12-Telemetry Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 66xx-6W10312-Telemetry Command Reference
02-INT commands
02-INT commands 93.18 KB
INT commands
INT and telemetry stream are mutually exclusive on the device. Configure only one of them.
You can enable sampling for only one of the following features on the device:
·     INT.
·     NetStream.
·     IPv6 NetStream.
·     Mirroring.
·     sFlow.
·     Telemetry stream.
·     MOD.
For more information about NetStream, IPv6 NetStream, mirroring, and sFlow, see Network Management and Monitoring Configuration Guide. For more information about telemetry stream and MOD, see Telemetry Configuration Guide.
display telemetry ifa
Use display telemetry ifa to display INT configuration.
# Display INT configuration.
<Sysname> display telemetry ifa
  Telemetry ifa status          : Enabled
  Telemetry ifa packet-drop     : Enabled
  Telemetry ifa device-id       : 10.1.1.10
  Telemetry ifa role:
    Twenty-FiveGigE1/0/3: Transit
  Telemetry ifa loopback:
    Twenty-FiveGigE1/0/4
  Telemetry ifa action:
    GigabitEthernet1/0/2:
      Telemetry ifa 1 acl user-defined 5000 action mirror-to-processor drop
      Telemetry ifa 2 action mirror-to-processor
Telemetry ifa role
INT role:
·     Ingress—Entry node.
·     Transit—Transit node.
·     Egress—Exit node.
Global INT packet dropping: Enabled or Disabled.
Interface on which internal loopback is enabled.
Telemetry ifa collector
Encapsulation parameters for INT packets.
Flexible INT configuration:
·     ifa 1—Action ID.
·     action add-metadata—Action of adding collected data on the transit node.
·     action mirror-to-processor drop—Action of mirroring incoming INT packets to the INT processor and dropping original INT packets on the transit node.
·     local-loopback action add-metadata—Action of adding collected data to incoming INT packets on the entry or exit node.
telemetry ifa acl action add-metadata
telemetry ifa acl action mirror-to-processor drop
telemetry ifa acl local-loopback action add-metadata
telemetry ifa action mirror-to-processor
telemetry ifa collector
telemetry ifa device-id
telemetry ifa role
Use telemetry ifa acl action add-metadata to configure an action of adding collected data to incoming INT packets on the transit node.
Use undo telemetry ifa acl action add-metadata to delete an action.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } action add-metadata
undo telemetry ifa ifa-id
No action is configured.
ifa-id: Specifies an action ID in the range of 1 to 32.
user-defined: Specifies a user-defined ACL.
acl-number: Specifies a user-defined ACL by its number in the range of 5000 to 5999.
name acl-name: Specifies a user-defined ACL by its name, a case-insensitive string of 1 to 63 characters.
This command adds collected data to INT packets matching the specified ACL for calculating the transmission delay of the network.
If the specified ACL does not contain rules, no packets will match the ACL.
If an ACL is used on the entry node to match original packets, the ACL specified in this command must have the same identification attributes plus an attribute to identify the INT flag. The identification attributes and the attribute to identify the INT flag must be in the same rule. For example, the rule in the ACL used on the entry node is rule permit tcp source 10.0.0.3 0, the rule in the ACL specified in this command must be rule permit tcp source 10.0.0.3 0 ifa l5 aaaaaaaabbbbbbbb ffffffffffffffff 0.
This command and the telemetry ifa role command are mutually exclusive on an interface.
You can execute this command multiple times to configure different actions for different traffic types. If you execute this command multiple times with the same ifa-id, the most configuration takes effect.
# Configure an action of adding collected data to incoming INT packets on Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] telemetry ifa 1 acl user-defined 5001 action add-metadata
acl (ACL and QoS Command Reference)
telemetry ifa role
Use telemetry ifa acl action mirror-to-processor drop to configure an action of mirroring incoming INT packets to the INT processor and dropping original INT packets on the exit node.
Use undo telemetry ifa acl action mirror-to-processor drop to delete an action.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } action mirror-to-processor drop
This command mirrors incoming INT packets matching the specified ACL to the INT processor, drops original INT packets, encapsulates the mirrored INT packets, and sends them to the collector.
# Configure an action of mirroring incoming INT packets matching the specified ACL to the INT processor and dropping the original INT packets on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] telemetry ifa 2 acl user-defined 5001 action mirror-to-processor sampler S1 drop
telemetry ifa role
Use telemetry ifa acl local-loopback action add-metadata to configure an action of adding collected data to local loopback traffic on the entry or exit node.
Use undo telemetry ifa to delete an action.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } local-loopback action add-metadata
This command adds collected data to local loopback traffic matching the specified ACL for calculating the transmission delay of the network.
# Configure an action of adding collected data to local loopback traffic on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] telemetry ifa 2 acl user-defined 5001 local-loopback action add-metadata
telemetry ifa role
Use telemetry ifa action mirror-to-processor to configure an action of mirroring incoming packets to the INT processor on the entry or exit node.
Use undo telemetry ifa action mirror-to-processor to delete an action.
telemetry ifa ifa-id [ acl [ mac | user-defined ] { acl-number | name acl-name } ] action mirror-to-processor [ sampler sampler-name ]
acl: Specifies an ACL. If you do not specify this keyword, the command mirrors all packets.
·     mac: Specifies a Layer 2 ACL.
·     user-defined: Specifies a user-defined ACL.
