H3C SR6604 & SR6608 Routers Installation Guide-6W128
HomeSupportResource CenterRoutersSR6600 SeriesSR6600 SeriesTechnical DocumentsInstall & UpgradeInstallation GuidesH3C SR6604 & SR6608 Routers Installation Guide-6W128
Table of Contents
Related Documents
01-Text
01-Text 20.19 MB
Preparing for installation· 1
Safety recommendations· 1
Safety symbols· 1
General safety recommendations· 1
Electricity safety· 1
Laser safety· 2
Router moving· 2
Examining the installation site· 2
Temperature and humidity· 2
Altitude· 3
Cleanliness· 3
Cooling system·· 3
ESD prevention· 4
EMI 5
Lightning protection· 5
Space· 6
Power supply· 7
Installation accessories· 7
Pre-instalation checklist 7
Installing the router 9
Check before installation· 9
Installing the router in a 19-inch rack· 10
Attaching cage nuts to the rack· 10
Installing the cable management brackets· 11
Attaching the mounting brackets to the router 12
Installing the router in the rack· 12
Grounding the router 13
Installing an MPU· 14
Installing an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU· 14
Installing an RSE-X1 MPU· 16
Installing an MCP MPU· 17
Installing an SSD drive· 18
Installing a FIP module and an air deflector 20
Installing a FIP module· 20
(Optional) Installing an air deflector 21
Installing a SAP/OAP/switching fabric module· 21
Installing a HIM/MIM/MIC/MIC-X interface module· 22
Assembling a MIC-X adapter module and MIC interface module into a MIC-X interface module· 22
Installing an interface module· 24
Installing a fan tray· 25
Installing a CF card· 26
Installing a power module· 26
Connecting a power cord· 27
Connecting an AC power cord· 27
Connecting a DC power cord· 27
Installing FRUs· 30
Installing an air filter 30
Installing a fiber management tray· 31
Installing a lightning protector for a network port 32
Connecting the AC power supply to a power strip with lightning protection· 33
Installing a surge protector (optional) 34
Connecting interface cables· 36
Connecting the AUX cable· 36
Overview· 36
Connecting an Ethernet cable· 37
Overview· 37
Making an Ethernet cable· 39
Connecting an Ethernet cable· 39
Connecting a fiber cable· 39
Transceiver modules· 39
Fiber cables· 40
Connecting a fiber cable· 42
Connecting an E1/T1 cable· 44
E1/T1 cable overview· 44
Connecting an E1/T1 cable· 45
Connecting a CE3/CT3/T3 cable· 47
CE3/CT3/T3 cable overview· 47
Connecting a serial port cable· 48
Overview· 48
Connecting a serial port cable· 50
Accessing the router 51
Login methods· 51
Accessing the router from the console port 51
Connecting the router to a configuration terminal 51
Using a console cable to connect the router to a configuration terminal 51
Setting terminal parameters· 54
Powering on the router 54
Checking before power-on· 54
Checking after power-on· 55
Displaying boot information· 55
Logging in to the router through Telnet 56
Configuring basic settings· 56
Hardware management and maintenance· 58
Displaying hardware information of the router 58
Displaying the software and hardware version information of the router 58
Displaying the operational statistics of the router 58
Displaying detailed information about a module· 59
Displaying the electrical label information of a module· 59
Displaying the CPU usage of a module· 60
Displaying the memory usage of a module· 61
Displaying the CF card information· 61
Displaying the operational status of the fan· 62
Displaying the operational status of power modules· 62
Displaying the alarming thresholds of a module· 62
Port configuration and management 63
Configuring a combo interface· 63
Displaying transceiver module information and alarming information· 64
Saving the current configuration of the router 65
Rebooting a module or router 65
Replacement procedures· 67
Safety recommendations· 67
Replacing a power module· 67
Replacing an MPU· 68
Prerequisites· 68
Replacing an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU· 68
Replacing an RSE-X1 MPU· 69
Replacing an MCP· 69
Replacing a FIP module· 70
Replacing an SSD drive· 71
Replacing a SAP/OAP/switching fabric module· 71
Replacing a HIM/MIM/MIC/MIC-X· 72
Replacing a CF card· 73
Replacing a transceiver module· 74
Replacing a fan tray· 75
Replacing an air filter 75
Replacing a memory module· 76
When to replace a memory module· 76
Memory module structure· 77
Memory module slot 78
Replacing a memory module· 78
Troubleshooting· 80
MPU failures· 80
RUN LED is off 80
RUN LED fast flashes· 80
ALM LED is steady on or flashes· 80
FIP module failures· 81
RUN LED is off 81
RUN LED fast flashes· 81
Power module failures· 81
Power LED is off 81
Red power LED is on· 82
Fan failures· 82
Fan tray is absent 82
ALM LED is red· 82
HIM/MIM/MIC/MIC-X failures· 83
Configuration system issues· 83
No terminal display· 83
Garbled terminal display· 84
No response from the serial port 84
Dealing with console login password loss· 84
Examining the state of password recovery capability· 85
Skipping current system configuration· 86
Skipping authentication for console login· 87
Restoring to factory default configuration· 88
Cooling system failure· 89
Interface module, cable, and connection failure· 89
Software upgrade failures· 90
No response from the serial port of the MPU· 90
TFTP upgrade failure· 90
FTP upgrade failure· 91
System software image file missing errors· 91
Appendix A Chassis views and technical specifications· 92
Chassis views· 92
SR6604· 92
SR6608· 94
Dimensions and weights· 99
Power consumption· 100
Power modules· 101
AC power modules· 102
DC power modules· 103
Fan trays· 104
MPUs· 105
RPE-X1· 105
RPE-X3· 106
RPE-X5· 107
RPE-X5E· 108
RSE-X1· 109
MCP-X1/MCP-X2· 110
Components· 111
Switching fabric modules· 115
SFE-L1· 116
SFE-L2· 116
Flexible interface platform modules· 117
FIP-10· 117
FIP-20· 118
FIP-110· 119
FIP-210· 120
FIP-240· 122
FIP-260· 123
FIP-300· 123
FIP-310· 124
FIP-380· 126
FIP-600· 127
FIP-660· 128
FIP-680· 129
Service aggregation platform modules· 131
SAP-48GBE· 131
SAP-24GBP· 132
SAP-48GBP· 133
SAP-20GE2XP· 135
SAP-28GE· 136
SAP-XP4GE32· 137
Transceiver modules· 139
Lightning protector for a port 139
Power strip with lightning protection· 139
Surge lightning protector 139
Appendix B Hardware compatibility matrixes· 140
MPU and Comware compatibility matrix· 140
Service module and MPU compatibility matrix· 140
Interface module and Comware compatibility matrix· 141
Appendix C LEDs· 142
MPU LEDs· 143
Switching fabric module LEDs· 153
FIP LEDs· 153
SAP LEDs· 159
HIM/MIM/MIC/MIC-X LEDs· 164
Power module LEDs· 165
Fan tray LEDs· 166
Appendix D Arranging slots and numbering interfaces· 167
Slot arrangement 167
Slot arrangement for MPUs, switching fabric modules, and service modules· 169
Numbering interfaces· 169
Examples· 170
Example 1· 170
Example 2· 170
Table 1 shows the model and product code matrix for the H3C SR6604 and SR6608 routers.
Table 1 Router model and product code matrix
Model (on the front panel)
Product code
H3C SR6604
RT-SR6604-Chassis-H3
H3C SR6608
RT-SR6608-Chassis-H3
RT-SR6608-DS-H3
To avoid any equipment damage or bodily injury caused by improper use, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
Safety symbols
When reading this document, note the following symbols:
WARNING WARNING means an alert that calls attention to important information that if not understood or followed can result in personal injury.
CAUTION CAUTION means an alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software.
·     Keep the chassis and installation tools away from walk areas.
·     Make sure the ground is dry and flat and anti-slip measures are in place.
·     Unplug all the external cables (including power cords) before moving the chassis.
Electricity safety
·     Locate the emergency power-off switch in the room before installation. Shut the power off at once in case accident occurs.
·     Make sure the router has been reliably grounded.
·     Do not open or close the chassis cover when the router is powered on.
·     Use an uninterrupted power supply (UPS).
·     If there are two power inputs, disconnect the two power inputs to power off the router.
·     Do not work alone when the router has power.
·     Always verify that the power has been disconnected.
Laser safety
WARNING
WARNING!
·     The router is a Class 1 laser device.
·     Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the router is operating.
Router moving
CAUTION
CAUTION:
Do not hold the handle of the fan tray or power module, the handle on the rear cover of the chassis, or the air vents of chassis to move the router. Doing so might cause equipment damage or even bodily injury.
When moving the router, follow these guidelines:
·     When moving the router, hold the handles at both sides of the chassis.
·     Use at least two people to move the router.
·     Move the router carefully.
The router can only be used indoors. To make sure the router operates correctly and to prolong its service lifetime, the installation site must meet the following requirements:
·     Temperature and humidity
·     Cleanliness
·     EMI
Maintain temperature and humidity in the equipment room in an acceptable range.
·     Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
·     Lasting low relative humidity can cause washer contraction and ESD and bring problems including loose screws and circuit failure.
·     High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the router.
For the temperature and humidity requirements of the router, see Table 2 and Table 3.
Table 2 Temperature requirements
Item
Temperature
Operating temperature
0°C to 45°C (32°F to 113°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Table 3 Humidity requirements
Item
Humidity
Operating humidity (noncondensing)
10% RH to 95% RH
Storage humidity (noncondensing)
5% RH to 95% RH
Altitude
Table 4 Altitude requirements
Item
Altitude
Operating altitude
–60 m to +4000 m (–196.85 to +13123.36 ft)
Storage altitude
–60 m to +4500 m (–196.85 to +14763.78 ft)
Cleanliness
Dust buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points, especially when indoor relative humidity is low. In the worst case, electrostatic adsorption can cause communication failure.
Table 5 Dust concentration limit in the equipment room
Substance
Concentration limit (particles/m3)
Dust particles
≤ 3 x 104
(No visible dust on desk in three days)
Dust particle diameter ≥ 5 µm
The equipment room must also meet strict limits on salts, acids, and sulfides to eliminate corrosion and premature aging of components, as shown in Table 6.
Table 6 Harmful gas limits in the equipment room
Gas
Max. (mg/m3)
SO2
0.2
H2S
0.006
NH3
0.05
Cl2
0.01
NO2
0.04
Cooling system
The router uses left to right airflow for heat dissipation.
To ensure good ventilation, the following requirements must be met:
·     Leave a minimum clearance of 100 mm (3.94 in) at the inlet and outlet air vents.
·     The installation site has a good cooling system.
Figure 1 Airflow
ESD prevention
CAUTION
CAUTION:
Make sure the resistance reading between human body and the ground is in the range of 1 to 10 megohms (Mohms).
To prevent electrostatic discharge (ESD), note the following guidelines:
·     Make sure the router and the floor are reliably grounded.
·     Take dust-proof measures for the equipment room.
·     Maintain the humidity and temperature in the acceptable range.
·     Always wear an ESD wrist strap when touching a circuit board or transceiver module.
·     Place the removed memory module, CF card, or interface module on an antistatic workbench, with the face upward, or put it into an antistatic bag.
·     Touch only the edges, instead of electronic components when observing or moving a removed memory module, CF card, or interface module.
To attach the ESD wrist strap:
1.     Wear the wrist strap on your wrist.
2.     Lock the wrist strap tight around your wrist to keep good contact with the skin.
3.     Insert the ESD wrist strap into the specially designed hole on the router chassis or attach it to the grounding screw of the chassis with the alligator clips.
4.     Make sure the rack is reliably grounded.
Figure 2 Attaching an ESD wrist strap
(1) ESD wrist strap
(2) Lock
(3) Alligator clip
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the router and application system, adversely affect the router in the following ways:
·     A conduction pattern of capacitance coupling.
·     Inductance coupling.
·     Electromagnetic wave radiation.
·     Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
·     If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid.
·     Keep the router far away from radio transmitting stations, radar stations, and high-frequency devices.
·     Use electromagnetic shielding, for example, shielded interface cables, when necessary.
To protect the router from lightning, perform the following tasks:
·     Make sure the grounding cable of the chassis is reliably grounded.
·     Make sure the grounding terminal of the AC power receptacle is reliably grounded.
·     Connect the AC power supply to a power strip with lightning protection to enhance the lightning protection capability of the power supply.
·     Install a surge protector at the input end of outdoor signal lines (for example, E1/T1 line) to which interface modules of the router are connected to enhance the lightning protection capability.
For how to install a lightning protector and surge protector, see "Connecting the AC power supply to a power strip with lightning protection" and "Installing a surge protector (optional)."
Space
For easy installation and maintenance, follow these space requirements:
·     Reserve a minimum of 1 m (3.28 ft) of clearance between the rack and walls or other devices.
·     For heat dissipation, make sure the headroom in the equipment room is not less than 3 m (9.84 ft).
·     Make sure the rack has enough space to accommodate the router. See Table 7 for rack requirements. For more information about chassis dimensions, see "Appendix A Chassis views and technical specifications."
Table 7 Router dimensions and rack requirements
Model
Chassis dimensions
Rack requirements
SR6604 AC
SR6604 DC
·     Height—220 mm (8.66 in)/5 RU
·     Width—436 mm (17.17 in)
·     Depth—576 mm (22.68 in)
¡ 480 mm (18.90 in) for the chassis
¡ 95 mm (3.74 in) for the cable management brackets at the chassis front
¡ 11 mm (0.43 in) for the grounding screw at the chassis rear
·     A minimum of 0.8 m (2.62 ft) in depth (recommended)
·     A minimum of 95 mm (3.74 in) between the front rack posts and the front door
·     A minimum of 481 mm (18.94 in) between the front rack posts and the rear door
SR6608 AC
SR6608 DC
·     Height—308 mm (12.13 in)/7 RU
SR6608-DS
The signal cables and power cords are routed through the front of the chassis. If you use power cords that has a conductor cross-section area of a minimum of 16 sq mm (0.02 sq in), leave more space between the front rack posts and the front door as appropriate.
Power supply
·     Make sure the power supply system at the installation site is stable and meets the requirements of the power modules, including the rated input voltage.
·     Select power modules based on the power consumption of the cards and fan trays. For more information about system power consumption and technical specifications of power modules, see "Power consumption" and "Power modules."
Table 8 Installation accessories
Console cable
Grounding cable
ESD wrist strap
Cable tie
Mounting brackets
M6 screws (provided with the SR6608-DS and user-supplied for other router models)
Cage nuts (provided with the SR6608-DS and user-supplied for other router models)
Table 9 Pre-instalation checklist
Item
Requirements
Result
Installation site
Ventilation
·     There is a minimum clearance of 100 mm (3.94 in) around the inlet and outlet vents for heat dissipation of the router chassis.
·     A ventilation system is available at the installation site.
Temperature
0°C to 45°C (32°F to 113°F).
Relative humidity
10% to 95% (noncondensing).
Cleanliness
·     Dust concentration ≤ 3 × 104 particles/m3.
·     No dust on desk within three days.
ESD prevention
·     The equipment and floor are reliably grounded.
·     The equipment room is dust-proof.
·     The humidity and temperature are in the acceptable range.
·     Wear an ESD wrist strap and uniform when touching a circuit board.
·     Place the removed memory module, CF card, or HIM/MIM/MIC/MIC-X on an antistatic workbench, with the face upward, or put it into an antistatic bag.
·     Touch only the edges, instead of electronic components when observing or moving a removed memory module, CF card, or HIM/MIM/MIC/MIC-X.
EMI prevention
·     Take effective measures to protect the power system from the power grid system.
·     Separate the protection ground of the router from the grounding device or lightning protection grounding device as far as possible.
·     Keep the router far away from radio stations, radar and high-frequency devices operating in high current.
·     Use electromagnetic shielding when necessary.
·     The grounding cable of the chassis is reliably grounded.
·     The grounding terminal of the AC power receptacle is reliably grounded.
·     A port lightning arrester is installed. (Optional)
·     A power lightning arrester is installed. (Optional)
·     A signal lightning arrester is installed at the input end of an external signal cable. (Optional)
Electricity safety
·     Equip an uninterrupted power supply (UPS).
·     In case of emergency during operation, switch off the external power switch.
Rack-mounting requirements
·     Install the router in an open rack if possible. If you install the router in a closed cabinet, make sure the cabinet is equipped with a good ventilation system.
·     The rack is sturdy enough to support the weight of the router and installation accessories.
·     The size of the rack is appropriate for the router.
·     The front and rear of the rack are a minimum of 0.8 m (31.50 in) away from walls or other devices.
Safety precautions
·     The router is far away from any moist areas and heat sources.
·     The emergency power switch in the equipment room is located.
Tools
·     Installation accessories supplied with the router.
·     User supplied tools.
Reference
·     Documents shipped with the router.
·     Online documents.
IMPORTANT
IMPORTANT:
Keep the packages of your router and its accessories safely for future use.
Figure 3 Router installation flow
To prepare for installing the router:
·     Make sure you have read "Preparing for installation" carefully and the installation site meets all the requirements.
·     Prepare a 19-inch rack. For more information about how to install a rack, see the installation guide provided with the rack.
·     Make sure the rack is sturdy and securely grounded.
·     Make sure there is sufficient clearance around the rack for heat dissipation and installation.
·     Make sure there is no debris inside or around the rack.
·     Move the router to a place near the rack.
IMPORTANT
IMPORTANT:
·     To mount multiple devices in a rack, install the heavier equipment at the lower half of the rack.
·     The SR6608 router is heavy. For rack stability, install it at a lowest possible position.
This section uses an SR6604 as an example.
1.     Determine where to install the router in the rack, and then install a rack shelf on the rack.
2.     As shown in Figure 4, mark the positions of cage nuts on the front rack posts by using a front mounting bracket.
Figure 4 Marking the positions of the cage nuts
3.     As shown in Figure 5, attach the cage nuts to the marked positions on the rack posts.
Figure 5 Installing cage nuts
As shown in Figure 6, attach the cable management bracket to the left mounting bracket with screws before attaching it to the router.
The SR6608-DS router is shipped with the cable management bracket attached to the left mounting bracket. You do not need to install the cable management bracket separately for the SR6608-DS router.
Figure 6 Installing the cable management bracket
(1) Left mounting bracket
(2) Cable management bracket
Before installing the router in a rack, attach the front mounting brackets to the two sides of the router.
To attach the front mounting brackets to the router, align the screw holes on the mounting brackets with the screw holes on the router chassis, and then fasten the screws.
Figure 7 Attaching the front mounting brackets to the two sides of the router
1.     Put the router on the rack shelf, and slide the router, making sure there is enough clearance between the router and rack posts for installing the mounting brackets.
2.     Attach the router horizontally by fastening the mounting brackets to the rack with appropriate pan head screws. The specifications of pan head screws must satisfy the installation requirements, and rustproof treatment has been made to their surfaces.
Figure 8 Attaching the router to the rack
WARNING
WARNING!
Correctly connecting the router grounding cable is crucial to lightning protection and EMI protection.
To connect the grounding cable:
1.     Remove the grounding screws from the grounding terminal on the rear panel of the router chassis.
2.     Use the grounding screws to attach the lug of the grounding cable to the grounding terminal and fasten the screws.
3.     Connect the other end of the grounding cable to the grounding strip of the rack.
Figure 9 Connecting the grounding cable to the grounding hole of router
·     Make sure the resistance reading between router chassis and the ground is smaller than 5 ohms.
·     To guarantee the grounding effect, use the grounding cable provided with the router to connect to the grounding strip in the equipment room as long as possible.
Installing an MPU
CAUTION
CAUTION:
·     To avoid system failure, make sure the software versions of the active MPU and standby MPU are the same.
¡     For a version lower than R7103, the system checks the software versions of the active MPU and standby MPU (if any). If they are inconsistent, the standby MPU will not start. You can use the ha slave-ignore-version-check command to force the system to ignore version check of the standby MPU.
