replace ip:%id,port:%pd string ABCDAAaefg case-insensitive
Rewritten string content: ABCD172.0.0.1fg
# Perform a rewrite test for file 123.txt.
<Sysname> loadbalance test rewrite value dzckgjlfdsfdsfsdnfsdkjgnf replace ip:%id,port:%pd file 123.txt
Rewritten file content:
66 67 73 2d 61 47 76 61 73 64 64 73 61 67 76 62 fgs-aGva sddsagvb
64 6a 63 78 6b 6c 63 78 76 0d 0a 0d 0a 0d 0a 0d djcxklcx v.......
0a 69 70 3a 31 37 32 2e 30 2e 30 2e 31 2c 70 6f .ip:172. 0.0.1,po
72 74 3a 38 30 09 6a 6b 64 67 6e 66 64 6a 6b 67 rt:80.jk dgnfdjkg
6e 66 64 6b 6a 67 6e 66 64 6b 6e 67 76 73 64 66 nfdkjgnf dkngvsdf
6c 0d 0a 0d 0a 0d 0a 0d 0a 66 67 73 2b 61 67 76 l....... .fgs+agv
61 73 64 64 73 61 67 76 62 64 6a 63 78 6b 6c 63 asddsagv bdjcxklc
78 76 0d 0a 66 67 73 64 61 67 76 61 73 64 64 73 xv..fgsd agvasdds
61 67 76 62 64 6a 63 78 6b 6c 63 78 76 agvbdjcx klcxv
loadbalance virtual-server-pool
Use loadbalance virtual-server-pool to create a virtual server pool and enter its view, or enter the view of an existing virtual server pool.
Use undo loadbalance virtual-server-pool to delete a virtual server pool.
loadbalance virtual-server-pool pool-name
undo loadbalance virtual-server-pool pool-name
No virtual server pools exist.
context-admin
pool-name: Specifies the virtual server pool name, a case-insensitive string of 1 to 63 characters.
You can add virtual servers with similar functions to a virtual server pool to facilitate management.
# Create the virtual server pool local-pool, and enter virtual server pool view.
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool]
loadbalance zone
Use loadbalance zone to create a DNS forward zone and enter its view, or enter the view of an existing DNS forward zone.
Use undo loadbalance zone to delete a DNS forward zone.
loadbalance zone domain-name
undo loadbalance zone domain-name
No DNS forward zones exist.
context-admin
domain-name: Specifies a domain name for the DNS forward zone, a case-insensitive string of 1 to 253 characters. Each dot-separated part in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
# Create a DNS forward zone with domain name abc.com, and enter DNS forward zone view.
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com]
display loadbalance zone
match
Use match to specify the proximity probe method for packets.
Use undo match to restore the default.
match [ match-id ] tcp { lb-probe lb-template | probe nqa-template }
undo match match-id
No proximity probe method is specified.
Proximity view
context-admin
match-id: Specifies a proximity probe method by its ID in the range of 1 to 65535. If the rule does not exist, the command creates the proximity probe method. If the rule already exists, the command modifies the proximity probe method. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest available ID.
tcp: Specifies TCP packets.
lb-probe lb-template: Specifies an LB probe template by its name, a case-insensitive string of 1 to 32 characters.
probe nqa-template: Specifies an NQA template by its name, a case-insensitive string of 1 to 32 characters.
If the match command is configured, the specified proximity probe method applies. If no packets match the type in the match command or the match command is not configured, the default proximity probe method specified by using the match default command applies.
You can specify only one proximity probe method for each type of packets.
If both the match command and the match default command are configured, specify the same template type in the two commands as a best practice for both templates to take effect. If you specify different template types, the NQA template does not take effect.
# Create the ICMP-type NQA template t4, and specify the NQA template as the proximity probe method for TCP packets.
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname] loadbalance proximity
[Sysname-lb-proximity] match tcp probe t4
match default
match acl
Use match class to create an ACL match rule or modify an existing ACL match rule.
Use undo match to delete a match rule.
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
No match rules exist.
LB class view
context-admin
vsys-admin
match-id: Specifies a match rule by its ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command creates an IPv4 ACL.
acl-number: Specifies the ACL number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter.
If the specified ACL does not exist, this rule is not matched.
You can create a maximum of 65535 match rules for an LB class.
# Create an ACL match rule for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match acl 2000
match app-group
Use match app-group to create an application group match rule or modify an existing application group match rule.
Use undo match app-group to delete a match rule.
match [ match-id ] app-group group-name
undo match match-id
Link-generic LB class view
context-admin
match-id: Specifies a match rule ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
app-group group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters.
If the specified application group does not exist, the rule does not take effect.
# Create an application group match rule for the link-generic LB class lbc1.
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1] match app-group http
app-group (Security Command Reference)
match class
Use match class to create a match rule that references an LB class or modify an existing match rule that references an LB class.
match [ match-id ] class class-name
undo match match-id
An LB class does not have a match rule.
LB class view
context-admin
vsys-admin
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters, to be referenced by the match rule. The current LB class cannot be referenced.
A match rule cannot reference an LB class that has already been referenced.
# Create a match rule that references the LB class lbc2 for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match class lbc2
match content
Use match content to create an HTTP entity match rule or modify an existing HTTP entity match rule.
match [ match-id ] content content [ offset offset ]
undo match match-id
HTTP LB class view
context-admin
vsys-admin
content content: Specifies the HTTP entity regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
offset offset: Specifies the offset value of the HTTP entity based on the start of the HTTP packet, in the range of 0 to 1000 bytes. The default is 0.
If the entity of an HTTP packet after the offset value matches the specified regular expression, the packet matches the rule.
# Create an HTTP entity match rule for the HTTP LB class lbc2: Specify the offset value as 10 and regular expression as abc.
[Sysname] loadbalance class lbc2 type http
[Sysname-lbc-http-lbc2] match content abc.* offset 10
match cookie
Use match cookie to create an HTTP cookie match rule or modify an existing HTTP cookie match rule.
match [ match-id ] cookie cookie-name value value
undo match match-id
HTTP LB class view
context-admin
vsys-admin
cookie cookie-name: Specifies the name of the HTTP cookie, a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the cookie value regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP packet contains the specified cookie with the value matching the specified regular expression, the packet matches the rule.
# Create an HTTP cookie match rule for the HTTP LB class lbc2: Specify the cookie name as JSession-id and cookie value regular expression as abc.
[Sysname-lbc-http-lbc2] match cookie JSession-id value abc.*
match default
Use match default to specify the default proximity probe method.
Use undo match default to restore the default.
match default { lb-probe lb-template | probe nqa-template }
The default proximity probe method is not specified.
Proximity view
context-admin
If the match command is configured, the specified proximity probe method applies. If no packets match the type in the match command or the match command is not configured, the default proximity probe method applies.
If both the match command and the match default command are configured, you must specify the same template type (load balancing or NQA) in the two commands as a best practice for both templates to take effect. If you specify different template types, the NQA template does not take effect.
# Create the ICMP-type NQA template t4, and specify the NQA template as the default proximity probe method.
[Sysname-lb-proximity] match default probe t4
match
nqa template (Network Management and Monitoring Command Reference)
match destination
Use match destination to create a destination IP address match rule or modify an existing destination IP address match rule.
match [ match-id ] destination { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
DNS/Link-generic LB class view
context-admin
ip address ipv4-address: Specifies an IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32.
mask: Specifies a subnet mask. The default is 255.255.255.255.
ipv6 address ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128.
# Create a match rule to match destination IPv4 address 1.1.1.1/32 for the DNS LB class lbc1.
[Sysname] loadbalance class lbc1 type dns
[Sysname-lbc-dns-lbc1] match destination ip address 1.1.1.1
# Create a match rule to match destination IPv4 address 1.1.1.1/32 for the link-generic LB class lbc2.
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match destination ip address 1.1.1.1
match destination domain-name
Use match destination domain-name to create a domain name match rule or modify an existing domain name match rule.
match [ match-id ] destination domain-name domain-name
undo match match-id
context-admin
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. Each dot-separated part in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), dots (.), and wildcards (asterisks and question marks).
When you use wildcards (asterisks and question marks) in a domain name, follow these guidelines:
· The wildcards can substitute any characters except for dots (.).
· An asterisk (*) can substitute a character string.
· A question mark (?) can substitute a single character.
# Create a domain name match rule for the link-generic LB class lbc1 to match domain name www.abc.com.
[Sysname-lbc-link-generic-lbc1] match destination domain-name www.aaa.com
match domain-name
Use match domain-name to create a domain name match rule or modify an existing domain name match rule.
match [ match-id ] domain-name domain-name
undo match match-id
DNS LB class view
context-admin
# Create a domain name match rule for DNS LB class lbc1 to match domain name www.abc.com.
[Sysname-lbc-dns-lbc1] match domain-name www.abc.com
match header
Use match header to create an HTTP header match rule or modify an existing HTTP header match rule.
match [ match-id ] header header-name value value
undo match match-id
HTTP LB class view
context-admin
vsys-admin
header header-name: Specifies the name of the HTTP packet header, a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the header value regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP packet contains the specified header with the value matching the specified regular expression, the packet matches the rule.
# Create an HTTP header match rule for the HTTP LB class lbc2: Specify the HTTP packet header name as user-agent and header value regular expression as abcd.
[Sysname-lbc-http-lbc2] match header user-agent value abcd
match interface
Use match interface to create an interface match rule or modify an existing interface match rule.
match [ match-id ] interface interface-type interface-number
undo match match-id
Generic/HTTP/Link-generic LB class view
context-admin
interface interface-type interface-number: Specifies an interface by its type and number. The interface type can be Layer 3 Ethernet interface and Layer 3 aggregate interface.
If the specified interface does not exist, the rule does not take effect.
# Create an interface match rule for the link-generic LB class lbc1 to match interface GigabitEthernet 1/0/0.
[Sysname-lbc-link-generic-lbc1] match interface gigabitethernet 1/0/0
match isp
Use match isp to create an ISP match rule or modify an existing ISP match rule.
match [ match-id ] isp isp-name
undo match match-id
LB class view
context-admin
isp-name: Specifies an ISP name, a case-insensitive string of 1 to 63 characters.
If the specified ISP does not exist or is not configured with an IP network segment, this rule is not matched.
# Create an ISP match rule for the generic LB class lbc1. Specify the ISP name as isp1.
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1] match isp isp1
match method
Use match method to create an HTTP method match rule or modify an existing HTTP method match rule.
match [ match-id ] method { ext ext-type | rfc rfc-type }
undo match match-id
HTTP LB class view
context-admin
vsys-admin
ext ext-type: Specifies the extended type, a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
rfc rfc-type: Specifies the RFC type to process the resources identified by the URI in HTTP request packets:
· CONNECT—Maintain the resources.
· DELETE—Delete the resources.
· GET—Request for the resources.
· HEAD—Request for the header of the response message of the resources.
· OPTIONS—Request to query the resources-related options and requirements supported by the server.
· POST—Add new data to the resources.
· PUT—Request the server to store the resource identified by the URI.
· TRACE—Request the server to return the request message it receives for test or diagnosis.
# Create a packet matching method match rule with extended type user for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match method ext user
# Create a packet matching method match rule with RFC type CONNECT for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match method rfc CONNECT
match payload
Use match payload to create a TCP payload match rule or modify an existing TCP payload match rule.
match [ match-id ] payload payload [ case-insensitive ] [ not ]
undo match match-id
Generic LB class view
context-admin
vsys-admin
payload: Specifies the TCP payload regular expression, a case-sensitive string of 1 to 255 characters.
case-insensitive: Disables case sensitivity for matching character strings. If you do not specify this keyword, case sensitivity is enabled.
not: Negates the match rule. If you do not specify this keyword, the LB action is taken when the TCP payload regular expression is matched.
The device takes the corresponding LB action on TCP packets matching a TCP payload match rule. If you specify the not keyword for a TCP payload match rule, the device takes the corresponding LB action on TCP packets not matching the TCP payload match rule.
# Create a match rule to match the payload hello for generic LB class c1.
[Sysname] loadbalance class c1 type generic
[Sysname-lbc-generic-c1] match payload hello
match radius-attribute
Use match radius-attribute to create a RADIUS attribute match rule or modify an existing RADIUS attribute match rule.
match [ match-id ] radius-attribute { code attribute-code | user-name } value attribute-value
undo match match-id
RADIUS LB class view
context-admin
vsys-admin
code attribute-code: Specifies the code of the RADIUS attribute type, in the range of 1 to 255.
user-name: Specifies the RADIUS attribute type as user-name (code 1).
value attribute-value: Specifies the RADIUS attribute regular expression, a case-sensitive string of 1 to 255 characters.
# Create a match rule to match usernames that contain aaa for RADIUS LB class lbc1.
[Sysname] loadbalance class lbc1 type radius
[Sysname-lbc-radius-lbc1] match radius-attribute user-name value aaa*
match source
Use match source to create a source IP address match rule or modify an existing source IP address match rule.
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
LB class view
context-admin
vsys-admin
source: Specifies the match rule type as source IP address.
# Create a match rule that matches source IP address 1.1.1.1/32 for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match source ip address 1.1.1.1
match sql
Use match sql to create a MySQL statement match rule or modify an existing MySQL statement match rule.
match [ match-id ] sql sql [ case-insensitive ] [ not ]
undo match match-id
MySQL LB class view
context-admin
vsys-admin
sql: Specifies a regular expression used to match MySQL statements, a case-sensitive string of 1 to 255 characters.
not: Specifies that the LB action is taken when the MySQL statement regular expression is not matched. If you do not specify this keyword, the LB action is taken when the MySQL statement regular expression is matched.
# Create a match rule that matches MySQL statement select for the MySQL LB class c1.
[Sysname] loadbalance class c1 type mysql
[Sysname-lbc-mysql-lbc1] match sql select
match url
Use match url to create an HTTP URL match rule or modify an existing HTTP URL match rule.
match [ match-id ] url url
undo match match-id
HTTP LB class view
context-admin
vsys-admin
url url: Specifies a URL regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
# Create an HTTP URL match rule with regular expression .*.html for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match url .*.html
match user
Use match user to create a user match rule or modify an existing user match rule.
match [ match-id ] [ identity-domain domain-name ] user user-name
undo match match-id
context-admin
vsys-admin
identity-domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user among users that do not belong to any identity domain.
user-name: Specifies a username, a case-sensitive string of 1 to 55 characters.
If the specified user does not exist, the rule does not take effect.
# Create a user match rule for the link-generic LB class lbc1 to match user u1 in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user u1
display loadbalance class
match user-group
Use match user-group to create a user group match rule or modify an existing user group match rule.
match [ match-id ] [ identity-domain domain-name ] user-group user-group-name
undo match match-id
context-admin
vsys-admin
identity-domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user group among user groups that do not belong to any identity domain.
user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 200 characters.
If the specified user group does not exist, the rule does not take effect.
# Create a user group match rule for the link-generic LB class lbc1 to match user group lb-group in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user-group lb-group
match version
Use match version to create an HTTP version match rule or modify an existing HTTP version match rule.
match [ match-id ] version { 1.0| 1.1 }
undo match match-id
HTTP LB class view
context-admin
vsys-admin
1.0: Specifies HTTP 1.0.
1.1: Specifies HTTP 1.1.
# Create an HTTP version match rule with HTTP 1.0 for the HTTP LB class lbc1.
[Sysname] loadbalance class lbc1 type http
[Sysname-lbc-dns-lbc1] match version 1.0
match-across-service enable
Use match-across-service enable to enable sticky entry matching across services.
Use undo match-across-service enable to disable sticky entry matching across services.
Sticky entry matching across services is disabled.
Address-port sticky group view
RADIUS sticky group view
context-admin
When the device fails to find matching a stikcy entry for traffic of a virtual server, this feature allows the device to match the sticky entries of other virtual servers with the same IP address as the current virtual server.
With this feature enabled, the device can distribute requests from the same client to different services of the same virtual server to the same server farm member.
# In address-port sticky group sg1, enable sticky entry matching across services.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] match-across-service enable
match-across-virtual-server enable
Use match-across-virtual-server enable to enable sticky entry matching across virtual servers.
Use undo match-across-virtual-server enable to disable sticky entry matching across virtual servers.
Sticky entry matching across virtual servers is disabled.
context-admin
When the device fails to find matching a stikcy entry for traffic of a virtual server, this feature allows the device to match the sticky entries of other virtual servers.
With this feature enabled, the device can distribute requests from the same client to different virtual servers to the same server farm member.
# In address-port sticky group sg1, enable sticky entry matching across virtual servers.
[Sysname-sticky-address-port-sg1] match-across-virtual-server enable
match-buffer-end
Use match-buffer-end to configure the buffering end string for TCP payload matching.
Use undo match-buffer-end to restore the default.
match-buffer-end string
No buffering end string is configured.
TCP-application parameter profile view
context-admin
vsys-admin
string: Specifies a string that indicates the end of buffering, a case-insensitive string of 1 to 31 characters.
For the TCP payload match rule, the device buffers traffic from clients for TCP payload matching during the buffering period. The device stops buffering traffic when any of the following events occurs:
· The device receives the buffering end string from clients.
· The size of buffered data exceeds the specified buffering size.
· The buffered data matches the TCP payload match rule.
This command specifies the string that indicates the end of buffering for traffic received from clients.
# In TCP-application parameter profile p1, configure the buffering end string as over.
[Sysname] parameter-profile p1 type tcp-application
[Sysname-para-tcp-application-p1] match-buffer-end over
match-buffer-size
match-buffer-time
match payload
match-buffer-size
Use match-buffer-size to set the maximum buffering size for TCP payload matching.
Use undo match-buffer-size to restore the default.
match-buffer-size size
The maximum buffering size is 4096 bytes.
context-admin
vsys-admin
size: Specifies the maximum buffering size in the range of 1 to 4096 bytes.
This command specifies the maximum size of TCP data from clients that the device can buffer.
# In TCP-application parameter profile p1, set the maximum buffering size to 2048 bytes for TCP payload matching.
[Sysname-para-tcp-application-p1] match-buffer-size 2048
match-buffer-end
match-buffer-time
match payload
match-buffer-time
Use match-buffer-time to set the buffering period for TCP payload matching.
Use undo match-buffer-time to restore the default.
match-buffer-time time
The buffering period for TCP payload matching is 3 seconds.
context-admin
vsys-admin
time: Specifies the buffering period in the range of 1 to 5 seconds.
This command specifies the amount of time for the device to buffer TCP data sent by clients.
# In TCP-application parameter profile p1, set the buffering period for TCP payload matching to 3 seconds.
[Sysname-para-tcp-application-p1] match-buffer-time 3
match-buffer-end
match-buffer-size
match payload
max-bandwidth
Use max-bandwidth to set the maximum expected bandwidth of an LB link.
Use undo max-bandwidth to restore the default.
max-bandwidth [ inbound | outbound ] bandwidth-value kbps
undo max-bandwidth [ inbound | outbound ]
The maximum expected bandwidth of an LB link is not limited.
Link view
context-admin
inbound: Specifies the maximum inbound expected bandwidth.
outbound: Specifies the maximum outbound expected bandwidth.
bandwidth-value: Specifies the maximum expected bandwidth in the range of 0 to 4294967295. The value 0 means the bandwidth is not limited.
kbps: Specifies the bandwidth unit as kbps.
If you do not specify the inbound or outbound keyword, the maximum expected bandwidth equals the inbound expected bandwidth plus the outbound expected bandwidth.
This command takes effect only on new sessions and does not take effect on existing sessions.
In addition to being used for link protection, the maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm, maximum bandwidth algorithm, and dynamic proximity algorithm.
# Set the maximum expected bandwidth of the LB link lk1 to 1 kbps.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] max-bandwidth 1 kbps
# Set the maximum inbound expected bandwidth of the LB link lk1 to 1 kbps.
[Sysname-lb-link-lk1] max-bandwidth inbound 1 kbps
# Set the maximum outbound expected bandwidth of the LB link lk1 to 1 kbps.
[Sysname-lb-link-lk1] max-bandwidth outbound 1 kbps
max-number
Use max-number to set the maximum number of proximity entries.
Use undo max-number to restore the default.
max-number number
The maximum number of proximity entries is 65535.
Proximity view
context-admin
number: Specifies the maximum number of proximity entries, in the range of 0 to 10000000. The value 0 indicates that the maximum number of proximity entries is not limited.
# Set the maximum number of proximity entries to 100.
[Sysname-lb-proximity] max-number 100
max-reuse
Use max-reuse to set the maximum number of times that a TCP connection can be reused.
