16-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10416-Security Command Reference
22-Protocol packet rate limit commands
22-Protocol packet rate limit commands 104.10 KB
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support parameters or commands that are available only in IRF mode.
anti-attack enable
Use anti-attack enable to enable packet rate limit.
Use undo anti-attack enable to disable packet rate limit.
In standalone mode:
anti-attack enable
In IRF mode:
anti-attack enable [ slot slot-number ]
undo anti-attack enable [ slot slot-number ]
Packet rate limit is disabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables packet rate limit for all member devices. (In IRF mode.)
To implement packet rate limit for a protocol, you must complete the following tasks:
·     Execute the anti-attack enable command to enable packet rate limit.
·     Execute the anti-attack protocol enable command to enable packet rate limit for the protocol.
# (In standalone mode.) Enable packet rate limit.
[Sysname] anti-attack enable
# (In IRF mode.) Enable packet rate limit for a slot.
[Sysname] anti-attack enable slot 1
Use anti-attack protocol enable to enable packet rate limit for protocols.
Use undo anti-attack protocol enable to disable packet rate limit for protocols.
In standalone mode:
anti-attack protocol { all | protocol } enable
undo anti-attack protocol { all | protocol } enable
In IRF mode:
anti-attack protocol { all | protocol } enable [ slot slot-number ]
undo anti-attack protocol { all | protocol } enable [ slot slot-number ]
Packet rate limit is disabled for all protocols.
all: Specifies all protocols.
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. Supported protocol values are shown in Table 1.
Table 1 Supported protocols
Protocol value
acsei
ACSEI protocol packets
arp
ARP protocol packets
capwap_ctrl
CAPWAP control packets
capwap_data
CAPWAP data packets
dhcp
DHCP protocol packets
dot11_action
802.11 ACK packets
dot11_assoc
802.11 association request packets
dot11_auth
802.11 authentication packets
dot11_ctrl
Other types of 802.11 protocol packets
dot11_deauth
802.11 deauthentication packets
dot11_disassoc
802.11 disassociation request packets
dot11_null
802.11 null data packets
dot11_reassoc
802.11 reassociation request packets
dot1x
802.1X authentication packets
ethernet
Packets that are not identified as packets of specific protocols
http
HTTP protocol packets
iactp
IACTP protocol packets
icmp
ICMP protocol packets
icmpv6_nd
ICMPv6 neighbor discovery protocol packets
icmpv6_other
ICMPv6 protocol packets except for neighbor discovery protocol packets
igmp
IGMP protocol packets
ip
IPv4 protocol packets
ipv6
IPv6 protocol packets
ntp
NTP protocol packets
portal_syn
Portal redirect packets
radius
RADIUS protocol packets
snmp
SNMP protocol packets
tcp
TCP protocol packets
telnet
Telnet protocol packets
udp
UDP protocol packets
vrrp
VRRP protocol packets
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables the feature for all member devices. (In IRF mode.)
# (In standalone mode.) Enable packet rate limit for ARP.
[Sysname] anti-attack protocol arp enable
# (In IRF mode.) Enable packet rate limit for ARP on a slot.
[Sysname] anti-attack protocol arp enable slot 1
anti-attack enable
anti-attack protocol flow-threshold
Use anti-attack protocol flow-threshold to enable flow-based packet rate limit for a protocol and set the maximum transmission rate per flow.
Use undo anti-attack protocol flow-threshold to disable flow-based packet rate limit for a protocol.
In standalone mode:
anti-attack protocol protocol flow-threshold flow-rate-limit
undo anti-attack protocol protocol flow-threshold
In IRF mode:
anti-attack protocol protocol flow-threshold flow-rate-limit [ slot slot-number ]
undo anti-attack protocol protocol flow-threshold [ slot slot-number ]
Flow-based packet rate limit is disabled for all protocols.
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. For information about supported protocol values, see Table 1.
flow-rate-limit: Specifies the maximum transmission rate per flow for the protocol in packets per second. The value range is 0 to 102400.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables flow-based packet rate limit and sets the threshold for all member devices. (In IRF mode.)
The device identifies flows of a protocol by source IP or MAC address. Protocol packets that are sourced from the same IP address or MAC address belong to the same flow.
You can configure both protocol-based and flow-based protocol packet rate limit for the same protocol. The device first performs flow-based protocol packet rate limit and then performs protocol-based packet rate limit. Excessive protocol packets are dropped.
# (In standalone mode.) Enable flow-based packet rate limit for ARP and set the maximum transmission rate per flow to 50 packets per second.
[Sysname] anti-attack protocol arp flow-threshold 50
# (In IRF mode.) Enable flow-based packet rate limit for ARP and set the maximum transmission rate per flow to 50 packets per second on a slot.
[Sysname] anti-attack protocol arp flow-threshold 50 slot 1
anti-attack protocol priority
Use anti-attack protocol priority to set the packet process priority for a protocol.
Use undo anti-attack protocol priority to restore the default.
In standalone mode:
anti-attack protocol protocol priority priority
undo anti-attack protocol protocol priority
In IRF mode:
anti-attack protocol protocol priority priority [ slot slot-number ]
undo anti-attack protocol protocol priority [ slot slot-number ]
The default settings vary by device model. To display the default setting for a protocol, execute the undo anti-attack protocol priority and display anti-attack protocol commands in turn.
priority: Specifies the packet process priority for the protocol, in the range of 0 to 4. A smaller value represents a higher priority.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the setting applies to all member devices. (In IRF mode.)
