H3C SR6600&SR6600-X Routers Configuration Examples-6W100
HomeSupportRoutersConfigure & DeployConfiguration ExamplesH3C SR6600&SR6600-X Routers Configuration Examples-6W100
05-H3C SR6600&SR6600-X Routers IS-IS Configuration Examples
SR6600 Router Series
SR6600-X Router Series
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
Example: Configuring IS-IS·· 1
Network requirements· 1
Requirements analysis· 2
Software version used· 2
Configuration restrictions and guidelines· 2
Configuration procedures· 2
Configuring Router A· 2
Configuring Router B· 2
Configuring Router C· 3
Configuring Router D·· 4
Configuring Router E· 4
Verifying the configuration· 5
Configuration files· 7
Related documentation· 9
Introduction
This document provides IS-IS configuration examples.
This document assumes that you have basic knowledge of IS-IS.
As shown in Figure 1, the company's headquarters and the branch run IS-IS. The partner runs OSPF.
Configure the routers to meet the following requirements:
·     Reduce traffic for Router A and Router B because they have relative low performance.
·     The Marketing Department can reach the Finance Department, the branch, and the partner.
·     The Finance Department and the branch cannot reach each other, and the branch does not have a route to the Finance Department.
·     When the IS-IS process on Router C restarts, the communication is not interrupted.
Figure 1 Network diagram
To meet the network requirements, you must perform the following tasks:
·     To reduce traffic for Router A and Router B, configure them as Level-1 routers to allow communication only between the Marketing Department and the Finance Department.
·     Configure route redistribution between IS-IS and OSPF on Router D to allow communication between the Marketing Department and the partner.
·     Configure Router C to use a prefix list to advertise only network 10.100.1.0/24 to Level-2 to ensure that the branch does not have a route to the Finance Department.
·     Enable IS-IS Graceful Restart (GR) on Router C to ensure that the communication is not interrupted when the IS-IS process on Router C restarts.
This configuration example was created and verified on R7607.
To avoid blackhole routes, do not change the network topology during the IS-IS GR process.
# Configure an IP address for GigabitEthernet 3/1/1.
[RouterA] interface gigabitethernet 3/1/1
[RouterA-GigabitEthernet3/1/1] ip address 192.168.1.1 24
[RouterA-GigabitEthernet3/1/1] quit
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IS-IS.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.1921.6800.1001.00
[RouterA-isis-1] quit
[RouterA–GigabitEthernet3/1/1] isis enable 1
[RouterA–GigabitEthernet3/1/1] quit
[RouterA] interface gigabitethernet 3/1/2
[RouterA–GigabitEthernet3/1/2] isis enable 1
[RouterA–GigabitEthernet3/1/2] quit
<RouterB> system-view
[RouterB] interface gigabitethernet 3/1/1
[RouterB-GigabitEthernet3/1/1] ip address 192.168.2.1 24
[RouterB-GigabitEthernet3/1/1] quit
# Configure IS-IS.
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.1921.6800.2001.00
[RouterB-isis-1] quit
[RouterB–GigabitEthernet3/1/1] isis enable 1
[RouterB–GigabitEthernet3/1/1] quit
[RouterB] interface gigabitethernet 3/1/2
[RouterB–GigabitEthernet3/1/2] isis enable 1
[RouterB–GigabitEthernet3/1/2] quit
<RouterC> system-view
[RouterC] interface gigabitethernet 3/1/1
[RouterC-GigabitEthernet3/1/1] ip address 192.168.1.2 24
[RouterC-GigabitEthernet3/1/1] quit
# Configure IS-IS.
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.1921.6801.0001.00
[RouterC-isis-1] quit
[RouterC–GigabitEthernet3/1/1] isis enable 1
[RouterC–GigabitEthernet3/1/1] quit
[RouterC] interface gigabitethernet 3/1/2
[RouterC–GigabitEthernet3/1/2] isis enable 1
[RouterC–GigabitEthernet3/1/2] quit
[RouterC] interface gigabitethernet 3/1/3
[RouterC–GigabitEthernet3/1/3] isis enable 1
[RouterC–GigabitEthernet3/1/3] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 10.100.1.0/24 to Level-2.
[RouterC] ip prefix-list 1 permit 10.100.1.0 24
[RouterC] isis 1
[RouterC-isis-1] address-family ipv4
[RouterC-isis-1-ipv4] import-route isis level-1 into level-2 filter-policy prefix-list 1
[RouterC-isis-1-ipv4] quit
[RouterC-isis-1] import-route isis level-1 into level-2 filter-policy prefix-list 1