Use undo max-reuse to restore the default.
max-reuse reuse-number
undo max-reuse
A TCP connection can be reused for a maximum of 1000 times.
OneConnect parameter profile view
MySQL parameter profile view
context-admin
reuse-number: Specifies the maximum number of reuse times, in the range of 1 to 4294967295.
After connection reuse is enabled, a TCP connection is not disconnected until the maximum number of reuse times is reached. After the TCP connection is disconnected, new connection requests trigger establishment of a new TCP connection.
# In OneConnect parameter profile ocp, set the maximum number of reuse times to 10000.
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] max-reuse 10000
memory-size
Use memory-size to set the memory size used for compression.
Use undo memory-size to restore the default.
memory-size size
undo memory-size
The memory size used for compression is 8 KB.
HTTP-compression parameter profile view
context-admin
vsys-admin
size: Specifies the memory size in KB used for compression. The value can only be 1, 2, 4, 8, 16, 32, or 64.
# Create the HTTP-compression parameter profile pa1, and set the memory size used for compression to 32 KB.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] memory-size 32
min-ttl
Use min-ttl to set the minimum TTL.
Use undo min-ttl to restore the default.
min-ttl ttl-value
undo min-ttl
The minimum TTL is 3600 seconds.
SOA view
context-admin
ttl-value: Specifies the minimum TTL in the range of 0 to 4294967295 seconds.
The minimum TTL is the amount of time that resource records on the primary DNS server are cached on the secondary DNS server.
# Set the minimum TTL to 1 day for DNS forward zone abc.com.
[Sysname-lb-zone-abc.com] soa
[Sysname-lb-zone-abc.com-soa] min-ttl 86400
monitor-interval
Use monitor-interval to set the monitoring time for an LB probe template.
Use undo monitor-interval to restore the default.
monitor-interval interval-time
The monitoring time is 10 seconds for a TCP-RST or TCP zero-window LB probe template, 1 second for an HTTP passive LB probe template, and 5 seconds for a custom-monitoring LB probe template.
HTTP passive LB probe template view
TCP-RST LB probe template view
TCP zero-window LB probe template view
Custom-monitoring LB probe template view
context-admin
vsys-admin
interval-time: Specifies the monitoring time in the range of 5 to 255 seconds for a TCP-RST or TCP zero-window LB probe template, in the range of 1 to 5 seconds for an HTTP passive LB probe template, and in the range of 1 to 86400 seconds for a custom-monitoring LB probe template.
During the monitoring time, the system counts the number of RST packets or zero-window packets sent by each server farm member in a server farm.
During the monitoring time, the system monitors the responses of matching HTTP requests and counts the number of URL error times.
After a custom-monitoring LB probe template is specified, the system executes the custom script file during the monitoring time to detect the state of real servers.
# In TCP RST LB probe template rsttplt, set the monitoring time to 60 seconds.
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] monitor-interval 60
external-script
node
Use node to create a statistics node and enter its view, or enter the view of an existing statistics node.
Use undo node to delete the specified statistics node.
node node-name
undo node node-name
No statistics nodes exist.
HTTP statistics parameter profile view
context-admin
node-name: Specifies the statistics node name, a case-insensitive string of 1 to 63 characters.
You can configure a maximum of 256 statistics nodes in one HTTP statistics parameter profile.
# In HTTP statistics parameter profile http1, create statistics node node1 and enter statistics node view.
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] node node1
[Sysname-para-http-statistics-http1-node-node1]
override-limit enable
Use override-limit enable to ignore the limits for sessions that match sticky entries.
Use undo override-limit enable to remove the configuration.
The session limits apply to sessions that match sticky entries.
Sticky group view
context-admin
vsys-admin
Use this command to ignore the following limits for sessions that match sticky entries:
· Bandwidth and connection parameters on real servers or links.
· Bandwidth ratios and maximum expected bandwidths for real servers or links.
· LB connection limit policies on virtual servers.
# Ignore the limits for sessions that match sticky entries generated in the sticky group st.
[Sysname] sticky-group st type http-cookie
[Sysname-sticky-http-cookie-st] override-limit enable
packet-loss-rate weight
Use packet-loss-rate weight to set the packet loss ratio weight for proximity calculation.
Use undo packet-loss-rate weight to restore the default.
packet-loss-rate weight packet-loss-rate-weight
The packet loss ratio weight for proximity calculation is 0.
Proximity view
context-admin
packet-loss-rate-weight: Specifies the packet loss ratio weight in the range of 0 to 255. The greater the weight value, the higher the weight.
This command sets the weight of the packet loss ratio in calculating the link quality. The packet loss ratio is used to calculate the link quality only if the proximity feature is enabled or the link quality algorithm is configured. The proximity feature and the link quality algorithm are mutually exclusive.
# Set the packet loss ratio weight for proximity calculation to 200.
[Sysname-lb-proximity] packet-loss-rate weight 200
predictor (link group view)
proximity enable (link group view)
parameter
Use parameter to specify a parameter profile to be referenced by a virtual server.
Use undo parameter to restore the default.
parameter { http | http-compression | http-statistics | ip | mysql | oneconnect | tcp | tcp-application } profile-name [ client-side | server-side ]
undo parameter { http | http-compression | http-statistics | ip | mysql | oneconnect | tcp | tcp-application } [ client-side | server-side ]
No parameter profile is referenced by a virtual server.
Virtual server view
context-admin
vsys-admin
{ http | http-compression | http-statistics | ip | mysql | oneconnect | tcp | tcp-application }: Specifies a parameter profile type, HTTP, HTTP-compression, HTTP statistics, IP, OneConnect, TCP, or TCP-application. The http and tcp keywords are supported by the virtual servers of the HTTP type. The http-compression, http-statistics, and oneconnect keywords are supported only by the virtual servers of the HTTP type. The mysql keyword is supported only by MySQL virtual servers. The tcp-application keyword is supported only by TCP virtual servers operating at Layer 7.
profile-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters.
client-side: Specifies a client-side parameter profile.
server-side: Specifies a server-side parameter profile.
The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
The virtual servers of the RADIUS type can only reference the IP parameter profile.
A client-side parameter profile optimizes and processes TCP connections between the client and the device. A server-side parameter profile optimizes and processes TCP connections between the device and the server. Only TCP parameter profiles support the client-side and server-side keywords.
# Specify the IP parameter profile pp2 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] parameter ip pp2
parameter-profile
Use parameter-profile to create a parameter profile and enter its view, or enter the view of an existing parameter profile.
Use undo parameter-profile to delete the specified parameter profile.
parameter-profile profile-name [ type { http | http-compression | http-statistics | ip | mysql | oneconnect | tcp | tcp-application } ]
undo parameter-profile profile-name
No parameter profiles exist.
context-admin
vsys-admin
profile-name: Specifies a parameter profile name, a case-insensitive string of 1 to 63 characters.
type { http | http-compression | http-statistics | ip | mysql | oneconnect | tcp | tcp-application }: Specifies a parameter profile type, HTTP, HTTP-compression, HTTP statistics, IP, MySQL, OneConnect, TCP, or TCP-application. When you create a parameter profile, you must specify the parameter profile type. You can enter an existing parameter profile view without entering the parameter profile type. Non-default vSystems do not support the http-statistics parameter.
You can configure advanced parameters through the parameter profile. The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
You can create HTTP, HTTP-compression, MySQL, HTTP statistics, OneConnect, or TCP-application parameter profiles only if the device has licenses installed. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create the IP parameter profile pp2, and enter parameter profile view.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
payload (HTTP/UDP payload sticky group view)
Use payload to configure the HTTP or UDP payload sticky method.
Use undo payload to delete the HTTP or UDP payload sticky method.
payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload
No sticky methods exist.
context-admin
vsys-admin
offset offset: Specifies the offset value of the HTTP or UDP payload based on the start of the HTTP or UDP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP or UDP payload, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP or UDP payload, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP or UDP payload, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Use this command to obtain the HTTP or UDP payload information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
# Configure the HTTP payload sticky method for the HTTP payload sticky group sg5: Starting from the 10th byte of start of the HTTP packet, use the 20-byte HTTP payload to generate sticky entries.
[Sysname] sticky-group sg5 type payload
[Sysname-sticky-payload-sg5] payload offset 10 length 20
# Configure the UDP payload sticky method for the UDP payload sticky group sg6: Starting from the 28th byte of start of the UDP packet, use the 6-byte UDP payload to generate sticky entries.
[Sysname] sticky-group sg6 type payload
[Sysname-sticky-payload-sg6] payload offset 28 length 6
payload (UDP passive sticky group view)
Use payload to configure the UDP payload passive sticky method.
Use undo payload to delete the UDP payload passive sticky method.
payload { get | match } [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload { get | match }
No UDP payload passive sticky methods exist.
context-admin
vsys-admin
get: Obtains the specified string in the UDP response payload, which is used to generate a UDP payload passive sticky entry.
match: Obtains the specified string in the UDP request payload, which is used to match a UDP payload passive sticky entry.
offset offset: Specifies the offset value of the UDP payload based on the start of the UDP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the UDP payload, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the UDP payload, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the UDP payload, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Use the payload get command to obtain the UDP response payload information based on the offset, start-string, end-string, and length values. Use the payload match command to obtain the UDP request payload information based on those values.
Both the payload get and payload match commands are required for a UDP payload passive sticky method.
The device obtains the payload information of an incoming UDP request based on the payload match command and obtains the payload information of an incoming UDP response based on the payload get command. If the payload information of the UDP request matches the payload information of the UDP response, the device generates a sticky entry based on the payload information of the UDP response. Subsequent UDP requests that match the sticky entry are forwarded according to the sticky entry.
# Configure the UDP payload passive sticky method for the UDP passive sticky group sg5: Obtain the 20-byte UDP payload string starting with id in the UDP response. If the obtained string matches the 20-byte UDP payload string starting with id in the UDP request, the device generates a sticky entry based on the string obtained from the UDP response.
[Sysname] sticky-group sg5 type udp-passive
[Sysname-sticky-udp-passive-sg5] payload get start id length 20
[Sysname-sticky-udp-passive-sg5] payload match start id length 20
payload rewrite
Use payload rewrite to rewrite the TCP payload.
Use undo payload rewrite to remove the configuration.
payload rewrite { both | request | response } value value replace replace-string
undo payload rewrite { both | request | response } value value
The TCP payload is not rewritten.
Generic LB action view
context-admin
vsys-admin
both: Specifies both the TCP request and response packets.
request: Specifies the TCP request packets.
response: Specifies the TCP response packets.
value value: Specifies the TCP packet header content to be rewritten, a case-sensitive string of 1 to 127 characters.
replace replace-string: Specifies the content after rewrite, a case-sensitive string of 1 to 127 characters. You can also specify the following replacement strings:
· %[variable]—Replaces the specified value with the variable associated with the server farm member. The variable is the variable name.
· %[1-9]—Replaces the specified value with the content in the corresponding parentheses of the specified value. For example, executing the payload rewrite value (Wel)(co)(me) replace %2 command will replace the string Welcome with co in the second pair of parentheses.
You can replace the specified value with the variable associated with the server farm member by specifying the replacement string %[variable]. For example, you can replace the string QMGR.S01 in the payload with QMGR.S0_1 by executing the following commands:
· variable var1 value _1 (in server farm member view).
· payload rewrite request value “QMGR.S01” replace QMGR.S01%[var1] (in generic LB action view).
# In generic LB action lba1, replace QMGR.S01 in the payload of TCP requests with QMGR.S01%[var1]. var1 is the name of the variable associated with the server farm member.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] payload rewrite request value QMGR.S01 replace QMGR.S01%[var1]
variable
pool-size
Use pool-size to set the maximum number of connections allowed in the MySQL connection pool.
Use undo pool-size to restore the default.
pool-size pool-size
undo pool-size
The maximum number of connections allowed in the MySQL connection pool is 1024.
context-admin
vsys-admin
pool-size: Specifies the maximum number of connections allowed in the MySQL connection pool, in the range of 1 to 64000.
After MySQL data transfer is completed, the TCP connection is stored in a connection pool instead of being closed. For a new connection request, the device selects an available connection from the connection pool before attempting to open a new connection.
# Set the maximum number of connections allowed in the MySQL connection pool to 2000 for the MySQL parameter profile p1.
[Sysname] parameter-profile p1 type mysql
[Sysname-para-mysql-p1] pool-size 2000
port (DNS server view)
Use port to configure the port number of a DNS server.
Use undo port to restore the default.
port port-number
undo port
The port number of a DNS server is 0.
DNS server view
context-admin
port-number: Specifies a port number in the range of 0 to 65535. The value 0 means that the original port number is used.
# Specify the port number of DNS server ds1 as 5353.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] port 5353
port (real server view)
Use port to configure the port number of a real server.
port port-number
undo port
The port number of a real server is 0. (The original port number is used.)
Real server view
context-admin
vsys-admin
port-number: Specifies a port number in the range of 0 to 65535. 0 means the original port number is used.
This configuration takes effect only when you enable the NAT feature for the server farm.
# Specify the port number of the real server rs as 8080.
[Sysname] real-server rs
[Sysname-rserver-rs] port 8080
transparent enable (server farm view)
port (transparent DNS proxy view)
Use port to configure the port number of a transparent DNS proxy.
port port-number
undo port
The port number of a transparent DNS proxy is 53.
Transparent DNS proxy view
context-admin
port-number: Specifies a port number in the range of 1 to 65535.
A transparent DNS proxy processes a DNS request only when the destination IP address and port number of the DNS request matches those of the transparent DNS proxy.
# Specify the port number of transparent DNS proxy dns-proxy1 as 5353.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-dns-proxy1] port 5353
display loadbalance dns-proxy
port (virtual server view)
Use port to configure the port number of a virtual server.
port { port-number [ to port-number ] } &<1-n>
undo port
The port number is 0 (indicates any port) for the virtual server of the IP, RADIUS, TCP, or UDP type. The port number is 80 for the virtual server of the HTTP type. The port number is 5060 for the virtual server of the SIP type.
Virtual server view
context-admin
vsys-admin
port-number [ to port-number ] &<1-n>: Specifies a space-separated list of up to n port number items. Each port number item specifies a port number or a range of port numbers in the form of start-port-number to end-port-number. For IP, RADIUS, TCP, and UDP virtual servers, the value range for the port-number argument is 0 to 65535 (0 means any port) and the value range for n is 1 to 32. For HTTP and SIP virtual servers, the value range for the port-number argument is 1 to 65535 and the value of n can only be 1.
If the virtual server has referenced an SSL policy, you must configure a non-default port number (typically 443) for the virtual server.
# Specify the port number of the IP-type virtual server vs3 as 8080.
[Sysname-vs-ip-vs3] port 8080
ssl-server-policy
predictor (DNS server pool view)
Use predictor to specify a scheduling algorithm for a DNS server pool.
Use undo predictor to restore the default.
predictor hash address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor { random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
The scheduling algorithm for a DNS server pool is weighted round robin.
context-admin
hash address: Specifies the hash algorithm based on the IP address.
destination: Specifies the hash algorithm based on the destination IP address.
source: Specifies the hash algorithm based on the source IP address.
source-ip-port: Specifies the hash algorithm based on the source IP address and port number.
mask mask-length: Specifies the mask length of the IPv4 address used in the hash algorithm. The value range for the mask-length argument is 0 to 32. The default is 32.
prefix prefix-length: Specifies the prefix length of the IPv6 address used in the hash algorithm. The value range for the prefix-length argument is 0 to 128. The default is 128.
random: Specifies the random algorithm, which randomly assigns DNS requests to DNS servers.
round-robin: Specifies the weighted round robin algorithm, which assigns DNS requests to DNS servers based on the weights of the DNS servers. A higher weight indicates more DNS requests will be assigned. The weight value used in this algorithm is configured in DNS server pool member view.
bandwidth: Specifies the bandwidth algorithm, which assigns DNS requests to DNS servers based on the weight and remaining bandwidth of the DNS servers. The weight value used in this algorithm is configured in DNS server view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns DNS requests to the DNS server corresponding to the idle link with the largest remaining bandwidth.
inbound: Selects a DNS server based on the inbound bandwidth.
outbound: Selects a DNS server based on the outbound bandwidth.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a DNS server.
In the bandwidth algorithm and maximum bandwidth algorithm, the remaining bandwidth is the maximum expected bandwidth minus the current bandwidth. If the maximum expected bandwidth is not configured, the remaining bandwidth is the maximum bandwidth of the link minus the current bandwidth.
# Specify the scheduling algorithm as random for DNS server pool dns-pool.
[Sysname] loadbalance dns-server-pool dns-pool
[Sysname-lb-dspool-dns-pool] predictor random
max-bandwidth (link view)
rate-limit bandwidth (link view)
Use predictor to specify a scheduling algorithm for a link group.
Link-based:
predictor { least-connection | link-quality | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
Link group member-based:
predictor { least-connection member | random | round-robin }
undo predictor
The scheduling algorithm for a link group is weighted round robin.
Link group view
context-admin
hash address: Performs the hash algorithm based on IP address.
destination: Performs the hash algorithm based on destination IP address.
source: Performs the hash algorithm based on source IP address.
source-ip-port: Performs the hash algorithm based on source IP address and port number.
mask mask-length: Specifies the IPv4 address mask length, in the range of 0 to 32. The default is 32.
prefix prefix-length: Specifies the IPv6 address prefix length, in the range of 0 to 128. The default is 128.
least-connection: Specifies the link-based weighted least connection algorithm. This algorithm always assigns new connections to the link with the fewest number of weighted active connections (the total number of active connections in all link groups divided by weight). The weight value used in this algorithm is configured in link view.
least-connection member: Specifies the link group member-based weighted least connection algorithm. This algorithm always assigns new connections to the link with the fewest number of weighted active connections (the number of active connections in the specified link group divided by weight). The weight value used in this algorithm is configured in link group member view.
link-quality: Specifies the link quality algorithm. This algorithm assigns new connections to links based on the link quality. The higher the quality, the more new connections assigned to the link. The link quality is calculated by using the network delay, hop count of routes (TTL), and packet loss ratio.
random: Specifies the random algorithm, which randomly assigns new connections to links.
round-robin: Specifies the weighted round robin algorithm, which assigns new connections to links based on the weights of links. A higher weight indicates more new connections will be assigned. The weight value used in this algorithm is configured in link group member view.
bandwidth: Specifies the bandwidth algorithm, which assigns packets to links based on the weight of the links and the bandwidth ratio. The weight value used in this algorithm is configured in link view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns packets to the idle link with the largest remaining bandwidth.
inbound: Selects a link based on the inbound bandwidth.
outbound: Selects a link based on the outbound bandwidth.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a link.
If you specify the link quality algorithm, you must also configure the following settings in proximity view:
· Proximity probe method.
· Network delay weight.
· TTL weight.
· Packet loss ratio weight.
The proximity probe method is used to probe the network delay, TTL, and packet loss ratio of the link. The weight values of network delay, TTL, and packet loss ratio are used for calculating the link quality.
For a link group, the link quality algorithm is mutually exclusive with the proximity feature. The most recent configuration overwrites the previous one.
# Specify the scheduling algorithm random for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] predictor random
predictor (server farm view)
Use predictor to specify a scheduling algorithm for a server farm.
Real server-based:
predictor { dync-round-robin | least-connection | least-time | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
Server farm member-based:
predictor hash [ carp ] address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor hash [ carp ] http [ offset offset ] [ start start-string ] [ [ end end-string ] | [ length length ] ]
predictor { least-connection member | least-time member | random | round-robin | }
undo predictor
The scheduling algorithm for a server farm is weighted round robin.