¡     For R7103 and higher versions, the standby MPU (if any) automatically synchronizes the software version from the active MPU to ensure that they are the same version.
·     When the router is installed with two MPUs, the standby MPU is hot swappable. When the router is installed with one MPU, the MPU is not hot swappable.
·     To avoid hardware damage, do not hot swap a FIP or SAP/OAP during the booting process of an MPU (with the RUN LED fast flashing).
Before installing an RPE-X1, RPE-X3, RPE-X5, or RPE-X5E MPU, install a compatible carrier in the MPU slot. The RPE-X1 MPU supports the BKEB carrier, the RPE-X3 MPU supports the BKEC carrier, and the RPE-X5/RPE-X5E MPU supports the BKED carrier. For the carrier model, see the barcode on the carrier.
The installation procedures for the RPE-X1, RPE-X3, RPE-X5, and RPE-X5E are the same. This example uses an RPE-X1.
To install an RPE-X1:
1.     Locate the slot to install the RPE-X1.
The RPE-X1 can be installed in slot 0 or slot 1. This procedure uses slot 1 as an example.
2.     Gently push the RPE-X1 carrier (with the components facing up) into slot 1 along the slide rails until the positioning pins on the backplane are seated in the positioning holes at the bottom of the RPE-X1 carrier. Then push the ejector levers inward to lock the RPE-X1 carrier in position and fasten the captive screws on the ejector levers.
Figure 10 Internal structure of the RPE-X1 carrier
Figure 11 Installing the RPE-X1 carrier
3.     Use even pressure to gently push the RPE-X1 into slot 1 along the slide rails, and then push the ejector levers inward to lock the board in position.
Figure 12 Inserting the RPE-X1 into the slot
4.     Fasten the captive screws on the RPE-X1.
5.     Observe the RUN LED on the RPE-X1 to verify that the RPE-X1 is installed correctly.
After the router is powered on, the RUN LED on the RPE-X1 flashes green at 8 Hz until the application software is loaded. When the RUN LED flashes green at 1 Hz, the RPE-X1 is operating correctly.
When two RPE-X1 or RPE-X3 MPUs are installed on the router, the ACT LED on the active MPU is steady green. For the MPU LED descriptions, see "MPU LEDs."
1.     Locate the slot to install the RSE-X1.
You can install an RSE-X1 in slot 1 or slot 2. This procedure uses slot 1 as an example.
2.     Loosen the captive screws on the filler panel in slot 1, and then remove the filler panel.
3.     Use even pressure to gently push the RSE-X1 into slot 1 along the slide rails, and then push the ejector levers inward to lock the RSE-X1 in position.
Figure 13 Inserting the RSE-X1 into the slot
4.     Fasten the captive screws on the RSE-X1.
5.     Observe the RUN LED on the RSE-X1 to verify that the RSE-X1 is installed correctly.
After the router is powered on, the RUN LED on the RSE-X1 flashes green at 8 Hz until the application software is loaded. When the RUN LED flashes green at 1 Hz, the RSE-X1 is operating correctly.
When two RSE-X1 MPUs are installed on the router, the ACT LED on the active MPU is steady green. For the MPU LED descriptions, see "MPU LEDs."
You can install an MCP in slot 1 or slot 2. The installation procedure is similar for MCPs. The following procedure uses installing an MCP-X1 in slot 1 as an example.
An MCP MPU supports only FIP-10 and FIP-20 modules.
To install an MCP:
1.     Loosen the captive screws on the filler panel in the slot, and then remove the filler panel.
2.     Use even pressure to gently push the MCP into slot 1 along the slide rails until positioning pins on the backplane are seated in the positioning holes, and then push the ejector levers inward to lock the MCP in position.
Figure 14 Inserting the MCP into the slot
3.     Fasten the captive screws on the MCP.
4.     Observe the RUN LEDs on the MCP to verify that the MCP is installed correctly.
After the router is powered on, the RUN LED on the MCP flashes green at 8 Hz until the application software is loaded. When the RUN LED flashes green at 1 Hz, the MCP is operating correctly.
When two MCP MPUs are installed on the router, the ACT LED on the active MPU is steady green. For the MPU LED descriptions, see "MPU LEDs."
Only the FIP-260, FIP-380, and SAP-XP4GE32 modules support mSATA SSD drives. The FIP-260, FIP-380, and SAP-XP4GE32 modules do not support SSD drives with SSC enabled. No SSD drive or screws are provided with the router. As a best practice, purchase an SSD drive and screws from H3C as needed.
To install an SSD drive:
1.     Locate the SSD drive slot on the service module.
Figure 15 FIP-260
(1) Front panel
(2) SSD drive slot
2.     Align the golden plating on the SSD drive with the mSATA connector in the slot.
3.     Slightly press the SSD drive until it is level with the surface of the connector.
4.     Use a Phillips screwdriver to screw the SSD drive into place.
Figure 16 Installing an SSD drive
IMPORTANT
IMPORTANT:
FIP-10 and FIP-20 can operate correctly only on a router installed with an MCP.
The router supports hot swapping of FIP modules.
The installation procedure is similar for FIPs. The following procedure installs a FIP-210.
To install a FIP module:
1.     Locate the slot to install the FIP module.
2.     Loosen the captive screws on the filler panel, and then remove the filler panel.
3.     Use even pressure to gently push the FIP module into the slot along the slide rails until positioning pins on the backplane are seated in the positioning holes, and then push the ejector levers inward to lock the FIP module in position.
If you encounter a resistance when pushing a FIP module into slot, remove the filler panels from the left and right slots and then install the FIP module. After the FIP module is installed, reinstall the removed filler panels to prevent dust from entering the chassis.
Figure 17 Inserting a FIP module
4.     Fasten the captive screws on the FIP module.
5.     Observe the RUN LED on the FIP to verify that the FIP module is installed correctly.
After the router is powered on, the RUN LED on the FIP flashes green once and then fast flashes (at 8 Hz) until the application software is loaded. When the RUN LED flashes green at 1 Hz, the FIP is operating correctly.
For the FIP LED descriptions, see "FIP LEDs."
For a FIP-660, if a service module slot adjacent to the FIP-660 is empty, install an air deflector over the slot.
To install an air deflector:
1.     Locate the service module slot to install the air deflector.
3.     Gently push the air deflector into the service slot along the slide rails until it snaps into place.
4.     Fasten the captive screws on the air deflector.
Figure 18 Installing an air deflector
The router supports hot swapping of SAPs, OAPs, and switching fabric modules.
The installation procedure is similar for SAPs, OAPs, and switching fabric modules. The following procedure installs a SAP module.
To install a SAP module:
1.     Locate the slot to install the SAP module.
3.     Use even pressure to gently push the SAP module into the slot along the slide rails until positioning pins on the backplane are seated in the positioning holes, and then push the ejector levers inward to lock the SAP module in position.
Figure 19 Inserting a SAP module
4.     Fasten the captive screws on the SAP module.
5.     Observe the RUN LED on the SAP to verify that the SAP module is installed correctly.
After the router is powered on, the RUN LED on the SAP flashes green once and then fast flashes (at 8 Hz) until the application software is loaded. When the RUN LED flashes green at 1 Hz, the SAP is operating correctly.
For the SAP LED descriptions, see "SAP LEDs."
CAUTION
CAUTION:
·     MIM interface modules are not hot swappable. MIC interface modules are hot swappable.
·     All MIC-X interface modules except the MIC-X-CNDE-SJK are hot swappable. To remove a MIC-X-CNDE-SJK interface module when the router is operating, press the REMOVE button on the interface module until its RUN LED turns off.
·     To remove a HIM interface module when the router is operating, first execute the remove command for the interface module.
·     To avoid hardware damage, when the RUN LED on a FIP module is fast flashing green, do not install or remove a HIM/MIM/MIC/MIC-X module on it.
IMPORTANT
IMPORTANT:
A MIC-X-ET16-compatible FIP module supports only one MIC-X-ET16 assembled by a MIC-X adapter module and a MIC-ET16L interface module.
MIC-X adapter module components
Figure 20 Screw
Figure 21 Carrier
Figure 22 Front panel
1.     Use a screwdriver to remove the four screws from the MIC interface module circuit board so that the front panel and the gasket are disengaged from the circuit board.
2.     Align the MIC interface module circuit board with the guide rails on the MIC-X adapter module carrier. Gently push the circuit board into the carrier along the guide rails until the circuit board makes close contact with the connectors on the MIC-X adapter module carrier.
3.     Install M3 screws provided with the MIC-X adapter module carrier into the two screw holes at the center of MIC interface module circuit board and fasten the screws.
4.     Select the front panel matching the MIC interface module, align the front panel with the ports on the circuit board, and use M3 screws to attach the front panel to the circuit board.
The MIC-CLP2L, MIC-CLP4L, MIC-SP4L, MIC-SP8L, MIC-ET16L interface modules can be assembled into corresponding MIC-X modules by using MIC-X adapter modules.
Figure 23 Assembling a MIC-X adapter module and a MIC interface module into a MIC-X interface module
The installation procedure is the same for HIM, MIM, MIC, and MIC-X interface modules.
To install a HIM/MIM/MIC/MIC-X interface module:
1.     Locate the slot to install the target module on the FIP module.
Keep the filler panel safe for future use.
3.     Use even pressure to push the module slowly along the slide rails into the slot, and then close the levers.
Install a HIM/MIM/MIC-X with the components upward and install an MIC with the components downward.
Figure 24 Pushing the module into the slot
4.     Fasten the captive screws on the module.
5.     Observe the LED for the slot on the router front panel to verify that the module is installed correctly.
If the LED is on after the module initialization completes, the module has been installed correctly and is operating correctly. If the LED is off, the module has failed the POST.
The fan tray is hot swappable and the fans can automatically adjust the speed.
To install a fan tray:
1.     Examine the warning sign on the fan tray to ensure the correct direction of the fan tray. Otherwise, the fan tray cannot be inserted into the slot.
2.     Gently push the fan tray slowly along the slide rails into the slot.
Figure 25 Pushing the fan tray into the slot
3.     Fasten the captive screws on the fan tray.
4.     Power on the router and check the status LED on the front panel.
On means the fan tray is operating correctly. Off means the fan tray has failed the POST. For the LED description of the fan tray, see "Appendix C LEDs."
To install a CF card on an MCP, remove the CF card cover first.
To install a CF card:
1.     Push the CF card eject button all the way into the slot, and make sure the button does not project from the panel.
2.     Insert the CF card into the slot following the direction shown in Figure 26, and make sure it does not project from the slot.
Figure 26 Inserting the CF card into the slot
The procedures for installing an AC power module and DC power module are the same. The following uses a PSR650-A AC power module as an example.
1.     Locate the slot to install the power module. Use even pressure to gently push the power module slowly along the slide rails into the slot.
Figure 27 Inserting the power module into the slot
2.     Fasten the captive screws on the power module.
3.     After connecting the power cord, power on the power module.
If the power module LED is green, the power module operates correctly. If the LED is red, the power module has failed.
1.     Make sure the power is OFF.
2.     Make sure the router is reliably grounded.
3.     Connect one end of the AC power cord to the AC receptacle on the router, and the other end to the AC power source.
4.     Fix the power cord to the power module handle by using a cable tie.
Figure 28 Connecting an AC power cord to the router
Connecting the power cord for the PSR650-D
WARNING
WARNING!
Identify the label on the DC power cord when connecting a DC power cord to avoid connection mistakes.
Figure 29 DC power cord
To connect the DC power cord:
2.     Remove the protection cover of the DC power module.
3.     Remove the screws from the terminals on the power module.
4.     Connect the end marked with "–" to the negative terminal (–) on the power module and fasten the screw.
5.     Connect the end marked with "+" to the positive terminal (+) on the power module and fasten the screw.
6.     Connect the other end of the DC power cord to the DC power source.
7.     Install the protection cover of the DC power module.
Figure 30 Connecting the DC power cord
Connecting the power cord for the PSR1200-D
Figure 31 DC power cord
1.     Loosen the captive screws on the power module to remove the power module connector.
2.     Connect the end marked with "–" to the negative terminal (–) on the power module and fasten the screw.
3.     Connect the end marked with "+" to the positive terminal (+) on the power module and fasten the screw.
Figure 32 Attaching the power cords to the power module connector
4.     Insert the power module connector in right direction into the power module, and fasten the captive screws.
Figure 33 Installing the power module connector to the power module
5.     Connect the other ends of the power cords to the DC power source.
Installing FRUs
Field replaceable units (FRUs) are not provided with the router. Purchase them as needed.
1.     Position the upper slide rail horizontally near the top of the left side of the chassis, as shown in Figure 34. Align the screw holes on the slide rail with those on the chassis.
2.     Fasten the fastening screws one by one.
3.     Position the lower slide rail horizontally near the bottom of the left side of the chassis, as shown in Figure 35. Align the screw holes on the slide rail with those on the chassis.
4.     Fasten the fastening screws one by one.
Figure 34 Installing the air filter slide rails
5.     Gently push the air filter along the slide rails until it is seated in position.
Figure 35 Inserting the air filter
6.     Fasten the captive screws.
Figure 36 Fastening the captive screws
Preparations
Confirm the following prerequisites:
·     The rack is fixed.
·     The router is installed.
The installation involves the following materials:
·     Fiber management tray (FMT)
·     M5 × 10 self-tapping screws (two screws for one FMT)
Installation procedure
To install an FMT:
1.     Align the FMT and the installation holes on the rack post.
2.     Fix each FMT with two M5 × 10 self-tapping screws.
Figure 37 Installing FMTs
Lightning protectors are applicable to only 10/100 Mbps copper Ethernet ports.
Read the instructions for the lightning protector carefully before you install it.
The router does not come with any lightning protectors.
If part of the network cable of a copper Ethernet port must be routed outdoors, connect a lightning protector to the cable before you plug the cable into the port. The router provides this type of lightning protector: single port, residual pulse energy (8/20μs test pulse) 5 KA, output voltage (8/20μs waveform): core-core ≤ 40 V, core-ground ≤ 600 V.
1.     Use a double-faced adhesive tape to stick the lightning protector onto the router chassis, and make sure it is as close to the grounding screw of the router as possible.
2.     Measure the distance between the protector and the grounding screw of the router, cut the ground wire of the protector as appropriate, and securely tighten the ground wire to the grounding screw of the router.
3.     Use the multimeter to measure whether the ground wire of the protector contacts well with the grounding screw of chassis.
4.     Insert the outdoor network cable into the protector's IN end, and the cable connected to the router into the OUT end, and look at the indicators on the lightning protector to verify that the connection is correct.
5.     Use nylon ties to bundle the cables neatly.
Figure 38 Installing a lightning protector for a network port
(1) Lightning protector
(2) Grounding cable
Installation precautions
The performance of the port lightning protector might be affected in the following cases:
·     The port lightning protector is installed in reverse direction. Connect the IN end to the outdoor network cable and the OUT end to the network port on the router.
·     The port lightning protector is not reliably grounded. After the connection, use the multimeter to confirm that the ground wire for the protector is as short as possible to ensure its good contact with the grounding screw of the router.
·     The installed port lighting protectors are not sufficient. If the router has more than one network port connected with other devices through cables outdoor, install a lightning protector for each network port.
CAUTION
CAUTION:
Make sure the PE terminal of the power socket has been securely grounded.
If part of the AC power line is routed outdoors, use a power strip with lightning protection to connect the AC power cord of the router to the AC power line to protect the router from being damaged by lightning strikes.
You can attach the power strip to the rack, workbench, or wall of equipment room.
After you connect the AC power cord from the router to a socket on the power strip, verify that the green RUN LED on the strip is on and the red LED is off.
If the red LED is on, use a multimeter to check the polarity of the wires in the power socket for wrong connections. If the zero wire (left) and the live wire (right) are correctly connected, check for missing grounding connection.
Figure 39 Power strip with lightning protection
(1) Working LED (green)
On means the circuit is operating correctly; off means the circuit is damaged.
(2) Grounding/pole detection LED (red)
On indicates a wrong wire connection (the wire is not grounded or the live line and null line are reversely connected), and you need to check the power supply line.
(3) Power switch
(4) IEC standard socket
It is used to connect to the power supply in the equipment room through a power cord.
(5) Overload automatic protector
The protector automatically opens the electric circuit when the current exceeds the threshold and closes the electric circuit when the current drops below the threshold.
(6) Multifunctional socket
It is used to connect the power module of the router.
CAUTION
CAUTION:
Ground the surge protector as near as possible. The grounding resistance must be less than 4 ohms. The grounding resistance must be less than 1 ohm if there are special grounding requirements.
Generally, you need to connect a surge protector before connecting a signal cable to the router. This can protect electronic devices against surge over-voltage resulting from lightning strokes and other interferences, and minimize impact on the router.
The surge protector is serially connected to a signal cable, so the surge protector must satisfy the requirements of network performance indexes such as data transmission bandwidth, as well as the lightning protection performance requirement. Before installing a surge protector, consider such performance indexes of the surge protector as lightning protection, bandwidth, transmission loss, and port type.
The router supports the following types of surge protectors:
·     Surge protector—Maximum discharge current 2.5KA/protection voltage 25V--SMB-75J/ SMB-75J-1W-10Mbps.
·     Surge protector—Maximum discharge current 2.5KA/protection voltage 25V-BNC-75K/ BNC-75K-10Mbps.
·     Surge protector (U port)—Maximum discharge current 3KA/common-mode 400V/differential mode 170V-RJ11.
To install a surge protector:
1.     Use a double-faced adhesive tape to stick the surge protector onto the router chassis, and make sure it is as close to the grounding screw of the router as possible.
4.     Insert the outdoor network cable into the protector's IN end, and the cable connected to the router into the OUT end, and look at the indicators on the surge protector to verify that the connection is correct.
Figure 40 Installing a surge protector
Precautions
The performance of the surge protector might be affected in the following cases:
·     The surge protector is installed in reverse direction. Connect the IN end to the outdoor network cable and the OUT end to the network port on the router.
·     The surge protector is not reliably grounded. After the connection, use the multimeter to confirm that the ground wire for the protector is as short as possible to ensure its good contact with the grounding screw of the router.
·     The installed surge protectors are not sufficient. If the router has more than one cable connected with other devices through cables outdoor, install a surge protector for each cable.
Overview
An AUX console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the AUX port of the router, and DB-25 and DB-9 male connectors at the other end for connecting to the serial port of the modem.
Figure 41 AUX cable
1.     Plug the DB-9 or DB-25 male connector at one end of the AUX cable into the serial port of the modem.
2.     Plug the RJ-45 connector of the AUX cable into the AUX port of the router.
Figure 42 Connecting the AUX port to a modem
Overview
10/100 Mbps Ethernet uses category-5 twisted pair cables, while 1000 Mbps Ethernet uses category-5 enhanced or category-6 twisted pair cables. Twisted pair cables include straight-through cables and crossover cables.
Category-5 cables provide a transmission frequency of 100 MHz for voice and data transmission; they are mainly used in 100Base-T and 10Base-T networks. Category-5 cables are common Ethernet cables, which can also be used to transmit 1000 Mbps Ethernet data.
Category-5 enhanced cables feature low attenuation and crosstalk, providing higher attenuation to crosstalk ratio (ACR), less delay error and higher performance than category-5 cables. Category-5 enhanced cables are mainly used in 1000 Mbps Ethernet networks.
Category-6 cables provide a transmission frequency of 1 MHz to 250 MHz, and improve the performance on crosstalk and return loss. A fine better return loss performance is extremely important for new-generation full-duplex high-speed networks. Category-6 cables have sufficient power sum ACR (PS-ACR) when operating at 200 MHz. They provide a bandwidth two times than that of category-5 enhanced cables, thus featuring a higher transmission performance. Therefore, category-6 cables are suitable for applications requiring a transmission speed of more than 1 Gbps.
