H3C Access Points Cloud Mode Web-Based Configuration Guide(E2442 R2442)-6W100
HomeSupportConfigure & DeployUser ManualsH3C Access Points Cloud Mode Web-Based Configuration Guide(E2442 R2442)-6W100
01-Login
01-Login 66.98 KB
Logging in to the Web interface
Log in to the Web interface through HTTP or HTTPS.
To ensure a successful login, verify that your operating system and Web browser meet the requirements, and follow the guidelines in this section.
Web browser requirements
As a best practice, use the following Web browsers:
·     Internet Explorer 10 or higher.
·     Mozilla Firefox 30.0.0.5269 or higher
·     Google Chrome 35.0.1916.114 or higher.
·     Safari 6.0 or higher.
To access the Web interface, you must use the following browser settings:
·     Accept the first-party cookies (cookies from the site you are accessing).
·     To ensure correct display of webpage contents after software upgrade or downgrade, clear data cached by the browser before you log in.
·     Enable active scripting or JavaScript, depending on the Web browser.
·     If you are using a Microsoft Internet Explorer browser, you must enable the following security settings:
¡     Run ActiveX controls and plug-ins.
¡     Script ActiveX controls marked safe for scripting.
Make sure the display resolution of the PC, laptop, or tablet that you use to access the Web interface is 1024 × 768 or higher.
Default login settings
Use settings in Table 1 for the first login.
Table 1 Default login settings
Item
Setting
Device IP (VLAN-interface 1)
192.168.0.50
IP address mask
255.255.0.0
Username
admin
Password
h3capadmin
User role
Concurrent login users
The Web interface allows a maximum of 64 concurrent accesses. If this limit is reached, login attempts will fail.
Logging in to the Web interface for the first time
IMPORTANT
IMPORTANT:
For security purposes, change the login information immediately after the first successful login.
You can log in to the device through HTTP or HTTPS. By default, HTTP and HTTPS are enabled.
Use Table 2 to determine the first-time login method.
Table 2 Hardware compatibility with the first-time login methods
Hardware series
Model
Method one compatibility
Method two compatibility
WA6600 series
WA6638
Yes
No
WA6638i
Yes
No
WA6636
Yes
No
WA6630X
Yes
No
WA6628
Yes
No
WA6628X
Yes
No
WA6628E-T
No
Yes
WA6622
Yes
No
WA6620
Yes
No
WA6620X
Yes
No
WA6300 series
WA6338
Yes
No
WA6338-HI
Yes
No
WA6338-LI
Yes
No
WA6330
Yes
No
WA6330-LI
Yes
No
WA6322
Yes
No
WA6322H
Yes
No
WA6322H-HI
Yes
No
WA6322H-LI
Yes
No
WA6320
Yes
No
WA6320-C
Yes
No
WA6320-D
Yes
No
WA6320-SI
Yes
No
WA6320H
Yes
No
WA6320H-LI
Yes
No
WA6320H-XEPON
Yes
No
WAP922 series
WAP922E
Yes
No
WAP923 series
WAP923
Yes
No
Method one
1.     Connect the device to the WLAN whose SSID is H3C_xxxxxx, where xxxxxx represents the last six characters of the device's MAC address.
2.     Visit http://myap.h3c.com through a browser.
3.     On the login page, enter the default username (admin) and the default password (h3capadmin).
4.     Click Login.
You can change the login password as prompted to enhance security.
Method two
¡     se an Ethernet cable to connect the configuration terminal to an Ethernet port on the device.
¡     To use a wireless connection, connect the configuration terminal to the WLAN whose SSID is H3C.
1.     Open the browser, and then enter login information:
a.     In the address bar, enter the IP address of the device.
-     HTTP access—Enter the address in the http://ip-address:port or ip-address:port format.
-     HTTPS accessEnter the address in the https://ip-address:port format.
The ip-address argument represents the IP address of the device. The port argument represents the HTTP or HTTPS service port. The default IP address is 192.168.0.50. The default port number is 80 for HTTP and 443 for HTTPS. You do not need to enter the port number if you have not changed the service port setting.
b.     On the login page, enter the default username (admin) and the default password (h3capadmin).
c.     Click Login.
2.     Change the login information:
¡     To change the IP address of the device, perform the following tasks:
-     Click the system view tab at the bottom of the page.
-     From the navigation tree, select Network Configuration > Network Services > IP Services. You are placed on the IP tab.
You must log in to the device again after you change the IP address.
¡     To change the password of the login user (h3capadmin at the first login) or add new administrator accounts, perform the following tasks:
-     From the navigation tree, select System > Administrators to access the administrator configuration page.
Logging out of the Web interface
IMPORTANT
IMPORTANT:
·     For security purposes, log out of the Web interface immediately after you finish your tasks.
·     The device does not automatically save the configuration when you log out of the Web interface. To prevent the loss of configuration when the device reboots, you must save the configuration.
To log out of the Web interface:
1.     Use one of the following methods to save the current configuration:
Method 1:
Click the admin icon  in the upper right corner of the Web interface, and click Save.
Method 2:
a.     Click the system view tab at the bottom of the page, select System > Management from the navigation tree.
b.     Click the Configuration tab to access the configuration page.
c.     Click Save Running Configuration.
2.     Click the admin icon , and then click Logout.