·     acl-number: Specifies an ACL by its number. The following are available value ranges:
¡     2000 to 2999 for basic ACLs.
¡     3000 to 3999 for advanced ACLs.
¡     4000 to 4999 for Layer 2 ACLs.
¡     5000 to 5999 for user-defined ACLs.
·     name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters.
sampler sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command mirrors all packets.
When specifying an ACL by its number, follow these rules:
·     To specify an IPv4 ACL, specify the acl-number argument.
·     To specify a Layer 2 or user-defined ACL, you can specify its ACL number without the mac or user-defined keyword.
When specifying an ACL by its name, follow these rules:
·     To specify an IPv4 ACL, specify the name acl-name option.
·     To specify a Layer 2 or user-defined ACL, you can specify both its ACL name and the related keyword.
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. You can reference a nonexistent sampler and then create the sampler. For more information about sampler, see Network Management and Monitoring Configuration Guide.
# Configure an action of mirroring incoming packets matching the specified ACL to the INT processor on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] telemetry ifa 1 acl 3000 action mirror-to-processor sampler S1
telemetry ifa role
Use telemetry ifa device-id to specify a device ID for an INT node.
Use undo telemetry ifa device-id to restore the default.
telemetry ifa device-id address
An INT node does not have a device ID.
address: Specifies an IPv4 address as the device ID. You can specify any IPv4 address other than 0.0.0.0. As a best practice, specify the loopback address of the device as the device ID.
# Specify IPv4 address 10.1.1.10 as the device ID.
[Sysname] telemetry ifa device-id 10.1.1.10
telemetry ifa role
telemetry ifa global enable
Use telemetry ifa global enable to enable INT globally.
Use undo telemetry ifa global enable to disable INT globally.
INT is enabled globally.
# Enable INT globally.
[Sysname] telemetry ifa global enable
telemetry ifa role
telemetry ifa global packet-drop
Use telemetry ifa global packet-drop to enable global INT packet dropping.
Use undo telemetry ifa global packet-drop to disable global INT packet dropping.
Global INT packet dropping is disabled.
Execute this command if you do not want to send INT packets to the downstream node.
# Enable global INT packet dropping.
[Sysname] telemetry ifa global packet-drop
telemetry ifa loopback
This command is required only on the S6805, S6825, and S9850 series switches.
Use telemetry ifa loopback to enable internal loopback on an interface on the entry node.
Use undo telemetry ifa loopback to disable internal loopback on an interface on the entry node.
Internal loopback is disabled on an interface on the entry node.
Interface view
When you execute the telemetry ifa role ingress (in common INT) or telemetry ifa action mirror-to-processor (in flexible INT) command on an interface, the device prints the port list in the port group to which the interface belongs. You must enable internal loopback on an interface in the port group other than that interface.
After you enable internal loopback on an interface, all settings on the interface are lost, and the interface can be used only for internal loopback.
If you specify multiple interfaces in the port group as ingress interfaces, you may enable internal loopback only on one interface in the port group.
To display port grouping information, you can also execute the display qos-acl resource command. The ports under an Interfaces field belong to the same port group.
# Enable internal loopback on Twenty-FiveGigE1/0/1 on the entry node.
[Sysname-Twenty-FiveGigE1/0/1] telemetry ifa loopback
All configurations on the interface will be lost. Continue?[Y/N]:y
[Sysname–Twenty-FiveGigE1/0/1]
telemetry ifa role
telemetry ifa role
Use telemetry ifa role to specify an INT role for an interface.
Use undo telemetry ifa role to restore the default.
telemetry ifa role { egress | ingress | transit }
An interface does not take any INT role.
egress: Specifies the interface as an egress interface.
ingress: Specifies the interface as an ingress interface.
transit: Specifies the interface as a transit interface.
For common INT, specify the interface on the entry node as the ingress interface. Specify the interface on the transit node as the transit interface. Specify the interface on the exit node as the egress interface.
Interfaces in different roles take different actions on incoming packets.
·     The ingress interface adds a timestamp and encapsulates the packet as an INT packet.
·     The transit interface adds a timestamp for the INT packet.
·     The egress interface adds a timestamp, encapsulates the INT packet according to the specified addressing parameters, and sends it to the collector.
# Specify Twenty-FiveGigE 1/0/1 as the transit interface.
[Sysname-Twenty-FiveGigE1/0/1] telemetry ifa role transit
Use telemetry ifa collector to configure the addressing parameters to encapsulate in INT packets sent to the collector.
Use undo telemetry ifa collector to restore the default.
telemetry ifa collector source source-address destination dest-address source-port port destination-port port [ vlan vlan-id ]
No addressing parameters are configured for INT packets.
source source-address: Specifies the source IP address for INT packets.
destination dest-address: Specifies the destination IP address for INT packets.
source-port port: Specifies the source port number for INT packets.
destination-port port: Specifies the destination port number for INT packets.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
Use this command on the exit node. The exit node uses the addressing parameters to find the outgoing interface for INT packets and sends the packets to the collector.
Do not specify the IP address of the management Ethernet port on the local device for the destination dest-address option.
# Specify source IP address 1.1.1.1, destination IP address 2.2.2.2, source port number 67, and destination port number 68 for INT packets.
[Sysname] telemetry ifa collector source 1.1.1.1 destination 2.2.2.2 source-port 67 destination-port 68
telemetry ifa role