The 10/100 Mbps Ethernet uses two pairs of cables, orange/white, orange, green/white and green cables, to transmit and receive data, while the 1000 Mbps Ethernet uses four pairs of cables to transmit and receive data.
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure 43 shows the pinouts of an RJ-45 connector.
Figure 43 RJ-45 connector pinout
EIA/TIA cabling specifications define two standards, 568A and 568B, for cable pinouts.
·     Standard 568APin 1: white/green stripe, pin 2: green steady, pin 3: white/orange stripe, pin 4: blue steady, pin 5: white/blue stripe, pin 6: orange steady, pin 7: white/brown stripe, pin 8: brown steady.
·     Standard 568BPin 1: white/orange stripe, pin 2: orange steady, pin 3: white/green stripe, pin 4: blue steady, pin 5: white/blue stripe, pin 6: green steady, pin 7: white/brown stripe, pin 8: brown steady.
Ethernet twisted pair cables can be classified into straight-through and crossover cables based on their pinouts.
For the pinouts of the twisted pair cables, see the following tables. (A and B represent the two ends of a cable, respectively.)
Table 10 Straight-through cable pinouts
Pinout No.
A
B
1
Orange/white
Orange/white
2
Orange
Orange
3
Green/white
Green/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Green
7
Brown/white
Brown/white
8
Brown
Brown
Table 11 Crossover cable pinouts
Pinout No.
A
B
1
Orange/white
Green/white
2
Orange
Green
3
Green/white
Orange/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Orange
7
Brown/white
Brown/white
8
Brown
Brown
To avoid affecting communication quality, strictly follow the pinouts in the above tables when identifying or making the two types of Ethernet cables.
1.     Cut the cable to a required length with the crimping pliers.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lay flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another. Insert the wires into the RJ-45 end and make sure the wires extend to the front of the RJ-45 end and make good contact with the metal contacts in the RJ-45 end and in the correct order.
5.     Crimp the RJ-45 connector with the crimping pliers until you hear a click.
6.     Use a cable tester to verify the connectivity of the cable.
1.     Plug one end of an Ethernet twisted pair cable into the copper Ethernet port (RJ-45 port) to be connected on the router and the other end of the cable into the Ethernet port of the peer device. The 10/100/1000Base-T copper ports of the router support MDI/MDI-X auto-sensing. They are connected to the network through category-5 or above twisted pairs that are equipped with RJ-45 connectors.
2.     Verify the status LED of the Ethernet ports. For more information about the LED status, see "Appendix C LEDs."
Transceiver modules
A transceiver module and a fiber cable with an LC or MPO connector are required for connecting a fiber port.
·     SFP transceiver modules—Connecting 100/1000 Mbps Ethernet fiber ports and SFP ports on some HIMs.
·     XFP transceiver modules—Connecting XFP ports on the HIM-1EXP.
·     SFP+ transceiver modules—Connecting GE SFP+ ports on the MCP-X2.
·     QSFP+ transceiver modules—Connecting 40GE QSFP+ ports on the MIC-QP1L.
Figure 44 SFP transceiver module
Figure 45 XFP transceiver module
Figure 46 SFP+ transceiver module
Figure 47 QSFP+ transceiver module (LC port)
Figure 48 QSFP+ transceiver module (MPO port)
Fiber cables
About fiber cables
You can use an optical fiber to connect a fiber Ethernet port or 10 Gbps Ethernet port. In addition, an optical fiber can connect these types of interface modules: HIM-4GBP/HIM-8GBP, HIM-CL1P/HIM-CL2P, HIM-CLS1P/HIM-CLS2P, HIM-MSP2P/HIM-MSP4P, HIM-PS1P, HIM-AL1P/HIM-AL2P, HIM-RS2P, HIM-1EXP, or MIC-QP1L.
Optical fibers feature low loss and long transmission distance.
Optical fibers can be classified into single-mode fibers and multi-mode fibers. A single-mode fiber carries only a single ray of light; a multi-mode fiber carries multiple modes of lights.
Table 12 Characteristics of single-mode and multi-mode optical fibers
Item
Single-mode fiber
Multi-mode fiber
Core
Small core (10 micrometers or less)
Larger core than single-mode fiber (50 micrometers, 62.5 micrometers or greater)
Dispersion
Less dispersion
Allows greater dispersion and therefore, signal loss exists.
Light source and transmission distance
Users lasers as the light source often within campus backbones for distance of several thousand meters
Uses LEDs as the light source often within LANs or distances of a couple hundred meters within a campus network
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient. There are multiple types of fiber connectors. Figure 49 shows an LC connector and MPO connector, respectively.
Figure 49 LC connector
光纤连接器.wmf
Figure 50 MPO connector
Some cards on the router provide dust plugs for the fiber ports (such as SFP ports). Before using such fiber ports, remove the dust plugs. Keep the dust plugs secure. When the fiber ports are not in use, install the dust plugs.
Fiber connectors are fitted with dust caps. Keep the dust caps correctly when the fiber connectors are in use. Install dust caps when the fiber connectors are not in use to avoid damage to their end face. Replace the dust cap if it is loose or polluted.
Before connecting an optical fiber, use dust free paper and absolute alcohol to clean the end face of the two fiber connectors. You can brush the end faces only in one direction.
After a fiber is installed well, the bend radius must be not less than 10 cm (3.94 in).
To pass a fiber through a metallic board hole, make sure the hole has a sleek and fully filleted surface (the filleting radius must be not less than 2 mm, or 0.08 in). To pass a fiber through a metallic board hole or bend it along the acute side of mechanical parts, make sure the fiber wears jackets or cushions.
Insert and remove a plug with care. Never exert a fierce force to the fiber or plug; otherwise the plug might be damaged or the fiber might be broken. Never pull, press or extrude the fiber fiercely. For the allowed maximum tensile load and crush load, see Table 13.
Table 13 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
WARNING
WARNING!
Do not stare into any fiber ports when you connect an optical fiber. The laser light emitted from the optical fiber might hurt your eyes.
Connecting a fiber cable with an LC connector
1.     Remove the dust plug from a fiber port of the router.
Figure 51 Removing the dust plug
2.     Install the transceiver module.
Figure 52 Installing the transceiver module
3.     Identify the Rx and Tx ports. Plug the LC connector at one end of one fiber cable into the Rx port of the router and the LC connector at the other end into the Tx port of the peer device. Plug the LC connector at one end of another fiber cable into the Tx port of the router and the LC connector at the other end to the Rx port of the peer device.
Figure 53 Installing the fiber connector
4.     View the LINK LED after connection.
¡     If the LED is on, the optical fiber link is present.
¡     If the LED is off, no link is present. This might be because the TX and Rx port of the optical fiber are not connected correctly. In this case, connect the optical fiber again.
Connecting a fiber cable with an MPO connector
1.     Wear an ESD wrist strap. Make sure the wrist strap makes good skin contact and is reliably grounded.
2.     Remove the dust plug from the target fiber port.
For interface modules with dust plugs provided as accessories, install dust plugs for empty fiber ports in time.
3.     Pull the bail latch on the transceiver module upwards.
4.     Take the transceiver module by its two sides and push the end without the bail latch gently into the port until it is firmly seated in the fiber port.
5.     Remove the dust plug and dust cap from the transceiver module and fiber connector, respectively.
6.     Orient the MPO fiber connector with the white dot on it facing right. Insert the connector horizontally into the transceiver module, and then push it into the transceiver module slightly until it clicks into the place, as shown in Figure 54.
7.     Use cable ties to bind the fiber cable every 150 mm (5.91 in).
8.     Attach labels to the fiber cable as required.
Figure 54 Installing a transceiver module and optical fiber (MPO connector)
CAUTION
CAUTION:
When connecting the interface cable, pay attention to the mark on the interface to avoid wrong insertion, which might damage the interface module or even the router.
As a best practice, install a lightning protector at the input end of the 8T1 cables to protect them against lightning strikes more efficiently when they are led outdoors.
E1 cable
You can use an 8E1 interface cable to connect to MIM-8E1(75)/MIM-8E1(75)-F modules.
Figure 55 8E1 splitter cable
The coaxial connector and 75-ohm E1 adapter cable are optional accessories, and must be purchased separately if needed.
T1 cable
You can use an 8T1 interface cable to connect to MIM-8T1/MIM-8T1-F modules.
Figure 56 8T1 splitter cable
Connecting an E1 cable (D15/D68 <----> BNC)
CAUTION
CAUTION:
·     If you do not need to extend the cable, you can directly connect the BNC connectors of the E1 75-ohm cable to the remote network device as follows.
a.     Connect the D15/D68 connector of the E1 75-ohm cable to the D15/D68 interface of the interface module and fasten the bolts to fix the cable.
b.     The other end of the cable provides one pair or multiple pairs of 75-ohm BNC connectors. Connect the TX connectors and the RX connectors on this end to the RX connectors and the TX connectors on the remote device respectively.
Figure 57 Connect an E1 75-ohm cable
·     If you want to extend the cable, connect each BNC connector of the E1 75-ohm cable to one end of a coaxial connector, and connect the remote device to the other end of the coaxial connector through an E1 75-ohm adapter cable.
Figure 58 Connecting an E1 75-ohm cable
·     If the impedance of the E1 interface on the remote device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure 59 Connecting an impedance converter
Connecting a T1 cable
1.     Connect the D68 connector of the 8-port T1 cable to the D68 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides eight RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
Figure 60 Connecting an 8T1 cable
You can use a CE3/CT3/T3 interface cable to connect the MIM-1CE3, MIM-1CT3, and MIM-1T3-V2 modules.
Figure 61 E3/T3 cable
As a best practice, install a special lightning protector at the input end of the E3/T3 cables to protect them against lightning strikes more efficiently when they are routed outdoors.
1.     Connect the SMB connector of an E3/T3 cable to the Tx port on the interface module and the other end to the Rx port on the device to be connected.
2.     Connect the SMB connector of another E3/T3 cable to the Rx port of interface module and the other end to the Tx port on the device to be connected.
Figure 62 Connecting a CE3/CT3/T3 cable
Overview
You can use a serial port cable to connect to the MIM-2SAE/MIM-4SAE/MIM-8SAE module. Select a serial port cable according to the link type.
Figure 63 V.24 DTE cable
Figure 64 V.24 DCE cable
Figure 65 V.35 DTE cable
Figure 66 V.35 DCE cable
Figure 67 X.21 DTE cable
Figure 68 X.21 DCE cable
Figure 69 RS449 DTE cable
Figure 70 RS449 DCE cable
Figure 71 RS530 DTE cable
Figure 72 RS530 DCE cable
1.     Check port type of the peer device and choose the synchronous serial interface cable of correct type.
2.     Plug the D28 end of the synchronous serial interface cable into the D28 interface of the SAE interface module.
3.     If the WAN uses DDN line, connect the cable to the port of the CSU/DSU.
4.     Identify the LINK LED on the SAE panel.
¡     If the LED is on, a link is present.
¡     If the LED is off, a fault has occurred on the link and signal is out of synchronization. In this case, examine the link.
Login methods
The following logins methods are available for you to log in to the router:
·     Logging in from the console port, which is the most common way to log in to a router and also the prerequisite for configuring other login methods.
·     Logging in through Telnet or SSH.
·     Logging in from the AUX port.
The first time you access the router, you can only log in to the CLI from the console port. To log in to the router from the console port, prepare the following items:
·     A console cableAn 8-core cable with a crimped RJ-45 connector at one end for connecting to the console port on the router, and a DB-9 connector at the other end for connecting to the 9-core serial port on the terminal.
·     A configuration terminalTypically a PC with a serial port.
You can connect the router to a configuration terminal by using a console cable or by using a USB console cable.
IMPORTANT
IMPORTANT:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating router, first connect the PC end. To disconnect a PC from an operating router, first disconnect the router end.
You can connect a configuration terminal to the router by using the console cable or by using the USB cable.
To connect a configuration terminal to the router by using a console cable:
1.     Select a configuration terminal, which can be a character terminal with an RS-232 serial port, or a PC.
If the PC does not have an RS-232 serial port but a USB port, use a USB to RS-232 adapter for the USB port and install the driver.
2.     Plug the DB-9 female connector of the console cable into the serial port on the configuration terminal and the RJ-45 connector into the console port on the router
The console cable connection procedures are the same for the routers. The following uses an SR6608 as an example.
Figure 73 Connecting the console cable
Using a USB console cable to connect the router to a configuration terminal
IMPORTANT
IMPORTANT:
After using a USB console cable to connect the router to a configuration terminal, you must download and install the USB console driver program before configuring the device.
To use a USB console cable to connect the router to a configuration terminal:
1.     Connect the USB Type A connector at one end of the USB console cable to the PC.
2.     Connect the other end of the USB console cable to the USB console port on the router.
3.     Click the following link, or copy it to the address bar on the browser to log in to download page of the USB console driver, and download the driver.
http://www.h3c.com.hk/Technical_Support___Documents/Software_Download/Routers/USB_Console/USB_Console/
4.     Select a driver program according to the operating system you use:
¡     XR21V1410_XR21B1411_Windows_Ver1840_x86_Installer.EXE—Applicable to 32-bit operating systems.
¡     XR21V1410_XR21B1411_Windows_Ver1840_x64_Installer.EXE—Applicable to 64-bit operating systems.
5.     Click Next on the installation wizard.
Figure 74 Device driver installation wizard
6.     Click Continue Anyway if the following dialog box appears.
7.     Click Finish.
Figure 75 Completing the device driver installation wizard
To configure and manage the router through the console port, you must run a terminal emulator program, TeraTermPro or PuTTY, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
The following are the required terminal settings:
·     Bits per second—9600.
·     Data bits—8.
·     Stop bits—1.
·     Parity—None.
·     Flow control—None.
Before powering on the router, verify the following items:
·     The power cord and grounding cable are correctly connected.
·     The power source voltage meets the requirement of the router.
·     The console cable is correctly connected, the terminal or PC used for configuration has started, and the configuration parameters have been set.
·     If a CF card is used, verify that the CF card is in position.
After powering on the router, verify the following items:
·     The LEDs on the front panel of the main processing unit (MPU) are normal. For the LED description, see "Appendix C LEDs."
·     The fans are operating correctly, and you can hear fan rotating.
·     The configuration terminal displays information normally. You can see the startup window on the local configuration terminal. For more information, see "Displaying boot information."
·     After the power-on self-test (POST), the system prompts you to press Enter. When the command line prompt appears, the router is ready for configuration.
Power on the router, and you can see the following information:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Press Ctrl+T to start memory test
Booting Normal Extend BootWare........
*                    H3C SR66 BootWare, Version 7.1.064                    *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Apr  6 2017
CPU Type            : XLS408
CPU L1 Cache        : 32KB
CPU Clock Speed     : 1000MHz
Memory Type         : DDR2 SDRAM
Memory Size         : 2048MB
Memory Speed        : 533MHz
BootWare Size       : 1024KB
Flash Size          : 4MB
cfa0 Size           : 244MB
BASIC CPLD Version  : 131.0
EXTEND CPLD Version : 133.0
PCB Version         : Ver.B
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
·     If the router has two RPE-X1 MPUs in slot 0 and slot 1, the router by default boots with the system software image in the RPE-X1 MPU in slot 0.
·     If the router has two RSE-X1 MPUs in slot 0 and slot 1, the router by default boots with the system software image in RSE-X1 MPU in slot 1.
Starting to get the main application file--cfa0:/main.bin!..................
The main application file is self-decompressing
Done!
System is starting.....
Starting application at 0x00010000 ...
Mainboard 0 is master.
User interface con0 is available.
Press ENTER to get started.
Press Enter, and the following prompt appears:
<H3C>
You can now configure the router.
Logging in to the router through Telnet
1.     After powering on the router, log in to the router through the console port. Enable the Telnet function on the router and set user privileges.
2.     Connect the PC to the management Ethernet interface on the router and specify an IP address for the interface.
3.     Specify an IP address for the PC, make sure the PC and the interface are in the same network segment.
For more information about how to log in to the router through Telnet, see H3C SR6600/SR6600-X Routers Fundamentals Configuration Guide.
Configuring basic settings
Step
Remarks
1.     Set the current time and date.
clock datetime time date
Optional.
Available in user view.
2.     Enter system view.
Required.
3.     Enter Ethernet interface view.
N/A
4.     Specify an IP address for the interface.
By default, no IP address is assigned to any interfaces.
5.     Return to system view.
Available in any view.
6.     Specify a static route.
ip route-static dest-address { mask | mask-length } { next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address } track track-entry-number [ preference preference-value ] [ tag tag-value ] [ description description-text ]
Required.
By default, the preference of a static route is 60, tag is 0, and no description is configured.
Do not specify the permanent keyword together with the bfd or track keyword.
7.     Save the current configuration to the startup configuration file in the root directory of the storage media.
save [ safely ] [ backup | main ] [ force ]
8.     Verify the running configuration.
display current-configuration
Hardware management and maintenance
The output depends on your router model. For more information about the commands used in this chapter, see H3C SR6600/SR6600-X Routers Command References.
Displaying hardware information of the router
Displaying the software and hardware version information of the router
Use the display version command to display software and hardware version information of the router. The output includes the following information: the current software version and hardware version, router operating time, type and operating time of each main processing unit (MPU) and service module. The output of this command depends on your router model.
<Sysname> display version
Displaying the operational statistics of the router
When you perform routine maintenance or the system fails, you might need to view the operational information of each functional module for locating failures. Generally, you need to run display commands one by one. To collect more information one time, you can execute the display diagnostic-information command in any view to display or save the operational statistics of multiple functional modules of the router. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
·     To save the operational statistics of each functional module of the router, type y when the system prompts you to save or display the diagnostic information.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.diag)[cfa0:/default.diag]:aa.diag
Diagnostic information is outputting to cfa0:/aa.diag.
Please wait...
Save succeeded.
Execute the more aa.diag command in user view, and then press the Page Up and Page Down keys to view the contents of the file aa.diag.
·     To display the operational statistics of each functional module of the router, type n when the system prompts you to save or display the diagnostic information. The output is too much and omitted here.
08:54:16 UTC Fri 11/12/2017
…Omitted…
Displaying detailed information about a module
Use the display device verbose command to display detailed information about modules in each slot.
<Sysname>display device verbose
 System-mode(Current/After Reboot): Normal/Normal
 Slot No.  Board type    Status       Primary    SubSlots
 0         RPE-X1        Normal       Master     0
 1         N/A           Absent       N/A        N/A
 2         N/A           Absent       N/A        N/A
 3         N/A           Absent       N/A        N/A
 4         N/A           Absent       N/A        N/A
 5         FIP-210       Startup      N/A        2
Use the display device slot slot-number command to display detailed information about the module in the specified slot.
<Sysname> display device slot 0
 Slot 0 : RPE-X1
 SubSlot No.   Card Type           Status      Max Ports
 0             Fixed SubCard       Normal      3
Table 14 Output description
Slot No.
Slot number of the module
Card Type
Module model. The value NONE indicates that no module is present in the slot.
Status
Running status of the module:
·     Absent—No module is present in the slot.
·     Fault—The module in the slot is booting, or the module fails and cannot boot correctly.
·     Normal—The module in the slot is a service module and is operating correctly.
Max Ports
Maximum number of submodules that that module supports.
Displaying the electrical label information of a module
Use the display device manuinfo command to display the electrical label information of the module in each slot.
Electrical label information is also called permanent configuration data or archive information, which includes the module name, serial number, MAC address, and vendor name.
<Sysname> display device manuinfo
 Slot 0:
DEVICE_NAME:NONE
DEVICE_SERIAL_NUMBER:NONE
MAC_ADDRESS:NONE
MANUFACTURING_DATE:NONE
VENDOR_NAME:H3C
 Slot 5:
DEVICE_NAME:NONE
MAC_ADDRESS:NONE
VENDOR_NAME:H3C
Use the display device manuinfo slot slot-number command to display the electrical label information of the module in the specified slot.