Server farm view
context-admin
vsys-admin
carp: Specifies the Cache Array Routing Protocol (CARP) hash algorithm. When the number of available real servers changes, this protocol makes all available real servers have the smallest load changes.
http: Performs the hash algorithm based on the HTTP content.
offset offset: Specifies the offset value based on the start of the HTTP content, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP content, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP content, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP content, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
dync-round-robin: Specifies the dynamic round robin algorithm, which assigns new connections to real servers based on load weight values calculated by using the memory usage, CPU usage, and disk usage of the real servers. The smaller the load, the greater the weight value. A real server with a greater weight value is assigned more connections.
least-connection: Specifies the real server-based weighted least connection algorithm, which always assigns new connections to the real server with the fewest number of weighted active connections (the total number of active connections in all server farms divided by weight). The weight value used in this algorithm is configured in real server view.
least-connection member: Specifies the server farm member-based weighted least connection algorithm, which always assigns new connections to the server farm member with the fewest number of weighted active connections (the number of active connections in the specified server farm divided by weight). The weight value used in this algorithm is configured in server farm member view.
least-time: Specifies the least time algorithm, which assigns new connections to real servers based on load weight values calculated by using the response time of the real servers. The shorter the response time, the greater the weight value. A real server with a greater weight value is assigned more connections.
least-time member: Specifies the server farm member-based least time algorithm, which assigns new connections to server farm members based on load weight values calculated by using the response time of the server farm members. The shorter the response time, the greater the weight value. A server farm member with a greater weight value is assigned more connections.
random: Specifies the random algorithm, which randomly assigns new connections to real servers.
round-robin: Specifies the weighted round robin algorithm, which assigns new connections to real servers based on the weights of real servers. A higher weight indicates more new connections will be assigned. The weight value used in this algorithm is configured in server farm member view.
bandwidth: Specifies the bandwidth algorithm, which assigns packets to real servers based on the weight of the real servers and the bandwidth ratio. The weight value used in this algorithm is configured in real server view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns packets to the idle real server with the largest remaining bandwidth.
inbound: Selects a real server based on the inbound bandwidth.
outbound: Selects a real server based on the outbound bandwidth.
The dynamic round robin algorithm can take effect only if you specify an SNMP-DCA NQA template. If no SNMP-DCA NQA template is specified, the non-weighted round robin algorithm is used. For more information about NQA templates, see NQA configuration in Network Management and Monitoring Configuration Guide.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a real server.
In the bandwidth algorithm and maximum bandwidth algorithm, the remaining bandwidth is the maximum expected bandwidth minus the current bandwidth. If the maximum expected bandwidth is not configured, the remaining bandwidth is the maximum bandwidth of the real server minus the current bandwidth.
# Specify the scheduling algorithm for the server farm sf as random.
[Sysname] server-farm sf
[Sysname-sfarm-sf] predictor random
max-bandwidth (real server view)
rate-limit bandwidth (real server view)
predictor (virtual server pool view)
Use predictor to specify a scheduling algorithm for a virtual server pool.
predictor { alternate | fallback | preferred } { least-connection | proximity | random | round-robin | topology | { bandwidth | max-bandwidth } [ inbound | outbound ] | hash address { source | source-ip-port | destination } [ mask mask-length | prefix prefix-length ] }
undo predictor { alternate | fallback }
The scheduling algorithm for a virtual server pool is weighted round robin. No alternative or backup scheduling algorithm is specified.
Virtual server pool view
context-admin
alternate: Specifies the alternative scheduling algorithm.
fallback: Specifies the backup scheduling algorithm.
preferred: Specifies the preferred scheduling algorithm.
least-connection: Specifies the weighted least connection algorithm. This algorithm always assigns DNS requests to the virtual server with the fewest number of weighted active connections (the number of active connections divided by weight).
proximity: Specifies the dynamic proximity algorithm, which assigns DNS requests to virtual servers based on dynamic proximity entries.
random: Specifies the random algorithm, which randomly assigns DNS requests to virtual servers.
round-robin: Specifies the weighted round robin algorithm, which assigns DNS requests to virtual servers based on the weights of the virtual servers. A higher weight indicates more DNS requests will be assigned.
topology: Specifies the static proximity algorithm, which assigns DNS requests to virtual servers based on static proximity entries.
bandwidth: Specifies the bandwidth algorithm, which assigns DNS requests to virtual servers based on the weight of the virtual servers and the remaining bandwidth.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns DNS requests to the virtual server corresponding to the idle link with the largest remaining bandwidth.
inbound: Selects a virtual server based on the inbound bandwidth.
outbound: Selects a virtual server based on the outbound bandwidth.
Non-default vSystems do not support this command.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a virtual server.
# Specify the preferred scheduling algorithm for the virtual server pool local-pool as random, and alternative scheduling algorithm as least-connection.
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] predictor preferred random
[Sysname-lb-vspool-local-pool] predictor alternate least-connection
prefer-method
Use prefer-method to specify the preferred compression algorithm.
Use undo prefer-method to restore the default.
prefer-method { deflate | gzip }
undo prefer-method
The preferred compression algorithm is gzip.
context-admin
vsys-admin
deflate: Specifies the Deflate compression algorithm.
gzip: Specifies the default GNU zip compression algorithm.
If the client request supports the configured compression algorithm, the configured compression algorithm applies. If the client request does not support the configured compression algorithm, the compression algorithm contained in the request applies.
# Create the HTTP-compression parameter profile http1, and specify the preferred compression algorithm as deflate.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] prefer-method deflate
primary-nameserver
Use primary-nameserver to configure the host name for the primary DNS server.
Use undo primary-nameserver to restore the default.
primary-nameserver host-name
No host name is configured for the primary DNS server.
SOA view
context-admin
host-name: Specifies the host name for the primary DNS server, a case-insensitive and dot-separated string of up to 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
The host name of the primary DNS server can be a relative domain name (does not end with a dot) or an absolute domain name (ends with a dot). For an absolute domain name, the host name is not automatically expanded and cannot exceed 254 characters. For a relative domain name, the current domain name is automatically appended to the host name. The host name plus the appended domain name cannot exceed 254 characters.
# Configure the host name for the primary DNS server as ns1.abc.com for DNS forward zone abc.com.
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com-soa] primary-nameserver ns1.abc.com
display loadbalance zone
priority (DNS server pool member view)
Use priority to set the priority of a DNS server pool member.
Use undo priority to restore the default.
priority priority
undo priority
The priority of a DNS server pool member is 4.
context-admin
priority: Specifies the priority value in the range of 1 to 8. A greater value means a higher priority.
Typically, only the members with the highest priority in a DNS server pool participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command in DNS server pool view.
# Set the priority of DNS server pool member ds1 to 3.
[Sysname] loadbalance dns-server-pool dsp1
[Sysname-lb-dspool-dsp1] dns-server ds1 port 10
[Sysname-dspool-dsp1-#member#-ds1-port-10] priority 3
selected-server (DNS server pool view)
priority (DNS server view)
Use priority to set the priority of a DNS server.
priority priority
undo priority
The priority of a DNS server is 4.
DNS server view
context-admin
Typically, only the DNS servers with the highest priority participate in scheduling. If the number of such DNS servers is smaller than the required minimum number, more DNS servers are selected by priority in descending order. If the allowed maximum number is exceeded after DNS servers with a certain priority are added, only some of the DNS servers with that priority are added.
# Set the priority of DNS server ds1 to 3.
[Sysname-lb-ds-ds1] priority 3
priority (link group member view)
Use priority to set the priority of a link group member.
priority priority
undo priority
The priority of a link group member is 4.
Link group member view
context-admin
Typically, only the members with the highest priority in a link group participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command.
# Set the priority of link group member lk1 to 3.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] priority 3
selected- link
priority (link view)
Use priority to set the priority of a link.
priority priority
undo priority
The priority of a link is 4.
Link view
context-admin
Typically only the links with the highest priority participate in scheduling. If the number of such links is smaller than the required minimum number, more links are selected by priority in descending order.
# Set the priority of the link lk1 to 3.
[Sysname-lb-link-lk1] priority 3
selected-link
priority (real server view)
Use priority to set the priority of a real server.
priority priority
undo priority
The priority of a real server is 4.
Real server view
context-admin
vsys-admin
priority: Specifies the priority value of the real server, in the range of 1 to 8. A greater value means a higher priority to be referenced.
Typically only the real servers with the highest priority participate in scheduling. If the number of such real servers is smaller than the required minimum number, more real servers are selected by priority in descending order.
# Set the priority of the real server rs to 3.
[Sysname-rserver-rs] priority 3
selected-server
priority (server farm member view)
Use priority to set the priority of a server farm member.
priority priority
undo priority
The priority of a server farm member is 4.
Server farm member view
context-admin
vsys-admin
Typically, only the members with the highest priority in a server farm participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command in server farm view.
# Set the priority of server farm member rs1 to 3.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] priority 3
selected-server (server farm view)
priority (SNAT global policy view)
Use priority to set the priority of a SNAT global policy.
priority priority
undo priority
The priority of a SNAT global policy is 0.
context-admin
priority: Specifies the priority value in the range of 0 to 65535. A greater value means a higher priority.
You can configure multiple SNAT global policies with different priorities. They are matched in descending order of priority values.
# Set the priority of SNAT global policy sn1 to 100.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] priority 100
probe (DNS server pool member view)
Use probe to specify a health monitoring method for a DNS server pool member.
Use undo probe to restore the default.
probe template-name
undo probe template-name
No health monitoring method is specified for a DNS server pool member.
context-admin
template-name: Specifies an NQA template by its name, a case-insensitive string of 1 to 32 characters.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The DNS server pool uses the parameters defined in the NQA template to detect the availability of the pool members.
The health monitoring method configuration in DNS server pool member view takes precedence over the configuration in DNS server pool view.
The health monitoring result for a DNS server affects the availability of a DNS server pool member. The health monitoring result for a DNS server pool member does not affect the availability of a DNS server.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the DNS server pool member ds1 as t4.
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-dspool-dsp1-#member#-ds1-port-10] probe t4
nqa template (Network Management and Monitoring Command Reference)
success-criteria (DNS server pool member view)
probe (DNS server pool view)
Use probe to specify a health monitoring method for a DNS server pool.
probe template-name
No health monitoring method is specified for a DNS server pool.
context-admin
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The DNS server pool uses the parameters defined in the NQA template to detect the availability of DNS servers.
The health monitoring method configuration in DNS server view takes precedence over the configuration in DNS server pool view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the DNS server pool dns-pool as t4.
[Sysname-lb-dspool-dns-pool] probe t4
success-criteria (DNS server pool view)
probe (DNS server view)
Use probe to specify a health monitoring method for a DNS server.
probe template-name
No health monitoring method is specified for a DNS server.
DNS server view
context-admin
# Create the ICMP-type NQA template t4, and specify the health monitoring method for DNS server ds1 as t4.
[Sysname-lb-ds-ds1] probe t4
success-criteria (DNS server view)
probe (link group member view)
Use probe to specify a health monitoring method for a link group member.
probe template-name
No health monitoring method is specified for a link group member.
context-admin
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The link group uses the parameters defined in the NQA template to detect the availability of the link group members.
The health monitoring method configuration in link group member view takes precedence over the configuration in link group view.
The health monitoring result for a link affects the availability of a link group member. The health monitoring result for a link group member does not affect the availability of a link.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the link group member lk1 as t4.
[Sysname-lb-lgroup-lg-#member#-lk1] probe t4
success-criteria (link group member view)
probe (link group view)
Use probe to specify a health monitoring method for a link group.
probe template-name
No health monitoring method is specified for a link group.
Link group view
context-admin
The link group uses the parameters defined in the NQA template to detect the availability of links.
The health monitoring method configuration in link view takes precedence over the configuration in link group view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the link group lg as t4.
[Sysname-lb-lgroup-lg] probe t4
success-criteria (link group view)
probe (link view)
Use probe to specify a health monitoring method for an LB link.
probe template-name
No health monitoring method is specified for an LB link.
Link view
context-admin
You can configure multiple health monitoring methods for an LB link. By default, health monitoring succeeds only when all the specified health monitoring methods succeed. You can use the success-criteria command to specify the health monitoring success criteria for the LB link.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the LB link lk1 as t4.
[Sysname-lb-link-lk1] probe t4
success-criteria (link view)
probe (real server view)
Use probe to specify a health monitoring method for a real server.
probe template-name [ nqa-template-port ]
No health monitoring method is specified for a real server.
Real server view
context-admin
vsys-admin
nqa-template-port: Uses the destination port number specified in the NQA template for detection. If you do not specify this keyword, the real server's port number is used for detection.
The health monitoring method configuration in real server view takes precedence over the configuration in server farm view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the real server rs as t4.
[Sysname-rserver-rs] probe t4
success-criteria (real server view)
probe (server farm member view)
Use probe to specify a health monitoring method for a server farm member.
No health monitoring method is specified for a server farm member.
context-admin
vsys-admin
nqa-template-port: Uses the destination port number specified in the NQA template for detection. If you do not specify this keyword, the server farm member's port number is used for detection.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The server farm uses the parameters defined in the NQA template to detect the availability of the server farm members.
The health monitoring method configuration in server farm member view takes precedence over the configuration in server farm view.
The health monitoring result for a real server affects the availability of a server farm member. The health monitoring result for a server farm member does not affect the availability of a real server.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the server farm member rs1 as t4.
[Sysname-sfarm-sf-#member#-rs1-port-80] probe t4
success-criteria (server farm member view)
probe (server farm view)
Use probe to specify a health monitoring method for a server farm.
Use undo probe to delete a health monitoring method from a server farm.
No health monitoring method is specified for a server farm.
Server farm view
context-admin
vsys-admin
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the server farm sf as t4.
<Sysname>system-view
[Sysname-sfarm-sf] probe t4
success-criteria (server farm view)
probe-template (real server view)
Use probe-template to specify a custom-monitoring LB probe template for a real server.
Use undo probe-template to remove a custom-monitoring LB probe template from a real server.
probe-template external-monitor template-name
undo probe-template external-monitor template-name
No custom-monitoring LB probe template is specified for a real server.
Real server view
context-admin
template-name: Specifies a custom-monitoring template by its name, a case-insensitive string of 1 to 32 characters.
This command can monitor a real sever by referencing a custom-monitoring LB probe template.
The monitoring result of a real server affects the availability of a server farm member, but the monitoring result of a server farm member does not affect the availability of a real server.
# Specify custom-monitoring LB probe template test_external for real server rs.
[Sysname-rserver-rs] probe-template external-monitor test_external
probe-template (server farm member view)
Use probe-template to specify a custom-monitoring probe template for a server farm member.
Use undo probe-template to remove a custom-monitoring LB probe template from a server farm member.
No custom-monitoring probe template is specified for a server farm member.
context-admin
This command can monitor a sever farm member by referencing a custom-monitoring LB probe template.
You can configure this command for all server farm members in server farm view or for a single server farm member in server farm member view. If you configure this command in both server farm view and server farm member view, the configuration in server farm member view takes effect.
# Specify custom-monitoring LB probe template test_external for server farm member rs1.
[Sysname-sfarm-sf-#member#-rs1-port-80] probe-template external-monitor test_external
probe-template (server farm view)
Use probe-template to specify an LB probe template for a server farm.
Use undo probe-template to remove an LB probe template for a server farm.
probe-template { external-monitor | http-passive | tcp-rst | tcp-zero-window } template-name
undo probe-template { external-monitor | http-passive | tcp-rst | tcp-zero-window }
No LB probe template is specified for a server farm.
Server farm view
context-admin
vsys-admin
external-monitor: Specifies a custom-monitoring LB probe template.
http-passive: Specifies an HTTP passive LB probe template.
tcp-rst: Specifies a TCP-RST LB probe template.
tcp-zero-window: Specifies a TCP zero-window LB probe template.
template-name: Specifies the template name, a case-insensitive string of 1 to 32 characters.
This command can monitor all real severs in a server farm.
A server farm can reference only one HTTP passive LB probe template, one TCP-RST LB probe template, and one TCP zero-window LB probe template at the same time.
You can specify multiple custom-monitoring LB probe templates for a server farm.
# Specify TCP-RST LB probe template r1 for server farm sf.
[Sysname-sfarm-sf] probe-template tcp-rst r1
probe log enable (real server view)
Use probe log enable to enable health monitoring logging for a real server.
Use undo probe log enable to disable health monitoring logging for a real server.
probe log enable
Health monitoring logging is enabled for a real server.
Real server view
context-admin
This feature generates logs when the health of a real server changes.
# Enable health monitoring logging for real server rs.
[Sysname-rserver-rs] probe log enable
probe log enable (server farm member view)
Use probe log enable to enable health monitoring logging for a server farm member.
Use undo probe log enable to disable health monitoring logging for a server farm member.
probe log enable
Health monitoring logging is enabled for a server farm member.
context-admin
This feature generates logs when the health of a server farm member changes.
# Enable health monitoring logging for server farm member rs1.
[Sysname-sfarm-sf-#member#-rs1-port-80] probe log enable
protect-action
Use protect-action to configure the protection action for an LB probe template.
Use undo protect-action to restore the default.
protect-action { auto-shutdown | busy [ probe-interval interval ] [ probe-times times ] }
undo protect-action
The protection action is to place a real server in busy state.
context-admin
vsys-admin
auto-shutdown: Automatically shuts down a real server.
busy: Places a real server in busy state.
probe-interval interval: Specifies the interval for probing the real server in busy state, in the range of 5 to 3600 seconds. The default is 30 seconds.
probe-times times: Specifies the maximum number of times for probing the real server in busy state, in the range of 0 to 255. The default is 0, which means that the number of probe times is not limited.
For the busy action, after placing a real server in busy state, the device starts probing the real server at the specified probe intervals. If the number of RST or zero-window packets sent does not reach the threshold in a probe interval, the real server is placed back in normal state. If threshold violation persists when the maximum probe times is reached, the system automatically shuts down the real server.
A real server that is shut down or placed in busy state due to packet threshold violation will be restored to normal state immediately when the referenced LB probe template is deleted.
If a real server is shut down or placed in busy state due to packet threshold violation, you can restore the real server to normal state after a period of time (by executing the auto-shutdown recovery-time command) or immediately (by executing the recover-from-auto-shutdown (real server view) command).
# In TCP-RST LB probe template rsttplt, configure the protection action as busy, set the probe interval to 30 seconds, and set the probe times to 3.
[Sysname-lbpt-tcp-rst-rsttplt] protect-action busy probe-interval 30 probe-times 3
protected-url
Use protected-url to configure the URLs to be protected.
Use undo protected-url to remove all protected URLs.
protected-url url
undo protected-url
No URLs are protected.
Protection rule view
context-admin
vsys-admin
url: Specifies a regular expression to match URLs, a case-sensitive string of 1 to 255 characters. The regular expression cannot contain question marks (?).
If the number of times that a user accesses a protected URL exceeds the request threshold during the protection period, the protection action is taken.
The device does not match the parameters in a URL and matches only the portion before the question mark (?).
# In protection rule 5, configure www.aaa.com/index.html as a protected URL.
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] protected-url www.aaa.com/index.html
cookie (protection policy view)
protection-action
protection-period
source-ip
protection-action
Use protection-action to configure a protection action.
Use undo protection-action to restore the default.
protection-action { warning | { drop | verify { insert-header | js } } } *
No protection action is configured.
HTTP protection policy view
context-admin
vsys-admin
warning: Generates a log message.
drop: Drops requests.
verify: Performs cookie verification on subsequent requests.
insert-header: Performs cookie verification by inserting an HTTP header.
js: Performs cookie verification by inserting a JS script.
The protection action is taken when protection rules in a protection policy are matched. The device supports the following protection actions:
· Warning—Generates a log message and sends it to the information center.
· Drop—Drops requests.
· Verify cookie—Returns a response carrying a cookie value to the client. If a subsequent request carries the returned cookie value, it passes the verification. If a subsequent request does not carry a cookie value or carries a different cookie value, it fails to pass the verification and is dropped. This protection action is useful in scenarios where attackers cannot insert cookie values into attack packets. The device supports returning a cookie value by inserting an HTTP header or a JS script.
# In HTTP protection policy p1, configure generating log messages and performing cookie verification by inserting an HTTP header as the protection actions.
[Sysname] loadbalance protection-policy p1 type http
[Sysname-lbpp-http-p1] protection-action warning verify insert-header
protection-period
Use protection-period to set the protection period.
Use undo protection-period to restore the default.
protection-period period
The protection period is 120 seconds.
context-admin
vsys-admin
period: Specifies a protection period in the range of 1 to 900 seconds.
# In protection rule 5, set the protection period to 5 seconds.
[Sysname-lbpp-http-p1-rule-5] protection-period 5
protected-url
protection-action
protection-policy
Use protection-policy to specify a protection policy for a virtual server.
Use undo protection-policy to restore the default.
protection-policy http policy-name
undo protection-policy http
No protection policy is specified for a virtual server.
HTTP virtual server view
context-admin
vsys-admin
policy-name: Specifies a protection policy by its name, a case-insensitive string of 1 to 63 characters.
The protection policy specified for a virtual server protects the traffic matching the virtual server.
# Specify protection policy p1 for HTTP virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs]protection-policy http p1
Use proximity enable to enable the proximity feature for a link group.
Use undo proximity enable to disable the proximity feature for a link group.
proximity enable
The proximity feature is disabled for a link group.
