05-Network Connectivity
HomeSupportWirelessWBC Series Multiservice Access ControllersReference GuidesCommand ReferencesH3C WBC Series Multservice Access Controllers Command References(E5448)-6W10005-Network Connectivity
14-NAT commands
14-NAT commands 380.72 KB
NAT commands· 1
address· 1
block-size· 1
display nat address-group· 2
display nat alg· 4
display nat all 5
display nat dns-map· 11
display nat eim·· 13
display nat inbound· 14
display nat log· 15
display nat no-pat 16
display nat outbound· 17
display nat outbound port-block-group· 19
display nat port-block· 20
display nat port-block-group· 21
display nat port-block-usage· 23
display nat server 24
display nat server-group· 25
display nat session· 26
display nat static· 28
display nat statistics· 31
global-ip-pool 32
inside ip· 33
local-ip-address· 34
nat address-group· 35
nat alg· 35
nat dns-map· 37
nat hairpin enable· 38
nat icmp-error reply· 38
nat inbound· 39
nat inbound rule move· 41
nat log alarm·· 42
nat log enable· 43
nat log flow-active· 44
nat log flow-begin· 44
nat log flow-end· 45
nat log port-block usage threshold· 46
nat log port-block-assign· 46
nat log port-block-withdraw· 47
nat mapping-behavior endpoint-independent 48
nat outbound· 49
nat outbound port-block-group· 52
nat outbound rule move· 53
nat port-block global-share enable· 53
nat port-block-group· 54
nat redirect reply-route· 55
nat server 56
nat server rule move· 60
nat server-group· 61
nat static enable· 62
nat static inbound· 62
nat static inbound net-to-net 64
nat static inbound rule move· 66
nat static outbound· 67
nat static outbound net-to-net 69
nat static outbound rule move· 71
port-block· 71
port-range· 72
reset nat count statistics· 73
reset nat session· 74
NAT commands
Access controller modules do not support parameters or commands that are available only in IRF mode.
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address. You can specify a maximum of 65535 addresses in an IP address range.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
You can specify a maximum of 65535 addresses in one command execution. Make sure the address ranges in a single NAT address group or in multiple NAT address groups do not overlap.
# Add address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
nat address-group
block-size
Use block-size to set the port block size.
Use undo block-size to restore the default.
block-size block-size
undo block-size
The port block size is 256.
NAT port block group view
block-size: Specifies the number of ports for a port block. The value range for this argument is 1 to 65535.
Set an appropriate port block size based on the number of private IP addresses, the number of public IP addresses, and the port range in the port block group.
The port block size cannot be larger than the number of ports in the port range.
# Set the port block size to 1024 for port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
Use display nat address-group to display NAT address group information.
display nat address-group [ group-id ]
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535. If you do not specify the group-id argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
  Totally 5 NAT address groups.
  Address group ID: 1    Address group name: a
    Port range: 1-65535
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group ID: 2
    Port range: 1-65535
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group ID: 3
    Port range: 1024-65535
      202.110.10.40         202.110.10.50
  Address group ID: 4
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group ID: 6
    Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
    Port range: 1-65535
Information about the NAT address group
Address group ID
ID of the NAT address group.
Totally n NAT address groups
Total number of NAT address groups.
Address group name
Name of the NAT address group. If no address group name is configured, this field is not displayed.
Port range
Port range for public IP addresses.
Port block size
Number of ports in a port block. This field is not displayed if the port block size is not set.
Number of extended port blocks. This field is not displayed if the number of extended port blocks is not set.
Address information
Information about the IP addresses in the address group.
For addresses added by using the address command:
·     Start address—Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---).
·     End address—End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---).
nat address-group
display nat alg
Use display nat alg to display the NAT ALG status for all supported protocols.
display nat alg
# Display the NAT ALG status for all supported protocols.
<Sysname> display nat alg
NAT ALG:
  DNS        : Enabled
  FTP        : Disabled
  H323       : Disabled
  ICMP-ERROR : Disabled
  ILS        : Disabled
  MGCP       : Disabled
  NBT        : Disabled
  PPTP       : Disabled
  RTSP       : Disabled
  RSH        : Disabled
  SCCP       : Disabled
  SIP        : Disabled
  SQLNET     : Disabled
  TFTP       : Disabled
  XDMCP      : Disabled
display nat all
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# Display all NAT configuration information.
<Sysname> display nat all
  Address group ID: 1:
    Port range: 1-65535
  Address group ID: 2:
    Port range: 1-65535
  Address group ID: 3:
  Address group ID: 4:
  Address group ID: 6:
    Port range: 1-65535
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT inbound information:
  Totally 1 NAT inbound rules.
  Interface: Vlan-interface20
    ACL: 2038
    Address group ID: 2
    Add route: Y         NO-PAT:Y  Reversible: N
    Rule name: abc
    Priority: 1000
    NAT counting: 0
    Config status: Active
NAT outbound information:
  Totally 2 NAT outbound rules.
  Interface: Vlan-interface10
    ACL: 2036
    Address group ID: 1
    Port-preserved: Y        NO-PAT: N  Reversible: N
    Rule name: lee
    Priority: 122
    NAT counting: 0
    Config status: Inactive
    Reasons for inactive status:
      The following items don't exist or aren't effective: ACL.
    ACL: 2037
    Address group ID: 1
    Port-preserved: N        NO-PAT: Y  Reversible: Y
    Rule name: rabbit
    Priority: 100
    NAT counting: 0
NAT internal server information:
  Totally 2 internal servers.
    Global ACL    : 2000
    Local IP/port : 192.168.10.1/23
    Rule name     : sept
    Priority      : 1000
    NAT counting  : 0
    Config status : Active
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23
    Local IP/port : 192.168.10.15/23
    ACL           : 2000
    Rule name     : blue
    NAT counting  : 0
Static NAT mappings:
  Totally 2 inbound static NAT mappings.
  Net-to-net:
    Global IP    : 2.2.2.1 – 2.2.2.255
    Local IP     : 1.1.1.0
    Netmask      : 255.255.255.0
    ACL          : 3000
    Reversible   : Y
    Rule name    : green
    Priority     : 4
    NAT counting : 0
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    ACL          : 2001
    Reversible   : Y
    Rule name    : blue
    Priority     : 4
    NAT counting : 0
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    ACL          : 3000
    Reversible   : Y
    Rule name    : yellow
    Priority     : 5
    NAT counting : 0
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    ACL:         : 2001
    Reversible   : Y
    Rule name    : pink
    Priority     : 6
    NAT counting : 0
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
  Interface: Vlan-interface30
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.server.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : www.service.com
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
    The following items don't exist or aren't effective: interface IP address.
