HomeSupportConfigure & DeployConfiguration GuidesH3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Configuration Guide-6W10201-Fundamentals Configuration Guide
15-License management
15-License management 91.11 KB
Managing licenses
About licenses
License-based features require a license to run on your device.
License types
Licenses include trial licenses and formal licenses. Purchase and install a formal license for a license-based feature before its trial license expires, so that the feature is still usable.
Licenses for different device types
You must purchase a license key for each IRF member device. To license an IRF member device, use the license key and the member's SN and DID to register an activation file and install the activation file on the IRF member device. An IRF member device is licensed even if the device joins another IRF fabric.
Restrictions and guidelines: License management
License operations
Make sure no one else is performing license management tasks on the device you are working with.
Activation file and DID file operations
When you manage DID files or activation files, follow these restrictions and guidelines:
·     Do not open and edit the files to avoid file corruption.
·     Do not modify the names of the files to avoid licensing error.
·     For licensed features to function correctly, do not delete files that are usable or in use in the flash:/license directory. The license management feature uses this directory for license management.
License consistency in an IRF fabric
For licensed features to function correctly in an IRF fabric, make sure all IRF member devices are installed with the same licenses.
License management tasks at a glance
To manage licenses, perform the following tasks:
1.     Identifying the license storage
2.     (Optional.) Compressing the license storage
3.     Obtaining required information for license register
4.     Registering a license
5.     Installing a license
6.     Managing installed licenses
¡     Uninstalling a license
¡     Transferring a license
¡     Recovering an activation file
To identify the license storage, execute the following command in any view:
display license feature
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
About license storage compression
Compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
This command clears expired licenses and uninstalled licenses. The DID changes each time the license storage is compressed. Licenses generated based on the old DID cannot be installed after the compression.
1.     Back up the Uninstall keys of uninstalled licenses.
When you uninstall an unexpired formal license, an Uninstall key is created. The Uninstall key is required for transferring the license.
2.     Make sure all licenses generated based on the old DID have been installed.
3.     Enter system view.
4.     Compress the license storage.
license compress slot slot-number
1.     (Optional.) Identify features to be licensed by using the display license feature command.
2.     Obtain the following information:
¡     License key, which is obtained by purchasing the license.
¡     SN and DID information, which can be obtained by using the display license device-id command.
3.     If the DID is contained in an .id file, use FTP or TFTP to upload the file to the Web client, such as PC.
If FTP is used to transfer the .id file, use the Binary mode.
If the DID is a string, skip this step.
4.     Back up the license key, SN, and DID information in case of loss.
About registering a license
License registration has the following procedures:
·     Registering licenses for the first time—Register a license for a device that has not previously been registered.
·     Registering upgrade licenses—Register add-ons, add-on features, or a time extension.
If a device has registered a license, the device is bound to the license regardless of the license status (expired, uninstalled, or transferred). The next time you register a new license for the device, always use the procedure of registering upgrade licenses.
If you do not know which registration procedure should be used, select registering licenses for the first time. Enter the required information, and the website will display messages for the correct registration choice.
If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors, contact H3C Support.
1.     Visit the H3C website at http://www.h3c.com/en/Support/Online_Help/License_Service/.
2.     Select Register the First Time.
3.     Enter the authorization serial number in the Input the license key field and click Submit.
A dialog box opens, displaying product categories matching the license key.
4.     In the dialog box, select a product category and click OK.
¡     Always select LSW_S6800 Series as the product category for the S6800, S6860, and S6861 switch series.
¡     Select LSW_S6820 Series as the product category for the S6820 switch series.
5.     Enter the device S/N.
6.     Upload the DID file.
7.     Enter the required contact information and verify code, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
8.     Download the activation file to the PC.
A copy of the activation file will also be sent to the email address that you enter in the contact information.
2.     Select Register Upgrade Licenses.
6.     Upload the DID file and click Submit.
When installing a license, the system automatically searches the storage media for a matching feature package. When a match is found, it stops searching and installs the package.
Installing an activation file
2.     Install an activation file.
license activation-file install file-name slot slot-number
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Restrictions and guidelines for license uninstallation
Back up the Uninstall key of a license properly for the license's next use.
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
Uninstalling an activation file
2.     Uninstall an activation file.
license activation-file uninstall file-name slot slot-number
Only unexpired activation files can be uninstalled.
About license transfer
You can transfer a license from one device to another if the license has not expired.
1.     Log in to the source device, and uninstall the license to obtain the uninstallation information. For more information, see "Uninstalling a license."
2.     Obtain the Uninstall key of the license by using the display license command.
3.     Access the target device and obtain SN and DID information. For more information, see "Obtaining required information for license register."
4.     Register a license for the target device. For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
5.     Install the new license on the target device. For more information, see "Installing a license."
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
1.     Use the copy command to copy the backup activation file to directory flash:/license.
2.     Use the display license command to verify that the state of the recovered activation file is In use.
3.     Restart the device if the license state is In use but the licensed feature cannot function correctly.
Display and maintenance commands for license management
Display detailed license information.
display license [ activation-file ] [ slot slot-number ]
Display the SN and DID information.
display license device-id slot slot-number
Display brief feature license information.