<Sysname> display device manuinfo slot 5
 Slot 5:
DEVICE_NAME:NONE
MAC_ADDRESS:NONE
VENDOR_NAME:H3C
Table 15 Output description
DEVICE_NAME
Module type
Module serial number
MAC_ADDRESS
MAC address of the module:
·     An MPU has a MAC address.
·     A service module does not have a MAC address, and the field displays NONE.
MANUFACTURING_DATE
Manufacturing data of the module
VENDOR_NAME
Vendor name
The operation is not supported on the specified board or subslot
The display device manuinfo command is not supported on a module that is virtualized through the MPU.
Displaying the CPU usage of a module
Use the display cpu-usage command to display the CPU usage of the module in each slot.
<Sysname> display cpu-usage
Slot 0 CPU usage:
       2% in last 5 seconds
       2% in last 1 minute
       1% in last 5 minutes
Slot 5 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
Table 16 Output description
Slot 0 CPU usage
CPU usage of the module in slot 0.
If the module in the slot has multiple CPUs, Slot 0 CPU usage shows the usage of the main CPU of the module in slot 0, and Slot 0 CPU 1 CPU usage shows the usage of the standby CPU of the module in slot 0.
Average CPU usage in the last five seconds (after the router boots, the router calculates and records the average usage at the interval of five seconds).
1% in last 1 minute
Average CPU usage in the last minute (after the router boots, the router calculates and records the average usage at the interval of one minute).
Average CPU usage in the last five minutes (after the router boots, the router calculates and records the average usage at the interval of five minutes).
Displaying the memory usage of a module
Use the display memory command to display the memory information of the MPU.
<Sysname> display memory
System Total Memory(bytes): 431869088
Total Used Memory(bytes): 71963156
Used Rate: 16%
Table 17 Output description
Physical memory size (in bytes) of the module
Used memory size (in bytes) of the module
Used Rate
Memory usage of the module
Displaying the CF card information
Use the display device cf-card command to display the CF card information.
<Sysname> display device cf-card
 Slot No.      Dev No.      Status      Size(M)
 0             0            Normal      495
 0             1            Absent      N/A
Table 18 Output description
Slot No
Slot number of the CF card
Dev No.
Device number of the CF card:
·     0 for a built-in CF card
·     1 for an external CF card
Status
Operational status of the CF card:
·     Absent—No CF card is present in the slot.
·     Fault—The CF card fails.
·     Normal—The CF card is operating correctly.
Size (M)
Storage capacity of the CF card
Displaying the operational status of the fan
Use the display fan command to display the operational status of the fan.
<Sysname> display fan
 Fan     1 State: Normal
Table 19 Output description
Fan     1
Number of the fan
The fan state:
·     Normal—The fan is operating correctly.
·     Absent—The fan is not in position.
·     Fault—The fan fails.
Displaying the operational status of power modules
Use the display power-supply command to display the operational status of power supplies.
<Sysname> display power-supply
Power No.   State       Description
1           Normal      EMERSON-650AC
2           Absent      Unknown
Table 20 Output description
Power No.
Power supply slot
The power supply state:
·     Normal—The power supply is operating correctly.
·     Absent—The power supply is not in position.
·     Fault—The power supply fails.
Description for the power supply
Displaying the alarming thresholds of a module
When the router is operating, too high a temperature and too low a temperature of a module affect the normal operation of the router. When the temperature of a module exceeds 80°C (176°F) or drops below 0°C (32°F), the system sends traps to prompt you to solve the problem.
To display the alarming thresholds of a module:
Step
Remarks
N/A
2.     Display the temperature information of your router.
display environment
Optional
Port configuration and management
Configuring a combo interface
Combo interface overview
A combo interface is a logical interface comprising an SFP port of a transceiver module and an RJ-45 Ethernet port. The two ports share one forwarding interface, so they cannot work simultaneously. When you enable either port, the other port is automatically disabled. You can select to activate a port as needed.
Configuration prerequisites
Use the display interface interface-type interface-number command to find out which port is an SFP port and which port is an RJ-45 Ethernet port.
·     If the output includes "Media type is not sure, Port hardware type is No connector", it means that the port is an SFP port. For example, the following output shows that GigabitEthernet 5/0/1 is an SFP port.
[Sysname] display interface GigabitEthernet 5/0/1
 GigabitEthernet5/0/1 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0000-fc00-7506
 Description: GigabitEthernet5/0/1 Interface
 Loopback is not set
 Media type is not sure,Port hardware type is No connector
·     If the output includes "Media type is twisted pair, Port hardware type is 1000_BASE_T", it means that the interface is an RJ-45 Ethernet port. For example, the following output shows that GigabitEthernet 5/0/0 is an RJ-45 Ethernet port.
[Sysname] display interface GigabitEthernet 5/0/0
 GigabitEthernet5/0/0 current state: DOWN ( Administratively )
 Description: GigabitEthernet5/0/0 Interface
 Loopback is not set
Step
Remarks
N/A
2.     Enter view of the SFP port or RJ-45 port of the combo interface.
N/A
3.     Activate the RJ-45 Ethernet port or SFP port.
combo enable { copper | fiber }
Required.
By default, the Ethernet port is active.
Displaying transceiver module information and alarming information
Table 21 Commonly used transceiver modules
Transceiver module type
Application scenarios
Whether can be an optical transceiver
Whether can be an electrical transceiver
SFP (Small Form-factor Pluggable)
Typically used for 100M/1000M Ethernet ports or POS 155M/622M/2.5G ports
Yes
Yes
XFP(10-Gigabit small Form-factor Pluggable)
Typically used for 10G ports
Yes
No
SFP+
Yes
No
QSFP+
Typically used for 40G ports
Yes
No
To identify transceiver modules, you can use the following command to view the key parameters of the transceiver modules, including transceiver module type, connector type, central wavelength of the laser sent, transmission distance, and vendor name or name of the vendor who customizes the transceiver modules.
To display transceiver module information:
Purpose
Remarks
Display key parameters of the transceiver module in a specified interface
Available for all transceiver modules.
Displaying the alarming information or fault detection parameters for a transceiver module
The system outputs alarm information for you to locate and troubleshoot faults of transceiver modules. For the H3C-customized transceiver modules, the system can also monitor the key parameters, such as temperature, voltage, laser bias current, TX power, and RX power. When these parameters are abnormal, you can take corresponding measures to prevent transceiver module faults.
To display the alarming information or fault detection parameters of a transceiver module:
Purpose
Remarks
Display the current alarm information of the transceiver module in a specified interface
For more information about the transceiver module displaying commands, see H3C SR6600/SR6600-X Routers Fundamentals Command Reference.
Saving the current configuration of the router
You can save the current configuration of the router in one of the following methods:
·     Fast savingExecuting the save command without the safely keyword. This mode saves the file more quickly but is likely to lose the existing configuration file if the router reboots or the power fails during the process. The fast saving mode is suitable for environments where the power supply is stable.
·     Safe savingExecuting the save command with the safely keyword. The mode saves the file more slowly but can retain the configuration file in the router even if the router reboots or the power fails during the process. The safe saving mode is preferred in environments where a stable power supply is unavailable or remote maintenance is involved.
To save the current configuration of the router:
Remarks
Save the current configuration to the specified file, but the configuration file will not be set as the file for the next startup.
Use either command.
The configuration file must be with extension .cfg.
During the execution of the save command, the startup configuration file to be used at the next system startup might be lost if the router reboots or the power supply fails. In this case, the router will boot with the factory defaults, and after the router reboots, you need to re-specify a startup configuration file for the next system startup.
Save the current configuration to the root directory of the storage medium of the active or standby MPU and specify the file as the startup configuration file that will be used at the next system startup.
save [ safely ]
Rebooting a module or router
When upgrading and maintaining the startup configuration file or configuration file for the router, you need to reboot the router. After you change the operating mode of a MPU or service module, you must restart the corresponding module. To reboot a router, use one of the following methods:
·     Use the reboot command to reboot a router.
·     Enable the scheduled reboot function at the CLI. You can set a time at which the router can automatically reboot, or set a delay so that the router can automatically reboot within the delay.
·     Power on the router after powering it off, which is also called hard reboot or cold start. Powering off a running router causes data loss and hardware damages, and therefore is not recommended.
The precision of the rebooting timer is 1 minute. One minute before the rebooting time, the router prompts "REBOOT IN ONE MINUTE" and reboots in one minute.
If you are performing file operations when the router is to be rebooted, the system does not execute the reboot command for security.
To reboot the router immediately:
Remarks
Reboot the router or the module in the specified slot immediately.
reboot [ slot slot-number ]
Required.
If you execute the command without specifying the slot keyword, the command reboots the router, including the active MPU, standby MPU, the switching fabric modules, and the service modules.
If the main startup configuration file does not exist, do not use the reboot command to reboot the router or the active MPU. In this case, specify the main startup configuration file first, and then reboot the active MPU.
To enable the scheduled reboot function:
Remarks
Enable the scheduled reboot function and specify a specific reboot time and date.
schedule reboot at hh:mm [ date ]
Use either command
The scheduled reboot function is disabled by default.
Enable the scheduled reboot function and specify a reboot waiting time.
schedule reboot delay { hh:mm | mm }
Replacement procedures
The router uses a modular, all-pluggable design, and supports replacing hot swappable modules without interrupting the router operation.
Safety recommendations
1.     Always wear an ESD wrist strap or ESD gloves when replacing the modules.
2.     When working with a removable module, such as an MPU, RPE-X1/RPE-X3/RPE-X5/RPE-X5E carrier (used when you use an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU), FIP module, SAP module, switching fabric module, memory module, CF card, or HIM/MIM, follow these guidelines:
¡     Ensure good alignment with the slot to avoid damage to the module during installation or removal.
¡     Before removing a module, make sure the captive screws are completely loosened. Otherwise, the panel of the module might be deformed.
¡     Avoid touching any components on the PCB during observing or moving the module.
¡     Put the removed module on an antistatic workbench with the PCB side facing upward or place them in antistatic bags.
Replacing a power module
The replacement procedure of an AC power module is the same as a DC power module. This section takes an AC power module as an example.
To replace a power module:
1.     Loosen the captive screws of the power module until all spring pressure is released.
2.     Gently pull the power module out of the slot along the slide rails.
Figure 76 Pulling out the power module
3.     Put the removed power module on an antistatic workbench or into an antistatic bag.
4.     If you do not install a new power module in the slot, install a filler panel. To install a power module, see "Installing a power module."
Replacing an MPU
CAUTION
CAUTION:
·     For a version lower than R7103, the system checks the software versions of the active MPU and standby MPU (if any). If they are inconsistent, the standby MPU will not start. You can use the ha slave-ignore-version-check command to force the system to ignore version check of the standby MPU.
·     For R7103 and higher versions, the standby MPU (if any) automatically synchronizes the software version from the active MPU to ensure that they are the same version.
1.     If the router is configured with only one MPU, make sure all power sources to the router are turned off before replacing the MPU.
2.     If the router is configured with two MPUs, make sure both MPUs operate correctly before replacing an MPU.
¡     As a best practice to replace the active MPU, execute the reboot command in the system view of the active MPU to trigger an active and standby switchover. For more information about the reboot command, see the relevant command reference.
¡     To replace the standby MPU, you can remove it immediately.
Replacing an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU
The replacement procedures for the RPE-X1, RPE-X3, RPE-X5, and RPE-X5E MPUs are the same. This example uses an RPE-X1.
To replace an RPE-X1 MPU:
1.     Determine the MPU to be removed. This section takes the MPU in slot 1 as an example.
2.     Loosen the captive screws of the MPU until all spring pressure is released.
3.     Holding the ejector levers of the MPU with both hands, pull the ejector levers outward, and gently pull the MPU out of the slot along the slide rails.
Figure 77 Pulling the RPE-X1 MPU out of the slot
4.     Install a new RPE-X1 MPU. For more information, see "Installing an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU."
Replacing an RSE-X1 MPU
Figure 78 Pulling the RSE-X1 MPU out of the slot
4.     If you do not install a new MPU in the slot, install a filler panel. To install a new MPU, see "Installing an RSE-X1 MPU."
Replacing an MCP
To replace an MCP, for example, MCP-X1:
1.     Determine the MCP to be removed. This section takes the MCP in slot 1 as an example.
2.     Loosen the captive screws on the MCP until all spring pressure is released.
3.     Holding the ejector levers of the MCP with both hands, pull the ejector levers outwards, and gently pull the MCP out of the slot along the slide rails.
Figure 79 Pulling the MCP out of the slot
4.     If you do not install a new MCP in the slot, install a filler panel. To install a new MCP, see "Installing an MCP MPU."
Replacing a FIP module
1.     Determine the FIP module to be removed. This section takes the FIP module in slot 3 as an example.
2.     Loosen the captive screws of the FIP module until all spring pressure is released.
3.     Holding the ejector levers of the FIP module with both hands, pull the ejector levers outward, and gently pull the FIP module out of the slot along the slide rails.
Figure 80 Pulling the FIP module out of the slot
4.     If you do not install a new FIP module in the slot, install a filler panel. To install a new FIP module, see "Installing a FIP module and an air deflector."
Replacing an SSD drive
Before you remove an SSD drive, remove the service module from the router. For the removal procedure of service modules, see "Replacing a FIP module" or "Replacing a SAP/OAP/switching fabric module."
To remove an SSD drive:
1.     Use a Phillips screwdriver to remove the fastening screws on the SSD drive.
2.     Gently lift the SSD drive free from the connector and slightly pull the SSD drive out of the slot.
Keep the SSD drive secure.
3.     Install a new SSD drive. For the installation procedure, see "Installing an SSD drive."
Figure 81 Removing an SSD drive
CAUTION
CAUTION:
When the RUN LED of the SAP/OAP/switching fabric module is fast flashing, do not remove the module.
To replace a SAP/OAP/switching fabric module:
1.     Determine the SAP/OAP/switching fabric module to be removed. This section takes the SAP module in slot 3 as an example.
2.     Loosen the captive screws of the SAP module until all spring pressure is released.
3.     Holding the ejector levers of the SAP module with both hands, pull the ejector levers outward, and gently pull the SAP module out of the slot along the slide rails.
Figure 82 Pulling the SAP module out of the slot
4.     If you do not install a new SAP module in the slot, install a filler panel. To install a new SAP module, see "Installing a SAP/OAP/switching fabric module."
Replacing a HIM/MIM/MIC/MIC-X
CAUTION
CAUTION:
To avoid hardware damage, do not install or remove a HIM/MIM/MIC/MIC-X module when the RUN LED on a FIP module is fast flashing green.
IMPORTANT
IMPORTANT:
After you remove a HIM/MIM/MIC/MIC-X from a FIP, the HIM/MIM/MIC/MIC-X settings will not automatically restore if you reinstall the HIM/MIM/MIC/MIC-X on the FIP after the FIP reboots. To save the settings, make sure the HIM/MIM/MIC/MIC-X is in position before rebooting the FIP module or inserting the FIP module into the router.
IMPORTANT
IMPORTANT:
The replacement procedures for HIMs, MIMs, MICs, and MIC-Xs are similar.
To replace a HIM/MIM/MIC/MIC-X:
1.     Determine the HIM/MIM/MIC/MIC-X to be removed, and completely loosen the captive screws of the HIM/MIM/MIC/MIC-X.
2.     Fully open the ejector levers on the HIM/MIM/MIC/MIC-X. Hold the ejector levers and then gently pull the HIM/MIM/MIC/MIC-X out of the slot along the slide rails.
The ejector levers of the FIP module are long. When removing the HIM/MIM/MIC/MIC-X in slot 1 on the FIP module, avoid touching the right ejector lever of the FIP module.
Figure 83 Replacing a HIM/MIM/MIC/MIC-X
3.     If you do not install a new HIM/MIM/MIC/MIC-X in the slot, install a filler panel. To install a new HIM/MIM/MIC/MIC-X, see "Installing a HIM/MIM/MIC/MIC-X interface module."
Replacing a CF card
CAUTION
CAUTION:
To avoid hardware damage, do not remove the CF card when the router is booting or the CF LED is flashing.
To replace a CF card:
1.     Make sure the CF card LED is not flashing. A flashing CF card LED means that the system is accessing the CF card.
To replace the CF card on the MCP, remove the CF card cover first.
2.     As shown in Figure 84, press the CF card eject button of the CF card reader so that the eject button protects from the panel.
Figure 84 Pressing the eject button
3.     Press the eject button again to eject the CF card part-way out of the CF card reader, and then pull the CF card out of the CF card reader.
Figure 85 Pressing the eject button to eject the CF card
4.     Install a new CF card. For more information, see "Installing a CF card."
To protect the CF card, place it into an antistatic bag.
Replacing a transceiver module
WARNING
WARNING!
·     Do not stare into the optical fibers.
·     When removing a transceiver module, do not touch the golden finger of the transceiver module.
The replacement procedure is the same for LC and MPO transceiver modules. The LC transceiver module is used as an example in this procedure:
1.     Remove the optical fibers from the transceiver module.
2.     Pivot the clasp down to the horizontal position.
3.     As shown in Figure 86, holding the handle of the transceiver module, gently pull the transceiver module out.
4.     Insert the plastic plug to the removed transceiver module, and put the transceiver module into its original shipping materials.
5.     If you do not install a new transceiver module in the interface, install a dust-proof plug in the interface. To install a transceiver module, see "Connecting a fiber cable."
Figure 86 Removing a transceiver module
When replacing a transceiver module, make sure the two transceiver modules connected by the same optical fiber have the same wavelength.
Replacing a fan tray
CAUTION
CAUTION:
·     The router supports automatic fan speed adjustment and hot-swapping of the fan tray.
·     Keep your hands away from the spinning fan blades when removing the fan tray.
To replace a fan tray:
1.     Loosen the captive screws of the fan tray until all spring pressure is released.
2.     Gently pull the fan tray out of the slot along the slide rails.
Figure 87 Pulling out the fan tray
3.     Install a new fan tray. For more information, see "Installing a fan tray."
·     Do not keep the router working without a fan tray for more than two minutes because poor ventilation might cause damage to the router.
·     To protect the removed fan tray, place it in an antistatic bag.
·     For more information about the LED status on the fan tray, see "Appendix C LEDs."
Replacing an air filter
CAUTION
CAUTION:
You can clean the air filter with water, but wait until it is completely dry before installing it again.
An air filter is an optional accessory.
To replace an air filter:
1.     Loosen the captive screws of the air filter until all spring pressure is released.
Figure 88 Loosening the captive screws of the air filter
2.     Gently pull the air filter out along the slide rails.
Figure 89 Pulling the air filter out along the slide rails
3.     Install a new air filter. For more information, see "Installing an air filter."
Replacing a memory module
The RPE-X1s and FIPs are equipped with memory modules. Before installing or removing a memory module, remove the RPE-X1 or FIP from the chassis first. For more information, see "Replacing an MPU," "Replacing an RSE-X1 MPU," and "Replacing a FIP module."
When to replace a memory module
CAUTION
CAUTION:
·     Use the memory modules provided by H3C only. Otherwise, the router might be unable to operate correctly.
·     For all the MPUs and service modules, except RPE-X1 MPU, memory modules with the same capacity must be used in pairs, for the specifications of memory modules supported, see "Appendix A Chassis views and technical specifications."
Memory modules are removable components of the router.
You need to replace a memory module in the following situations:
·     More memory is needed to upgrade the application program.
·     The router needs to maintain a large routing table or support other highly memory consuming operations.
·     An existing memory module is damaged.
Figure 90 Memory module replacement flowchart
Memory module structure
Figure 91 Memory module structure (DDR2)
(1) Connector edge
(2) Polarization notch
(3) Latch notch
Figure 92 Memory module structure (DDR3)
(1) Connector edge
(3) Latch notch
Memory module slot
Figure 93 Memory module slot
(1) Release latch
(2) Memory module slot
CAUTION
CAUTION:
·     Do not touch the surface-mounted components of the memory module directly with your hands to avoid damaging the memory module. Hold the memory module only at its non-conductive edge.