Link group view
context-admin
The proximity feature takes precedence over the scheduling algorithm in selecting a link. If no link is selected according to the proximity feature, the scheduling algorithm is used.
For a link group, the proximity feature is mutually exclusive with the link quality algorithm. The most recent configuration overwrites the previous one.
# Enable the proximity feature for the link group lg.
[Sysname-lb-lgroup-lg] proximity enable
proximity enable (server farm view)
Use proximity enable to enable the proximity feature for a server farm.
Use undo proximity enable to disable the proximity feature for a server farm.
The proximity feature is disabled for a server farm.
Server farm view
context-admin
The proximity feature takes precedence over the scheduling algorithm in selecting a real server. If no real server is selected according to the proximity feature, the scheduling algorithm is used.
# Enable the proximity feature for the server farm sf.
[Sysname-sfarm-sf] proximity enable
radius-attribute
Use radius-attribute to configure the RADIUS attribute sticky method.
Use undo radius-attribute to delete the RADIUS attribute sticky method.
radius-attribute { code attribute-code | framed-ip-address | user-name }
No RADIUS sticky methods exist.
RADIUS sticky group view
context-admin
vsys-admin
code attribute-code: Specifies the code of the RADIUS attribute type, in the range of 1 to 255.
framed-ip-address: Specifies the RADIUS attribute type as framed-ip-address (code 8).
user-name: Specifies the RADIUS attribute type as user-name (code 1).
The RADIUS attribute sticky method takes effect only on RADIUS packets.
# Configure the RADIUS attribute sticky method for sticky group s1 by specifying the RADIUS attribute type as user-name.
[Sysname] sticky-group s1 type radius
[Sysname-sticky-radius-s1] radius-attribute user-name
Use rate-limit bandwidth to set the maximum bandwidth of a link.
Use undo rate-limit bandwidth to restore the default.
rate-limit bandwidth [ inbound | outbound ] bandwidth-value kbps
undo rate-limit bandwidth [ inbound | outbound ]
The maximum bandwidth of a link is not limited.
Link view
context-admin
inbound: Specifies the maximum inbound bandwidth.
outbound: Specifies the maximum outbound bandwidth.
bandwidth-value: Specifies the maximum bandwidth in the range of 0 to 4294967295. The value 0 means the bandwidth is not limited.
kbps: Specifies the bandwidth unit as kbps.
If you do not specify the inbound or outbound keyword, the maximum bandwidth equals the inbound bandwidth plus the outbound bandwidth.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Set the maximum bandwidth of the link lk1 to 1 kbps.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] rate-limit bandwidth 1 kbps
# Set the maximum inbound bandwidth of the link lk1 to 1 kbps.
[Sysname-lb-link-lk1] rate-limit bandwidth inbound 1 kbps
# Set the maximum outbound bandwidth of the link lk1 to 1 kbps.
[Sysname-lb-link-lk1] rate-limit bandwidth outbound 1 kbps
Use rate-limit bandwidth to set the maximum bandwidth of a real server.
The maximum bandwidth of a real server is not limited.
Real server view
context-admin
vsys-admin
# Set the maximum bandwidth of the real server rs to 1 kbps.
[Sysname-rserver-rs] rate-limit bandwidth 1 kbps
# Set the maximum inbound bandwidth of the real server rs to 1 kbps.
[Sysname-rserver-rs] rate-limit bandwidth inbound 1 kbps
# Set the maximum outbound bandwidth of the real server rs to 1 kbps.
[Sysname-rserver-rs] rate-limit bandwidth outbound 1 kbps
rate-limit bandwidth (virtual server view)
Use rate-limit bandwidth to set the maximum bandwidth of a virtual server.
The maximum bandwidth of a virtual server is not limited.
Virtual server view
context-admin
vsys-admin
# Set the maximum bandwidth of the IP-type virtual server vs3 to 1 kbps.
[Sysname-vs-ip-vs3] rate-limit bandwidth 1 kbps
# Set the maximum inbound bandwidth of the IP-type virtual server vs3 to 1 kbps.
[Sysname-vs-ip-vs3] rate-limit bandwidth inbound 1 kbps
# Set the maximum outbound bandwidth of the IP-type virtual server vs3 to 1 kbps.
[Sysname-vs-ip-vs3] rate-limit bandwidth outbound 1 kbps
rate-limit connection (link group member view)
Use rate-limit connection to set the maximum number of connections per second of a link group member.
Use undo rate-limit connection to restore the default.
rate-limit connection connection-number
The maximum number of connections per second of a link group member is 0.
context-admin
connection-number: Specifies the maximum number of connections per second in the range of 0 to 4294967295. 0 means the number is not limited.
# Set the maximum number of connections per second of the link group member lk1 to 1000.
[Sysname-lb-lgroup-lg-#member#-lk1] rate-limit connection 1000
rate-limit connection (link view)
Use rate-limit connection to set the maximum number of connections per second of a link.
The maximum number of connections per second of a link is 0.
Link view
context-admin
# Set the maximum number of connections per second of the link lk1 to 10000.
[Sysname-lb-link-lk1] rate-limit connection 10000
rate-limit connection (real server view)
Use rate-limit connection to set the maximum number of connections per second of a real server.
The maximum number of connections per second of a real server is 0.
Real server view
context-admin
vsys-admin
# Set the maximum number of connections per second of the real server rs to 10000.
[Sysname-rserver-rs] rate-limit connection 10000
rate-limit connection (server farm member view)
Use rate-limit connection to set the maximum number of connections per second of a server farm member.
The maximum number of connections per second of a server farm member is 0.
context-admin
vsys-admin
# Set the maximum number of connections per second of the server farm member rs1 to 1000.
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit connection 1000
rate-limit connection (virtual server view)
Use rate-limit connection to set the maximum number of connections per second of a virtual server.
The maximum number of connections per second of a virtual server is 0.
Virtual server view
context-admin
vsys-admin
# Set the maximum number of connections per second of the IP-type virtual server vs3 to 10000.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] rate-limit connection 10000
rate-limit http-request (real server view)
Use rate-limit http-request to set the maximum number of HTTP requests per second for a real server.
Use undo rate-limit http-request to restore the default.
rate-limit http-request request-number
The maximum number of HTTP requests per second is 0 for a real server.
Real server view
context-admin
vsys-admin
request-number: Specifies the maximum number of HTTP requests per second, in the range of 0 to 4294967295. 0 means the number is not limited.
# Set the maximum number of HTTP requests per second to 10000 for real server rs.
[Sysname-rserver-rs] rate-limit http-request 10000
rate-limit http-request (server farm member view)
Use rate-limit http-request to set the maximum number of HTTP requests per second for a server farm member.
The maximum number of HTTP requests per second is 0 for a server farm member.
context-admin
vsys-admin
The number of HTTP requests per second is used for determining whether a server farm member is busy. If the number of HTTP requests received by a server farm member per second exceeds the specified maximum value, the server farm member is considered busy.
# Set the maximum number of HTTP requests per second to 10000 for server farm member rs.
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit http-request 10000
readwrite-separation
Use readwrite-separation to enable read/write separation for the MySQL database.
Use undo readwrite-separation to disable read/write separation for the MySQL database.
readwirte-separation read-server-farm read-server-farm-name [ read-sticky-group read-sticky-group-name ] write-server-farm write-sever-farm-name [ write-sticky-group write-sticky-group-name ]
Read/write separation is disabled for the MySQL database.
MySQL virtual server view
context-admin
vsys-admin
read-server-farm read-server-farm-name: Specifies a read server farm by its name, a case-insensitive string of 1 to 63 characters.
read-sticky read-sticky-group-name: Specifies a sticky group for the read server farm by its name, a case-insensitive string of 1 to 63 characters.
write-server-farm write-server-farm-name: Specifies a write server farm by its name, a case-insensitive string of 1 to 63 characters.
write-sticky write-sticky-group-name: Specifies a sticky group for the write server farm by its name, a case-insensitive string of 1 to 63 characters.
Read/write separation allows read commands and write commands to be executed by the read server farm and write server farm, respectively, which helps reduce the impact of concurrent read/write requests on database performance.
# Enable read/write separation for the MySQL database of MySQL virtual server vs1.
[Sysname] virtual-server vs1 type mysql
[Sysname-vs-mysql-vs1] readwrite-separation read-server-farm rd write-server-farm wr
real-server (server farm view)
Use real-server to create a server farm member and enter its view, or enter the view of an existing server farm member.
Use undo real-server to delete a server farm member.
real-server real-server-name port port-number
undo real-server real-server-name port port-number
No server farm members exist.
Server farm view
context-admin
vsys-admin
real-server-name: Specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters.
port-number: Specifies the port number of the server farm member, in the range of 0 to 65535.
You can use one of the following methods to add a member to a server farm:
· Use the real-server command in server farm view. H3C recommends using this method.
· Use the server-farm command in real server view.
You cannot use both methods to add a member with the same real server name and port number to a server farm.
# Add server farm member rs1 and enter server farm member view.
server-farm (real server view)
real-server (system view)
Use real-server to create a real server and enter its view, or enter the view of an existing real server.
Use undo real-server to delete the specified real server.
No real servers exist.
context-admin
vsys-admin
real-server-name: Specifies the real server name, a case-insensitive string of 1 to 63 characters.
You can configure this command only if the device has licenses installed. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create real server rs and enter real server view.
rebalance per-request
Use rebalance per-request to enable load balancing for each HTTP request.
Use undo rebalance per-request to restore the default.
Load balancing applies to the first HTTP request of a connection. Other HTTP requests are processed in the same way.
HTTP parameter profile view
context-admin
vsys-admin
# Enable load balancing for each HTTP request in the HTTP parameter profile pp1.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] rebalance per-request
record
Use record to configure a resource record of the specified type.
Use undo record to delete a resource record of the specified type.
record { cname alias alias-name canonical canonical-name | mx [ host hostname ] exchanger exchanger-name preference preference | ns [ sub subname ] authority ns-name | srv [ service service-name ] host-offering-service hostname priority priority weight weight port port-number | txt [ sub subname ] describe-txt description } [ ttl ttl-value ]
undo record { cname alias alias-name canonical canonical-name | mx [ host hostname ] exchanger exchanger-name | ns [ sub subname ] authority ns-name } | srv [ service hostname ] host-offering-service hostname port port-number | txt [ sub subname ] describe-txt description
No resource records exist.
DNS forward zone view
context-admin
cname: Configures a canonical name (CNAME) resource record.
alias alias-name: Specifies an alias for a host name, a case-insensitive, dot-separated string that contains a maximum of 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
canonical canonical-name: Specifies the host name, a case-insensitive, dot-separated string that contains a maximum 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
mx: Configures a mail exchanger (MX) resource record.
host hostname: Specifies the host name for the MX resource record, a case-insensitive, dot-separated string that contains a maximum 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
exchanger exchanger-name: Specifies the host name of the mail server, a case-insensitive, dot-separated string that contains a maximum 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
preference preference: Specifies the preference for the MX resource record, in the range of 0 to 65535. The smaller the value, the higher the priority.
ns: Configure a name server (NS) resource record.
sub subname: Specifies a subname for the DNS forward zone, a case-insensitive, dot-separated string of 1 to 254 characters for an absolute domain name or 1 to 253 characters for a relative domain name. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
authority ns-name: Specifies the host name of the authoritative DNS server, a case-insensitive, dot-separated string that contains a maximum of 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
srv: Configures a service resource record.
service service-name: Specifies a service by its name, a case-insensitive, dot-separated string of 1 to 254 characters for an absolute domain name or 1 to 253 characters for a relative domain name. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters. In a service name (for example, _ftp._tcp.movie.edu), add an underscore before the application name and the protocol name to distinguish them from host domain names. If you do not specify a service name, the domain name of the DNS forward zone applies.
host-offering-service host-name: Specifies the name of the host that provides the service, a case-insensitive, dot-separated string of 1 to 254 characters for an absolute domain name or 1 to 253 characters for a relative domain name. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
priority priority: Specifies a priority value for the resource record in the range of 0 to 100. The smaller the priority value, the higher the priority.
weight weight-value: Specifies a weight value for the resource record in the range of 0 to 100.
port port-number: Specifies a port number in the range of 0 to 65535.
txt: Configures a text resource record.
describe-txt description: Specifies the description for the TXT resource record, a case-insensitive string of 1 to 255 characters.
ttl ttl-value: Specifies the TTL for resource records, in the range of 0 to 4294967295 seconds. The default is 3600.
The host name specified in a resource record can be a relative domain name (does not end with a dot) or an absolute domain name (ends with a dot). For an absolute domain name, the host name is not automatically expanded and cannot exceed 254 characters. For a relative domain name, the current domain name is automatically appended to the host name. The relative domain name plus the appended domain name cannot exceed 254 characters.
If a service has multiple resource records, the device first attempts to connect to the record with the lowest priority. If multiple resource records have the same priority, the device first attempts to connect to the record with the highest weight.
The TTL setting in this command takes precedence over the TTL setting in DNS forward zone view.
You can configure multiple resource records for a DNS forward zone.
# Configure an MX resource record for DNS forward zone abc.com: Specify the host name of the mail server as mail.abc.com and the preference for the resource record as 10.
[Sysname-lb-zone-abc.com] record mx exchanger mail.abc.com preference 10
# Configure a CNAME resource record for DNS forward zone abc.com: Specify alias test.abc.com for host name aaa.abc.com.
[Sysname-lb-zone-abc.com] record cname alias test.abc.com canonical aaa.abc.com
# Configure an NS resource record for DNS forward zone abc.com: Specify the host name of the authoritative DNS server as ns1.abc.com.
[Sysname-lb-zone-abc.com] record ns authority ns1.abc.com
# Configure a TXT resource record for DNS forward zone abc.com.
[Sysname-lb-zone-abc.com] record txt sub hotline describe-txt v=spf1 include:spf.abcmail.abc.com.cn -all
# Configure an SRV resource record for DNS forward zone abc.com.
[Sysname-lb-zone-abc.com] record srv service _http._tcp.example.com. host-offering-service www.example.com priority 5 weight 10 port 80
record ptr
Use record ptr to configure a pointer record (PTR) resource record.
Use undo record ptr to delete a PTR resource record.
record ptr { ip ipv4-address | ipv6 ipv6-address } domain-name [ ttl ttl-value ]
undo record ptr { ip ipv4-address | ipv6 ipv6-address } domain-name
No PTR resource records exist.
DNS reverse zone view
context-admin
ip ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address.
domain-name: Specifies a domain name, a case-insensitive, dot-separated string that contains a maximum of 253 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
You can configure PTR resource records for IP addresses that require reverse DNS resolution.
The IP address specified in a PTR resource record must be within the IP address range of the DNS reverse zone.
You can configure multiple PTR resource records for a DNS reverse zone.
# Configure a PTR resource record for the DNS reverse zone with IPv4 address 10.1.1.0/24.
[Sysname] loadbalance reverse-zone ip 10.1.1.0 24
[Sysname-lb-rzone-10.1.1.0/24] record ptr ip 10.1.1.1 mail.h3c.com
display loadbalance reverse-zone
Use recover-from-auto-shutdown to manually recover a real server in Auto shutdown state.
Real server view
context-admin
vsys-admin
Use this command to manually recover a real server shut down by intelligent monitoring.
If health monitoring is not configured, a recovered real server is set to Unknown state.
If health monitoring is configured and succeeds, a recovered real server is set to Active state. If health monitoring fails, a recovered real server is set to Probe-failed state.
# Manually recover a real server in Auto shutdown state.
[Sysname] real-server rs
[Sysname-rserver-rs] recover-from-auto-shutdown
recover-from-auto-shutdown (server farm member view)
Use recover-from-auto-shutdown to manually recover a server farm member in Auto shutdown state.
context-admin
vsys-admin
Use this command to manually recover a server farm member shut down by intelligent monitoring.
If health monitoring is not configured, a recovered server farm member is set to Unknown state.
If health monitoring is configured and succeeds, a recovered server farm member is set to Active state. If health monitoring fails, a recovered server farm member is set to Probe-failed state.
# Manually recover a server farm member in Auto shutdown state.
[Sysname-sfarm-sf-#member#-rs1-port-80] recover-from-auto-shutdown
redirect relocation (LB action view)
Use redirect relocation to enable the redirection feature and specify a redirection URL for an LB action.
Use undo redirect relocation to disable the redirection feature for an LB action.
redirect relocation relocation
The redirection feature is disabled for an LB action.
HTTP LB action view
context-admin
vsys-admin
relocation: Specifies a redirection URL, a case-sensitive string of 1 to 255 characters. You can also specify the question mark (?) or the following character strings as the redirection URL (each character string can be used only once):
· %h: Specifies the host name and port number in the client request packet.
· %{host}: Specifies the IP address in the client request packet.
· %{port}: Specifies the port number in the client request packet.
· %p: Specifies the URL in the client request packet.
This command and the server-farm command are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
This command redirects all HTTP request packets matching an LB action to the specified URL.
# Enable the redirection feature for the HTTP LB action lba1, and specify the redirection URL as https://%h%p.
[Sysname] loadbalance action lba1 type http
[Sysname-lba-http-lba1] redirect relocation https://%h%p
redirect relocation (virtual server view)
Use redirect relocation to enable the redirection feature and specify a redirection URL for a virtual server.
Use undo redirect relocation to disable the redirection feature for a virtual server.
The redirection feature is disabled for a virtual server.
context-admin
vsys-admin
relocation: Specifies a redirection URL, a case-sensitive string of 1 to 255 characters. The redirection feature redirects all request packets matching the virtual server to the URL. You can also specify the question mark (?) or the following character strings as the redirection URL (each character string can be used only once):
# Enable the redirection feature for the HTTP-type virtual server vs2, and specify the redirection URL as https://%h%p.
[Sysname] virtual-server vs2 type http
[Sysname-vs-http-vs2] redirect relocation https://%h%p
redirect return-code (LB action view)
Use redirect return-code to specify the status code in the redirection packets that the LB device returns to clients.
Use undo redirect return-code to restore the default.
redirect return-code { 301 | 302 }
The status code in the redirection packets that the LB device returns to clients is 302.
HTTP LB action view
context-admin
vsys-admin
301: Deletes request resources permanently.
302: Deletes request resources temporarily.
This configuration takes effect only when the redirection feature is enabled for the HTTP LB action.
# Specify the status code in the redirection packets that the LB device returns to clients as 301 for the HTTP LB action lba1.
[Sysname-lba-http-lba1] redirect return-code 301
redirect relocation
redirect return-code (virtual server view)
context-admin
vsys-admin
This configuration takes effect only when the redirection feature is enabled for the virtual server.
# Specify the status code in the redirection packets that the LB device returns to clients as 301 for the HTTP-type virtual server vs2.
[Sysname-vs-http-vs2] redirect return-code 301
redirect relocation
redundancy-group
Use redundancy-group to specify a redundancy group for a virtual server, to which traffic matching the virtual server is directed.
Use undo redundancy-group to restore the default.
redundancy-group group-name
The traffic matching a virtual server is directed to all effective failover groups.
Virtual server view
context-admin
group-name: Specifies a redundancy group by its name, a case-sensitive string of 1 to 15 characters.
If the specified redundancy group does not exist or does not contain effective failover groups, this command does not take effect.
The virtual server that has a specified redundancy group cannot be associated with the same server farm as any other virtual servers.
# Specify redundancy group aaa for TCP-type virtual server vs.
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] redundancy-group aaa
refresh
Use refresh to set the refresh interval.
Use undo refresh to restore the default.
refresh refresh-interval
undo refresh
The refresh interval is 3600 seconds.
SOA view
context-admin
refresh-interval: Specifies the refresh interval in the range of 300 to 2419200 seconds.
The secondary DNS server obtains SOA resource records from the primary DNS server at the refresh interval. After obtaining SOA resource records, the secondary DNS server compares them with the local SOA resource records.
# Set the refresh interval to 4 hours for DNS forward zone abc.com.
[Sysname-lb-zone-abc.com] soa
[Sysname-lb-zone-abc.com-soa] refresh 14400
reload http-response
Use reload http-response to reload a response file.
reload http-response { file filename }
context-admin
vsys-admin
file filename: Specifies a file by its name, a case-insensitive string of 1 to 255 characters.
If a response file changes, you must reload the file to make it take effect.
For a distributed device, if you do not specify a response file to reload, the device reloads all response files from the active MPU.
# Reload response file subsys_intf.js.
[Sysname] reload http-response /index/subsys_intf.js
fallback-action response raw-file
response
request-version all
Use request-version all to enable compression for responses to HTTP 1.0 requests.
