16-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5426P02)-6W10416-Security Configuration Guide
16-Public key management
16-Public key management 126.36 KB
Managing public keys
About public key management
This chapter describes public key management for the following asymmetric key algorithms:
·     Revest-Shamir-Adleman Algorithm (RSA).
·     Digital Signature Algorithm (DSA).
·     Elliptic Curve Digital Signature Algorithm (ECDSA).
Asymmetric key algorithm overview
Asymmetric key algorithms are used by security applications to secure communications between two parties, as shown in Figure 1. Asymmetric key algorithms use two separate keys (one public and one private) for encryption and decryption. Symmetric key algorithms use only one key.
Figure 1 Encryption and decryption
A key owner can distribute the public key in plain text on the network but must keep the private key in privacy. It is mathematically infeasible to calculate the private key even if an attacker knows the algorithm and the public key.
Usage of asymmetric key algorithms
Security applications (such as SSH, SSL, and PKI) use the asymmetric key algorithms for the following purposes:
·     Encryption and decryption—Any public key receiver can use the public key to encrypt information, but only the private key owner can decrypt the information.
·     Digital signature—The key owner uses the private key to digitally sign information to be sent. The receiver decrypts the information with the sender's public key to verify information authenticity.
RSA, DSA, and ECDSA can all perform digital signature, but only RSA can perform encryption and decryption.
Public key management tasks at a glance
To manage public keys, perform the following tasks:
1.     Creating a local key pair
2.     Distributing a local host public key
¡     Exporting a host public key
¡     Displaying a host public key
To enable the peer device to authenticate the local device, you must distribute the local device's public key to the peer device.
3.     Configuring a peer host public key
¡     Importing a peer host public key from a public key file
¡     Entering a peer host public key
To encrypt information sent to a peer device or authenticate the digital signature of the peer device, you must configure the peer device's public key on the local device.
4.     (Optional.) Destroying a local key pair
When you create a local key pair, follow these guidelines:
·     The key algorithm must be the same as required by the security application.
·     When you create an RSA or DSA key pair, enter an appropriate key modulus length at the prompt. The longer the key modulus length, the higher the security, and the longer the key generation time.
When you create an ECDSA key pair, choose the appropriate elliptic curve. The elliptic curve determines the ECDSA key length. The longer the key length, the higher the security, and the longer the key generation time.
See Table 1 for more information about key modulus lengths and key lengths.
·     If you do not assign the key pair a name, the system assigns the default name to the key pair and marks the key pair as default. You can also assign the default name to another key pair, but the system does not mark the key pair as default. The key pair name must be unique among all manually named key pairs that use the same key algorithm. If a name conflict occurs, the system asks whether you want to overwrite the existing key pair.
·     The key pairs are automatically saved and can survive system reboots.
Table 1 A comparison of different types of asymmetric key algorithms
Generated key pairs
Modulus/key length
RSA
·     One host key pair, if you specify a key pair name.
·     One server key pair and one host key pair, if you do not specify a key pair name.
Both key pairs use their default names.
Only SSH 1.5 uses the RSA server key pair.
Key modulus length: 512 to 2048 bits.
Default: 1024 bits.
To ensure security, use a minimum of 768 bits.
DSA
One host key pair.
Default: 1024 bits.
ECDSA
One host key pair.
Key length: 192, 256, 384, or 521 bits.
2.     Create a local key pair.
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
About distribution of local host public keys
You must distribute a local host public key to a peer device so the peer device can perform the following operations:
·     Use the public key to encrypt information sent to the local device.
·     Authenticate the digital signature signed by the local device.
To distribute a local host public key, you must first export or display the key.
·     Export a host public key:
¡     Export a host public key to a file.
¡     Export a host public key to the monitor screen, and then save it to a file.
After the key is exported to a file, transfer the file to the peer device. On the peer device, import the key from the file.
·     Display a host public key.