# Enable IS-IS GR.
[RouterC -isis-1] graceful-restart
[RouterC -isis-1] quit
<RouterD> system-view
[RouterD] interface gigabitethernet 3/1/1
[RouterD-GigabitEthernet3/1/1] ip address 192.168.10.2 24
[RouterD-GigabitEthernet3/1/1] quit
# Configure IS-IS.
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.1921.6802.0001.00
[RouterD-isis-1] quit
[RouterD–GigabitEthernet3/1/1] isis enable 1
[RouterD–GigabitEthernet3/1/1] quit
[RouterD] interface gigabitethernet 3/1/2
[RouterD–GigabitEthernet3/1/2] isis enable 1
[RouterD–GigabitEthernet3/1/2] quit
# Configure OSPF.
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
# Redistribute OSPF and direct routes into IS-IS.
[RouterD] isis 1
[RouterD-isis-1] address-family ipv4
[RouterD-isis-1-ipv4] import-route ospf
[RouterD-isis-1-ipv4] import-route direct
[RouterD-isis-1-ipv4] quit
# Redistribute IS-IS and direct routes into OSPF.
[RouterD] ospf 1
[RouterD-ospf-1] import-route isis 1
[RouterD-ospf-1] import-route direct
<RouterE> system-view
[RouterE] interface gigabitethernet 3/1/1
[RouterE-GigabitEthernet3/1/1] ip address 192.168.20.2 24
[RouterE-GigabitEthernet3/1/1] quit
# Configure OSPF.
[RouterE] ospf
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 10.200.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
# Verify that the branch can reach the Marketing Department, but cannot reach the Finance Department.
[RouterD] display isis route
                         Level-2 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 192.168.10.0/24      10         NULL    GE3/1/1         Direct          D/L/-
 192.168.1.0/24       20         NULL    GE3/1/1         192.168.10.1    R/-/-
 10.100.1.0/24        30         NULL    GE3/1/1         192.168.10.1    R/-/-
 192.168.2.0/24       20         NULL    GE3/1/1         192.168.10.1    R/-/-
# Verify that the company can communicate with the partner.
·     Display the IS-IS routing table on Router C.
[RouterC] display isis route
                         Level-1 IPv4 Forwarding Table
 192.168.10.0/24      10         NULL    GE3/1/3         Direct          D/L/-
 192.168.1.0/24       10         NULL    GE3/1/1         Direct          D/L/-
 10.100.1.0/24        20         NULL    GE3/1/1         192.168.1.1     R/L/-
 10.100.2.0/24        20         NULL    GE3/1/2         192.168.2.1     R/-/-
 192.168.2.0/24       10         NULL    GE3/1/2         Direct          D/L/-
 10.200.1.0/24        10         0       GE3/1/3         192.168.10.2    R/-/-
 192.168.20.0/24      10         0       GE3/1/3         192.168.10.2    R/-/-
·     Ping 10.200.1.1 from the interface GigabitEthernet 3/1/2 on Router A.
[RouterA] ping –a 10.1.1.1 10.200.1.1
Ping 10.200.1.1 (10.200.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.200.1.1: icmp_seq=0 ttl=252 time=1.862 ms
56 bytes from 10.200.1.1: icmp_seq=1 ttl=252 time=2.969 ms
56 bytes from 10.200.1.1: icmp_seq=2 ttl=252 time=1.402 ms
56 bytes from 10.200.1.1: icmp_seq=3 ttl=252 time=1.324 ms
56 bytes from 10.200.1.1: icmp_seq=4 ttl=252 time=1.510 ms
--- Ping statistics for 10.200.1.1 ---
round-trip min/avg/max/std-dev = 1.324/1.813/2.969/0.606 ms
# Verify that the communication is not interrupted when the IS-IS process restarts.
·     Ping Router B from Router A.
[RouterA] ping -c 10000 10.100.2.1
Ping 10.100.2.1 (10.100.2.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.100.2.1: icmp_seq=0 ttl=254 time=1.185 ms
56 bytes from 10.100.2.1: icmp_seq=1 ttl=254 time=1.087 ms
·     Restart the IS-IS process on Router C.
[RouterC] reset isis all graceful-restart
Reset IS-IS process? [Y/N] :y
56 bytes from 10.100.2.1: icmp_seq=2 ttl=254 time=1.672 ms
56 bytes from 10.100.2.1: icmp_seq=3 ttl=254 time=1.751 ms
56 bytes from 10.100.2.1: icmp_seq=4 ttl=254 time=1.816 ms
56 bytes from 10.100.2.1: icmp_seq=5 ttl=254 time=1.814 ms
·     Check the IS-IS GR state on Router C.
[RouterC] display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 3
Number of waiting LSPs: 0
                          Level-2 restart information
Configuration files
·     Router A:
isis 1
 is-level level-1
interface GigabitEthernet3/1/1
 isis enable 1
interface GigabitEthernet3/1/2
 ip address 10.100.1.1 255.255.255.0
 isis enable 1
·     Router B:
isis 1
 is-level level-1
 ip address 192.168.2.1 255.255.255.0
 isis enable 1
 ip address 10.100.2.1 255.255.255.0
 isis enable 1
·     Router C:
isis 1
 graceful-restart
 address-family ipv4 unicast
 ip address 192.168.1.2 255.255.255.0
 isis enable 1
 ip address 192.168.2.2 255.255.255.0
 isis enable 1
interface GigabitEthernet3/1/3
 ip address 192.168.10.1 255.255.255.0
 isis enable 1
 ip prefix-list 1 index 10 permit 10.100.1.0 24
·     Router D:
isis 1
 is-level level-2
  import-route direct
  import-route ospf 1
ospf 1
 import-route direct
 import-route isis 1
 area 0.0.0.0
 ip address 192.168.10.2 255.255.255.0
 isis enable 1
 ip address 192.168.20.1 255.255.255.0
·     Router E:
ospf 1
 area 0.0.0.0
 ip address 192.168.20.2 255.255.255.0
 ip address 10.200.1.1 255.255.255.0
·     H3C SR6600 SR6600-X Routers Layer 3—IP Routing Command Reference-Release 7607
·     H3C SR6600 SR6600-X Routers Layer 3—IP Routing Configuration Guide-Release 7607
