- 03-Monitor
- 01-Application analysis center
- 02-Blacklist logs
- 03-Single-packet attack logs
- 04-Scanning attack logs
- 05-Flood attack logs
- 06-WAF logs
- 07-Threat logs
- 08-Reputation logs
- 09-URL filtering logs
- 10-File filtering logs
- 11-Security policy logs
- 12-IPCAR logs
- 13-Sandbox logs
- 14-Terminal status
- 15-Application audit logs
- 16-System logs
- 17-Configuration logs
- 18-Traffic logs
- 19-TopN traffic
- 20-Security policy hit analysis
- 21-TopN threats
- 22-TopN URL filtering statistics
- 23-TopN file filtering statistics
- 24-Attack defense statistics
- 25-Connection rate ranking
- 26-TopN traffic trends
- 27-Security policy hit trend analysis
- 28-TopN threat trends
- 29-TopN URL filtering trends
- 30-TopN file filtering trends
- 31-Botnet analysis
- 32-Asset security
- 33-Threat case management
- 34-Report settings
- 35-Session list
- 36-User information center
- 37-IPv4 online users
- 38-IPv6 online users
- 39-MAC authentication online users
- 40-Terminal status
| 18-Traffic logs | 30.89 KB |
Traffic logs
Introduction
This page displays traffic information on a per-flow basis. Administrators can apply appropriate bandwidth limit policies according to traffic logs.
For traffic logs to be displayed, you must enable session statistics collection on the System > Session Aging Time Settings > Advanced Setting page.
· Only one log operation (import, export, or delete) is allowed at a time.
· Only one user can perform a log operation at a time. When you import, export, or delete logs, make sure no one else is performing a log operation.
Manage traffic logs
Import logs
1. Click the Monitor tab.
2. In the navigation pane, select Device Logs > Traffic Logs.
3. Click Import.
4. In the dialog box that opens, click Yes.
5. Select a log file, and enter the password for the log file. The password was set when the file was exported.
Export logs
3. Click Advanced search.
4. On the page that opens, specify the search criteria to display the logs to be exported.
5. Click Export.
6. On the page that opens, configure the log export settings.
Table 1 Log export configuration items
Item |
Set password |
Enter a password for encrypting the log files. This password is required when you view or import the exported log files. |
Log range |
Specify the range of logs to be exported. Options are: · All results—Exports all logs that satisfy the search criteria. The page displays the total number of logs to be exported. · Day on the current page—Exports logs of the day indicated by the Time field on the current page. You can define the ending page to decrease the number of logs to be exported. |
7. Select one of the following export methods.
¡ Export to one file—Exports logs to one file. When a small number of logs are to be exported, select this method.
The system supports exporting a maximum of 65000 logs to one log file.
¡ Export to files—Exports logs to multiple files. If more than 65000 logs are to be exported, select this method.
8. Perform one of the following tasks as required:
¡ If you have selected Export to one file, click OK in the dialog box that opens.
¡ If you have selected Export to files, specify the number of logs to be exported to each file and click OK in the dialog box that opens.
When a log export to one file is complete, a dialog box opens, asking you whether to continue exporting the remaining logs to a new file.
- To continue the export, click Yes.
- To stop the export process, click No.