Use undo request-version all to restore the default.
request-version all
Compression is disabled for responses to HTTP 1.0 requests.
HTTP-compression parameter profile view
context-admin
vsys-admin
# Create the HTTP-compression parameter profile http1, and enable compression for responses to HTTP 1.0 requests.
[Sysname-para-http-compression-http1] request-version all
reset loadbalance connections
Use reset loadbalance connections to clear application layer connections.
context-admin
vsys-admin
This command clears all application layer connections, including reused idle connections.
# Clear application layer connections.
<Sysname> reset loadbalance connection
reset loadbalance dns-cache
Use reset loadbalance dns-cache to clear DNS cache information.
reset loadbalance dns-cache [ vpn-instance vpn-instance-name ] [ domain-name domain-name ]
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DNS cache information for the public network.
domain-name domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. If you do not specify this option, the command clears DNS cache information for all domain names.
# Clear DNS cache information for all domain names.
<Sysname> reset loadbalance dns-cache
reset loadbalance dns-listener statistics
Use reset loadbalance dns-listener statistics to clear DNS listener statistics.
reset loadbalance dns-listener statistics [ dns-listener-name ]
context-admin
dns-listener-name: Specifies a DNS listener by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS listeners.
# Clear statistics for the DNS listener dl2.
<Sysname> reset loadbalance dns-listener statistics dl2
# Clear statistics for all DNS listeners.
display loadbalance dns-listener statistics
reset loadbalance dns-map statistics
Use reset loadbalance dns-map statistics to clear DNS mapping statistics.
reset loadbalance dns-map statistics [ dns-map-name ]
context-admin
dns-map-name: Specifies a DNS mapping by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS mappings.
# Clear statistics for the DNS mapping dm2.
<Sysname> reset loadbalance dns-map statistics dm2
# Clear statistics for all DNS mappings.
display loadbalance dns-map statistics
reset loadbalance dns-proxy statistics
Use reset loadbalance dns-proxy statistics to clear transparent DNS proxy statistics.
reset loadbalance dns-proxy statistics [ dns-proxy-name ]
context-admin
dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS transparent proxies.
# Clear statistics for transparent DNS proxy dns-proxy1.
<Sysname> reset loadbalance dns-proxy statistics dns-proxy1
display loadbalance dns-proxy statistics
reset loadbalance dns-server statistics
Use reset loadbalance dns-server statistics to clear DNS server statistics or DNS server pool member statistics.
reset loadbalance dns-server statistics [ dns-server-name ]
reset loadbalance dns-server statistics dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ]
context-admin
dns-server-name: Specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS servers.
dns-server-pool dns-server-pool-name: Clears statistics for members of a DNS server pool. The dns-server-pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server dns-server-name port port-number: Clears statistics for a DNS server pool member. The dns-server-name argument specifies a DNS server pool member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the DNS server pool member, in the range of 0 to 65535. If you do not specify this option, the command clears statistics for all members of a DNS server pool.
# Clear statistics for DNS server ds1.
<Sysname> reset loadbalance dns-server statistics ds1
# Clear statistics for all members in DNS server pool dsp.
<Sysname> reset loadbalance dns-server statistics dns-server-pool dsp
display loadbalance dns-server statistics
reset loadbalance hot-backup statistics
Use reset loadbalance hot-backup statistics to clear LB hot backup statistics.
context-admin
vsys-admin
# Clear LB hot backup statistics.
<Sysname> reset loadbalance hot-backup statistics
reset loadbalance link statistics
Use reset loadbalance link statistics to clear link statistics or link group member statistics.
reset loadbalance link statistics [ link-name ]
reset loadbalance link statistics link-group link-group-name [ name link-name ]
context-admin
link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics about all links.
link-group link-group-name: Clears statistics for members of a link group. The link-group-name argument specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
name link-name: Clears statistics for of a link group member. The link-name argument specifies a link group member by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clears statistics for all members of a link group.
Non-default vSystems do not support this command.
# Clear statistics about all links.
<Sysname> reset loadbalance link statistics
# Clear statistics about all members in link group lg.
<Sysname> reset loadbalance link statistics link-group lg
reset loadbalance local-dns-server parse-fail-record
Use reset loadbalance local-dns-server parse-fail-record to clear DNS request parse failures.
context-admin
# Clear DNS request parse failures.
<Sysname> reset loadbalance local-dns-server parse-fail-record
reset loadbalance proximity
Use reset loadbalance proximity to clear proximity entry information.
reset loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears proximity entry information for the public network.
ip [ ipv4-address ]: Clears IPv4 proximity entry information. If you specify the ipv4-address argument, this command clears information about the proximity entry corresponding to the IPv4 address. If you do not specify the ipv4-address argument, this command clears information about all IPv4 proximity entries.
ipv6 [ ipv6-address ]: Clears IPv6 proximity entry information. If you specify the ipv6-address argument, this command clears information about the proximity entry corresponding to the IPv6 address. If you do not specify the ipv6-address argument, this command clears information about all IPv6 proximity entries.
If you do not specify the vpn-instance, ip, or ipv6 keyword, this command clears information about all IPv4 and IPv6 proximity entries for the public network.
# Clear information about all IPv6 proximity entries for the public network.
<Sysname> reset loadbalance proximity ipv6
reset real-server statistics
Use reset real-server statistics to clear real server statistics or server farm member statistics.
reset real-server statistics [ real-server-name ]
reset real-server statistics server-farm server-farm-name [ name real-server-name port port-number ]
context-admin
vsys-admin
real-server-name: Clears statistics of the specified real server. The real-server-name argument specifies a real server name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics of all real servers.
server-farm server-farm-name: Clears statistics for members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
name real-server-name port port-number: Clears statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command clears statistics for all members of a server farm.
# Clear statistics of all real servers.
<Sysname> reset real-server statistics
# Clear statistics of all members in server farm sf.
<Sysname> reset real-server statistics server-farm sf
display real-server statistics
reset sticky dns-proxy
Use reset sticky dns-proxy to clear sticky entry information for transparent DNS proxies.
In standalone mode:
reset sticky dns-proxy [ dns-proxy-name dns-proxy-name ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | dns-server-addr { ipv4-address | ipv6-address } | dns-server-pool pool-name | dns-server-port port-number | key sticky-key ] * [ slot slot-number ]
In IRF mode:
reset sticky dns-proxy [ dns-proxy-name dns-proxy-name ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | dns-server-addr { ipv4-address | ipv6-address } | dns-server-pool pool-name | dns-server-port port-number | key sticky-key ] * [ chassis chassis-number slot slot-number ]
context-admin
context-operator
dns-proxy dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clears sticky entry information for all transparent DNS proxies.
class { class-name | default-class }: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters, or specifies the default LB class.
client-addr { ipv4-address | ipv6-address }: Specifies a client by its IPv4 or IPv6 address.
dns-server-addr { ipv4-address | ipv6-address }: Specifies a DNS server by its IPv4 or IPv6 address.
dns-server-pool pool-name: Specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server-port port-number: Specifies a DNS server port number in the range of 0 to 65535.
key sticky-key: Specifies a key value, a case-sensitive string of 1 to 36 characters.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears sticky entry information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears sticky entry information for all cards. (In IRF mode.)
# Clear sticky entry information for client address 3.0.0.1 of transparent DNS proxy dp.
<Sysname> reset sticky dns-proxy dns-proxy-name dp client-addr 3.0.0.1
reset sticky virtual-server
Use reset sticky virtual-server to clear sticky entry information for virtual servers.
In standalone mode:
reset sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | sticky-type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ slot slot-number ]
In IRF mode:
reset sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | sticky-type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ chassis chassis-number slot slot-number ]
context-admin
context-operator
virtual-server virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clears sticky entry information for all virtual servers.
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }: Specifies a link by its IPv4 address, IPv6 address, or output interface.
link-group link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
real-server-addr { ipv4-address | ipv6-address }: Specifies a real server by its IPv4 or IPv6 address.
real-server-port port-number: Specifies a real server port number in the range of 0 to 65535.
server-farm server-farm-name: Specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
text text: Specifies a text string to match.
sticky-type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }: Specifies a sticky group type.
key sticky-key: Specifies a key value, a case-sensitive string of 1 to 36 characters. If you do not specify key value, this command clears sticky entries for all key values.
# Clear sticky entry information for client address 3.0.0.1 of virtual server vs.
<Sysname> reset sticky virtual-server virtual-server-name vs client-addr 3.0.0.1
reset virtual-server statistics
Use reset virtual-server statistics to clear virtual server statistics.
reset virtual-server statistics [ virtual-server-name ]
context-admin
vsys-admin
virtual-server-name: Clears statistics of the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics of all virtual servers.
# Clear statistics of all virtual servers.
<Sysname> reset virtual-server statistics
display virtual-server statistics
response
Use response to specify a response file for matching HTTP requests.
Use undo response to restore the default.
response { url url file filename | workpath workpath zip-file zip-filename }
undo response { url url | workpath workpath }
No response file is specified for HTTP requests.
HTTP LB action view
context-admin
vsys-admin
url url: Specifies the URL path used to match HTTP requests, a case-sensitive string of 1 to 255 characters. The specified URL path must start with a forward slash (/).
file filename: Specifies an uncompressed file by its name, a case-insensitive string of 1 to 255 characters.
workpath workpath: Specifies a working path to match the URL in HTTP requests, a case-sensitive string of 1 to 255 characters. The working path can be a single forward slash (/), or a string that starts with a forward slash and does not end with a forward slash.
zip-file zip-filename: Specifies a zip file by its name, a case-insensitive string of 1 to 255 characters. The relative path in the zip file is used to match the URL in HTTP requests.
If the URL path in a client request matches the specified URL path, the device responds to the request by using an uncompressed file.
If the URL path in a client request matches the specified working path plus a relative path in the zip file, the device responds to the request by using the file in the zip file. For example, if you configure the response workpath /index zip-file flash:/za/zb/test.zip command and a relative path /css/col.css exists in test.zip, the matching URL is /index/css/col.css and the response file is col.css.
URL-encoded URLs cannot be matched.
If you configure both an uncompressed file and a compressed file for the same URL path, the uncompressed file is used to respond to matching HTTP requests.
The path specified in the command must exist on each card of the device.
For the same HTTP LB action, only one uncompressed file can be used for a URL, and one uncompressed file can be used for multiple URLs.
If you specify multiple compressed files for one or more URL paths in the same HTTP LB action, the most recent configuration takes effect.
If you specify multiple uncompressed files for one URL path in the same HTTP LB action, the most recent configuration takes effect. One uncompressed file can be used for different URL paths.
Any two of the following commands are mutually exclusive:
· response
· server-farm (LB action view)
· redirect relocation (LB action view)
# Specify response file subsys.js for the HTTP requests with URL path /index/subsys/subsys_intf.js.
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] response url /index/subsys/subsys_intf.js file subsys.js
display loadbalance action
responsible-mail
Use responsible-mail to specify the email address of the administrator.
Use undo responsible-mail to restore the default.
responsible-mail mail-address
No administrator's email address is specified.
SOA view
context-admin
mail-address: Specifies the administrator's email address, a case-insensitive, dot-separated string that contains a maximum of 254 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). Each dot-separated part can have a maximum of 63 characters.
The email address of the administrator can be a relative domain name (does not end with a dot) or an absolute domain name (ends with a dot). For an absolute domain name, the email address is not automatically expanded and cannot exceed 254 characters. For a relative domain name, the current domain name is automatically appended to the email address. The email address plus the appended domain name cannot exceed 254 characters.
# Specify the administrator's email address root.ns1.abc.com for DNS forward zone abc.com.
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com-soa] responsible-mail root.ns1.abc.com
display loadbalance zone
retry
Use retry to set the retry interval.
Use undo retry to restore the default.
retry retry-interval
undo retry
The retry interval is 600 seconds.
SOA view
context-admin
retry-interval: Specifies the retry interval in the range of 500 to 1209600 seconds.
The retry interval is the amount of time that the secondary DNS server waits after it fails to copy a DNS forward zone.
# Set the retry interval to 30 minutes for DNS forward zone abc.com.
[Sysname-lb-zone-abc.com-soa] retry 1800
route-advertisement enable
Use route-advertisement enable to enable IP address advertisement for a virtual server.
Use undo route-advertisement enable to disable IP address advertisement for a virtual server.
IP address advertisement is disabled for a virtual server.
Virtual server view
context-admin
vsys-admin
After this feature is configured, the device advertises the IP address of the virtual server to OSPF for route calculation. When the service of a data center switches to another data center, the traffic to the virtual server can also be switched to that data center. For information about OSPF, see Layer 3—IP Routing Configuration Guide.
# Enable IP address advertisement for the virtual server vs.
[Sysname] virtual-server vs type ip
[Sysname-vs-ip-vs] route-advertisement enable
router interface
Use router interface to specify an outgoing interface for an LB link.
Use undo router interface to delete the outgoing interface for an LB link.
router interface interface-type interface-number
No outgoing interface is specified for an LB link.
LB link view
context-admin
interface-type interface-number: Specifies an outgoing interface.
In scenarios where IP addresses are obtained through PPPoE, use this command to dynamically obtain the outbound next hop IP address through the specified outgoing interface.
The specified outgoing interface must be an interface that can dynamically obtain IP addresses.
You can configure both this command and the router ip or router ipv6 command. The command configured later overwrites the command configured first.
If you configure this command after configuring the vpn-instance (link view) command, this command overwrites the vpn-instance (link view) command. After you configure this command, you cannot configure the vpn-instance (link view) command.
# Specify Dialer0 as the outgoing interface for the LB link cnc.
[Sysname] loadbalance link cnc
[Sysname-lb-link-cnc] router interface Dialer0
router ip
Use router ip to specify the outbound next hop for an LB link.
Use undo router ip to restore the default.
router ip ipv4-address
undo router ip
The outbound next hop is not specified for an LB link.
LB link view
context-admin
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
You can specify only one outbound next hop for an LB link.
# Specify the outbound next hop as 1.2.3.4 for the LB link lk1.
[Sysname-lb-link-lk1] router ip 1.2.3.4
router ipv6
Use router ipv6 to specify the outbound next hop for an LB link.
Use undo router ipv6 to restore the default.
router ipv6 ipv6-address
undo router ipv6
LB link view
context-admin
ipv6-address: Specifies an IPv6 address, which cannot be an all-zero address, a multicast address, a loopback address, or a link-local address.
# Specify the outbound next hop as 8008::8 for the LB link lk1.
[Sysname-lb-link-lk1] router ipv6 8008::8
rst threshold
Use rst threshold to set the RST packet count threshold for a TCP-RST LB probe template.
Use undo rst threshold to restore the default.
rst threshold number
undo rst threshold
The RST packet count threshold is 1000000.
TCP-RST LB probe template view
context-admin
vsys-admin
number: Specifies the RST packet count threshold value, in the range of 1 to 4294967295.
When the number of RST packets sent by a real server reaches the threshold, the protection action specified in the protect-action command is taken.
# In TCP-RST LB probe template rsttplt, set the RST packet count threshold to 20.
<Sysname>system-view
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] rst threshold 20
protect-action
rtt weight
Use rtt weight to set the network delay weight for proximity calculation.
Use undo rtt weight to restore the default.
rtt weight rtt-weight
The network delay weight for proximity calculation is 100.
Proximity view
context-admin
rtt-weight: Specifies the network delay weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher weight.
# Set the network delay weight for proximity calculation to 200.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] rtt weight 200
rule (parameter profile view)
Use rule to configure a filtering rule for compression.
Use undo rule to restore the default.
rule [ rule-id ] { deny | permit } { content-type | url } expression
undo rule rule-id
No filtering rules are configured.
context-admin
vsys-admin
rule-id: Specifies a rule by its ID in the range of 1 to 65535. If the rule does not exist, the command creates the rule. If the rule already exists, the command modifies the rule. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
deny: Does not compress matching packets.
permit: Compresses matching packets.
content-type: Matches content types in the content-type header of packets.
url: Matches URLs in packets.
expression: Specifies a regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
# Create the HTTP-compression parameter profile http1, and configure the device to not compress the response packets containing the string image in URLs.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] rule deny url image
rule (protection policy view)
Use rule to create a protection rule and enter its view, or enter the view of an existing protection rule.
Use undo rule to delete a protection rule.
rule rule-id
undo rule rule-id
No protection rules exist.
context-admin
rule-id: Specifies a rule ID in the range of 1 to 65535.
You can configure multiple protection rules in an HTTP protection policy. The device compares the URL in a packet with the URLs configured in the protection rules according to the order of the rule IDs. If a match is found and the configured protection threshold is exceeded, the device performs the associated protection action. If the URL in the packet does not match the URL configured in a specific protection rule, the device compares the URL with the next protection rule.
# In HTTP protection policy p1, create protection rule 5 and enter its view.
secondary-cookie delimiters
Use secondary-cookie delimiters to configure the delimiter that separates secondary cookies in URLs.
Use undo secondary-cookie delimiters to restore the default.
secondary-cookie delimiters text
The delimiter that separates secondary cookies in URLs can be slash (/), ampersand (&), number sign (#), or plus (+).
context-admin
vsys-admin
text: Specifies the delimiter, a string of 1 to 4 characters including exclamation mark (!), quotation mark (',"), number sign (#), semicolon (;), brackets (( ),[ ], < >), question mark (?), backslash (\), caret (^), grave accent (`), vertical bar (|), colon (:), at sign (@), ampersand (&), dollar sign ($), plus (+), asterisk (*), comma (,), and slash (/). Each character in the string is considered as a delimiter.
# For the HTTP parameter profile pp1, configure the delimiter that separates secondary cookies in URLs as slash (/), at sign (@), number sign (#), or dollar sign ($).
[Sysname-para-http-pp1] secondary-cookie delimiters !@#$
secondary-cookie start
Use secondary-cookie start to configure the start delimiter for secondary cookies in URLs.
Use undo secondary-cookie start to restore the default.
secondary-cookie start text
The start delimiter for secondary cookies in URLs is question mark (?).
context-admin
vsys-admin
text: Specifies the delimiter, a string of 1 to 2 characters including exclamation mark (!), quotation mark ("), number sign (#), semicolon (;), brackets ([ ], < >), question mark (?), backslash (\), caret (^), grave accent (`), and vertical bar (|).
# For the HTTP parameter profile pp1, configure the start delimiter for secondary cookies in URLs as question mark (?) or exclamation mark (!).
[Sysname-para-http-pp1] secondary-cookie start ?!
selected-link
Use selected-link to specify the number of links to participate in scheduling.
Use undo selected-link to restore the default.
selected-link min min-number max max-number
undo selected-link
The links with the highest priority participate in scheduling.
Link group view
context-admin
min min-number: Specifies the minimum number of links to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of links to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of links available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of links available to participate in scheduling is smaller than the min-number setting, more links are selected by priority in descending order.
# Configure the minimum number and maximum number of links in the link group lg to participate in scheduling as 20 and 30, respectively.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] selected-link min 20 max 30
predictor (link group view)
priority (link view)
selected-server (DNS server pool view)
Use selected-server to specify the number of DNS servers to participate in scheduling.
Use undo selected-server to restore the default.
selected-server min min-number max max-number
The DNS servers with the highest priority participate in scheduling.
context-admin
min min-number: Specifies the minimum number of DNS servers to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of DNS servers to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of DNS servers available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of DNS servers available to participate in scheduling is less than the min-number setting, more DNS servers are selected by priority in descending order.
# Configure the minimum number and maximum number of DNS servers in DNS server pool dns-pool to participate in scheduling as 20 and 30, respectively.
[Sysname] loadbalance dns-server-pool dns-pool
[Sysname-lb-dspool-dns-pool] selected-server min 20 max 30
selected-server (server farm view)
Use selected-server to specify the number of real servers to participate in scheduling.
The real servers with the highest priority participate in scheduling.
Server farm view
context-admin
vsys-admin
min min-number: Specifies the minimum number of real servers to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of real servers to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of real servers available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of real servers available to participate in scheduling is less than the min-number setting, more real servers are selected by priority in descending order.
# Configure the minimum number and maximum number of real servers in the server farm sf to participate in scheduling as 20 and 30, respectively.
[Sysname] server-farm sf
[Sysname-sfarm-sf] selected-server min 20 max 30
predictor (server farm view)
priority (real server view)
serial
Use serial to configure the serial number for a DNS forward zone.
Use undo serial to restore the default.
serial number
undo serial
The serial number for a DNS forward zone is 1.
SOA view
context-admin
number: Specifies the serial number in the range of 1 to 4294967295.
