- 04-DPI Command Reference
- 01-DPI engine commands
- 02-IPS commands
- 03-URL filtering commands
- 04-Data filtering commands
- 05-File filtering commands
- 06-Anti-virus commands
- 07-Data analysis center commands
- 08-WAF commands
- 09-Proxy policy commands
- 10-IP reputation commands
- 11-Domain reputation commands
- 12-APT defense commands
- 13-DLP commands
- 14-Content moderation commands
| 10-IP reputation commands | 101.32 KB |
display ip-reputation attack-category
display ip-reputation exception
display ip-reputation signature library
display ip-reputation top-hit-statistics
ip-reputation signature auto-update
ip-reputation signature auto-update-now
ip-reputation signature rollback
ip-reputation signature update
The following compatibility matrix shows the support of hardware platforms for IP reputation:
Hardware platform |
Module type |
IP reputation compatibility |
M9006 M9010 M9014 |
Blade IV firewall module |
Yes |
Blade V firewall module |
No |
NAT module |
No |
M9010-GM |
Encryption module |
Yes |
M9016-V |
No |
M9008-S M9012-S |
Yes |
Intrusion prevention service (IPS) module |
Yes |
Video network gateway module |
Yes |
M9008-S-6GW |
IPv6 module |
Yes |
M9008-S-V |
Yes |
M9000-AI-E4 M9000-AI-E8 M9000-AI-E16 |
Yes |
M9000-X06 M9000-X10 |
Blade VI firewall module |
Yes |
attack-category
Use attack-category to configure actions for an attack category.
Use undo attack-category to restore the default.
attack-category attack-id { action { deny | permit } | logging { disable | enable } }*
undo attack-category attack-id
No actions are configured for an attack category. Each attack category has its own pre-defined actions.
IP reputation view
context-admin
attack-id: Specifies an attack category ID. The value range depends on the IP reputation file and the device model.
action: Specifies an action.
deny: Drops matching packets.
permit: Allows matching packets to pass through.
logging: Sets the logging status for the attack category. When a packet matches the attack category with logging enabled, the device generates logs for the matching events.
disable: Disables logging for the matching events.
enable: Enables logging for the matching events.
The command configuration takes effect after you enable IP reputation.
On the IP reputation list, an IP address can belong to multiple attack categories. Each attack category has its own actions.
If an IP address belongs to only one attack category, the device takes the actions in this attack category. If an IP address belongs to multiple attack categories, the device takes an action that has higher priority among all actions in those attack categories. The drop action has higher priority than the permit action.
If logging is enabled for any one of attack categories to which an IP address belongs, the device generates a log when the IP address is matched.
The device supports fast output of IP reputation logs. For more information about fast log output, see fast log output commands in Network Management and Monitoring Command Reference.
# Set the action to deny for attack category 1 and enable logging for the attack category.
[Sysname] ip-reputation
[Sysname-ip-reputation] attack-category 1 action deny logging enable
global enable
Use display ip-reputation to display IP reputation information about an IP address.
display ip-reputation ipv4 ipv4-address
context-admin
context-operator
ipv4 ipv4-address: Specifies an IPv4 address.
The IP reputation list contains the following attribute information for an IP address: attack category, match field, actions on matching packets, and the hit count.
If an IP address belongs to multiple attack categories, the command displays information about the IP address based on the attack category ID.
# Display IP reputation information about IP address 192.168.1.1.
<Sysname> display ip-reputation ipv4 192.168.1.1
IP address Attack ID Attack name Direction Action Logging Hit count
192.168.1.1 1 ddos src deny enabled 1000
2 web dst permit disabled
Figure 1 Command output
IP address |
IP address on the IP reputation list. |
Attack ID |
ID of the attack category to which the IP address belongs. |
Attack name |
Name of the attack category to which the IP address belongs. |
Direction |
Match field attribute of the IP address: · src—Used as the source IP address match criterion. · dst—Used as the destination IP address match criterion. · src/dst—Used as the source or destination IP address match criterion. |
Action |
Action on matching packets: · permit—Allows the packets to pass through. · deny—Drops the packets. |
Logging |
Logging status, enabled or disabled. |
Hit count |
Number of times that the IP address is matched. |
Use display ip-reputation attack-category to display information about attack categories for IP reputation.
context-admin
context-operator
The command displays attack category information after IP reputation is enabled.
If you do not specify actions for an attack category, the pre-defined actions are displayed.
# Display information about attack categories for IP reputation.
<Sysname> display ip-reputation attack-category
ID Attack name Action Logging
1 ddos permit enabled
2 web deny disabled
Figure 2 Command output
ID |
Attack category ID. |
Attack name |
Attack category name. |
Action |
Action that the device takes on packets matching the attack category. · permit—Forwards the packets. · deny—Discards the packets. |
Logging |
attack-category
Use display ip-reputation exception to display exception IP addresses.
context-admin
context-operator
The command displays exception IP addresses, if any, when the IP reputation is enabled.
# Display exception IP addresses.
<Sysname> display ip-reputation exception
IP address
10.1.1.1
10.10.1.1
Figure 3 Command output
IP address |
Exception IP address. |
Use display ip-reputation signature library to display information about the IP reputation signature library.
context-admin
context-operator
# Display information about the IP reputation signature library.
<Sysname> display ip-reputation signature library
iP-reputation signature library information:
Type SigVersion ReleaseTime Size
Current 1.02 Fri Sep 13 09:05:35 2014 71594
Last - - -
Factory - - -
Type |
Version type of the IP reputation signature library. · Current—Current version. · Last—Previous version. · Factory—Factory default version. (Not supported currently.) |
SigVersion |
Version number of the IP reputation signature library. |
ReleaseTime |
Release time of the IP reputation signature library. |
Size(bytes) |
Size of the IP reputation signature library file, in bytes. |
Use display ip-reputation top-hit-statistics to display statistics for IP addresses with the highest hits on the IP reputation list.
In standalone mode:
display ip-reputation top-hit-statistics [ top-number ] [ slot slot-number ]
In IRF mode:
display ip-reputation top-hit-statistics [ top-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
top-number: Specifies the number of top ranking IP addresses. The value range is 10 to 100, and the default is 10.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays statistics for IP addresses with the highest hits on the IP reputation list for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays statistics for IP addresses with the highest hits on the IP reputation list for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot. Support for this option depends on the device model.
This command displays statistics for IP addresses with the highest hits on the IP reputation list when the top hit ranking feature is enabled.
This command does not display IP addresses with no hits. Therefore, the number of IP addresses in the command output might be less than the value of the top-number argument.
# (In standalone mode.) Display statistics for 10 IP addresses with the highest hits on the IP reputation list.
<Sysname> display ip-reputation top-hit-statistics 10 slot 1
Slot 1:
IP address Hit count
10.1.1.1 1000
10.1.1.2 999
10.1.1.3 996
10.1.1.4 994
10.1.1.5 994
10.1.1.6 994
Figure 4 Command output
IP address |
Hit count |
Number of times that the IP address is hit. |
exception
Use exception to specify an exception IP address.
Use undo exception to remove an exception IP address.
exception ipv4 ipv4-address
undo exception ipv4 ipv4-address
No exception IP address is specified.
IP reputation view
context-admin
ipv4 ipv4-address: Specifies an exception IPv4 address.
The command takes effect after you enable IP reputation.
The device forwards a packet if the source or destination IP address of the packet is an exception IP address.
Repeat this command to add multiple exception IP addresses.
# Specify 192.168.1.1 as an exception IP address.
[Sysname-ip-reputation] exception ipv4 192.168.1.1
global enable
global enable
Use global enable to enable IP reputation globally.
Use undo global enable to disable IP reputation globally.
global enable
undo global enable
IP reputation is disabled globally.
IP reputation view
context-admin
# Enable IP reputation globally.
[Sysname-ip-reputation] global enable
ip-reputation
Use ip-reputation to enter IP reputation view.
Use undo ip-reputation to delete all configuration in IP reputation view.
ip-reputation
undo ip-reputation
context-admin
# Enter IP reputation view.
Use ip-reputation signature auto-update to enable automatic update of the IP reputation signature library and enter automatic IP reputation signature library update configuration view.
Use undo ip-reputation signature auto-update to disable automatic update of the IP reputation signature library.
Automatic update of the IP reputation signature library is disabled.
context-admin
After you enable automatic update of the IP reputation signature library, the device periodically accesses the signature database services on the official website to download the latest IP reputation signature library.
# Enable automatic update of the IP reputation signature library and enter automatic IP reputation signature library update configuration view.
[Sysname] ip-reputation signature auto-update
[Sysname-ip-reputation-autoupdate]
update schedule
Use ip-reputation signature auto-update-now to trigger an automatic update of the IP reputation signature library manually.
context-admin
After you execute this command, the device immediately starts the automatic update process of the IP reputation signature library no matter whether or not automatic signature library update is enabled. Before overwriting the current signature library file, the device automatically backs it up to the ipreputation_sigpack_curr.dat file in the device storage medium.
You can execute this command anytime you find a new version of signature library on the official website.
# Trigger an automatic update of the IP reputation signature library manually.
[Sysname] ip-reputation signature auto-update-now
Use ip-reputation signature rollback to roll back the IP reputation signature library.
ip-reputation signature rollback last
context-admin
last: Rolls back the IP reputation signature library to the previous version.
If an IP reputation signature library update causes exceptions or a high false alarm rate, you can roll back the IP reputation signature library.
Before performing an IP reputation signature library rollback, the device backs up the current IP reputation signature library as the previous version. For example, the previous library version is V1 and the current library version is V2. If you perform a rollback to the previous version, library version V1 becomes the current version and library version V2 becomes the previous version. If you perform a rollback to the previous version again, the library rolls back to library version V2.