NAT logging:
  Log enable          : Enabled(ACL 2000)
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Enabled(10 minutes)
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
  NO-PAT IP usage     : Disabled
NAT hairpinning:
  Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
  Mapping mode : Endpoint-Independent
  ACL          : 2050
NAT ALG:
  DNS        : Enabled
  FTP        : Disabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RSH        : Enabled
  RTSP       : Enabled
  SCCP       : Enabled
  SIP        : Disabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Enabled
NAT port block group information:
  Totally 3 NAT port block groups.
  Port block group 1:
    Port range: 1-65535
    Block size: 256
    Local IP address information:
      Start address        End address          VPN instance
      172.16.1.1           172.16.1.254         ---
      192.168.1.1          192.168.1.254        ---
      192.168.3.1          192.168.3.254        ---
    Global IP pool information:
      201.1.1.1            201.1.1.10
      201.1.1.21           201.1.1.25
  Port block group 2:
    Port range: 10001-30000
    Block size: 500
      10.1.1.1             10.1.10.255          ---
      202.10.10.101        202.10.10.120
  Port block group 3:
    Port range: 1-65535
    Block size: 256
NAT outbound port block group information:
  Totally 2 outbound port block group items.
    port-block-group: 2
    Rule name       : red
    NAT counting: 0
    port-block-group: 10
    Rule name: lee
    NAT counting: 0
    Config status   : Inactive
      The following items don't exist or aren't effective: port block group.
Static NAT load balancing:     Disabled
The output shows all NAT configuration information. Table 2 describes only the fields for the output of the nat hairpin enable, nat mapping-behavior, and nat alg commands.
Information about the NAT address group. See Table 1 for output description.
Information about the internal server group. See Table 14 for output description.
Inbound dynamic NAT configuration. See Table 5 for output description.
Outbound dynamic NAT configuration. See Table 8 for output description.
NAT server mapping configuration. See Table 13 for output description.
Static NAT mappings
Static NAT mappings. See Table 16 for output description.
NAT DNS mappings
NAT DNS mappings. See Table 3 for output description.
NAT logging
NAT logging configuration. See Table 6 for output description.
NAT hairpinning
NAT hairpin configuration.
Totally n interfaces enabled NAT hairpinning
Number of interfaces with NAT hairpin enabled.
NAT hairpin-enabled interface.
Rule name
Name of the NAT rule.
NAT counting
Number of times the NAT rule is matched.
Priority
Priority of the NAT rule.
Config status
Status of the NAT hairpin configuration: Active or Inactive.
Reasons why the NAT hairpin configuration does not take effect. This field is available when the Config status is Inactive.
Mapping behavior mode of PAT: Endpoint-Independent or Address and Port-Dependent.
ACL
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---).
Config status
Status of the NAT mapping behavior configuration: Active or Inactive.
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status is Inactive.
NAT ALG
NAT ALG configuration for different protocols.
Configuration information about NAT port block groups. See Table 11 for output description.
Configuration information about static outbound port block mapping rules. See Table 9 for output description.
display nat dns-map
Use display nat dns-map to display NAT DNS mappings.
display nat dns-map
# Display NAT DNS mappings.
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
Information about NAT DNS mappings.
Totally n NAT DNS mappings
Total number of NAT DNS mappings.
Domain name
Domain name of the internal server.
Global IP
Public IP address of the internal server.
·     If Easy IP is configured, this field displays the IP address of the specified interface.
·     If you do not specify a public IP address, this field displays hyphens (---).
Global port
Public port number of the internal server.
Protocol
Protocol name and number of the internal server.
Config status
Status of the DNS mapping: Active or Inactive.
Reasons why the DNS mapping does not take effect. This field is available when the Config status is Inactive.
nat dns-map
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
display nat eim
EIM entries are created when PAT operates in EIM mode. An EIM entry is a 3-tuple entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
·     The same EIM entry applies to subsequent connections initiated from the same source IP and port.
·     The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
# Display information about NAT EIM entries.
<Sysname> display nat eim
Slot 0:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Protocol: TCP(6)
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
Protocol
Protocol name and number.
Total entries found
Total number of EIM entries.
nat outbound
display nat inbound
Use display nat inbound to display inbound dynamic NAT configuration.
display nat inbound
# Display inbound dynamic NAT configuration.
<Sysname> display nat inbound
  Totally 2 NAT inbound rules.
    ACL: 2038
    Address group ID: 2
    Add route: Y          NO-PAT: Y  Reversible: N
    Rule name: abcd
    Priority: 1000
    NAT counting: 0
    ACL: 2037
    Address group ID: 1       Address group name: abc
    Rule name: eif
    Priority: 1000
    NAT counting: 0
Table 5 Command output
Information about inbound dynamic NAT configuration.
Totally n NAT inbound rules
Total number of inbound dynamic NAT rules.
Interface where the inbound dynamic NAT rule is configured.
ACL
ACL number or name.
Address group ID
ID of the NAT address group used by the inbound dynamic NAT rule.
Address group name
Add route
Whether to add a route when a packet matches the inbound dynamic NAT rule:
·     Y—Adds a route.
·     N—Does not add a route.
NO-PAT
Whether NO-PAT or PAT is used:
·     Y—NO-PAT is used.
·     N—PAT is used.
Reversible
Whether reverse address translation is allowed:
·     Y—Reverse address translation is allowed.
·     N—Reverse address translation is not allowed.
Rule name
Priority
NAT counting
Config status
Status of the inbound dynamic NAT rule: Active or Inactive.
Reasons why the inbound dynamic NAT rule does not take effect:
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
  Flow-end            : Disabled
  Alarm               : Disabled
Table 6 Command output
NAT logging
Log enable
Enabling status of NAT logging.
If an ACL is specified for NAT logging, this field also displays the ACL number or name.
Flow-begin
Enabling status of logging for NAT session establishment events.
Flow-end
Enabling status of logging for NAT session removal events.
Flow-active
Enabling status of logging for active NAT flows. If it is enabled, this field also displays the interval in minutes at which active flow logs are generated.
Port-block-assign
Enabling status of NAT444 user logging for port block assignment.
Port-block-withdraw
Enabling status of NAT444 user logging for port block withdrawal.
Alarm
Enabling status of logging for NAT alarms.
nat log enable
nat log flow-active
nat log flow-begin
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
display nat no-pat
Default user roles
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
·     The same entry applies to subsequent connections initiated from the same source IP address.
·     The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# Display information about NO-PAT entries for all cards.
<Sysname> display nat no-pat
Slot 0:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Reversible: N
Type      : Inbound
Local   IP: 192.168.100.200
Global  IP: 200.100.1.200
Reversible: Y
Type      : Outbound
Table 7 Command output
Global IP
Public IP address.
