12-Telemetry Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 66xx-6W10312-Telemetry Command Reference
04-Flow group commands
04-Flow group commands 78.57 KB
Flow group commands
This feature is supported only in Release 6616 and later.
display telemetry flow-group
Use display telemetry flow-group to display the configuration and application status of flow groups.
display telemetry flow-group [ group-id | name group-name ] [ slot slot-number ]
group-id: Specifies a flow group by its ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group by its name, a case-sensitive string of 1 to 63 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the configuration and application status on the master device.
If you do not specify the group-id or name group-name option, this command displays the configuration and application status of all flow groups.
# Display the configuration of flow group 1 and its application status in slot 2.
<Sysname> display telemetry flow-group 1 slot 2
Flow group 1 (Successful)
  ACL       : 2001
  Template  :
    destination-ip
    destination-port
    source-ip
    source-port
    vxlan
      inner-destination-ip
      inner-source-ip
  Mode      : MOD
Aging time: 100 minutes
Rate limit: -
Max-entry : -
Flow group 2 named aaa (Successful)
ID, name, and application status of the flow group. Values for the application status include:
·     Successful—The flow group is applied successfully.
·     Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration.
·     Inactive—The flow group has not been administratively applied.
·     Incomplete—The flow group fails to be applied because its configuration is incomplete.
Rate limit
Maximum rate of packets to the CPU in pps. A hyphen (-) indicates that no rate limit is configured.
Max entry
Maximum number of flow entries generated. A hyphen (-) indicates that no entry limit is configured.
display telemetry flow-group flow-table
Use display telemetry flow-group flow-table to display the flow entries generated by flow groups.
display telemetry flow-group flow-table [ [ group-id | name group-name ] | mod | mice-elephant-flow ] [ destination-ip dst-ip | destination-port dst-port | protocol protocol | source-ip src-ip | source-port src-port | vxlan [ inner-destination-ip dst-ip | inner-destination-port dst-port | inner-protocol protocol | inner-source-ip src-ip | inner-source-port src-port | vxlan-id vxlan-id ] * ] * [ slot slot-number ]
mod: Specifies flow groups in MOD mode and flow groups in simple MOD mode.
mice-elephant-flow: Specifies flow groups in elephant/mice flow mode.
destination-ip dst-ip: Specifies the destination IP address.
destination-port dst-port: Specifies the destination port number.
protocol protocol: Specifies the network layer protocol.
source-ip src-ip: Specifies the source IP address.
source-port src-port: Specifies the source port number.
vxlan: Specifies the VXLAN protocol.
·     inner-destination-ip dst-ip: Specifies the inner destination IP address of VXLAN packets.
·     inner-destination-port dst-port: Specifies the inner destination port number of VXLAN packets.
·     inner-protocol protocol: Specifies the inner network layer protocol.
·     inner-source-ip src-ip: Specifies the inner source IP address.
·     inner-source-port src-port: Specifies the inner source port number.
·     vxlan-id vxlan-id: Specifies the VXLAN ID.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the flow entries on all member devices.
If you do not specify flow groups, this command displays the flow entries generated by each flow group.
If you specify the mice-elephant-flow keyword, this command displays the flow entries generated for elephant flows. For more information about elephant flows and mice flows, see elephant and mice flows distinguishing in ACL and QoS Configuration Guide.
# Display the flow entries generated by flow group 1 for slot 1.
<Sysname> display telemetry flow-group flow-table 1 slot 1
Slot: 1
Flow group 1 (name: abc)
Mode: MOD
Src IP          Dst IP          Pro SPort DPort Aging    Packets
In Src IP       In Dst IP       InP InSP  InDP  VXLAN ID Bytes
192.168.1.86    192.168.10.2    6   20    30    12m10s   10
-               -               -   -     -     -        12400
Mode
Flow group mode:
·     MOD—MOD mode or simple MOD mode.
·     Mice elephant flow—Elephant/mice flow mode.
In Src IP
Inner source IP address of VXLAN packets.
In Dst IP
Inner destination IP address of VXLAN packets.
InP
Inner network layer protocol.
InSP
Inner source port number.
InDP
Inner destination port number.
if-match acl
Use if-match acl to specify an ACL in a flow group.
Use undo if-match acl to remove an ACL from a flow group.
undo if-match acl
No ACL is specified in a flow group.
Flow group view
acl-number: Specifies an IPv4 ACL by its number. The following are available value ranges:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
name acl-name: Specifies the IPv4 ACL name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter.
A flow group takes effect only on the traffic that matches the specified ACL.
Only one ACL can be specified for a flow group.
If you do not specify a VPN instance in the ACL, the ACL applies to both VPN packets and non-VPN packets.
An ACL referenced by a flow group supports only the 5-tuple (source IP address, destination IP address, source port number, destination port number, and protocol) and DSCP priority match items.
# Specify ACL 3000 in flow group 1.
[Sysname] telemetry flow-group 1
[Sysname-telemetry-flow-group-1] if-match acl 3000
acl (ACL and QoS Command Reference)
telemetry apply flow-group
Use telemetry apply flow-group to apply a flow group.