·     To protect the removed memory module, place it in an antistatic bag.
To replace a memory module:
1.     Determine the module (MPU or FIP) for which you will replace a memory module, and put the module on a flat workbench.
2.     Pull the release latches away from the memory module at both ends so that the memory module is lifted from the memory module slot.
3.     Holding the non-conductive edge, remove the memory module.
Figure 94 Removing the memory module
4.     Align the polarization notch of the memory module with the key in the connector.
5.     Insert the memory module into the slot.
6.     Carefully and firmly press the memory module at both ends until you hear a click. This indicates the memory module is seated in the memory module slot.
7.     Verify that the release latches have firmly locked the memory module in position.
Figure 95 Installing the memory module
Troubleshooting
IMPORTANT
IMPORTANT:
The barcode stuck on the router chassis contains production and servicing information. Before you return a faulty router for serving, provide the barcode information of the router to H3C Support.
MPU failures
RUN LED is off
Symptom
The RUN LED of the MPU is off. For more information about the RUN LED, see "Appendix C LEDs."
Solution
To resolve the issue:
1.     Verify that the MPU is installed in a right slot.
¡     An RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU must be installed in slot 0 or slot 1.
¡     An RSE-X1 MPU must be installed in slot 1 or slot 2.
¡     An MCP-X1/X2 must be installed in slot 1 or slot 2.
2.     Verify that the router is powered on correctly. A green POWER LED indicates that the router is powered on correctly.
3.     If the issue persists, contact H3C Support.
RUN LED fast flashes
Symptom
Five minutes after the router is powered on or the MPU is inserted in the router, the RUN LED of the MPU still fast flashes at 8 Hz.
Solution
1.     Verify that the terminal display is correct.
2.     Verify that the software image file properties are correct in the BootWare menu.
ALM LED is steady on or flashes
Symptom
The ALM LED of the MPU is steady on or flashes. A failure or exception has occurred.
For example, the ALM LED is on when the following message is displayed:
%Jun 25 14:38:45:444 2017 H3C DRVMSG/3/TempCritical:
 CPU temperature critical in Slot 3, index is 1.
For more information about the ALM LED, see "Appendix C LEDs."
Solution
1.     Verify the output (such as the system temperature and PCB voltage alarms) on the serial terminal and the software management tool.
2.     If the issue persists, contact H3C Support.
FIP module failures
RUN LED is off
Symptom
The RUN LED on the FIP module is off.
Solution
1.     Verify that the router is powered on.
2.     Verify that the FIP module is installed in a right slot.
3.     Execute the display version command to display system version information:
   Slot3:
    The Board is present, state is unknown
4.     If the issue persists, contact H3C Support.
Symptom
20 minutes after the router is powered on or the FIP module is plugged into the router, the RUN LED on the FIP module still fast flashes at 8 Hz.
Solution
1.     Execute the display version command to display system version information.
   Slot3:
The output shows that the FIP module is in position.
Power module failures
Power LED is off
Symptom
The router cannot be powered on and the power LED on the front panel is off.
Solution
1.     Verify that the power switch is turned on.
2.     Verify that the power cords of the router are firmly connected.
3.     Verify that the switch of the power source is turned on.
4.     Verify that the power cord is not damaged.
5.     If the issue persists, contact H3C Support.
Red power LED is on
Symptom
The router cannot be powered on and the red power LED on the front panel is on.
Solution
1.     Verify that the power switch is turned on and the power module is firmly seated.
2.     Verify that the power source meets the requirements of the router.
Fan failures
Fan tray is absent
Symptom
After the router is booted, the system displays the following information:
%Jul  5 14:47:20:618 2017 H3C DEV/4/FAN ABSENT:
 Fan 1 is absent.
Solution
1.     Verify that the fan tray is in position.
2.     Verify that the fan tray is in firm contact with the backplane of the router chassis.
ALM LED is red
Symptom
When the router is running, the ALM LED on the fan tray panel might turn red, and the following information might appear on the configuration terminal:
%Jul  5 14:59:03:878 2017 H3C DRVMSG/3/FanPlugIn:Fan 1 Plug In.
%Jul  5 14:59:03:879 2017 H3C DRVMSG/3/FanErr:Fan 1 Error.
#Jul  5 14:59:03:998 2017 H3C DEV/1/FAN STATE CHANGES TO FAILURE:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.6<fanfailure>: fan ID is 1
 %Jul  5 14:59:03:998 2017 H3C DEV/4/FAN FAILED:
 Fan 1 failed.
Solution
1.     Identify whether any foreign objects have entered the fan tray.
HIM/MIM/MIC/MIC-X failures
Symptom
When a HIM/MIM/MIC/MIC-X is installed while the router is running, the following information might appear on the configuration terminal:
%Apr 26 15:36:09:404 2017 H3C DRVICOUT/1/DrvIcOutStr:Slot=5;(Src Slot[5])
 Slot 5/2 Plug In Failed!
Solution
1.     Verify that the HIM/MIM/MIC/MIC-X is installed securely.
2.     Verify that the HIM/MIM/MIC/MIC-X is correctly installed in a FIP module. For HIM/MIM/MIC/MIC-X and FIP module compatibility, see H3C SR6600/SR6600-X Routers Interface Module Guide.
3.     Verify that the interface module connector pins of the FIP module are bent.
Configuration system issues
If the configuration environment setup is correct, the configuration terminal displays boot information when the router is powered on. If the setup is incorrect, the configuration terminal displays nothing or garbled text.
No terminal display
Symptom
The configuration terminal displays nothing when the router is powered on.
Solution
1.     Verify that the power supply system is operating correctly and the console cable is correctly connected.
2.     Verify that the console cable is connected to a correct serial port.
3.     Verify that the following terminal settings are correct:
¡     Bits per second—9600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Flow control—None.
¡     Terminal emulation—VT100.
Garbled terminal display
Symptom
Terminal display is garbled.
Solution
1.     Make sure the Data bits field is set to 8 for the console terminal. If the Data bits field is set to 5 or 6, the console terminal will display garbled characters.
2.     Make sure the Bits per second field is set to 9600 kbps. An incorrect bits per second might also cause the configuration terminal to display garbled characters.
No response from the serial port
Symptom
The serial port gives no response.
Solution
1.     Verify that the serial port settings are correct. For more information about the serial port settings, see "Setting terminal parameters."
Dealing with console login password loss
CAUTION
CAUTION:
Dealing with console login password loss from BootWare menus requires device reboot and is service-disruptive.
How to deal with console login password loss depends on the state of password recovery capability (see Figure 96). Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
·     If password recovery capability is enabled, a console user can access the device configuration without authentication and configure new passwords.
·     If password recovery capability is disabled, a console user must restore the factory-default configuration before configuring new passwords. Restoring the factory-default configuration deletes the main and backup next-startup configuration files.
To enhance system security, disable password recovery capability.
Figure 96 Dealing with console login password loss
Examining the state of password recovery capability
1.     Reboot the router.
CPU Type            : XLS408
CPU L1 Cache        : 32KB
Flash Size          : 4MB
cfa0 Size           : 244MB
PCB Version         : Ver.B
2.     Press Ctrl + B within three seconds after the "Press Ctrl+B to enter extended boot menu..." prompt message appears.
BootWare password: Not required. Please press Enter to continue.
3.     Press Enter and read the password recovery capability state message displayed before the EXTEND-BOOTWARE menu.
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
Skipping current system configuration
1.     Reboot the router to access the EXTEND-BOOTWARE menu, and then enter 6.
The current mode is password recovery.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 6
After the configuration skipping flag is set successfully, the following message appears:
Flag Set Success.
2.     When the EXTEND-BOOTWARE menu appears again, enter 0 to reboot the router.
The router starts up with empty configuration.
3.     To use the configuration in the next-startup configuration file, load the file in system view.
<sysname> system-view
[sysname] configuration replace file startup.cfg
Current configuration will be lost, save current configuration? [Y/N]:n
Info: Now replacing the current configuration. Please wait...
Info: Succeeded in replacing current configuration with the file startup.cfg.
4.     Configure a new console login password.
In the following example, the console login authentication mode is password and the authentication password is 123456. For security, the password is always saved in hashed format to the configuration file, regardless of whether you specify the simple keyword or hash keyword for the set authentication password command.
[sysname] user-interface console 0
[sysname-ui-console0] authentication-mode password
[sysname-ui-console0] set authentication password simple 123456
5.     To make the settings take effect after a reboot, save the running configuration to the next-startup configuration file.
[sysname] save
Skipping authentication for console login
1.     Reboot the router to access the EXTEND-BOOTWARE menu, and then enter 8.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 8
The router deletes the console login password configuration commands from the main next-startup configuration file. After the operation is completed, the following message appears:
Clear Image Password Success!
3.     Configure a new console login password (see "Configure a new console login password.").
4.     To make the setting take effect after a reboot, save the running configuration to the next-startup configuration file.
[sysname] save
Restoring to factory default configuration
1.     Reboot the router to access the EXTEND-BOOTWARE menu, and enter 5.
The current mode is no password recovery.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 5
2.     At the prompt for confirmation, enter Y.
The router deletes its main and backup next-startup configuration files and restores the factory-default configuration.
The current mode is no password recovery. The configuration files will be
deleted, and the system will start up with factory defaults, Are you sure to
 continue?[Y/N]Y
Setting...Done.
3.     When the EXTEND-BOOTWARE menu appears again, enter 0 to reboot the router.
The router starts up with the factory-default configuration.
4.     Configure a new console login password (see "Configure a new console login password.").
[sysname] save
Cooling system failure
Symptom
When the environmental temperature of a module reaches or exceeds the high temperature threshold, the fans rotate at full speed, and the following information appears on the configuration terminal:
%Might  4 19:37:29:945 2017 H3C DRVMSG/3/Temp2High:
 Environment temperature too high in Slot 5, index is 0.
When the CPU temperature of a module reaches or exceeds the high temperature threshold, the fans rotate at full speed, and the following information appears on the configuration terminal:
 CPU temperature too high in Slot 5, index is 0.
When the environmental temperature of a module reaches or exceeds the critical temperature threshold, the fans rotate at full speed, and the following information appears on the configuration terminal repeatedly:
%Might  4 19:37:54:945 2017 H3C DRVMSG/3/TempCritical:
 Environment temperature critical in Slot 5, index is 0.
When the CPU temperature of a module reaches or exceeds the critical temperature threshold, the fans rotate at full speed, and the following information appears on the configuration terminal repeatedly:
 CPU temperature critical in Slot 5, index is 0.
When the environmental or CPU temperature of a module exceeds the critical temperature threshold, the ALM LED of the MPU is red.
Solution
1.     Verify that the fans are running correctly.
2.     Verify that the operating environment of the router is well ventilated.
3.     Use the display environment command to identify whether the temperature in the router keeps rising.
For more information about the display environment command, see H3C SR6600/SR6600-X Routers Fundamentals Command Reference.
4.     If the temperature inside the router exceeds 90°C (194°F), power off the router immediately and contact H3C Support.
Interface module, cable, and connection failure
Symptom
After a HIM/MIM/MIC/MIC-X is installed and the router is powered on, the LEDs on the HIM/MIM/MIC/MIC-X panel might indicate abnormal operation.
Solution
1.     Verify that the HIM/MIM/MIC/MIC-X cable is correctly selected.
2.     Verify that the HIM/MIM/MIC/MIC-X cable is correctly connected.
3.     Use the display command to identify whether the interface on the interface module has been correctly configured and is operating correctly.
Software upgrade failures
No response from the serial port of the MPU
Symptom
The serial port of the MPU gives no response.
Solution
1.     Verify that the serial port settings are correct (whether the Bits per second field is set to 9600 kbps).
TFTP upgrade failure
Symptom
Start the router, and upgrade the software through TFTP. The following problems might occur:
·     The CF card has no enough space.
File will be transferred in binary mode
Downloading file from remote TFTP server, please wait...\
Failed to write data into storage device, maybe no enough space on device
·     The file to be downloaded is not found.
File not found.
·     The configuration of the network port is incorrect.
Can't connect to the remote host
Solution
1.     Delete some files in the CF card or use a new CF card so that enough space is available for the system software image.
2.     Type the correct file name.
3.     Configure the network port correctly, and make sure the network port is up and you can successfully ping the TFTP server from the network port.
FTP upgrade failure
Symptom
Start the router, and upgrade the software through FTP. The following problems might occur:
227 Entering Passive Mode (192,168,1,10,10,204)
150 "xxx" file ready to send (xxx bytes) in ASCII mode
FTP: Error Writing Local File(Screen).
227 Entering Passive Mode (192,168,1,10,10,203)
550 Error: File xxx does not exist
FTP: Unrecognized host or wrong IP address!
Solution
3.     Configure the network port correctly, and make sure the network port is up and you can successfully ping the FTP server from the network port.
System software image file missing errors
Symptom
When none of the main, backup, and secure system software image files exists, the system displays the following information at startup:
Application program does not exist.
Please input BootWare password:
If you select 1 on the main BootWare menu, the system displays the following information:
The main application file does not exist--cfa0:/main.bin!
Starting to get the backup application file--cfa0:/backup.bin!
The backup application file does not exist--cfa0:/backup.bin!
Starting to get the secure application file--cfa0:/secure.bin!
The secure application file does not exist--cfa0:/secure.bin!
Booting App fails!
The name of the main, backup, and secure system software image files vary by user settings.
Solution
To solve this issue:
1.     Download the software image again or set the file properties in the BootWare file list.
Chassis views
SR6604
CAUTION
CAUTION:
Do not use the handle on the rear cover to move the router chassis. This handle is designed to help you remove the rear cover and cannot support the chassis weight.
Figure 97 SR6604 front view (an RPE-X1 MPU installed)
(1) MPU slots (slot 0 and slot 1)
(2) Fan tray
(3) Service module/switching fabric module slots (slot 2 and slot 3)
(4) Power module slots
·     The SR6604 router installed with RPE-X3, RPE-X5, or RPE-X5E MPUs has the same front view as installed with RPE-X1 MPUs.
·     Before installing an RPE-X1, RPE-X3, RPE-X5, or RPE-X5E MPU, install a compatible carrier in the MPU slot.
Figure 98 SR6604 front view (an RSE-X1 MPU installed)
(1) MPU slot (slot 1)
(2) MPU/service module/switching fabric module slot (slot 2)
(3) Service module/switching fabric module slot (slot 3)
(5) Fan tray
Figure 99 SR6604 front view (an MCP-X1 installed)
(5) Fan tray
Figure 100 SR6604 front view (an MCP-X2 installed)
(5) Fan tray
Figure 101 SR6604 rear view
(1) Rear cover handle
(2) Air filter (optional)
(3) Chassis handle
(4) Grounding screw and sign
(5) Air vents
SR6608
CAUTION
CAUTION:
Figure 102 SR6608 front view (an RPE-X1 MPU installed)
(1) MPU slot (slot 0 and slot 1)
(2) Service module/switching fabric module slots (slot 2 through slot 5)
(3) Fan tray
·     The SR6608 router installed with RPE-X3, RPE-X5, or RPE-X5E MPUs has the same front view as installed with RPE-X1 MPUs.
Figure 103 SR6608 front view (an RSE-X1 MPU installed)
(3) Service module/switching fabric module slot (slot 3 through slot 5)
(5) Fan tray
Figure 104 SR6608 front view (an MCP-X1 installed)
(2) MPU/Service module/switching fabric module slot (slot 2)
(3) Service module/switching fabric module slots (slots 3 through 5)
(5) Fan tray
Figure 105 SR6608 front view (an MCP-X2 installed)
(5) Fan tray
Figure 106 SR6608-DS front view
(1) MPU slots (slots 0 and 1)
(2) Switching fabric module slot (slot 2)
(4) Service module slots (slots 4 and 5)
(5) Power module slots
(6) Fan tray
IMPORTANT
IMPORTANT:
·     An SFE-L2 switching fabric module is provided with the SR6608-DS router. As a best practice, install the module in slot 2. For the installation procedure, see "Installing a SAP/OAP/switching fabric module."
·     To install an SFE-L2 switching fabric module in slot 3 on the SR6608-DS router, first install an SFU carrier in the slot.
Figure 107 SR6608 rear view
(3) Chassis handle
(4) Grounding terminal and sign
(5) Air vents
Figure 108 SR6608-DS rear view
(2) Chassis handle
(3) Grounding terminal and sign
(4) Air vents
Dimensions and weights
Table 22 Dimensions and weights
Item
Specification
SR6604
SR6608
Height (H)
220 mm (8.66 in) (5 RU)
308 mm (12.13 in) (7 RU)
Width (W)
436 mm (17.17 in)
436 mm (17.17 in)
Depth (D)
480 mm (18.90 in)
476 mm (18.74 in)
Weight (full configuration)
38 kg (83.77 lb)
50 kg (110.23 lb)
Interface module slots
2
4
Table 23 Card weights and dimensions
Model
Net weight
Dimensions (H × W × D)
RPE-X1
1.4 kg (3.09 lb)
40 × 199 × 282 mm (1.57 × 7.83 × 11.10 in)
RPE-X3
0.85 kg (1.87 lb)
RPE-X5
0.95 kg (2.09 lb)
40 × 198.6 × 284.4 mm (1.57 × 7.82 × 11.20 in)
RPE-X5E
0.95 kg (2.09 lb)
RT-BKEB
N/A
44.1 × 376.6 × 414.8 mm (1.74 × 14.83 × 16.33 in)
RT-BKEC
N/A
RT-BKED
N/A
RT-BKEE
N/A
RSE-X1
3.4 kg (7.5 lb)
45 × 399 × 412 mm (1.77 × 15.71 × 16.22 in)
MCP-X1
3.5 kg (7.72 lb)
MCP-X2
3.5 kg (7.72 lb)
SFE-L1
2.1 kg (4.63 lb)
SFE-L2
0.65 kg (1.43 lb)
40.6 × 172 × 270 mm (1.60 × 6.77 × 10.63 in)
FIP-10
3 kg (6.61 lb)
FIP-110
3.25 kg (7.16 lb)
FIP-20
3 kg (6.61 lb)
FIP-210
3.35 kg (7.39 lb)
FIP-240
3.45 kg (7.61 lb)
FIP-260
3.55 kg (7.83 lb)
FIP-300
3.60 kg (7.94 lb)
FIP-310
3.60 kg (7.94 lb)
FIP-380
3.55 kg (7.83 lb)
FIP-600
3.55 kg (7.83 lb)
FIP-660
3.85 kg (8.49 lb)
FIP-680
3.9 kg (8.60 lb)
SAP-48GBE
3.8 kg (8.38 lb)
SAP-24GBP
3.3 kg (7.28 lb)
SAP-48GBP
3.65 kg (8.05 lb)
SAP-20GE2XP
3.65 kg (8.05 lb)
SAP-28GE
4.15 kg (9.15 lb)
SAP-XP4GE32
3.75 kg (8.27 lb)
Table 24 Power module weights and dimensions
Model
Net weight
PSR650-A
2.43 kg (5.36 lb)
41 × 140 × 340 mm (1.61 × 5.51 × 13.39 in)
PSR1200-A
2.6 kg (5.73 lb)
PSR650-D
2.25 kg (4.96 lb)
PSR1200-D
2.25 kg (4.96 lb)
Power consumption
Table 25 Card power consumption
Model
Min. power consumption
Max. power consumption
RPE-X1
12.60 W
16.40 W
RPE-X3
10.60 W
10.75 W
RPE-X5
8.99 W
9.97 W
RPE-X5E
14.23 W
15.58 W
RSE-X1
29 W
31.20 W
MCP-X1
50.11 W
52.32 W
MCP-X2
50.11 W
52.32 W
SFE-L1
12.20 W
13.80 W
SFE-L2
5 W
5 W
FIP-10
10.80 W
32.16 W
FIP-110
27.40 W
60 W
FIP-20
10.36 W
54.60 W
FIP-210
57.30 W
104.70 W
FIP-240
72 W
156 W
FIP-260
56.51 W
59.56 W
FIP-300
73.64 W
132.72 W
FIP-310
77.76 W
128.64 W
FIP-380
66.81 W
83.79 W
FIP-600
89.24 W
113.38 W
FIP-660
91.5 W
131.76 W
FIP-680
88 W
148 W
SAP-48GBE
116 W
162 W
SAP-24GBP
72.79 W
124.60 W
SAP-48GBP
102.67 W
132.60 W
SAP-20GE2XP
95.96 W
149.34 W
SAP-28GE
91.84 W
153.42 W
SAP-XP4GE32
79.3 W
96.38 W
Table 26 Fan power consumption
Model
Power consumption
SR6604 fan tray
28.30 W to 35.20 W
SR6608 fan tray
28.90 W to 36.11 W
Power modules
The router supports hot-swappable AC and DC power modules, but an AC power module and a DC power module cannot work together. You can install one power module or multiple power modules for redundancy, but the power modules in use must have the same specifications.