Local IP
Private IP address.
Reversible
Type of the NO-PAT entry:
·     Inbound—A NO-PAT entry created during inbound dynamic NAT.
·     Outbound—A NO-PAT entry created during outbound dynamic NAT.
Total entries found
Total number of NO-PAT entries.
nat inbound
nat outbound
Use display nat outbound to display outbound dynamic NAT configuration.
# Display outbound dynamic NAT configuration.
<Sysname> display nat outbound
    Address group ID: 1
    Rule name: acdefg
    Priority: 1000
    NAT counting: 0
    ACL: 2037
    Address group ID: ---
    Rule name: abefg
    Priority: 1000
    NAT counting: 0
    ACL: 2100
    Address group ID: 2
    Port-preserved: N          NO-PAT: N  Reversible: N
    Priority: 0
    NAT counting: 0
Table 8 Command output
Information about outbound dynamic NAT configuration.
Totally n NAT outbound rules
Total number of outbound dynamic NAT rules.
Interface where the outbound dynamic NAT rule is configured.
ACL
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT rule, this field displays hyphens (---).
Address group ID
ID of the address group used by the outbound dynamic NAT rule. If no address group is specified, the field displays hyphens (---).
Address group name
Port-preserved
Whether to try to preserve the port numbers for PAT.
·     Y—Tries to preserve the port numbers.
·     N—Allows translating port numbers.
NO-PAT
Whether NO-PAT is used:
·     Y—NO-PAT is used.
·     N—PAT is used.
Reversible
Rule name
Priority
NAT counting
Config status
Status of the outbound dynamic NAT rule: Active or Inactive.
Reasons why the outbound dynamic NAT rule does not take effect.
nat outbound
Use display nat outbound port-block-group to display static outbound port block mapping rules for NAT444.
# Display static outbound port block mapping rules for NAT444.
<Sysname> display nat outbound port-block-group
    port-block-group: 2
    Rule name: abcdefg
    NAT counting: 0
    Rule name: abcfg
    NAT counting: 0
Table 9 Command output
Information about static outbound port block mapping rules.
Totally n outbound port block group items
Total number of static outbound port block mapping rules.
Interface where the static outbound port block mapping rules configured.
port-block-group
ID of the port block group.
Rule name
Name of the static outbound port block mapping rule.
NAT counting
Number of times the mapping rule is matched.
Config status
Status of the port block mapping rule: Active or Inactive.
Reasons why the port block mapping rule does not take effect. This field is available when the Config status is Inactive.
Use display nat port-block to display NAT port block mappings.
display nat port-block { dynamic [ address-group { group-id | name group-name } ] | static [ port-block-group group-id ] }
dynamic: Displays dynamic port block mappings.
address-group: Displays port block mappings for the specified address group. If you do not specify a NAT address group, this command displays port block mappings for all address groups.
group-id: Specifies the ID of the address group. The value range for this argument is 0 to 65535.
name group-name: Specifies the name of the address group. The name is a case-insensitive string of 1 to 63 characters.
static: Displays static port block mappings.
port-block-group group-id: Displays port block mappings for the specified port block group. The group-id argument specifies the ID of the port block group. The value range for the group-id argument is 0 to 65535. If you do not specify a port block group, this command displays port block mappings for all port block groups.
# Display static port block mappings.
<Sysname> display nat port-block static
Slot 0:
Local VPN     Local IP         Global IP        Port block   Connections
---           100.100.100.111  202.202.100.101  10001-10256  0
---           100.100.100.112  202.202.100.101  10257-10512  0
---           100.100.100.113  202.202.100.101  10513-10768  0
---           100.100.100.113  202.202.100.101  10769-11024  0
Total mappings found: 4
# Display dynamic port block mappings.
<Sysname> display nat port-block dynamic
Slot 0:
---           101.1.1.12       192.168.135.201  10001-11024  1
Total mappings found: 1
Table 10 Command output
Local VPN
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field displays hyphens (---).
Local IP
Private IP address.
Global IP
Public IP address.
Port block
Port block defined by a start port number and an end port number.
Connections
Number of connections established by using the ports in the port block.
Use display nat port-block-group to display NAT port block group configuration.
display nat port-block-group [ group-id ]
group-id: Specifies the ID of a NAT port block group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays configuration of all NAT port block groups.
# Display configuration of all NAT port block groups.
<Sysname> display nat port-block-group
  Port block group 1:
    Port range: 1-65535
    Block size: 256
  Port block group 2:
    Block size: 500
  Port block group 3:
    Port range: 1-65535
    Block size: 256
# Display information about NAT port block group 1.
<Sysname> display nat port-block-group 1
  Port block group 1:
    Port range: 1-65535
    Block size: 256
Table 11 Command output
Information about the port block group configuration.
Totally n NAT port block groups
Total number of port block groups.
Port block group
Port range
Port range for the public IP addresses.
Block size
Information about the private IP addresses.
Information about the public IP addresses.
Start address
Start IP address of a private or public IP address range. If no start IP address is specified for the address range, this field displays hyphens (---).
End address
End IP address of a private or public IP address range. If no end IP address is specified for the address range, this field displays hyphens (---).
VPN instance
MPLS L3VPN instance to which the private IP address range belongs. If no VPN instance is specified for the private address range, this field displays hyphens (---).
Use display nat port-block-usage to display the port block usage for address groups.
display nat port-block-usage [ address-group group-id ]
address-group group-id: Specifies the ID of an address group. The value range for the group-id argument is 0 to 65535. If you do not specify an address group, this command displays the port block usage for all address groups.
# Display the port block usage for address groups.
<Sysname> display nat port-block-usage
Slot 1:
Address group 0 on channel 0:
  Total port block entries :10
  Active port block entries:9
  Current port block usage :90%
Total NAT address groups found: 1
Table 12 Command output
CPU
Number of the CPU.
Address group
channel
Field-programmable gate array (FPGA) ID.
Total number of port blocks in the address group.
Total number of assigned port blocks in the address group.
Port block usage in the address group.
Total number of address groups.
display nat server
Use display nat server to display NAT server mappings.
display nat server
# Display NAT server mappings.
<Sysname> display nat server
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23-30
    Local IP/port : 192.168.10.15-192.168.10.22/23
    Rule name     : abcg
    NAT counting  : 0
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    Rule name     : abcdefg
    NAT counting  : 0
Table 13 Command output
Information about NAT server mapping.
Interface where the NAT server mapping is configured.
Protocol
Protocol number and name of the internal server.
Global IP/port
Public IP address and port number of the internal server.
·     Global IP—A single IP address or an IP address range. If you use Easy IP, this field displays the IP address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---).