The serial number indicates the configuration order of a DNS forward zone. A newly configured DNS forward zone has a greater serial number than an old DNS forward zone.
The secondary DNS server periodically queries the serial numbers of DNS forward zones on the primary DNS server and compares them with local serial numbers.
# Configure the serial number as 123 for DNS forward zone abc.com.
[Sysname-lb-zone-abc.com-soa] serial 123
server-connection reuse
Use server-connection reuse to enable connection reuse between the LB device and the server.
Use undo server-connection reuse to disable connection reuse between the LB device and the server.
Connection reuse between the LB device and the server is disabled.
MySQL parameter profile view
context-admin
vsys-admin
This command allows the LB device to establish connections to the server that can be reused by clients. Because multiple clients can use the same connection, the number of connections between the clients and the server is reduced.
# Enable connection reuse between the LB device and the server for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] server-connection reuse
Use server-farm to specify the primary server farm.
Use undo server-farm to restore the default.
server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name [ backup backup-sticky-name ] ]
undo server-farm
No primary server farm is specified.
LB action view
context-admin
vsys-admin
server-farm-name: Specifies a primary server farm name, a case-insensitive string of 1 to 63 characters.
backup backup-server-farm-name: Specifies a backup server farm name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies a primary sticky group by its name, a case-insensitive string of 1 to 63 characters.
backup backup-sticky-name: Specifies a backup sticky group by its name, a case-insensitive string of 1 to 63 characters. This option is supported only by HTTP virtual servers and RADIUS virtual servers.
This command is mutually exclusive with the forward all or redirect relocation command. If you configure one command, the other command (if configured) is automatically cancelled.
When the primary server farm is available (contains real servers), packets are forwarded through the primary server farm. When the primary server farm is not available, packets are forwarded through the backup server farm.
If you specify both a primary sticky group and a backup sticky group, the device generates both primary sticky entries and backup sticky entries. If packets do not match primary sticky entries, backup sticky entries will apply.
The device generates backup sticky entries for only the following sticky group combinations:
· RADIUS-type primary sticky group and port-address-type backup sticky group.
· HTTP cookie-type primary sticky group and port-address-type backup sticky group.
· HTTP cookie-type primary sticky group and HTTP passive-type backup sticky group.
# Specify the primary server farm sf, the backup server farm sfb, and the sticky group sg1 for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] server-farm sf backup sfb sticky sg1
forward all
Use server-farm to specify the server farm for a real server.
undo server-farm [ server-farm-name ]
A real server does not belong to any server farm.
Real server view
context-admin
vsys-admin
server-farm-name: Specifies a server farm name, a case-insensitive string of 1 to 63 characters.
You can specify a server farm that has not been created.
# Specify the server farm sf for the real server rs.
[Sysname-rserver-rs] server-farm sf
server-farm (system view)
Use server-farm to create a server farm and enter its view, or enter the view of an existing server farm.
Use undo server-farm to delete the specified server farm.
undo server-farm server-farm-name
No server farms exist.
context-admin
vsys-admin
You can add servers with common attributes to a server farm to facilitate management.
# Create the server farm sf and enter server farm view.
[Sysname-sfarm-sf]
service enable (DNS listener view)
Use service enable to enable the DNS listener feature.
Use undo service enable to disable the DNS listener feature.
service enable
undo service enable
The DNS listener feature is disabled.
DNS listener view
context-admin
# Enable the DNS listener feature for the DNS listener ct-listener.
[Sysname] loadbalance dns-listener ct-listener
[Sysname-lb-dl-ct-listener] service enable
service enable (DNS mapping view)
Use service enable to enable the DNS mapping feature.
Use undo service enable to disable the DNS mapping feature.
service enable
undo service enable
The DNS mapping feature is disabled.
DNS mapping view
context-admin
# Enable the DNS mapping feature for the DNS mapping dm1.
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] service enable
service enable (transparent DNS proxy view)
Use service enable to enable the transparent DNS proxy feature.
Use undo service enable to disable the transparent DNS proxy feature.
service enable
undo service enable
The transparent DNS proxy feature is disabled.
Transparent DNS proxy view
context-admin
# Enable the transparent DNS proxy feature for transparent DNS proxy dns-proxy1.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] service enable
service enable (virtual server view)
Use service enable to enable a virtual server.
Use undo service enable to disable a virtual server.
service enable
undo service enable
A virtual server is disabled.
Virtual server view
context-admin
vsys-admin
# Enable the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] service enable
service object-group
Use service object-group to specify a service object group for address translation.
Use undo service object-group to restore the default.
service object-group object-group-name
All packets matching virtual servers are translated.
SNAT global policy view
context-admin
vsys-admin
object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 63 characters.
If you specify a service object group, the device performs SNAT on only packets with a matching service. For information about configuring a service object group, see object group configuration in Security Configuration Guide.
# Specify a service object group obj1 for SNAT global policy sn1.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] service object-group obj1
object-group (Security Command Reference)
set ip tos (LB action view)
Use set ip tos to set the ToS field value of IP packets sent to the server.
Use undo set ip tos to restore the default.
set ip tos tos-number
undo set ip tos
The ToS field of IP packets sent to the server is not changed.
LB action view
context-admin
vsys-admin
tos-number: Specifies the ToS field value in the range of 0 to 255.
# Set the ToS field value to 20 for IP packets sent to the server for the generic LB action lba1.
[Sysname-lba-generic-lba1] set ip tos 20
set ip tos (parameter profile view)
Use set ip tos to set the ToS field value of IP packets sent to the client.
undo set ip tos
The ToS field of IP packets sent to the client is not changed.
Parameter profile view
context-admin
vsys-admin
This command is available in IP parameter profile view only.
# Set the ToS field value to 20 for IP packets sent to the client for the IP parameter profile pp2.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2] set ip tos 20
shutdown (link group member view)
Use shutdown to shut down a link group member.
Use undo shutdown to activate a link group member.
shutdown
A link group member is activated.
Link group member view
context-admin
# Shut down the link group member lk1.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] shutdown
shutdown (link view)
Use shutdown to shut down a link.
Use undo shutdown to activate a link.
shutdown
A link is activated.
Link view
context-admin
# Shut down the link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] shutdown
shutdown (real server view)
Use shutdown to shut down a real server.
Use undo shutdown to activate a real server.
shutdown
A real server is activated.
Real server view
context-admin
vsys-admin
# Shut down the real server rs.
[Sysname-rserver-rs] shutdown
Use shutdown to shut down a server farm member.
Use undo shutdown to activate a server farm member.
shutdown
A server farm member is activated.
Server farm member view
context-admin
vsys-admin
# Shut down the server farm member rs1.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] shutdown
skip current-dns-proxy
Use skip current-dns-proxy to skip the current transparent DNS proxy.
Use undo skip current-dns-proxy to restore the default.
The forwarding mode is to discard packets.
DNS LB action view
context-admin
This command enables DNS requests to skip the current transparent DNS proxy and match the next transparent DNS proxy or virtual server.
A DNS request can skip a maximum of five transparent DNS proxies and virtual servers.
This command is mutually exclusive with the dns-server-pool or forward all command. If you configure one command, the other command (if configured) is automatically cancelled.
# Skip the current transparent DNS proxy in DNS LB action lba1.
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] skip current-dns-proxy
slow-online (link group view)
Use slow-online to enable the slow online feature for a link group.
Use undo slow-online to disable the slow online feature for a link group.
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
The slow online feature is disabled for a link group.
Link group view
context-admin
standby-time standby-time: Specifies the standby timer in the range of 0 to 600 seconds. The default is 5 seconds.
ramp-up-time ramp-up-time: Specifies the ramp-up timer in the range of 3 to 600 seconds. The default is 5 seconds.
The links newly added to a link group might be unable to immediately process large numbers of services assigned by the LB device. To resolve this issue, enable the slow online feature for the link group. The feature uses the standby timer and ramp-up timer. When a link is added, the LB device does not assign any service to the link until the standby timer expires.
When the standby timer expires, the ramp-up timer starts. During the ramp-up time, the LB device increases the service amount according to the processing capability of the link, until the ramp-up timer expires.
# Enable the slow online feature for the link group lg.
[Sysname-lb-lgroup-lg] slow-online
slow-online (server farm view)
Use slow-online to enable the slow online feature for a server farm.
Use undo slow-online to disable the slow online feature for a server farm.
undo slow-online
The slow online feature is disabled for a server farm.
Server farm view
context-admin
vsys-admin
The real servers newly added to a server farm might not be able to immediately process large numbers of services assigned by the LB device. To resolve this issue, enable the slow online feature for the server farm. The feature uses the standby timer and ramp-up timer. When a real server is added, the LB device does not assign any service to the real server until the standby timer expires.
When the standby timer expires, the ramp-up timer starts. During the ramp-up time, the LB device increases the service amount according to the processing capability of the real server, until the ramp-up timer expires.
# Enable the slow online feature for the server farm sf.
[Sysname-sfarm-sf] slow-online
slow-shutdown enable (link group member view)
Use slow-shutdown enable to enable the slow offline feature for a link group member.
Use undo slow-shutdown enable to disable the slow offline feature for a link group member.
The slow offline feature is disabled for a link group member.
context-admin
The shutdown command immediately terminates existing connections of a link group member. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a link group member, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the link group member is shut down.
# Enable the slow offline feature for the link group member lk1.
[Sysname-lb-lgroup-lg-link-lk1] slow-shutdown enable
slow-shutdown enable (link view)
Use slow-shutdown enable to enable the slow offline feature for a link.
Use undo slow-shutdown enable to disable the slow offline feature for a link.
The slow offline feature is disabled for a link.
Link view
context-admin
The shutdown command immediately terminates existing connections of a link. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a link, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the link is shut down.
# Enable the slow offline feature for the link lk1.
[Sysname-lb-link-lk1] slow-shutdown enable
slow-shutdown enable (real server view)
Use slow-shutdown enable to enable the slow offline feature for a real server.
Use undo slow-shutdown enable to disable the slow offline feature for a real server.
The slow offline feature is disabled for a real server.
Real server view
context-admin
vsys-admin
The shutdown command immediately terminates existing connections of a real server. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a real server, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the real server is shut down.
# Enable the slow offline feature for the real server rs.
[Sysname-rserver-rs] slow-shutdown enable
slow-shutdown enable (server farm member view)
Use slow-shutdown enable to enable the slow offline feature for a server farm member.
Use undo slow-shutdown enable to disable the slow offline feature for a server farm member.
The slow offline feature is disabled for a server farm member.
context-admin
vsys-admin
The shutdown command immediately terminates existing connections of a server farm member. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a server farm member, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the server farm member is shut down.
# Enable the slow offline feature for the server farm member rs1.
[Sysname-sfarm-sf-#member#-rs1-port-80] slow-shutdown enable
snat enable
Use snat enable to enable a SNAT global policy.
Use undo snat enable to disable a SNAT global policy.
snat enable
undo snat enable
A SNAT global policy is disabled.
context-admin
vsys-admin
# Enable SNAT global policy sn1.
[Sysname-lb-snat-gp-sn1] snat enable
snat-mode
Use snat-mode to specify a translation mode for a server farm.
Use undo snat-mode to restore the default.
snat-mode { auto-map | tcp-option }
undo snat-mode
No translation mode is specified for a server farm.
Server farm view
context-admin
vsys-admin
auto-map: Specifies the automatic mapping mode.
tcp-option: Specifies the TCP option mode.
The device supports the following translation modes for a server farm:
· Automatic mapping—Translates the source IP address into the IP address of the interface connecting to the real servers.
· TCP option—Translates the source IP address into the IP address carried in the TCP option field of packets.
· SNAT address pool—Translates the source IP address into an IP address in the SNAT address pool specified by using the snat-pool (server farm view) command.
You can configured only one translation mode for a server farm. This command and the snat-pool (server farm view) command are mutually exclusive.
If SNAT is not configured for a server farm, the server farm uses SNAT global policies for address translation (if configured).
# Specify the automatic mapping translation mode for server farm sf.
[Sysname-sfarm-sf] snat-mode auto-map
snat-pool (link group view)
Use snat-pool to specify the SNAT address pool to be referenced by a link group.
Use undo snat-pool to restore the default.
snat-pool pool-name
undo snat-pool
No SNAT address pool is referenced by a link group.
Link group view
context-admin
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters.
After a link group references a SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
# Specify the SNAT address pool lbsp to be referenced by the link group lg.
[Sysname-lb-lgroup-lg] snat-pool lbsp
Use snat-pool to specify the SNAT address pool to be referenced by a server farm.
snat-pool pool-name
undo snat-pool
No SNAT address pool is referenced by a server farm.
Server farm view
context-admin
vsys-admin
After a server farm references a SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
# Specify the SNAT address pool lbsp to be referenced by the server farm sf.
[Sysname-sfarm-sf] snat-pool lbsp
snmp-agent trap enable loadbalance
Use snmp-agent trap enable loadbalance to enable SNMP notifications for load balancing.
Use undo snmp-agent trap enable loadbalance to disable SNMP notifications for load balancing.
All SNMP notifications are enabled for load balancing.
context-admin
To report critical load balancing events to an NMS, enable SNMP notifications for load balancing. For load balancing event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for load balancing.
[Sysname] undo snmp-agent trap enable loadbalance
soa
Use soa to create an SOA resource record and enter SOA view, or enter the view of an existing SOA resource record.
Use undo soa to delete the SOA resource record and all its setting.
soa
undo soa
No SOA resource record exists.
DNS forward zone view
context-admin
# Create an SOA resource record for DNS forward zone abc.com and enter SOA view.
source-ip
Use source-ip to configure a source-IP-based request threshold.
Use undo source-ip to restore the default.
source-ip request-threshold threshold
undo source-ip
The source-IP-based request threshold is not configured.
Protection rule view
context-admin
vsys-admin
request-threshold threshold: Specifies a request threshold in the range of 1 to 4294967295.
If the number of times that a user accesses a protected URL exceeds the request threshold during the protection period, the protection action is taken. The device determines whether requests belong to the same user based on the following elements:
· Cookie—Requests with the same cookie value for a cookie (specified in the cookie command in protection rule view) belong to the same user.
· Source IP address—Requests with the same source IP address belong to the same user.
If you configure both a cookie-based request threshold and a source-IP-based request threshold, the protection action is taken when either threshold is exceeded.
# In protection rule 5, configure a source-IP-based request threshold of 2.
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] source-ip request-threshold 2
cookie (protection policy view)
protected-url
protection-action
protection-period
source-ip object-group (parameter profile view)
Use source-ip object-group to enable collection of HTTP traffic statistics by source IP address object group.
Use undo source-ip object-group to remove a source IP address object group for HTTP traffic statistics collection.
source-ip object-group object-group-name
undo source-ip object-group object-group-name
HTTP traffic statistics are collected on a per-IP address basis.
HTTP statistics parameter profile view
context-admin
object-group-name: Specifies a source IP address object group by its name, a case-insensitive string of 1 to 63 characters.
If HTTP packets match the specified URL and source IP address object group, they are counted based on the source IP address object group. If HTTP packets match the specified URL but do not match the specified source IP address object group, they are counted based on the source IP address.
You can specify a maximum of 1024 source IP address object groups in one HTTP statistics parameter profile.
This command takes effect only on IP address objects configured by using the host, subnet, and range keywords in the network command. For information about configuring IP address objects, see object group configuration in Security Configuration Guide.
# In HTTP statistics parameter profile http1, enable collection of HTTP traffic statistics by source IP address object group cnc.
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] source-ip object-group cnc
network (Security Command Reference)
source-ip object-group (SNAT global policy view)
Use source-ip object-group to specify a source IP address object group for address translation.
Use undo source-ip object-group to restore the default.
All packets are translated.
context-admin
vsys-admin
If you specify a source IP address object group, the device performs SNAT on only packets with a matching source IP address. For information about configuring an IP address object group, see object group configuration in Security Configuration Guide.
# Specify source IP address object group obj1 for SNAT global policy sn1.
[Sysname-lb-snat-gp-sn1] source-ip object-group obj1
src-addr-option
Use src-addr-option to configure the TCP option for SNAT.
Use undo src-addr-option to restore the default.
src-addr-option option-number [ encode { binary | string } ]
No TCP option is configured for SNAT.
TCP parameter profile view
context-admin
vsys-admin
option-number: Specifies a TCP option by its number. Valid numbers are 6, 7, 9 to 18, and 22 to 254.
encode { binary | string }: Specifies the bindary or string encoding mode. The default is the binary mode.
This command enables the device to parse the IP address in the TCP option by using the specified encoding mode. Then, the device translates the source IP address according to the configured translation mode.
This command takes effect only in a TCP parameter profile that is referenced as a client-side parameter profile by a virtual server.
# In TCP parameter profile pp3, specify TCP option 28 with binary encoding mode for SNAT.
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] src-addr-option 28 encode binary
ssl session-id
Use ssl session-id to configure an SSL sticky method based on SSL session ID.
Use undo ssl session-id to restore the default.
ssl session-id
undo ssl session-id
No sticky methods exist.
SSL sticky group view
context-admin
The SSL sticky method based on SSL session ID applies only to HTTPS request packets. This sticky method requires specifying an SSL server policy for the virtual server.
# Configure the SSL sticky method based on SSL session ID for the SSL sticky group sg6.
[Sysname] sticky-group sg6 type ssl
[Sysname-sticky-ssl-sg6] ssl session-id
ssl url rewrite
Use ssl url rewrite to rewrite the URL in the Location header of HTTP response packets sent by the server.
Use undo ssl url rewrite to remove the configuration.
ssl url rewrite location location [ clearport clear-port ] [ sslport ssl-port ]
undo ssl url rewrite location location [ clearport clear-port ]
The URL in the Location header of HTTP response packets sent by the server is not rewritten.
HTTP LB action view
context-admin
vsys-admin
location location: Specifies the Location header URL regular expression, a case-sensitive string of 1 to 255 characters.
clearport clear-port: Specifies the HTTP port number to be rewritten, in the range of 1 to 65535. The default is 80.
sslport ssl-port: Specifies the SSL port number after rewrite, in the range of 1 to 65535. The default is 443.
If the Location header of an HTTP response packet contains the location and clear-port values, the system rewrites HTTP in the URL to HTTPS and rewrites the clear-port value to the ssl-port value.
# For the HTTP LB action lba2, rewrite the URL http://www.ss.com:8080 in the Location header of HTTP response packets sent by the server to https://www.ss.com:443.
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] ssl url rewrite location www.ss.com clearport 8080 sslport 443
ssl-client-policy (LB action view)
Use ssl-client-policy to specify an SSL client policy to encrypt traffic between the LB device (SSL client) and the SSL server.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
undo ssl-client-policy policy-name
No SSL client policy is referenced.
HTTP LB action view
context-admin
vsys-admin
policy-name: Specifies an SSL policy by its name, a case-insensitive string of 1 to 31 characters.
You must disable and then enable a virtual server for a modified SSL policy to take effect.
The device does not support specifying an SSL client policy that uses the following cipher suites:
· exp_rsa_des_cbc_sha.
· exp_rsa_rc2_md5.
· exp_rsa_rc4_md5.
· rsa_des_cbc_sha.
# Specify the SSL client policy scp for the HTTP LB action lba2.
[Sysname-lba-http-lba2] ssl-client-policy scp
ssl-client-policy (virtual server view)
Use ssl-client-policy to specify an SSL client policy for a virtual server to encrypt traffic between the LB device (SSL client) and the SSL server.
A virtual server does not reference any SSL client policy.
HTTP virtual server view
context-admin
vsys-admin
· exp_rsa_rc2_md5.
· exp_rsa_rc4_md5.
· rsa_des_cbc_sha.
# Specify the SSL client policy scp for the HTTP virtual server vs2.
[Sysname] virtual-server vs2 type http
[Sysname-vs-http-vs2] ssl-client-policy scp
ssl-server-policy
Use ssl-server-policy to specify an SSL server policy for a virtual server to encrypt traffic between the LB device (SSL server) and the SSL client.
Use undo ssl-server-policy to remove an SSL server policy.
ssl-server-policy policy-name [ sni server-name ]
undo ssl-server-policy policy-name [ policy-name sni ]
A virtual server does not reference any SSL server policy.
HTTP/TCP virtual server view
context-admin
vsys-admin
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
sni server-name: Specifies an SSL server indication, a case-insensitive string of 1 to 253 characters.
The device does not support specifying an SSL server policy that uses the following cipher suites:
· exp_rsa_rc2_md5.
· exp_rsa_rc4_md5.
· rsa_des_cbc_sha.