AC power modules
PSR650-A
Figure 109 PSR650-A view
(1) AC-input power receptacle
(2) Power switch
(3) Handle
(4) Power module status LED
Table 27 PSR650-A specifications
Item
Specification
Rated input voltage
100 VAC to 240 VAC @ 50 or 60 Hz
Maximum input current
10 A
Maximum power
650 W
PSR1200-A
Figure 110 PSR1200-A view
(2) Power switch
(3) Handle
Table 28 PSR1200-A specifications
Item
Specification
Rated input voltage
16 A
Maximum power
1213 W
DC power modules
PSR650-D
Figure 111 PSR650-D view
(1) DC-input terminal block
(2) Power switch
(3) Handle
Table 29 PSR650-D specifications
Item
Specification
Rated input voltage
–48 VDC to –60 VDC
25 A
Maximum power
650 W
PSR1200-D
Figure 112 PSR1200-D view
(1) Power module connector
(2) Power switch
(3) Handle
Table 30 PSR1200-D specifications
Item
Specification
Rated input voltage
–48 VDC to –60 VDC
42 A
Maximum power
1213 W
Fan trays
The fan tray structures of the SR6604 and SR6608 are similar.
Figure 113 SR6604 fan tray
Figure 114 SR6608 fan tray
(1) Fan tray status LED (RUN)
(2) Alarm LED (ALM)
(3) Handle
(4) Fans
Table 31 Fan tray specifications
Fan (built-in)
Specification
SR6604
SR6608
Rated voltage
12 VDC
Automatic fan speed adjustment
Supported
136.4 × 31 × 427.8 mm (5.37 ×1.22 × 16.84 in)
228 × 31 × 413.3 mm (8.98 ×1.22 × 16.27 in)
Failsafe
Supported
Hot swapping
Supported
MPUs
A main processing unit (MPU) calculates routes, manages the FIB, supervises and controls the system, and provides a precise system clock and the real time clock (RTC) function.
The RPE-X1, RPE-X3, RPE-X5, RPE-X5E, RSE-X1, MCP-X1, and MCP-X2 MPUs are available for the router. You can select them as needed.
If you order an RPE-X1, RPE-X3, RPE-X5, or RPE-X5E MPU, you must also order a compatible carrier. For the MPU carrier installation procedure, see "Installing an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU."
RPE-X1
Figure 115 RPE-X1 MPU
(1) Reset button (RESET)
(2) RUN LED
(3) Active/Standby LED (ACT)
(4) Alarm LED (ALM)
(5) LINK/ACT LED for the Ethernet management port
(6) Management Ethernet port (MANAGEMENT)
(7) Console port (CONSOLE)
(8) AUX port (AUX)
(9) Host-mode USB port 0 (0)
(10) Device-mode USB port 1 (1)
(11) USB 1 LED
(12) CF card LED
(13) CF card
(14) CF card button
Table 32 RPE-X1 specifications
Item
Specification
Flash
4 MB
Memory type and size
·     Default—One 1-GB DDR2 SDRAM
·     Maximum—Two 1-GB DDR2 SDRAMs
NVRAM
128 KB
Console port
1
9600 bps (default) to 115200 bps
AUX port
1
1 (10Base-T/100Base-TX/1000Base-T)
CF card
·     256 MB by default for the built-in CF card
·     256 MB, 512 MB, or 1 GB for an optional external CF card (CF cards less than 256 MB are not supported)
USB ports
2 (USB 0: Type A connector, operating in the host mode; USB 1: Type B connector, operating in the device mode)
Power consumption
37 W
Reset button
1
Hot swapping
Supported
·     The flash memory stores the BootWare image.
·     The SDRAM stores the running configuration and buffers data during data forwarding.
·     The non-volatile random access memory (NVRAM) stores system exception logs.
·     The CF card stores system software image and configuration files.
RPE-X3
Figure 116 RPE-X3 MPU
(1) USB port
(2) Management Ethernet port (MANAGEMENT)RUN LED
(3) MPU status LEDs
(4) Reset button (RESET)
(5) USB console port
(6) Console/AUX port (CONSOLE/AUX)
Table 33 RPE-X3 specifications
Item
Specification
Flash
8 MB
NVRAM
128 KB
Console port
1
Supports switching to AUX port
USB console port
1
USB port
1
Host mode, type A connector
Reset button
1
Hot swapping
Supported
·     SDRAM stores running configuration and buffers data during data forwarding.
·     Non-volatile random access memory (NVRAM) stores system exception logs.
RPE-X5
CAUTION
CAUTION:
If you connect a large-sized USB drive directly to the RPE-X5 MPU, the right ejector lever of the MPU might be damaged. You must use a USB extension cable to connect a large-sized USB drive to the USB port on the MPU.
Figure 117 RPE-X5 MPU
(1) USB port
(2) Console/AUX port
(3) Management Ethernet port (MANAGEMENT)
(4) Management Ethernet port LED
(5) MPU status LEDs
Table 34 RPE-X5 specifications
Item
Specification
Flash
4 GB
DDR4 SDRAM
Default: 4 GB
Console/AUX port
1, 9600 bps (default) to 115200 bps
USB port
1 USB 3.0 port (Host mode, Type A connector)
Hot swapping
Supported
RPE-X5E
CAUTION
CAUTION:
If you connect a large-sized USB drive directly to the RPE-X5E MPU, the right ejector lever of the MPU might be damaged. You must use a USB extension cable to connect a large-sized USB drive to the USB port on the MPU.
Figure 118 RPE-X5E MPU
(1) 10GBASE-R-SFP+ port (SFP+1)
(5) 10GBASE-R-SFP+ port (SFP+0)
(6) USB port
(7) MPU status LEDs
(8) Power button
Table 35 RPE-X5E specifications
Item
Specification
Flash
64 GB
DDR4 SDRAM
Default: 32 GB
Console/AUX port
10GBASE-R-SFP+ port
2
USB port
Power button
1
Hot swapping
Supported
RSE-X1
Figure 119 RSE-X1 MPU
(2) CF card button
(3) CF card
(4) CF card LED
(5) Host-mode USB port 0 (0)
(6) Device-mode USB port 1 (1)
(7) USB 1 LED
(8) LINK/ACT LED for the Ethernet management port
(9) Management Ethernet port (MANAGEMENT)
(10) Console port (CONSOLE)
(11) AUX port (AUX)
(12) Active/Standby LED (ACT)
(13) Power alarm LED (PALM)
(14) RUN LED
(15) System alarm LED (ALM)
Table 36 RSE-X1 specifications
Item
Specification
Flash
4 MB
·     Default—Two 1-GB DDR2 SDRAMs
·     Maximum—Two 2-GB DDR2 SDRAMs
NVRAM
128 KB
Console port
1
AUX port
1
CF card
USB ports
Reset button
1
Power consumption
75 W
Hot swapping
Supported
MCP-X1/MCP-X2
Figure 120 MCP-X1
(1) Combo interface 1
(2) Combo interface 3
(3) CF card slot (CF CARD)
(4) CF card LED (CF)
(5) Management Ethernet port (MANAGEMENT)
(6) Console port (CONSOLE)
(7) AUX port (AUX)
(8) Reset button (RESET)
(9) MCP-X1 status LED
(10) USB port
(11) Combo interface 2
(12) Combo interface 0
Figure 121 MCP-X2
(7) AUX port (AUX)
(9) MCP-X2 status LED
(10) USB port
(11) 10 Gbps Ethernet port
(12) Combo interface 2
(13) Combo interface 0
Table 37 MCP specifications
Item
Specification
Flash
8 MB
·     MCP-X1
¡     Default—One 2-GB DDR3 SDRAM
¡     Maximum—Two 2-GB DDR3 SDRAMs
·     MCP-X2
¡     DefaultTwo 2-GB DDR3 SDRAMs
NVRAM
128 KB
Combo interfaces
4
Copper ports (automatic MDI/MDI-X)
10 Mbps, half/full-duplex
100 Mbps, half/full-duplex
Fiber ports
1000 Mbps, full-duplex
10 Gbps Ethernet ports
·     MCP-X1—None
·     MCP-X22
Console port
1
AUX port
1
CF card
·     1 GB by default for the built-in CF card
USB port
1 (USB 0: Type A connector, operating in the host mode)
Reset button
1
Power consumption
53 W
Hot swapping
Supported
Components
CF card
A compact flash (CF) card stores logs, system software image files, and configuration files.
The router is equipped with a built-in CF card, which is identified with cfa0. In addition, the router provides an external CF card slot to expand the storage space.
The CF cards supported by the router are available in the following sizes:
·     256 MB
·     512 MB
·     1 GB
IMPORTANT
IMPORTANT:
·     Use CF cards provided by H3C only. The router might be incompatible with other CF cards.
·     CF cards less than 256 MB are not supported.
Console port
The router provides an RS232 asynchronous serial console port that can be connected to a computer for system debugging, configuration, maintenance, management, and host software loading.
Table 38 Console port specifications
Item
Specification
Connector
RJ-45
Standard compliant
Asynchronous EIA/TIA-232
Baud rate
Transmission distance
≤ 15 m (49.21 ft)
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC to run the terminal emulation program
·     Command line interface (CLI)
USB console port
You can connect a configuration terminal to the USB console port if the configuration terminal has a USB port but does not have a serial port. On the configuration terminal, you must install a USB device driver.
Table 39 USB console port specifications
Item
Connector type
USB Type AB
Interface standard
USB 2.0, full speed
Baud rate
User configurable (default: 9600 bps, maximum: 115200 bps)
Purposes
·     Connects to a character terminal.
·     Provides a connection to a local configuration terminal that has a USB port but does not have a serial port.
AUX port
The AUX port is an RS-232 asynchronous serial port used for remote configuration or dialup backup. You must connect the local modem to the remote modem through PSTN and then to the remote device for remote system debugging, configuration, maintenance, and management. In the event that the console port fails, the AUX port can be connected to a terminal as a backup port of the console port.
Table 40 AUX port specifications
Item
Specification
Connector
RJ-45
Standard compliant
Baud rate
Services
Connects the serial port of a remote PC through a pair of modems to establish a dial-up connection with the PC
The dialup function for an AUX port is supported only on Comware 5. For MPU and Comware compatibility, see "MPU and Comware compatibility matrix."
The management Ethernet port is a 10Base-T/100Base-TX/1000Base-T RJ-45 port. It allows you to upgrade software and manage the router through a network management server without using any service interfaces of the router. The management Ethernet port is used only for managing the router and it does not have service processing capabilities such as data forwarding.
Table 41 Management Ethernet port specifications
Item
Specification
Connector
RJ-45
Interface type
Automatic MDI/MDI-X
Number of interfaces
1
Frame format
Ethernet_II
Ethernet_SNAP
Interface speed and duplex mode
Interface cable and maximum transmission distance
Category-5 twisted pair with a maximum transmission distance of 100 m (328.08 ft)
Function
Used for router software upgrade and network management
The media dependent interface (MDI) standard is typically used on the Ethernet port of network adapters. The media dependent interface crossover (MDI-X) standard is typically used on hubs or LAN switches.
Combo interface
The MCP provides four combo interfaces.
Table 42 Copper Ethernet port specifications
Item
Specification
Connector
RJ-45
Interface type
Automatic MDI/MDI-X
Frame format
Ethernet_II
Ethernet_SNAP
·     The media dependent interface (MDI) standard is typically used on the Ethernet port of network adapters. The media dependent interface crossover (MDI-X) standard is typically used on hubs or LAN switches.
·     For a combo interface, you can use either the copper port or the fiber port. To switch between the copper and fiber ports, use the combo enable { copper | fiber } command in interface view.
Table 43 Fiber Ethernet port specifications
Item
Specification
Connector type
LC
SFP
Interface standards
802.3, 802.3u, and 802.3ab
Operating mode
1000 Mbps, full duplex
The MCP-X2 provides two 10 Gbps Ethernet ports. 10 Gbps SFP+ ports do not support 1000 Mbps transceiver modules.
Table 44 10 Gbps Ethernet port specifications
Item
Specification
Protocol
802.3ae
Connector type
LC
SFP+
Physical layer
10GBASE-R/W
Transmission rate
·     LAN PHY—10.3125 Gbps
·     WAN PHY—9.95328 Gbps
10GBASE-R-SFP+ port
Item
Specification
Connector type
LC
SFP+
Interface standards
802.3ae
Operating mode
10 Gbps, full duplex
RESET button
CAUTION
CAUTION:
·     If you perform no save operation before resetting the router, the current system configuration will be lost.
·     Never press the RESET button when the RUN LED is flashing fast or when the router is accessing the CF card or a USB storage device. Otherwise, the file system of the router might be damaged.
To reset the current MPU, press the RESET button.
·     If you press the RESET button when only one MPU is equipped, the whole system will be reset.
·     To perform an active/standby switchover when two MPUs are equipped, press the RESET button on the active MPU. The system automatically switches the services to the standby MPU, without interrupting the ongoing services.
·     If you press the RESET button on the standby MPU when two MPUs are equipped, the standby MPU will be reset but the system operation will not be affected.
The RUN LED goes off when the MPU is reset, flashes fast (at 8 Hz) when BootWare is running, and flashes slowly (at 1 Hz) after the system is booted and operates correctly.
Power button
WARNING
WARNING!
The device might still have power after you press the power button. Do not reboot the RPE-X5E MPU or remove power cords from the RPE-X5E MPU until the power button/LED goes off.
CAUTION
CAUTION:
·     Forced power-off might cause data loss in virtual machines. Please use it with caution.
·     Avoid accidentally pressing the power button when the device is operating. Doing so will power off the device system and cause service interruption.
·     If a virtual machine cannot be shut down gracefully, log in to it, terminate the running processes, and then shut down it.
The power button is used to power on or power off the Comware system and virtual machines created on the Comware system.
To gracefully shut down the Comware system when the device is operating, press and hold the power button for 0.5 to 3 seconds. To forcibly shut down the Comware system, press and hold the power button for more than 3 seconds.
By default, pressing the power button on a powered-off device starts the Comware system but not the virtual machines. You can use the autostart command to configure the virtual machines to be started together with the Comware system.
Typically, you can use the reboot command to reboot the RPE-X5E MPU. However, if the RPE-X5E MPU is powered off by pressing the power button, you need to press the power button to turn it on and then execute the reboot command.
Switching fabric modules
The SR6600 router supports switching fabric modules only when it is installed with RPE-X3, RPE-X5, or RPE-X5E MPUs.
SFE-L1
Front panel
Figure 122 SFE-L1 front panel
(1) Captive screw
(2) Ejector lever
(3) Switching fabric module status LED (RUN)
Technical specifications
Table 45 SFE-L1 specifications
Item
Specification
DDR2 SDRAM
2 GB
NVRAM
128 KB
Hot swapping
Supported
Compatible device models
All SR6600 routers except for the SR6608-DS
SFE-L2
Front panel
Figure 123 SFE-L2 front panel
(1) Captive screw
(2) Switching fabric module status LED (RUN)
(3) Ejector lever
Table 46 SFE-L2 specifications
Item
Specification
DDR2 SDRAM, 128 MB
NVRAM
128 KB
Hot swapping
Supported
SR6608-DS
Flexible interface platform modules
IMPORTANT
IMPORTANT:
Use transceiver modules for the service modules provided by H3C only. The router might be incompatible with transceiver modules from other vendors. The system generates an alarm when a transceiver module from another vendor is installed.
The router does not support the FIP-600 in ESS 7821P09 or later.
Each combo interface on the service modules has a fiber port and a copper port. Only one port is activated at a time. By default, the fiber port is activated. To activate a port, use the combo enable { copper | fiber } command in interface view. For more information about the combo enable { copper | fiber } command, see H3C SR6600/SR6600-X Routers Interface Command Reference(V7).
A flexible interface platform module is a processing engine and you can install different interface modules in a FIP to support different network services as needed. This section describes the FIP modules available for the H3C SR6604 and SR6608 routers.
When you order or install a FIP, use Table 69 to check the FIP and MPU compatibility.
FIP-10
The FIP-10 supports only MIMs, and you can plug at most four MIMs into a FIP.
Front panel
Figure 124 FIP-10 front panel
(1) Slot 4
(2) Slot 3
(3) OPEN BOOK mark
(4) Status LED (RUN)
(5) Slot 1
(6) Slot 2
The OPEN BOOK mark indicates that the operator must read the following sections before working with the FIP:
Table 47 References for FIP operations
Operation
Reference
Install and remove the FIP
See "Installing a FIP module" and "Replacing a FIP module."
Install and remove MIMs
See "Installing a HIM/MIM/MIC/MIC-X interface module" and "Replacing a HIM/MIM/MIC/MIC-X."
Connect network cables
See "Connecting an Ethernet cable."
Connect optical fibers
See "Connecting a fiber cable."
Item
Specification
HIM
Not supported
MIM
4 MIMs supported at the same time
MIC
Not supported.
Hot-swapping
Supported
Slot
Four
FIP-20
You can plug up to two HIMs or two MIMs into the FIP-20. The FIP-20 also supports intermix of a HIM and a MIM.
Front panel
Figure 125 FIP-20 front panel
(1) Slot 2
(2) Slot 1
(3) Status LED
(4) OPEN BOOK mark
Table 48 References for FIP operations
Operation
Reference
Install and remove interface modules
Item
Specification
HIM
2 HIMs supported
MIM
2 MIMs supported
MIC
Not supported
Hot swapping
Supported
2
FIP-110
You can plug up to four MIMs into the FIP-110 to provide high-density narrowband aggregation and protect the investment in the MIMs for MSR routers.
Front panel
Figure 126 FIP-110 front panel
(1) Slot 4
(2) Slot 3
(3) Combo interface 1
(4) Combo interface 0
(5) Slot 1
(6) Slot 2
(7) OPEN BOOK mark
The OPEN BOOK mark indicates that the operator must read the following chapters before working with the FIP:
Table 49 References for FIP operations
Operation
Reference
Item
Specification
Flash
4 MB
·     DefaultTwo 1-GB DDR2 SDRAMs
NVRAM
128 KB
Combo interfaces
2
2 copper ports (automatic MDI/MDIX)
2 fiber ports
HIM
Not supported
MIM
MIC
Not supported
Hardware encryption
Supported
Power consumption
75 W
Hot-swapping
Supported
Combo interface specifications
Table 50 FIP-110 copper Ethernet port specifications
Item
Specification
Connector
RJ-45
Interface type
Autosensing
Supported frame format
Ethernet_II
Ethernet_SNAP
10 Mbps
Half/full duplex, auto-negotiation
100 Mbps
1000 Mbps
Full duplex, auto-negotiation
Table 51 FIP-110 fiber Ethernet port specifications
Item
Specification
Connector
LC
SFP
Interface standards
Duplex mode
FIP-210
You can plug up to two HIMs into the FIP-210 to provide high-speed service processing or plug up to two MIMs into the FIP to provide high-density narrowband aggregation. The FIP-210 also supports the mix of a HIM and a MIM.