·     port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---).
Local IP/port
For common NAT server mappings and object group-based NAT server mappings, this field displays the private IP address and port number of the internal server.
·     Local IP—A single IP address or an IP address range.
For a load sharing NAT server mapping, this field displays the internal server group ID, IP address, port number, and number of connections of each member.
ACL
ACL number or name. If no ACL is specified, this field is not displayed.
Rule name
Name of the NAT server mapping.
NAT counting
Number of times the NAT server mapping is matched.
Config status
Status of the NAT server mapping: Active or Inactive.
Reasons why the NAT server mapping does not take effect. This field is available when the Config status is Inactive.
nat server
Use display nat server-group to display internal server group configuration.
display nat server-group [ group-id ]
group-id: Specifies the ID of the internal server group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays the configuration of all internal server groups.
# Display the configuration of all internal server groups.
<Sysname> display nat server-group
                      192.168.0.27          23          500
  2                   ---                   ---         ---
# Display the configuration of internal server group 1.
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
Table 14 Command output
Information about the NAT server group configuration.
Totally n NAT server groups
Total number of NAT server groups.
Group Number
Inside IP
Private IP address of a server in the internal server group. If no address is specified, this field displays hyphens (---).
Port
Private port number of a server in the internal server group. If no port number is specified, this field displays hyphens (---).
Weight
Weight of a server in the internal server group. If no weight value is specified, this field displays hyphens (---).
nat server-group
display nat session
Use display nat session to display NAT sessions.
display nat session [ [ responder ] { source-ip source-ip | destination-ip destination-ip } * ] [ verbose ]
responder: Displays NAT sessions by responder. If you do not specify this keyword, this command displays NAT sessions by initiator.
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
verbose: Displays detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about NAT sessions.
If you do not specify any parameters, this command displays all NAT sessions.
# Display detailed information about NAT sessions.
<Sysname> display nat session verbose
Slot 0:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Vlan-interface10
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.10/1877
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
  Inbound interface: Vlan-interface20
State: TCP_SYN_SENT
Application: SSH
Rule ID: -/-/-
Rule name:
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
Table 15 Command output
Initiator
Session information about the initiator.
Responder
Session information about the responder.
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
DS-Lite tunnel peer
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
The fields identify the following information:
·     VPN instance—MPLS L3VPN instance to which the session belongs. The VPN instance field is not supported in the current software version.
·     VLAN ID—VLAN ID to which the session belongs for Layer 2 forwarding.
·     Inline ID—INLINE to which the session belongs for Layer 2 forwarding.
If no VPN instance, VLAN ID, or inline ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Inbound interface
Input interface.
NAT session status.
Application
Application layer protocol type, such as FTP and DNS.
This field displays OTHER for the protocol types identified by non-well-known ports.
Rule ID
ID of the security policy rule.
Rule name
Name of the security policy rule.
Start time
Time when the session starts.
TTL
Remaining NAT session lifetime in seconds.
Number of packets and packet bytes from the initiator to the responder.
Number of packets and packet bytes from the responder to the initiator.
Total number of sessions.
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# Display static NAT mappings.
<Sysname> display nat static
  Net-to-net:
    Global IP    : 1.1.1.1 - 1.1.1.255
    Local IP     : 2.2.2.0
    ACL          : 2000
    Reversible   : Y
    NAT counting : 0
    Rule name    : abcdefg
    Priority     : 1000
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    ACL          : 2000
    Reversible   : Y
    Rule name    : abefg
    Priority     : 1000
    NAT counting : 0
      The following items don't exist or aren't effective: local VPN, global VPN, and ACL.
  Net-to-net:
    Global IP    : 2.2.2.0
    ACL          : 2000
    Reversible   : Y
    Rule name    : abefg
    Priority     : 1000
    NAT counting : 0
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    ACL:         : 2001
    Reversible   : Y
    Rule name    : abcd
    Priority     : 1000
    NAT counting : 0
Table 16 Command output
Static NAT mappings
Information about static NAT mapping configuration.
Totally n inbound static NAT mappings
Total number of inbound static NAT mappings.
Totally n outbound static NAT mappings
Total number of outbound static NAT mappings.
Net-to-net
Net-to-net static NAT mapping.
IP-to-IP
One-to-one static NAT mapping.
Local IP
Private IP address or address range.
Global IP
Public IP address or address range.
Netmask
Network mask.
ACL
Reversible
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed.
Interfaces on which static NAT is enabled.
Totally n interfaces enabled with static NAT
Total number of interfaces where static NAT is enabled.
Interface on which static NAT is enabled.
Rule name
Priority
NAT counting
Config status
Status of the static NAT mapping: Active or Inactive.
Reasons why the static NAT mapping does not take effect. This field is available when the Config status is Inactive.
nat static enable
nat static inbound
nat static outbound
Use display nat statistics to display NAT statistics.
display nat statistics [ summary ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
# Display detailed information about NAT statistics.
<Sysname> display nat statistics
Slot 0:
  Total session entries: 100
  Total EIM entries: 1
  Total inbound NO-PAT entries: 0
  Total outbound NO-PAT entries: 0
  Total static port block entries: 10
  Total dynamic port block entries: 15
  Active static port block entries: 0
  Active dynamic port block entries: 0
Table 17 Command output
Number of NAT session entries.
Total EIM entries
Total number of inbound NO-PAT entries.
Total number of outbound NO-PAT entries.
Total number of static NAT444 mappings.
Total number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks.
Number of static port block mappings that are in use.
Number of dynamic port block mappings that have been created. It equals the number of dynamically assigned port blocks.
# Display NAT statistics summary.
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions  EIM       SPB       DPB       ASPB      ADPB
0    100       1         10        15        0         0
Table 18 Command output
Sessions
EIM
Number of EIM entries.
SPB
Number of static NAT444 mappings.
DPB
Number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks.
ASPB
Number of static port block mappings in use.
ADPB
global-ip-pool
Use global-ip-pool to add a public IP address range to a NAT port block group.
Use undo global-ip-pool to remove a public IP address range from a NAT port block group.
global-ip-pool start-address end-address
undo global-ip-pool start-address [ end-address ]
No public IP address ranges exist.
start-address end-address: Specifies the start IP address and end IP address of a public IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one public IP address is specified.
A static port block mapping maps a public IP address to multiple private IP addresses and assigns a unique port block to each private IP address. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
Every time you execute this command, an address range can contain a maximum of 255 public IP addresses. All public IP address ranges in one port block group cannot overlap.
Public IP address ranges in different port block groups can overlap. The port ranges for overlapped public IP address ranges cannot overlap.
# Add a public IP address range to the port block group 1. The public IP address range consists of IP addresses from 202.10.1.1 to 202.10.1.10.