When the maximum transmission rate is reached, the device determines packets to be dropped by priority. Packets of the lowest priority are dropped first.
# (In standalone mode.) Set the packet process priority to 0 for ARP.
[Sysname] anti-attack protocol arp priority 0
# (In IRF mode.) Set the packet process priority to 0 for ARP on a slot.
[Sysname] anti-attack protocol arp priority 0 slot 1
anti-attack protocol threshold
Use anti-attack protocol threshold to set the maximum transmission rate for a protocol.
Use undo anti-attack protocol threshold to restore the default for a protocol.
In standalone mode:
anti-attack protocol protocol threshold rate-limit
undo anti-attack protocol protocol threshold
In IRF mode:
anti-attack protocol protocol threshold rate-limit [ slot slot-number ]
undo anti-attack protocol protocol threshold [ slot slot-number ]
The default settings vary by device model. To display the default setting for a protocol, execute the undo anti-attack protocol threshold and display anti-attack protocol commands in turn.
rate-limit: Specifies the maximum transmission rate for the protocol in packets per second. The value range is 0 to 102400.
Excessive packets are dropped.
# (In standalone mode.) Set the maximum transmission rate to 1000 packets per second for ARP.
[Sysname] anti-attack protocol arp threshold 1000
# (In IRF mode.) Set the maximum transmission rate to 1000 packets per second for ARP on a slot.
[Sysname] anti-attack protocol arp threshold 1000 slot 1
Use display anti-attack protocol to display packet rate limit information about protocols.
In standalone mode:
display anti-attack protocol [ protocol ]
In IRF mode:
display anti-attack protocol [ protocol ] [ slot slot-number ]
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. If you do not specify a protocol, the command displays information about all protocols. For information about supported protocol values, see Table 1.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays packet rate limit information for all member devices. (In IRF mode.)
# (In standalone mode.) Display packet rate limit information about all protocols. Only protocol-based protocol packet rate limit is enabled in this example.
<Sysname> display anti-attack protocol
                        Anti-attack statistics
Protocol       anti-attack Priority Limit(pps)  Rate(pps) Passed    Dropped
dot1x          enable      1        1024        0         0         0
dhcp           enable      2        2000        0         0         0
igmp           enable      2        1024        0         0         0
ntp            enable      2        256         0         0         0
arp            enable      1        1024        0         17907     0
snmp           enable      0        1024        0         0         0
telnet         enable      0        100         0         0         0
icmp           enable      0        20          0         0         0
icmpv6_nd      enable      0        1024        0         0         0
icmpv6_other   enable      0        1024        0         0         0
iactp          enable      1        2560        0         0         0
acsei          enable      2        128         0         0         0
http           enable      1        1024        0         0         0
https          enable      1        1024        0         0         0
openflow       enable      1        1024        0         0         0
portal         enable      1        1024        0         0         0
udp            enable      2        20          0         0         0
tcp            enable      2        1           0         0         0
ip             enable      4        2560        0         0         0
ipv6           enable      2        128         0         0         0
ethernet       enable      2        128         0         0         0
radius         enable      1        2048        0         0         0
vrrp           enable      1        2048        0         0         0
capwap_ctrl    enable      1        2048        0         0         0
capwap_data    enable      1        2048        0         0         0
dot11_auth     enable      1        256         0         0         0
dot11_assoc    enable      1        256         0         0         0
dot11_reassoc  enable      1        256         0         0         0
dot11_null     enable      1        1024        0         0         0
dot11_disassoc enable      1        256         0         0         0
dot11_deauth   enable      1        256         0         0         0
dot11_action   enable      1        256         0         0         0
dot11_ctrl     enable      1        512         0         0         0
portal_syn     enable      1        1024        0         0         0
lacp           enable      1        256         0         0         0
# (In IRF mode.) Display packet rate limit information about all protocols on a slot. Only protocol-based protocol packet rate limit is enabled in this example.
<Sysname> display anti-attack protocol slot 1
Slot 1:
Anti-attack
Status of protocol-based packet rate limit for the protocol:
·     Enabled—The feature is enabled.
·     Disabled—The feature is disabled.
Priority
Packet processing priority of the protocol. A smaller value represents a higher priority.
Limit(pps)
Maximum packet transmission rate of the protocol, in packets per second.
Rate(pps)
Current packet transmission rate of the protocol, in packets per second.
Passed
Number of protocol packets sent to the CPU.
Dropped
Number of dropped protocol packets.
# (In standalone mode.) Display packet rate limit information about ARP. Both protocol-based protocol packet rate limit and flow-based protocol packet rate limit are enabled in this example.
<Sysname> display anti-attack protocol arp
FlowSource              FlowLimit(pps)    FlowRate(pps)   Passed    Dropped
00e0-fc12-7723          1000              0               2         0
0011-e212-8801          1000              0               17905     0
# (In IRF mode.) Display packet rate limit information about ARP on a slot. Both protocol-based protocol packet rate limit and flow-based protocol packet rate limit are enabled in this example.
<Sysname> display anti-attack protocol arp slot 1
Slot 1:
FlowSource
Source IP or MAC address of the flow.
FlowLimit(pps)
Maximum transmission rate for the flow, in packets per second.
FlowRate(pps)
Current transmission rate of the flow, in packets per second.
