- 03-Monitor
- 01-Application analysis center
- 02-Blacklist logs
- 03-Single-packet attack logs
- 04-Scanning attack logs
- 05-Flood attack logs
- 06-WAF logs
- 07-Threat logs
- 08-Reputation logs
- 09-URL filtering logs
- 10-File filtering logs
- 11-Security policy logs
- 12-IPCAR logs
- 13-Sandbox logs
- 14-Terminal status
- 15-Application audit logs
- 16-System logs
- 17-Configuration logs
- 18-Traffic logs
- 19-TopN traffic
- 20-Security policy hit analysis
- 21-TopN threats
- 22-TopN URL filtering statistics
- 23-TopN file filtering statistics
- 24-Attack defense statistics
- 25-Connection rate ranking
- 26-TopN traffic trends
- 27-Security policy hit trend analysis
- 28-TopN threat trends
- 29-TopN URL filtering trends
- 30-TopN file filtering trends
- 31-Botnet analysis
- 32-Asset security
- 33-Threat case management
- 34-Report settings
- 35-Session list
- 36-User information center
- 37-IPv4 online users
- 38-IPv6 online users
- 39-MAC authentication online users
- 40-Terminal status
| 19-TopN traffic | 48.17 KB |
TopN traffic
This help contains the following topics:
Introduction
The device analyzes traffic statistics and generates the following types of traffic ranking reports that display the traffic ranking results in bar chart, pie chart, and list:
· TopN Users.
· TopN Applications.
· TopN Source Addresses.
· TopN Destination Addresses.
· TopN Contexts.
On each of the preceding report configuration page, you can customize conditions such as the time range and the traffic direction for statistics collection. Then, you can generate the report and export the report as needed.
TopN users
Perform this task to generate the topN users traffic report and export the report.
1. Click Stats conditions in the top left corner of the page.
2. Configure the statistics collection conditions.
Table 1 Statistics collection condition configuration items for the topN users traffic report
Item |
Traffic direction |
Select the traffic direction. Options are: · Upstream. · Downstream. · Bidirectional. |
Time range |
Select a time range from the list. Options are: · Today. · Past week. · Past month. · Custom. |
Show Top |
Enter the number of users to display. |
3. Click Start.
4. Click a user on the topN users traffic report to view the application usage statistics for the user.
5. To export the topN users traffic report, click Export report.
TopN applications
Perform this task to generate the topN applications traffic report and export the report.
Table 2 Statistics collection condition configuration items for the topN applications traffic report
Item |
Traffic direction |
Time range |
Query object |
Enter the source IP address whose application usage traffic statistics will be collected. |
Ranked by |
Select the ranked object. Options are: · Application category. · Application. |
Show Top |
Enter the number of applications to display. |
3. Click Start.
4. Click an application on the topN applications traffic report and select Source address to view the topN source addresses that used the application.
5. Click an application on the topN applications traffic report and select User to view the topN users for the application.
6. To export the topN applications traffic report, click Export report.
TopN source addresses
Perform this task to generate the topN source addresses traffic report and export the report.
Table 3 Statistics collection condition configuration items for the topN source addresses traffic report
Item |
Traffic direction |
Time range |
Application category |
Select the application category. |
Application |
Select an application in the designated application category. The device will rank the source IP addresses by the amount of traffic they spent on the application. |
Show Top |
Enter the number of source IP addresses to display. |
3. Click Start.
4. Click a source IP address on the topN source addresses traffic report to view the topN applications accessed by the source IP address.
5. To export the topN source addresses traffic report, click Export report.
TopN destination addresses
Support for this feature depends on the device model.
Perform this task to generate the topN destination addresses traffic report and export the report.
Table 4 Statistics collection condition configuration items for the topN destination addresses traffic report
Item |
Traffic direction |
Time range |
Application |
Select an application in the designated application category. The device will rank the destination IP addresses by the amount of traffic they spent on the application. |
Show Top |
Enter the number of destination IP addresses to display. |
3. Click Start.
4. Click a destination IP address on the topN destination addresses traffic report to go to the TopN applications page to view detailed application traffic.
5. To export the topN destination addresses traffic report, click Export report.
TopN contexts
Perform this task to generate the topN contexts traffic report and export the report.
Table 5 Statistics collection condition configuration items for the topN contexts traffic report
Item |
Traffic direction |
Time range |
Show Top |
Enter the number of contexts to display. |
3. Click Start.
4. To export the topN contexts traffic report, click Export report.