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
inside ip
Use inside ip to add a server to an internal server group.
Use undo inside ip to remove a server from an internal server group.
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
An internal server group has no server members.
Internal server group view
inside-ip: Specifies the IP address of an internal server.
port port-number: Specifies the port number of an internal server, in the range of 1 to 65535, excluding FTP port 20.
weight weight-value: Specifies the weight of the internal server. The value range is 1 to 1000, and the default value is 100.
An internal server with a larger weight receives a larger percentage of connections in the internal server group.
# Add a server with IP address 10.1.1.2 and port number 30 to internal server group 1.
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
nat server-group
local-ip-address
Use local-ip-address to add a private IP address range to a NAT port block group.
Use undo local-ip-address to remove a private IP address range from a NAT port block group.
local-ip-address start-address end-address
undo local-ip-address start-address [ end-address ]
No private IP address ranges exist in a NAT port block group.
start-address end-address: Specifies the start IP address and end IP address of a private IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one private IP address is specified.
A static port block mapping maps one public IP address to multiple private IP addresses and assigns a unique port block to each private IP address.
In a NAT port block group, the number of private IP addresses cannot be larger than the number of assignable port blocks. Otherwise, some private IP addresses cannot obtain port blocks. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
# Add a private IP address range to port block group 1. The private IP address range consists of IP addresses from 172.16.1.1 to 172.16.1.255.
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id [ name group-name ]
undo nat address-group group-id
No NAT address groups exist.
name group-name: Assigns a name to the NAT address group. The group-name argument is a case-sensitive string of 1 to 63 characters.
A NAT address group is a set of address ranges. Use the address command to add an address range to a NAT address group. Dynamic NAT translates the source IP address of a packet into an IP address in the address group.
# Create a NAT address group numbered 1 and named abc.
[Sysname] nat address-group 1 name abc
address
display nat all
nat inbound
nat outbound
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
NAT ALG is enabled for DNS, FTP, ICMP error messages, RTSP, and PPTP, and is disabled for the other supported protocols.
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
h323: Enables NAT ALG for H.323.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sip: Enables NAT ALG for SIP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat dns-map
Use nat dns-map to configure a NAT DNS mapping.
Use undo nat dns-map to remove a NAT DNS mapping.
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
No NAT DNS mappings exist.
domain domain-name: Specifies the domain name of an internal server. A domain name is a dot-separated case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.) (for example, aabbcc.com). The domain name can contain a maximum of 253 characters, and each separated string contains no more than 63 characters.
protocol pro-type: Specifies the type of the protocol used by the internal server, tcp or udp.
interface interface-type interface-number: Enables Easy IP to use the IP address of the interface specified by its type and number as the public address of the internal server.
ip global-ip: Specifies the public IP address used by the internal server to provide services for the external network.
port global-port: Specifies the public port number used by the internal server to provide services for the external network. The port number format can be one of the following:
·     A number in the range of 1 to 65535.
·     A protocol name, a string of 1 to 15 characters. For example, ftp and telnet.
NAT DNS mapping must cooperate with the NAT Server feature.
·     A NAT DNS mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server.
·     A NAT server mapping maps the public IP and port to the private IP and port of the internal server.
The cooperation allows an internal host to access an internal server on the same private network by using the domain name of the internal server when the DNS server is on the public network. The DNS reply from the external DNS server contains only the domain name and public IP address of the internal server in the payload. The NAT interface might have multiple internal servers configured with the same public IP address but different private IP addresses. DNS ALG might find an incorrect internal server by using only the public IP address. If a DNS mapping is configured, DNS ALG can obtain the public IP address, public port number, and protocol type of the internal server by using the domain name. Then it can find the correct internal server by using the public IP address, public port number, and protocol type of the internal server.
You can configure multiple NAT DNS mappings.
# Configure a NAT DNS mapping to map the domain name www.server.com to the public IP address 202.112.0.1, public port number 12345, and protocol type TCP.
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
display nat all
display nat dns-map
nat server
nat hairpin enable
Use nat hairpin enable to enable NAT hairpin.
Use undo nat hairpin enable to disable NAT hairpin.
nat hairpin enable
NAT hairpin is disabled.
Interface view
NAT hairpin allows internal hosts to access each other or allows internal hosts to access internal servers. It must cooperate with NAT Server, outbound dynamic NAT, or outbound static NAT. The source and destination IP addresses of the packets are translated on the interface connected to the internal network.
# Enable NAT hairpin on interface VLAN-interface 10.
[Sysname-Vlan-interface10] nat hairpin enable
display nat all
Use nat icmp-error reply to enable sending ICMP error messages upon NAT failures.
Use undo nat icmp-error reply to restore the default.
No ICMP error messages are sent upon NAT failures.
Disabling sending ICMP error messages upon NAT failures reduces useless packets, saves bandwidth, and avoids exposing the device IP address to the public network.
This command is required for traceroute.
# Enable sending ICMP error messages upon NAT failures.
[Sysname] nat icmp-error reply
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule.
Use undo nat inbound to delete an inbound dynamic NAT rule.
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group { group-id | name group-name } [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
No inbound dynamic NAT rules exist.
Interface view
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group for address translation.
group-id: Specifies the address group ID. The value range for this argument is 0 to 65535.
name group-name: Specifies the address group name, a case-insensitive string of 1 to 63 characters.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
add-route: Automatically adds a route to the source address after translation. The output interface is the NAT interface and the next hop is the source address before translation.
rule rule-name: Specifies a name for the rule, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the rule does not have a name.
priority priority: Specifies a priority for the rule, in the range of 0 to 2147483647. A smaller value represents a higher priority. If you do not specify this option, the rule has the lowest priority among the same type of NAT rules.
disable: Disables the inbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the inbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
counting: Enables NAT counting. The number of flows that use the address mapping is counted.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the following modes:
·     PAT—Performs both IP address translation and port translation.
·     NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
·     Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
·     Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically cooperates with one of the following to implement bidirectional NAT:
·     Outbound dynamic NAT (the nat outbound command).
·     NAT Server (the nat server command).
·     Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the subnets where the internal and external networks reside overlap. For other network scenarios:
·     If you specify the add-route keyword, the device automatically adds a route to the source address after translation for a packet. The destination address is the NATed address in the NAT address group, the output interface is the interface where the command is executed, and the next hop is the source address before translation.
·     If you do not specify the add-route keyword, you must manually add the route. As a best practice, add routes manually because automatic route adding is slow.
An ACL can be used by only one inbound dynamic NAT rule on an interface.
You can configure multiple inbound dynamic NAT rules on an interface.
Inbound dynamic NAT rules configured with the same priority value are matched by using their ACLs.
