- H3C SR6600&SR6600-X Routers Configuration Examples-6W100
- 01-H3C SR6600&SR6600-X Routers Basic MPLS Configuration Examples
- 02-H3C SR6600&SR6600-X Routers BGP Configuration Examples
- 03-H3C SR6600&SR6600-X Routers Ethernet Link Aggregation Configuration Examples
- 04-H3C SR6600&SR6600-X Routers IPv6 IS-IS Configuration Examples
- 05-H3C SR6600&SR6600-X Routers IS-IS Configuration Examples
- 06-H3C SR6600&SR6600-X Routers OSPF Configuration Examples
- 07-H3C SR6600&SR6600-X Routers OSPFv3 Configuration Examples
- 08-H3C SR6600&SR6600-X Routers Policy-Based Routing Configuration Examples
- 09-H3C SR6600&SR6600-X Routers PPP Configuration Examples
- 10-H3C SR6600&SR6600-X Routers RBAC Configuration Examples
| 09-H3C SR6600&SR6600-X Routers PPP Configuration Examples | 196.90 KB |
H3C SR6600&SR6600-X Routers |
SR6600 Router Series
SR6600-X Router Series
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
The information in this
document is subject to change without notice.
Example: Configuring MP and CHAP
Example: Configuring PPPoE server IP address assignment through a remote DHCP server
Introduction
This document provides PPP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of PPP, MP, PPPoE, and DHCP.
Network requirements
As shown in Figure 1, bind Serial 2/1/0 and Serial 2/1/1 into an MP bundle on an MP-group interface. Specify CHAP as the authentication mode for each PPP link.
Software version used
This configuration example was created and verified on Release R7607.
When you configure MP and CHAP, follow these restrictions and guidelines:
· The username and password on each end must be the same for CHAP authentication.
· To bring up the configured serial interfaces, use the shutdown and then undo shutdown commands.
· Make sure you create a network access user.