If you execute this command multiple times without the sni server-name option, the most recent configuration takes effect.
You can specify multiple SSL server policies with SSL server indications, and each SSL server policy must have a different SSL server indication.
If you specify multiple SSL server policies, only the SSL server policy without an SSL server indication takes effect.
# Specify the SSL server policy ssp for the HTTP virtual server vs2.
[Sysname-vs-http-vs2] ssl-server-policy ssp
statistics-match url
Use statistics-match url to configure a URL match rule.
Use undo statistics-match url to delete a URL match rule.
statistics-match [ rule-id ] url url
undo statistics-match rule-id
No URL match rules exist.
Statistics node view
context-admin
rule-id: Specifies the match rule ID in the range of 1 to 256. If you do not specify a match rule ID, the system assigns the smallest available rule ID to the match rule.
url: Specifies a URL regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
You can configure a maximum of 256 URL match rules for one statistics node.
# In statistics node bank, configure a string of .html to match URLs in HTTP packets.
[Sysname-para-http-statistics-http1] node bank
[Sysname-para-http-statistics-http1-node-bank] statistics-match url *.html
status-code
Use status-code to configure a response status code to check.
Use undo status-code to remove a response status code.
status-code code
undo status-code code
No response status code is configured for checking.
HTTP passive LB probe template view
context-admin
vsys-admin
code: Specifies a response status code, in the range of 100 to 599.
The device monitors the responses of HTTP requests with URLs specified in the check-url command. If the status code in an HTTP response is the same as the specified response status code, a URL error is recorded.
You can configure a maximum of 10 response status codes for one HTTP passive load balancing template.
# Configure response status code 404 in HTTP passive load balancing template tplt.
[Sysname] loadbalance probe-template http-passive tplt
[Sysname-lbpt-http-passive-tplt] status-code 404
check-url
sticky
Use sticky to specify a sticky group for a virtual server.
Use undo sticky to restore the default.
sticky sticky-name
undo sticky
No sticky group is specified for a virtual server.
context-admin
vsys-admin
sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters.
You can also specify a sticky group by using the default server-farm and server-farm (LB action view) commands. The sticky group specified by using the sticky command has the highest priority.
This command allows you to specify only HTTP cookie sticky groups.
# Specify the HTTP cookie sticky group test for HTTP virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] sticky test
default server-farm
sticky-group
sticky-group
Use sticky-group to create a sticky group and enter its view, or enter the view of an existing sticky group.
Use undo sticky-group to delete the specified sticky group.
sticky-group group-name [ type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius| sip | ssl | tcp-payload | udp-passive } ]
undo sticky-group group-name
No sticky groups exist.
context-admin
vsys-admin
group-name: Specifies a sticky group name, a case-insensitive string of 1 to 63 characters.
type { address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }: Specifies the sticky group type, address and port, HTTP entity, HTTP cookie, HTTP header, HTTP passive, HTTP or UDP payload, RADIUS, SIP, SSL, TCP payload, or UDP passive. When you create a sticky group, you must specify the sticky group type. You can enter an existing sticky group view without entering the type of the sticky group.
A sticky group uses a specific sticky method to distribute similar sessions to the same real server or link. The sticky method applies to the first packet of a session. Subsequent packets of the session are distributed to the same real server or link.
You can configure only the address- and port-type sticky groups if the device does not have any licenses installed. To configure sticky groups of any other type, you must install licenses. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create the address- and port-type sticky group sg1 and enter sticky group view.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1]
sticky-over-busy enable
Use sticky-over-busy enable to enable stickiness-over-busyness.
Use undo sticky-over-busy enable to disable stickiness-over-busyness.
Stickiness-over-busyness is disabled.
Sticky group view
context-admin
vsys-admin
This command enables the device to assign client requests to real servers based on sticky entries, regardless of whether the real servers are busy.
When stickiness-over-busyness is disabled, the device assigns client requests to only the real servers in normal state.
# In address- and port-type sticky group sg1, enable stickiness-over-busyness.
[Sysname-sticky-address-port-sg1] sticky-over-busy enable
sticky-sync enable (transparent DNS proxy view)
Use sticky-sync enable to enable sticky entry synchronization for a transparent DNS proxy.
Use undo sticky-sync enable to disable sticky entry synchronization for a transparent DNS proxy.
sticky-sync enable [ global ]
Sticky entry synchronization is disabled for a transparent DNS proxy.
context-admin
global: Enables global synchronization.
Non-default vSystems do not support this command.
This command can back up sticky entry information to ensure service continuity during a master and backup switchover in hot backup mode.
In an IRF fabric, if you do not specify the global keyword when enabling sticky entry synchronization, sticky entries are synchronized between cards in the failover group. If you specify the global keyword, sticky entries are synchronized among all cards.
In a VRRP network, you must specify the global keyword for the sticky entry synchronization feature to take effect.
The device deletes existing sticky entries and generates new ones when the following events occur:
· Sticky entry synchronization is disabled.
· Sticky entry synchronization is changed from failover group-based synchronization to global synchronization.
· Sticky entry synchronization is changed from global synchronization to failover group-based synchronization.
# Enable sticky entry synchronization for transparent DNS proxy dns_proxy1.
[Sysname] loadbalance dns-proxy dns_proxy1 type udp
[Sysname-lb-dp-udp-dns_proxy1] sticky-sync enable
sticky-sync enable (virtual server view)
Use sticky-sync enable to enable sticky entry synchronization for a virtual server.
Use undo sticky-sync enable to disable sticky entry synchronization for a virtual server.
Sticky entry synchronization is disabled for a virtual server.
Virtual server view
context-admin
vsys-admin
For successful sticky entry synchronization, if you want to specify a sticky group, enable sticky entry synchronization before specifying a sticky group on both LB devices. You can specify a sticky group by using the sticky sticky-name option when you specify a primary server farm (see the default server-farm command).
# Enable sticky entry synchronization for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] sticky-sync enable
success-criteria (DNS server pool member view)
Use success-criteria to specify the health monitoring success criteria for a DNS server pool member.
Use undo success-criteria to restore the default.
success-criteria { all | at-least min-number }
Health monitoring succeeds only when all the specified health monitoring methods succeed.
context-admin
all: Specifies the health monitoring success criteria as all successful health monitoring methods.
at-least min-number: Specifies the health monitoring success criteria as the specified minimum number of successful health monitoring methods, in the range of 1 to 4294967295.
If the min-number setting exceeds the number of existing health monitoring methods on the device, the number of existing health monitoring methods applies.
The health monitoring success criteria configuration in DNS server pool member view takes precedence over the configuration in DNS server pool view.
The health monitoring result for a DNS server affects the availability of a DNS server pool member. The health monitoring result for a DNS server pool member does not affect the availability of a DNS server.
# Configure the health monitoring success criteria for the DNS server pool member ds1 as a minimum number of 2 successful health monitoring methods.
[Sysname] loadbalance dns-server-pool dsp1
[Sysname-lb-dsp-dsp1] dns-server ds1 port 10
[Sysname-lb-dsp-dsp1-#member#-ds1-port-10] success-criteria at-least 2
success-criteria (DNS server pool view)
Use success-criteria to specify the health monitoring success criteria for a DNS server pool.
context-admin
The health monitoring success criteria configuration in DNS server view takes precedence over the configuration in DNS server pool view.
# Configure the health monitoring success criteria for the DNS server pool dns-pool as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-dspool-dns-pool] success-criteria at-least 2
success-criteria (DNS server view)
Use success-criteria to specify the health monitoring success criteria for a DNS server.
DNS server view
context-admin
# Configure the health monitoring success criteria for DNS server ds1 as a minimum number of 2 successful health monitoring methods.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] success-criteria at-least 2
success-criteria (link group member view)
Use success-criteria to specify the health monitoring success criteria for a link group member.
context-admin
The health monitoring success criteria configuration in link group member view takes precedence over the configuration in link group view.
The health monitoring result for a link affects the availability of a link group member. The health monitoring result for a link group member does not affect the availability of a link.
# Configure the health monitoring success criteria for the link group member lk1 as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-lgroup-lg-#member#-lk1] success-criteria at-least 2
success-criteria (link group view)
Use success-criteria to specify the health monitoring success criteria for a link group.
Link group view
context-admin
The health monitoring success criteria configuration in link view takes precedence over the configuration in link group view.
# Configure the health monitoring success criteria for the link group lg as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-lgroup-lg] success-criteria at-least 2
success-criteria (link view)
Use success-criteria to specify the health monitoring success criteria for an LB link.
LB link view
context-admin
# Configure the health monitoring success criteria for the LB link lk1 as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-link-lk1] success-criteria at-least 2
success-criteria (real server view)
Use success-criteria to specify the health monitoring success criteria for a real server.
Real server view
context-admin
vsys-admin
The health monitoring success criteria configuration in real server view takes precedence over the configuration in server farm view.
# Configure the health monitoring success criteria for the real server rs as a minimum number of 2 successful health monitoring methods.
[Sysname] real-server rs
[Sysname-rserver-rs] success-criteria at-least 2
success-criteria (server farm member view)
Use success-criteria to specify the health monitoring success criteria for a server farm member.
context-admin
vsys-admin
The health monitoring success criteria configuration in server farm member view takes precedence over the configuration in server farm view.
The health monitoring result for a real server affects the availability of a server farm member. The health monitoring result for a server farm member does not affect the availability of a real server.
# Configure the health monitoring success criteria for the server farm member rs1 as a minimum number of 2 successful health monitoring methods.
[Sysname-sfarm-sf-#member#-rs1-port-80] success-criteria at-least 2
success-criteria (server farm view)
Use success-criteria to specify the health monitoring success criteria for a server farm.
Server farm view
context-admin
vsys-admin
# Configure the health monitoring success criteria for the server farm sf as a minimum number of 2 successful health monitoring methods.
[Sysname-sfarm-sf] success-criteria at-least 2
syn retransmission-timeout
Use syn retransmission-timeout to set the retransmission timeout time for SYN packets.
Use undo syn retransmission-timeout to restore the default.
syn retransmission-timeout timeout-value
The retransmission timeout time for SYN packets is 10 seconds.
context-admin
vsys-admin
timeout-value: Specifies the retransmission timeout time for SYN packets, in the range of 1 to 75 seconds.
This command sets the amount of time the device waits for a SYN ACK before closing a TCP connection.
# Set the retransmission timeout time for SYN packets to 5 seconds for TCP connections.
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] syn retransmission-timeout 5
display parameter-profile
tcp connection idle-timeout
Use tcp connection idle-timeout to set the idle timeout for TCP connections.
Use undo tcp connection idle-timeout to restore the default.
tcp connection idle-timeout value
The idle timeout is 0 seconds for TCP connections, which means TCP connections never time out.
context-admin
vsys-admin
value: Specifies the idle timeout in the range of 10 to 86400 seconds.
This command sets the idle timeout for TCP connections between the LB device and the clients and for TCP connections between the LB device and the servers. If no traffic is available on a TCP connection before the idle timeout expires, the LB device terminates the TCP connection.
# Set the idle timeout to 60 seconds for TCP connections.
[Sysname] parameter-profile pp1 type tcp
[Sysname-para-tcp-pp1] tcp connection idle-timeout 60
tcp mss
Use tcp mss to set the MSS for the LB device.
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The MSS is not set for the LB device.
context-admin
vsys-admin
value: Specifies the MSS value in the range of 128 to 1460 bytes.
This command takes effect only when the HTTP virtual server has referenced a TCP parameter profile.
When the client establishes a TCP connection to the LB device, the client sends its own MSS value to the LB device. The LB device records the MSS value and sends the configured MSS value to the client. The client and the LB device use the smaller MSS value for communication.
When the LB device establishes a TCP connection to the server, the LB device sends the configured MSS value to the server. The server records the MSS value and sends its own MSS value to the LB device. The LB device and the server use the smaller MSS value for communication.
# Set the MSS to 1300 bytes for the LB device.
[Sysname] parameter-profile tcp type tcp
[Sysname-para-tcp-tcp] tcp mss 1300
tcp option insert
Use tcp option insert to insert the client IP address into a TCP option.
Use undo tcp option insert to remove the configuration.
tcp option insert option-number src-addr [ encode { binary | string } ]
undo tcp option insert option-number
The client IP address is not inserted into any TCP options.
context-admin
vsys-admin
option-number: Specifies a TCP option by its number. Valid values are 6, 7, 9 to 18, and 22 to 254.
encode { binary | string }: Specifies the binary or string encoding mode. The default is binary mode.
This command inserts the client's actual IP address as the source IP address into the specified option in headers of TCP packets sent to the server.
This command takes effect only on TCP parameter profiles referenced by the following virtual servers:
· HTTP virtual servers.
· TCP virtual servers configured with SSL server policies.
· TCP virtual servers operating at Layer 7.
· MySQL virtual servers.
You can execute this command multiple times to insert the client IP address to a maximum of five TCP options.
If you execute this command multiple times for the same TCP option, the most recent configuration takes effect.
# In TCP parameter profile para2, insert the client IP address into TCP option 28.
[Sysname] parameter-profile para2 type tcp
[Sysname-para-tcp-para2] tcp option insert 28 src-addr
parameter-profile
tcp option remove
Use tcp option remove to remove the specified TCP option from TCP packet headers.
Use undo tcp option remove to cancel the removal configuration.
tcp option remove option-number
undo tcp option remove option-number
No TCP option is removed from TCP packet headers.
context-admin
vsys-admin
option-number: Specifies a TCP option by its number in the range of 3 to 254.
This command removes the specified TCP option from headers of TCP packets sent to the server.
You can execute this command multiple times to remove a maximum of five TCP options.
# In TCP parameter profile para2, remove TCP option 8 from TCP packet headers.
[Sysname-para-tcp-para2] tcp option remove 8
parameter-profile
tcp window-size
Use tcp window-size to configure the maximum local window size for TCP connections.
Use undo tcp window-size to restore the default.
tcp window-size size
The maximum local window size for TCP connections is 65535.
context-admin
vsys-admin
size: Specifies the maximum local window size for TCP connections, in the range of 8192 to 65535.
# Set the maximum local window size for TCP connections to 8192 for the TCP parameter profile pp3.
[Sysname-para-tcp-pp3] tcp window-size 8192
tcp-close
Use tcp-close to configure the method to close TCP connections.
Use undo tcp-close to restore the default.
tcp-close { fin | rst }
undo tcp-close
FIN packets are sent to close TCP connections.
Generic/HTTP LB action view
context-admin
vsys-admin
fin: Closes TCP connections by sending FIN packets.
rst: Closes TCP connections by sending RST packets.
# In generic LB action lba1, configure the rst method to close TCP connections.
[Sysname-lba-generic-lba1] tcp-close rst
tcp-payload
Use tcp-payload to configure the TCP payload sticky method.
Use undo tcp-payload to delete the TCP payload sticky method.
tcp-payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo tcp-payload
No TCP payload sticky methods exist.
TCP payload sticky group view
context-admin
vsys-admin
offset offset: Specifies the offset value of the TCP payload based on the start of the TCP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the TCP payload, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the TCP payload, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the TCP payload, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Use this command to obtain the TCP payload information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
If you do not specify any parameters in this command, the sticky entry is generated based on the whole TCP packet.
# Configure the TCP payload sticky method for the TCP payload sticky group sg: Use the whole TCP packet to generate sticky entries.
[Sysname] sticky-group sg type tcp-payload
[Sysname-sticky-payload-sg] tcp-payload
timeout (LB probe template view)
Use timeout to set the timeout time for probe responses.
Use undo timeout to restore the default.
undo timeout
The timeout time for probe responses is 3 seconds for ICMP probe packets and custom monitoring probe packets and is 5 seconds for HTTP passive probe packets.
ICMP LB probe template view
Custom-monitoring LB probe template view
context-admin
vsys-admin
timeout-value: Specifies the timeout time for probe responses, in the range of 1 to 60 seconds for ICMP probe packets, 1 to 255 seconds for HTTP passive probe packets, and 1 to 86400 seconds for custom monitoring probe packets.
As a best practice, set the timeout time for probe responses to be smaller than the monitoring time (set by using the monitor-interval command).
After an HTTP passive LB probe template is referenced, the device monitors the responses of HTTP requests with URLs specified in the check-url command. If the response time for an HTTP request exceeds the specified timeout time, a URL error is recorded.
# Set the timeout time for probe responses to 5 seconds in the ICMP template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lbpt-icmp-icmptplt] timeout 5
check-url
monitor-interval
timeout (proximity view)
Use timeout to set the timeout timer for proximity entries.
undo timeout
The timeout timer for proximity entries is 60 seconds.
Proximity view
context-admin
timeout-value: Specifies the timeout timer in the range of 60 to 3600 seconds.
# Set the timeout timer for proximity entries to 80 seconds.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] timeout 80
timeout (sticky group view)
Use timeout to set the timeout timer for sticky entries.
timeout { indefinite | timeout-value }
undo timeout
The timeout timer for sticky entries is 86400 seconds for sticky groups of the HTTP cookie, HTTP passive, and UDP passive types and 60 seconds for sticky groups of other types.
Sticky group view
context-admin
vsys-admin
indefinite: Specifies an indefinite timeout timer for sticky entries so that the sticky entries never age out. Sticky groups of the HTTP cookie type, HTTP passive type, and UDP passive type do not support this keyword.
timeout-value: Specifies the timeout timer in the range of 0 to 31536000 seconds for sticky groups of the HTTP cookie type and in the range of 10 to 604800 seconds for sticky groups of other types.
For sticky groups of the HTTP cookie type, the following principles apply:
· If the sticky method is cookie insert or cookie rewrite, a timeout timer of 0 indicates session persistency.
· If the sticky method is cookie get, a timeout timer of 0 indicates the timeout time for the sticky entries is 0 seconds.
# Set the timeout timer for sticky entries to 100 seconds in the address- and port-type sticky group sg1.
[Sysname-sticky-address-port-sg1] timeout 100
time-wait timeout
Use time-wait timeout to set the TIME_WAIT state timeout time for TCP connections.
Use undo time-wait timeout to restore the default.
time-wait timeout value
The TIME_WAIT state timeout time is 2 seconds for TCP connections.
context-admin
vsys-admin
value: Specifies the TIME_WAIT state timeout time in the range of 1 to 65535 seconds.
A TCP connection cannot be released until the TIME_WAIT timer expires. To release TCP connections faster and improve load balancing efficiency, use this command to set a shorter TIME_WAIT state timeout time.
# Set the TIME_WAIT state timeout time for TCP connections to 30 seconds in the TCP parameter profile pa1.
[Sysname] parameter-profile pa1 type tcp
[Sysname-para-tcp-pa1] time-wait timeout 30
topology region
Use topology region to configure a topology.
Use undo topology region to restore the default.
topology region region-name { ip ipv4-address { mask-length | mask } | ipv6 ipv6-address prefix-length } [ priority priority ]
undo topology region region-name [ ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address [ prefix-length ] ]
No topologies exist.
context-admin
region-name: Specifies a region by its name, a case-insensitive string of 1 to 63 characters.
ip ipv4-address: Specifies the IPv4 address of a virtual server.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32. The default is 32.
mask: Specifies the mask for the IPv4 address. The default is 255.255.255.255.
ipv6 ipv6-address prefix-length: Specifies the IPv6 address of a virtual server.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 0 to 128. The default is 128.
priority priority: Specifies the priority of the topology, in the range of 1 to 255. The default weight is 100.
A topology associates the region where the local DNS server resides with the IP address of a virtual server.
When the static proximity algorithm (topology) is specified for the virtual server pool by using the predictor command, you must configure a topology.
When a DNS request matches multiple topology records, the topology record with the highest priority is selected.
You can execute this command multiple times to configure multiple IP address ranges for a region.
If you only specify a region when deleting a topology, all topologies for the region are deleted.
# Configure a topology by associating the region region-ct with the IPv4 address 1.2.3.4.
[Sysname] topology region region-ct ip 1.2.3.4 24 priority 200
loadbalance region
predictor (virtual server pool view)
translation-mode
Use translation-mode to configure a translation mode for a SNAT global policy.
Use undo translation-mode to restore the default.
translation-mode { auto-map | snat-pool pool-name }
No translation mode is configured for a SNAT global policy.
context-admin
vsys-admin
snat-pool pool-name: Specifies the SNAT address pool mode. The pool-name argument specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters.
The device supports the following translation modes in a SNAT global policy:
· SNAT address pool—Translates the source IP address into an IP address in the specified SNAT address pool.
If SNAT is not configured for a server farm, the server farm uses SNAT global policies for address translation.