·     NAT rules with named ACLs have higher priorities than NAT rules with unnamed ACLs.
·     NAT rules with named ACLs are matched in alphabetical order of their ACL names.
·     NAT rules with unnamed ACLs are matched in descending order of their ACL numbers.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface VLAN-interface 10. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds routes for translated packets. Set the rule name to abc, and the priority to 0.
[Sysname-Vlan-interface10] nat inbound 2001 address-group 1 no-pat add-route rule abc priority 0
display nat all
display nat inbound
display nat no-pat
Use nat inbound rule move to change the priority of an inbound dynamic NAT rule.
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the rule be moved.
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
This command is applicable only to named inbound dynamic NAT rules.
A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound dynamic NAT rule abc to the line before the rule def.
[Sysname-Vlan-interface10] nat inbound rule move abc before def
nat inbound
nat log alarm
Use nat log alarm to enable NAT alarm logging.
Use undo nat log alarm to disable NAT alarm logging.
nat log alarm
undo nat log alarm
NAT alarm logging is disabled.
Packets that need to be translated are dropped if the NAT resources are not enough. In NO-PAT, the NAT resources refer to the public IP addresses. In EIM PAT, the NAT resources refer to public IP addresses and ports. In NAT444, the NAT resources refer to public IP addresses, port blocks, or ports in port blocks. NAT alarm logging monitors the usage of NAT resources and outputs logs if the NAT resources are not enough.
The NAT444 gateway generates alarm logs when the ports in the extended port blocks of a dynamic port block mapping are all occupied.
Before configuring alarm logging for NAT, you must configure the custom NAT log generation and outputting features. For more information about information center, see System Management Configuration Guide.
This command take effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT alarm logging.
[Sysname] nat log alarm
display nat all
display nat log
nat log enable
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT logging is disabled.
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging, NAT444 user logging (including port block assignment and withdrawal logging), NAT alarm logging, or NAT NO-PAT logging.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
display nat all
display nat log
nat log alarm
nat log flow-active
nat log flow-begin
nat log flow-end
·     nat log port-block-assign
·     nat log port-block-withdraw
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time. The logging feature helps track active NAT flows by periodically logging the active NAT flows.
Logging for active NAT flows takes effect only after you enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
Logging for NAT session establishment events takes effect only after you enable NAT logging.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
Logging for NAT session removal events takes effect only after you enable NAT logging.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
Use nat log port-block usage threshold to set the port block usage threshold.
Use undo nat log port-block port-usage threshold to restore the default.
nat log port-block usage threshold value
undo nat log port-block usage threshold
The port block usage threshold is 90%.
value: Specifies a threshold in the range of 40 to 100 in percentage.
A log is generated when the port block usage exceeds the threshold.
# Set the port block usage threshold to 60%.
[Sysname] nat log port-block usage threshold 60
display nat all
display nat log
nat log enable
Use nat log port-block-assign to enable NAT444 user logging for port block assignment.
Use undo nat log port-block-assign to disable NAT444 user logging for port block assignment.
NAT444 user logging is disabled for port block assignment.
For static port block mappings, the NAT444 gateway generates a user log when it translates the first connection from a private IP address.
For dynamic port block mappings, the NAT444 gateway generates a user log when it assigns or extends a port block for a private IP address.
This command takes effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT444 user logging for port block assignment.
[Sysname] nat log port-block-assign
display nat all
display nat log
nat log enable
Use nat log port-block-withdraw to enable NAT444 user logging for port block withdrawal.
Use undo nat log port-block-withdraw to disable NAT444 user logging for port block withdrawal.
NAT444 user logging is disabled for port block withdrawal.
For static port block mappings, the NAT444 gateway generates a user log when all connections from a private IP address are disconnected.
For dynamic port block mappings, the NAT444 gateway generates a user log when all the following conditions are met:
·     The port blocks (including the extended ones) assigned to the private IP address are withdrawn.
·     The corresponding mapping entry is deleted.
# Enable NAT444 user logging for port block withdrawal.
[Sysname] nat log port-block-withdraw
display nat all
display nat log
nat log enable
Use nat mapping-behavior endpoint-independent to specify the Endpoint-Independent Mapping (EIM) mode for PAT.
Use undo nat mapping-behavior to restore the default.
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat mapping-behavior endpoint-independent
Address and Port-Dependent Mapping applies.
acl: Specifies an ACL to define the applicable scope of Endpoint-Independent Mapping.
PAT supports the following NAT mapping modes:
·     Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the translated IP address and port. It allows internal hosts behind different NAT gateways to access each other.
·     Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
If you specify an ACL, Endpoint-Independent Mapping applies to packets that are permitted by the ACL. If you do not specify an ACL, Endpoint-Independent Mapping applies to all packets.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping mode to FTP and HTTP packets, and the Address and Port-Dependent Mapping mode to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
nat outbound
display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group { group-id | name group-name } no-pat [ reversible ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group { group-id | name group-name } ] [ port-preserved ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
No outbound dynamic NAT rules exist.
Interface view
address-group: Specifies an address group for NAT.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
port-preserved: Tries to preserve port number for PAT. This keyword does not take effect on dynamic NAT port block mapping.
disable: Disables the outbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the outbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Outbound dynamic NAT is typically configured on the interface connected to the external network. You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT supports the following modes:
·     PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
·     NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡     Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡     Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Dynamic NAT444 does not support the NO-PAT mode.
When you specify a NAT address group, follow these restrictions and guidelines:
·     An address group cannot be used by both the nat inbound and nat outbound commands.
·     An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
·     When port block parameters are specified in the NAT address group, this command configures a dynamic NAT port block mapping. Packets matching the ACL permit rule are processed by dynamic NAT444.
When you specify an ACL, follow these restrictions and guidelines:
·     An ACL can be used by only one outbound dynamic NAT rule on an interface.
·     If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
·     Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. If two ACL-based dynamic NAT rules are configured, the rule with the higher ACL number has higher priority.
Outbound dynamic NAT rules configured with the same priority value and an ACL are matched by using the ACLs in the rule.
# Configure an outbound dynamic PAT rule on interface VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1
[Sysname-Vlan-interface10] quit
Or
# Configure an outbound NO-PAT rule on interface VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of VLAN-interface 10 as the translated address.
[Sysname] interface Vlan-interface 10
Or
# Configure an outbound NO-PAT rule on VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat reversible
display nat eim
Use nat outbound port-block-group to configure a static outbound port block mapping rule on an interface.
Use undo nat outbound port-block-group to delete a static port block mapping rule on an interface.
nat outbound port-block-group group-id [ rule rule-name ] [ counting ]
undo nat outbound port-block-group group-id
No static outbound port block mapping rule is configured on an interface.