After the key is displayed, record the key, for example, copy it to an unformatted file. On the peer device, you must literally enter the key.
When you export a host public key, follow these restrictions and guidelines:
·     If you specify a file name in the command, the command exports the key to the specified file.
·     If you do not specify a file name, the command exports the key to the monitor screen. You must manually save the exported key to a file.
2.     Export a local host public key.
¡     Export an RSA host public key:
public-key local export rsa [ name key-name ] { openssh | ssh1 | ssh2 } [ filename ]
¡     Export an ECDSA host public key.
public-key local export ecdsa [ name key-name ] { openssh | ssh2 } [ filename ]
¡     Export a DSA host public key.
public-key local export dsa [ name key-name ] { openssh | ssh2 } [ filename ]
Perform the following tasks in any view:
·     Display local RSA public keys.
display public-key local rsa public [ name key-name ]
Do not distribute the RSA server public key serverkey (default) to a peer device.
·     Display local ECDSA public keys.
display public-key local ecdsa public [ name key-name ]
·     Display local DSA public keys.
display public-key local dsa public [ name key-name ]
About peer host public key configuration
You can configure the peer host public key by using the following methods:
·     Import the peer host public key from a public key file (recommended).
·     Manually enter (type or copy) the peer host public key.
For information about how to obtain the host public key of a device, see "Distributing a local host public key."
Restrictions and guidelines for peer host public key configuration
When you configure a peer host public key, follow these restrictions and guidelines:
·     When you manually enter the peer host public key, make sure the entered key is in the correct format. To obtain the peer host public key in the correct format, use the display public-key local public command to display the public key on the peer device and record the key. The format of the public key displayed in any other way might be incorrect. If the key is not in the correct format, the system discards the key and displays an error message.
·     Always import rather than enter the peer host public key if you are not sure whether the device supports the format of the recorded peer host public key.
Before you perform this task, make sure you have exported the host public key to a file on the peer device and obtained the file from the peer device. For information about exporting a host public key, see "Exporting a host public key."
After you import the key, the system automatically converts the imported public key to a string in the Public Key Cryptography Standards (PKCS) format.
2.     Import a peer host public key from a public key file.
public-key peer keyname import sshkey filename
By default, no peer host public keys exist.
Before you perform this task, make sure you have displayed the key on the peer device and recorded the key. For information about displaying a host public key, see "Displaying a host public key."
2.     Specify a name for the peer host public key and enter public key view.
3.     Type or copy the key.
You can use spaces and carriage returns, but the system does not save them.
4.     Exit public key view.
peer-public-key end
When you exit public key view, the system automatically saves the peer host public key.
To ensure security, destroy the local key pair and generate a new key pair in any of the following situations:
·     The local key has leaked. An intrusion event might occur.
·     The storage media of the device is replaced.
·     The local certificate has expired. For more information about local certificates, see "Configuring PKI."
2.     Destroy a local key pair.
public-key local destroy{ dsa | ecdsa | rsa } [ name key-name ]
Display and maintenance commands for public keys
Display local public keys.
display public-key local { dsa | ecdsa | rsa } public [ name key-name ]
Display peer host public keys.
display public-key peer [ brief | name publickey-name ]
Examples of public key management
Example: Entering a peer host public key
As shown in Figure 2, to prevent illegal access, the AC authenticates the device through a digital signature. Before configuring authentication parameters on the AC, use the following procedure to configure the public key of the device on the AC:
·     Create RSA key pairs on the device and export the RSA host public key to a file.
·     Manually specify the RSA host public key of the device on the AC.
Figure 2 Network diagram
1.     Configure the device:
# Create local RSA key pairs with the default names on the device, and use the default key modulus length (1024 bits).
[Device] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Display all local RSA public keys.