Use undo telemetry apply flow-group to remove the application of a flow group.
telemetry apply flow-group { group-id | name group-name }
undo telemetry apply flow-group { group-id | name group-name }
No flow group is applied.
Only one flow group can be applied.
For a flow group in MOD mode or elephant/mice flow mode to work correctly, you must set the hardware resource operating mode to EM by using the hardware-resource switch-mode command (see device management commands in Fundamentals Command Reference).
# Apply flow group 1.
[Sysname] telemetry apply flow-group 1
Use telemetry flow-group to create a flow group and enter its view, or enter the view of an existing flow group.
Use undo telemetry flow-group to delete a flow group.
telemetry flow-group group-id [ name group-name ] [ mode { mice-elephant-flow | simple-mod } ]
undo telemetry flow-group { group-id | name group-name }
No flow groups exist.
group-id: Specifies a flow group ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group name, a case-sensitive string of 1 to 63 characters. The name must be globally unique and cannot start with system-defined-.
mode: Specifies a flow group mode. The default is MOD mode.
·     mice-elephant-flow: Specifies the elephant/mice flow mode.
·     simple-mod: Specifies the simple MOD mode.
The flow entries generated by a flow group can be used by other features. A flow group can be in one of the following modes:
·     MOD mode—Used by MOD. This mode occupies hardware resources but has a lower burden on the CPU.
·     Simple MOD mode—Used by MOD. This mode has a higher burden on the CPU but saves hardware resources.
·     Elephant/mice flow mode—Used by the elephant and mice flows distinguishing feature.
You cannot name or rename an existing flow group and cannot modify the mode of an existing flow group.
To delete an applied flow group, first remove the application and then delete the flow group.
# Create flow group 1 in MOD mode and enter its view.
# Create flow group 2 in simple MOD mode and enter its view.
[Sysname] telemetry flow-group 2 mode mice-elephant-flow
[Sysname-telemetry-flow-group-2]
# Create flow group 3 in elephant/mice flow MOD mode and enter its view.
[Sysname] telemetry flow-group 3 mode simple-mod
[Sysname-telemetry-flow-group-3]
telemetry flow-group aging-time
Use telemetry flow-group aging-time to set the aging time for flow entries.
Use undo telemetry flow-group aging-time to restore the default.
telemetry flow-group aging-time aging-time
The aging time for flow entries is 15 minutes.
aging-time: Specifies the aging time for flow entries in minutes. The value range for this argument is 1 to 16.
# Set the aging time for flow entries to 20 minutes.
[Sysname] telemetry flow-group aging-time 20
telemetry flow-group max-entry
Use telemetry flow-group max-entry to set the maximum number of flow entries generated.
Use undo telemetry flow-group max-entry to restore the default.
telemetry flow-group max-entry max-entries
By default, the number of flow entries is not limited.
max-entries: Specifies the maximum number of flow entries generated. The value range for this argument is 1 to 8192.
When the maximum number of flow entries is reached, the device does not generate new flow entries until old flow entries are aged out.
# Set the maximum number of flow entries generated to 100.
[Sysname] telemetry flow-group max-entry 100
telemetry flow-group rate-limit
Use telemetry flow-group rate-limit to set the aging time for flow entries.
Use undo telemetry flow-group rate-limit to restore the default.
telemetry flow-group rate-limit pps
By default, the rate of packets sent to the CPU is not limited.
pps: Specifies the maximum rate of packets sent to the CPU to limit the flow entry generation rate. The value range for this argument is 1 to 1024.
# Set the maximum rate of packets sent to the CPU to 100 pps.
[Sysname] telemetry flow-group rate-limit 100
template
Use template to configure a flow entry generation rule.
Use undo template to delete a flow entry generation rule.
template { destination-ip | destination-port | protocol | source-ip | source-port | vxlan { inner-destination-ip | inner-destination-port | inner-protocol | inner-source-ip | inner-source-port | vxlan-id } * } *
undo template
No flow entry generation rule is configured.
destination-ip: Generates flow entries based on the destination IP address.
destination-port: Generates flow entries based on the destination port number.
protocol: Generates flow entries based on the Layer 3 protocol type.
source-ip: Generates flow entries based on the source IP address.
source-port: Generates flow entries based on the source port number.
vxlan: Generates flow entries for VXLAN packets.
·     inner-destination-ip: Generates flow entries based on the inner destination IP address.
·     inner-destination-port: Generates flow entries based on the inner destination port number.
·     inner-protocol: Generates flow entries based on the inner Layer 3 protocol type.
·     inner-source-ip: Generates flow entries based on the inner source IP address.
·     inner-source-port: Generates flow entries based on the inner source port number.
·     vxlan-id: Generates flow entries based on the VXLAN ID.
This command enables the device to identify traffic and generate flow entries based on the specified header fields.
# Configure flow group 1 to generated flow entries based on the source IP address, destination IP address, source port number, and destination port number.
[Sysname-telemetry-flow-group-1] template destination-ip destination-port source-ip source-port