Interface view
group-id: Specifies a NAT port block group by its ID. The value range for this argument is 0 to 65535.
After you configure this command on an interface, the system automatically computes the mappings and creates entries for them. When a private IP address accesses the public network, the private IP address is translated to the mapped public IP address, and the ports are translated to ports in the selected port block.
You can configure multiple port block mapping rules on an interface.
# Configure a static outbound port block mapping rule on VLAN-interface 10, and specify the rule name as abc.
[Sysname-Vlan-interface10] nat outbound port-block-group 1 rule abc
display nat all
nat outbound rule move
Use nat outbound rule move to change the priority of an outbound dynamic NAT rule.
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound dynamic NAT rules.
# Move the outbound dynamic NAT rule abc to the line before the rule def.
[Sysname-Vlan-interface10] nat outbound rule move abc before def
nat outbound
nat port-block global-share enable
Use nat port-block global-share enable to enable port block global sharing.
Use undo nat port-block global-share enable to disable port block global sharing.
Port block global sharing is disabled.
When multiple interfaces have dynamic NAT port block mapping configured, the interfaces might create different port block mappings for packets from the same IP address. You can use this command to configure the interfaces to use the same port block mapping for translating packets from the same IP address.
# Enable port block global sharing.
[Sysname] nat port-block global-share enable
port-block
Use nat port-block-group to create a NAT port block group and enter its view, or enter the view of an existing NAT port block group.
Use undo nat port-block-group to delete a NAT port block group.
nat port-block-group group-id
undo nat port-block-group group-id
No NAT port block groups exist.
group-id: Assigns an ID to the NAT port block group. The value range for this argument is 0 to 65535.
A NAT port block group is configured to implement static port block mapping for NAT444.
You must configure the following items for a NAT port block group:
·     A minimum of one private IP address range (see the local-ip-address command).
·     A minimum of one public IP address range (see the global-ip-address command).
·     A port range (see the port-range command).
·     A port block size (see the block-size command).
The system computes static port block mappings according to the port block group configuration, and creates entries for the mappings.
# Create NAT port block group 1.
<Sysname>system-view
[Sysname]nat port-block-group 1
block-size
display nat all
global-ip-pool
local-ip-address
port-range
nat redirect reply-route
Use nat redirect reply-route enable to enable NAT reply redirection.
Use undo nat redirect reply-route enable to disable NAT reply redirection.
NAT reply redirection is disabled.
Interface view
NAT reply redirection allows an interface to use the NAT session entry information to translate the destination IP addresses for NAT reply packets and find the output interfaces for the NATed reply packets.
# Enable NAT reply redirection on VLAN-interface 10.
[Sysname-Vlan-interface10] nat redirect reply-route enable
nat server
Use nat server to create a NAT server mapping (also called NAT server rule). The mapping maps the private IP address and port of an internal server to a public address and port.
Use undo nat server to delete a NAT server mapping.
Common NAT server mapping:
·     A single public address with no or a single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] inside local-address [ local-port ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ]
·     A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2
·     Consecutive public addresses with no or a single public port:
nat server protocol pro-type global global-address1 global-address2 [ global-port ] inside { local-address | local-address1 local-address2 } [ local-port ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ]
·     Consecutive public addresses with a single public port:
nat server protocol pro-type global global-address1 global-address2 global-port inside local-address local-port1 local-port2 [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global global-address1 global-address2 global-port
Load sharing NAT server mapping:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } inside server-group group-id [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port }
ACL-based NAT server mapping:
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
No NAT server mappings exist.
Interface view
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, NAT Server can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
·     A number in the range of 1 to 255.
·     A protocol name of icmp, tcp, or udp.
global: Specifies the public network information about the internal server.
global-address: Specifies the public address of an internal server.
global-address1 global address2: Specifies a public IP address range, which can include a maximum of 10000 addresses. The global-address1 argument specifies the start address, and the global address2 argument specifies the end address that must be greater than the start address.
current-interface: Enables Easy IP on the current interface. The primary IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The primary IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 10000 ports. The global-port1 argument specifies the start port, and the global-port2 argument specifies the end port that must be greater than the start port. The public port number format can be one of the following:
·     A number in the range of 1 to 65535. Both the start port and the end port support this format.
·     A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
inside: Specifies the private network information about the internal server.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and the local-address2 argument specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
·     A number in the range of 1 to 65535, excluding FTP port 20.
global-port: Specifies the public port number. The default value and value range are the same as those for the local-port argument.
local-address: Specifies the private IP address.
server-group group-id: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-id argument specifies the internal server group ID. The value range for the group-id argument is 0 to 65535.
acl: Specifies an ACL. If you specify an ACL, only packets permitted by the ACL can be translated by using the mapping.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
rule rule-name: Specifies a name for the mapping, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the mapping does not have a name.
priority priority: Specifies a priority for the mapping, in the range of 0 to 2147483647. A smaller value represents a higher priority. If you do not specify this option, the mapping has the lowest priority among the same type of NAT rules.
disable: Disables the NAT server mapping. If you do not specify this keyword, the mapping is enabled.
description text: Specifies a description for the mapping. The text argument is a case-insensitive string of 1 to 63 characters.
You can configure the NAT server mapping to allow servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network to provide services for external users.
NAT server mappings are usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port. When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mappings. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 19 Address-port mappings for NAT Server
External network
Internal network
One public address
One private address
One public address and one public port number
One private address and one private port number
One public address and N consecutive public port numbers
·     One private address and one private port number
·     N consecutive private addresses and one private port number
·     One private address and N consecutive private port numbers
N consecutive public addresses
N consecutive public addresses and one public port number
One internal server group
Public addresses matching an ACL
One private address
 The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface. This restriction also applies when Easy IP is used. The maximum number of NAT server mappings equals the number of public ports in the specified public port range.
As a best practice, do not configure Easy IP for multiple NAT server mappings by using the same interface.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of a NAT server mapping not using Easy IP, the Easy IP configuration becomes invalid. If the conflicting IP address is modified to another IP address or the NAT server mapping without Easy IP is removed, the Easy IP configuration takes effect.
When you configure a load sharing NAT server mapping, you must make sure a user uses the same public address and public port to access the same service on an internal server. For this purpose, make sure value N in the following mappings is equal to or less than the number of servers in the internal server group:
·     One public address and N consecutive public port numbers are mapped to one internal server group.
·     N consecutive public addresses and a public port number are mapped to one internal server group.
ACL-based NAT server mappings that are configured with the same priority value are matched by using the ACLs in their rules:
·     Mappings with named ACLs have higher priorities than mappings with unnamed ACLs.