[Device] display public-key local rsa public
Key name: hostkey (default)
Key type: RSA
Time when key pair created: 16:48:31 2015/05/12
Key code:
   30819F300D06092A864886F70D010101050003818D0030818902818100DA3B90F59237347B
   8D41B58F8143512880139EC9111BFD31EB84B6B7C7A1470027AC8F04A827B30C2CAF79242E
   45FDFF51A9C7E917DB818D54CB7AEF538AB261557524A7441D288EC54A5D31EFAE4F681257
   6D7796490AF87A8C78F4A7E31F0793D8BA06FB95D54EBB9F94EB1F2D561BF66EA27DFD4788
   CB47440AF6BB25ACA50203010001
Key name: serverkey (default)
Key type: RSA
Key code:
   307C300D06092A864886F70D0101010500036B003068026100C9451A80F7F0A9BA1A90C7BC
   1C02522D194A2B19F19A75D9EF02219068BD7FD90FCC2AF3634EEB9FA060478DD0A1A49ACE
   E1362A4371549ECD85BA04DEE4D6BB8BE53B6AED7F1401EE88733CA3C4CED391BAE633028A
   AC41C80A15953FB22AA30203010001
2.     Configure the AC:
# Enter the host public key of the device in public key view. The key must be literally the same as displayed on the device.
<AC> system-view
[AC] public-key peer device
Enter public key view. Return to system view with "peer-public-key end" command.
[AC-pkey-public-key-device]30819F300D06092A864886F70D010101050003818D003081890
[AC-pkey-public-key-device]8D41B58F8143512880139EC9111BFD31EB84B6B7C7A1470027A
[AC-public-key-device]45FDFF51A9C7E917DB818D54CB7AEF538AB261557524A7441D2
[AC-pkey-public-key-device]6D7796490AF87A8C78F4A7E31F0793D8BA06FB95D54EBB9F94E
[AC-pkey-public-key-device]CB47440AF6BB25ACA50203010001
# Save the public key and return to system view.
[AC-pkey-public-key-device] peer-public-key end
# Verify that the peer host public key configured on the AC is the same as the key displayed on the device.
[AC] display public-key peer name device
Key name: device
Key type: RSA
Key modulus: 1024
Key code:
Example: Importing a public key from a public key file
As shown in Figure 3, the AC authenticates the device through a digital signature. Before configuring authentication parameters on the AC, use the following procedure to configure the public key of the device on the AC:
·     Import the RSA host public key of the device from the public key file to the AC.
Figure 3 Network diagram
# Create local RSA key pairs with default names on the device, and use the default modulus length (1024 bits).
Generating Keys...
Key type: RSA
Key code:
Key type: RSA
Key code:
# Export the RSA host public key to file device.pub.
[Device] public-key local export rsa ssh2 device.pub
[Device] quit
# Enable the FTP server function, create an FTP user with username ftp and password 123, and configure the FTP user role as network-admin.
[Device] ftp server enable
[Device] local-user ftp
[Device-luser-manage-ftp] password simple 123
[Device-luser-manage-ftp] service-type ftp
[Device-luser-manage-ftp] authorization-attribute user-role network-admin
[Device-luser-manage-ftp] quit
# Use FTP in binary mode to get public key file device.pub from the device.
<AC> ftp 10.1.1.1
Connected to 10.1.1.1 (10.1.1.1).
220 FTP service ready.
User (10.1.1.1:(none)): ftp
331 Password required for ftp.
Password:
230 User logged in.
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> binary
200 TYPE is now 8-bit binary
ftp> get device.pub
227 Entering Passive Mode (10,1,1,1,118,252)
150 Accepted data connection
226 File successfully transferred
301 bytes received in 0.003 seconds (98.0 kbyte/s)
ftp> quit
221-Goodbye. You uploaded 0 and downloaded 1 kbytes.
221 Logout.
# Import the host public key from key file device.pub.
<AC> system-view
[AC] public-key peer device import sshkey device.pub
Key name: device
Key type: RSA
Key modulus: 1024
Key code:
