- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Device management commands
- 09-Tcl commands
- 10-Python commands
- 11-License management commands
- 12-MAC learning through a Layer 3 device commands
- 13-Cloud connection commands
| 10-Python commands | 42.41 KB |
Python commands
exit()
Use exit() to exit the Python shell.
exit()
Python shell
context-admin
To return to user view from the Python shell, you cannot use the quit command. You must use the exit() command.
# Exit the Python shell.
Python 2.7.3 (default)
[GCC 4.4.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
<Sysname>
python
Use python to enter the Python shell.
python
context-admin
In the Python shell, you can use the following items:
· Python 2.7 commands.
· Python 2.7 standard API.
· Comware 7 extended API.
# Enter the Python shell.
<Sysname> python
python filename
Use python filename to execute a Python script.
python filename [ param ]
context-admin
filename: Specifies the name of a Python script on a storage medium of the device. The script name is case sensitive and must use the extension .py. The extension .py is case insensitive.
param: Specifies the parameters to be passed to the script. To enter multiple parameters, use spaces as the delimiter.
You cannot perform any operations while you are executing a Python script.
Make sure the statements in the script meet the syntax requirements. The system stops executing a Python script if it finds a statement with syntax errors.
When executing a script, the system uses the defaults for interactive statements. The system does not stop for human input.
# Execute Python script test.py.
<Sysname> python test.py 1 2
['/flash:/test.py', '1', '2']