Front panel
Figure 127 FIP-210 front panel
(2) Combo interface 0
(3) Slot 1
(4) Slot 2
(5) OPEN BOOK mark
Table 52 References for FIP operations
Operation
Reference
Item
Specification
Flash
4 MB
NVRAM
128 KB
Combo interfaces
2
2 fiber ports
HIM
2 HIMs supported
MIM
2 MIMs supported
MIC
Not supported
Hardware encryption
Supported
Hot swapping
Supported
Specifications of combo interfaces on the FIP-210 and the FIP-110 are the same. For more information, see Table 50 and Table 51.
FIP-240
The FIP-240 provides two combo interfaces. It supports HIMs, MIMs, or a mix of HIMs and MIMs.
Front panel
Figure 128 FIP-240 front panel
(1) Slot 4
(2) Slot 3
(5) Slot 1
(6) Slot 2
Item
Specification
Flash
8 MB
·     Default—One 2-GB DDR3 SDRAM
·     Maximum—Two 2-GB DDR3 SDRAMs
NVRAM
128 KB
Combo interface
2
2 copper ports (MDI/MDIX autosensing)
2 fiber ports
MIM
4 supported
HIM
2 full-height or 4 half-height HIMs supported
Half-height HIMs include the following models:
·     HIM-4G4P.
·     HIM-TS8P.
·     HIM-8GBP-V2.
·     HIM-8GBP-V3.
·     HIM-4GBP-V3.
·     HIM-8GBE-V3.
·     HIM-4GBE-V3.
MIC
Not supported
Hardware encryption
Supported
Hot swapping
Supported
Specifications of combo interfaces on the FIP-240 and the FIP-110 are the same. For more information, see Table 50 and Table 51.
FIP-260
A FIP-260 provides four MIC-X interface module slots.
Front panel
Figure 129 FIP-260 front panel
(1) Captive screw
(2) Slot 4
(3) Slot 3
(4) Ejector lever
(5) Slot 1
(6) Slot 2
Item
Specification
4GB DDR4
Drive
(Optional) 512 GB mSATA SSD
The mSATA hard disk with SSC enabled is not supported on the FIP-260.
MIM
Not supported
HIM
Not supported
MIC
Not supported
MIC-X
A maximum of 4
Hardware encryption
Supported
Hot swapping
Supported
FIP-300
The FIP-300 provides twelve combo interfaces. It supports HIMs, MIMs, or a mix of HIMs and MIMs.
Front panel
Figure 130 FIP-300 front panel
(1) HIM/MIM slot
(2) GE0 through GE11 copper port status LEDs
(3) GE0 through GE11 fiber ports
(4) RUN LED
(5) GE0 through GE11 copper ports
(6) Ejector lever
(7) Captive screw
Item
Specification
Flash
8 MB
·     DefaultTwo 2-GB DDR3 SDRAMs
The SDRAMs must be used in pairs and must be the same size.
NVRAM
128 KB
Combo interface
12
Copper ports (MDI/MDIX autosensing)
Fiber ports
HIM
1
MIM
1
MIC
Not supported
Hardware encryption
Supported
Hot swapping
Supported
Specifications of combo interfaces on the FIP-300 and the FIP-110 are the same. For more information, see Table 50 and Table 51.
FIP-310
The FIP-310 provides four combo interfaces and two SFP+ ports. It supports HIMs, MIMs, or a mix of HIMs and MIMs.
Front panel
Figure 131 FIP-310 front panel
(2) Combo interface status LED
(3) Combo interface 3
(4) SFP+ port 0
(5) SFP+ port 1
(6) RUN LED
(7) SFP+ port 1 status LED
(8) SFP+ port 0 status LED
(9) Combo interface 2
(10) Combo interface 0
(11) HIM/MIM slot
(12) Ejector lever
(13) Captive screw
Item
Specification
Flash
8 MB
They must be inserted in slot 1 or slot 3. These two slots are located near the backplane connectors on the FIP module.
NVRAM
128 KB
Combo interfaces
2
2 fiber ports
10G Ethernet port
2
HIM
1
MIM
1
MIC
Not supported
Hardware encryption
Supported
Hot-swapping
Supported
Specifications of combo interfaces on the FIP-310 and the FIP-110 are the same. For more information, see Table 50 and Table 51.
10GE port specifications
Table 53 FIP-310 10GE port specifications
Item
Specification
Connector
LC
Transceiver module type
SFP+
Interface standards
802.3ae
Duplex mode
FIP-380
A FIP-380 delivers high-speed service processing capability. It provides two 10GBASE-R-SFP+ ports, fourteen 1000BASE-X-SFP ports, and eight 100/1000BASE-T copper ports. It supports MIC-X interface modules.
Front panel
Figure 132 FIP-380 front panel
(1) Captive screw
(2) Slot 2
(3) 10GBASE-R-SFP+ ports SFP+22 and SFP+23
(4) 1000BASE-X-SFP ports SFP0 to SFP13
(5) 100/1000 BASE-T Ethernet copper ports GE14 to GE21
(6) Ejector lever
(7) Slot 1
Item
Specification
8GB DDR4
Drive
The mSATA hard disk with SSC enabled is not supported on the FIP-380.
2
14
100/1000BASE-T ports
8
HIM
Not supported
MIM
Not supported
MIC
Not supported
MIC-X
A maximum of 2
Hardware encryption
Supported
Hot swapping
Supported
10GBASE-R-SFP+ port specifications
Table 54 FIP-380 10GBASE-R-SFP+ port specifications
Item
Specification
Connector
LC
SFP+
Interface standards
802.3ae
Duplex mode
1000BASE-X-SFP port specifications
Table 55 FIP-380 1000BASE-X-SFP port specifications
Item
Specification
Connector
LC
SFP
Interface standards
Duplex mode
100/1000BASE-T Ethernet copper port specifications
Table 56 FIP-380 100/1000BASE-T Ethernet copper port specifications
Item
Specification
Connector
RJ-45
Interface type
Autosensing
100 Mbps
1000 Mbps
FIP-600
The FIP-600 provides four combo interfaces. It supports a maximum of two HIMs.
Front panel
Figure 133 FIP-600 front panel
(3) Slot 1
(4) Slot 2
(5) OPEN BOOK mark
Item
Specification
Flash
8 MB
NVRAM
128 KB
Combo interfaces
2
2 fiber ports
HIM
2
MIM
Not supported
MIC
Not supported
Hardware encryption
Supported
Hot-swapping
Supported
Specifications of combo interfaces on the FIP-600 and the FIP-110 are the same. For more information, see Table 50 and Table 51.
FIP-660
A FIP-660 provides four MIC-X interface module slots. When installing a FIP-660, if a service module slot adjacent to the FIP-660 is empty, install an air deflector over the slot.
Front panel
Figure 134 FIP-660 front panel
(1) Captive screw
(2) Slot 4
(3) Slot 3
(4) Ejector lever
(5) Slot 1
(6) Slot 2
Air deflector
Figure 135 FIP-660 air deflector
Item
Specification
16GB DDR4
Drive
Not supported
MIM
Not supported
HIM
Not supported
MIC
Not supported
MIC-X
A maximum of 4
Hardware encryption
Supported
Hot swapping
Supported
FIP-680
The FIP-680 provides 4 SFP+ ports, 12 SFP ports, and 8 copper GE ports. It supports a maximum of two MICs.
Front panel
Figure 136 FIP-680 front panel
(1) Interface module slot
(2) 10GBASE-R-SFP+ ports (4 in total)
(3) 1000BASE-X-SFP ports (12 in total)
(4) 10/100/1000BASE-T copper Ethernet ports (8 in total)
(5) Module status LED (RUN)
(6) 10/100/1000BASE-T copper Ethernet port status LED
Item
Specification
·     DefaultTwo 4-GB DDR3 SDRAMs
·     Maximum—Two 4-GB DDR3 SDRAMs
NVRAM
128 KB
10GE fiber ports (SFP+)
4
GE fiber ports (SFP)
12
Copper Ethernet ports
8
10/100/1000M autosensing
HIM
Not supported
MIM
Not supported
MIC
2
Hardware encryption
Supported
Hot-swapping
Supported
10GE SFP+ port specifications
Table 57 FIP-680 10GE SFP+ port specifications
Item
Specification
Connector
LC
SFP+
Synchronous Ethernet
Not supported
1588v2.2
Not supported
Interface standards
802.3ae
Duplex mode
GE SFP port specifications
Table 58 FIP-680 GE SFP port specifications
Item
Specification
Connector
LC
SFP
Not supported
1588v2.2
Not supported
Interface standards
Duplex mode
Table 59 FIP-680 copper Ethernet port specifications
Item
Specification
Connector
RJ-45
Interface type
Autosensing
Ethernet_II
Ethernet_SNAP
10 Mbps
100 Mbps
1000 Mbps
Service aggregation platform modules
IMPORTANT
IMPORTANT:
A service aggregation platform (SAP) module provides network ports for receiving packets from the network and sending packets to the network. This section describes the SAPs available for the H3C SR6604 and SR6608 routers.
SAP-48GBE
The SAP-48GBE has 48 high-performance RJ-45 ports that can be both routed and switched. One two-color LED is available for each port to indicate their activity and link status. The module also has a RUN LED to indicate the module operating status.
Front panel
Figure 137 SAP-48GBE front panel
(1) LEDs for GE ports 0 to 47
(2) SAP module status LED (RUN)
(3) GE ports 0 to 47
(4) Ejector levers
(5) Captive screw
Item
Specification
Flash
4 MB
NVRAM
128 KB
Max power consumption
200 W
Connector type
RJ-45
48
Interface standards
Interface type
Automatic MDI/MDIX
Cable type
Straight-through/crossover Ethernet cable
100 m (328.08 ft)
Ethernet_II
Ethernet_SNAP
10 Mbps
Full/half duplex, auto-negotiation
100 Mbps
1000 Mbps
SAP-24GBP
The SAP-24GBP has 24 high-performance fiber SFP ports that can be both routed and switched. One two-color LED is available for each port to indicate their activity and link status. The module also has a RUN LED to indicate the module operating status.
Front panel
Figure 138 SAP-24GBP front panel
(1) SFP ports 0 to 23
(3) LEDs for SFP ports 0 to 23
(4) Ejector levers
(5) Captive screw
Item
Specification
Flash
4 MB
NVRAM
128 KB
150 W
Connector type
SFP
24
Interface standards
Ethernet_II
Ethernet_SNAP
Interface speed
1000 Mbps (recommended)
Full duplex
Fixed Ethernet port specifications
Specifications of the SAP-24GBP fixed Ethernet ports and the FIP-110 fiber combo ports are the same. For more information, see Table 51.
SAP-48GBP
The SAP-48GBP has 48 high-performance fiber SFP ports that can be both routed and switched. One two-color LED is available for each port to indicate their activity and link status. The module also has a RUN LED to indicate the module operating status.
Front panel
Figure 139 SAP-48GBP front panel
(1) SFP ports 0 to 47
(3) LEDs for SFP ports 0 to 47
(4) Ejector levers
(5) Captive screw
Item
Specification
Flash
4 MB
NVRAM
128 KB
144 W
Connector type
SFP
48
Interface standards
Ethernet_II
Ethernet_SNAP
Interface speed
Full duplex
Specifications of the SAP-48GBP fixed Ethernet ports and the FIP-110 fiber combo ports are the same. For more information, see Table 51.
SAP-20GE2XP
Front panel
Figure 140 SAP-20GE2XP front panel
(1) SFP ports (GE0 to GE15)
(2) Combo interfaces (GE16 to GE19)
(3) SFP+ port 0
(4) SFP+ port 1
(5) Operating status LED (RUN)
Item
Specification
Flash
8 MB.
·     Default—Two 2-GB DDR3 SDRAMs.
·     MaximumFour 2-GB DDR3 SDRAMs.
NVRAM
128 KB.
SFP ports
16 × SFP ports, 100/1000 Mbps auto-sensing.
Combo interfaces
Four.
·     Copper portStraight-through/crossover autosensing:
¡     10/100 Mbps, half/full-duplex.
¡     1000 Mbps, full-duplex.
·     Fiber port—1000 Mbps, full-duplex.
10G SFP+ ports
2.
Hot swapping
Supported.
Table 60 SFP port specifications
Item
Specification
Connector type
LC
SFP
Network synchronization
Supported
1588v2.2 protocol
Supported
Interface standards
Operating mode
Table 61 Copper combo port specifications
Item
Specification
Connector type
RJ-45
Interface type
Auto MDI/MDI-X
Frame format supported
·     Ethernet_II
·     Ethernet_SNAP
10 Mbps auto-sensing
100 Mbps auto-sensing
For the fiber combo port specifications, see Table 60.
Table 62 SFP+ port specifications
Item
Specification
Connector type
LC
Transceiver module
SFP+
Supported
1588v2.2 protocol
Supported
Interface standards
802.3ae
Operating mode
SAP-28GE
Front panel
Figure 141 SAP-28GE front panel
(2) Combo interfaces (GE16 to GE27)
(3) Operating status LED (RUN)
Item
Specification
Flash
8 MB.
NVRAM
128 KB.
SFP ports
Combo interfaces
12.
Hot swapping
Supported.
Table 63 SFP port specifications
Item
Specification
Connector type
LC
SFP
Supported
1588v2.2 protocol
Supported
Interface standards
Operating mode
Table 64 Copper combo port specifications
Item
Specification
Connector type
RJ-45
Interface type
Auto MDI/MDI-X
·     Ethernet_II
·     Ethernet_SNAP
For the fiber combo port specifications, see Table 63.
SAP-XP4GE32
Front panel
Figure 142 SAP-XP4GE32 front panel
(1) Captive screw
(2) 10/100/1000Base-T Ethernet copper ports GE0 to GE11
(3) Combo interfaces GE12 to GE23
(4) 1000BASE-X-SFP ports SFP24 to SFP31
(5) 10GBASE-R-SFP+ ports SFP+32 to SFP+35
(6) Operating status LED (RUN)
(7) Ejector lever
Item
Specification
8GB DDR4
Built-in hard disk
The mSATA hard disk with SSC enabled is not supported on the SAP-XP4GE32.
Transceiver modules
·     8 × 1000BASE-X-SFP ports
·     4 ×10GBASE-R-SFP+ ports
12 × 10/100/1000Base-T Ethernet copper ports
Combo interfaces
12
Hot swapping
Supported.
Table 65 10/100/1000BASE-T Ethernet copper port specifications
Item
Specification
Connector type
RJ-45
Interface type
Autosensing
10 Mbps
100 Mbps
1000 Mbps
Table 66 1000BASE-X-SFP port specifications
Item
Specification
Connector type
LC
SFP
Interface standards
Operating mode
Table 67 10GBASE-R-SFP+ port specifications
Item
Specification
Connector type
LC
SFP+
Interface standards
802.3ae
Operating mode
For the copper combo port specifications, see Table 65.
For the fiber combo port specifications, see Table 66.
Transceiver modules
For more information about transceiver modules supported by the SR6604 and SR6608 switches, see H3C SR6600/SR6600-X Routers Interface Module Guide.
Lightning protector for a port
Port protective unit–single port, maximum discharge current (8/20μs waveform): 5 kA, output voltage (10/700μs waveform): core-core < 40 V, core-ground < 600 V.
For how to install the port lightning protector, see "Installing a lightning protector for a network port."
If part of the network cable of a copper Ethernet port must be routed outdoors, connect a lightning protector to the cable before you plug the cable into the port.
·     Lightning protector for 10/100 Mbps copper Ethernet ports—Single port, residual pulse energy (8/20μs test pulse) 2.5 KA, output voltage (8/20μs waveform): core-core ≤ 15 V, core-ground ≤ 300 V.
·     Lightning protector for 1000 Mbps copper Ethernet ports—Single port, residual pulse energy (8/20μs test pulse) 3 KA, output voltage (8/20μs waveform): core-core ≤ 15 V, core-ground ≤ 300 V.
Power strip with lightning protection
If part of the AC power line is routed outdoors, use a power strip with lightning protection to connect the AC power cord of the router to the AC power line to protect the router from being damaged by lightning strikes.
You can attach the power strip to the rack, workbench, or wall of equipment room.
The specifications for the power strip with lightning protection that can be installed on the router are as follows:
Maximum discharge current: 6500 A, protection voltage: 500 VAC to 220 VAC.
For how to install the power lightning protector, see "Connecting the AC power supply to a power strip with lightning protection."
Surge lightning protector
Generally, you need to connect a surge protector before connecting a signal cable to the router. This can protect electronic devices against surge over-voltage resulting from lightning strokes and other interferences, and minimize impact on the router.
The router supports the following types of surge protectors:
·     Surge protector—Maximum discharge current 2.5KA/protection voltage 25V--SMB-75J/ SMB-75J-1W-10Mbps
·     Surge protector—Maximum discharge current 2.5KA/protection voltage 25V-BNC-75K/ BNC-75K-10Mbps
·     Surge protector (U port)—Maximum discharge current 3KA/common-mode 400V/differential mode 170V-RJ11
For how to install the signal lightning arrester, see "Installing a surge protector (optional)."
Appendix B Hardware compatibility matrixes
In the compatibility matrixes, "√" means "Supported" and "×" means "Not supported."
Table 68 MPU and Comware compatibility matrix
MPU
Comware 5
Comware 7
RPE-X1
RPE-X3
RPE-X5
RPE-X5E
RSE-X1
MCP-X1
MCP-X2
Service module and MPU compatibility matrix
Table 69 Service module and MPU compatibility matrix
Service module
RPE-X1
RPE-X3
RPE-X5
RPE-X5E
RSE-X1
MCP-X1
MCP-X2
FIP-10
FIP-20
FIP-110
FIP-210
FIP-240
FIP-260
FIP-300
FIP-310
FIP-380
FIP-600
FIP-660
FIP-680
SAP-48GBE
SAP-24GBP
SAP-48GBP
SAP-20GE2XP
SAP-28GE
SAP-XP4GE32
SPE-FWM-200
SPE-SSL-200
Interface module and Comware compatibility matrix
Table 70 Interface module and Comware compatibility matrix
Interface module
Comware 5
Comware 7
SAPs
SAP-48GBE
SAP-24GBP
SAP-48GBP
SAP-20GE2XP
SAP-28GE
SAP-XP4GE32
OAPs
SPE-FWM-200
SPE-SSL-200
Appendix C LEDs
The MPUs, switching fabric modules, FIPs, SAPs, HIM/MIM/MICs, power modules, and fan trays available for the router provide various LEDs to indicate the operating status.
Table 71 H3C SR6604 and SR6608 routers LEDs
LED
Remarks
RPE-X1 LEDs
Run LED (RUN)
See Table 72.
Active LED (ACT)
Alarm LED (ALM)
Management Ethernet port LED (LINK/ACT)
USB port LED (USB)
CF card LED (CF)
RPE-X3 LEDs
See Table 73.
Alarm LED (ALM)
Active LED (ACT)
Run LED (RUN)
RPE-X5 LEDs
Run LED (RUN)
See Table 74.
IRF LED (IRF)
Management Ethernet port LED (MANAGEMENT)
Alarm LED (ALM)
Active LED (ACT)
RPE-X5E LEDs
Run LED (RUN)
See Table 75.
IRF LED (IRF)
10GBASE-R-SFP+ port (SFP+0 and SFP+1)
Alarm LED (ALM)
Active LED (ACT)
Power button
RSE-X1 LEDs
Run LED (RUN)
See Table 76.
Active LED (ACT)
Alarm LED (ALM)
USB port LED (USB)
CF card LED (CF)
MCP-X1 LEDs
10/100/1000 Mbps copper Ethernet port LEDs (GE0 through GE3)
See Table 77.
