03-Monitor
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath IPS Comware 7 Web-Based Configuration Guide(R8X60)-6W60003-Monitor
40-Terminal status
40-Terminal status 27.05 KB
Terminal status
This help contains the following topics:
·     Introduction
¡     Terminal heat map
¡     Terminal information
·     Restrictions and guidelines
Introduction
Terminal heat map
The terminal heat map offers a visual representation of the state of each terminal in each network segment. The terminal state can be normal, abnormal, or unreachable. You can search terminals by terminal state or block state. You can click the IP address of a terminal to block the terminal. The blocked terminal cannot access the network until the block duration expires or you unblock it.
The terminal heat map uses different colors to represent different states.
·     Unused (Gray)—The device does not detect the traffic from the terminal that uses the IP address.
·     Normal (Green)—The device has detected the traffic from the terminal, and the traffic is between the bandwidth lower limit and the bandwidth upper limit.
·     Abnormal (Orange)—The terminal is in abnormal state, which includes the following situations:
¡     Poorly connected—The traffic from the terminal is below the bandwidth lower limit.
¡     Illegally used—The IP address of the terminal is used by another illegal terminal. The device detects this situation when terminal information changes.
·     Unreachable (Red)—The device detected the traffic from the terminal and then cannot detect the traffic. This state transitions to the Unused state after being kept for seven days.
·     Blocked (Purple)—The IP address of the terminal is administratively blocked.
This section displays information about and states of all terminals for monitoring purposes. By monitoring the MAC address, manufacturer, and model information of a terminal, you can prevent its IP address from being illegally used or prevent it from being illegally replaced. You can also click Unblocked or Blocked to block or unblock a terminal.
The block function can be used only after you click Enable globally on the Policies > Attack Defense > Blacklist page.