# Roll back the IP reputation signature library to the previous version.
[Sysname] ip-reputation signature rollback last
Use ip-reputation signature update to manually update the IP reputation signature library.
ip-reputation signature update file-path
context-admin
file-path: Specifies the IP reputation signature library file path, a string of 1 to 255 characters.
If the device cannot access the signature database services on the official website, use one of the following methods to manually update the IP reputation signature library:
· Local update—Updates the IP reputation signature library by using a locally stored IP reputation signature library file. To use this method, first obtain the signature library file from the official website and import it to the device.
(In standalone mode.) Store the update file on the active MPU for successful signature library update.
(In IRF mode.) Store the update file on the global active MPU for successful signature library update.
The following describes the format of the file-path parameter for different update scenarios.
Update scenario |
Format of file-path |
Remarks |
The update file is stored in the current working directory. |
filename |
To display the current working directory, use the pwd command. For information about the pwd command, see file system management in Fundamentals Command Reference. |
The update file is stored in a different directory on the same storage medium. |
filename |
Before configuring the ip-reputation signature update command, use the cd command to open the directory where the file is stored. For information about the cd command, see file system management in Fundamentals Command Reference. |
The update file is stored on a different storage medium. |
path/filename |
Before configuring the ip-reputation signature update command, use the cd command to open the root directory of the storage medium where the file is stored. For information about the cd command, see file system management in Fundamentals Command Reference. |
· FTP/TFTP update—Updates the IP reputation signature library by using the file stored on an FTP or TFTP server. The device automatically downloads the signature file from the server before using it to update the signature library.
Update scenario |
Remarks |
The update file is stored on an FTP server. |
ftp://username:password@server/filename |
The username parameter represents the FTP login username. The password parameter represents the FTP login password. The server parameter represents the IP address or host name of the FTP server. Replace the following special characters in the FTP login username and password with their respective escape characters: · Colon (:)—%3A or %3a. · At sign (@)—%40. · Forward slash (/)—%2F or %2f. |
The update file is stored on a TFTP server. |
tftp://server/filename |
The server parameter represents the IP address or host name of the TFTP server. |
NOTE: To update the signature library successfully, make sure the device and the FTP or TFTP server can reach each other. If you specify the FTP or TFTP server by its host name, you must also make sure the device can resolve the host name into an IP address through static or dynamic DNS. For more information about DNS, see Layer 3—IP Services Configuration Guide. |
# Manually update the IP reputation signature library by using an IP reputation signature library file stored on a TFTP server.
[Sysname] ip-reputation signature update tftp://192.168.0.10/ip-1.0.2-en.dat
# Manually update the IP reputation signature library by using an IP reputation signature library file stored on the device. The file is stored in directory cfb0:/dpi/ip-1.0.23-en.dat, and the current working directory is cfa0:.
<Sysname> cd cfb0:/
[Sysname] ip-reputation signature update dpi/ip-1.0.23-en.dat
top-hit-statistics enable
Use top-hit-statistics enable to enable the top hit ranking feature for IP addresses.
Use undo top-hit-statistics enable to disable the top hit ranking feature.
The top hit ranking feature is disabled for IP addresses on the IP reputation list.
IP reputation view
context-admin
This feature takes effect after you enable IP reputation.
This feature enables the device to collect hit statistics for IP addresses on the IP reputation list and rank them. After you disable this feature, the device clears hit statistics for IP reputation.
# Enable the top hit ranking feature for IP addresses on the IP reputation list.
[Sysname-ip-reputation] top-hit-statistics enable
update schedule
Use update schedule to schedule the time for automatic IP reputation signature library update.
Use undo update schedule to restore the default.
The device starts updating the IP reputation signature library at a random time between 01:00:00 and 03:00:00 every day.
Automatic IP reputation signature library update configuration view
context-admin
daily: Updates the IP reputation signature library every day.
weekly: Updates the IP reputation signature library every week.
fri: Updates the IP reputation signature library every Friday.
mon: Updates the IP reputation signature library every Monday.
sat: Updates the IP reputation signature library every Saturday.
sun: Updates the IP reputation signature library every Sunday.
thu: Updates the IP reputation signature library every Thursday.
tue: Updates the IP reputation signature library every Tuesday.
wed: Updates the IP reputation signature library every Wednesday.
start-time time: Specifies the start time in the hh:mm:ss format. The value range is 00:00:00 to 23:59:59.
tingle minutes: Specifies the tolerance time in minutes. The value range is 0 to 120. An automatic library update will occur at a random time between the following time points:
· Start time minus half the tolerance time.
· Start time plus half the tolerance time.
For example, if you specify the start time as 01:00:00 and the tolerance time as 60 minutes, the device will perform the update at a random time between 00:30:00 to 01:30:00.
# Configure the device to automatically update the IP reputation signature library every Monday at a random time between 20:25:00 and 20:35:00.
[Sysname-ip-reputation-autoupdate] update schedule weekly mon start-time 20:30:00 tingle 10