# Specify SNAT address pool sp for address translation in SNAT global policy sn1.
[Sysname-lb-snat-gp-sn1] translation-mode snat-pool sp
transparent enable (link group view)
Use transparent enable to disable NAT for a link group.
Use undo transparent enable to enable NAT for a link group.
transparent enable
NAT is enabled for a link group.
Link group view
context-admin
# Disable NAT for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-sinalab] transparent enable
transparent enable (server farm view)
Use transparent enable to disable NAT for a server farm.
Use undo transparent enable to enable NAT for a server farm.
transparent enable
NAT is enabled for a server farm.
Server farm view
context-admin
vsys-admin
If the server farm is referenced by a virtual server of the HTTP type, the NAT feature takes effect even if it is disabled.
# Disable NAT for the server farm sf.
[Sysname] server-farm sf
[Sysname-sfarm-sf] transparent enable
ttl (DNS forward zone view)
Use ttl to set the TTL for resource records.
Use undo ttl to restore the default.
ttl ttl-value
undo ttl
The TTL for resource records is 3600 seconds.
context-admin
ttl-value: Specifies the TTL value in the range of 0 to 4294967295 seconds.
# Set the TTL for resource records to 1 day for DNS forward zone abc.com.
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com] ttl 86400
display loadbalance zone
ttl (DNS mapping view)
Use ttl to set the TTL for DNS records.
ttl ttl-value
undo ttl
The TTL for DNS records is 3600 seconds.
DNS mapping view
context-admin
Use this command to set a proper TTL to cache DNS records for DNS responses.
· For the DNS client to get the updated DNS record when the LB policy or virtual server configuration changes, set a smaller TTL value, for example, 60 seconds.
· For stable, fast domain name resolution when the network is stable, set a larger TTL value, for example, 86400 seconds.
# Set the TTL for DNS records to 4000 seconds for the DNS mapping dm1.
[Sysname-lb-dm-dm1] ttl 4000
display loadbalance dns-map
ttl weight
Use ttl weight to set the TTL weight for proximity calculation.
Use undo ttl weight to restore the default.
ttl weight ttl-weight
undo ttl weight
The TTL weight for proximity calculation is 100.
Proximity view
context-admin
ttl-weight: Specifies the TTL weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher weight.
# Set the TTL weight for proximity calculation to 200.
[Sysname-lb-proximity] ttl weight 200
udp per-packet
Use udp per-packet to enable per-packet load balancing for UDP traffic for a virtual server.
Use undo udp per-packet to disable per-packet load balancing for UDP traffic for a virtual server.
udp per-packet
undo udp per-packet
Per-packet load balancing for UDP traffic is disabled for a virtual server.
UDP virtual server view
UDP-based SIP virtual server view
context-admin
vsys-admin
When per-packet load balancing for UDP traffic is disabled, the LB device distributes traffic matching the virtual server according to application type. Traffic of the same application type is distributed to one real server.
When per-packet load balancing for UDP traffic is enabled, the following results apply:
· The LB device distributes traffic matching the virtual server on a per-packet basis.
· The LB device does not collect statistics of connections on the virtual server or real server.
· If NAT is not enabled for the referenced server farm, the LB device does not collect statistics of packets sent by the virtual server or real server.
· The following configurations are still effective:
¡ Scheduling algorithm configured on the server farm referenced by the virtual server.
¡ Sticky method of the sticky group when the virtual server references the server farm.
Because packets of the same session have the same quintuple, the hash scheduling algorithm or the source IP address sticky method yields the same result for the packets. For example, if a server farm uses the hash scheduling algorithm or the source IP address sticky method, the LB device distributes UDP packets of the same session to one real server. In this case, the LB device cannot distribute UDP packets on a per-packet basis.
# Enable per-packet load balancing for UDP traffic for the UDP virtual server vs5.
[Sysname] virtual-server vs5 type udp
[Sysname-vs-udp-vs5] udp per-packet
username
Use username to specify the login username and password of the MySQL database.
Use undo username to remove the login username and password of the MySQL database.
username username [ password { cipher | simple } string ]
undo username username
The login username and password of the MySQL database is not specified.
MySQL virtual server view
context-admin
vsys-admin
username: Specifies the username, a case-sensitive string of 1 to 63 characters.
password: Specifies the password. If you do not specify the password, the password is null.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 127 characters. Its encrypted form is a case-sensitive string of 1 to 255 characters.
You can configure a maximum of 100 login users.
The specified login username and password must be the same as the actual login username and password of the MySQL database.
# Specify the username and password as root and 123456, respectively, for the MySQL virtual server vs1.
[Sysname] virtual-server vs1 type mysql
[Sysname-vs-mysql-vs1] username root password simple 123456
variable
Use variable to associate a variable with a server farm member.
Use undo variable to disassociate a variable from a server farm member.
variable variable-name value value
undo variable variable-name
No variable is associated with a server farm member.
context-admin
vsys-admin
variable-name: Specifies a variable name, a case-sensitive string of 1 to 63 characters.
value value: Specifies the variable value, a case-sensitive string of 1 to 127 characters.
# Associate a variable with variable name var1 and variable value 1 with server farm member rs.
[Sysname-sfarm-sf] real-server rs port 5001
[Sysname-sfarm-sf-#member#-rs-port-5001] variable var1 value _1
payload rewrite
version
Use version to configure the MySQL database version.
Use undo version to restore the default.
version { 5.0 | 5.1 | 5.5 | 5.6 | 5.7 }
undo version
The MySQL database version is 5.6.
context-admin
vsys-admin
{ 5.0 | 5.1 | 5.5 | 5.6 | 5.7 }: Specifies the MySQL database version number.
The LB device performs authentication for clients on behalf of the MySQL server and sends database initialization packets of the specified MySQL version to clients.
# Configure the MySQL database version as 5.7 for the MySQL virtual server vs1.
[Sysname-vs-mysql-vs1] version 5.7
virtual-ip
Use virtual-ip to add a virtual IPv4 address to a virtual server pool.
Use undo virtual-ip to delete a virtual IPv4 address from a virtual server pool.
virtual-ip ipv4-address link link-name [ weight weight-value ]
undo virtual-ip ipv4-address
No virtual IPv4 addresses are added to a virtual server pool.
Virtual server pool view
context-admin
ipv4-address: Specifies a virtual IPv4 address.
link link-name: Specifies an LB link by its name, a case-insensitive string of 1 to 63 characters.
weight weight-value: Specifies the weight for the virtual IPv4 address, in the range of 1 to 255. The default weight is 100.
In scenarios where server load balancing is not required, you can configure virtual IPv4 addresses instead of virtual servers to simplify configuration.
For the weighted round-robin scheduling algorithm, a virtual IPv4 address with a greater weight value are preferentially scheduled.
You can add multiple virtual IPv4 addresses to a virtual server pool, and a virtual IPv4 address can be associated with one link. If you execute this command multiple times for the same virtual IPv4 address, the most recent configuration takes effect.
# Add virtual IPv4 address 10.0.0.1 associated with LB link link1 to virtual server pool local-pool.
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] virtual-ip 10.0.0.1 link link1
loadbalance link
virtual-ipv6
Use virtual-ipv6 to add a virtual IPv6 address to a virtual server pool.
Use undo virtual-ipv6 to delete a virtual IPv6 address from a virtual server pool.
virtual-ipv6 ipv6-address link link-name [ weight weight-value ]
undo virtual-ipv6 ipv6-address
No virtual IPv6 addresses are added to a virtual server pool.
context-admin
ipv6-address: Specifies a virtual IPv6 address.
weight weight-value: Specifies the weight for the virtual IPv6 address, in the range of 1 to 255. The default weight is 100.
In scenarios where server load balancing is not required, you can configure virtual IPv6 addresses instead of virtual servers to simplify configuration.
For the weighted round-robin scheduling algorithm, a virtual IPv6 address with a greater weight value are preferentially scheduled.
You can add multiple virtual IPv6 addresses to a virtual server pool, and a virtual IPv6 address can be associated with one link. If you execute this command multiple times for the same virtual IPv6 address, the most recent configuration takes effect.
# Add virtual IPv6 address 10::1 associated with LB link link1 to virtual server pool local-pool.
[Sysname-lb-vspool-local-pool] virtual-ipv6 10::1 link link1
loadbalance link
virtual ip address
Use virtual ip address to configure an IPv4 address (VSIP) for a virtual server.
Use undo virtual ip address to restore the default.
virtual ip address ipv4-address [ mask-length | mask ]
No IPv4 address is configured for a virtual server.
Virtual server view
context-admin
vsys-admin
ipv4-address: Specifies an IPv4 address. It cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X (with a mask length of 32).
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32. This argument is not supported by virtual servers of the HTTP type.
mask: Specifies a subnet mask. The default is 255.255.255.255. This argument is not supported by virtual servers of the HTTP type.
If the IP address of an interface connected to a client is in the same network segment as the VSIP, you must specify an interface for sending gratuitous ARP or ND packets.
# Configure the IPv4 address for the IP-type virtual server vs3 as 1.1.1.1/24.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] virtual ip address 1.1.1.1 24
arp-nd interface (virtual server view)
virtual ipv6 address
Use virtual ipv6 address to configure an IPv6 address (VSIP) for a virtual server.
Use undo virtual ipv6 address to restore the default.
virtual ipv6 address ipv6-address [ prefix-length ]
No IPv6 address is configured for a virtual server.
Virtual server view
context-admin
vsys-admin
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (when the prefix length is not 0).
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128. This argument is not supported by virtual servers of the HTTP type.
If the IPv6 address of an interface connected to a client is in the same network segment as the VSIP, you must specify an interface for sending gratuitous ARP or ND packets.
# Configure the IPv6 address for the IP-type virtual server vs3 as 1001::1/64.
[Sysname-vs-ip-vs3] virtual ipv6 address 1001::1 64
virtual-server (system view)
Use virtual-server to create a virtual server and enter its view, or enter the view of an existing virtual server.
Use undo virtual-server to delete the specified virtual server.
virtual-server virtual-server-name [ type { http | ip | link-ip | | mysql sip-tcp | sip-udp | radius | tcp | udp } ]
undo virtual-server virtual-server-name
No virtual servers exist.
context-admin
vsys-admin
virtual-server-name: Specifies the virtual server name, a case-insensitive string of 1 to 63 characters.
type { http | ip | link-ip | mysql | sip-tcp | sip-udp | radius | tcp | udp }: Specifies the virtual server type as HTTP, IP, link-IP, MySQL, RADIUS, TCP-based SIP, UDP-based SIP, TCP, or UDP. When you create a virtual server, you must specify a virtual server type. You can enter an existing virtual server view without entering the type of the virtual server.
You can create HTTP, MySQL, RADIUS, SIP, TCP, or UDP virtual servers only if the device has licenses installed. For information about licensing, see license management in Fundamentals Configuration Guide.
# Create the virtual server vs3 with the IP type, and enter virtual server view.
[Sysname-vs-ip-vs3]
virtual-server (virtual server pool view)
Use virtual-server to add a virtual server to a virtual server pool.
Use undo virtual-server to delete a virtual server from a virtual server pool.
virtual-server virtual-server-name link link-name [ weight weight-value ]
No virtual servers are added to a virtual server pool.
context-admin
virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters.
weight weight-value: Specifies the weight for the virtual server, in the range of 1 to 255. The default weight is 100. For the weighted round robin algorithm, a greater value means a higher priority to be referenced. If you do not specify this option, the default weight 100 applies.
You can add multiple virtual servers to a virtual server pool.
To ensure correct operation of inbound link load balancing when server load balancing is also enabled, do not specify the virtual server's IP address as the DNS listener's IP address.
The virtual server's IP address for inbound link load balancing must be a unicast address with a 32-bit mask length. The IP address cannot be an all-zero address.
# Add the virtual server vs1 associated with the LB link link1 to the virtual server pool local-pool.
[Sysname-lb-vspool-local-pool] virtual-server vs1 link link1
loadbalance link
virtual-server-pool
Use virtual-server-pool to specify a virtual server pool for a DNS mapping.
Use undo virtual-server-pool to restore the default.
virtual-server-pool pool-name
undo virtual-server-pool pool-name
No virtual server pool is specified for a DNS mapping.
DNS mapping view
context-admin
pool-name: Specifies the virtual server pool name, a case-insensitive string of 1 to 63 characters.
# Specify the virtual server pool pool1 for the DNS mapping dm1.
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] virtual-server-pool pool1
vpn-instance (DNS listener view)
Use vpn-instance to specify a VPN instance for a DNS listener.
Use undo vpn-instance to restore the default.
undo vpn-instance
A DNS listener belongs to the public network.
DNS listener view
context-admin
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
# Specify VPN instance vpn1 for DNS listener ct-listener.
[Sysname] loadbalance dns-listener ct-listener
[Sysname-lb-dl-ct-listener] vpn-instance vpn1
display loadbalance dns-listener
vpn-instance (DNS server view)
Use vpn-instance to specify a VPN instance for a DNS server.
undo vpn-instance
A DNS server belongs to the public network.
DNS server view
context-admin
# Specify VPN instance vpn1 for DNS server ds1.
[Sysname-vs-http-vs] vpn-instance vpn1
display loadbalance dns-server
vpn-instance (link view)
Use vpn-instance to specify a VPN instance for a link.
undo vpn-instance
A link belongs to the public network.
Link view
context-admin
Before executing this command, you must create the VPN instance by using the ip vpn-instance vpn-instance-name command. If the specified VPN instance has not been created, the link state will be unavailable.
# Specify VPN instance vpn1 for link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] vpn-instance vpn1
ip vpn-instance (MPLS Command Reference)
vpn-instance (real server view)
Use vpn-instance to specify a VPN instance for a real server.
undo vpn-instance
A real server belongs to the public network if VPN instance inheritance is disabled.
A real server belongs to the VPN instance specified for its virtual server if VPN instance inheritance is enabled.
Real server view
context-admin
# Specify VPN instance vpn1 for real server rs.
[Sysname-rserver-rs] vpn-instance vpn1
inherit vpn-instance disable
vpn-instance (SNAT address pool view)
Use vpn-instance to specify a VPN instance for a SNAT address pool.
undo vpn-instance
A SNAT address pool belongs to the public network.
context-admin
Use this command to isolate SNAT address pools if they overlap.
As a best practice, specify the VPN instance of the associated real server for a SNAT address pool.
# Specify VPN instance vpn1 for SNAT address pool sn1.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] vpn-instance vpn1
vpn-instance (SNAT global policy view)
Use vpn-instance to specify a VPN instance for a SNAT global policy.
undo vpn-instance
A SNAT global policy belongs to the public network.
context-admin
vsys-admin
# Specify VPN instance vpn1 for SNAT global policy sn1.
vpn-instance (transparent DNS proxy view)
Use vpn-instance to specify a VPN instance for a transparent DNS proxy.
undo vpn-instance
A transparent DNS proxy belongs to the public network.
Transparent DNS proxy view
context-admin
# Specify VPN instance vpn1 for transparent DNS proxy dns-proxy1.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] vpn-instance vpn1
vpn-instance (virtual server view)
Use vpn-instance to specify a VPN instance for a virtual server.
A virtual server belongs to the public network.
Virtual server view
context-admin
# Specify VPN instance vpn1 for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] vpn-instance vpn1
vrrp vrid
Use vrrp vrid to bind a VRRP group to a virtual server.
Use undo vrrp vrid to unbind a VRRP group from a virtual server.
vrrp [ ipv6 ] vrid virtual-router-id interface interface-type interface-number
undo vrrp [ ipv6 ]
No VRRP group is bound to a virtual server.
Virtual server view
context-admin
ipv6: Specifies an IPv6 VRRP group. To use this command to bind an IPv4 VRRP group to a virtual server, do not specify this keyword.
virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
interface-type interface-number: Specifies the interface on which the VRRP group was created.
In an HA system, execute this command if you configure server load balancing on the primary device to make sure the return packets are processed on the same master device. For more information about HA, see high availability group configuration in High Availability Configuration Guide.
Multiple virtual servers bound to different VRRP groups cannot use the same SNAT address pool.
A virtual server can be bound to a maximum of one IPv4 or IPv6 VRRP group. You can bind an IPv4 VRRP group to only an IPv4 virtual server, or bind an IPv6 VRRP group to only an IPv6 virtual server.
# Bind VRRP group 1 to TCP virtual server vs.
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] vrrp vrid 1 interface gigabitethernet 1/0/1
virtual-server
vrrp vrid (High Availability Command Reference)
weight (DNS server pool member view)
Use weight to set the weight of a DNS server pool member.
Use undo weight to restore the default.
weight weight-value
undo weight
The weight of a DNS server pool member is 100.
context-admin
weight-value: Specifies the weight in the range of 1 to 255. A greater value means a higher priority in scheduling.
The weight configured in this command is used in the weighted round-robin algorithm.
# Set the weight of the DNS server pool member ds1 to 150.
[Sysname-lb-dspool-dsp1] dns-server ds1 port 10
[Sysname-lb-dspool-dsp1-#member#-ds1-port-10] weight 150
weight (DNS server view)
Use weight to set the weight of a DNS server to be used by the weighted round robin algorithm and bandwidth algorithm.
weight weight-value
undo weight
The weight of a DNS server is 100.
DNS server view
context-admin
# Set the weight of the DNS server ds1 to 150.
[Sysname-lb-ds-ds1] weight 150
weight (link group member view)
Use weight to set the weight of a link group member.
weight weight-value
undo weight
The weight of a link group member is 100.
Link group member view
context-admin
The weight configured in this command is used in the weighted least-connection algorithm and weighted round-robin algorithm.
# Set the weight of the link group member lk1 to 150.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] weight 150
weight (link view)
Use weight to set the weight of a link to be used by the weighted round robin and weighted least connection algorithms.
weight weight-value
undo weight
The weight of a link is 100.
Link view
context-admin
weight-value: Specifies the weight in the range of 1 to 255. For the weighted round robin or weighted least connection algorithm, a greater value means a higher priority to be referenced.
# Set the weight of the link lk1 to 150.
[Sysname-lb-link-lk1] weight 150
weight (real server view)
Use weight to set the weight of a real server to be used by the weighted round robin and weighted least connection algorithms.
weight weight-value
undo weight
The weight of a real server is 100.
Real server view
context-admin
vsys-admin
# Set the weight of the real server rs to 150.
[Sysname-rserver-rs] weight 150
weight (server farm member view)
Use weight to set the weight of a server farm member.
weight weight-value
undo weight
The weight of a server farm member is 100.
Server farm member view
context-admin
vsys-admin
# Set the weight of the server farm member rs1 to 150.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] weight 150
whois-mntner
Use whois-mntner to specify a whois maintainer object for an ISP.
Use undo whois-mntner to delete a whois maintainer object for an ISP.
whois-mntner mntner-name
undo whois-mntner mntner-name
No whois maintainer object is specified for an ISP.
ISP view
context-admin
mntner-name: Specify a whois maintainer object by its name, a case-sensitive string of 1 to 63 characters.
This command specifies the geographical area where ISP address information is to be updated by the whois server.
You can specify a maximum of 10 whois maintainer objects for an ISP.
A whois maintainer object is globally unique.
# Specify whois maintainer object MAINT-CHINANET for ISP isp1.
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] whois-mntner MAINT-CHINANET
window-size
Use window-size to set the window size used for compression.
Use undo window-size to restore the default.
window-size size
undo window-size
The window size used for compression is 16 KB.
HTTP-compression parameter profile view
context-admin
vsys-admin
size: Specifies the window size in KB used for compression. The value can only be 1, 2, 4, 8, 16, or 32.
# Create the HTTP-compression parameter profile pa1, and set the window size used for compression to 32 KB.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compression-pa1] window-size 32
zero-window threshold
Use zero-window threshold to set the percentage threshold of zero-window packets for a TCP zero-window LB probe template.
Use undo zero-window threshold to restore the default.
zero-window threshold percentage
undo packet-zero-window
The percentage threshold of zero-window packets is 40%.
TCP zero-window LB probe template view
context-admin
vsys-admin
percentage: Specifies the percentage threshold of zero-window packets, in the range of 1 to 100.
When the percentage of zero-window packets sent by a real server reaches the threshold, the protection action specified in the protect-action command is taken.
# In TCP zero-window LB probe template zerotplt, set the percentage threshold of zero-window packets to 20%.
<Sysname>system-view
[Sysname] loadbalance probe-template tcp-zero-window zerotplt
[Sysname-lbpt-tcp-zwnd-zerotplt] zero-window threshold 20
protect-action