Configuration procedures
Configuring Device A
# Create a user account for Device B.
[DeviceA] local-user userb class network
# Set a password for the user account.
[DeviceA-luser-network-userb] password simple hello
# Set the service type of the user account to PPP.
[DeviceA-luser-network-userb] service-type ppp
[DeviceA-luser-network-userb] quit
# Enable PPP encapsulation on Serial 2/1/0.
[DeviceA] interface serial 2/1/0
[DeviceA-Serial2/1/0] link-protocol ppp
# Set the authentication mode to CHAP.
[DeviceA-Serial2/1/0] ppp authentication-mode chap domain system
[DeviceA-Serial2/1/0] quit
# Enable PPP encapsulation on Serial 2/1/1.
[DeviceA] interface serial 2/1/1
[DeviceA-Serial2/1/1] link-protocol ppp
[DeviceA-Serial2/1/1] ppp authentication-mode chap domain system
[DeviceA-Serial2/1/1] quit
# Configure local authentication for the PPP user in the default ISP domain system.
[DeviceA] domain system
[DeviceA-isp-system] authentication ppp local
# Create an MP-group interface, and assign an IP address to it.
[DeviceA] interface mp-group 3/0/1
[DeviceA-MP-group3/0/1] ip address 1.1.1.1 24
[DeviceA-MP-group3/0/1] quit
# Configure interface Serial 2/1/0.
[DeviceA-Serial2/1/0] ppp mp mp-group 3/0/1
[DeviceA-Serial2/1/0] shutdown
[DeviceA-Serial2/1/0] undo shutdown
# Configure interface Serial 2/1/1.
[DeviceA-Serial2/1/1] ppp mp mp-group 3/0/1
[DeviceA-Serial2/1/1] shutdown
[DeviceA-Serial2/1/1] undo shutdown
Configuring Device B
[DeviceB] interface serial 2/1/0
[DeviceB-Serial2/1/0] link-protocol ppp
# Configure the username and password for CHAP authentication.
[DeviceB-Serial2/1/0] ppp chap user userb
[DeviceB-Serial2/1/0] ppp chap password simple hello
[DeviceB-Serial2/1/0] quit
[DeviceB] interface serial 2/1/1
[DeviceB-Serial2/1/1] link-protocol ppp
[DeviceB-Serial2/1/1] ppp chap user userb
[DeviceB-Serial2/1/1] ppp chap password simple hello
[DeviceB-Serial2/1/1] quit
[DeviceB] interface mp-group 3/0/1
[DeviceB-MP-group3/0/1] ip address 1.1.1.2 24
[DeviceB-MP-group3/0/1] quit
# Add interface Serial 2/1/0 to MP-group 3/0/1, and bring up the interface.
[DeviceB-Serial2/1/0] ppp mp mp-group 3/0/1
[DeviceB-Serial2/1/0] shutdown
[DeviceB-Serial2/1/0] undo shutdown
# Add interface Serial 2/1/1 to MP-group 3/0/1, and bring up the interface.
[DeviceB-Serial2/1/1] ppp mp mp-group 3/0/1
[DeviceB-Serial2/1/1] shutdown
[DeviceB-Serial2/1/1] undo shutdown
# Display MP information on Device A.
Template: MP-group3/0/1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: MP-group3/0/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group3/0/1
Sequence format: long (rcv)/long (sent)
Bundle Up Time: 2017/07/22 16:51:40:835
0 lost fragments, 5 reordered, 0 unassigned, 0 interleaved
Sequence: 4 (rcv)/5 (sent)
Active member channels: 2 members
Serial2/1/0 Up-Time:2017/07/22 16:51:40:836
Serial2/1/1 Up-Time:2017/07/22 16:51:53:542
# Display information about interface MP-group 3/0/1 on Device A.
[DeviceA] display interface mp-group 3/0/1
MP-group3/0/1
Current state: UP
Line protocol state: UP
Description: MP-group3/0/1 Interface
Bandwidth: 128kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds
Internet Address is 1.1.1.1/24 Primary
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 128000 bps
Last 300 seconds input rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Last 300 seconds output rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Input: 8 packets, 466 bytes, 0 drops
Output: 8 packets, 456 bytes, 0 drops
# Ping Device B from Device A.
Ping 1.1.1.2 (1.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 1.1.1.2: icmp_seq=0 ttl=255 time=25.749 ms
56 bytes from 1.1.1.2: icmp_seq=1 ttl=255 time=25.751 ms
56 bytes from 1.1.1.2: icmp_seq=2 ttl=255 time=25.521 ms
56 bytes from 1.1.1.2: icmp_seq=3 ttl=255 time=25.512 ms
56 bytes from 1.1.1.2: icmp_seq=4 ttl=255 time=25.599 ms
--- Ping statistics for 1.1.1.2 ---
round-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms
<DeviceA>%Jul 22 17:08:22:460 2017 DeviceA PING/6/PING_STATISTICS: Ping statisti
cs for 1.1.1.2: 5 packets transmitted, 5 packets received, 0.0% packet loss, rou
nd-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms.
Configuration files
interface Serial2/1/0
ppp mp MP-group3/0/1
interface Serial2/1/1
interface MP-group3/0/1
ip address 1.1.1.1 255.255.255.0
local-user 123 class network
password cipher $c$3$5ulb/vg58eiBIm5EnilnsZ2cS2Cmwg==
service-type ppp
· Device B:
ppp chap password cipher $c$3$4kD4T3bLZ/lngijhEKIS70/oTbNSkw==
ppp chap user 123
ppp chap password cipher $c$3$mVlcV3W+YQBgmxKePKpZV9tTcaFhXg==
ppp chap user 123
ip address 1.1.1.2 255.255.255.0
As shown in Figure 2, Device A acts as the PPPoE server to provide access control and CHAP authentication for Host A. Device B acts as the DHCP server. Configure Device A as a DHCP relay agent to relay an IP address from Device B to Host A.
The configuration example was created and verified on Release R7607.
When you configure the PPPoE server, follow these restrictions and guidelines:
· The username and password configured on the PPPoE server and the host must be the same for CHAP authentication.
· Make sure you create a network access user account for the PPPoE user.
# Assign IP addresses to interfaces GigabitEthernet 2/1/0 and GigabitEthernet 2/1/1.
[DeviceA] interface gigabitethernet 2/1/0
[DeviceA-GigabitEthernet2/1/0] ip address 10.1.1.1 24
[DeviceA-GigabitEthernet2/1/0] quit
[DeviceA] interface gigabitethernet 2/1/1
[DeviceA-GigabitEthernet2/1/1] ip address 3.1.1.2 24
[DeviceA-GigabitEthernet2/1/1] quit
# Configure interface Virtual-Template 10 to use CHAP for authentication and use a DHCP address pool for IP address assignment.