CF card LED (CF)
Run LED (RUN)
Active LED (ACT)
Alarm LED (ALM)
1000 Mbps fiber Ethernet port LED (SFP0 through SFP3)
MCP-X2 LEDs
See Table 78.
CF card LED (CF)
Run LED (RUN)
Active LED (ACT)
Alarm LED (ALM)
10 Gbps Ethernet port LED (SFP+LINK/ACT)
Switching fabric module LEDs
Run LED (RUN)
See Table 79.
FIP LEDs
Run LED (RUN)
See Table 81.
10/100/1000 Mbps copper Ethernet port LED (GE0 and GE1)
1000 Mbps fiber Ethernet port LED (SFP0 and SFP1)
SAP LEDs
Run LED (RUN)
See Table 88 and Table 89.
10/100/1000 Mbps Ethernet port LED
HIM/MIM/MIC/ MIC-X LEDs
See H3C SR6600/SR6600-X Routers Interface Module Guide.
Power module LEDs
Power LED
See Table 94.
Fan tray LEDs
Run LED (RUN)
See Table 95.
Alarm LED (ALM)
MPU LEDs
CAUTION
CAUTION:
To avoid damaging the file system on the CF card, do not remove the CF card when the CF LED is flashing.
Figure 143 LEDs on the RPE-X1
Table 72 RPE-X1 LED description
LED
Status
(green)
RUN
Off
No power input is available, or the RPE-X1 has failed.
Slow flashing (1 Hz)
The RPE-X1 is operating correctly.
Fast flashing (8 Hz)
The application software is being loaded (in this case, never power off the device or hot-swap the RPE-X1; otherwise the RPE-X1 might be damaged).
(green)
ACT
Off
The RPE-X1 is in standby state.
Steady on
The RPE-X1 is in active state.
(red)
ALM
Off
The system is operating correctly and no alarm has occurred.
Steady on
A fault has occurred on the system or the available power is insufficient. In this state, check the system log immediately.
A critical fault has occurred to the system. In this state, handle the fault immediately.
(yellow/green)
LINK/ACT
Steady yellow
A 10/100 Mbps link is present.
Steady green
A 1000 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 10/100 Mbps.
Flashing green
Data is being received or transmitted at 1000 Mbps.
(green)
CF
Off
No CF card is present or the CF card is not recognizable.
Steady on
A CF card is in position and has been detected.
Flashing
The system is accessing the CF card. In this state, do not remove the CF card.
(green)
USB
Off
No host is connected to the device-mode USB port.
Steady on
A host is connected to the device-mode USB port. The USB cable can be unplugged in this state.
Flashing
Data is being transmitted or received through the device-mode USB port. In this state, do not unplug the USB cable.
Figure 144 RPE-X3 LEDs
Table 73 RPE-X3 LED description
LED
Status
(yellow/green)
LINK/ACT
Steady yellow
Steady green
Flashing yellow
Flashing green
(red)
ALM
Off
Steady on
A fault has occurred on the system.
(red)
PALM
Off
Steady on
(green)
ACT
Off
The MPU is in standby state.
Steady on
The MPU is in active state.
(green)
RUN
Off
No power input is available, or the MPU has failed.
The MPU is operating correctly.
The system software is being loaded. To avoid damage to the MPU, never power off the device or hot-swap the MPU.
Figure 145 LEDs on the RPE-X5
Table 74 RPE-X5 LED description
LED
Status
(yellow/green)
RUN
Fast flashing green
BIOS stage
The BIOS is operating correctly.
Slow flashing yellow
No or insufficient memory or initialization failure.
Fast flashing yellow
The extended segment does not exist.
Off
Hardware failure or no power input.
Steady green
BootWare stage
The SDRAM is performing self-test.
Fast flashing green
The BootWare runs.
Slow flashing green
The Comware system has started with the configuration file and the system is operating correctly.
Steady yellow
The boot image does not exist.
The SDRAM has failed the self-test.
Off
Slow flashing green
Comware stage
The system is operating correctly.
Fast flashing green (5 seconds)
USB-based automatic configuration has succeeded.
(red)
PALM
Steady on
The system power is insufficient.
Off
The power system is operating correctly.
(yellow/green)
IRF
Slow flashing green
The device is in IRF mode and the MPU is the global active MPU.
Steady green
The device is in IRF mode and the MPU is a standby MPU.
Steady yellow
The device is in IRF mode but the IRF configuration has failed.
Off
The device is in standalone mode.
(yellow/green)
MANAGEMENT
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 100 Mbps.
Off
No link is present or the port is faulty.
(red)
ALM
Fast flashing (10 seconds)
USB-based automatic configuration has failed.
Steady on
Off
(green)
ACT
Steady on
Off
Figure 146 LEDs on the RPE-X5E
Table 75 RPE-X5E LED description
LED
Status
(yellow/green)
RUN
Fast flashing green
BIOS stage
Off
Steady green
BootWare stage
Fast flashing green
The BootWare runs.
Slow flashing green
Steady yellow
Off
Slow flashing green
Comware stage
(red)
PALM
Steady on
Off
(yellow/green)
IRF
Slow flashing green
Steady green
Steady yellow
Off
(green)
SFP+0 and SFP+1
Steady green
After a link is set up, using the command to bring up or shut down the port does not change the LED status.
A 10 Gbps link is present.
Flashing green
Data is being received or transmitted at 10000 Mbps.
Off
No link is present.
(yellow/green)
MANAGEMENT
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
(red)
ALM
Steady on
Off
(green)
ACT
Steady on
Off
(red/green)
Power button
Fast flashing red
The MPU has been powered up to start up the Comware system.
Slow flashing red
The BIOS is starting up.
Slow flashing green
The BootWare is starting up.
Steady green
The Comware system starts up and is operating correctly.
Fast flashing green
The power button has been pressed and the Comware system starts to shut down.
Steady red
The shutdown of the Comware system is in progress.
Off
The Comware system has shut down.
Figure 147 RSE-X1 LEDs
Table 76 RSE-X1 LED description
LED
Status
(green)
CF
Off
Steady on
Flashing
(green)
USB
Off
Steady on
Flashing
 (yellow/green)
LINK/ACT
Steady yellow
Steady green
Flashing yellow
Flashing green
(green)
ACT
Off
The RSE-X1 is in standby state.
Steady on
The RSE-X1 is in active state.
(red)
PALM
Off
The system power module is normal.
Steady on
(green)
RUN
Off
No power input is available, or the RSE-X1 has failed.
The RSE-X1 is operating correctly.
The application software is being loaded (in this case, never power off the device or hot-swap the RSE-X1; otherwise the RSE-X1 might be damaged).
(red)
ALM
Off
Steady on
Figure 148 MCP-X1 LEDs
Table 77 MCP-X1 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
The corresponding interface is not connected.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
CF
Off
Steady green
Flashing green
Steady yellow
A CF card not provided by H3C.
(green)
RUN
Off
No power input is available, or the MCP-X1 has failed.
The MCP-X1 is operating correctly.
The application software is being loaded (in this case, never power off the device or hot-swap the MCP-X1; otherwise the MCP-X1 might be damaged).
(green)
ACT
Off
The MCP-X1 is in standby state.
Steady on
The MCP-X1 is in active state.
(red)
PALM
Off
Steady on
(red)
ALM
Off
Steady on
LINK
Off
Steady green
Steady yellow
ACT
Off
No data is being received or transmitted.
Flashing yellow
Data is being received or transmitted.
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure 149 MCP-X2 LEDs
Table 78 MCP-X2 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
CF
Off
Steady green
Flashing green
Steady yellow
(green)
RUN
Off
(green)
ACT
Off
Steady on
(red)
PALM
Off
Steady on
(red)
ALM
Off
Steady on
LINK
Off
Steady green
Steady yellow
ACT
Off
Flashing yellow
SFP+LINK/ACT
Off
No link is present.
Steady green
Flashing green
Data is being received or transmitted at 10 Gbps.
Steady yellow
Transceiver module check has failed.
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure 150 SFE-L1 status LED
Figure 151 SFE-L2 status LED
Table 79 SFE-L1 LED description
LED
Status
(green)
RUN
Off
No link is present or the module is faulty.
The module is operating correctly.
Application software is being loaded.
To avoid damage to the module, do not power off the device or hot-swap the module while the application software is being loaded.
FIP LEDs
Figure 152 FIP-10 status LED
Figure 153 FIP-20 status LED
Table 80 FIP-10/20 LED description
LED
Status
(green)
RUN
Off
No link is present or the FIP is faulty.
The FIP is operating correctly.
System software is being loaded. To avoid damage to the FIP, never power off the device or hot-swap the FIP while the system software is being loaded.
Figure 154 FIP-110 LEDs
Figure 155 FIP-210 LEDs
Figure 156 FIP-240 LEDs
Figure 157 FIP-600 LEDs
Table 81 FIP-110/210/240/600 LED description
LED
Status
(yellow/green)
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
RUN
Off
No power input is available or the FIP has failed.
(yellow/green)
Off
No link is present.
Steady green
A link is present.
Flashing green
Data is being sent or received at 1000 Mbps.
Steady yellow
The transceiver module failed to be detected.
Figure 158 FIP-260 LEDs
Table 82 FIP-260 LED description
LED
Status
(green)
RUN
Off
No power input is available or the FIP-260 has failed.
Steady green
The FIP software system is starting up.
Figure 159 FIP-300 LEDs
Table 83 FIP-300 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
SFP0 through SFP11
Off
No link is present.
Steady green
Flashing green
Steady yellow
POST has failed.
(green)
RUN
Off
No power input is available or the FIP-300 has failed.
Figure 160 FIP-310 LEDs
Table 84 FIP-310 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady green
Flashing green
Steady yellow
POST has failed.
(green)
RUN
Off
(yellow/green)
SFP+
Off
No link is present.
Steady green
Flashing green
Steady yellow
POST has failed.
Figure 161 FIP-380 LEDs
Table 85 FIP-380 LED description
LED
Status
(yellow/green)
SFP+22 and SFP+23
Off
No link is present or the port has failed.
Steady yellow
Flashing yellow (8 Hz)
Steady green
Flashing green (8 Hz)
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady yellow
Steady green
(green)
RUN
Off
No power input is available or the FIP-380 has failed.
Steady green
(yellow/green)
GE14 through GE21
Off
Steady yellow
Steady green
Figure 162 FIP-660 LEDs
Table 86 FIP-660 LED description
LED
Status
(green)
RUN
Off
No power input is available or the FIP-660 has failed.
Steady green
Figure 163 FIP-680 LEDs
Table 87 FIP-680 LED description
LED
Status
(green)
SFP1 through SFP12
Off
No link is present.
Steady green
Flashing green
(green)
SFP+1 through SFP+4
Off
No link is present.
Steady green
Flashing green
(yellow/green)
GE13 through GE20
Off
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
Off
System software is being loaded. To avoid damage to the FIP, never power off the device or hot-swap the FIP when the system software is being loaded.
SAP LEDs
Figure 164 SAP LEDs(SAP-48GBE)
Table 88 SAP-48GBE LED description
Item
Status
(yellow/green)
Status LEDs of GE 0 through GE 47
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
RUN
Off
No power input is available or the SAP-48GBE has failed.
The SAP-48GBE is operating correctly.
Application program is being loaded (in this case, never power off the device or hot-swap the SAP-48GBE; otherwise, the SAP-48GBE might be damaged), or the SAP-48GBE is not operating.
Figure 165 SAP LEDs (SAP-24GBP)
Table 89 SAP-24GBP LED description
LED
Status
(green)
RUN
Off
No power input is available or the SAP-24GBP has failed.
The SAP-24GBP is operating correctly.
Application program is being loaded (in this case, never power off the device or hot-swap the SAP-24GBP; otherwise, the SAP-24GBP might be damaged), or the SAP-24GBP is not operating.
(yellow/green)
Status LEDs of SFP 0 to SFP 23
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure 166 SAP LEDs (SAP-48GBP)
Table 90 SAP-48GBP LED description
LED
Status
(yellow/green)
Status LEDs of SFP 0 to SFP 47
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
System status LED
Off
No power input is available or the SAP-48GBP has failed.
The SAP-48GBP is operating correctly.
Application program is being loaded (in this case, never power off the device or hot-swap the SAP-48GBP; otherwise, the SAP-48GBP might be damaged), or the SAP-48GBP is not working.
Figure 167 SAP-20GE2XP LEDs
Table 91 SAP-20GE2XP LED description
LED
Status
(green)
RUN
Off
No power input is available or the SAP-20GE2XP has failed.
The SAP-20GE2XP is operating correctly.
System software is being loaded or the SAP-20GE2XP is not operating.
CAUTION CAUTION:
To avoid hardware damage, do not power off the router, or insert or remove the SAP-20GE2XP when system software is being loaded.
(yellow/green)
Status LEDs for SFP+ port 0 and SFP+ port 1
Off
No link is present.
Steady green
Flashing green
Steady yellow
The transceiver module has failed to be detected.
(yellow/green)
Status LEDs for fiber combo ports GE16 to GE19
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Status LEDs for copper combo ports GE16 to GE19
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Status LEDs for SFP ports GE0 to GE15
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure 168 SAP-28GE LEDs
Table 92 SAP-28GE LED description
LED
Status
(green)
RUN
Off
No power input is available or the SAP-28GE has failed.
The SAP-28GE is operating correctly.
System software is being loaded or the SAP-28GE is not operating.
CAUTION CAUTION:
To avoid hardware damage, do not power off the router, or insert or remove the SAP-28GE when system software is being loaded.
(yellow/green)
Status LEDs for fiber combo ports GE16 to GE27
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Status LEDs for copper combo ports GE16 to GE27
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure 169 SAP-XP4GE32 LEDs
Table 93 SAP-XP4GE32 LED description
LED
Status
(yellow/green)
·     GE0 through GE11
·     GE12 through GE23 (copper combo port)
Off
No power input is available or the port has failed.
Steady yellow
Steady green
(yellow/green)
·     SFP12 through SFP23 (fiber combo port)
·     SFP24 through SFP31
Off
No link is present.
Steady yellow
Steady green
 (green)
SFP+32 through SFP+35
Off
Steady green
(green)
RUN
Off
No power input is available or the SAP-XP4GE32 has failed.
CAUTION CAUTION:
HIM/MIM/MIC/MIC-X LEDs
For HIM/MIM/MIC/MIC-X LED description, see H3C SR6600/SR6600-X Routers Interface Module Guide.
Power module LEDs
Figure 170 PSR650-A AC power module LED
Figure 171 PSR1200-A AC power module LED
Figure 172 PSR650-D DC power module LED
Figure 173 PSR1200-D DC power module LED
Table 94 AC/DC power LED description
LED
Status
Power LED
Steady green
The power module is operating correctly.
Steady red
The power module is faulty.
Off
No power is input.
Fan tray LEDs
Figure 174 Fan tray for the SR6604
Figure 175 Fan tray for the SR6608
Table 95 Fan tray LED description
LED
Status
(green)
RUN
Off
The system is powered off or the fan tray is faulty.
Steady on
The fan tray is operating correctly.
(red)
ALM
Off
Steady on
The fan tray is faulty.
Appendix D Arranging slots and numbering interfaces
Slot arrangement
The router provides multiple types of ports, including console port, AUX port, GigabitEthernet port, serial (synchronous) port, POS port, and E1 port.
Figure 176 Slot arrangement on the SR6604 configured with an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU
Figure 177 Slot arrangement on the SR6604 configured with an RSE-X1 or MCP-X1/X2 MPU
Figure 178 Slot arrangement on the SR6608 configured with an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU
Figure 179 Slot arrangement on the SR6608 configured with an RSE-X1 or MCP-X1/X2 MPU
·     The numbers in Figure 176 through Figure 179 represent corresponding slot numbers.
·     On a router configured with an RSE-X1 or MCP-X1/X2 MPU, the slots are numbered from 1 instead 0.
Slot arrangement for MPUs, switching fabric modules, and service modules
Table 96 Slot arrangement for MPUs, switching fabric modules, and service modules
MPUs
RPE-X1/RPE-X3/RPE-X5/RPE-X5E (supporting 1+1 redundancy)
Slot 0 and slot 1
An SR6608-DS router does not support the RPE-X1 MPU.
RSE-X1 (supporting 1+1 redundancy)
Slot 1 and slot 2
Not supported on an SR6608-DS router.
MCP-X1/X2 (supporting 1+1 redundancy)
Slot 1 and slot 2
SFE-L1
Slot 2 and slot 3
Slot 2 through slot 5
SFE-L2
N/A
Slot 2 and slot 3 on an SR6608-DS router. (To install the SFE-L2 switching fabric module in slot 3 on an SR6608-DS router, first install a carrier in the slot.)
Service modules
FIP-10
FIP-20
FIP-110
FIP-210
FIP-240
FIP-260
FIP-300
FIP-310
FIP-380
FIP-600
FIP-660
FIP-680
SAP/OAP card
Slot 2 and slot 3
·     Slot 2 through slot 5
(The router does not support installing the FIP-240 or FIP-680 in slot 5 if it is installed with the RPE-X5 or RPE-X5E MPU.)
·     Slot 3 through slot 5 on an SR6608-DS router
(The SR6616-DS router does not support the FIP-240 and does not support installing the FIP-680 in slot 5 if it is installed with the RPE-X5 or RPE-X5E MPU.).
Numbering interfaces
Before installing a HIM/MIM/MIC/MIC-X, you must install a FIP.
The interfaces of the router are numbered in the form of interface-type X/Y/Z,
Where,
·     interface-typeType of the interface such as GE port and serial port.
·     XNumber of the slot where the FIP/SAP resides, in the range of 2 to 3 on the SR6604 and 2 to 5 on the SR6608.
·     Y—Number of the slot where the HIM/MIM/MIC/MIC-X resides on the FIP. For a SAP, the subslot number is 0.
·     Z—Number of the interface on the HIM/MIM/MIC/MIC-X or on the SAP.
For each interface type on a HIM/MIM/MIC/MIC-X or SAP, the number Z starts from 0.
·     Different interface modules on the same FIP have the same slot number.
·     Different interfaces on the same HIM/MIM/MIC/MIC-X have the same subslot number.
Example 1
A MIM-2GBE module is installed on a FIP-110 in slot 3 of the router.
·     Fixed GigabitEthernet interfaces 0 and 1 on the FIP-110 are numbered GigabitEthernet 3/0/0 and GigabitEthernet 3/0/1, respectively.
The subslot number Y of fixed GE interfaces on a FIP is 0.
·     If the MIM-2GBE module is installed in slot 1 of the FIP-110, the two GigabitEthernet interfaces 0 and 1 on the MIM-2GBE are numbered GigabitEthernet 3/1/0 and GigabitEthernet 3/1/1, respectively,
·     If the MIM-2GBE module is installed in slot 2 of the FIP-110, the two GigabitEthernet interfaces 0 and 1 on the MIM-2GBE are numbered GigabitEthernet 3/2/0 and GigabitEthernet 3/2/1, respectively.
Example 2
A HIM-4GBE module is installed on a FIP-210 in slot 3 of the router.
·     The two fixed GigabitEthernet interfaces 0 and 1 on the FIP-210 are numbered GigabitEthernet 3/0/0 and GigabitEthernet 3/0/1, respectively.
·     If the HIM-4GBE is installed in slot 1 of the FIP-210, the GigabitEthernet interfaces 0 and 3 on the HIM-4GBE are numbered GigabitEthernet 3/1/0 to GigabitEthernet 3/1/3, respectively.
·     If the HIM-4GBE is installed in slot 2 of the FIP-210, the GigabitEthernet interfaces 0 and 3 on the HIM-4GBE are numbered GigabitEthernet 3/2/0 to GigabitEthernet 3/2/3, respectively.
  • Become a Partner
  • Partner Resources