·     Mappings with named ACLs are matched in alphabetical order of their ACL names.
·     Mappings with unnamed ACLs are matched in descending order of their ACL numbers.
An error message for a rollback failure when you perform a configuration rollback for an internal server in the following situation:
·     In the running configuration, the name of a NAT server mapping is assigned automatically by the system.
·     In the replacement configuration file, the name does not exist.
The system will compare the running configuration file and the replacement file, and display an error message about the mismatch. You can ignore the error message because the NAT server mapping configuration in the configuration file is installed successfully. For example, the NAT server mapping configuration is nat server global 112.1.1.1 inside 192.168.20.1 in the running configuration, and the is nat server global 112.1.1.1 inside 192.168.20.1 rule ServerRule_num in the replacement configuration file. After the rollback operation, the new NAT server configuration is successfully installed.
# Allow external users to access the internal Web server at 10.110.10.10 through http://202.110.10.10:8080.
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# Configure an ACL-based NAT server mapping to allow users to use IP addresses in subnet 192.168.0.0/24 to access the internal server at 10.0.0.172.
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-Vlan-interface10] nat server global 3000 inside 10.0.0.172
display nat all
display nat server
nat server-group
nat server rule move
Use nat server rule move to change the priority of an ACL-based NAT server rule.
nat server rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
This command is applicable only to named ACL-based NAT server rules.
# Move the ACL-based NAT server rule abc to the line before the ACL-based NAT server rule def.
[Sysname-Vlan-interface10] nat server rule move abc before def
nat server
nat server-group
Use nat server-group to create an internal server group and enter its view, or enter the view of an existing internal server group.
Use undo nat server-group to delete an internal server group.
nat server-group group-id
undo nat server-group group-id
No internal server groups exist.
group-id: Assigns an ID to the internal server group.The value range for this argument is 0 to 65535.
An internal server group can contain multiple members configured by the inside ip command.
# Create internal server group 1.
display nat all
inside ip
nat server
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on VLAN-interface 10.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface10] nat static enable
display nat all
display nat static
nat static
nat static net-to-net
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip local-ip [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound global-ip local-ip
No NAT mappings exist.
global-ip: Specifies a public IP address.
local-ip: Specifies a private IP address.
acl: Specifies an ACL to identify the internal hosts that can access the external network.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address.
disable: Disables the one-to-one inbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source IP address of a packet from the external network to the internal network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the internal network to the external network matches the local-ip, the destination IP address is translated into the global-ip.
·     If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡     Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
One-to-one mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address local local-network { mask-length | mask } [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound net-to-net global-start-address global-end-address local local-network { mask-length | mask }
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 255 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses.
disable: Disables the net-to-net inbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
When the source address of a packet from the external network matches the public address range, the source address is translated into a private address in the private address range. When the destination address of a packet from the internal network matches the private address range, the destination address is translated into a public address in the public address range.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Net-to-net mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
nat static inbound rule move
Use nat static inbound rule move to change the priority of an inbound one-to-one static NAT rule.
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command is applicable only to named inbound one-to-one static NAT rules.
# Move the inbound one-to-one static NAT rule abc to the line before the inbound one-to-one static NAT rule def.
[Sysname] nat static inbound rule move abc before def
nat static inbound
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip global-ip [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound local-ip global-ip
acl: Specifies an ACL to define the destination IP addresses that internal hosts can access.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP address.
disable: Disables the one-to-one outbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
·     If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Static NAT takes precedence over dynamic NAT when they are both configured on an interface.
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
One-to-one mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address global global-network { mask-length | mask } [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound net-to-net local-start-address local-end-address global global-network { mask-length | mask }
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 255 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
global-network: Specifies a public network address.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
ipv4-acl-number: Specifies an ACL number in the range of 2000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses.
disable: Disables the net-to-net outbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Net-to-net mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
nat static outbound rule move
Use nat static outbound rule move to change the priority of an outbound one-to-one static NAT rule.
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command is applicable only to named outbound one-to-one static NAT rules..
# Move the outbound one-to-one static NAT rule abc to the line before the outbound one-to-one static NAT rule def.
[Sysname] nat static outbound rule move abc before def
nat static outbound
port-block
Use port block to configure port block parameters for a NAT address group.
Use undo port block to restore the default.
port block block-size block-size [ extended-block-number extended-block-number ]
undo port block
No port block parameters are configured for a NAT address group.
NAT address group view
block-size block-size: Specifies the port block size. The value range for the block-size argument is 1 to 65535. In a NAT address group, the port block size cannot be larger than the number of ports in the port range.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When a private IP address accesses the public network, but the ports in the selected port block are all occupied, the NAT444 gateway extends port blocks one by one for the private IP address.
To configure dynamic port block mappings, port block parameters are required in the NAT address group. When a private IP address initiates a connection to the public network, the NAT444 gateway assigns it a public IP address and a port block, and creates an entry for the mapping. For subsequent connections from the private IP address, the NAT444 gateway translates the private IP address to the mapped public IP address and the ports to ports in the selected port block.
# Set the port block size to 256 and the number of extended port blocks to 1 in NAT address group 2.
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
nat address-group
port-range
Use port-range to specify a port range for public IP addresses.
Use undo port-range to restore the default.
port-range start-port-number end-port-number
undo port-range
The port range for public IP addresses is 1 to 65535.
NAT port block group view
start-port-number end-port-number: Specifies the start port number and end port number for the port range. The end port number cannot be smaller than the start port number. As a best practice, set the start port number to be equal to or larger than 1024 to avoid an application protocol identification error.
The port range must include all ports that public IP addresses use for address translation.
The number of ports in a port range cannot be smaller than the port block size.
# Specify the port range as 1024 to 65535 for NAT address group 1.
[Sysname] nat address-group 1
[Sysname-address-group-1] port-range 1024 65535
# Specify the port range as 30001 to 65535 for NAT port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] port-range 30001 65535
nat address-group
reset nat count statistics
Use reset nat count statistics to clear NAT counting statistics.
reset nat count statistics { all | dynamic | server | static | static-port-block }
all: Clears all counting statistics for NAT mappings.
dynamic: Clears counting statistics for dynamic NAT mappings.
server: Clears counting statistics for NAT server mappings.
static: Clears counting statistics for static NAT mappings.
static-port-block: Clears counting statistics for NAT444 mappings.
# Clear all counting statistics for static NAT mappings.
<Sysname> reset nat count statistics all
display nat inbound
display nat outbound
display nat outbound port-block-group
display nat port-block
display nat static
display nat server
reset nat session
Use reset nat session to clear NAT sessions.
reset nat session
# Clear all NAT sessions.
<Sysname> reset nat session
display nat session