[DeviceA] interface virtual-template 10
[DeviceA-Virtual-Template10] ppp authentication-mode chap domain system
# Assign an IP address to Virtual-Template 10.
[DeviceA-Virtual-Template10] ip address 1.1.1.1 32
[DeviceA-Virtual-Template10] quit
# Enable the PPPoE server on GigabitEthernet 2/1/0, and bind the interface to Virtual-Template 10.
[DeviceA-GigabitEthernet2/1/0] pppoe-server bind virtual-template 10
# Enable DHCP.
# Enable relay entry recording on the relay agent.
[DeviceA] dhcp relay client-information record
# Create a DHCP relay address pool pool1.
[DeviceA] dhcp server ip-pool pool1
# Specify a gateway address for the DHCPv4 clients in pool1.
[DeviceA-dhcp-pool-pool1] gateway-list 2.2.2.2 export-route
# Specify a DHCP server for pool1.
[DeviceA-dhcp-pool-pool1] remote-server 3.1.1.1
[DeviceA-dhcp-pool-pool1] quit
# Configure a PPPoE user.
[DeviceA] local-user user1 class network
[DeviceA-luser-network-user1] password simple pass1
[DeviceA-luser-network-user1] service-type ppp
[DeviceA-luser-network-user1] quit
# Associate ISP domain system with pool 1.
[DeviceA-isp-system] authorization-attribute ip-pool pool1
[DeviceA-isp-system] quit
# Assign an IP address to GigabitEthernet 2/1/1.
[DeviceA-GigabitEthernet2/1/1] ip address 3.1.1.1 24
# Enable DHCP.
[DeviceB] dhcp enable
# Create DHCP address pool pool1, and specify a primary subnet and a gateway address for DHCP clients.
[DeviceB] dhcp server ip-pool pool1
[DeviceB-dhcp-pool-pool1] network 2.2.2.0 24
[DeviceB-dhcp-pool-pool1] gateway-list 2.2.2.1
[DeviceB-dhcp-pool-pool1] quit
# Configure a static route to the PPPoE server.
[DeviceB] ip route-static 2.2.2.0 24 3.1.1.2
1. Creating an Internet connection on Host A.
a. Right click My Network Places, select Properties from the list.
The Network Connections page appears, as shown in Figure 3.
Figure 3 The Network Connections page
b. Double click New Connection Wizard. On the wizard that appears, click Next.
c. On the window that appears, select Connect to the Internet, and click Next, as shown in Figure 4.
Figure 4 Selecting network connection type
d. On the window that appears, select Connect using a broadband connection that requires a user name and password, and click Next, as shown in Figure 5.
Figure 5 Selecting Internet Connection method
e. On the window that appears, perform either of the following tasks, as shown in Figure 6:
- Enter an ISP name in the ISP Name field, and click Next.
- Click Next directly.
Figure 6 Creating a connection name
f. On the window that appears, select Anyone's use, and click Next, as shown in Figure 7.
Figure 7 Configuring the connection availability
g. On the window that appears, perform the following tasks, as shown in Figure 8:
- Enter user1 in the User name field.
- Enter pass1 in the Password and the Confirm password fields.
- Click Next.
Figure 8 Configuring Internet account information
h. On the window that appears, click Finish.
The connection dialog box appears, as shown in Figure 9.
Figure 9 The connection dialog box
i. On the dialog box, click Connect.
j. Return to the Network Connections page.
You can view a new broadband connection.
k. Double click the connection.
The broadband connection status window appears, as shown in Figure 10, which indicates that the connection has been established successfully.
Figure 10 The broadband connection status window
2. Display the relay entry on the relay agent on Device A.
[DeviceA] display dhcp relay client-information
Total number of client-information items: 1
Total number of dynamic items: 1
Total number of temporary items: 0
IP address MAC address Type Interface VPN name
2.2.2.1 3408-0499-b48c Dynamic VA0 N/A
3. Display binding information about the assigned DHCP address on Device B.
[DeviceB] display dhcp server ip-in-use
IP address Client identifier/ Lease expiration Type
Hardware address
2.2.2.1 0033-3430-382e-3034- Jul 24 16:28:57 2017 Auto(C)
3939-2e62-3438-632d-
5641-30
Configuration files
· Device A:
dhcp enable
gateway-list 2.2.2.10 2.2.2.20 export-route
interface Virtual-Template10
interface GigabitEthernet2/1/0
port link-mode route
interface GigabitEthernet2/1/1
ip address 3.1.1.2 255.255.255.0
domain system
password cipher $c$3$rgL97ckhgtCEhbMs1yy7lxMp2yVuIOk8
service-type ppp
· Device B:
dhcp enable
network 2.2.2.0 mask 255.255.255.0
ip address 3.1.1.1 255.255.255.0
Related documentation
· H3C SR6600 SR6600-X Routers Layer 2—WAN Access Command Reference-Release 7607
· H3C SR6600 SR6600-X Routers Layer 2—WAN Access Configuration Guide-Release 7607
