- 05-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-mDNS relay configuration
- 06-IP forwarding basics configuration
- 07-Fast forwarding configuration
- 08-Adjacency table configuration
- 09-IRDP configuration
- 10-IP performance optimization configuration
- 11-UDP helper configuration
- 12-IPv6 basics configuration
- 13-DHCPv6 configuration
- 14-IPv6 fast forwarding configuration
- 15-Tunneling configuration
- 16-GRE configuration
- 17-HTTP redirect configuration
00-Preface | 100.74 KB |
Preface
This configuration guide describes IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6800 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
